MOAB: Mesh Oriented datABase
(version 5.2.1)
Vector3D is the object that effeciently stores information about about three-deminsional vectors. It is also the parent class of MsqVertex. More...
#include <Vector3D.hpp>
Public Member Functions | |
Vector3D () | |
Vector3D (double xyz) | |
Vector3D (double x, double y, double z) | |
Vector3D (const double xyz[3]) | |
Vector3D (const Vector3D &to_copy) | |
double | x () const |
double | y () const |
double | z () const |
void | get_coordinates (double &x, double &y, double &z) const |
void | get_coordinates (double xyz[3]) const |
const double & | operator[] (size_t index) const |
void | x (const double x) |
void | y (const double y) |
void | z (const double z) |
void | set (const double x, const double y, const double z) |
void | set (const double xyz[3]) |
void | set (const Vector3D &to_copy) |
double & | operator[] (size_t index) |
Vector3D & | operator= (const Vector3D &to_copy) |
Vector3D & | operator= (const double &to_copy) |
Vector3D | operator- () const |
Vector3D & | operator*= (const double scalar) |
Vector3D & | operator/= (const double scalar) |
divides each Vector3D entry by the given scalar. | |
Vector3D & | operator*= (const Vector3D &rhs) |
Vector3D & | operator+= (const Vector3D &rhs) |
Vector3D & | operator-= (const Vector3D &rhs) |
int | within_tolerance_box (const Vector3D &compare_to, double tolerance) const |
double | length_squared () const |
double | length () const |
void | set_length (const double new_length) |
void | normalize () |
Vector3D | operator~ () const |
const double * | to_array () const |
double * | to_array () |
Static Public Member Functions | |
static double | distance_between (const Vector3D &p1, const Vector3D &p2) |
static double | interior_angle (const Vector3D &a, const Vector3D &b, MsqError &err) |
static Vector3D | interpolate (const double param, const Vector3D &p1, const Vector3D &p2) |
Protected Attributes | |
double | mCoords [3] |
Friends | |
const Vector3D | operator+ (const Vector3D &lhs, const Vector3D &rhs) |
const Vector3D | operator- (const Vector3D &lhs, const Vector3D &rhs) |
const Vector3D | operator* (const Vector3D &lhs, const double scalar) |
lhs * scalar | |
const Vector3D | operator* (const double scalar, const Vector3D &rhs) |
scalar * rhs | |
const Vector3D | operator/ (const Vector3D &lhs, const double scalar) |
double | operator% (const Vector3D &v1, const Vector3D &v2) |
dot product | |
double | inner (const Vector3D v1[], const Vector3D v2[], int n) |
dot product for array | |
double | operator% (const double scalar, const Vector3D &v2) |
scalar * sum_i v2[i] | |
double | operator% (const Vector3D &v1, const double scalar) |
scalar * sum_i v1[i] | |
const Vector3D | operator* (const Vector3D &v1, const Vector3D &v2) |
cross product | |
void | eqAx (Vector3D &v, const Matrix3D &A, const Vector3D &x) |
\( v = A*x \) | |
void | plusEqAx (Vector3D &v, const Matrix3D &A, const Vector3D &x) |
\( v += A*x \) | |
void | plusEqTransAx (Vector3D &v, const Matrix3D &A, const Vector3D &x) |
\( v += A^T*x \) | |
void | eqTransAx (Vector3D &v, const Matrix3D &A, const Vector3D &x) |
bool | operator== (const Vector3D &lhs, const Vector3D &rhs) |
bool | operator!= (const Vector3D &lhs, const Vector3D &rhs) |
double | length (const Vector3D *v, int n) |
L2 norm for an array of Vector3Ds. | |
double | Linf (const Vector3D *v, int n) |
L inf norm for array of Vector3Ds. |
Definition at line 55 of file Vector3D.hpp.
MBMesquite::Vector3D::Vector3D | ( | ) | [inline] |
MBMesquite::Vector3D::Vector3D | ( | double | xyz | ) | [inline] |
MBMesquite::Vector3D::Vector3D | ( | double | x, |
double | y, | ||
double | z | ||
) | [inline] |
MBMesquite::Vector3D::Vector3D | ( | const double | xyz[3] | ) | [inline] |
Definition at line 186 of file Vector3D.hpp.
References mCoords.
