MOAB: Mesh Oriented datABase
(version 5.2.1)
#include <PatchData.hpp>
Public Types | |
enum | ComputedInfo { MIN_UNSIGNED_AREA = 0, MAX_UNSIGNED_AREA, MIN_EDGE_LENGTH, MAX_EDGE_LENGTH, MINMAX_SIGNED_DET2D, MINMAX_SIGNED_DET3D, AVERAGE_DET3D, MAX_COMPUTED_INFO_ENUM } |
Public Member Functions | |
MESQUITE_EXPORT | PatchData () |
MESQUITE_EXPORT | ~PatchData () |
MESQUITE_EXPORT void | attach_settings (const Settings *p_settings) |
MESQUITE_EXPORT const Settings * | settings () const |
MESQUITE_EXPORT void | fill (size_t num_vertex, const double *vtx_coords, size_t num_elem, EntityTopology type, const size_t *connectivity, const bool *vertex_fixed_flags, MsqError &err) |
For use by testing code -- create patch explicitly. | |
MESQUITE_EXPORT void | fill (size_t num_vertex, const double *vtx_coords, size_t num_elem, const EntityTopology *elem_types, const size_t *connectivity, const bool *vertex_fixed_flags, MsqError &err) |
MESQUITE_EXPORT void | fill (size_t num_vertex, const double *vtx_coords, size_t num_elem, const EntityTopology *elem_types, const size_t *vertex_per_elem, const size_t *elem_connectivity, const bool *vertex_fixed_flags, MsqError &err) |
MESQUITE_EXPORT void | fill_global_patch (MsqError &err) |
Create global patch. | |
MESQUITE_EXPORT void | set_mesh_entities (std::vector< Mesh::ElementHandle > &patch_elems, std::vector< Mesh::VertexHandle > &free_vertices, MsqError &err) |
MESQUITE_EXPORT void | clear_computed_info () |
This function clears the patch information such as maximum volume, etc ... | |
MESQUITE_EXPORT bool | have_computed_info (ComputedInfo info) const |
MESQUITE_EXPORT void | get_minmax_element_unsigned_area (double &min, double &max, MsqError &err) |
MESQUITE_EXPORT void | get_minmax_edge_length (double &min, double &max) const |
MESQUITE_EXPORT void | clear () |
Removes data. | |
MESQUITE_EXPORT void | reorder () |
Reorders the mesh data. | |
MESQUITE_EXPORT size_t | num_nodes () const |
number of vertices in the patch. | |
MESQUITE_EXPORT size_t | num_free_vertices () const |
MESQUITE_EXPORT size_t | num_slave_vertices () const |
MESQUITE_EXPORT size_t | num_fixed_vertices () const |
MESQUITE_EXPORT size_t | num_elements () const |
number of elements in the Patch. | |
MESQUITE_EXPORT bool | is_vertex_free (size_t index) const |
MESQUITE_EXPORT bool | is_vertex_not_free (size_t index) const |
MESQUITE_EXPORT bool | is_vertex_slave (size_t index) const |
MESQUITE_EXPORT bool | is_vertex_fixed (size_t index) const |
MESQUITE_EXPORT size_t | num_corners () const |
number of element corners (number of vertex uses) in patch | |
MESQUITE_EXPORT const MsqVertex * | get_vertex_array (MsqError &err) const |
Returns a pointer to the start of the vertex array. | |
MESQUITE_EXPORT const MsqVertex * | get_vertex_array () const |
MESQUITE_EXPORT const MsqMeshEntity * | get_element_array (MsqError &err) const |
Returns a pointer to the start of the element array. | |
MESQUITE_EXPORT MsqMeshEntity * | get_element_array (MsqError &err) |
MESQUITE_EXPORT size_t * | get_connectivity_array () |
MESQUITE_EXPORT Mesh::ElementHandle * | get_element_handles_array () |
MESQUITE_EXPORT Mesh::VertexHandle * | get_vertex_handles_array () |
MESQUITE_EXPORT const MsqVertex & | vertex_by_index (size_t index) const |
MESQUITE_EXPORT MsqMeshEntity & | element_by_index (size_t index) |
MESQUITE_EXPORT const MsqMeshEntity & | element_by_index (size_t index) const |
MESQUITE_EXPORT size_t | get_vertex_index (MsqVertex *vertex) |
MESQUITE_EXPORT size_t | get_element_index (MsqMeshEntity *element) |
MESQUITE_EXPORT void | get_element_vertex_coordinates (size_t elem_index, std::vector< Vector3D > &coords, MsqError &err) |
Get the coordinates of vertices attached to the specified element. | |
MESQUITE_EXPORT void | get_element_vertex_indices (size_t elem_index, std::vector< size_t > &vertex_indices, MsqError &err) |
MESQUITE_EXPORT void | get_vertex_element_indices (size_t vertex_index, std::vector< size_t > &elem_indices, MsqError &err) |
MESQUITE_EXPORT void | get_vertex_element_indices (size_t vertex_index, unsigned element_dimension, std::vector< size_t > &elem_indices, MsqError &err) |
MESQUITE_EXPORT const size_t * | get_vertex_element_adjacencies (size_t vertex_index, size_t &array_len_out, MsqError &err) |
MESQUITE_EXPORT void | get_adjacent_vertex_indices (size_t vertex_index, std::vector< size_t > &vert_indices, MsqError &err) const |
This function fills a vector<size_t> with the indices to vertices connected to the given vertex by an edge. If vert_indices is not initially empty, the function will not delete the current contents. Instead, it will append the new indices at the end of the vector. | |
MESQUITE_EXPORT void | get_adjacent_entities_via_n_dim (int n, size_t ent_ind, std::vector< size_t > &adj_ents, MsqError &err) |
Get the indices of entities attached to entity (given by ent_ind). adj_ents is filled with the indices into the entity array of elements adjacent to the given element via an n-dimensional entity. | |
MESQUITE_EXPORT void | generate_vertex_to_element_data () |
MESQUITE_EXPORT void | set_vertex_coordinates (const Vector3D &coords, size_t index, MsqError &err) |
set the coordinates of the index-th vertex in the raw array | |
MESQUITE_EXPORT void | move_vertex (const Vector3D &delta, size_t index, MsqError &err) |
increment the coordinates of the index-th vertex in the raw array | |
MESQUITE_EXPORT void | snap_vertex_to_domain (size_t vertex_index, MsqError &err) |
MESQUITE_EXPORT bool | domain_set () const |
MESQUITE_EXPORT void | get_domain_normal_at_vertex (size_t vert_index, Mesh::ElementHandle element, Vector3D &normal_out, MsqError &err) |
MESQUITE_EXPORT void | get_domain_normal_at_element (size_t elem_index, Vector3D &surf_norm, MsqError &err) |
MESQUITE_EXPORT void | get_domain_normals_at_corners (size_t element_index, Vector3D normals_out[], MsqError &err) |
MESQUITE_EXPORT void | get_domain_normal_at_corner (size_t elemen_index, unsigned corner, Vector3D &normal, MsqError &err) |
MESQUITE_EXPORT void | get_domain_normal_at_mid_edge (size_t element_index, unsigned edge_number, Vector3D &normal, MsqError &err) |
