MOAB: Mesh Oriented datABase
(version 5.2.1)
#include <NonSmoothDescent.hpp>
Definition at line 55 of file NonSmoothDescent.hpp.
enum MBMesquite::NonSmoothDescent::Direction [private] |
Definition at line 165 of file NonSmoothDescent.hpp.
enum MBMesquite::NonSmoothDescent::OptStatus [private] |
MSQ_NO_STATUS | |
MSQ_STEP_ACCEPTED | |
MSQ_IMP_TOO_SMALL | |
MSQ_FLAT_NO_IMP | |
MSQ_STEP_TOO_SMALL | |
MSQ_EQUILIBRIUM | |
MSQ_ZERO_SEARCH | |
MSQ_MAX_ITER_EXCEEDED |
Definition at line 139 of file NonSmoothDescent.hpp.
enum MBMesquite::NonSmoothDescent::Status [private] |
Definition at line 151 of file NonSmoothDescent.hpp.
Definition at line 56 of file NonSmoothDescent.cpp.
References MSQ_DBGOUT.
: currentQM( qm ) { MSQ_DBGOUT( 1 ) << "- Executed NonSmoothDescent::NonSmoothDescent()\n"; }
virtual MESQUITE_EXPORT MBMesquite::NonSmoothDescent::~NonSmoothDescent | ( | ) | [inline, virtual] |
Definition at line 61 of file NonSmoothDescent.hpp.
MBMesquite::NonSmoothDescent::NonSmoothDescent | ( | const NonSmoothDescent & | pd | ) | [private] |
bool MBMesquite::NonSmoothDescent::check_equilibrium | ( | OptStatus & | opt_status, |
MsqError & | err | ||
) | [private] |
Definition at line 1209 of file NonSmoothDescent.cpp.
References MBMesquite::NonSmoothDescent::ActiveSet::active_ind, convex_hull_test(), get_active_directions(), MBMesquite::length(), mActive, mGradient, MSQ_EQUILIBRIUM, MSQ_ERRZERO, MSQ_PRINT, and qmHandles.
Referenced by minmax_opt().
{ std::vector< Vector3D > dir; // TODO - this subroutine is no longer clear to me... is it still // appropriate for quads and hexes? I think it might be in 2D, but // 3D is less clear. Is there a more general algorithm to use? // ask Todd/check in numerical optimization bool equil = false; const size_t num_active = mActive.active_ind.size(); ; if( num_active == qmHandles.size() ) { equil = true; status = MSQ_EQUILIBRIUM; MSQ_PRINT( 3 )( "All the function values are in the active set\n" ); } /* set up the active mGradient directions */ this->get_active_directions( mGradient, dir, err ); MSQ_ERRZERO( err ); /* normalize the active directions */ for( size_t j = 0; j < num_active; j++ ) dir[j] /= dir[j].length(); equil = this->convex_hull_test( dir, err ); if( equil ) status = MSQ_EQUILIBRIUM; return equil; }
bool MBMesquite::NonSmoothDescent::check_vector_dots | ( | const std::vector< Vector3D > & | vec, |
const Vector3D & | normal, | ||
) | [private] |
Definition at line 1101 of file NonSmoothDescent.cpp.
References moab::dot(), and MBMesquite::EPSILON.
Referenced by convex_hull_test().
{ double test_dot = vec[0] % normal; unsigned ind = 1; while( ( fabs( test_dot ) < EPSILON ) && ( ind < vec.size() ) ) { test_dot = vec[ind] % normal; ind++; } for( unsigned i = ind; i < vec.size(); i++ ) { double dot = vec[i] % normal; if( ( ( dot > 0 && test_dot < 0 ) || ( dot < 0 && test_dot > 0 ) ) && ( fabs( dot ) > EPSILON ) ) { return true; } } return false; }
void MBMesquite::NonSmoothDescent::cleanup | ( | ) | [protected, virtual] |
Implements MBMesquite::VertexMover.
Definition at line 134 of file NonSmoothDescent.cpp.
{ MSQ_DBGOUT( 1 ) << "- Executing NonSmoothDescent::cleanup()\n"; MSQ_DBGOUT( 1 ) << "- Done with NonSmoothDescent::cleanup()\n"; }
void MBMesquite::NonSmoothDescent::compute_alpha | ( | MsqError & | err | ) | [private] |
Definition at line 1532 of file NonSmoothDescent.cpp.
References moab::E, mAlpha, maxAlpha, mFunction, mGS, minStepSize, MSQ_PRINT, mSteepest, and qmHandles.
{ double steepest_function; double steepest_grad; double alpha_i; double min_positive_value = HUGE_VAL; // FUNCTION_TIMER_START("Compute Alpha"); MSQ_PRINT( 2 )( "In compute alpha\n" ); mAlpha = HUGE_VAL; steepest_function = mFunction[mSteepest]; steepest_grad = mGS[mSteepest]; for( size_t i = 0; i < qmHandles.size(); i++ ) { /* if it's not active */ if( i != mSteepest ) { alpha_i = steepest_function - mFunction[i]; if( fabs( mGS[mSteepest] - mGS[i] ) > 1E-13 ) { /* compute line intersection */ alpha_i = alpha_i / ( steepest_grad - mGS[i] ); } else { /* the lines don't intersect - it's not under consideration*/ alpha_i = 0; } if( ( alpha_i > minStepSize ) && ( fabs( alpha_i ) < fabs( mAlpha ) ) ) { mAlpha = fabs( alpha_i ); MSQ_PRINT( 3 )( "Setting alpha %lu %g\n", (unsigned long)i, alpha_i ); } if( ( alpha_i > 0 ) && ( alpha_i < min_positive_value ) ) { min_positive_value = alpha_i; } } } if( ( mAlpha == HUGE_VAL ) && ( min_positive_value != HUGE_VAL ) ) { mAlpha = min_positive_value; } /* if it never gets set, set it to the default */ if( mAlpha == HUGE_VAL ) { mAlpha = maxAlpha; MSQ_PRINT( 3 )( "Setting alpha to the maximum step length\n" ); } MSQ_PRINT( 3 )( " The initial step size: %f\n", mAlpha ); // FUNCTION_TIMER_END(); }
bool MBMesquite::NonSmoothDescent::compute_function | ( | PatchData * | pd, |
std::vector< double > & | function, | ||
) | [private] |
Definition at line 896 of file NonSmoothDescent.cpp.
References currentQM, MBMesquite::QualityMetric::evaluate(), MSQ_ERRZERO, and qmHandles.
Referenced by compute_gradient(), optimize_vertex_positions(), and step_acceptance().
{ // NEED 1.0/FUNCTION WHICH IS ONLY TRUE OF CONDITION NUMBER func.resize( qmHandles.size() ); bool valid_bool = true; for( size_t i = 0; i < qmHandles.size(); i++ ) { valid_bool = valid_bool && currentQM->evaluate( *patch_data, qmHandles[i], func[i], err ); MSQ_ERRZERO( err ); } return valid_bool; }
bool MBMesquite::NonSmoothDescent::compute_gradient | ( | PatchData * | pd, |
std::vector< Vector3D > & | grad_out, | ||
) | [private] |
Definition at line 911 of file NonSmoothDescent.cpp.
References compute_function(), currentQM, MBMesquite::QualityMetric::evaluate_with_gradient(), freeVertexIndex, mGradient, MBMesquite::PatchData::move_vertex(), MSQ_DBGOUT, MSQ_ERRZERO, qmHandles, MBMesquite::PatchData::set_vertex_coordinates(), tmpGrad, tmpIdx, value(), and MBMesquite::PatchData::vertex_by_index().
{ MSQ_DBGOUT( 2 ) << "Computing Gradient\n"; bool valid = true; #ifdef NUMERICAL_GRADIENT const double delta = 10e-6; std::vector< double > func( qmHandles.size() ), fdelta( qmHandles.size() ); valid = this->compute_function( patch_data, func, err ); MSQ_ERRZERO( err ); /* gradient in the x, y, z direction */ for( int j = 0; j < 3; j++ ) { // perturb the coordinates of the free vertex in the j direction by delta Vector3D delta_3( 0, 0, 0 ); Vector3D orig_pos = patch_data->vertex_by_index( freeVertexIndex ); delta_3[j] = delta; patch_data->move_vertex( delta_3, freeVertexIndex, err ); // compute the function at the perturbed point location valid = valid && this->compute_function( patch_data, fdelta, err ); MSQ_ERRZERO( err ); // compute the numerical gradient for( size_t i = 0; i < qmHandles.size(); i++ ) { mGradient[i][j] = ( fdelta[i] - func[i] ) / delta; // MSQ_DEBUG_ACTION(3,{fprintf(stdout," Gradient // value[%d][%d]=%g\n",i,j,mGradient[i][j]);}); } // put the coordinates back where they belong patch_data->set_vertex_coordinates( orig_pos, freeVertexIndex, err ); } #else double value; gradient_out.resize( qmHandles.size() ); for( size_t i = 0; i < qmHandles.size(); i++ ) { valid = valid && currentQM->evaluate_with_gradient( *patch_data, qmHandles[i], value, tmpIdx, tmpGrad, err ); MSQ_ERRZERO( err ); assert( tmpIdx.size() == 1 && tmpIdx[0] == freeVertexIndex ); gradient_out[i] = tmpGrad[0]; } #endif return valid; }
bool MBMesquite::NonSmoothDescent::convex_hull_test | ( | const std::vector< Vector3D > & | vec, |
) | [private] |
Definition at line 1121 of file NonSmoothDescent.cpp.
