MOAB: Mesh Oriented datABase
(version 5.2.1)
#include "Mesquite.hpp"
#include <iostream>
#include <memory>
#include <ctype.h>
#include "MeshImpl.hpp"
#include "MsqError.hpp"
#include "InstructionQueue.hpp"
#include "TerminationCriterion.hpp"
#include "QualityAssessor.hpp"
#include "PMeanPTemplate.hpp"
#include "PatchPowerMeanP.hpp"
#include "ConjugateGradient.hpp"
#include "PlanarDomain.hpp"
#include "IdealShapeTarget.hpp"
#include "ConditionNumberQualityMetric.hpp"
#include "ReferenceMesh.hpp"
#include "RefMeshTargetCalculator.hpp"
#include "TestUtil.hpp"
#include "TQualityMetric.hpp"
#include "ElementPMeanP.hpp"
#include "VertexPMeanP.hpp"
#include "TSquared.hpp"
#include "TShapeNB1.hpp"
#include "TShapeB1.hpp"
#include "TShapeOrientNB1.hpp"
#include "TShapeOrientNB2.hpp"
#include "TShapeOrientB1.hpp"
#include "TShapeSize2DNB1.hpp"
#include "TShapeSizeB1.hpp"
#include "TShapeSize2DB2.hpp"
#include "TShapeSizeB3.hpp"
#include "TShapeSizeOrientNB1.hpp"
#include "TShapeSizeOrientB1.hpp"
#include "TShapeSizeOrientB2.hpp"
Enumerations | |
enum | AveragingScheme { NONE = 0, ELEMENT, VERTEX, PATCH } |
Functions | |
static PlanarDomain | make_domain (Mesh *mesh, MsqError &) |
static int | do_smoother (const char *input_file, const char *output_file, const char *ref_mesh_file, double of_power, unsigned metric_idx, AveragingScheme avg_scheme) |
static void | usage (const char *argv0, bool help=false) |
static void | check_next_arg (int argc, char *argv[], int &i) |
static double | parse_double (int argc, char *argv[], int &i) |
static int | comp_string_start (const char *p, const char *s) |
static AveragingScheme | parse_averaging (int argc, char *argv[], int &i) |
static unsigned | parse_metric (int argc, char *argv[], int &i) |
static void | list_metrics () |
int | main (int argc, char *argv[]) |
Variables | |
struct { | |
TMetric * u | |
const char * n | |
} | metrics [] |
const char *const | averaging_names [] = { "none", "element", "vertex", "patch" } |
const double | DEFAULT_OF_POWER = 1.0 |
const unsigned | DEFAULT_METRIC_IDX = 0 |
const AveragingScheme | DEFAULT_AVG_SCHEME = NONE |
std::string | DEFAULT_INPUT_FILE = "/2D/vtk/quads/untangled/quads_4by2_bad.vtk" |
std::string | DEFAULT_OUTPUT_FILE = "./out.vtk" |
enum AveragingScheme |
static void check_next_arg | ( | int | argc, |
char * | argv[], | ||
int & | i | ||
) | [static] |
Definition at line 256 of file 2d_target_test.cpp.
References usage.
Referenced by main(), parse_averaging(), parse_double(), and parse_metric().
{ if( i == argc ) { cerr << "Expected argument following \"" << argv[i] << '"' << endl; usage( argv[0] ); } ++i; }
static int comp_string_start | ( | const char * | p, |
const char * | s | ||
) | [static] |
Definition at line 279 of file 2d_target_test.cpp.
Referenced by parse_averaging(), and parse_metric().
{ int i; for( i = 0; p[i]; ++i ) if( tolower( p[i] ) != tolower( s[i] ) ) return 0; return s[i] ? -1 : 1; }
static int do_smoother | ( | const char * | input_file, |
const char * | output_file, | ||
const char * | ref_mesh_file, | ||
double | of_power, | ||
unsigned | metric_idx, | ||
AveragingScheme | avg_scheme | ||
) | [static] |
Definition at line 109 of file 2d_target_test.cpp.