MESQUITE_EXPORT void | get_domain_normal_at_element (const MsqMeshEntity *elem_ptr, Vector3D &surf_norm, MsqError &err) |
Alternative signature. Same functionality. | |
MESQUITE_EXPORT void | get_domain_normal_at_sample (size_t element_index, Sample location, Vector3D &surf_norm, MsqError &err) |
MESQUITE_EXPORT void | move_free_vertices_constrained (Vector3D dk[], size_t nb_vtx, double step_size, MsqError &err) |
Moves free vertices and then snaps the free vertices to the domain. | |
MESQUITE_EXPORT void | set_free_vertices_constrained (PatchDataVerticesMemento *memento, Vector3D dk[], size_t nb_vtx, double step_size, MsqError &err) |
MESQUITE_EXPORT void | project_gradient (std::vector< Vector3D > &gradient, MsqError &err) |
Project gradient vector terms onto geometric domain. | |
MESQUITE_EXPORT double | get_max_vertex_movement_squared (PatchDataVerticesMemento *memento, MsqError &err) |
MESQUITE_EXPORT void | update_mesh (MsqError &err, const TagHandle *tag=0) |
This function copies to the TSTT mesh the changes made to the free vertices / elements of the PatchData object. | |
MESQUITE_EXPORT void | update_slave_node_coordinates (MsqError &err) |
MESQUITE_EXPORT void | update_slave_node_coordinates (const size_t *elem_indices, size_t num_elem, MsqError &err) |
MESQUITE_EXPORT void | set_all_vertices_soft_free (MsqError &err) |
Remove the soft_fixed flag from all vertices in the patch. | |
MESQUITE_EXPORT void | set_all_vertices_soft_fixed (MsqError &err) |
Add a soft_fixed flag to all vertices in the patch. | |
MESQUITE_EXPORT void | set_free_vertices_soft_fixed (MsqError &err) |
Add a soft_fixed flag to all free vertices in the patch. | |
MESQUITE_EXPORT void | set_vertex_culled (size_t vtx_index) |
Mark vertex as culled (soft fixed) | |
MESQUITE_EXPORT void | clear_vertex_culled (size_t vtx_index) |
MESQUITE_EXPORT int | check_vertex_culled (size_t vtx_index) const |
check if vertex is culled | |
MESQUITE_EXPORT void | get_subpatch (size_t center_vertex_index, unsigned num_adj_elem_layers, PatchData &pd_to_fill, MsqError &err) |
MESQUITE_EXPORT void | get_free_vertex_coordinates (std::vector< Vector3D > &coords_out) const |
MESQUITE_EXPORT PatchDataVerticesMemento * | create_vertices_memento (MsqError &err) |
MESQUITE_EXPORT void | recreate_vertices_memento (PatchDataVerticesMemento *memento, MsqError &err) |
MESQUITE_EXPORT void | set_to_vertices_memento (PatchDataVerticesMemento *memento, MsqError &err) |
MESQUITE_EXPORT void | set_mesh (Mesh *ms) |
MESQUITE_EXPORT Mesh * | get_mesh () const |
Returns the originating meshSet. | |
MESQUITE_EXPORT void | set_domain (MeshDomain *dm) |
MESQUITE_EXPORT MeshDomain * | get_domain () const |
MESQUITE_EXPORT const Settings * | get_settings () const |
MESQUITE_EXPORT const MappingFunction * | get_mapping_function (EntityTopology type) const |
MESQUITE_EXPORT const MappingFunction2D * | get_mapping_function_2D (EntityTopology type) const |
MESQUITE_EXPORT const MappingFunction3D * | get_mapping_function_3D (EntityTopology type) const |
MESQUITE_EXPORT void | get_sample_location (size_t element_index, Sample sample, Vector3D &result, MsqError &err) const |
Get R^3 coordinates for logical sample location. | |
MESQUITE_EXPORT NodeSet | non_slave_node_set (size_t elem_idx) const |
MESQUITE_EXPORT NodeSet | get_samples (size_t element, NodeSet non_slave_nodes) const |
MESQUITE_EXPORT NodeSet | get_samples (size_t element) const |
MESQUITE_EXPORT void | get_samples (size_t element, std::vector< Sample > &samples_out, MsqError &err) const |
Private Member Functions | |
PatchData (const PatchData &pd) | |
PatchData & | operator= (const PatchData &pd) |
bool | attach_extra_data (ExtraData *data) |
Attach an ExtraData object to this PatchData. | |
bool | remove_extra_data (ExtraData *data) |
Remove an ExtraData object from this PatchData. | |
void | notify_new_patch () |
notify all attached ExtraData instances that patch contents have changed | |
void | notify_sub_patch (PatchData &sub_patch, const size_t *vertex_index_map, const size_t *element_index_map, MsqError &err) |
notify all attached ExtraData instances that a subpatch is being initalized | |
void | notify_patch_destroyed () |
notify all attached ExtraData instances that this patch is being destroyed | |
void | enslave_higher_order_nodes (const size_t *element_offset_array, unsigned char *vertex_flags, MsqError &err) const |
void | initialize_data (size_t *elem_offset_array, unsigned char *vertex_flags, MsqError &err) |
void | note_have_info (ComputedInfo info) |
void | update_cached_normals (MsqError &) |
Static Private Member Functions | |
static void | make_handles_unique (Mesh::EntityHandle *handles, size_t &count, size_t *index_map=0) |
Private Attributes | |
Mesh * | myMesh |
The Mesh used to fill this PatchData [may be NULL]. | |
MeshDomain * | myDomain |
The geometric domain of the mesh [may be NULL]. | |
std::vector< MsqVertex > | vertexArray |
std::vector< Mesh::VertexHandle > | vertexHandlesArray |
size_t | numFreeVertices |
size_t | numSlaveVertices |
std::vector< MsqMeshEntity > | elementArray |
std::vector< Mesh::ElementHandle > | elementHandlesArray |
std::vector< size_t > | elemConnectivityArray |
std::vector< size_t > | vertAdjacencyArray |
std::vector< size_t > | vertAdjacencyOffsets |
std::vector< unsigned > | vertexNormalIndices |
std::vector< Vector3D > | normalData |
std::vector< unsigned short > | vertexDomainDOF |
std::vector< size_t > | offsetArray |
std::vector< unsigned char > | byteArray |
std::vector< bool > | bitMap |
double | computedInfos [MAX_COMPUTED_INFO_ENUM] |
unsigned | haveComputedInfos |
ExtraData * | dataList |
const Settings * | mSettings |
Static Private Attributes | |
static const Settings | defaultSettings |
Friends | |
class | MBMesquite::ExtraData |
std::ostream & | operator<< (std::ostream &, const PatchData &) |
Display the coordinates and connectivity information. |
Contains all the mesh information necessary for one iteration of the optimization algorithms over a local mesh patch.
Definition at line 70 of file PatchData.hpp.
Definition at line 161 of file PatchData.hpp.
