MOAB: Mesh Oriented datABase
(version 5.4.0)
#include <MeshDomain1D.hpp>
Public Member Functions | |
CircleDomain (const Vector3D ¢er, const Vector3D &normal, double radius) | |
CircleDomain (const MsqCircle &circle) | |
const MsqCircle & | geom () const |
virtual void | snap_to (Mesh::VertexHandle entity_handle, Vector3D &coordinate) const |
virtual void | vertex_normal_at (Mesh::VertexHandle entity_handle, Vector3D &coordinate) const |
virtual void | element_normal_at (Mesh::ElementHandle entity_handle, Vector3D &coordinate) const |
virtual void | vertex_normal_at (const Mesh::VertexHandle *handles, Vector3D coordinates[], unsigned count, MsqError &err) const |
evaluate surface normals | |
virtual void | closest_point (Mesh::VertexHandle handle, const Vector3D &position, Vector3D &closest, Vector3D &normal, MsqError &err) const |
evaluate closest point and normal | |
virtual void | domain_DoF (const Mesh::VertexHandle *handle_array, unsigned short *dof_array, size_t num_handles, MsqError &err) const |
virtual double | arc_length (const double position1[3], const double position2[3], MsqError &err) |
Measure arc length along curve. | |
virtual void | position_from_length (const double from_here[3], double length, double result_point[3], MsqError &err) |
Get a position on the curve given an arc length. | |
Private Attributes | |
MsqCircle | mGeom |
Definition at line 122 of file MeshDomain1D.hpp.
MBMesquite::CircleDomain::CircleDomain | ( | const Vector3D & | center, |
const Vector3D & | normal, | ||
double | radius | ||
) | [inline] |
Definition at line 128 of file MeshDomain1D.hpp.
MBMesquite::CircleDomain::CircleDomain | ( | const MsqCircle & | circle | ) | [inline] |
Definition at line 130 of file MeshDomain1D.hpp.
: mGeom( circle ) {}
double MBMesquite::CircleDomain::arc_length | ( | const double | position1[3], |
const double | position2[3], | ||
MsqError & | err | ||
) | [virtual] |
Get the length along a curve between two points on the curve.
Implements MBMesquite::CurveDomain.
Definition at line 188 of file MeshDomain1D.cpp.
References moab::angle(), MBMesquite::MsqCircle::center(), mGeom, MBMesquite::MsqCircle::normal(), and MBMesquite::MsqCircle::radius().
Referenced by MBMesquite::CircleDomainTest::test_arc_length().
void MBMesquite::CircleDomain::closest_point | ( | Mesh::VertexHandle | handle, |
const Vector3D & | position, | ||
Vector3D & | closest, | ||
) | const [virtual] |
Given a position in space, return the closest position in the domain and the domain normal at that point.
entity_handle | Evaluate the subset of the domain contianing this entity |
position | Input position for which to evaluate |
closest | Closest position in the domain. |
normal | Domain normal at the location of 'closest' |
Implements MBMesquite::MeshDomain.
Definition at line 165 of file MeshDomain1D.cpp.
References MBMesquite::MsqCircle::center(), geom(), INTERNAL_ERROR, MSQ_SETERR, and MBMesquite::MsqCircle::radial_vector().
{ // no normal, get tangent instead if( !geom().closest( position, closest, normal ) ) { // at center? normal = geom().radial_vector(); closest = geom().center() + normal; } MSQ_SETERR( err )( "Cannot get normal for CircleDomain", MsqError::INTERNAL_ERROR ); }
void MBMesquite::CircleDomain::domain_DoF | ( | const Mesh::VertexHandle * | handle_array, |
unsigned short * | dof_array, | ||
size_t | num_handles, | ||
Definition at line 180 of file MeshDomain1D.cpp.
{ std::fill( dof_array, dof_array + num_handles, 1 ); }
void MBMesquite::CircleDomain::element_normal_at | ( | Mesh::ElementHandle | entity_handle, |
Vector3D & | coordinate | ||
Definition at line 150 of file MeshDomain1D.cpp.