References check_vector_dots(), find_plane_normal(), find_plane_points(), MBMesquite::MsqError::INVALID_STATE, MSQ_CHECK_X_COORD_DIRECTION, MSQ_CHECK_Y_COORD_DIRECTION, MSQ_CHECK_Z_COORD_DIRECTION, MSQ_EQUIL, MSQ_HULL_TEST_ERROR, MSQ_NO_EQUIL, MSQ_PRINT, MSQ_SETERR, MSQ_THREE_PT_PLANE, MSQ_TWO_PT_PLANE, MSQ_XDIR, MSQ_YDIR, and MSQ_ZDIR.
Referenced by check_equilibrium().
{ // int ierr; bool equil = false; Direction dir_done = MSQ_ZDIR; Status status = MSQ_CHECK_Z_COORD_DIRECTION; Vector3D pt1, pt2, pt3, normal; /* tries to determine equilibrium for the 3D case */ if( vec.size() <= 2 ) status = MSQ_NO_EQUIL; while( ( status != MSQ_EQUIL ) && ( status != MSQ_NO_EQUIL ) && ( status != MSQ_HULL_TEST_ERROR ) ) { if( status == MSQ_CHECK_Z_COORD_DIRECTION ) { this->find_plane_points( MSQ_ZDIR, MSQ_YDIR, vec, pt1, pt2, pt3, status, err ); dir_done = MSQ_ZDIR; } if( status == MSQ_CHECK_Y_COORD_DIRECTION ) { this->find_plane_points( MSQ_YDIR, MSQ_XDIR, vec, pt1, pt2, pt3, status, err ); dir_done = MSQ_YDIR; } if( status == MSQ_CHECK_X_COORD_DIRECTION ) { this->find_plane_points( MSQ_XDIR, MSQ_ZDIR, vec, pt1, pt2, pt3, status, err ); dir_done = MSQ_XDIR; } if( status == MSQ_TWO_PT_PLANE ) { pt3 = Vector3D( 0, 0, 0 ); } if( ( status == MSQ_TWO_PT_PLANE ) || ( status == MSQ_THREE_PT_PLANE ) ) { this->find_plane_normal( pt1, pt2, pt3, normal, err ); equil = this->check_vector_dots( vec, normal, err ); if( equil ) { switch( dir_done ) { case MSQ_ZDIR: equil = false; status = MSQ_CHECK_Y_COORD_DIRECTION; break; case MSQ_YDIR: equil = false; status = MSQ_CHECK_X_COORD_DIRECTION; break; case MSQ_XDIR: equil = true; status = MSQ_EQUIL; } } else if( equil == 0 ) { status = MSQ_NO_EQUIL; } else { MSQ_SETERR( err )( "equil flag not set to 0 or 1", MsqError::INVALID_STATE ); } } } switch( status ) { case MSQ_NO_EQUIL: MSQ_PRINT( 3 )( "Not an equilibrium point\n" ); equil = false; break; case MSQ_EQUIL: MSQ_PRINT( 3 )( "An equilibrium point\n" ); equil = true; break; default: MSQ_PRINT( 3 )( "Failed to determine equil or not; status = %d\n", status ); } // FUNCTION_TIMER_END(); return ( equil ); }
void MBMesquite::NonSmoothDescent::find_active_set | ( | const std::vector< double > & | function, |
ActiveSet & | active_set | ||
) | [private] |
Definition at line 967 of file NonSmoothDescent.cpp.
References MBMesquite::NonSmoothDescent::ActiveSet::active_ind, MBMesquite::NonSmoothDescent::ActiveSet::add(), MBMesquite::EPSILON, MSQ_DBGOUT, qmHandles, MBMesquite::NonSmoothDescent::ActiveSet::set(), and MBMesquite::NonSmoothDescent::ActiveSet::true_active_value.
Referenced by minmax_opt(), optimize_vertex_positions(), and step_acceptance().
{ // local parameter initialization const double activeEpsilon = .3e-4; // activeEpsilon = .3e-8; double function_val; double active_value0; double temp; // FUNCTION_TIMER_START("Find Active Set"); MSQ_DBGOUT( 2 ) << "\nFinding the active set\n"; /* the first function value is our initial active value */ active_set.set( 0 ); active_set.true_active_value = function[0]; // MSQ_DEBUG_ACTION(3,{fprintf(stdout," function value[0]: %g\n",function[0]);}); /* first sort out the active set... all vals within active_epsilon of largest val */ for( size_t i = 1; i < qmHandles.size(); i++ ) { function_val = function[i]; if( active_set.true_active_value < function_val ) active_set.true_active_value = function_val; active_value0 = function[active_set.active_ind[0]]; temp = fabs( function_val - active_value0 ); // MSQ_DEBUG_ACTION(3,{fprintf(stdout," function value[%d]: %g\n",i,function[i]);}); if( function_val > active_value0 ) { // seek max_i function[i] if( temp >= activeEpsilon ) { active_set.set( i ); // new max } else { active_set.add( i, fabs( function_val - active_value0 ) < EPSILON ); } } else { if( temp < activeEpsilon ) { active_set.add( i, fabs( function_val - active_value0 ) < EPSILON ); } } } }
void MBMesquite::NonSmoothDescent::find_plane_normal | ( | const Vector3D & | pt1, |
const Vector3D & | pt2, | ||
const Vector3D & | pt3, | ||
Vector3D & | cross, | ||
MsqError & | |||
) | [inline, private] |
Definition at line 242 of file NonSmoothDescent.hpp.
References MBMesquite::Vector3D::length().
void MBMesquite::NonSmoothDescent::find_plane_points | ( | Direction | dir1, |
Direction | dir2, | ||
const std::vector< Vector3D > & | vec, | ||
Vector3D & | pt1, | ||
Status & | status, | ||
MsqError & | |||
) | [private] |
Definition at line 140 of file NonSmoothDescent.cpp.
References MBMesquite::CLOCKWISE, MBMesquite::COUNTERCLOCKWISE, MBMesquite::EPSILON, MSQ_CHECK_BOTTOM_UP, MSQ_CHECK_TOP_DOWN, MSQ_CHECK_X_COORD_DIRECTION, MSQ_CHECK_Y_COORD_DIRECTION, MSQ_EQUIL, MSQ_HULL_TEST_ERROR, MSQ_NO_EQUIL, MSQ_PRINT, and MSQ_TWO_PT_PLANE.