{ MIN_UNSIGNED_AREA = 0, //!< minimum volume or area out of all elements in the patch MAX_UNSIGNED_AREA, //!< maximum volume or area out of all elements in the patch MIN_EDGE_LENGTH, //!< minimum edge length in the patch MAX_EDGE_LENGTH, //!< maximum edge length in the patch MINMAX_SIGNED_DET2D, //!< minimum and maximum corner area out of all elements in the patch MINMAX_SIGNED_DET3D, //!< minimum and maximum corner volume out of all elements in the //!< patch AVERAGE_DET3D, //!< average corner determinant out of all elements in the patch MAX_COMPUTED_INFO_ENUM };
Definition at line 71 of file PatchData.cpp.
: myMesh( 0 ), myDomain( 0 ), numFreeVertices( 0 ), numSlaveVertices( 0 ), haveComputedInfos( 0 ), dataList( 0 ), mSettings( &defaultSettings ) { }
Definition at line 78 of file PatchData.cpp.
References notify_patch_destroyed().
{ notify_patch_destroyed(); }
MBMesquite::PatchData::PatchData | ( | const PatchData & | pd | ) | [private] |
Doesn't allow PatchData to be copied implicitly. Mementos such as PatchDataVerticesMemento should be used when necessary.
bool MBMesquite::PatchData::attach_extra_data | ( | ExtraData * | data | ) | [private] |
Definition at line 1961 of file PatchData.cpp.
References dataList, MBMesquite::ExtraData::patchNext, and MBMesquite::ExtraData::patchPtr.
Referenced by MBMesquite::ExtraData::ExtraData().
MESQUITE_EXPORT void MBMesquite::PatchData::attach_settings | ( | const Settings * | p_settings | ) | [inline] |
Definition at line 77 of file PatchData.hpp.
References mSettings.
Referenced by MBMesquite::TerminationCriterion::accumulate_outer(), check_global_patch_slaved(), PatchDataTest::check_higher_order_vertices_slaved(), QualityMetricTester::compare_analytical_and_numerical_diagonals(), QualityMetricTester::compare_analytical_and_numerical_gradients(), QualityMetricTester::compare_analytical_and_numerical_hessians(), QualityMetricTester::compare_eval_and_eval_with_indices(), QualityMetricTester::compare_eval_with_diag_and_eval_with_hessian(), QualityMetricTester::compare_eval_with_grad_and_eval_with_diagonal(), QualityMetricTester::compare_eval_with_grad_and_eval_with_hessian(), QualityMetricTester::compare_eval_with_indices_and_eval_with_diagonal(), QualityMetricTester::compare_eval_with_indices_and_eval_with_gradient(), QualityMetricTester::compare_eval_with_indices_and_eval_with_hessian(), MBMesquite::create_ideal_element_patch(), MBMesquite::TerminationCriterion::cull_vertices_global(), IdealTargetTest::get_calc_target(), MBMesquite::MeshUtil::get_global_patch(), MBMesquite::PatchPowerMeanP::initialize_block_coordinate_descent(), MBMesquite::TargetWriter::loop_over_mesh(), MBMesquite::VertexMover::loop_over_mesh(), MBMesquite::QualityAssessor::loop_over_mesh_internal(), TQualityMetricTest::regression_inverse_mean_ratio_grad(), TQualityMetricTest::regression_inverse_mean_ratio_hess(), MBMesquite::TerminationCriterion::reset_outer(), MBMesquite::ShapeImprover::run_wrapper(), tag_patch_slaved(), test_bad_element(), QualityAssessorTest::test_basic_stats_sample(), QualityMetricTester::test_diagonal_with_fixed_vertex(), QualityMetricTester::test_domain_deviation_gradient(), QualityMetricTester::test_domain_deviation_quality(), QualityMetricTester::test_evaluate_unit_edge_element(), QualityMetricTester::test_evaluate_unit_edge_tris_about_vertex(), QualityMetricTester::test_evaluate_unit_element(), QualityMetricTester::test_evaluate_unit_hexes_about_vertex(), QualityMetricTester::test_evaluate_unit_quads_about_vertex(), QualityMetricTester::test_evaluate_unit_tris_about_vertex(), PatchDataTest::test_fixed_by_geom_dim(), QualityMetricTester::test_get_edge_evaluations(), QualityMetricTester::test_get_edge_indices(), QualityMetricTester::test_get_element_evaluations(), QualityMetricTester::test_get_element_indices(), QualityMetricTester::test_get_in_element_evaluations(), QualityMetricTester::test_get_indices_fixed(), QualityMetricTester::test_get_sample_evaluations(), QualityMetricTester::test_get_sample_indices(), QualityMetricTester::test_get_vertex_evaluations(), QualityMetricTester::test_get_vertex_indices(), QualityMetricTester::test_grad_transform_invariant(), TMPQualityMetricTest< QMType >::test_gradient_3D(), TMPQualityMetricTest< QMType >::test_gradient_common(), QualityMetricTester::test_gradient_reflects_quality(), QualityMetricTester::test_gradient_with_fixed_vertex(), QualityMetricTester::test_hessian_transform_invariant(), QualityMetricTester::test_hessian_with_fixed_vertex(), QualityMetricTester::test_ideal_element_positive_definite_Hessian(), QualityMetricTester::test_ideal_element_zero_gradient(), QualityMetricTester::test_ideal_element_zero_vertex_gradient(), QualityMetricTester::test_measures_quality(), QualityMetricTester::test_measures_transform(), QualityMetricTester::test_measures_vertex_quality(), PatchDataTest::test_quad8_patch(), QualityMetricTester::test_symmetric_Hessian_diagonal_blocks(), QualityMetricTester::test_transform_invariant(), QualityMetricTester::test_type_is_not_supported(), QualityMetricTester::test_type_is_supported(), PatchDataTest::test_update_slave_node_coords(), and QualityMetricTester::test_vertex_gradient_reflects_quality().
{ mSettings = p_settings; }
MESQUITE_EXPORT int MBMesquite::PatchData::check_vertex_culled | ( | size_t | vtx_index | ) | const [inline] |
Definition at line 501 of file PatchData.hpp.
References MBMesquite::MsqVertex::MSQ_CULLED, and vertexArray.
{ return vertexArray[vtx_index].get_flags() | MsqVertex::MSQ_CULLED; }
void MBMesquite::PatchData::clear | ( | ) | [inline] |
Removes data.
Returns average corner determinant over all corners in the patch This information is stored in the patch and should not decrease performance when used properly. See also PatchData::clear_computed_info() .
Definition at line 786 of file PatchData.hpp.
References elemConnectivityArray, elementArray, elementHandlesArray, haveComputedInfos, myDomain, myMesh, normalData, numFreeVertices, numSlaveVertices, vertAdjacencyArray, vertAdjacencyOffsets, vertexArray, vertexHandlesArray, and vertexNormalIndices.
Referenced by set_mesh_entities().
{ vertexArray.clear(); vertexHandlesArray.clear(); elementArray.clear(); elementHandlesArray.clear(); elemConnectivityArray.clear(); vertAdjacencyArray.clear(); vertAdjacencyOffsets.clear(); vertexNormalIndices.clear(); normalData.clear(); // vertexDomainDOF.clear(); numFreeVertices = 0; numSlaveVertices = 0; haveComputedInfos = 0; myMesh = 0; myDomain = 0; }
MESQUITE_EXPORT void MBMesquite::PatchData::clear_computed_info | ( | ) | [inline] |
Definition at line 176 of file PatchData.hpp.