References MBMesquite::TerminationCriterion::add_absolute_vertex_movement(), MBMesquite::TerminationCriterion::add_iteration_limit(), MBMesquite::QualityAssessor::add_quality_assessment(), MBMesquite::InstructionQueue::add_quality_assessor(), averaging_names, geom, MBMesquite::inner(), make_domain(), mesh, metrics, MSQ_CHKERR, MBMesquite::NONE, MBMesquite::outer(), PATCH, MBMesquite::MeshImpl::read_vtk(), MBMesquite::IQInterface::run_instructions(), MBMesquite::QualityAssessor::scale_histograms(), MBMesquite::QualityImprover::set_inner_termination_criterion(), MBMesquite::InstructionQueue::set_master_quality_improver(), MBMesquite::QualityImprover::set_outer_termination_criterion(), MBMesquite::PatchSetUser::use_global_patch(), and MBMesquite::MeshImpl::write_vtk().
Referenced by main().
{ MsqPrintError err( cerr ); TMetric* const target_metric = metrics[metric_idx].u; cout << "Input file: " << input_file << endl; cout << "Metric: "; if( avg_scheme != NONE ) cout << averaging_names[avg_scheme] << " average of "; cout << metrics[metric_idx].n << endl; cout << "Of Power: " << of_power << endl; auto_ptr< TargetCalculator > tc; auto_ptr< MeshImpl > ref_mesh_impl; auto_ptr< ReferenceMesh > ref_mesh; if( ref_mesh_file ) { ref_mesh_impl.reset( new MeshImpl ); ref_mesh_impl->read_vtk( ref_mesh_file, err ); if( MSQ_CHKERR( err ) ) return 2; ref_mesh.reset( new ReferenceMesh( ref_mesh_impl.get() ) ); tc.reset( new RefMeshTargetCalculator( ref_mesh.get() ) ); } else { tc.reset( new IdealShapeTarget() ); } TQualityMetric jacobian_metric( tc.get(), target_metric ); ElementPMeanP elem_avg( of_power, &jacobian_metric ); VertexPMeanP vtx_avg( of_power, &jacobian_metric ); QualityMetric* mmetrics[] = { &jacobian_metric, &elem_avg, &vtx_avg, &jacobian_metric }; QualityMetric* metric = mmetrics[avg_scheme]; TerminationCriterion outer, inner; outer.add_iteration_limit( 1 ); inner.add_absolute_vertex_movement( 1e-4 ); inner.add_iteration_limit( 100 ); PMeanPTemplate obj1( of_power, metric ); PatchPowerMeanP obj2( of_power, metric ); ObjectiveFunction& objective = *( ( avg_scheme == PATCH ) ? (ObjectiveFunction*)&obj2 : (ObjectiveFunction*)&obj1 ); ConjugateGradient solver( &objective, err ); if( MSQ_CHKERR( err ) ) return 1; solver.set_inner_termination_criterion( &inner ); solver.set_outer_termination_criterion( &outer ); solver.use_global_patch(); ConditionNumberQualityMetric qm_metric; QualityAssessor before_assessor; QualityAssessor after_assessor; before_assessor.add_quality_assessment( metric, 10 ); before_assessor.add_quality_assessment( &qm_metric ); after_assessor.add_quality_assessment( metric, 10 ); InstructionQueue q; q.add_quality_assessor( &before_assessor, err ); q.set_master_quality_improver( &solver, err ); q.add_quality_assessor( &after_assessor, err ); MeshImpl mesh; mesh.read_vtk( input_file, err ); if( MSQ_CHKERR( err ) ) return 2; PlanarDomain geom = make_domain( &mesh, err ); if( MSQ_CHKERR( err ) ) return 1; MeshDomainAssoc mesh_and_domain = MeshDomainAssoc( &mesh, &geom ); q.run_instructions( &mesh_and_domain, err ); if( MSQ_CHKERR( err ) ) return 3; mesh.write_vtk( output_file, err ); if( MSQ_CHKERR( err ) ) return 2; cout << "Wrote: " << output_file << endl; before_assessor.scale_histograms( &after_assessor ); return 0; }
static void list_metrics | ( | ) | [static] |
int main | ( | int | argc, |
char * | argv[] | ||
Definition at line 343 of file 2d_target_test.cpp.