{ int i; int num_min, num_max; Rotate rotate = CLOCKWISE; int num_rotated = 0; double pt_1, pt_2; double min, inv_slope; double min_inv_slope = 0.; double max; double max_inv_slope = 0; double inv_origin_slope = 0; const int num_vec = vec.size(); const int auto_ind_size = 50; int auto_ind[auto_ind_size]; std::vector< int > heap_ind; int* ind; if( num_vec <= auto_ind_size ) ind = auto_ind; else { heap_ind.resize( num_vec ); ind = &heap_ind[0]; } status = MSQ_CHECK_BOTTOM_UP; /* find the minimum points in dir1 starting at -1 */ num_min = 0; ind[0] = -1; ind[1] = -1; ind[2] = -1; min = 1.0; for( i = 0; i < num_vec; i++ ) { if( vec[i][dir1] < min ) { min = vec[i][dir1]; ind[0] = i; num_min = 1; } else if( fabs( vec[i][dir1] - min ) < EPSILON ) { ind[num_min++] = i; } } if( min >= 0 ) status = MSQ_NO_EQUIL; if( status != MSQ_NO_EQUIL ) { switch( num_min ) { case 1: /* rotate to find the next point */ pt1 = vec[ind[0]]; pt_1 = pt1[dir1]; pt_2 = pt1[dir2]; if( pt1[dir2] <= 0 ) { rotate = COUNTERCLOCKWISE; max_inv_slope = -HUGE_VAL; } if( pt1[dir2] > 0 ) { rotate = CLOCKWISE; min_inv_slope = HUGE_VAL; } switch( rotate ) { case COUNTERCLOCKWISE: for( i = 0; i < num_vec; i++ ) { if( i != ind[0] ) { inv_slope = ( vec[i][dir2] - pt_2 ) / ( vec[i][dir1] - pt_1 ); if( ( inv_slope > max_inv_slope ) && ( fabs( inv_slope - max_inv_slope ) > EPSILON ) ) { ind[1] = i; max_inv_slope = inv_slope; num_rotated = 1; } else if( fabs( inv_slope - max_inv_slope ) < EPSILON ) { ind[2] = i; num_rotated++; } } } break; case CLOCKWISE: for( i = 0; i < num_vec; i++ ) { if( i != ind[0] ) { inv_slope = ( vec[i][dir2] - pt_2 ) / ( vec[i][dir1] - pt_1 ); if( ( inv_slope < min_inv_slope ) && ( fabs( inv_slope - max_inv_slope ) > EPSILON ) ) { ind[1] = i; min_inv_slope = inv_slope; num_rotated = 1; } else if( fabs( inv_slope - min_inv_slope ) < EPSILON ) { ind[2] = i; num_rotated++; } } } } switch( num_rotated ) { case 0: MSQ_PRINT( 3 )( "No points in the rotation ... odd\n" ); status = MSQ_HULL_TEST_ERROR; break; case 1: MSQ_PRINT( 3 )( "Found a line in the convex hull\n" ); pt2 = vec[ind[1]]; status = MSQ_TWO_PT_PLANE; break; default: MSQ_PRINT( 3 )( "Found 2 or more points in the rotation\n" ); if( fabs( pt_1 ) > EPSILON ) inv_origin_slope = pt_2 / pt_1; switch( rotate ) { case COUNTERCLOCKWISE: if( inv_origin_slope >= max_inv_slope ) status = MSQ_NO_EQUIL; else status = MSQ_CHECK_TOP_DOWN; break; case CLOCKWISE: if( inv_origin_slope <= min_inv_slope ) status = MSQ_NO_EQUIL; else status = MSQ_CHECK_TOP_DOWN; } } break; case 2: /* use these two points to define the plane */ MSQ_PRINT( 3 )( "Found two minimum points to define the plane\n" ); pt1 = vec[ind[0]]; pt2 = vec[ind[1]]; status = MSQ_TWO_PT_PLANE; break; default: /* check to see if all > 0 */ MSQ_PRINT( 3 )( "Found 3 or more points in min plane %f\n", min ); if( vec[ind[0]][dir1] >= 0 ) status = MSQ_NO_EQUIL; else status = MSQ_CHECK_TOP_DOWN; } } /***************************/ /* failed to find any information, checking top/down this coord*/ /***************************/ if( status == MSQ_CHECK_TOP_DOWN ) { /* find the maximum points in dir1 starting at 1 */ num_max = 0; ind[0] = -1; ind[1] = -1; ind[2] = -1; max = -1.0; for( i = 0; i < num_vec; i++ ) { if( vec[i][dir1] > max ) { max = vec[i][dir1]; ind[0] = i; num_max = 1; } else if( fabs( vec[i][dir1] - max ) < EPSILON ) { ind[num_max++] = i; } } if( max <= 0 ) status = MSQ_NO_EQUIL; if( status != MSQ_NO_EQUIL ) { switch( num_max ) { case 1: /* rotate to find the next point */ pt1 = vec[ind[0]]; pt_1 = pt1[dir1]; pt_2 = pt1[dir2]; if( pt1[dir2] < 0 ) { rotate = CLOCKWISE; min_inv_slope = HUGE_VAL; } if( pt1[dir2] >= 0 ) { rotate = COUNTERCLOCKWISE; max_inv_slope = -HUGE_VAL; } switch( rotate ) { case COUNTERCLOCKWISE: for( i = 0; i < num_vec; i++ ) { if( i != ind[0] ) { inv_slope = ( vec[i][dir2] - pt_2 ) / ( vec[i][dir1] - pt_1 ); if( inv_slope > max_inv_slope ) { ind[1] = i; max_inv_slope = inv_slope; num_rotated = 1; } else if( fabs( inv_slope - max_inv_slope ) < EPSILON ) { ind[2] = i; num_rotated++; } } } break; case CLOCKWISE: for( i = 0; i < num_vec; i++ ) { if( i != ind[0] ) { inv_slope = ( vec[i][dir2] - pt_2 ) / ( vec[i][dir1] - pt_1 ); if( inv_slope < min_inv_slope ) { ind[1] = i; min_inv_slope = inv_slope; num_rotated = 1; } else if( fabs( inv_slope - min_inv_slope ) < EPSILON ) { ind[2] = i; num_rotated++; } } } } switch( num_rotated ) { case 0: MSQ_PRINT( 3 )( "No points in the rotation ... odd\n" ); status = MSQ_HULL_TEST_ERROR; break; case 1: MSQ_PRINT( 3 )( "Found a line in the convex hull\n" ); pt2 = vec[ind[1]]; status = MSQ_TWO_PT_PLANE; break; default: MSQ_PRINT( 3 )( "Found 2 or more points in the rotation\n" ); /* check to see if rotation got past origin */ inv_origin_slope = pt_2 / pt_1; switch( rotate ) { case COUNTERCLOCKWISE: if( inv_origin_slope >= max_inv_slope ) status = MSQ_NO_EQUIL; else if( dir1 == 2 ) status = MSQ_CHECK_Y_COORD_DIRECTION; else if( dir1 == 1 ) status = MSQ_CHECK_X_COORD_DIRECTION; else status = MSQ_EQUIL; break; case CLOCKWISE: if( inv_origin_slope <= min_inv_slope ) status = MSQ_NO_EQUIL; else if( dir1 == 2 ) status = MSQ_CHECK_Y_COORD_DIRECTION; else if( dir1 == 1 ) status = MSQ_CHECK_X_COORD_DIRECTION; else status = MSQ_EQUIL; } } break; case 2: /* use these two points to define the plane */ pt1 = vec[ind[0]]; pt2 = vec[ind[1]]; status = MSQ_TWO_PT_PLANE; break; default: /* check to see if all > 0 */ MSQ_PRINT( 3 )( "Found 3 in max plane %f\n", max ); if( vec[ind[0]][dir1] <= 0 ) status = MSQ_NO_EQUIL; else if( dir1 == 2 ) status = MSQ_CHECK_Y_COORD_DIRECTION; else if( dir1 == 1 ) status = MSQ_CHECK_X_COORD_DIRECTION; else status = MSQ_EQUIL; } } } }
void MBMesquite::NonSmoothDescent::form_grammian | ( | const std::vector< Vector3D > & | vec, |
) | [private] |
Definition at line 1199 of file NonSmoothDescent.cpp.
References MBMesquite::NonSmoothDescent::ActiveSet::active_ind, mActive, mG, and MBMesquite::NonSmoothDescent::SymmetricMatrix::resize().
Referenced by search_direction().
{ /* form the grammian with the dot products of the gradients */ const size_t num_active = mActive.active_ind.size(); mG.resize( num_active ); for( size_t i = 0; i < num_active; i++ ) for( size_t j = i; j < num_active; j++ ) mG( i, j ) = vec[i] % vec[j]; }
void MBMesquite::NonSmoothDescent::form_PD_grammian | ( | MsqError & | err | ) | [private] |
Definition at line 1339 of file NonSmoothDescent.cpp.
References MBMesquite::NonSmoothDescent::ActiveSet::active_ind, MBMesquite::MsqError::INVALID_STATE, mActive, mG, mPDG, MSQ_SETERR, pdgInd, and singular_test().
{ int i, j, k; int g_ind_1; bool singular = false; const int num_active = mActive.active_ind.size(); /* this assumes the grammian has been formed */ for( i = 0; i < num_active; i++ ) { for( j = i; j < num_active; j++ ) { if( mG( i, j ) == -1 ) { MSQ_SETERR( err )( "Grammian not computed properly", MsqError::INVALID_STATE ); return; } } } /* use the first gradient in the active set */ g_ind_1 = 0; mPDG[0][0] = mG( 0, 0 ); pdgInd[0] = mActive.active_ind[0]; /* test the rest and add them as appropriate */ k = 1; i = 1; while( ( k < 3 ) && ( i < num_active ) ) { mPDG[0][k] = mPDG[k][0] = mG( 0, i ); mPDG[k][k] = mG( i, i ); if( k == 2 ) { /* add the dot product of g1 and g2 */ mPDG[1][k] = mPDG[k][1] = mG( g_ind_1, i ); } this->singular_test( k + 1, mPDG, singular, err ); if( !singular ) { pdgInd[k] = mActive.active_ind[i]; if( k == 1 ) g_ind_1 = i; k++; } i++; } }
void MBMesquite::NonSmoothDescent::form_reduced_matrix | ( | SymmetricMatrix & | P | ) | [private] |
Definition at line 1489 of file NonSmoothDescent.cpp.
