MOAB: Mesh Oriented datABase
(version 5.2.1)
Classes | |
class | MBMesquite::MsqError |
Used to hold the error state and return it to the application. More... | |
class | MBMesquite::MsqError::Trace |
One line of stack trace data. More... | |
class | MBMesquite::MsqError::Setter |
class | MBMesquite::MsqPrintError |
Utility class for printing error data - used in Mesquite tests. More... | |
Namespaces | |
namespace | MBMesquite |
Implements the NonSmoothDescent class member functions. | |
Defines | |
#define | MSQ_CHKERR(err) ( err.error() && err.push( MSQ_FUNCTION, __FILE__, __LINE__ ) ) |
Mesquite's Error Checking macro. | |
#define | MSQ_ERRRTN(err) if( MSQ_CHKERR( err ) ) return |
If passed error is true, return from a void function. | |
#define | MSQ_ERRZERO(err) if( MSQ_CHKERR( err ) ) return 0 |
Return zero/NULL on error. | |
#define | MSQ_ERRFALSE(err) if( MSQ_CHKERR( err ) ) return false |
Return false on error. | |
#define | MSQ_SETERR(err) MBMesquite::MsqError::setter( err, MSQ_FUNCTION, __FILE__, __LINE__ ).set |
Macro to set error - use err.clear() to clear. | |
Functions | |
std::ostream & | MBMesquite::operator<< (std::ostream &, const MsqError &) |
Print message and stack trace. | |
std::ostream & | MBMesquite::operator<< (std::ostream &, const MsqError::Trace &) |
Print MsqError::Trace. |
