MOAB: Mesh Oriented datABase
(version 5.4.0)
00001 /* ***************************************************************** 00002 MESQUITE -- The Mesh Quality Improvement Toolkit 00003 00004 Copyright 2006 Sandia National Laboratories. Developed at the 00005 University of Wisconsin--Madison under SNL contract number 00006 624796. The U.S. Government and the University of Wisconsin 00007 retain certain rights to this software. 00008 00009 This library is free software; you can redistribute it and/or 00010 modify it under the terms of the GNU Lesser General Public 00011 License as published by the Free Software Foundation; either 00012 version 2.1 of the License, or (at your option) any later version. 00013 00014 This library is distributed in the hope that it will be useful, 00015 but WITHOUT ANY WARRANTY; without even the implied warranty of 00016 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00017 Lesser General Public License for more details. 00018 00019 You should have received a copy of the GNU Lesser General Public License 00020 (lgpl.txt) along with this library; if not, write to the Free Software 00021 Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA 00022 00023 (2006) kraftche@cae.wisc.edu 00024 00025 ***************************************************************** */ 00026 00027 /*! \file QualityMetricTest.cpp 00028 00029 Unit testing for the QualityMetric class 00030 \author Jason Kraftcheck 00031 */ 00032 #include "Mesquite.hpp" 00033 #include "VertexQM.hpp" 00034 #include "ElementQM.hpp" 00035 #include "IdealElements.hpp" 00036 #include "UnitUtil.hpp" 00037 #include "TopologyInfo.hpp" 00038 #include "PatchData.hpp" 00039 #include "cppunit/extensions/HelperMacros.h" 00040 #include "TMPDerivs.hpp" 00041 00042 #include <string> 00043 00044 using namespace MBMesquite; 00045 00046 class QualityMetricTest : public CppUnit::TestFixture 00047 { 00048 CPPUNIT_TEST_SUITE( QualityMetricTest ); 00049 CPPUNIT_TEST( test_fixed_vertex_list ); 00050 CPPUNIT_TEST( test_remove_fixed_gradients ); 00051 CPPUNIT_TEST( test_remove_fixed_hessians ); 00052 CPPUNIT_TEST( test_gradient_constant ); 00053 CPPUNIT_TEST( test_gradient_linear ); 00054 CPPUNIT_TEST( test_gradient_parabolic ); 00055 CPPUNIT_TEST( test_gradient_tau ); 00056 CPPUNIT_TEST( test_Hessian_constant ); 00057 CPPUNIT_TEST( test_Hessian_linear ); 00058 CPPUNIT_TEST( test_Hessian_parabolic ); 00059 CPPUNIT_TEST( test_Hessian_tau ); 00060 CPPUNIT_TEST( test_diagonal_constant ); 00061 CPPUNIT_TEST( test_diagonal_linear ); 00062 CPPUNIT_TEST( test_diagonal_parabolic ); 00063 CPPUNIT_TEST( test_diagonal_tau ); 00064 CPPUNIT_TEST_SUITE_END(); 00065 PatchData tri_pd; 00066 00067 public: 00068 void setUp(); 00069 00070 void test_fixed_vertex_list(); 00071 void test_remove_fixed_gradients(); 00072 void test_remove_fixed_hessians(); 00073 void test_gradient_constant(); 00074 void test_gradient_linear(); 00075 void test_gradient_parabolic(); 00076 void test_gradient_tau(); 00077 void test_Hessian_constant(); 00078 void test_Hessian_linear(); 00079 void test_Hessian_parabolic(); 00080 void test_Hessian_tau(); 00081 void test_diagonal_constant(); 00082 void test_diagonal_linear(); 00083 void test_diagonal_parabolic(); 00084 void test_diagonal_tau(); 00085 00086 void compare_indices( QualityMetric& qm, 00087 PatchData& pd, 00088 size_t sample, 00089 double value, 00090 const std::vector< size_t >& indices ); 00091 void compare_gradient( QualityMetric& qm, 00092 PatchData& pd, 00093 size_t sample, 00094 double value, 00095 const std::vector< size_t >& indices, 00096 const