References MBMesquite::NonSmoothDescent::ActiveSet::active_ind, mActive, mG, MBMesquite::P, and MBMesquite::NonSmoothDescent::SymmetricMatrix::resize().
{ const size_t P_size = mActive.active_ind.size() - 1; P.resize( P_size ); for( size_t i = 0; i < P_size; i++ ) { P( i, i ) = mG( 0, 0 ) - 2 * mG( 0, i + 1 ) + mG( i + 1, i + 1 ); for( size_t j = i + 1; j < P_size; j++ ) { P( i, j ) = mG( 0, 0 ) - mG( 0, j + 1 ) - mG( i + 1, 0 ) + mG( i + 1, j + 1 ); } } }
void MBMesquite::NonSmoothDescent::get_active_directions | ( | const std::vector< Vector3D > & | gradient, |
std::vector< Vector3D > & | dir, | ||
) | [private] |
Definition at line 1090 of file NonSmoothDescent.cpp.
References MBMesquite::NonSmoothDescent::ActiveSet::active_ind, and mActive.
Referenced by check_equilibrium(), and search_direction().
{ const size_t num_active = mActive.active_ind.size(); dir.resize( num_active ); for( size_t i = 0; i < num_active; i++ ) { dir[i] = pGradient[mActive.active_ind[i]]; } }
void MBMesquite::NonSmoothDescent::get_gradient_projections | ( | const Vector3D & | mSearch, |
) | [private] |
Definition at line 1524 of file NonSmoothDescent.cpp.
References mGradient, mGS, MSQ_PRINT, mSteepest, and qmHandles.
void MBMesquite::NonSmoothDescent::get_min_estimate | ( | double * | final_est, |
) | [private] |
Definition at line 1503 of file NonSmoothDescent.cpp.
References MBMesquite::NonSmoothDescent::ActiveSet::active_ind, MBMesquite::EPSILON, mActive, mAlpha, mGS, and qmHandles.
Referenced by step_acceptance().
{ double est_imp; *final_est = -HUGE_VAL; for( size_t i = 0; i < mActive.active_ind.size(); i++ ) { est_imp = -mAlpha * mGS[mActive.active_ind[i]]; if( est_imp > *final_est ) *final_est = est_imp; } if( *final_est == 0 ) { *final_est = -HUGE_VAL; for( size_t i = 0; i < qmHandles.size(); i++ ) { est_imp = -mAlpha * mGS[i]; if( ( est_imp > *final_est ) && ( fabs( est_imp ) > EPSILON ) ) { *final_est = est_imp; } } } }
std::string MBMesquite::NonSmoothDescent::get_name | ( | ) | const [virtual] |
Get string name for use in diagnostic and status output.
Implements MBMesquite::Instruction.
Definition at line 62 of file NonSmoothDescent.cpp.
{ return "NonSmoothDescent"; }
PatchSet * MBMesquite::NonSmoothDescent::get_patch_set | ( | ) | [virtual] |
Implements MBMesquite::QualityImprover.
Definition at line 67 of file NonSmoothDescent.cpp.
References patchSet.
{ return &patchSet; }
bool MBMesquite::NonSmoothDescent::improvement_check | ( | MsqError & | err | ) | [inline, private] |
Definition at line 251 of file NonSmoothDescent.hpp.
References mActive, MSQ_PRINT, originalValue, and MBMesquite::NonSmoothDescent::ActiveSet::true_active_value.
{ /* check to see that the mesh didn't get worse */ if( originalValue < mActive.true_active_value ) { MSQ_PRINT( 2 ) ( "The local mesh got worse; initial value %f; final value %f\n", originalValue, mActive.true_active_value ); return false; } return true; }
void MBMesquite::NonSmoothDescent::init_max_step_length | ( | PatchData & | pd, |
) | [private] |
Definition at line 1636 of file NonSmoothDescent.cpp.
References MBMesquite::PatchData::get_vertex_array(), MBMesquite::MsqError::INVALID_MESH, MBMesquite::length_squared(), maxAlpha, MSQ_PRINT, MSQ_SETERR, MBMesquite::PatchData::num_elements(), and MBMesquite::PatchData::num_nodes().
Referenced by optimize_vertex_positions().
{ size_t i, j; double max_diff = 0; double diff = 0; MSQ_PRINT( 2 )( "In init_max_step_length\n" ); /* check that the input data is correct */ if( pd.num_elements() == 0 ) { MSQ_SETERR( err )( "Num incident vtx = 0\n", MsqError::INVALID_MESH ); return; } /* find the maximum distance between two incident vertex locations */ const MsqVertex* coords = pd.get_vertex_array( err ); for( i = 0; i < pd.num_nodes() - 1; i++ ) { for( j = i; j < pd.num_nodes(); j++ ) { diff = ( coords[i] - coords[j] ).length_squared(); if( max_diff < diff ) max_diff = diff; } } max_diff = sqrt( max_diff ); if( max_diff == 0 ) { MSQ_SETERR( err ) ( "Maximum distance between incident vertices = 0\n", MsqError::INVALID_MESH ); return; } maxAlpha = max_diff / 100; MSQ_PRINT( 3 )( " Maximum step is %g\n", maxAlpha ); }
void MBMesquite::NonSmoothDescent::init_opt | ( | PatchData & | pd, |
) | [private] |
Definition at line 1598 of file NonSmoothDescent.cpp.
References currentQM, MBMesquite::NonSmoothDescent::SymmetricMatrix::fill(), MBMesquite::QualityMetric::get_evaluations(), mAlpha, maxAlpha, mFunction, mG, mGradient, mGS, mPDG, MSQ_ERRRTN, MSQ_NO_STATUS, MSQ_PRINT, mSteepest, optStatus, originalFunction, pdgInd, prevActiveValues, qmHandles, MBMesquite::NonSmoothDescent::SymmetricMatrix::resize(), and testFunction.
{ qmHandles.clear(); currentQM->get_evaluations( pd, qmHandles, true, err );MSQ_ERRRTN( err ); MSQ_PRINT( 2 )( "\nInitializing Optimization \n" ); /* for the purposes of initialization will be set to zero after */ optStatus = MSQ_NO_STATUS; mSteepest = 0; mAlpha = 0; maxAlpha = 0; MSQ_PRINT( 3 )( " Initialized Constants \n" ); pdgInd[0] = pdgInd[1] = pdgInd[2] = -1; mPDG = Matrix3D( 0.0 ); MSQ_PRINT( 3 )( " Initialized search and PDG \n" ); mFunction.clear(); mFunction.resize( qmHandles.size(), 0.0 ); testFunction.clear(); testFunction.resize( qmHandles.size(), 0.0 ); originalFunction.clear(); originalFunction.resize( qmHandles.size(), 0.0 ); mGradient.clear(); mGradient.resize( qmHandles.size(), Vector3D( 0.0 ) ); mGS.resize( qmHandles.size() ); MSQ_PRINT( 3 )( " Initialized function/gradient \n" ); mG.resize( qmHandles.size() ); mG.fill( -1 ); MSQ_PRINT( 3 )( " Initialized G\n" ); prevActiveValues.clear(); prevActiveValues.reserve( 32 ); MSQ_PRINT( 3 )( " Initialized prevActiveValues\n" ); }
void MBMesquite::NonSmoothDescent::initialize | ( | PatchData & | pd, |
Definition at line 72 of file NonSmoothDescent.cpp.
References minStepSize, and MSQ_DBGOUT.
{ minStepSize = 1e-6; MSQ_DBGOUT( 1 ) << "- Executed NonSmoothDescent::initialize()\n"; }
void MBMesquite::NonSmoothDescent::initialize_mesh_iteration | ( | PatchData & | pd, |
void MBMesquite::NonSmoothDescent::minmax_opt | ( | PatchData & | pd, |
) | [private] |
Definition at line 568 of file NonSmoothDescent.cpp.
References MBMesquite::NonSmoothDescent::ActiveSet::active_ind, check_equilibrium(), compute_alpha(), compute_gradient(), find_active_set(), get_gradient_projections(), mActive, mFunction, mGradient, MSQ_DBG, MSQ_EQUILIBRIUM, MSQ_ERRRTN, MSQ_FLAT_NO_IMP, MSQ_FUNCTION_TIMER, MSQ_IMP_TOO_SMALL, MSQ_MAX_ITER_EXCEEDED, MBMesquite::MSQ_MAX_OPT_ITER, MSQ_PRINT, MSQ_STEP_TOO_SMALL, MSQ_ZERO_SEARCH, optStatus, originalFunction, originalValue, prevActiveValues, print_active_set(), search_direction(), step_acceptance(), MBMesquite::NonSmoothDescent::ActiveSet::true_active_value, and validity_check().