{ std::memcpy( mCoords, xyz, 3 * sizeof( double ) ); }
MBMesquite::Vector3D::Vector3D | ( | const Vector3D & | to_copy | ) | [inline] |
Definition at line 190 of file Vector3D.hpp.
References mCoords.
{ std::memcpy( mCoords, to_copy.mCoords, 3 * sizeof( double ) ); }
double MBMesquite::Vector3D::distance_between | ( | const Vector3D & | p1, |
const Vector3D & | p2 | ||
) | [inline, static] |
Definition at line 384 of file Vector3D.hpp.
References length().
Referenced by MBMesquite::MeshDomainAssoc::MeshDomainAssoc(), and MBMesquite::MeshUtil::meshes_are_different().
{ Vector3D v = p2 - p1; return v.length(); }
void MBMesquite::Vector3D::get_coordinates | ( | double & | x, |
double & | y, | ||
double & | z | ||
) | const [inline] |
Definition at line 208 of file Vector3D.hpp.
References mCoords.
Referenced by MBMesquite::LineDomain::position_from_length(), MBMesquite::CircleDomain::position_from_length(), MBMesquite::NonSmoothDescent::validity_check(), and MBMesquite::ArrayMesh::vertex_set_coordinates().
void MBMesquite::Vector3D::get_coordinates | ( | double | xyz[3] | ) | const [inline] |
Definition at line 214 of file Vector3D.hpp.
References mCoords.
{ std::memcpy( xyz, mCoords, 3 * sizeof( double ) ); }
double MBMesquite::Vector3D::interior_angle | ( | const Vector3D & | a, |
const Vector3D & | b, | ||
MsqError & | err | ||
) | [static] |
Definition at line 47 of file Vector3D.cpp.
References INTERNAL_ERROR, moab::Util::is_finite(), length(), and MSQ_SETERR.
Referenced by MBMesquite::MeshWriter::Projection::init().
{ double len1 = lhs.length(); double len2 = rhs.length(); double angle_cos = ( lhs % rhs ) / ( len1 * len2 ); if( !moab::Util::is_finite( angle_cos ) ) { MSQ_SETERR( err )( MsqError::INTERNAL_ERROR ); return 0.0; } // Adjust the cosine if slightly out of range if( ( angle_cos > 1.0 ) && ( angle_cos < 1.0001 ) ) { angle_cos = 1.0; } else if( angle_cos < -1.0 && angle_cos > -1.0001 ) { angle_cos = -1.0; } return std::acos( angle_cos ); }
Vector3D MBMesquite::Vector3D::interpolate | ( | const double | param, |
const Vector3D & | p1, | ||
Definition at line 482 of file Vector3D.hpp.
return ( 1 - param ) * p1 + param * p2;
double MBMesquite::Vector3D::length | ( | ) | const [inline] |
Definition at line 401 of file Vector3D.hpp.
References mCoords.
Referenced by MBMesquite::MeshTransform::add_rotation(), SphericalDomainTest::check_closest_pt(), MBMesquite::MsqMeshEntity::check_element_orientation_corners(), SphericalDomainTest::check_normal(), check_results(), check_slaved_coords(), MBMesquite::MsqCircle::closest(), MBMesquite::MsqSphere::closest(), compare_node_coords(), compute_corner_area(), MBMesquite::MsqMeshEntity::compute_corner_normals(), MBMesquite::MsqMeshEntity::compute_signed_area(), distance_between(), distance_from_origin(), MBMesquite::AspectRatioGammaQualityMetric::evaluate(), MBMesquite::BoundedCylinderDomain::evaluate(), MBMesquite::IdealWeightMeanRatio::evaluate(), MBMesquite::CylinderDomain::evaluate(), MBMesquite::IdealWeightInverseMeanRatio::evaluate(), MBMesquite::ConicDomain::evaluate(), MBMesquite::EdgeLengthRangeQualityMetric::evaluate_common(), MBMesquite::IdealWeightMeanRatio::evaluate_with_gradient(), MBMesquite::IdealWeightInverseMeanRatio::evaluate_with_gradient(), MBMesquite::IdealWeightMeanRatio::evaluate_with_Hessian(), MBMesquite::IdealWeightInverseMeanRatio::evaluate_with_Hessian(), MBMesquite::IdealWeightMeanRatio::evaluate