std::vector< Vector3D >& grad ); 00097 }; 00098 00099 CPPUNIT_TEST_SUITE_NAMED_REGISTRATION( QualityMetricTest, "QualityMetricTest" ); 00100 CPPUNIT_TEST_SUITE_NAMED_REGISTRATION( QualityMetricTest, "Unit" ); 00101 00102 // Create a single-triangle patch with one fixed vertex 00103 void QualityMetricTest::setUp() 00104 { 00105 MsqError err; 00106 const double vtx_coords[] = { 1, 0, 0, 0, 1, 0, 3, 0, 0, 0, 0, 0, 2, 1, 0 }; 00107 const size_t connectivity[] = { 0, 1, 3, 1, 2, 4 }; 00108 const bool fixed[] = { false, false, false, true, true }; 00109 tri_pd.fill( 5, vtx_coords, 2, TRIANGLE, connectivity, fixed, err ); 00110 CPPUNIT_ASSERT( !err ); 00111 } 00112 00113 // tolerance on numerical gradient/hessian values 00114 const double EPSILON = 5e-3; 00115 00116 /**\brief Fake quality metric for testing numerial gradient 00117 * 00118 * Implement a vertex metric for which the "quality" at a given 00119 * vertex is the value of the x-coordinate of that vertex. Thus 00120 * the gradient of the "quality" at every vertex should be {1,0,0}. 00121 */ 00122 class LinearVertexMetric : public VertexQM 00123 { 00124 public: 00125 std::string get_name() const 00126 { 00127 return "Fake metric for testing numerical gradient"; 00128 } 00129 int get_negate_flag() const 00130 { 00131 return 1; 00132 } 00133 bool evaluate( PatchData& pd, size_t vtx_idx, double& value, MsqError& ) 00134 { 00135 value = pd.vertex_by_index( vtx_idx )[0]; 00136 return true; 00137 } 00138 bool evaluate_with_indices( PatchData& pd, 00139 size_t vtx_idx, 00140 double& value, 00141 std::vector< size_t >& indices, 00142 MsqError& ) 00143 { 00144 value = pd.vertex_by_index( vtx_idx )[0]; 00145 indices.resize( 1 ); 00146 indices[0] = vtx_idx; 00147 return true; 00148 } 00149 }; 00150 00151 /**\brief Fake quality metric for testing numerial gradient 00152 * 00153 * Implement an element metric for which the "quality" is always 1.0. 00154 * The resulting gradient and Hessian should always be zero. 00155 */ 00156 class ConstantElementMetric : public ElementQM 00157 { 00158 public: 00159 std::string get_name() const 00160 { 00161 return "Fake metric for testing numerical gradient"; 00162 } 00163 int get_negate_flag() const 00164 { 00165 return 1; 00166 } 00167 bool evaluate( PatchData& pd, size_t, double& value, MsqError& ) 00168 { 00169 value = 1.0; 00170 return true; 00171 } 00172 bool evaluate_with_indices( PatchData& pd, 00173 size_t elem_idx, 00174 double& value, 00175 std::vector< size_t >& indices, 00176 MsqError& ) 00177 { 00178 MsqMeshEntity& elem = pd.element_by_index( elem_idx ); 00179 unsigned nv = elem.node_count(); 00180 const size_t* conn = elem.get_vertex_index_array(); 00181 indices.clear(); 00182 for( unsigned i = 0; i < nv; ++i ) 00183 if( conn[i] < pd.num_free_vertices() ) indices.push_back( conn[i] ); 00184 00185 value = 1.0; 00186 return true; 00187 } 00188 }; 00189 00190 /**\brief Fake quality metric for testing numerial gradient 00191 * 00192 * Implement a vertex metric for which the "quality" at a given 00193 * vertex is the square of the value of the y-coordinate of that vertex. Thus 00194 * the Hessian of the "quality" at every vertex should be {2,0,0}. 