{ bool equilibriumPt = false; Vector3D mSearch( 0, 0, 0 ); // int valid; MSQ_FUNCTION_TIMER( "Minmax Opt" ); MSQ_PRINT( 2 )( "In minmax_opt\n" ); mFunction = originalFunction; originalValue = mActive.true_active_value; int iterCount = 0; int optIterCount = 0; MSQ_PRINT( 3 )( "Done copying original function to function\n" ); this->find_active_set( mFunction, mActive ); prevActiveValues.clear(); prevActiveValues.push_back( mActive.true_active_value ); /* check for equilibrium point */ /* compute the gradient */ this->compute_gradient( &pd, mGradient, err );MSQ_ERRRTN( err ); if( mActive.active_ind.size() >= 2 ) { MSQ_PRINT( 3 )( "Testing for an equilibrium point \n" ); equilibriumPt = this->check_equilibrium( optStatus, err );MSQ_ERRRTN( err ); if( MSQ_DBG( 2 ) && equilibriumPt ) MSQ_PRINT( 2 )( "Optimization Exiting: An equilibrium point \n" ); } /* terminate if we have found an equilibrium point or if the step is too small to be worthwhile continuing */ while( ( optStatus != MSQ_EQUILIBRIUM ) && ( optStatus != MSQ_STEP_TOO_SMALL ) && ( optStatus != MSQ_IMP_TOO_SMALL ) && ( optStatus != MSQ_FLAT_NO_IMP ) && ( optStatus != MSQ_ZERO_SEARCH ) && ( optStatus != MSQ_MAX_ITER_EXCEEDED ) ) { /* increase the iteration count by one */ /* smooth_param->iter_count += 1; */ iterCount += 1; optIterCount += 1; if( iterCount > MSQ_MAX_OPT_ITER ) optStatus = MSQ_MAX_ITER_EXCEEDED; MSQ_PRINT( 3 )( "\nITERATION %d \n", iterCount ); /* compute the gradient */ this->compute_gradient( &pd, mGradient, err );MSQ_ERRRTN( err ); MSQ_PRINT( 3 )( "Computing the search direction \n" ); this->search_direction( pd, mSearch, err );MSQ_ERRRTN( err ); /* if there are viable directions to search */ if( ( optStatus != MSQ_ZERO_SEARCH ) && ( optStatus != MSQ_MAX_ITER_EXCEEDED ) ) { MSQ_PRINT( 3 )( "Computing the projections of the gradients \n" ); this->get_gradient_projections( mSearch, err );MSQ_ERRRTN( err ); MSQ_PRINT( 3 )( "Computing the initial step size \n" ); this->compute_alpha( err );MSQ_ERRRTN( err ); MSQ_PRINT( 3 )( "Testing whether to accept this step \n" ); this->step_acceptance( pd, iterCount, mSearch, err );MSQ_ERRRTN( err ); // MSQ_PRINT(3)("The new free vertex position is %f %f %f\n", // mCoords[freeVertexIndex][0],mCoords[freeVertexIndex][1],mCoords[freeVertexIndex][2]); if( MSQ_DBG( 3 ) ) { /* Print the active set */ this->print_active_set( mActive, mFunction ); } /* check for equilibrium point */ if( mActive.active_ind.size() >= 2 ) { MSQ_PRINT( 3 )( "Testing for an equilibrium point \n" ); equilibriumPt = this->check_equilibrium( optStatus, err );MSQ_ERRRTN( err ); if( MSQ_DBG( 2 ) && equilibriumPt ) MSQ_PRINT( 2 )( "Optimization Exiting: An equilibrium point \n" ); } /* record the values */ prevActiveValues.push_back( mActive.true_active_value ); } else { /* decrease the iteration count by one */ /* smooth_param->iter_count -= 1; */ iterCount -= 1; if( MSQ_DBG( 2 ) ) { MSQ_PRINT( 2 ) ( "Optimization Exiting: No viable directions; equilibrium point \n" ); /* Print the old active set */ this->print_active_set( mActive, mFunction ); } } } MSQ_PRINT( 2 )( "Checking the validity of the mesh\n" ); if( !this->validity_check( pd, err ) ) MSQ_PRINT( 2 )( "The final mesh is not valid\n" );MSQ_ERRRTN( err ); MSQ_PRINT( 2 )( "Number of optimization iterations %d\n", iterCount ); switch( optStatus ) { default: MSQ_PRINT( 2 )( "Optimization Termination OptStatus: Invalid early termination\n" ); break; case MSQ_EQUILIBRIUM: MSQ_PRINT( 2 )( "Optimization Termination OptStatus: Equilibrium\n" ); break; case MSQ_STEP_TOO_SMALL: MSQ_PRINT( 2 )( "Optimization Termination OptStatus: Step Too Small\n" ); break; case MSQ_IMP_TOO_SMALL: MSQ_PRINT( 2 )( "Optimization Termination OptStatus: Improvement Too Small\n" ); break; case MSQ_FLAT_NO_IMP: MSQ_PRINT( 2 )( "Optimization Termination OptStatus: Flat No Improvement\n" ); break; case MSQ_ZERO_SEARCH: MSQ_PRINT( 2 )( "Optimization Termination OptStatus: Zero Search\n" ); break; case MSQ_MAX_ITER_EXCEEDED: MSQ_PRINT( 2 )( "Optimization Termination OptStatus: Max Iter Exceeded\n" ); break; } }
NonSmoothDescent& MBMesquite::NonSmoothDescent::operator= | ( | const NonSmoothDescent & | pd | ) | [private] |
void MBMesquite::NonSmoothDescent::optimize_vertex_positions | ( | PatchData & | pd, |
Definition at line 79 of file NonSmoothDescent.cpp.
References compute_function(), find_active_set(), freeVertexIndex, init_max_step_length(), init_opt(), MBMesquite::MsqError::INVALID_MESH, mActive, minmax_opt(), MSQ_ERRRTN, MSQ_FUNCTION_TIMER, MSQ_PRINT, MSQ_SETERR, MBMesquite::MsqFreeVertexIndexIterator::next(), MBMesquite::PatchData::num_elements(), MBMesquite::PatchData::num_free_vertices(), MBMesquite::PatchData::num_nodes(), originalFunction, MBMesquite::MsqFreeVertexIndexIterator::reset(), validity_check(), and MBMesquite::MsqFreeVertexIndexIterator::value().
{ MSQ_FUNCTION_TIMER( "NonSmoothDescent" ); // cout << "- Executing NonSmoothDescent::optimize_node_positions()\n"; /* perform the min max smoothing algorithm */ MSQ_PRINT( 2 )( "\nInitializing the patch iteration\n" ); MSQ_PRINT( 3 )( "Number of Vertices: %d\n", (int)pd.num_nodes() ); MSQ_PRINT( 3 )( "Number of Elements: %d\n", (int)pd.num_elements() ); // Michael: Note: is this a reliable way to get the dimension? // NOTE: Mesquite only does 3-dimensional (including surface) meshes. // mDimension = pd.get_mesh()->get_geometric_dimension(err); MSQ_ERRRTN(err); // MSQ_PRINT(3)("Spatial Dimension: %d\n",mDimension); MSQ_PRINT( 3 )( "Spatial Dimension: 3\n" ); MSQ_PRINT( 3 )( "Num Free = %d\n", (int)pd.num_free_vertices() ); MsqFreeVertexIndexIterator free_iter( pd, err );MSQ_ERRRTN( err ); free_iter.reset(); free_iter.next(); freeVertexIndex = free_iter.value(); MSQ_PRINT( 3 )( "Free Vertex Index = %lu\n", (unsigned long)freeVertexIndex ); // TODO - need to switch to validity via metric evaluations should // be associated with the compute_function somehow /* check for an invalid mesh; if it's invalid return and ask the user to use untangle */ if( !this->validity_check( pd, err ) ) { MSQ_PRINT( 1 )( "ERROR: Invalid mesh\n" ); MSQ_SETERR( err ) ( "Invalid Mesh: Use untangle to create a valid " "triangulation", MsqError::INVALID_MESH ); return; } /* initialize the optimization data up to numFunctionValues */ this->init_opt( pd, err );MSQ_ERRRTN( err ); this->init_max_step_length( pd, err );MSQ_ERRRTN( err ); MSQ_PRINT( 3 )( "Done initializing optimization\n" ); /* compute the initial function values */ // TODO this should return a bool with the validity this->compute_function( &pd, originalFunction, err );MSQ_ERRRTN( err ); // find the initial active set this->find_active_set( originalFunction, mActive ); this->minmax_opt( pd, err );MSQ_ERRRTN( err ); }
void MBMesquite::NonSmoothDescent::print_active_set | ( | const ActiveSet & | active_set, |
const std::vector< double > & | func | ||
) | [private] |
Definition at line 1587 of file NonSmoothDescent.cpp.