References check_next_arg(), DEFAULT_AVG_SCHEME, DEFAULT_INPUT_FILE, DEFAULT_METRIC_IDX, DEFAULT_OF_POWER, DEFAULT_OUTPUT_FILE, do_smoother(), input_file, list_metrics(), parse_averaging(), parse_double(), parse_metric(), and usage.
{ MsqPrintError err( cout ); // CL settings double of_power = DEFAULT_OF_POWER; unsigned metric_idx = DEFAULT_METRIC_IDX; AveragingScheme avg_scheme = DEFAULT_AVG_SCHEME; const char* input_file = 0; const char* output_file = 0; const char* ref_mesh_file = 0; bool proc_opts = true; for( int i = 1; i < argc; ++i ) { if( !proc_opts || argv[i][0] != '-' ) { if( output_file ) { cerr << "Unexpected file name: \"" << argv[i] << '"' << endl; usage( argv[0] ); } else if( input_file ) output_file = argv[i]; else input_file = argv[i]; continue; } if( !argv[i][1] || argv[i][2] ) { cerr << "Invalid option: \"" << argv[i] << '"' << endl; usage( argv[0] ); } switch( argv[i][1] ) { case 'p': of_power = parse_double( argc, argv, i ); break; case 'm': metric_idx = parse_metric( argc, argv, i ); break; case 'a': avg_scheme = parse_averaging( argc, argv, i ); break; case 'r': check_next_arg( argc, argv, i ); ref_mesh_file = argv[i]; break; case '-': proc_opts = false; break; case 'h': usage( argv[0], true ); break; case 'l': list_metrics(); break; default: cerr << "Invalid option: \"" << argv[i] << '"' << endl; usage( argv[0] ); } } if( !input_file ) input_file = DEFAULT_INPUT_FILE.c_str(); if( !output_file ) output_file = DEFAULT_OUTPUT_FILE.c_str(); return do_smoother( input_file, output_file, ref_mesh_file, of_power, metric_idx, avg_scheme ); }
static PlanarDomain make_domain | ( | Mesh * | mesh, |
MsqError & | err | ||
) | [static] |
Definition at line 187 of file 2d_target_test.cpp.
References MBMesquite::arrptr(), MBMesquite::Mesh::get_all_vertices(), MBMesquite::MsqError::INVALID_STATE, MSQ_CHKERR, MSQ_SETERR, and MBMesquite::Mesh::vertices_get_coordinates().
Referenced by do_smoother().
{ // calculate bounding box of mesh vertices Vector3D minimum( HUGE_VAL, HUGE_VAL, HUGE_VAL ); Vector3D maximum( -HUGE_VAL, -HUGE_VAL, -HUGE_VAL ); std::vector< Mesh::VertexHandle > vertices; mesh->get_all_vertices( vertices, err ); if( MSQ_CHKERR( err ) ) { return PlanarDomain( minimum, maximum ); } if( vertices.empty() ) { std::cerr << "Mesh contains no vertices" << std::endl; exit( 1 ); } std::vector< MsqVertex > coords( vertices.size() ); mesh->vertices_get_coordinates( arrptr( vertices ), arrptr( coords ), vertices.size(), err ); if( MSQ_CHKERR( err ) ) { return PlanarDomain( minimum, maximum ); } std::vector< MsqVertex >::const_iterator i; for( i = coords.begin(); i != coords.end(); ++i ) { const MsqVertex& v = *i; for( unsigned j = 0; j < 3; ++j ) { if( v[j] < minimum[j] ) minimum[j] = v[j]; if( v[j] > maximum[j] ) maximum[j] = v[j]; } } // Look for a "zero" plane int k; maximum -= minimum; for( k = 2; k >= 0 && maximum[k] > 1e-6; --k ) ; if( k < 0 ) { MSQ_SETERR( err )( "Cannot determine plane of mesh.", MsqError::INVALID_STATE ); return PlanarDomain( minimum, maximum ); } Vector3D point( 0.0, 0.0, 0.0 ), normal( 0.0, 0.0, 0.0 ); normal[k] = 1.0; point[k] = minimum[k]; return PlanarDomain( normal, point ); }
static AveragingScheme parse_averaging | ( | int | argc, |
int & | i | ||
) | [static] |
Definition at line 287 of file 2d_target_test.cpp.