00195 */ 00196 class ParabolicVertexMetric : public VertexQM 00197 { 00198 public: 00199 std::string get_name() const 00200 { 00201 return "Fake metric for testing numerical gradient"; 00202 } 00203 int get_negate_flag() const 00204 { 00205 return 1; 00206 } 00207 bool evaluate( PatchData& pd, size_t vtx_idx, double& value, MsqError& ) 00208 { 00209 value = pd.vertex_by_index( vtx_idx )[1]; 00210 value *= value; 00211 return true; 00212 } 00213 bool evaluate_with_indices( PatchData& pd, 00214 size_t vtx_idx, 00215 double& value, 00216 std::vector< size_t >& indices, 00217 MsqError& ) 00218 { 00219 value = pd.vertex_by_index( vtx_idx )[1]; 00220 value *= value; 00221 indices.resize( 1 ); 00222 indices[0] = vtx_idx; 00223 return true; 00224 } 00225 }; 00226 00227 /**\brief More complex fake metric for testing finite difference 00228 * 00229 * Calculate /f$ (det(M)-1)^2 /f$ where the rows of M are the 00230 * coordinates of the three vertices in the triangle. 00231 */ 00232 class TriTauMetric : public ElementQM 00233 { 00234 public: 00235 std::string get_name() const 00236 { 00237 return "Triangle Tau Metric"; 00238 } 00239 int get_negate_flag() const 00240 { 00241 return 1; 00242 } 00243 MsqMatrix< 3, 3 > matrix( PatchData& pd, size_t elem_idx ) 00244 { 00245 MsqMeshEntity& elem = pd.element_by_index( elem_idx ); 00246 unsigned nv = elem.node_count(); 00247 const size_t* conn = elem.get_vertex_index_array(); 00248 CPPUNIT_ASSERT( nv == 3 ); 00249 00250 MsqMatrix< 3, 3 > M; 00251 M.set_row( 0, pd.vertex_by_index( conn[0] ).to_array() ); 00252 M.set_row( 1, pd.vertex_by_index( conn[1] ).to_array() ); 00253 M.set_row( 2, pd.vertex_by_index( conn[2] ).to_array() ); 00254 00255 return M; 00256 } 00257 00258 bool evaluate( PatchData& pd, size_t element_idx, double& value, MsqError& ) 00259 { 00260 MsqMatrix< 3, 3 > M = matrix( pd, element_idx ); 00261 value = det( M ) - 1; 00262 value *= value; 00263 return true; 00264 } 00265 00266 bool evaluate_with_indices( PatchData& pd, 00267 size_t elem_idx, 00268 double& value, 00269 std::vector< size_t >& indices, 00270 MsqError& ) 00271 { 00272 MsqMatrix< 3, 3 > M = matrix( pd, elem_idx ); 00273 value = det( M ) - 1; 00274 value *= value; 00275 00276 indices.clear(); 00277 unsigned nv = pd.element_by_index( elem_idx ).node_count(); 00278 const size_t* conn = pd.element_by_index( elem_idx ).get_vertex_index_array(); 00279 for( unsigned i = 0; i < nv; ++i ) 00280 if( pd.is_vertex_free( conn[i] ) ) indices.push_back( conn[i] ); 00281 00282 return true; 00283 } 00284 }; 00285 00286 void QualityMetricTest::test_fixed_vertex_list() 00287 { 00288 // define a patch of four quads such that 00289 // the number of fixed vertices in each quad 00290 // varies from 0 to 3 00291 /* 2------1-----8 00292 * | | |\ 00293 * | (0) | (3) | \ 00294 * | | | \ 00295 * 3------0-----7 \ 00296 * | | |\ \ 00297 * | (1) | (2) | \ \ 00298 * | | | \ \ 00299 * 4------5-----6 \ \ 00300 * \____\____\___\__ fixed 00301 */ 00302 const double coords[] = { 0, 0, 0, 0, 1, 0, -1, 1, 0, -1, 0, 0, -1, -1, 0, 0, -1, 0, 1, -1, 0, 1, 0, 0, 1, 1, 0 }; 00303 const size_t conn[] = { 0, 1, 2, 3, 3, 4, 5, 0, 6, 7, 0, 5, 0, 7, 8, 1 }; 00304 const bool fixed[] = { false, false, false, false, false, true, true, true, true }; 00305 00306 MsqPrintError err( std::cout ); 00307 PatchData pd; 00308 pd.fill( 9, coords, 4, QUADRILATERAL, conn, fixed, err ); 00309 ASSERT_NO_ERROR( err ); 00310 00311 uint32_t bits; 00312 std::vector< size_t > indices; 00313 std::vector< size_t >::iterator it; 00314 const size_t* verts; 00315 unsigned i; 00316 00317 indices.clear(); 00318 bits = QualityMetric::fixed_vertex_bitmap( pd, &pd.element_by_index( 0 ), indices ); 00319 CPPUNIT_ASSERT_EQUAL( (size_t)4, indices.size() ); 00320 CPPUNIT_ASSERT_EQUAL( (uint32_t)0, bits & 0xF ); 00321 CPPUNIT_ASSERT( pd.num_free_vertices() > *std::max_element( indices.begin(), indices.end() ) ); 00322 verts = pd.element_by_index( 0 ).get_vertex_index_array(); 00323 for( i = 0; i < 4; ++i ) 00324 CPPUNIT_ASSERT( std::find( verts, verts + 4, indices[i] ) != verts + 4 ); 00325 00326 indices.clear(); 00327 bits = QualityMetric::fixed_vertex_bitmap( pd, &pd.element_by_index( 1 ), indices ); 00328 CPPUNIT_ASSERT_EQUAL( (size_t)3, indices.size() ); 00329 verts = pd.element_by_index( 1 ).get_vertex_index_array(); 00330 for( i = 0; i < 4; ++i ) 00331 { 00332 it = std::find( indices.begin(), indices.end(), verts[i] ); 00333 if( verts[i] < pd.num_free_vertices() ) 00334 { 00335 CPPUNIT_ASSERT( it != indices.end() ); 00336 CPPUNIT_ASSERT_EQUAL( 0u, bits & ( 1 << i ) ); 00337 } 00338 else 00339 { 00340 CPPUNIT_ASSERT( it == indices.end() ); 00341 CPPUNIT_ASSERT_EQUAL( 1u, ( bits >> i ) & 1 ); 00342 } 00343 } 00344 00345 indices.clear(); 00346 bits = QualityMetric::fixed_vertex_bitmap( pd, &pd.element_by_index( 2 ), indices ); 00347 CPPUNIT_ASSERT_EQUAL( (size_t)1, indices.size() ); 00348 verts = pd.element_by_index( 2 ).get_vertex_index_array(); 00349 for( i = 0; i < 4; ++i ) 00350 { 00351 it = std::find( indices.begin(), indices.end(), verts[i] ); 00352 if( verts[i] < pd.num_free_vertices() ) 00353 { 00354 CPPUNIT_ASSERT( it != indices.end() ); 00355 CPPUNIT_ASSERT_EQUAL( 0u, bits & ( 1 << i ) ); 00356 } 00357 else 00358 { 00359 CPPUNIT_ASSERT( it == indices.end() ); 00360 CPPUNIT_ASSERT_EQUAL( 1u, ( bits >> i ) & 1 ); 00361 } 00362 } 00363 00364 indices.clear(); 00365 bits = QualityMetric::fixed_vertex_bitmap( pd, &pd.element_by_index( 3 ), indices ); 00366 CPPUNIT_ASSERT_EQUAL( (size_t)2, indices.size() ); 00367 verts = pd.element_by_index( 3 ).get_vertex_index_array(); 00368 for( i = 0; i < 4; ++i ) 00369 { 00370 it = std::find( indices.begin(), indices.end(), verts[i] ); 00371 if( verts[i] < pd.num_free_vertices() ) 00372 { 00373 CPPUNIT_ASSERT( it != indices.end() ); 00374 CPPUNIT_ASSERT_EQUAL( 0u, bits & ( 1 << i ) ); 00375 } 00376 else 00377 { 00378 CPPUNIT_ASSERT( it == indices.end() ); 00379 CPPUNIT_ASSERT_EQUAL( 1u, ( bits >> i ) & 1 ); 00380 } 00381 } 00382 } 00383 00384 void QualityMetricTest::test_remove_fixed_gradients() 00385 { 00386 // define a list of vectors 00387 std::vector< Vector3D > grads( 6 ); 00388 grads[0] = Vector3D( 0, 0, 0 ); 00389 grads[1] = Vector3D( 1, 1, 1 ); 00390 grads[2] = Vector3D( 2, 2, 2 ); 00391 grads[3] = Vector3D( 3, 3, 3 ); 00392 grads[4] = Vector3D( 4, 4, 4 ); 00393 grads[5] = Vector3D( 5, 5, 5 ); 00394 // remove the first, third, and last 00395 uint32_t flags = 1u | 4u | 32u; 00396 // call function, choose element type w/ correct number of corners 00397 QualityMetric::remove_fixed_gradients( PRISM, flags, grads ); 00398 // check results 00399 CPPUNIT_ASSERT_EQUAL( (size_t)3, grads.size() ); 00400 CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 1, 1, 1 ), grads[0], DBL_EPSILON ); 00401 CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 3, 3, 3 ), grads[1], DBL_EPSILON ); 00402 CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 4, 4, 4 ), grads[2], DBL_EPSILON ); 00403 } 00404 00405 void QualityMetricTest::test_remove_fixed_hessians() 00406 { 00407 // define Hessian matrix for a quadrilateral 00408 Matrix3D m[10] = { Matrix3D( 0.0 ), Matrix3D( 1.0 ), Matrix3D( 2.0 ), Matrix3D( 3.0 ), Matrix3D( 4.0 ), 00409 Matrix3D( 5.0 ), Matrix3D( 6.0 ), Matrix3D( 7.0 ), Matrix3D( 8.0 ), Matrix3D( 9.0 ) }; 00410 // convert to std::vector 00411 std::vector< Matrix3D > hess( 10 ); 00412 std::copy( m, m + 10, hess.begin() ); 00413 // mark fist and third vertices as fixed 00414 uint32_t flags = 1u | 4u; 00415 // call function to remove grads for fixed vertices 