MOAB: Mesh Oriented datABase
(version 5.2.1)
#include <ConicDomain.hpp>
Public Member Functions | |
ConicDomain (double radius_at_point, double height_to_apex, Vector3D axis_direction=Vector3D(0, 0, 1), Vector3D axis_point=Vector3D(0, 0, 0), bool outward_normal=true) | |
ConicDomain () | |
virtual | ~ConicDomain () |
virtual void | snap_to (Mesh::VertexHandle entity_handle, Vector3D &coordinate) const |
virtual void | vertex_normal_at (Mesh::VertexHandle entity_handle, Vector3D &coordinate) const |
virtual void | element_normal_at (Mesh::ElementHandle entity_handle, Vector3D &coordinate) const |
virtual void | vertex_normal_at (const Mesh::VertexHandle *handle, Vector3D coords[], unsigned count, MsqError &err) const |
evaluate surface normals | |
virtual void | closest_point (Mesh::VertexHandle handle, const Vector3D &position, Vector3D &closest, Vector3D &normal, MsqError &err) const |
evaluate closest point and normal | |
virtual void | domain_DoF (const Mesh::VertexHandle *handle_array, unsigned short *dof_array, size_t count, MsqError &err) const |
const Vector3D & | axis () const |
const Vector3D & | point () const |
double | point_radius () const |
double | height_from_point () const |
Protected Member Functions | |
virtual void | evaluate (Mesh::VertexHandle handle, const Vector3D &point, Vector3D &closest, Vector3D &normal) const |
Private Attributes | |
Vector3D | mAxis |
Direction of central axis of cone. Unit vector. | |
Vector3D | mPoint |
A point on the axis of the cone. | |
double | mRadius |
Radius at mPoint. | |
double | mHeight |
Distance from mPoint to apex, in direction of mAxis. | |
double | outwardSign |
1.0 if normal points away from axis, -1.0 otherwise |
Define the geometry of an unbounded cone with circular cross-section.
Definition at line 45 of file ConicDomain.hpp.
MBMesquite::ConicDomain::ConicDomain | ( | double | radius_at_point, |
double | height_to_apex, | ||
Vector3D | axis_direction = Vector3D( 0, 0, 1 ) , |
Vector3D | axis_point = Vector3D( 0, 0, 0 ) , |
bool | outward_normal = true |
) | [inline] |
radius_at_point | The radius of the cone at axis_point |
height_to_apex | The distance in the direction of axis_direction from axis_point to the apex |
axis_direction | Vector defining the direction of the axis |
axis_point | A point through which the axis passes. Cone is not bounded at apex. It extends infinitely in both directions. |
Definition at line 57 of file ConicDomain.hpp.
: mAxis( axis_direction / axis_direction.length() ), mPoint( axis_point ), mRadius( radius_at_point ), mHeight( height_to_apex ), outwardSign( outward_normal ? 1.0 : -1.0 ) { }
MBMesquite::ConicDomain::ConicDomain | ( | ) | [inline] |
Definition at line 64 of file ConicDomain.hpp.
MBMesquite::ConicDomain::~ConicDomain | ( | ) | [virtual] |
Definition at line 38 of file ConicDomain.cpp.
const Vector3D& MBMesquite::ConicDomain::axis | ( | ) | const [inline] |
Definition at line 83 of file ConicDomain.hpp.
Referenced by ConicDomainTest::test_construct(), and ConicDomainTest::test_snap_to().
{ return mAxis; }
void MBMesquite::ConicDomain::closest_point | ( | Mesh::VertexHandle | handle, |
const Vector3D & | position, | ||
Vector3D & | closest, | ||
Vector3D & | normal, | ||
MsqError & | err | ||
) | const [virtual] |
Given a position in space, return the closest position in the domain and the domain normal at that point.
entity_handle | Evaluate the subset of the domain contianing this entity |
position | Input position for which to evaluate |
closest | Closest position in the domain. |
normal | Domain normal at the location of 'closest' |
Implements MBMesquite::MeshDomain.
Definition at line 126 of file ConicDomain.cpp.
References evaluate().
Referenced by ConicDomainTest::test_closest_point().
{ evaluate( handle, position, closest, normal ); }
void MBMesquite::ConicDomain::domain_DoF | ( | const Mesh::VertexHandle * | handle_array, |
unsigned short * | dof_array, | ||
size_t | count, | ||
Definition at line 132 of file ConicDomain.cpp.
{ std::fill( dof_array, dof_array + count, (unsigned short)2 ); }
void MBMesquite::ConicDomain::element_normal_at | ( | Mesh::ElementHandle | entity_handle, |
Vector3D & | coordinate | ||
Definition at line 112 of file ConicDomain.cpp.
References evaluate(), and l.
Referenced by ConicDomainTest::test_normal_at().
{ Vector3D p( v ), l; // NOTE: Explicitly invoke this class's evaluate method for elements. // BoundedCylindarDomain overrides evaluate for vertices only. ConicDomain::evaluate( h, p, l, v ); }
void MBMesquite::ConicDomain::evaluate | ( | Mesh::VertexHandle | handle, |
const Vector3D & | point, | ||
Vector3D & | normal | ||
) | const [protected, virtual] |
Definition at line 40 of file ConicDomain.cpp.