References averaging_names, check_next_arg(), comp_string_start(), MBMesquite::NONE, and usage.
{ check_next_arg( argc, argv, i ); for( unsigned j = 0; j < 4; ++j ) if( comp_string_start( argv[i], averaging_names[j] ) ) return (AveragingScheme)j; cerr << "Expected one of { "; for( unsigned j = 0; j < 4; ++j ) cerr << '"' << averaging_names[j] << "\" "; cerr << "} following \"" << argv[i - 1] << '"' << endl; usage( argv[0] ); return NONE; }
static double parse_double | ( | int | argc, |
int & | i | ||
) | [static] |
Definition at line 266 of file 2d_target_test.cpp.
References check_next_arg(), and usage.
{ check_next_arg( argc, argv, i ); char* endptr; double result = strtod( argv[i], &endptr ); if( endptr == argv[i] || *endptr ) { cerr << "Expected real number following \"" << argv[i - 1] << '"' << endl; usage( argv[0] ); } return result; }
static unsigned parse_metric | ( | int | argc, |
int & | i | ||
) | [static] |
Definition at line 300 of file 2d_target_test.cpp.
References check_next_arg(), comp_string_start(), metrics, n, and usage.
{ check_next_arg( argc, argv, i ); unsigned part = 0, all = 0, count = 0, have_all = 0; for( unsigned j = 0; metrics[j].u; ++j ) { if( unsigned k = comp_string_start( argv[i], metrics[j].n ) ) { if( k > 0 ) { all = j; have_all = 1; } else { part = j; ++count; } } } if( have_all ) return all; if( count ) { if( count == 1 ) return part; cerr << "Ambiguous metric name: \"" << argv[i] << '"' << endl; usage( argv[0] ); } cerr << "Invalid metric name following \"" << argv[i - 1] << "\" option" << endl; usage( argv[0] ); return (unsigned)-1; }
static void usage | ( | const char * | argv0, |
bool | help = false |
) | [static] |
Definition at line 231 of file 2d_target_test.cpp.
References averaging_names, DEFAULT_AVG_SCHEME, DEFAULT_INPUT_FILE, DEFAULT_METRIC_IDX, DEFAULT_OF_POWER, DEFAULT_OUTPUT_FILE, help(), and metrics.
{ ostream& str = help ? cout : cerr; str << argv0 << " [-p <power>] [-m metric_name] [-a averaging] [-e]" << " -r [ref_mesh] [input_file] [output_file]" << endl << argv0 << " <-l|-h>" << std::endl; if( help ) { str << " -p : specify exponent value for p-mean^p OF template (default: " << DEFAULT_OF_POWER << ")" << endl << " -m : specify 2D target metric to use (default: " << metrics[DEFAULT_METRIC_IDX].n << ")" << endl << " -a : specify metric averaging scheme (default: " << averaging_names[DEFAULT_AVG_SCHEME] << ")" << endl << " (none,vertex,element,patch)" << endl << " -e : sample at mid-edge points (default is corners only)" << endl << " -r : use reference mesh instead of ideal elements for targets" << endl << " -l : list available metrics" << endl << " -h : this help output" << endl << " default input file: " << DEFAULT_INPUT_FILE << endl << " default output file: " << DEFAULT_OUTPUT_FILE << endl << endl; } exit( !help ); }
const char* const averaging_names[] = { "none", "element", "vertex", "patch" } |
Definition at line 98 of file 2d_target_test.cpp.
Referenced by do_smoother(), parse_averaging(), and usage().
const AveragingScheme DEFAULT_AVG_SCHEME = NONE |
Definition at line 103 of file 2d_target_test.cpp.
std::string DEFAULT_INPUT_FILE = "/2D/vtk/quads/untangled/quads_4by2_bad.vtk" |
Definition at line 104 of file 2d_target_test.cpp.
const unsigned DEFAULT_METRIC_IDX = 0 |
Definition at line 102 of file 2d_target_test.cpp.
const double DEFAULT_OF_POWER = 1.0 |
Definition at line 101 of file 2d_target_test.cpp.
std::string DEFAULT_OUTPUT_FILE = "./out.vtk" |
Definition at line 105 of file 2d_target_test.cpp.
struct { ... } metrics[] [static] |
Referenced by do_smoother(), list_metrics(), main(), parse_metric(), and usage().
const char* n |
Definition at line 75 of file 2d_target_test.cpp.