References haveComputedInfos.
{ haveComputedInfos = 0; }
MESQUITE_EXPORT void MBMesquite::PatchData::clear_vertex_culled | ( | size_t | vtx_index | ) | [inline] |
Definition at line 495 of file PatchData.hpp.
References vertexArray.
{ vertexArray[vtx_index].flags() &= ~MsqVertex::MSQ_CULLED; }
PatchDataVerticesMemento * MBMesquite::PatchData::create_vertices_memento | ( | MsqError & | err | ) | [inline] |
Creates a memento that holds the current state of the PatchData coordinates.
This function instantiate PatchDataVerticesMemento object and returns a pointer to it. The PatchDataVerticesMemento contains the current state of the PatchData coordinates. It can be used to restore the same PatchData object to those coordinates.
It is the responsibility of the caller to discard the PatchDataVerticesMemento when not needed any more.
Definition at line 916 of file PatchData.hpp.
References MSQ_CHKERR, and recreate_vertices_memento().
Referenced by MBMesquite::QuasiNewton::initialize(), MBMesquite::TrustRegion::initialize(), MBMesquite::ConjugateGradient::initialize(), MBMesquite::FeasibleNewton::initialize(), UnOptimizer::optimize_vertex_positions(), MBMesquite::SteepestDescent::optimize_vertex_positions(), MBMesquite::TerminationCriterion::reset_inner(), and MBMesquite::TerminationCriterion::reset_patch().
{ PatchDataVerticesMemento* memento = new PatchDataVerticesMemento; recreate_vertices_memento( memento, err ); if( MSQ_CHKERR( err ) ) { delete memento; return 0; } return memento; }
MESQUITE_EXPORT bool MBMesquite::PatchData::domain_set | ( | ) | const [inline] |
Returns whether a domain is associated with the MeshSet from which the Patch originates. If false, you cannot ask for a surface normal.
Definition at line 362 of file PatchData.hpp.
References myDomain.
Referenced by MBMesquite::MsqMeshEntity::check_element_orientation(), MBMesquite::MsqMeshEntity::check_element_orientation_corners(), MBMesquite::MsqMeshEntity::compute_corner_normals(), MBMesquite::AspectRatioGammaQualityMetric::evaluate(), MBMesquite::TMPQualityMetric::evaluate_surface_common(), get_domain_normal_at_element(), get_domain_normal_at_mid_edge(), get_domain_normal_at_vertex(), get_domain_normals_at_corners(), QualityMetricTester::get_inverted_element(), MBMesquite::MsqMeshEntity::inverted_jacobian_2d(), MBMesquite::FeasibleNewton::optimize_vertex_positions(), project_gradient(), snap_vertex_to_domain(), and update_slave_node_coordinates().
{ return 0 != myDomain; }
MsqMeshEntity & MBMesquite::PatchData::element_by_index | ( | size_t | index | ) | [inline] |
Definition at line 878 of file PatchData.hpp.
References elementArray.
Referenced by MsqHessianTest::accumulate_entries(), MBMesquite::append_elem_samples(), MBMesquite::RefSizeTargetCalculator::average_edge_length(), PatchDataTest::check_sub_patch(), MBMesquite::TerminationCriterion::count_inverted(), MBMesquite::EdgeLengthMetric::evaluate(), MBMesquite::SizeMetric::evaluate(), MBMesquite::AspectRatioGammaQualityMetric::evaluate(), MBMesquite::ConditionNumberQualityMetric::evaluate(), MBMesquite::AffineMapMetric::evaluate(), MBMesquite::IdealWeightMeanRatio::evaluate(), MBMesquite::UntangleBetaQualityMetric::evaluate(), MBMesquite::IdealWeightInverseMeanRatio::evaluate(), FauxMetric< B >::evaluate(), MBMesquite::AWQualityMetric::evaluate_internal(), MBMesquite::TQualityMetric::evaluate_internal(), MBMesquite::TMPQualityMetric::evaluate_surface_common(), MBMesquite::EdgeLengthMetric::evaluate_with_gradient(), MBMesquite::AWQualityMetric::evaluate_with_gradient(), MBMesquite::TQualityMetric::evaluate_with_gradient(), MBMesquite::IdealWeightMeanRatio::evaluate_with_gradient(), MBMesquite::IdealWeightInverseMeanRatio::evaluate_with_gradient(), MBMesquite::IdealWeightMeanRatio::evaluate_with_Hessian(), MBMesquite::TQualityMetric::evaluate_with_Hessian(), MBMesquite::AWQualityMetric::evaluate_with_Hessian(), MBMesquite::IdealWeightInverseMeanRatio::evaluate_with_Hessian(), MBMesquite::IdealWeightMeanRatio::evaluate_with_Hessian_diagonal(), MBMesquite::TQualityMetric::evaluate_with_Hessian_diagonal(), MBMesquite::AWQualityMetric::evaluate_with_Hessian_diagonal(), MBMesquite::IdealWeightInverseMeanRatio::evaluate_with_Hessian_diagonal(), MBMesquite::ElementQM::evaluate_with_indices(), MBMesquite::AffineMapMetric::evaluate_with_indices(), MBMesquite::EdgeQM::evaluate_with_indices(), FauxMetric< B >::evaluate_with_indices(), ConstantElementMetric::evaluate_with_indices(), TriTauMetric::evaluate_with_indices(), fill(), MBMesquite::IdealShapeTarget::get_2D_target(), MBMesquite::TargetReader::get_2D_target(), FakeTargetCalc::get_2D_target(), MBMesquite::IdealShapeTarget::get_3D_target(), MBMesquite::TargetReader::get_3D_target(), FakeTargetCalc::get_3D_target(), MBMesquite::EdgeIterator::get_adjacent_vertices(), QualityMetricTester::get_degenerate_element(), get_domain_normal_at_element(), get_domain_normal_at_mid_edge(), MBMesquite::EdgeQM::get_edge_evaluations(), MBMesquite::ElementQM::get_element_evaluations(), FauxMetric< B >::get_element_evaluations(), QualityMetricTester::get_inverted_element(), get_minmax_edge_length(), QualityMetricTester::get_nonideal_element(), MBMesquite::TargetCalculator::get_refmesh_Jacobian_2D(), MBMesquite::TargetCalculator::get_refmesh_Jacobian_3D(), get_sample_location(), get_samples(), get_subpatch(), MBMesquite::TargetReader::get_surface_target(), FakeTargetCalc::get_surface_target(), MBMesquite::VertexQM::get_vertex_corner_handles(), QualityMetricTester::get_zero_element(), MBMesquite::NonGradient::getPatchDimension(), MBMesquite::MappingFunction2D::jacobian(), MBMesquite::MappingFunction3D::jacobian(), MBMesquite::MeshUtil::lambda_distribution(), MBMesquite::TargetWriter::loop_over_mesh(), MBMesquite::QualityAssessor::loop_over_mesh_internal(), TriTauMetric::matrix(), non_slave_node_set(), MBMesquite::CachingTargetCalculator::notify_sub_patch(), MBMesquite::SmartLaplacianSmoother::num_inverted(), MBMesquite::populate_data(), project_gradient(), MsqMeshEntityTest::test_all_nodes(), MsqMeshEntityTest::test_check_element_orientation(), QualityMetricTester::test_diagonal_with_fixed_vertex(), QualityMetricTest::test_fixed_vertex_list(), QualityMetricTester::test_get_element_indices(), QualityMetricTester::test_get_indices_fixed(), QualityMetricTester::test_get_sample_indices(), QualityMetricTester::test_gradient_reflects_quality(), QualityMetricTester::test_gradient_with_fixed_vertex(), QualityMetricTester::test_hessian_with_fixed_vertex(), MappingFunctionTest::test_jacobian_2d(), MappingFunctionTest::test_jacobian_3d(), QualityMetricTester::test_measures_quality(), PatchDataTest::test_patch_contents(), PatchDataTest::test_quad8_patch(), MsqMeshEntityTest::test_unsigned_area_common(), MsqMeshEntityTest::test_unsigned_area_poly(), TerminationCriterionTest::test_untangled_mesh(), PatchDataTest::test_update_slave_node_coords(), update_slave_node_coordinates(), MBMesquite::NonSmoothDescent::validity_check(), and MBMesquite::MeshWriter::write_vtk().