_with_Hessian_diagonal(), MBMesquite::IdealWeightInverseMeanRatio::evaluate_with_Hessian_diagonal(), MBMesquite::NonSmoothDescent::find_plane_normal(), MBMesquite::MeshWriter::Projection::init(), interior_angle(), MBMesquite::MsqSphere::intersect(), main(), MBMesquite::MeshUtil::meshes_are_different(), MBMesquite::MsqPlane::MsqPlane(), MBMesquite::DomainUtil::non_coplanar_vertices(), MBMesquite::CircleDomain::position_from_length(), MBMesquite::MsqCircle::radial_vector(), set_length(), MBMesquite::SphericalDomain::snap_to(), MBMesquite::LineDomainTest::test_arc_length(), MBMesquite::CircleDomainTest::test_arc_length(), GeomPrimTest::test_circle_closest_to_point(), GeomPrimTest::test_circle_from_two_points(), ConicDomainTest::test_construct(), GeomPrimTest::test_line_basic(), ConicDomainTest::test_normal_at(), GeomPrimTest::test_plane_basic(), MBMesquite::CircleDomainTest::test_position_from_length(), MBMesquite::LineDomainTest::test_position_from_length(), VtkTest::test_read_quadratic(), MBMesquite::CircleDomainTest::test_snap_to(), CylinderDomainTest::test_x_normal_at(), CylinderDomainTest::test_z_normal_at(), untangle_function_2d(), and MBMesquite::SphericalDomain::vertex_normal_at().
double MBMesquite::Vector3D::length_squared | ( | ) | const [inline] |
Definition at line 397 of file Vector3D.hpp.
References mCoords.
Referenced by MBMesquite::MsqCircle::closest(), CompareMetric::equal(), DistTestMetric::evaluate(), DistTestMetric::evaluate_with_indices(), MBMesquite::MsqLine::intersect(), MBMesquite::MsqSphere::intersect(), MBMesquite::DomainUtil::non_colinear_vertices(), MBMesquite::MsqCircle::three_point(), and MBMesquite::MsqCircle::two_point().
void MBMesquite::Vector3D::normalize | ( | ) | [inline] |
Definition at line 476 of file Vector3D.hpp.
References set_length().
Referenced by MBMesquite::SphericalDomain::closest_point(), MBMesquite::MsqMeshEntity::compute_corner_normals(), MBMesquite::condition_number_2d(), MBMesquite::CylinderDomain::evaluate(), MBMesquite::Matrix3D::Matrix3D(), MBMesquite::PlanarDomain::set_plane(), IdealElementTest::test_side_height_pyr(), IdealElementTest::test_unit_height_pyr(), IdealElementTest::test_unit_pyr(), and MBMesquite::MeshWriter::write_stl().
{ set_length( 1.0 ); }
Vector3D & MBMesquite::Vector3D::operator*= | ( | const double | scalar | ) | [inline] |
Definition at line 292 of file Vector3D.hpp.
References mCoords.
Vector3D MBMesquite::Vector3D::operator- | ( | ) | const [inline] |
Definition at line 273 of file Vector3D.hpp.
References mCoords, and Vector3D().
Vector3D & MBMesquite::Vector3D::operator/= | ( | const double | scalar | ) | [inline] |
Reimplemented in MBMesquite::MsqVertex.
Definition at line 255 of file Vector3D.hpp.
References mCoords.
Referenced by MBMesquite::MsqVertex::operator=().
Vector3D & MBMesquite::Vector3D::operator= | ( | const double & | to_copy | ) | [inline] |
const double & MBMesquite::Vector3D::operator[] | ( | size_t | index | ) | const [inline] |
double & MBMesquite::Vector3D::operator[] | ( | size_t | index | ) | [inline] |
Vector3D MBMesquite::Vector3D::operator~ | ( | ) | const [inline] |
Definition at line 142 of file Vector3D.hpp.
References MBMesquite::length().
{ return *this * ( 1.0 / length() ); }
void MBMesquite::Vector3D::set | ( | const double | x, |
const double | y, | ||
const double | z | ||
) | [inline] |
Definition at line 236 of file Vector3D.hpp.
References mCoords.