References MBMesquite::Vector3D::length(), MBMesquite::length_squared(), mAxis, mHeight, mPoint, mRadius, n, outwardSign, and t.
Referenced by closest_point(), element_normal_at(), snap_to(), and vertex_normal_at().
{ // translate such that cone point (mPoint) is at origin Vector3D pt = p_point - mPoint; // find the plane containing both the input point an the axis Vector3D n = mAxis * pt; double len = n.length(); if( len < 1e-12 ) { // point on axis // choose any plane that does't contain the axis if( fabs( mAxis[0] ) <= fabs( mAxis[1] ) && fabs( mAxis[0] ) < fabs( mAxis[2] ) ) n = mAxis * Vector3D( 1, 0, 0 ); else if( fabs( mAxis[1] ) <= fabs( mAxis[2] ) ) n = mAxis * Vector3D( 0, 1, 0 ); else n = mAxis * Vector3D( 0, 0, 1 ); } else { n /= len; } // Find two points that are the intersection of the plane with the // circular cross-section of the cone centered at mPoint Vector3D p1 = mRadius * ( n * mAxis ); Vector3D p2 = -p1; // Define two lines of intersect between the cone and the plane // as the two lines from the apex to each of p1 and p2. Vector3D apex = mHeight * mAxis; Vector3D v1 = p1 - apex; Vector3D v2 = p2 - apex; // Find closest point on each line to input position double t1 = v1 % ( p_point - apex ) / ( v1 % v1 ); double t2 = v2 % ( p_point - apex ) / ( v2 % v2 ); // Select the closest of the two p1 = apex + t1 * v1; p2 = apex + t2 * v2; double t; if( ( p1 - p_point ).length_squared() < ( p2 - p_point ).length_squared() ) { normal = v1 * n; closest = p1; t = t1; } else { normal = v2 * n; closest = p2; t = t2; } // If we're below the apex (t > 0), then the normal // should be in the same direction as the axis. Otherwise // it should be in the opposite direction. if( t * ( normal % mAxis ) < 0.0 ) normal = -normal; // normalize and translate normal *= outwardSign / normal.length(); closest += mPoint; }
double MBMesquite::ConicDomain::height_from_point | ( | ) | const [inline] |
Definition at line 95 of file ConicDomain.hpp.
{ return mHeight; }
const Vector3D& MBMesquite::ConicDomain::point | ( | ) | const [inline] |
Definition at line 87 of file ConicDomain.hpp.
{ return mPoint; }
double MBMesquite::ConicDomain::point_radius | ( | ) | const [inline] |
Definition at line 91 of file ConicDomain.hpp.
Referenced by ConicDomainTest::test_construct().
{ return mRadius; }
void MBMesquite::ConicDomain::snap_to | ( | Mesh::VertexHandle | entity_handle, |
Modifies "coordinate" so that it lies on the domain to which "entity_handle" is constrained. The handle determines the domain. The coordinate is the proposed new position on that domain.
Definition at line 100 of file ConicDomain.cpp.
References evaluate(), and n.
Referenced by ConicDomainTest::test_snap_to().
void MBMesquite::ConicDomain::vertex_normal_at | ( | Mesh::VertexHandle | entity_handle, |
Returns the normal of the domain to which "entity_handle" is constrained. For non-planar surfaces, the normal is calculated at the point on the domain that is closest to the passed in value of "coordinate". If the domain does not have a normal, or the normal cannot be determined, "coordinate" is set to (0,0,0). Otherwise, "coordinate" is set to the domain's normal at the appropriate point. In summary, the handle determines the domain. The coordinate determines the point of interest on that domain.
User should see also PatchData::get_domain_normal_at_vertex and PatchData::get_domain_normal_at_element .
Definition at line 106 of file ConicDomain.cpp.
Referenced by ConicDomainTest::test_normal_at(), and vertex_normal_at().
void MBMesquite::ConicDomain::vertex_normal_at | ( | const Mesh::VertexHandle * | handles, |
Vector3D | coordinates[], | ||
unsigned | count, | ||
Returns normals for a domain.
handles | The domain evaluated is the one in which this mesh entity is constrained. |
coordinates | As input, a list of positions at which to evaluate the domain. As output, the resulting domain normals. |
count | The length of the coordinates array. |
Definition at line 120 of file ConicDomain.cpp.
References vertex_normal_at().
{ for( unsigned i = 0; i < count; ++i ) vertex_normal_at( h[i], coords[i] ); }
Vector3D MBMesquite::ConicDomain::mAxis [private] |
Definition at line 105 of file ConicDomain.hpp.
Referenced by evaluate().
double MBMesquite::ConicDomain::mHeight [private] |
Definition at line 108 of file ConicDomain.hpp.
Vector3D MBMesquite::ConicDomain::mPoint [private] |
Definition at line 106 of file ConicDomain.hpp.
double MBMesquite::ConicDomain::mRadius [private] |
double MBMesquite::ConicDomain::outwardSign [private] |
Definition at line 109 of file ConicDomain.hpp.