Referenced by allocate_matrix(), moab::WriteSTL::ascii_write_triangles(), moab::WriteHDF5::assign_ids(), MBMesquite::PMeanPMetric::average_with_Hessian_diagonal(), moab::GeomUtil::box_tri_overlap(), moab::BoxPlaneIter::BoxPlaneIter(), moab::MeshGeneration::BrickInstance(), moab::BVHTree::build_tree(), MBMesquite::ArrayMesh::build_vertex_adjacency_list(), AveragingQMTest::check_average_and_weights(), MBMesquite::CompareQM::check_hess(), check_no_slaved_corners(), moab::WriteHDF5Parallel::check_serial_tag_data(), check_valid_adj_list(), check_valid_parents_children(), check_valid_set_contents(), moab::ParallelComm::clean_shared_tags(), moab::GeomUtil::closest_location_on_polygon(), TriStats::commafy(), moab::WriteHDF5Parallel::communicate_shared_set_ids(), moab::ParCommGraph::compute_partition(), contains_duplicates(), create_hex_mesh(), MBMesquite::create_ideal_element_patch(), create_mesh(), create_mesh_in_memory(), moab::WriteHDF5Parallel::create_tag_tables(), create_unitsq_quads(), create_unitsq_tris(), distance_from_origin(), LinearMappingFunctionTest::do_coeff_test(), LinearMappingFunctionTest::do_deriv_test(), dump_set_ranges(), moab::SmoothFace::DumpModelControlPoints(), moab::SpectralQuad::evalFcn(), MBMesquite::TShapeSizeB3::evaluate(), MBMesquite::AffineMapMetric::evaluate(), MBMesquite::VarianceTemplate::evaluate(), MBMesquite::IdealWeightMeanRatio::evaluate(), MBMesquite::IdealWeightInverseMeanRatio::evaluate(), MBMesquite::ConicDomain::evaluate(), moab::element_utility::Spectral_hex_map< moab::Matrix3 >::evaluate(), moab::Element::SpectralHex::evaluate(), moab::Element::SpectralQuad::evaluate(), moab::element_utility::Spectral_hex_map< moab::Matrix3 >::evaluate_scalar_field(), moab::Element::SpectralHex::evaluate_scalar_field(), moab::Element::SpectralQuad::evaluate_scalar_field(), MBMesquite::TMPQualityMetric::evaluate_surface_common(), MBMesquite::TShapeSizeB3::evaluate_with_grad(), MBMesquite::VarianceTemplate::evaluate_with_gradient(), MBMesquite::IdealWeightMeanRatio::evaluate_with_gradient(), MBMesquite::IdealWeightInverseMeanRatio::evaluate_with_gradient(), MBMesquite::TShapeSizeB3::evaluate_with_hess(), MBMesquite::AddQualityMetric::evaluate_with_Hessian(), MBMesquite::PatchPowerMeanP::evaluate_with_Hessian(), MBMesquite::IdealWeightMeanRatio::evaluate_with_Hessian(), MBMesquite::AWQualityMetric::evaluate_with_Hessian(), MBMesquite::TQualityMetric::evaluate_with_Hessian(), MBMesquite::PowerQualityMetric::evaluate_with_Hessian(), MBMesquite::LPtoPTemplate::evaluate_with_Hessian(), MBMesquite::IdealWeightInverseMeanRatio::evaluate_with_Hessian(), MBMesquite::MultiplyQualityMetric::evaluate_with_Hessian(), MBMesquite::PMeanPTemplate::evaluate_with_Hessian(), MBMesquite::VarianceTemplate::evaluate_with_Hessian_diagonal(), MBMesquite::IdealWeightMeanRatio::evaluate_with_Hessian_diagonal(), MBMesquite::IdealWeightInverseMeanRatio::evaluate_with_Hessian_diagonal(), MBMesquite::ElementQM::evaluate_with_indices(), MBMesquite::AffineMapMetric::evaluate_with_indices(), FauxMetric< B >::evaluate_with_indices(), find_block(), TopologyInfoTest::find_face(), TopologyInfoTest::find_side(), find_side(), moab::Skinner::find_skin_vertices_1D(), moab::Intx2MeshInPlane::findNodes(), moab::IntxRllCssphere::findNodes(), moab::Intx2MeshOnSphere::findNodes(), findpt_list_sort(), MBMesquite::PlanarDomain::fit_vertices(), gauss_nodes(), gauss_to_legendre(), gauss_to_legendre_t(), gauss_weights(), geometric_mean(), get_boundary_vertices(), MBMesquite::MsqMeshEntity::get_connected_vertices(), get_edge_lengths(), get_expected_ghosts(), QualityMetricTester::get_ideal_element(), moab::RefinerTagManager::get_input_gids(), CompareMetric::get_mask_axis(), CompareMetric::get_name(), moab::BSPTreeBoxIter::get_neighbors(), QualityMetricTester::get_nonideal_element(), moab::RefinerTagManager::get_output_gids(), moab::MeshSetSequence::get_parent_child_meshsets(), moab::ParallelComm::get_part_neighbor_ids(), MBMesquite::TargetCalculator::get_refmesh_Jacobian_2D(), MBMesquite::TargetCalculator::get_refmesh_Jacobian_3D(), get_slaved_coords(), moab::gs_data::gs_data_op_many(), hash_index_2(), hash_index_3(), hash_setfac_2(), hash_setfac_3(), heappermute(), moab::ElemUtil::hex_eval(), how_many_numbers(), iMeshP_getNumPartNborsArr(), iMeshP_getPartNborsArr(), MBMesquite::MeshWriter::Projection::init(), GaussIntegration::initialize(), moab::gs_data::initialize(), inner(), MBMesquite::inner(), MBMesquite::inner_product(), moab::Range::insert_list(), moab::element_utility::Spectral_hex_map< moab::Matrix3 >::integrate_scalar_field(), MBMesquite::is_side_boundary(), MBMesquite::TargetCalculator::jacobian_2D(), MBMesquite::TargetCalculator::jacobian_3D(), lagrange_0(), lagrange_1(), lagrange_2(), lagrange_2u(), lagrange_setup(), lagrange_weights(), lagrange_weights_deriv(), legendre(), legendre_d1(), legendre_d2(), legendre_matrix(), legendre_row_even(), MBMesquite::length_squared(), MBMesquite::Linf(), list_max(), list_metrics(), list_min(), moab::ReadSms::load_file_impl(), lob_bnd_base_alloc(), lob_bnd_base_setup(), lob_bnd_ext_alloc(), lobatto_nodes_aux(), lobatto_to_legendre(), lobatto_weights(), main(), moab::Element::Map::Map(), mb_adjacent_vertex_test(), mb_skin_full_common(), mb_skin_subset_common(), mb_upward_adjacencies_test(), merge_ranges(), moab::ElemUtil::nat_coords_trilinear_hex2(), MBMesquite::PatchData::non_slave_node_set(), obbox_calc_tfm_2(), opt_area_intp_2(), opt_edge_hess_2(), opt_edge_hess_3(), opt_edge_intp_2(), opt_edge_intp_3(), opt_vol_intp_3(), MBMesquite::SmartLaplacianSmoother::optimize_vertex_positions(), MBMesquite::LaplacianSmoother::optimize_vertex_positions(), moab::pack_tuples(), parse_metric(), PartMap::part_from_coords(), MBMesquite::plus_eq_scaled(), pmean(), MBMesquite::pmean_corner_diagonals(), MBMesquite::pmean_corner_hessians(), moab::AdaptiveKDTree::print(), moab::Core::print_database(), MBMesquite::project_to_perp_plane(), quad_all_in_xy_plane(), moab::range_to_blocked_list_templ(), moab::range_to_id_list_templ(), moab::ReadNASTRAN::read_element