Referenced by MBMesquite::average_corner_diagonals(), HigherOrderTest::basic_hex_test(), HigherOrderTest::basic_quad_test(), HigherOrderTest::basic_tet_test(), MBMesquite::PointDomain::closest_point(), MBMesquite::SphericalDomain::closest_point(), MBMesquite::ParallelHelperImpl::comm_smoothed_vtx_b(), MBMesquite::ParallelHelperImpl::comm_smoothed_vtx_b_no_all(), MBMesquite::ParallelHelperImpl::comm_smoothed_vtx_nb(), MBMesquite::ParallelHelperImpl::comm_smoothed_vtx_nb_no_all(), MBMesquite::ParallelHelperImpl::comm_smoothed_vtx_tnb(), MBMesquite::ParallelHelperImpl::comm_smoothed_vtx_tnb_no_all(), MBMesquite::PointDomain::element_normal_at(), MBMesquite::XYRectangle::element_normal_at(), MBMesquite::CylinderDomain::evaluate(), get_ideal_quad(), get_ideal_tet(), main(), MBMesquite::MsqCommonIGeom::move_to(), MBMesquite::MsqCommonIGeom::normal(), MBMesquite::SphericalDomain::snap_to(), MsqHessianTest::test_axpy(), MsqHessianTest::test_cg_solver(), MsqVertexTest::test_hex_vertices(), MsqMeshEntityTest::test_hex_vertices(), PatchDataTest::test_move_free_vertices_constrained(), PatchDataTest::test_movement_function(), HigherOrderTest::test_quad_basic_mid_spin(), Matrix3DTest::test_times_vector(), Matrix3DTest::test_vector_times(), MeshInterfaceTest::test_vertices(), CylinderDomainTest::test_x_normal_at(), BoundedCylinderDomainTest::test_x_snap_to(), CylinderDomainTest::test_x_snap_to(), CylinderDomainTest::test_z_normal_at(), CylinderDomainTest::test_z_snap_to(), BoundedCylinderDomainTest::test_z_snap_to(), SphereDomainArg::value(), CylinderDomainArg::value(), PlanarDomainArg::value(), LineDomainArg::value(), CircleDomainArg::value(), MBMesquite::PointDomain::vertex_normal_at(), MBMesquite::SphericalDomain::vertex_normal_at(), MBMesquite::XYRectangle::vertex_normal_at(), MBMesquite::TagVertexMesh::vertices_get_coordinates(), MBMesquite::MsqIMesh::vertices_get_coordinates(), MBMesquite::MsqMOAB::vertices_get_coordinates(), and MBMesquite::ArrayMesh::vertices_get_coordinates().
void MBMesquite::Vector3D::set | ( | const double | xyz[3] | ) | [inline] |
Definition at line 242 of file Vector3D.hpp.
References mCoords.
void MBMesquite::Vector3D::set | ( | const Vector3D & | to_copy | ) | [inline] |
Definition at line 246 of file Vector3D.hpp.
References mCoords.
void MBMesquite::Vector3D::set_length | ( | const double | new_length | ) | [inline] |
Definition at line 471 of file Vector3D.hpp.
Referenced by normalize().
{ double factor = new_length / length(); *this *= factor; }
const double* MBMesquite::Vector3D::to_array | ( | ) | const [inline] |
Definition at line 153 of file Vector3D.hpp.
Referenced by MBMesquite::VertexMover::commit_jacobi_coords(), MBMesquite::MappingFunction2D::jacobian(), MBMesquite::MappingFunction3D::jacobian(), TriTauMetric::matrix(), MBMesquite::DeformingCurveSmoother::smooth_curve(), MBMesquite::LineDomainTest::test_arc_length(), MBMesquite::CircleDomainTest::test_arc_length(), MappingFunctionTest::test_jacobian_2d(), MappingFunctionTest::test_jacobian_3d(), MBMesquite::CircleDomainTest::test_position_from_length(), MBMesquite::LineDomainTest::test_position_from_length(), MBMesquite::TagVertexMesh::vertex_set_coordinates(), MBMesquite::MeshImpl::vtk_read_polydata(), MBMesquite::MeshImpl::vtk_read_structured_grid(), and MBMesquite::MeshImpl::vtk_read_unstructured_grid().
{ return mCoords; }
double* MBMesquite::Vector3D::to_array | ( | ) | [inline] |
Definition at line 158 of file Vector3D.hpp.
{ return mCoords; }
int MBMesquite::Vector3D::within_tolerance_box | ( | const Vector3D & | compare_to, |
double | tolerance | ||
Definition at line 389 of file Vector3D.hpp.
References mCoords.