00416 QualityMetric::remove_fixed_hessians( QUADRILATERAL, flags, hess ); 00417 // the submatrix with the first and third rows/columns removed should be 00418 // { 4, 6, 00419 // 9 } 00420 CPPUNIT_ASSERT_EQUAL( (size_t)3, hess.size() ); 00421 CPPUNIT_ASSERT_MATRICES_EQUAL( Matrix3D( 4.0 ), hess[0], DBL_EPSILON ); 00422 CPPUNIT_ASSERT_MATRICES_EQUAL( Matrix3D( 6.0 ), hess[1], DBL_EPSILON ); 00423 CPPUNIT_ASSERT_MATRICES_EQUAL( Matrix3D( 9.0 ), hess[2], DBL_EPSILON ); 00424 } 00425 00426 void QualityMetricTest::test_gradient_constant() 00427 { 00428 MsqError err; 00429 std::vector< size_t > indices; 00430 std::vector< Vector3D > gradient; 00431 double value; 00432 size_t ELEMENT = 0; 00433 00434 ConstantElementMetric constant; 00435 QualityMetric& qm = constant; 00436 00437 bool valid = qm.evaluate_with_gradient( tri_pd, ELEMENT, value, indices, gradient, err ); 00438 CPPUNIT_ASSERT( !err ); 00439 CPPUNIT_ASSERT( valid ); 00440 compare_indices( qm, tri_pd, ELEMENT, value, indices ); 00441 CPPUNIT_ASSERT_EQUAL( indices.size(), gradient.size() ); 00442 CPPUNIT_ASSERT_EQUAL( (size_t)2, indices.size() ); // two free vertices in triangle 00443 00444 CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 0, 0, 0 ), gradient[0], EPSILON ); 00445 CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 0, 0, 0 ), gradient[1], EPSILON ); 00446 } 00447 00448 void QualityMetricTest::test_gradient_linear() 00449 { 00450 MsqError err; 00451 std::vector< size_t > indices; 00452 std::vector< Vector3D > gradient; 00453 double value; 00454 size_t VERTEX = 0; 00455 00456 LinearVertexMetric linear; 00457 QualityMetric& qm = linear; 00458 00459 bool valid = qm.evaluate_with_gradient( tri_pd, VERTEX, value, indices, gradient, err ); 00460 CPPUNIT_ASSERT( !err ); 00461 CPPUNIT_ASSERT( valid ); 00462 compare_indices( qm, tri_pd, VERTEX, value, indices ); 00463 CPPUNIT_ASSERT_EQUAL( indices.size(), gradient.size() ); 00464 CPPUNIT_ASSERT_EQUAL( (size_t)1, indices.size() ); 00465 CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 1, 0, 0 ), gradient[0], EPSILON ); 00466 } 00467 00468 void QualityMetricTest::test_gradient_parabolic() 00469 { 00470 const size_t VERTEX = 1; // pick vertex with non-zero Y-coordinate 00471 MsqError err; 00472 std::vector< size_t > indices; 00473 std::vector< Vector3D > gradient; 00474 double value; 00475 00476 ParabolicVertexMetric parab; 00477 QualityMetric& qm = parab; 00478 00479 bool valid = qm.evaluate_with_gradient( tri_pd, VERTEX, value, indices, gradient, err ); 00480 CPPUNIT_ASSERT( !err ); 00481 CPPUNIT_ASSERT( valid ); 00482 compare_indices( qm, tri_pd, VERTEX, value, indices ); 00483 CPPUNIT_ASSERT_EQUAL( indices.size(), gradient.size() ); 00484 CPPUNIT_ASSERT_EQUAL( (size_t)1, indices.size() ); // two free vertices in triangle 00485 00486 const double expected_y = 2 * tri_pd.vertex_by_index( VERTEX )[1]; 00487 CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 0, expected_y, 0 ), gradient[0], EPSILON ); 00488 } 00489 00490 void QualityMetricTest::test_gradient_tau() 00491 { 00492 MsqError err; 00493 std::vector< size_t > indices; 00494 std::vector< Vector3D > gradient; 00495 double value; 00496 size_t ELEMENT = 1; 00497 00498 TriTauMetric qm; 00499 00500 bool valid = qm.evaluate_with_gradient( tri_pd, ELEMENT, value, indices, gradient, err ); 00501 CPPUNIT_ASSERT( !err ); 00502 CPPUNIT_ASSERT( valid ); 00503 compare_indices( qm, tri_pd, ELEMENT, value, indices ); 00504 CPPUNIT_ASSERT_EQUAL( indices.size(), gradient.size() ); 00505 CPPUNIT_ASSERT_EQUAL( (size_t)2, indices.size() ); // two free