(), read_numbers(), moab::ReadHDF5::read_var_len_tag(), moab::SimplexTemplateRefiner::refine_entity(), refl(), moab::TypeSequenceManager::replace_subsequence(), run_smoother(), MBMesquite::MeshImpl::set_skin_flags(), moab::ParCommGraph::settle_comm_by_ids(), moab::ParCommGraph::settle_send_graph(), MBMesquite::CylinderDomain::snap_to(), MBMesquite::ConicDomain::snap_to(), moab::CN::SubEntityVertexIndices(), MBMesquite::sum_corner_diagonals(), MBMesquite::sum_corner_hessians(), sum_of_ratios_squared(), sum_sqr(), MBMesquite::sum_sqr_corner_diagonals(), MBMesquite::sum_sqr_corner_hessians(), tag_vals_from_gid(), tensor_c3(), tensor_r3(), TopologyInfoTest::test_adj(), MsqMeshEntityTest::test_all_nodes(), SphericalDomainTest::test_closest_point(), TetLagrangeShapeTest::test_corner_coeff(), TriLagrangeShapeTest::test_corner_derivs(), TetLagrangeShapeTest::test_corner_derivs(), test_create_ghost_ents(), test_create_tag(), test_create_var_len_tag(), PMeanPTemplateTest::test_diagonal(), QualityMetricTester::test_diagonal_with_fixed_vertex(), TetLagrangeShapeTest::test_edge_coeff(), TriLagrangeShapeTest::test_edge_derivs(), TetLagrangeShapeTest::test_edge_derivs(), TetLagrangeShapeTest::test_face_coeff(), TetLagrangeShapeTest::test_face_derivs(), test_get_set(), QualityMetricTester::test_gradient_reflects_quality(), QualityMetricTester::test_gradient_with_fixed_vertex(), PMeanPTemplateTest::test_Hessian(), QualityMetricTester::test_hessian_with_fixed_vertex(), QualityMetricTester::test_ideal_element_positive_definite_Hessian(), TetLagrangeShapeTest::test_invalid_nodebits_coeff(), TetLagrangeShapeTest::test_invalid_nodebits_deriv(), MappingFunctionTest::test_jacobian_2d(), TargetCalculatorTest::test_jacobian_2D(), MappingFunctionTest::test_jacobian_3d(), TargetCalculatorTest::test_jacobian_3D(), QualityMetricTester::test_measures_quality(), TetLagrangeShapeTest::test_mid_coeff(), TriLagrangeShapeTest::test_mid_derivs(), TetLagrangeShapeTest::test_mid_derivs(), PatchDataTest::test_num_corners(), QualityAssessorTest::test_print_stats(), TopologyInfoTest::test_rev_adj(), IdealElementTest::test_side_height_pyr(), QualityMetricTester::test_symmetric_Hessian_diagonal_blocks(), ArrayMeshTest::test_tag_data(), IdealElementTest::test_unit_height_pyr(), IdealElementTest::test_unit_pyr(), test_unitsq_quads(), test_unitsq_tris(), MBMesquite::DomainClassifier::test_valid_classification(), test_var_length_parallel(), MBMesquite::times_eq_minus(), MBMesquite::PatchData::update_cached_normals(), moab::EntityRefiner::update_heap_size(), moab::Intx2MeshOnSphere::update_tracer_data(), FakeMesh::vertices_get_attached_elements(), FakeMesh::vertices_get_fixed_flag(), TreeValidator::visit(), MBMesquite::TMPQualityMetric::weight(), moab::WriteVtk::write_bit_tag(), moab::WriteVtk::write_data(), ProgOptions::write_man_page(), moab::WriteHDF5::write_sets(), MBMesquite::MeshWriter::write_stl(), moab::WriteVtk::write_tag(), ManPage::write_text(), and XI_face().
Definition at line 74 of file 2d_target_test.cpp.
