MOAB: Mesh Oriented datABase
(version 5.2.1)
#include <MeshInterface.hpp>
Public Member Functions | |
virtual | ~MeshDomain () |
virtual void | snap_to (Mesh::VertexHandle entity_handle, Vector3D &coordinate) const =0 |
virtual void | vertex_normal_at (Mesh::VertexHandle entity_handle, Vector3D &coordinate) const =0 |
virtual void | element_normal_at (Mesh::ElementHandle entity_handle, Vector3D &coordinate) const =0 |
virtual void | vertex_normal_at (const Mesh::VertexHandle *handles, Vector3D coordinates[], unsigned count, MsqError &err) const =0 |
evaluate surface normals | |
virtual void | closest_point (Mesh::VertexHandle handle, const Vector3D &position, Vector3D &closest, Vector3D &normal, MsqError &err) const =0 |
evaluate closest point and normal | |
virtual void | domain_DoF (const Mesh::EntityHandle *handle_array, unsigned short *dof_array, size_t num_handles, MsqError &err) const =0 |
Get degrees of freedom in vertex movement. |
The MeshDomain class provides geometrical information concerning the Mesh. It is called during surface meshes optimization to figure out the surface normal, how to snap vertices back to the surface, etc... .
Definition at line 363 of file MeshInterface.hpp.
virtual MBMesquite::MeshDomain::~MeshDomain | ( | ) | [inline, virtual] |
Definition at line 366 of file MeshInterface.hpp.
virtual void MBMesquite::MeshDomain::closest_point | ( | Mesh::VertexHandle | handle, |
const Vector3D & | position, | ||
Vector3D & | closest, | ||
Vector3D & | normal, | ||
MsqError & | err | ||
) | const [pure virtual] |
Given a position in space, return the closest position in the domain and the domain normal at that point.
entity_handle | Evaluate the subset of the domain contianing this entity |
position | Input position for which to evaluate |
closest | Closest position in the domain. |
normal | Domain normal at the location of 'closest' |
Implemented in MBMesquite::DomainClassifier, MBMesquite::CircleDomain, MBMesquite::MsqIGeom, MBMesquite::PlanarDomain, MBMesquite::XYRectangle, MBMesquite::LineDomain, MBMesquite::ConicDomain, MBMesquite::SphericalDomain, MBMesquite::XYPlanarDomain, MBMesquite::CylinderDomain, MBMesquite::PointDomain, ParaboloidDomain, and MBMesquite::MsqIRel.
Referenced by MBMesquite::PatchData::snap_vertex_to_domain().
virtual void MBMesquite::MeshDomain::domain_DoF | ( | const Mesh::EntityHandle * | handle_array, |
unsigned short * | dof_array, | ||
size_t | num_handles, | ||
Given a vertex, return how the domain constrains the location of that vertex as the number of degrees of freedom in the motion of the vertex. If the domain is a geometric domain, the degrees of freedom for a vertex is the dimension of the geometric entity the vertex is constrained to lie on (e.g. point = 0, curve = 1, surface = 2, volume = 3.)
Implemented in ParaboloidDomain.
Referenced by check_results(), MBMesquite::DomainClassifier::domain_DoF(), MBMesquite::geom_classify_vertices(), MBMesquite::Instruction::initialize_vertex_byte(), MBMesquite::SlaveBoundaryVertices::loop_over_mesh(), PatchDataTest::test_fixed_by_geom_dim(), and MBMesquite::PatchData::update_cached_normals().
virtual void MBMesquite::MeshDomain::element_normal_at | ( | Mesh::ElementHandle | entity_handle, |
Vector3D & | coordinate | ||
Implemented in MBMesquite::DomainClassifier, MBMesquite::CircleDomain, MBMesquite::MsqIGeom, MBMesquite::PlanarDomain, MBMesquite::XYRectangle, MBMesquite::LineDomain, MBMesquite::ConicDomain, MBMesquite::SphericalDomain, ParaboloidDomain, MBMesquite::XYPlanarDomain, MBMesquite::CylinderDomain, MBMesquite::PointDomain, and MBMesquite::MsqIRel.
Referenced by MBMesquite::PatchData::get_domain_normal_at_element(), MBMesquite::PatchData::get_domain_normal_at_mid_edge(), MBMesquite::PatchData::get_domain_normal_at_vertex(), MBMesquite::PatchData::get_domain_normals_at_corners(), and MBMesquite::PatchData::project_gradient().
virtual void MBMesquite::MeshDomain::snap_to | ( | Mesh::VertexHandle | entity_handle, |
Modifies "coordinate" so that it lies on the domain to which "entity_handle" is constrained. The handle determines the domain. The coordinate is the proposed new position on that domain.
Implemented in MBMesquite::DomainClassifier, MBMesquite::CircleDomain, MBMesquite::MsqIGeom, MBMesquite::PlanarDomain, MBMesquite::LineDomain, MBMesquite::XYRectangle, ParaboloidDomain, MBMesquite::ConicDomain, MBMesquite::SphericalDomain, MBMesquite::XYPlanarDomain, MBMesquite::CylinderDomain, MBMesquite::PointDomain, and MBMesquite::MsqIRel.
Referenced by MBMesquite::geom_classify_elements(), MBMesquite::geom_classify_vertices(), MBMesquite::DeformingDomainWrapper::move_to_domain(), and MBMesquite::PatchData::snap_vertex_to_domain().
virtual void MBMesquite::MeshDomain::vertex_normal_at | ( | Mesh::VertexHandle | entity_handle, |
Returns the normal of the domain to which "entity_handle" is constrained. For non-planar surfaces, the normal is calculated at the point on the domain that is closest to the passed in value of "coordinate". If the domain does not have a normal, or the normal cannot be determined, "coordinate" is set to (0,0,0). Otherwise, "coordinate" is set to the domain's normal at the appropriate point. In summary, the handle determines the domain. The coordinate determines the point of interest on that domain.
User should see also PatchData::get_domain_normal_at_vertex and PatchData::get_domain_normal_at_element .
Implemented in MBMesquite::DomainClassifier, MBMesquite::CircleDomain, MBMesquite::MsqIGeom, MBMesquite::PlanarDomain, MBMesquite::XYRectangle, MBMesquite::LineDomain, ParaboloidDomain, MBMesquite::ConicDomain, MBMesquite::SphericalDomain, MBMesquite::XYPlanarDomain, MBMesquite::CylinderDomain, MBMesquite::PointDomain, and MBMesquite::MsqIRel.
Referenced by check_results(), MBMesquite::PatchData::update_cached_normals(), and MBMesquite::DomainClassifier::vertex_normal_at().
virtual void MBMesquite::MeshDomain::vertex_normal_at | ( | const Mesh::VertexHandle * | handles, |
Vector3D | coordinates[], | ||
unsigned | count, | ||
Returns normals for a domain.
handles | The domain evaluated is the one in which this mesh entity is constrained. |
coordinates | As input, a list of positions at which to evaluate the domain. As output, the resulting domain normals. |
count | The length of the coordinates array. |