{ assert( index < elementArray.size() ); return elementArray[index]; }
const MsqMeshEntity & MBMesquite::PatchData::element_by_index | ( | size_t | index | ) | const [inline] |
Definition at line 884 of file PatchData.hpp.
void MBMesquite::PatchData::enslave_higher_order_nodes | ( | const size_t * | element_offset_array, |
unsigned char * | vertex_flags, | ||
MsqError & | err | ||
) | const [private] |
Call before initialize_data to change vertex_flags for higher-order nodes to MSQ_DEPENDENT.
Definition at line 1519 of file PatchData.cpp.
References elemConnectivityArray, elementArray, MBMesquite::MsqVertex::MSQ_DEPENDENT, MBMesquite::MsqVertex::MSQ_HARD_FIXED, and vertexHandlesArray.
Referenced by fill().
{ for( size_t i = 0; i < elementArray.size(); ++i ) { size_t start = elem_offset_array[i]; size_t conn_len = elem_offset_array[i + 1] - start; for( size_t j = elementArray[i].vertex_count(); j < conn_len; ++j ) { const size_t vert_idx = elemConnectivityArray[start + j]; assert( vert_idx < vertexHandlesArray.size() ); if( !( vertex_flags[vert_idx] & MsqVertex::MSQ_HARD_FIXED ) ) vertex_flags[vert_idx] |= MsqVertex::MSQ_DEPENDENT; } } }
void MBMesquite::PatchData::fill | ( | size_t | num_vertex, |
const double * | vtx_coords, | ||
size_t | num_elem, | ||
EntityTopology | type, | ||
const size_t * | connectivity, | ||
const bool * | vertex_fixed_flags, | ||
Create a patch containing elements of the same type and without any higher-order nodes.
num_vertex | Number of vertices in patch |
vtx_coords | Array of vertex coords. Length must be 3*num_vertex |
type | Element type |
connectivity | Element connectivity, specified as a list of vertex numbers, beginning with zero. |
vertex_fixed_flags | Optional array to specify which vertices are to be marked as fixed. If not specified, no vertices are fixed. |
Definition at line 1658 of file PatchData.cpp.
References MBMesquite::arrptr(), and MSQ_CHKERR.
Referenced by MBMesquite::create_four_quads_patch(), MBMesquite::create_ideal_element_patch(), MBMesquite::create_one_hex_patch(), MBMesquite::create_one_inverted_tet_patch(), MBMesquite::create_one_pyr_patch(), MBMesquite::create_one_quad_patch(), MBMesquite::create_one_tet_patch(), MBMesquite::create_one_tri_patch(), MBMesquite::create_one_wdg_patch(), MBMesquite::create_qm_two_hex_patch(), MBMesquite::create_qm_two_pyr_patch(), MBMesquite::create_qm_two_quad_patch_with_domain(), MBMesquite::create_qm_two_tet_patch(), MBMesquite::create_qm_two_tri_patch_with_domain(), MBMesquite::create_qm_two_wdg_patch(), MBMesquite::create_six_quads_patch_with_domain(), MBMesquite::create_twelve_hex_patch(), MBMesquite::create_two_tri_patch(), fill(), IdealTargetTest::get_calc_target(), QualityMetricTester::get_ideal_element(), QualityMetricTester::get_ideal_hexes(), QualityMetricTester::get_ideal_quads(), QualityMetricTester::get_ideal_tris(), init_pd(), TQualityMetricTest::regression_inverse_mean_ratio_grad(), TQualityMetricTest::regression_inverse_mean_ratio_hess(), MsqMeshEntityTest::test_all_nodes(), QualityMetricTest::test_fixed_vertex_list(), TargetCalculatorTest::test_get_refmesh_Jacobian_2D(), TargetCalculatorTest::test_get_refmesh_Jacobian_3D(), TMPQualityMetricTest< QMType >::test_gradient_3D(), TMPQualityMetricTest< QMType >::test_gradient_common(), MappingFunctionTest::test_jacobian_2d(), MappingFunctionTest::test_jacobian_3d(), PatchDataTest::test_patch_contents(), PatchDataTest::test_quad8_patch(), MsqMeshEntityTest::test_unsigned_area_common(), MsqMeshEntityTest::test_unsigned_area_poly(), and PatchDataTest::test_update_slave_node_coords().
{ std::vector< EntityTopology > types( num_elem ); std::fill( types.begin(), types.end(), type ); const EntityTopology* type_ptr = num_elem ? arrptr( types ) : 0; this->fill( num_vertex, coords, num_elem, type_ptr, connectivity, fixed, err );MSQ_CHKERR( err ); }
const EntityTopology * | elem_types, | ||
Create a patch containing elements without any higher-order nodes.
elem_types | The type of each element |
vertex_fixed_flags | Optional array to specify which vertices are to be marked as fixed. If NULL, no vertices are fixed. |
Definition at line 1667 of file PatchData.cpp.
References MBMesquite::arrptr(), corners, fill(), and MSQ_CHKERR.
{ std::vector< size_t > lengths( num_elem ); std::transform( types, types + num_elem, lengths.begin(), std::ptr_fun( TopologyInfo::corners ) ); const size_t* len_ptr = num_elem ? arrptr( lengths ) : 0; this->fill( num_vertex, coords, num_elem, types, len_ptr, conn, fixed, err );MSQ_CHKERR( err ); }
const size_t * | vertex_per_elem, | ||
const size_t * | elem_connectivity, | ||
Most general form of fill function. Works for polygons, elements with higher-order nodes, etc.
vertex_per_elem | The length of the connectivity list for each element. |
Definition at line 1676 of file PatchData.cpp.