vertices in triangle 00506 00507 MsqMatrix< 3, 3 > M = qm.matrix( tri_pd, ELEMENT ); 00508 MsqMatrix< 3, 3 > dM = transpose( adj( M ) ); 00509 dM *= 2 * ( det( M ) - 1 ); 00510 00511 if( indices[0] == 2 ) 00512 { 00513 CPPUNIT_ASSERT_EQUAL( (size_t)1, indices[1] ); 00514 std::swap( indices[0], indices[1] ); 00515 std::swap( gradient[0], gradient[1] ); 00516 } 00517 else 00518 { 00519 CPPUNIT_ASSERT_EQUAL( (size_t)1, indices[0] ); 00520 CPPUNIT_ASSERT_EQUAL( (size_t)2, indices[1] ); 00521 } 00522 CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( dM.row( 0 ).data() ), gradient[0], EPSILON ); 00523 CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( dM.row( 1 ).data() ), gradient[1], EPSILON ); 00524 } 00525 00526 void QualityMetricTest::test_Hessian_constant() 00527 { 00528 MsqError err; 00529 std::vector< size_t > indices; 00530 std::vector< Vector3D > gradient; 00531 std::vector< Matrix3D > Hessian; 00532 double value; 00533 size_t ELEMENT = 0; 00534 00535 ConstantElementMetric constant; 00536 QualityMetric& qm = constant; 00537 00538 bool valid = qm.evaluate_with_Hessian( tri_pd, ELEMENT, value, indices, gradient, Hessian, err ); 00539 CPPUNIT_ASSERT( !err ); 00540 CPPUNIT_ASSERT( valid ); 00541 compare_gradient( qm, tri_pd, ELEMENT, value, indices, gradient ); 00542 CPPUNIT_ASSERT_EQUAL( indices.size() * ( indices.size() + 1 ) / 2, Hessian.size() ); 00543 CPPUNIT_ASSERT_EQUAL( (size_t)2, indices.size() ); 00544 00545 CPPUNIT_ASSERT_MATRICES_EQUAL( Matrix3D( 0.0 ), Hessian[0], EPSILON ); 00546 CPPUNIT_ASSERT_MATRICES_EQUAL( Matrix3D( 0.0 ), Hessian[1], EPSILON ); 00547 } 00548 00549 void QualityMetricTest::test_Hessian_linear() 00550 { 00551 MsqError err; 00552 std::vector< size_t > indices; 00553 std::vector< Vector3D > gradient; 00554 std::vector< Matrix3D > Hessian; 00555 double value; 00556 size_t VERTEX = 0; 00557 00558 LinearVertexMetric linear; 00559 QualityMetric& qm = linear; 00560 00561 bool valid = qm.evaluate_with_Hessian( tri_pd, VERTEX, value, indices, gradient, Hessian, err ); 00562 CPPUNIT_ASSERT( !err ); 00563 CPPUNIT_ASSERT( valid ); 00564 compare_gradient( qm, tri_pd, VERTEX, value, indices, gradient ); 00565 CPPUNIT_ASSERT_EQUAL( indices.size() * ( indices.size() + 1 ) / 2, Hessian.size() ); 00566 CPPUNIT_ASSERT_EQUAL( (size_t)1, indices.size() ); 00567 CPPUNIT_ASSERT_MATRICES_EQUAL( Matrix3D( 0.0 ), Hessian[0], EPSILON ); 00568 } 00569 00570 void QualityMetricTest::test_Hessian_parabolic() 00571 { 00572 MsqError err; 00573 std::vector< size_t > indices; 00574 std::vector< Vector3D > gradient; 00575 std::vector< Matrix3D > Hessian; 00576 double value; 00577 size_t VERTEX = 0; 00578 00579 ParabolicVertexMetric parab; 00580 QualityMetric& qm = parab; 00581 00582 bool valid = qm.evaluate_with_Hessian( tri_pd, VERTEX, value, indices, gradient, Hessian, err ); 00583 CPPUNIT_ASSERT( !err ); 00584 CPPUNIT_ASSERT( valid ); 00585 compare_gradient( qm, tri_pd, VERTEX, value, indices, gradient ); 00586 CPPUNIT_ASSERT_EQUAL( indices.size() * ( indices.size() + 1 ) / 2, Hessian.size() ); 00587 CPPUNIT_ASSERT_EQUAL( (size_t)1, indices.size() ); 00588 00589 Matrix3D expected( 0.0, 0.0, 0.0, 0.0, 2.0, 0.0, 0.0, 0.0, 0.0 ); 00590 CPPUNIT_ASSERT_MATRICES_EQUAL( expected, Hessian[0], EPSILON ); 00591 } 00592 00593 void QualityMetricTest::test_Hessian_tau() 00594 { 00595 MsqError err; 00596 std::vector< size_t > indices; 00597 std::vector< Vector3D > gradient; 00598 std::vector< Matrix3D > Hessian; 00599 double value; 00600 size_t ELEMENT = 1; 00601 00602 TriTauMetric qm; 00603 00604 bool valid = qm.evaluate_with_Hessian( tri_pd, ELEMENT, value, indices, gradient, Hessian, err ); 00605 CPPUNIT_ASSERT( !err ); 00606 CPPUNIT_ASSERT( valid ); 00607 compare_gradient( qm, tri_pd, ELEMENT, value, indices, gradient ); 00608 CPPUNIT_ASSERT_EQUAL( indices.size() * ( indices.size() + 1 ) / 2, Hessian.size() ); 00609 CPPUNIT_ASSERT_EQUAL( (size_t)2, indices.size() ); // two free vertices in triangle 00610 00611 MsqMatrix< 3, 3 > M = qm.matrix( tri_pd, ELEMENT ); 00612 MsqMatrix< 3, 3 > d2M[6]; 00613 set_scaled_2nd_deriv_of_det( d2M, 2 * ( det( M ) - 1 ), M ); 00614 pluseq_scaled_outer_product( d2M, 2, transpose( adj( M ) ) ); 00615 00616 if( indices[0] == 2 ) 00617 { 00618 CPPUNIT_ASSERT_EQUAL( (size_t)1, indices[1] ); 00619 std::swap( indices[0], indices[1] ); 00620 std::swap( gradient[0], gradient[1] ); 00621 std::swap( Hessian[0], Hessian[2] ); 00622 Hessian[1] = transpose( Hessian[1] ); 00623 } 00624 else 00625 { 00626 CPPUNIT_ASSERT_EQUAL( (size_t)1, indices[0] ); 00627 CPPUNIT_ASSERT_EQUAL( (size_t)2, indices[1] ); 00628 } 00629 00630 CPPUNIT_ASSERT_MATRICES_EQUAL( Matrix3D( d2M[0].data() ), Hessian[0], EPSILON ); 00631 CPPUNIT_ASSERT_MATRICES_EQUAL( Matrix3D( d2M[1].data() ), Hessian[1], EPSILON ); 00632 CPPUNIT_ASSERT_MATRICES_EQUAL( Matrix3D( d2M[3].data() ), Hessian[2], EPSILON ); 00633 } 00634 00635 void QualityMetricTest::test_diagonal_constant() 00636 { 00637 MsqError err; 00638 std::vector< size_t > indices; 00639 std::vector< Vector3D > gradient; 00640 std::vector< SymMatrix3D > Hessian; 00641 double value; 00642 size_t ELEMENT = 0; 00643 00644 ConstantElementMetric constant; 00645 QualityMetric& qm = constant; 00646 00647 bool valid = qm.evaluate_with_Hessian_diagonal( tri_pd, ELEMENT, value, indices, gradient, Hessian, err ); 00648 CPPUNIT_ASSERT( !err ); 00649 CPPUNIT_ASSERT( valid ); 00650 compare_gradient( qm, tri_pd, ELEMENT, value, indices, gradient ); 00651 CPPUNIT_ASSERT_EQUAL( indices.size(), Hessian.size() ); 00652 CPPUNIT_ASSERT_EQUAL( (size_t)2, indices.size() ); 00653 00654 CPPUNIT_ASSERT_MATRICES_EQUAL( SymMatrix3D( 0.0 ), Hessian[0], EPSILON ); 00655 CPPUNIT_ASSERT_MATRICES_EQUAL( SymMatrix3D( 0.0 ), Hessian[1], EPSILON ); 00656 } 00657 00658 void QualityMetricTest::test_diagonal_linear() 00659 { 00660 MsqError err; 00661 std::vector< size_t > indices; 00662 std::vector< Vector3D > gradient; 00663 std::vector< SymMatrix3D > Hessian; 00664 double value; 00665 size_t VERTEX = 0; 00666 00667 LinearVertexMetric linear; 00668 QualityMetric& qm = linear; 00669 00670 bool valid = qm.evaluate_with_Hessian_diagonal( tri_pd, VERTEX, value, indices, gradient, Hessian, err ); 00671 CPPUNIT_ASSERT( !err ); 00672 CPPUNIT_ASSERT( valid ); 00673 compare_gradient( qm, tri_pd, VERTEX, value, indices, gradient ); 00674 CPPUNIT_ASSERT_EQUAL( indices.size(), Hessian.size() ); 00675 CPPUNIT_ASSERT_EQUAL( (size_t)1, indices.size() ); 00676 CPPUNIT_ASSERT_MATRICES_EQUAL( SymMatrix3D( 0.0 ), Hessian[0], EPSILON ); 00677 } 00678 00679 void QualityMetricTest::test_diagonal_parabolic() 00680 { 00681 MsqError err; 00682 std::vector< size_t > indices; 00683 std::vector< Vector3D > gradient; 00684 std::vector< SymMatrix3D > Hessian; 00685 double value; 00686 size_t VERTEX = 0; 00687 00688 ParabolicVertexMetric parab; 00689 QualityMetric& qm = parab; 00690 00691 bool valid = qm.evaluate_with_Hessian_diagonal( tri_pd, VERTEX, value, indices, gradient, Hessian, err ); 00692 CPPUNIT_ASSERT( !err ); 00693 CPPUNIT_ASSERT( valid ); 00694 compare_gradient( qm, tri_pd, VERTEX, value, indices, gradient ); 00695 CPPUNIT_ASSERT_EQUAL( indices.size(), Hessian.size() ); 