Referenced by VtkTest::check_4quad_block(), VtkTest::check_8hex_block(), and smooth_mesh().
double MBMesquite::Vector3D::x | ( | ) | const [inline] |
Definition at line 196 of file Vector3D.hpp.
References mCoords.
Referenced by HigherOrderTest::basic_hex_test(), HigherOrderTest::basic_quad_test(), HigherOrderTest::basic_tet_test(), MBMesquite::SphericalDomain::closest_point(), MBMesquite::operator*(), MBMesquite::operator+(), MBMesquite::operator-(), MBMesquite::operator/(), MBMesquite::MeshWriter::Projection::project(), MBMesquite::MeshWriter::Projection::rotation(), MBMesquite::SphericalDomain::snap_to(), Vector3DTest::test_copy_constructor(), Vector3DTest::test_default_constructor(), Vector3DTest::test_double_constructor(), HigherOrderTest::test_tri_slac(), CylinderDomainTest::test_x_normal_at(), BoundedCylinderDomainTest::test_x_snap_to(), CylinderDomainTest::test_x_snap_to(), BoundedCylinderDomainTest::test_z_snap_to(), Vector3DTest::throw_exception(), MBMesquite::SphericalDomain::vertex_normal_at(), MBMesquite::MsqMOAB::vertices_get_coordinates(), MBMesquite::MsqIMesh::vertices_get_coordinates(), MBMesquite::MeshImpl::write_exodus(), and MBMesquite::MeshWriter::write_stl().
{ return mCoords[0]; }
void MBMesquite::Vector3D::x | ( | const double | x | ) | [inline] |
double MBMesquite::Vector3D::y | ( | ) | const [inline] |
Definition at line 200 of file Vector3D.hpp.
References mCoords.
Referenced by HigherOrderTest::basic_hex_test(), HigherOrderTest::basic_quad_test(), HigherOrderTest::basic_tet_test(), MBMesquite::ParallelHelperImpl::comm_smoothed_vtx_b(), MBMesquite::ParallelHelperImpl::comm_smoothed_vtx_b_no_all(), MBMesquite::operator*(), MBMesquite::operator+(), MBMesquite::operator-(), MBMesquite::operator/(), MBMesquite::MeshWriter::Projection::project(), MBMesquite::MeshWriter::Projection::rotation(), Vector3DTest::test_copy_constructor(), Vector3DTest::test_default_constructor(), Vector3DTest::test_double_constructor(), HigherOrderTest::test_tri_slac(), BoundedCylinderDomainTest::test_x_snap_to(), BoundedCylinderDomainTest::test_z_snap_to(), MBMesquite::MsqIMesh::vertices_get_coordinates(), MBMesquite::MsqMOAB::vertices_get_coordinates(), MBMesquite::MeshImpl::write_exodus(), MBMesquite::MeshWriter::write_stl(), and MBMesquite::MeshWriter::write_vtk().
{ return mCoords[1]; }
void MBMesquite::Vector3D::y | ( | const double | y | ) | [inline] |
double MBMesquite::Vector3D::z | ( | ) | const [inline] |
Definition at line 204 of file Vector3D.hpp.
References mCoords.
Referenced by HigherOrderTest::basic_hex_test(), HigherOrderTest::basic_quad_test(), HigherOrderTest::basic_tet_test(), MBMesquite::ParallelHelperImpl::comm_smoothed_vtx_b(), MBMesquite::ParallelHelperImpl::comm_smoothed_vtx_b_no_all(), MBMesquite::operator*(), MBMesquite::operator+(), MBMesquite::operator-(), MBMesquite::operator/(), MBMesquite::MeshWriter::Projection::rotation(), Vector3DTest::test_copy_constructor(), Vector3DTest::test_default_constructor(), Vector3DTest::test_double_constructor(), BoundedCylinderDomainTest::test_x_snap_to(), CylinderDomainTest::test_z_normal_at(), CylinderDomainTest::test_z_snap_to(), BoundedCylinderDomainTest::test_z_snap_to(), MBMesquite::MsqIMesh::vertices_get_coordinates(), MBMesquite::MsqMOAB::vertices_get_coordinates(), MBMesquite::MeshImpl::write_exodus(), MBMesquite::MeshWriter::write_stl(), and MBMesquite::MeshWriter::write_vtk().
{ return mCoords[2]; }
void MBMesquite::Vector3D::z | ( | const double | z | ) | [inline] |
\( v = A*x \)
Definition at line 757 of file Matrix3D.hpp.