References MBMesquite::NonSmoothDescent::ActiveSet::active_ind, MSQ_DBGOUT, and MSQ_PRINT.
Referenced by minmax_opt(), and search_direction().
{ if( active_set.active_ind.empty() ) MSQ_DBGOUT( 3 ) << "No active values\n"; /* print the active set */ for( size_t i = 0; i < active_set.active_ind.size(); i++ ) { MSQ_PRINT( 3 ) ( "Active value %lu: %f \n", (unsigned long)i + 1, func[active_set.active_ind[i]] ); } }
void MBMesquite::NonSmoothDescent::search_direction | ( | PatchData & | pd, |
Vector3D & | search_dir_out, | ||
) | [private] |
Definition at line 439 of file NonSmoothDescent.cpp.
References MBMesquite::NonSmoothDescent::ActiveSet::active_ind, b, MBMesquite::NonSmoothDescent::SymmetricMatrix::condition3x3(), moab::E, MBMesquite::EPSILON, form_grammian(), form_PD_grammian(), form_reduced_matrix(), get_active_directions(), MBMesquite::MsqError::INVALID_STATE, mActive, mFunction, mG, mGradient, MSQ_ERRRTN, MSQ_PRINT, MSQ_SETERR, MSQ_ZERO_SEARCH, mSteepest, optStatus, MBMesquite::P, print_active_set(), search_edges_faces(), and solve2x2().
{ bool viable; double a, b, c, denom; std::vector< Vector3D > dir; double R0, R1; SymmetricMatrix P; double x[2]; double search_mag; const int num_active = mActive.active_ind.size(); ; // TODO This might be o.k. actually - i don't see any dependence // on the element geometry here... try it and see if it works. // if not, try taking all of the gradients in the active set // and let the search direction be the average of those. // MSQ_FUNCTION_TIMER( "Search Direction" ); MSQ_PRINT( 2 )( "\nIn Search Direction\n" ); this->print_active_set( mActive, mFunction ); if( num_active == 0 ) { MSQ_SETERR( err )( "No active values in search", MsqError::INVALID_STATE ); return; } switch( num_active ) { case 1: mSearch = mGradient[mActive.active_ind[0]]; mSteepest = mActive.active_ind[0]; break; case 2: /* if there are two active points, move in the direction of the intersection of the planes. This is the steepest descent direction found by analytically solving the QP */ /* set up the active gradient directions */ this->get_active_directions( mGradient, dir, err );MSQ_ERRRTN( err ); /* form the grammian */ this->form_grammian( dir, err );MSQ_ERRRTN( err ); this->form_PD_grammian( err );MSQ_ERRRTN( err ); denom = ( mG( 0, 0 ) + mG( 1, 1 ) - 2 * mG( 0, 1 ) ); viable = true; if( fabs( denom ) > EPSILON ) { /* gradients are LI, move along their intersection */ b = ( mG( 0, 0 ) - mG( 0, 1 ) ) / denom; a = 1 - b; if( ( b < 0 ) || ( b > 1 ) ) viable = false; /* 0 < b < 1 */ if( viable ) { mSearch = a * dir[0] + b * dir[1]; } else { /* the gradients are dependent, move along one face */ mSearch = dir[0]; } } else { /* the gradients are dependent, move along one face */ mSearch = dir[0]; } mSteepest = mActive.active_ind[0]; break; default: /* as in case 2: solve the QP problem to find the steepest descent direction. This can be done analytically - as is done in Gill, Murray and Wright for 3 active points in 3 directions - test PD of G otherwise we know it's SP SD so search edges and faces */ /* get the active gradient directions */ this->get_active_directions( mGradient, dir, err );MSQ_ERRRTN( err ); /* form the entries of the grammian matrix */ this->form_grammian( dir, err );MSQ_ERRRTN( err ); this->form_PD_grammian( err );MSQ_ERRRTN( err ); if( num_active == 3 ) { if( mG.condition3x3() < 1e14 ) { // if not singular /* form the entries of P=Z^T G Z where Z = [-1...-1; I ] */ this->form_reduced_matrix( P ); /* form the RHS and solve the system for the coeffs */ R0 = mG( 0, 0 ) - mG( 1, 0 ); R1 = mG( 0, 0 ) - mG( 2, 0 ); bool ok = this->solve2x2( P( 0, 0 ), P( 0, 1 ), P( 1, 0 ), P( 1, 1 ), R0, R1, x, err );MSQ_ERRRTN( err ); if( ok ) { a = 1 - x[0] - x[1]; b = x[0]; c = x[1]; mSearch = a * dir[0] + b * dir[1] + c * dir[2]; mSteepest = mActive.active_ind[0]; } else { this->search_edges_faces( &dir[0], mSearch, err );MSQ_ERRRTN( err ); } } else { this->search_edges_faces( &dir[0], mSearch, err );MSQ_ERRRTN( err ); } } else { this->search_edges_faces( &dir[0], mSearch, err );MSQ_ERRRTN( err ); } } /* if the search direction is essentially zero, equilibrium pt */ search_mag = mSearch % mSearch; MSQ_PRINT( 3 )( " Search Magnitude %g \n", search_mag ); if( fabs( search_mag ) < 1E-13 ) optStatus = MSQ_ZERO_SEARCH; else mSearch /= std::sqrt( search_mag ); MSQ_PRINT( 3 ) ( " Search Direction %g %g Steepest %lu\n", mSearch[0], mSearch[1], (unsigned long)mSteepest ); }
void MBMesquite::NonSmoothDescent::search_edges_faces | ( | const Vector3D * | dir, |
Vector3D & | search, | ||
) | [private] |
Definition at line 1387 of file NonSmoothDescent.cpp.
References MBMesquite::NonSmoothDescent::ActiveSet::active_ind, b, MBMesquite::EPSILON, mActive, mG, MSQ_EQUILIBRIUM, mSteepest, and optStatus.
{ bool viable; double a, b, denom; Vector3D g_bar; Vector3D temp_search( 0, 0, 0 ); /* initialize the search direction to 0,0 */ double projection, min_projection; const size_t num_active = mActive.active_ind.size(); ; /* Check for viable faces */ min_projection = HUGE_VAL; for( size_t i = 0; i < num_active; i++ ) { /* FACE I */ viable = true; /* test the viability */ for( size_t j = 0; j < num_active; j++ ) { /* lagrange multipliers>0 */ if( mG( j, i ) < 0 ) viable = false; } /* find the minimum of viable directions */ if( ( viable ) && ( mG( i, i ) < min_projection ) ) { min_projection = mG( i, i ); temp_search = dir[i]; mSteepest = mActive.active_ind[i]; } /* INTERSECTION IJ */ for( size_t j = i + 1; j < num_active; j++ ) { viable = true; /* find the coefficients of the intersection and test the viability */ denom = 2 * mG( i, j ) - mG( i, i ) - mG( j, j ); a = b = 0; if( fabs( denom ) > EPSILON ) { b = ( mG( i, j ) - mG( i, i ) ) / denom; a = 1 - b; if( ( b < 0 ) || ( b > 1 ) ) /* 0 < b < 1 */ viable = false; for( size_t k = 0; k < num_active; k++ ) { /* lagrange multipliers>0 */ if( ( a * mG( k, i ) + b * mG( k, j ) ) <= 0 ) viable = false; } } else { viable = false; /* Linearly dependent */ } /* find the minimum of viable directions */ if( viable ) { g_bar = a * dir[i] + b * dir[j]; projection = g_bar % g_bar; if( projection < min_projection ) { min_projection = projection; temp_search = g_bar; mSteepest = mActive.active_ind[i]; } } } } if( optStatus != MSQ_EQUILIBRIUM ) { mSearch = temp_search; } }
void MBMesquite::NonSmoothDescent::singular_test | ( | int | n, |
const Matrix3D & | A, | ||
bool & | singular, | ||
) | [private] |
Definition at line 1310 of file NonSmoothDescent.cpp.
References MBMesquite::condition3x3(), MBMesquite::EPSILON, MBMesquite::MsqError::INVALID_ARG, and MSQ_SETERR.
Referenced by form_PD_grammian().