00696 CPPUNIT_ASSERT_EQUAL( (size_t)1, indices.size() ); 00697 00698 SymMatrix3D expected( 0.0, 0.0, 0.0, 2.0, 0.0, 0.0 ); 00699 CPPUNIT_ASSERT_MATRICES_EQUAL( expected, Hessian[0], EPSILON ); 00700 } 00701 00702 void QualityMetricTest::test_diagonal_tau() 00703 { 00704 MsqError err; 00705 std::vector< size_t > indices; 00706 std::vector< Vector3D > gradient; 00707 std::vector< SymMatrix3D > Hessian; 00708 double value; 00709 size_t ELEMENT = 1; 00710 00711 TriTauMetric qm; 00712 00713 bool valid = qm.evaluate_with_Hessian_diagonal( tri_pd, ELEMENT, value, indices, gradient, Hessian, err ); 00714 CPPUNIT_ASSERT( !err ); 00715 CPPUNIT_ASSERT( valid ); 00716 compare_gradient( qm, tri_pd, ELEMENT, value, indices, gradient ); 00717 CPPUNIT_ASSERT_EQUAL( indices.size(), Hessian.size() ); 00718 CPPUNIT_ASSERT_EQUAL( (size_t)2, indices.size() ); // two free vertices in triangle 00719 00720 MsqMatrix< 3, 3 > M = qm.matrix( tri_pd, ELEMENT ); 00721 MsqMatrix< 3, 3 > d2M[6]; 00722 set_scaled_2nd_deriv_of_det( d2M, 2 * ( det( M ) - 1 ), M ); 00723 pluseq_scaled_outer_product( d2M, 2, transpose( adj( M ) ) ); 00724 00725 if( indices[0] == 2 ) 00726 { 00727 CPPUNIT_ASSERT_EQUAL( (size_t)1, indices[1] ); 00728 std::swap( indices[0], indices[1] ); 00729 std::swap( gradient[0], gradient[1] ); 00730 std::swap( Hessian[0], Hessian[1] ); 00731 } 00732 else 00733 { 00734 CPPUNIT_ASSERT_EQUAL( (size_t)1, indices[0] ); 00735 CPPUNIT_ASSERT_EQUAL( (size_t)2, indices[1] ); 00736 } 00737 00738 SymMatrix3D exp0( d2M[0]( 0, 0 ), d2M[0]( 0, 1 ), d2M[0]( 0, 2 ), d2M[0]( 1, 1 ), d2M[0]( 1, 2 ), d2M[0]( 2, 2 ) ); 00739 SymMatrix3D exp1( d2M[3]( 0, 0 ), d2M[3]( 0, 1 ), d2M[3]( 0, 2 ), d2M[3]( 1, 1 ), d2M[3]( 1, 2 ), d2M[3]( 2, 2 ) ); 00740 00741 CPPUNIT_ASSERT_MATRICES_EQUAL( exp0, Hessian[0], EPSILON ); 00742 CPPUNIT_ASSERT_MATRICES_EQUAL( exp1, Hessian[1], EPSILON ); 00743 } 00744 00745 void QualityMetricTest::compare_indices( QualityMetric& qm, 00746 PatchData& pd, 00747 size_t sample, 00748 double value, 00749 const std::vector< size_t >& indices ) 00750 { 00751 double value2; 00752 std::vector< size_t > indices2; 00753 MsqError err; 00754 bool valid = qm.evaluate_with_indices( pd, sample, value2, indices2, err ); 00755 ASSERT_NO_ERROR( err ); 00756 CPPUNIT_ASSERT( valid ); 00757 CPPUNIT_ASSERT_DOUBLES_EQUAL( value2, value, EPSILON ); 00758 std::vector< size_t > indices1( indices ); 00759 std::sort( indices1.begin(), indices1.end() ); 00760 std::sort( indices2.begin(), indices2.end() ); 00761 ASSERT_STD_VECTORS_EQUAL( indices2, indices1 ); 00762 } 00763 00764 void QualityMetricTest::compare_gradient( QualityMetric& qm, 00765 PatchData& pd, 00766 size_t sample, 00767 double value, 00768 const std::vector< size_t >& indices, 00769 const std::vector< Vector3D >& grad ) 00770 { 00771 double value2; 00772 std::vector< size_t > indices2; 00773 std::vector< Vector3D > grad2; 00774 MsqError err; 00775 bool valid = qm.evaluate_with_gradient( pd, sample, value2, indices2, grad2, err ); 00776 ASSERT_NO_ERROR( err ); 00777 CPPUNIT_ASSERT( valid ); 00778 CPPUNIT_ASSERT_DOUBLES_EQUAL( value2, value, EPSILON ); 00779 CPPUNIT_ASSERT_EQUAL( indices2.size(), indices.size() ); 00780 CPPUNIT_ASSERT_EQUAL( indices.size(), grad.size() ); 00781 00782 for( size_t i = 0; i < indices.size(); ++i ) 00783 { 00784 size_t j = std::find( indices2.begin(), indices2.end(), indices[i] ) - indices2.begin(); 00785 CPPUNIT_ASSERT( j < indices2.size() ); // not found->indices don't match 00786 CPPUNIT_ASSERT_VECTORS_EQUAL( grad2[j], grad[i], EPSILON ); 00787 } 00788 }