Definition at line 771 of file Matrix3D.hpp.
Dot product for arrays of Vector3Ds. see also operator% .
Definition at line 344 of file Vector3D.hpp.
Definition at line 434 of file Vector3D.hpp.
{ return std::sqrt( length_squared( v, n ) ); }
Definition at line 443 of file Vector3D.hpp.
{ double max = 0; // loop over the length of the array for( int i = 0; i < n; ++i ) { if( max < std::fabs( v[i][0] ) ) max = std::fabs( v[i][0] ); if( max < std::fabs( v[i][1] ) ) max = std::fabs( v[i][1] ); if( max < std::fabs( v[i][2] ) ) max = std::fabs( v[i][2] ); } // return the value of the largest entry in the array return max; }
Definition at line 492 of file Vector3D.hpp.
return v1.mCoords[0] != v2.mCoords[0] || v1.mCoords[1] != v2.mCoords[1] || v1.mCoords[2] != v2.mCoords[2];
dot product
Definition at line 337 of file Vector3D.hpp.
return ( lhs.mCoords[0] * rhs.mCoords[0] + lhs.mCoords[1] * rhs.mCoords[1] + lhs.mCoords[2] * rhs.mCoords[2] );
double operator% | ( | const double | scalar, |
const Vector3D & | v2 | ||
) | [friend] |
Definition at line 363 of file Vector3D.hpp.
return ( scalar * ( rhs.mCoords[0] + rhs.mCoords[1] + rhs.mCoords[2] ) );
double operator% | ( | const Vector3D & | v1, |
const double | scalar | ||
) | [friend] |
Definition at line 368 of file Vector3D.hpp.
return ( scalar * ( lhs.mCoords[0] + lhs.mCoords[1] + lhs.mCoords[2] ) );
lhs * scalar
Definition at line 324 of file Vector3D.hpp.
{ return Vector3D( lhs.x() * scalar, lhs.y() * scalar, lhs.z() * scalar ); }
scalar * rhs
Definition at line 328 of file Vector3D.hpp.
{ return Vector3D( rhs.x() * scalar, rhs.y() * scalar, rhs.z() * scalar ); }
cross product
Definition at line 373 of file Vector3D.hpp.
{ return Vector3D( lhs.mCoords[1] * rhs.mCoords[2] - lhs.mCoords[2] * rhs.mCoords[1], lhs.mCoords[2] * rhs.mCoords[0] - lhs.mCoords[0] * rhs.mCoords[2], lhs.mCoords[0] * rhs.mCoords[1] - lhs.mCoords[1] * rhs.mCoords[0] ); }
Definition at line 316 of file Vector3D.hpp.
{ return Vector3D( lhs.x() + rhs.x(), lhs.y() + rhs.y(), lhs.z() + rhs.z() ); }
Definition at line 320 of file Vector3D.hpp.
{ return Vector3D( lhs.x() - rhs.x(), lhs.y() - rhs.y(), lhs.z() - rhs.z() ); }
Definition at line 332 of file Vector3D.hpp.
{ assert( scalar != 0 ); return Vector3D( lhs.x() / scalar, lhs.y() / scalar, lhs.z() / scalar ); }
Definition at line 487 of file Vector3D.hpp.
return v1.mCoords[0] == v2.mCoords[0] && v1.mCoords[1] == v2.mCoords[1] && v1.mCoords[2] == v2.mCoords[2];
\( v += A*x \)
Definition at line 764 of file Matrix3D.hpp.
void plusEqTransAx | ( | Vector3D & | v, |
const Matrix3D & | A, | ||
const Vector3D & | x | ||
) | [friend] |
\( v += A^T*x \)
Definition at line 778 of file Matrix3D.hpp.
double MBMesquite::Vector3D::mCoords[3] [protected] |
Definition at line 164 of file Vector3D.hpp.
Referenced by MBMesquite::eqAx(), MBMesquite::eqTransAx(), get_coordinates(), length(), length_squared(), MBMesquite::operator!=(), MBMesquite::operator%(), MBMesquite::operator*(), operator*=(), operator+=(), operator-(), operator-=(), operator/=(), operator=(), MBMesquite::operator==(), operator[](), MBMesquite::plusEqAx(), MBMesquite::plusEqTransAx(), set(), Vector3D(), within_tolerance_box(), x(), y(), and z().