Referenced by moab::SmoothFace::ac_at_edge(), moab::ReadUtil::assign_ids(), MBMesquite::NodeSet::bit_to_bool(), center(), check_equal(), check_geometric_set(), MBMesquite::NodeSet::clear(), MBMesquite::NodeSet::clear_bit(), moab::MeshSet::contains_entities(), count_owned_entities(), create_some_mesh(), dN0dr(), dN0ds(), dN0dt(), dN4dr(), dN6ds(), dN7dt(), moab::TagInfo::equals_default_value(), MBMesquite::TMPQualityMetric::evaluate_surface_common(), CompareMetric::evaluate_with_Hessian_diagonal(), TopologyInfoTest::find_side(), FakeTargetCalc::get_2D_target(), FakeTargetCalc::get_3D_target(), MBMesquite::get_delta_C(), moab::WriteHDF5::get_set_info(), FakeTargetCalc::get_surface_target(), MBMesquite::MeshWriter::Projection::init(), MBMesquite::Instruction::initialize_vertex_byte(), moab::IntxUtils::intersect_great_circle_arc_with_clat_arc(), moab::BSPTreeBoxIter::intersects(), lagrange_weights(), lagrange_weights_deriv(), main(), make_basic_sequence(), mb_skin_higher_order_faces_common(), mb_skin_higher_order_regions_common(), mb_temporary_test(), moab::SmoothCurve::move_to_curve(), N0(), N4(), N6(), N7(), MBMesquite::NodeSet::num_before(), MBMesquite::NodeSet::num_before_bit(), moab::GeomQueryTool::point_in_volume(), MBMesquite::popcount(), MBMesquite::NodeSet::position(), moab::SmoothCurve::position_from_u(), MBMesquite::project_to_perp_plane(), moab::range_to_blocked_list_templ(), moab::ReadHDF5::read_dense_tag(), MBMesquite::NodeSet::set_bit(), setup_mesh(), moab::BSPTreeBoxIter::side_above_plane(), moab::BSPTreeBoxIter::side_on_plane(), MeshImplTest::skin_mesh_higher_order(), MeshImplTest::skin_mesh_mixed(), moab::FBEngine::split_edge_at_point(), moab::BSPTreeBoxIter::splits(), moab::OrientedBoxTreeTool::stats(), CachingTargetTest::test_2d_target_subpatch(), CachingTargetTest::test_2d_targets_cached(), CachingTargetTest::test_3d_target_subpatch(), CachingTargetTest::test_3d_targets_cached(), test_assign_global_ids(), test_bc_sets(), test_blocks(), test_box_iterator(), test_box_tree_create(), NodeSetTest::test_clear_node(), QuadLagrangeShapeTest::test_coeff_center(), QuadLagrangeShapeTest::test_coeff_corners(), QuadLagrangeShapeTest::test_coeff_edges(), QuadLagrangeShapeTest::test_deriv_center(), QuadLagrangeShapeTest::test_deriv_corners(), QuadLagrangeShapeTest::test_deriv_edges(), QualityMetricTest::test_fixed_vertex_list(), test_geometric_sets(), test_get_by_tag(), test_get_by_tag_value(), PatchDataTestNormals::test_get_element_normals_bounded_domain(), PatchDataTestNormals::test_get_element_normals_infinite_domain(), test_iterator(), test_merge_leaf(), NodeSetTest::test_num_before(), NodeSetTest::test_num_nodes(), test_pack_sets_simple(), VtkTest::test_read_quadratic(), QualityMetricTest::test_remove_fixed_gradients(), QualityMetricTest::test_remove_fixed_hessians(), test_set_flags(), NodeSetTest::test_set_node(), test_shared_sets(), CachingTargetTest::test_surface_target_subpatch(), CachingTargetTest::test_surface_targets_cached(), ArrayMeshTest::test_tag_data(), QualityAssessorTest::test_tag_element(), QualityAssessorTest::test_tag_inverted(), QualityAssessorTest::test_tag_vertex(), test_tree_create(), test_valid_struct(), test_write_elements(), iMeshTest::testDoubleTag(), iMeshTest::testIntTag(), moab::SmoothCurve::u_from_position(), moab::BitTag::unpack(), v_tet_aspect_frobenius(), IntxUtilsCSLAM::velocity_case1(), moab::HiReconstruction::walf3d_curve_vertex_eval(), and moab::HiReconstruction::walf3d_surf_vertex_eval().