References MBMesquite::arrptr(), byteArray, elemConnectivityArray, element_by_index(), elementArray, elementHandlesArray, enslave_higher_order_nodes(), get_connectivity_array(), MBMesquite::Settings::get_slaved_ho_node_mode(), initialize_data(), mSettings, MSQ_ERRRTN, MBMesquite::MsqVertex::MSQ_HARD_FIXED, MBMesquite::MsqVertex::MSQ_PATCH_FIXED, MSQ_SETERR, NOT_IMPLEMENTED, numFreeVertices, numSlaveVertices, MBMesquite::MsqMeshEntity::set_element_type(), MBMesquite::Settings::SLAVE_ALL, MBMesquite::Settings::SLAVE_NONE, moab::sum(), vertexArray, and vertexHandlesArray.
{ size_t i; // count vertex uses size_t num_uses = std::accumulate( lengths, lengths + num_elem, 0 ); // Allocate storage for data vertexArray.resize( num_vertex ); vertexHandlesArray.resize( num_vertex ); elementArray.resize( num_elem ); elementHandlesArray.resize( num_elem ); elemConnectivityArray.resize( num_uses ); numFreeVertices = 0; numSlaveVertices = 0; // Must call clear() first so that any stale values get // zero'd when we call resize. byteArray.clear(); if( fixed ) { byteArray.resize( num_vertex, 0 ); for( i = 0; i < num_vertex; ++i ) if( fixed[i] ) byteArray[i] |= ( MsqVertex::MSQ_HARD_FIXED | MsqVertex::MSQ_PATCH_FIXED ); } for( i = 0; i < num_elem; ++i ) { element_by_index( i ).set_element_type( types[i] ); elementHandlesArray[i] = (Mesh::ElementHandle)i; } for( i = 0; i < num_vertex; ++i ) vertexHandlesArray[i] = (Mesh::VertexHandle)i; memcpy( get_connectivity_array(), conn, num_uses * sizeof( size_t ) ); std::vector< size_t > offsets( num_elem + 1 ); size_t sum = offsets[0] = 0; for( i = 1; i <= num_elem; ++i ) offsets[i] = sum += lengths[i - 1]; const Settings::HigherOrderSlaveMode ho_mode = mSettings ? mSettings->get_slaved_ho_node_mode() : Settings::SLAVE_ALL; switch( ho_mode ) { case Settings::SLAVE_ALL: byteArray.resize( num_vertex, 0 ); enslave_higher_order_nodes( arrptr( offsets ), arrptr( byteArray ), err );MSQ_ERRRTN( err ); break; case Settings::SLAVE_NONE: // Do nothing. We clear other bits when processing the 'fixed' array above. break; default: MSQ_SETERR( err ) ( "Specified higher-order noded slaving scheme not supported " "when initializind PatchData using PatchData::fill", MsqError::NOT_IMPLEMENTED ); return; } this->initialize_data( arrptr( offsets ), arrptr( byteArray ), err );MSQ_ERRRTN( err ); // initialize_data will re-order vertex handles and // update element connectivity accordingly. Use // the values we stored in vertexHandlesArray to // figure out the new index of each vertex, and initialize // the vertex. for( i = 0; i < num_vertex; ++i ) vertexArray[i] = coords + 3 * (size_t)vertexHandlesArray[i]; for( i = 0; i < num_vertex; ++i ) vertexArray[i].flags() = byteArray[i]; }
void MBMesquite::PatchData::fill_global_patch | ( | MsqError & | err | ) |
Create a global patch - mesh should be initialized first.
Definition at line 1783 of file PatchData.cpp.
References b, get_mesh(), MBMesquite::PatchIterator::get_next_patch(), MBMesquite::MsqError::INVALID_MESH, MSQ_ERRRTN, MSQ_SETERR, and MBMesquite::PatchSet::set_mesh().
Referenced by MBMesquite::TerminationCriterion::accumulate_outer(), check_global_patch_slaved(), MBMesquite::MeshUtil::get_global_patch(), MBMesquite::TerminationCriterion::reset_outer(), tag_patch_slaved(), TerminationCriterionTest::test_absolute_vertex_movement_edge_length(), MBMesquite::MeshWriter::write_eps(), MBMesquite::MeshWriter::write_gnuplot(), MBMesquite::MeshWriter::write_svg(), and MBMesquite::MeshWriter::write_vtk().
{ GlobalPatch gp; gp.set_mesh( get_mesh() ); PatchIterator iter( &gp ); bool b = iter.get_next_patch( *this, err );MSQ_ERRRTN( err ); if( !b ) MSQ_SETERR( err )( "Empty patch in PatchData::fill_global_patch", MsqError::INVALID_MESH ); assert( b ); }
Create the arrays that store which elements are attached to each node. If you know how many total vertex uses there are, pass it in. Otherwise the PatchData will calculate that number.
Definition at line 943 of file PatchData.cpp.
References elemConnectivityArray, elementArray, MSQ_FUNCTION_TIMER, num_nodes(), vertAdjacencyArray, and vertAdjacencyOffsets.
Referenced by MBMesquite::EdgeIterator::EdgeIterator(), get_vertex_element_adjacencies(), and reorder().
{ MSQ_FUNCTION_TIMER( "PatchData::generate_vertex_to_element_data" ); // Skip if data already exists if( !vertAdjacencyArray.empty() ) return; // Skip if patch is empty if( 0 == num_nodes() ) return; // Allocate offset array vertAdjacencyOffsets.clear(); vertAdjacencyOffsets.resize( num_nodes() + 1, 0 ); // Temporarily use offsets array to hold per-vertex element count std::vector< MsqMeshEntity >::iterator elem_iter; const std::vector< MsqMeshEntity >::iterator elem_end = elementArray.end(); for( elem_iter = elementArray.begin(); elem_iter != elem_end; ++elem_iter ) { size_t* conn_iter = elem_iter->get_vertex_index_array(); const size_t* conn_end = conn_iter + elem_iter->node_count(); for( ; conn_iter != conn_end; ++conn_iter ) ++vertAdjacencyOffsets[*conn_iter]; } // Convert counts to end indices. // When done, vertAdjacencyOffsets will contain, for each vertex, // one more than the *last* index for that vertex's data in the // adjacency array. This is *not* the final state for this data. // See comments for next loop. std::vector< size_t >::iterator off_iter = vertAdjacencyOffsets.begin(); const std::vector< size_t >::iterator off_end = vertAdjacencyOffsets.end(); size_t prev = *off_iter; ++off_iter; for( ; off_iter != off_end; ++off_iter ) { prev += *off_iter; *off_iter = prev; } // Allocate space for element numbers const size_t num_vert_uses = vertAdjacencyOffsets[num_nodes() - 1]; assert( num_vert_uses == elemConnectivityArray.size() ); vertAdjacencyArray.resize( num_vert_uses ); // Fill vertAdjacencyArray, using the indices in vertAdjacencyOffsets // as the location to insert the next element number in // vertAdjacencyArray. When done, vertAdjacenyOffsets will contain // the start index for each vertex, rather than one past the last // index. for( size_t i = 0; i < elementArray.size(); ++i ) { size_t* conn_iter = elementArray[i].get_vertex_index_array(); const size_t* conn_end = conn_iter + elementArray[i].node_count(); for( ; conn_iter != conn_end; ++conn_iter ) { const size_t array_index = --vertAdjacencyOffsets[*conn_iter]; vertAdjacencyArray[array_index] = i; } } // Last entry should be number of vertex uses (one past the // last index of the last vertex.) vertAdjacencyOffsets[num_nodes()] = num_vert_uses; }
void MBMesquite::PatchData::get_adjacent_entities_via_n_dim | ( | int | n, |
size_t | ent_ind, | ||
std::vector< size_t > & | adj_ents, | ||
Fills a vector of indices into the entities array. The entities in the vector are connected the given entity (ent_ind) via an n-diminsional entity (where 'n' is a given integer). Thus, if n = 0, the entities must be connected via a vertex. If n = 1, the entities must be connected via an edge. If n = 2, the entities must be connected via a two-dimensional element. NOTE: if n is 2 and the elements in the entity array are two-dimensional, no entities should meet this criterion. The adj_ents vector is cleared at the beginning of the call.
