MOAB: Mesh Oriented datABase
(version 5.2.1)
00001 /* ***************************************************************** 00002 MESQUITE -- The Mesh Quality Improvement Toolkit 00003 00004 Copyright 2007 Sandia National Laboratories. Developed at the 00005 University of Wisconsin--Madison under SNL contract number 00006 624796. The U.S. Government and the University of Wisconsin 00007 retain certain rights to this software. 00008 00009 This library is free software; you can redistribute it and/or 00010 modify it under the terms of the GNU Lesser General Public 00011 License as published by the Free Software Foundation; either 00012 version 2.1 of the License, or (at your option) any later version. 00013 00014 This library is distributed in the hope that it will be useful, 00015 but WITHOUT ANY WARRANTY; without even the implied warranty of 00016 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00017 Lesser General Public License for more details. 00018 00019 You should have received a copy of the GNU Lesser General Public License 00020 (lgpl.txt) along with this library; if not, write to the Free Software 00021 Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA 00022 00023 (2010) kraftche@cae.wisc.edu 00024 00025 ***************************************************************** */ 00026 00027 /** \file ConicDomain.cpp 00028 * \brief 00029 * \author Jason Kraftcheck 00030 */ 00031 00032 #include "Mesquite.hpp" 00033 #include "ConicDomain.hpp" 00034 00035 namespace MBMesquite 00036 { 00037 00038 ConicDomain::~ConicDomain() {} 00039 00040 void ConicDomain::evaluate( Mesh::VertexHandle, const Vector3D& p_point, Vector3D& closest, Vector3D& normal ) const 00041 { 00042 // translate such that cone point (mPoint) is at origin 00043 Vector3D pt = p_point - mPoint; 00044 00045 // find the plane containing both the input point an the axis 00046 Vector3D n = mAxis * pt; 00047 double len = n.length(); 00048 if( len < 1e-12 ) 00049 { 00050 // point on axis 00051 // choose any plane that does't contain the axis 00052 if( fabs( mAxis[0] ) <= fabs( mAxis[1] ) && fabs( mAxis[0] ) < fabs( mAxis[2] ) ) 00053 n = mAxis * Vector3D( 1, 0, 0 ); 00054 else if( fabs( mAxis[1] ) <= fabs( mAxis[2] ) ) 00055 n = mAxis * Vector3D( 0, 1, 0 ); 00056 else 00057 n = mAxis * Vector3D( 0, 0, 1 ); 00058 } 00059 else 00060 { 00061 n /= len; 00062 } 00063 // Find two points that are the intersection of the plane with the 00064 // circular cross-section of the cone centered at mPoint 00065 Vector3D p1 = mRadius * ( n * mAxis ); 00066 Vector3D p2 = -p1; 00067 // Define two lines of intersect between the cone and the plane 00068 // as the two lines from the apex to each of p1 and p2. 00069 Vector3D apex = mHeight * mAxis; 00070 Vector3D v1 = p1 - apex; 00071 Vector3D v2 = p2 - apex; 00072 // Find closest point on each line to input position 00073 double t1 = v1 % ( p_point - apex ) / ( v1 % v1 ); 00074 double t2 = v2 % ( p_point - apex ) / ( v2 % v2 ); 00075 // Select the closest of the two 00076 p1 = apex + t1 * v1; 00077 p2 = apex + t2 * v2; 00078 double t; 00079 if( ( p1 - p_point ).length_squared() < ( p2 - p_point ).length_squared() ) 00080 { 00081 normal = v1 * n; 00082 closest = p1; 00083 t = t1; 00084 } 00085 else 00086 { 00087 normal = v2 * n; 00088 closest = p2; 00089 t = t2; 00090 } 00091 // If we're below the apex (t > 0), then the normal 00092 // should be in the same direction as the axis. Otherwise 00093 // it should be in the opposite direction. 00094 if( t * ( normal % mAxis ) < 0.0 ) normal = -normal; 00095 // normalize and translate 00096 normal *= outwardSign / normal.length(); 00097 closest += mPoint; 00098 } 00099 00100 void ConicDomain::snap_to( Mesh::VertexHandle h, Vector3D& v ) const 00101 { 00102 Vector3D p( v ), n; 00103 evaluate( h, p, v, n ); 00104 } 00105 00106 void ConicDomain::vertex_normal_at( Mesh::VertexHandle h, Vector3D& v ) const 00107 { 00108 Vector3D p( v ), l; 00109 evaluate( h, p, l, v ); 00110 } 00111 00112 void ConicDomain::element_normal_at( Mesh::ElementHandle h, Vector3D& v ) const 00113 { 00114 Vector3D p( v ), l; 00115 // NOTE: Explicitly invoke this class's evaluate method for elements. 00116 // BoundedCylindarDomain overrides evaluate for vertices only. 00117 ConicDomain::evaluate( h, p, l, v ); 00118 } 00119 00120 void ConicDomain::vertex_normal_at( const Mesh::VertexHandle* h, Vector3D coords[], unsigned count, MsqError& ) const 00121 { 00122 for( unsigned i = 0; i < count; ++i ) 00123 vertex_normal_at( h[i], coords[i] ); 00124 } 00125 00126 void ConicDomain::closest_point( Mesh::VertexHandle handle, const Vector3D& position, Vector3D& closest, 00127 Vector3D& normal, MsqError& ) const 00128 { 00129 evaluate( handle, position, closest, normal ); 00130 } 00131 00132 void ConicDomain::domain_DoF( const Mesh::VertexHandle*, unsigned short* dof_array, size_t count, MsqError& ) const 00133 { 00134 std::fill( dof_array, dof_array + count, (unsigned short)2 ); 00135 } 00136 00137 } // namespace MBMesquite