References vertex_normal_at().
{ CircleDomain::vertex_normal_at( h, coordinate ); }
const MsqCircle& MBMesquite::CircleDomain::geom | ( | ) | const [inline] |
Definition at line 132 of file MeshDomain1D.hpp.
Referenced by closest_point(), snap_to(), and vertex_normal_at().
{ return mGeom; }
void MBMesquite::CircleDomain::position_from_length | ( | const double | from_here[3], |
double | length, | ||
double | result_point[3], | ||
) | [virtual] |
Measure a specified arc length along a curve.
from_here | Point on curve from which to measure |
length | Length along curve to move |
result_point | Output. A point on the curve length units from the point from_here in the forward direction along the curve. |
Definition at line 200 of file MeshDomain1D.cpp.
References moab::angle(), b, MBMesquite::MsqCircle::center(), MBMesquite::Vector3D::get_coordinates(), MBMesquite::Vector3D::length(), mGeom, MBMesquite::MsqCircle::normal(), and MBMesquite::MsqCircle::radius().
Referenced by MBMesquite::CircleDomainTest::test_position_from_length().
{ Vector3D b = Vector3D( from_here ) - mGeom.center(); Vector3D vy = mGeom.normal() * b; Vector3D vx = vy * mGeom.normal(); double angle = length / mGeom.radius(); double x = std::cos( angle ); double y = std::sin( angle ); vy *= y / vy.length(); vx *= x / vx.length(); Vector3D result = vx + vy; result *= mGeom.radius(); result += mGeom.center(); result.get_coordinates( result_point ); }
void MBMesquite::CircleDomain::snap_to | ( | Mesh::VertexHandle | entity_handle, |
Modifies "coordinate" so that it lies on the domain to which "entity_handle" is constrained. The handle determines the domain. The coordinate is the proposed new position on that domain.
Definition at line 137 of file MeshDomain1D.cpp.
References MBMesquite::MsqCircle::closest(), and geom().
Referenced by MBMesquite::CircleDomainTest::test_snap_to().
void MBMesquite::CircleDomain::vertex_normal_at | ( | Mesh::VertexHandle | entity_handle, |
Returns the normal of the domain to which "entity_handle" is constrained. For non-planar surfaces, the normal is calculated at the point on the domain that is closest to the passed in value of "coordinate". If the domain does not have a normal, or the normal cannot be determined, "coordinate" is set to (0,0,0). Otherwise, "coordinate" is set to the domain's normal at the appropriate point. In summary, the handle determines the domain. The coordinate determines the point of interest on that domain.
User should see also PatchData::get_domain_normal_at_vertex and PatchData::get_domain_normal_at_element .
Definition at line 142 of file MeshDomain1D.cpp.
References geom(), and MBMesquite::MsqCircle::radial_vector().
Referenced by element_normal_at(), and vertex_normal_at().
{ // no normal, return tangent instead. Vector3D junk, copy( coordinate ); if( !geom().closest( copy, junk, coordinate ) ) // at center? coordinate = geom().radial_vector(); }
void MBMesquite::CircleDomain::vertex_normal_at | ( | const Mesh::VertexHandle * | handles, |
Vector3D | coordinates[], | ||
unsigned | count, | ||
Returns normals for a domain.
handles | The domain evaluated is the one in which this mesh entity is constrained. |
coordinates | As input, a list of positions at which to evaluate the domain. As output, the resulting domain normals. |
count | The length of the coordinates array. |
Definition at line 155 of file MeshDomain1D.cpp.
References INTERNAL_ERROR, MSQ_SETERR, and vertex_normal_at().
{ for( unsigned i = 0; i < count; ++i ) vertex_normal_at( handles[i], coordinates[i] ); MSQ_SETERR( err )( "Cannot get normal for CircleDomain", MsqError::INTERNAL_ERROR ); }
MsqCircle MBMesquite::CircleDomain::mGeom [private] |
Definition at line 125 of file MeshDomain1D.hpp.
Referenced by arc_length(), and position_from_length().