Definition at line 670 of file PatchData.cpp.
References get_element_vertex_indices(), get_vertex_element_indices(), MSQ_ERRRTN, and MBMesquite::MSQ_MAX_NUM_VERT_PER_ENT.
{ // reset the vector adj_ents.clear(); // vertices of this entity (given by ent_ind) vector< size_t > verts; // vector to store elements attached to the vertices in verts vector< size_t > elem_on_vert[MSQ_MAX_NUM_VERT_PER_ENT]; // length of above vectos int length_elem_on_vert[MSQ_MAX_NUM_VERT_PER_ENT]; // get verts on this element get_element_vertex_indices( ent_ind, verts, err ); int num_vert = verts.size(); int i = 0; int j = 0; for( i = 0; i < num_vert; ++i ) { // get elements on the vertices in verts and the number of vertices get_vertex_element_indices( verts[i], elem_on_vert[i], err );MSQ_ERRRTN( err ); length_elem_on_vert[i] = elem_on_vert[i].size(); } // this_ent is the index for an entity which is a candidate to be placed // into adj_ents size_t this_ent; // num of times this_ent has been found in the vectors of entity indices int counter = 0; i = 0; // loop of each vert on ent_ind while( i < num_vert ) { // loop over each ent connected to vert j = 0; while( j < length_elem_on_vert[i] ) { // get candidate element this_ent = elem_on_vert[i][j]; // if we haven't already consider this ent if( this_ent != ent_ind ) { // if this_ent occurred earlier we would have already considered it // so start at i and j+1 int k1 = i; int k2 = j + 1; // this_ent has occured once so far counter = 1; // while k1 < num_vert while( k1 < num_vert ) { // loop over entries in the elem on vert vector while( k2 < length_elem_on_vert[k1] ) { // if it matches this_ent if( elem_on_vert[k1][k2] == this_ent ) { // mark it as 'seen', by making it the same as ent_ind // i.e., the entity passed to us. elem_on_vert[k1][k2] = ent_ind; ++counter; // do not look at remaining elems in this vector k2 += length_elem_on_vert[k1]; } else ++k2; } ++k1; k2 = 0; } // if this_ent occured enough times and isn't ent_ind if( counter > n && this_ent != ent_ind ) { adj_ents.push_back( this_ent ); } } ++j; } ++i; } }
void MBMesquite::PatchData::get_adjacent_vertex_indices | ( | size_t | vertex_index, |
std::vector< size_t > & | vert_indices, | ||
) | const |
Get the indices of vertices that are attached to vertex (given by vertex_index) by an element edge.
Definition at line 596 of file PatchData.cpp.
References MBMesquite::adj(), bitMap, conn, corners, dim, elementArray, MSQ_ERRRTN, num_nodes(), and MBMesquite::POLYGON.
Referenced by MBMesquite::EdgeLengthQualityMetric::evaluate_common(), MBMesquite::EdgeLengthRangeQualityMetric::evaluate_common(), MBMesquite::LocalSizeQualityMetric::evaluate_with_indices(), MBMesquite::get_delta_C(), MBMesquite::SmartLaplacianSmoother::optimize_vertex_positions(), MBMesquite::LaplacianSmoother::optimize_vertex_positions(), and QualityMetricTester::test_get_vertex_indices().
{ bitMap.clear(); bitMap.resize( num_nodes(), false ); const size_t* conn; size_t conn_idx, curr_vtx_idx; const unsigned* adj; unsigned num_adj, i; std::vector< MsqMeshEntity >::const_iterator e; for( e = elementArray.begin(); e != elementArray.end(); ++e ) { conn = e->get_vertex_index_array(); conn_idx = std::find( conn, conn + e->node_count(), vertex_index ) - conn; if( conn_idx == e->node_count() ) continue; // If a higher-order node, return corners of side/face // that node is in the center of. EntityTopology type = e->get_element_type(); if( conn_idx >= TopologyInfo::corners( type ) && type != POLYGON ) { unsigned dim, id; TopologyInfo::side_from_higher_order( type, e->node_count(), conn_idx, dim, id, err );MSQ_ERRRTN( err ); adj = TopologyInfo::side_vertices( type, dim, id, num_adj ); } else { EntityTopology topo = e->get_element_type(); if( topo == POLYGON ) { unsigned number_of_nodes = e->node_count(); num_adj = 2; // always 2 for a polygon unsigned vert_adj[2]; vert_adj[0] = ( conn_idx + 1 ) % number_of_nodes; vert_adj[1] = ( conn_idx + number_of_nodes - 1 ) % number_of_nodes; for( i = 0; i < num_adj; ++i ) { curr_vtx_idx = conn[vert_adj[i]]; // get index into patch vertex list if( !bitMap[curr_vtx_idx] ) { vert_indices.push_back( curr_vtx_idx ); bitMap[curr_vtx_idx] = true; } } } else { adj = TopologyInfo::adjacent_vertices( topo, conn_idx, num_adj ); for( i = 0; i < num_adj; ++i ) { curr_vtx_idx = conn[adj[i]]; // get index into patch vertex list if( !bitMap[curr_vtx_idx] ) { vert_indices.push_back( curr_vtx_idx ); bitMap[curr_vtx_idx] = true; } } } } } }
MESQUITE_EXPORT size_t* MBMesquite::PatchData::get_connectivity_array | ( | ) | [inline] |
Definition at line 264 of file PatchData.hpp.
References MBMesquite::arrptr(), and elemConnectivityArray.
{ return arrptr( elemConnectivityArray ); }
MESQUITE_EXPORT MeshDomain* MBMesquite::PatchData::get_domain | ( | ) | const [inline] |
Definition at line 549 of file PatchData.hpp.
Referenced by MBMesquite::destroy_patch_with_domain(), get_domain_normal_at_element(), get_domain_normal_at_mid_edge(), get_domain_normal_at_vertex(), get_domain_normals_at_corners(), CompareMetric::get_mask_axis(), MBMesquite::FeasibleNewton::optimize_vertex_positions(), project_gradient(), snap_vertex_to_domain(), update_cached_normals(), PatchTranslate::xform(), PatchScale::xform(), and PatchRotate::xform().
{ return myDomain; }
void MBMesquite::PatchData::get_domain_normal_at_corner | ( | size_t | elemen_index, |
unsigned | corner, | ||
Vector3D & | normal, | ||
Definition at line 1322 of file PatchData.cpp.
References elementArray, elementHandlesArray, get_domain_normal_at_vertex(), MBMesquite::MsqMeshEntity::get_vertex_index_array(), MBMesquite::MsqError::INVALID_ARG, MSQ_CHKERR, and MSQ_SETERR.