{ // int test; // double determinant; double cond; if( ( n > 3 ) || ( n < 1 ) ) { MSQ_SETERR( err )( "Singular test works only for n=1 to n=3", MsqError::INVALID_ARG ); return; } singular = true; switch( n ) { case 1: if( A[0][0] > 0 ) singular = false; break; case 2: if( fabs( A[0][0] * A[1][1] - A[0][1] * A[1][0] ) > EPSILON ) singular = false; break; case 3: /* calculate the condition number */ cond = condition3x3( A[0] ); if( cond < 1E14 ) singular = false; break; } }
bool MBMesquite::NonSmoothDescent::solve2x2 | ( | double | a11, |
double | a12, | ||
double | a21, | ||
double | a22, | ||
double | b1, | ||
double | b2, | ||
double | x[2], | ||
) | [private] |
Definition at line 1461 of file NonSmoothDescent.cpp.
References b1, b2, and MBMesquite::EPSILON.
{ double factor; /* if the system is not singular, solve it */ if( fabs( a11 * a22 - a21 * a12 ) > EPSILON ) { if( fabs( a11 ) > EPSILON ) { factor = ( a21 / a11 ); x[1] = ( b2 - factor * b1 ) / ( a22 - factor * a12 ); x[0] = ( b1 - a12 * x[1] ) / a11; } else if( fabs( a21 ) > EPSILON ) { factor = ( a11 / a21 ); x[1] = ( b1 - factor * b2 ) / ( a12 - factor * a22 ); x[0] = ( b2 - a22 * x[1] ) / a21; } return true; } else { return false; } }
void MBMesquite::NonSmoothDescent::step_acceptance | ( | PatchData & | pd, |
int | iter_count, | ||
const Vector3D & | search_dir, | ||
) | [private] |
Definition at line 701 of file NonSmoothDescent.cpp.
References compute_function(), find_active_set(), freeVertexIndex, get_min_estimate(), MBMesquite::PatchData::get_vertex_array(), improvement_check(), mActive, mAlpha, mFunction, minStepSize, MBMesquite::PatchData::move_vertex(), MSQ_ERRRTN, MSQ_FLAT_NO_IMP, MSQ_IMP_TOO_SMALL, MSQ_NO_STATUS, MSQ_PRINT, MSQ_STEP_ACCEPTED, MSQ_STEP_TOO_SMALL, optStatus, originalActive, originalFunction, prevActiveValues, MBMesquite::PatchData::set_vertex_coordinates(), testActive, testFunction, MBMesquite::NonSmoothDescent::ActiveSet::true_active_value, and validity_check().
{ const double minAcceptableImprovement = 1e-6; // int ierr; // int num_values; bool step_done; bool valid = true, accept_alpha; double estimated_improvement; double current_improvement = HUGE_VAL; double previous_improvement = HUGE_VAL; double current_percent_diff = HUGE_VAL; Vector3D original_point; // MSQ_FUNCTION_TIMER( "Step Acceptance" ); // num_values = qmHandles.size(); optStatus = MSQ_NO_STATUS; if( mAlpha < minStepSize ) { optStatus = MSQ_IMP_TOO_SMALL; step_done = true; MSQ_PRINT( 3 )( "Alpha starts too small, no improvement\n" ); } const MsqVertex* coords = pd.get_vertex_array( err ); /* save the original function and active set */ original_point = coords[freeVertexIndex]; originalFunction = mFunction; originalActive = mActive; step_done = false; for( int num_steps = 0; !step_done && num_steps < 100; ++num_steps ) { accept_alpha = false; while( !accept_alpha && mAlpha > minStepSize ) { /* make the step */ pd.move_vertex( -mAlpha * mSearch, freeVertexIndex, err ); // pd.set_coords_array_element(coords[freeVertexIndex],0,err); MSQ_PRINT( 2 )( "search direction %f %f \n", mSearch[0], mSearch[1] ); MSQ_PRINT( 2 ) ( "new vertex position %f %f \n", coords[freeVertexIndex][0], coords[freeVertexIndex][1] ); /* assume alpha is acceptable */ accept_alpha = true; /* never take a step that makes a valid mesh invalid or worsens the quality */ // TODO Validity check revision -- do the compute function up here // and then the rest based on validity valid = validity_check( pd, err );MSQ_ERRRTN( err ); if( valid ) { valid = improvement_check( err );MSQ_ERRRTN( err ); } if( !valid ) { accept_alpha = false; pd.move_vertex( mAlpha * mSearch, freeVertexIndex, err ); // pd.set_coords_array_element(coords[freeVertexIndex],0,err); mAlpha = mAlpha / 2; MSQ_PRINT( 2 )( "Step not accepted, the new alpha %f\n", mAlpha ); if( mAlpha < minStepSize ) { optStatus = MSQ_STEP_TOO_SMALL; step_done = true; MSQ_PRINT( 2 )( "Step too small\n" ); /* get back the original point, mFunction, and active set */ pd.set_vertex_coordinates( original_point, freeVertexIndex, err ); mFunction = originalFunction; mActive = originalActive; } } } if( valid && ( mAlpha > minStepSize ) ) { /* compute the new function and active set */ this->compute_function( &pd, mFunction, err );MSQ_ERRRTN( err ); this->find_active_set( mFunction, mActive ); /* estimate the minimum improvement by taking this step */ this->get_min_estimate( &estimated_improvement, err );MSQ_ERRRTN( err ); MSQ_PRINT( 2 ) ( "The estimated improvement for this step: %f\n", estimated_improvement ); /* calculate the actual increase */ current_improvement = mActive.true_active_value - prevActiveValues[iterCount - 1]; MSQ_PRINT( 3 )( "Actual improvement %f\n", current_improvement ); /* calculate the percent difference from estimated increase */ current_percent_diff = fabs( current_improvement - estimated_improvement ) / fabs( estimated_improvement ); /* determine whether to accept a step */ if( ( fabs( previous_improvement ) > fabs( current_improvement ) ) && ( previous_improvement < 0 ) ) { /* accept the previous step - it was better */ MSQ_PRINT( 2 )( "Accepting the previous step\n" ); /* subtract alpha in again (previous step) */ pd.move_vertex( -mAlpha * mSearch, freeVertexIndex, err ); // pd.set_coords_array_element(coords[freeVertexIndex],0,err); /* does this make an invalid mesh valid? */ // TODO Validity check revisison valid = validity_check( pd, err );MSQ_ERRRTN( err ); if( valid ) valid = improvement_check( err );MSQ_ERRRTN( err ); /* copy test function and active set */ mFunction = testFunction; mActive = testActive; optStatus = MSQ_STEP_ACCEPTED; step_done = true; /* check to see that we're still making good improvements */ if( fabs( previous_improvement ) < minAcceptableImprovement ) { optStatus = MSQ_IMP_TOO_SMALL; step_done = true; MSQ_PRINT( 2 )( "Optimization Exiting: Improvement too small\n" ); } } else if( ( ( fabs( current_improvement ) > fabs( estimated_improvement ) ) || ( current_percent_diff < .1 ) ) && ( current_improvement < 0 ) ) { /* accept this step, exceeded estimated increase or was close */ optStatus = MSQ_STEP_ACCEPTED; step_done = true; /* check to see that we're still making good improvements */ if( fabs( current_improvement ) < minAcceptableImprovement ) { MSQ_PRINT( 2 )( "Optimization Exiting: Improvement too small\n" ); optStatus = MSQ_IMP_TOO_SMALL; step_done = true; } } else if( ( current_improvement > 0 ) && ( previous_improvement > 0 ) && ( fabs( current_improvement ) < minAcceptableImprovement ) && ( fabs( previous_improvement ) < minAcceptableImprovement ) ) { /* we are making no progress, quit */ optStatus = MSQ_FLAT_NO_IMP; step_done = true; MSQ_PRINT( 2 )( "Opimization Exiting: Flat no improvement\n" ); /* get back the original point, function, and active set */ pd.set_vertex_coordinates( original_point, freeVertexIndex, err );MSQ_ERRRTN( err ); mFunction = originalFunction; mActive = originalActive; } else { /* halve alpha and try again */ /* add out the old step */ pd.move_vertex( mAlpha * mSearch, freeVertexIndex, err ); // pd.set_coords_array_element(coords[freeVertexIndex],0,err); /* halve step size */ mAlpha = mAlpha / 2; MSQ_PRINT( 3 )( "Step not accepted, the new alpha %f\n", mAlpha ); if( mAlpha < minStepSize ) { /* get back the original point, function, and active set */ MSQ_PRINT( 2 )( "Optimization Exiting: Step too small\n" ); pd.set_vertex_coordinates( original_point, freeVertexIndex, err );MSQ_ERRRTN( err ); mFunction = originalFunction; mActive = originalActive; optStatus = MSQ_STEP_TOO_SMALL; step_done = true; } else { testFunction = mFunction; testActive = mActive; previous_improvement = current_improvement; } } } } if( current_improvement > 0 && optStatus == MSQ_STEP_ACCEPTED ) { MSQ_PRINT( 2 )( "Accepted a negative step %f \n", current_improvement ); } }
void MBMesquite::NonSmoothDescent::terminate_mesh_iteration | ( | PatchData & | pd, |
bool MBMesquite::NonSmoothDescent::validity_check | ( | PatchData & | pd, |
) | [private] |
Definition at line 1013 of file NonSmoothDescent.cpp.
References conn, MBMesquite::PatchData::element_by_index(), MBMesquite::EPSILON, MBMesquite::Vector3D::get_coordinates(), MBMesquite::PatchData::get_vertex_array(), MBMesquite::MsqMeshEntity::get_vertex_index_array(), and MBMesquite::PatchData::num_elements().
{ // FUNCTION_TIMER_START("Validity Check"); // ONLY FOR SIMPLICIAL MESHES - THERE SHOULD BE A VALIDITY CHECKER ASSOCIATED // WITH MSQ ELEMENTS /* check that the simplicial mesh is still valid, based on right handedness. Returns a 1 or a 0 */ // TODO as a first step we can switch this over to the function // evaluation and use the rest of the code as is bool valid = true; double dEps = 1.e-13; double x1, x2, x3, x4, y1, y2, y3, y4, z1, z2, z3, z4; const MsqVertex* coords = pd.get_vertex_array( err ); for( size_t i = 0; i < pd.num_elements(); i++ ) { const size_t* conn = pd.element_by_index( i ).get_vertex_index_array(); coords[conn[0]].get_coordinates( x1, y1, z1 ); coords[conn[1]].get_coordinates( x2, y2, z2 ); coords[conn[2]].get_coordinates( x3, y3, z3 ); coords[conn[3]].get_coordinates( x4, y4, z4 ); double dDX2 = x2 - x1; double dDX3 = x3 - x1; double dDX4 = x4 - x1; double dDY2 = y2 - y1; double dDY3 = y3 - y1; double dDY4 = y4 - y1; double dDZ2 = z2 - z1; double dDZ3 = z3 - z1; double dDZ4 = z4 - z1; /* dDet is proportional to the cell volume */ double dDet = dDX2 * dDY3 * dDZ4 + dDX3 * dDY4 * dDZ2 + dDX4 * dDY2 * dDZ3 - dDZ2 * dDY3 * dDX4 - dDZ3 * dDY4 * dDX2 - dDZ4 * dDY2 * dDX3; /* Compute a length scale based on edge lengths. */ double dScale = ( sqrt( ( x1 - x2 ) * ( x1 - x2 ) + ( y1 - y2 ) * ( y1 - y2 ) + ( z1 - z2 ) * ( z1 - z2 ) ) + sqrt( ( x1 - x3 ) * ( x1 - x3 ) + ( y1 - y3 ) * ( y1 - y3 ) + ( z1 - z3 ) * ( z1 - z3 ) ) + sqrt( ( x1 - x4 ) * ( x1 - x4 ) + ( y1 - y4 ) * ( y1 - y4 ) + ( z1 - z4 ) * ( z1 - z4 ) ) + sqrt( ( x2 - x3 ) * ( x2 - x3 ) + ( y2 - y3 ) * ( y2 - y3 ) + ( z2 - z3 ) * ( z2 - z3 ) ) + sqrt( ( x2 - x4 ) * ( x2 - x4 ) + ( y2 - y4 ) * ( y2 - y4 ) + ( z2 - z4 ) * ( z2 - z4 ) ) + sqrt( ( x3 - x4 ) * ( x3 - x4 ) + ( y3 - y4 ) * ( y3 - y4 ) + ( z3 - z4 ) * ( z3 - z4 ) ) ) / 6.; /* Use the length scale to get a better idea if the tet is flat or just really small. */ if( fabs( dScale ) < EPSILON ) { return false; } else { dDet /= ( dScale * dScale * dScale ); } if( dDet > dEps ) { valid = true; } else if( dDet < -dEps ) { return false; } else { return false; } } // end for i=1,numElements // MSQ_DEBUG_ACTION(2,{fprintf(stdout,"Mesh Validity is: %d \n",valid);}); // FUNCTION_TIMER_END(); return ( valid ); }
Definition at line 181 of file NonSmoothDescent.hpp.
Referenced by compute_function(), compute_gradient(), and init_opt().
size_t MBMesquite::NonSmoothDescent::freeVertexIndex [private] |
Definition at line 174 of file NonSmoothDescent.hpp.
Definition at line 195 of file NonSmoothDescent.hpp.
Referenced by check_equilibrium(), form_grammian(), form_PD_grammian(), form_reduced_matrix(), get_active_directions(), get_min_estimate(), improvement_check(), minmax_opt(), optimize_vertex_positions(), search_direction(), search_edges_faces(), and step_acceptance().
double MBMesquite::NonSmoothDescent::mAlpha [private] |
Definition at line 192 of file NonSmoothDescent.hpp.
Referenced by compute_alpha(), get_min_estimate(), init_opt(), and step_acceptance().
double MBMesquite::NonSmoothDescent::maxAlpha [private] |
Definition at line 193 of file NonSmoothDescent.hpp.
Referenced by compute_alpha(), init_max_step_length(), and init_opt().
std::vector< double > MBMesquite::NonSmoothDescent::mFunction [private] |
Definition at line 183 of file NonSmoothDescent.hpp.
Referenced by compute_alpha(), init_opt(), minmax_opt(), search_direction(), and step_acceptance().
Definition at line 185 of file NonSmoothDescent.hpp.
Referenced by form_grammian(), form_PD_grammian(), form_reduced_matrix(), init_opt(), search_direction(), and search_edges_faces().
std::vector< Vector3D > MBMesquite::NonSmoothDescent::mGradient [private] |
Definition at line 188 of file NonSmoothDescent.hpp.
Referenced by check_equilibrium(), compute_gradient(), get_gradient_projections(), init_opt(), minmax_opt(), and search_direction().
std::vector< double > MBMesquite::NonSmoothDescent::mGS [private] |
Definition at line 184 of file NonSmoothDescent.hpp.
Referenced by compute_alpha(), get_gradient_projections(), get_min_estimate(), and init_opt().
double MBMesquite::NonSmoothDescent::minStepSize [private] |
Definition at line 177 of file NonSmoothDescent.hpp.
Referenced by compute_alpha(), initialize(), and step_acceptance().
Matrix3D MBMesquite::NonSmoothDescent::mPDG [private] |
Definition at line 186 of file NonSmoothDescent.hpp.
Referenced by form_PD_grammian(), and init_opt().
size_t MBMesquite::NonSmoothDescent::mSteepest [private] |
Definition at line 191 of file NonSmoothDescent.hpp.
Referenced by compute_alpha(), get_gradient_projections(), init_opt(), search_direction(), and search_edges_faces().
Definition at line 190 of file NonSmoothDescent.hpp.
Referenced by init_opt(), minmax_opt(), search_direction(), search_edges_faces(), and step_acceptance().
std::vector< double > MBMesquite::NonSmoothDescent::originalFunction [private] |
Referenced by init_opt(), minmax_opt(), optimize_vertex_positions(), and step_acceptance().
double MBMesquite::NonSmoothDescent::originalValue [private] |
Definition at line 182 of file NonSmoothDescent.hpp.
Referenced by improvement_check(), and minmax_opt().
Definition at line 180 of file NonSmoothDescent.hpp.
Referenced by get_patch_set().
int MBMesquite::NonSmoothDescent::pdgInd[3] [private] |
Definition at line 194 of file NonSmoothDescent.hpp.
std::vector< double > MBMesquite::NonSmoothDescent::prevActiveValues [private] |
Definition at line 187 of file NonSmoothDescent.hpp.
Referenced by init_opt(), minmax_opt(), and step_acceptance().
std::vector< size_t > MBMesquite::NonSmoothDescent::qmHandles [private] |
Definition at line 189 of file NonSmoothDescent.hpp.
Referenced by check_equilibrium(), compute_alpha(), compute_function(), compute_gradient(), find_active_set(), get_gradient_projections(), get_min_estimate(), and init_opt().
std::vector< double > MBMesquite::NonSmoothDescent::testFunction [private] |
Referenced by init_opt(), and step_acceptance().
std::vector< Vector3D > MBMesquite::NonSmoothDescent::tmpGrad [private] |
Referenced by compute_gradient().
std::vector< size_t > MBMesquite::NonSmoothDescent::tmpIdx [private] |