Referenced by MBMesquite::AspectRatioGammaQualityMetric::evaluate(), and get_domain_normal_at_sample().
{ assert( elem_index < elementArray.size() ); if( 2 != TopologyInfo::dimension( elementArray[elem_index].get_element_type() ) ) { MSQ_SETERR( err )( "Attempt to get corners of non-surface element", MsqError::INVALID_ARG ); return; } MsqMeshEntity& elem = elementArray[elem_index]; const size_t* const vertex_indices = elem.get_vertex_index_array(); get_domain_normal_at_vertex( vertex_indices[corner], elementHandlesArray[elem_index], normal, err );MSQ_CHKERR( err ); }
void MBMesquite::PatchData::get_domain_normal_at_element | ( | size_t | elem_index, |
Vector3D & | surf_norm, | ||
Get the normal to the domain at the centroid (projected to the domain) of a given element. Normal is returned in Vector3D &surf_norm. If the normal cannot be determined, or if the underlying domain is not a surface, the normal will be set to (0,0,0). Check PatchData::domain_set() is not false first.
Definition at line 1207 of file PatchData.cpp.
References domain_set(), element_by_index(), MBMesquite::MeshDomain::element_normal_at(), elementArray, elementHandlesArray, get_domain(), get_domain_normal_at_vertex(), MBMesquite::MsqMeshEntity::get_element_type(), MBMesquite::MsqMeshEntity::get_vertex_index_array(), MBMesquite::MsqError::INVALID_STATE, MSQ_ERRRTN, MSQ_SETERR, and MBMesquite::MsqMeshEntity::node_count().
Referenced by MBMesquite::MsqMeshEntity::check_element_orientation_corners(), MBMesquite::MsqMeshEntity::compute_signed_area(), MBMesquite::condition_number_2d(), MBMesquite::IdealWeightMeanRatio::evaluate(), MBMesquite::IdealWeightInverseMeanRatio::evaluate(), MBMesquite::IdealWeightMeanRatio::evaluate_with_gradient(), MBMesquite::IdealWeightInverseMeanRatio::evaluate_with_gradient(), MBMesquite::IdealWeightMeanRatio::evaluate_with_Hessian(), MBMesquite::IdealWeightInverseMeanRatio::evaluate_with_Hessian(), MBMesquite::IdealWeightMeanRatio::evaluate_with_Hessian_diagonal(), MBMesquite::IdealWeightInverseMeanRatio::evaluate_with_Hessian_diagonal(), get_domain_normal_at_element(), get_domain_normal_at_sample(), and untangle_function_2d().
{ // check if element as a mid-face node const MsqMeshEntity& elem = element_by_index( elem_index ); const int mid_node = TopologyInfo::higher_order_from_side( elem.get_element_type(), elem.node_count(), 2, 0, err );MSQ_ERRRTN( err ); // if we have the mid-element vertex, get cached normal for it if( mid_node > 0 ) { get_domain_normal_at_vertex( elem.get_vertex_index_array()[mid_node], elementHandlesArray[elem_index], surf_norm, err );MSQ_ERRRTN( err ); } // otherwise query domain for normal at element centroid else if( domain_set() ) { assert( elem_index < elementArray.size() ); elementArray[elem_index].get_centroid( surf_norm, *this, err );MSQ_ERRRTN( err ); get_domain()->element_normal_at( elementHandlesArray[elem_index], surf_norm ); } else MSQ_SETERR( err )( "No domain constraint set.", MsqError::INVALID_STATE ); }
MESQUITE_EXPORT void MBMesquite::PatchData::get_domain_normal_at_element | ( | const MsqMeshEntity * | elem_ptr, |
) | [inline] |
Definition at line 407 of file PatchData.hpp.
References elementArray, and get_domain_normal_at_element().
{ get_domain_normal_at_element( size_t( elem_ptr - &( elementArray[0] ) ), surf_norm, err ); }
void MBMesquite::PatchData::get_domain_normal_at_mid_edge | ( | size_t | element_index, |
unsigned | edge_number, | ||
Definition at line 1229 of file PatchData.cpp.
References domain_set(), element_by_index(), MBMesquite::MeshDomain::element_normal_at(), elementHandlesArray, get_domain(), get_domain_normal_at_vertex(), MBMesquite::MsqMeshEntity::get_element_type(), MBMesquite::MsqMeshEntity::get_vertex_index_array(), MBMesquite::MsqError::INVALID_STATE, MSQ_ERRRTN, MSQ_SETERR, MBMesquite::MsqMeshEntity::node_count(), and vertex_by_index().
Referenced by get_domain_normal_at_sample().
{ // check if element as a mid-edge node const MsqMeshEntity& elem = element_by_index( elem_index ); const int mid_node = TopologyInfo::higher_order_from_side( elem.get_element_type(), elem.node_count(), 1, edge_num, err );MSQ_ERRRTN( err ); // if we have the mid-edge vertex, get cached normal for it if( mid_node > 0 ) { get_domain_normal_at_vertex( elem.get_vertex_index_array()[mid_node], elementHandlesArray[elem_index], normal, err );MSQ_ERRRTN( err ); } // otherwise query domain for normal at center of edge else if( domain_set() ) { const unsigned* edge = TopologyInfo::edge_vertices( elem.get_element_type(), edge_num, err );MSQ_ERRRTN( err ); const MsqVertex& v1 = vertex_by_index( elem.get_vertex_index_array()[edge[0]] ); const MsqVertex& v2 = vertex_by_index( elem.get_vertex_index_array()[edge[1]] ); normal = 0.5 * ( v1 + v2 ); get_domain()->element_normal_at( elementHandlesArray[elem_index], normal ); } else { MSQ_SETERR( err )( "No domain constraint set.", MsqError::INVALID_STATE ); return; } }
MESQUITE_EXPORT void MBMesquite::PatchData::get_domain_normal_at_sample | ( | size_t | element_index, |
Sample | location, | ||
) | [inline] |
Definition at line 413 of file PatchData.hpp.
References MBMesquite::Sample::dimension, get_domain_normal_at_corner(), get_domain_normal_at_element(), get_domain_normal_at_mid_edge(), MBMesquite::MsqError::INVALID_ARG, MSQ_SETERR, and MBMesquite::Sample::number.
Referenced by MBMesquite::TMPQualityMetric::evaluate_surface_common(), and MBMesquite::MsqMeshEntity::inverted_jacobian_2d().
{ switch( location.dimension ) { case 0: get_domain_normal_at_corner( element_index, location.number, surf_norm, err ); break; case 1: get_domain_normal_at_mid_edge( element_index, location.number, surf_norm, err ); break; case 2: assert( location.number == 0 ); get_domain_normal_at_element( element_index, surf_norm, err ); break; default: MSQ_SETERR( err ) ( "Invalid dimension for surface element subentity.\n", MsqError::INVALID_ARG ); } }
void MBMesquite::PatchData::get_domain_normal_at_vertex | ( | size_t | vert_index, |
Mesh::ElementHandle | element, | ||
Vector3D & | normal_out, | ||
Definition at line 1296 of file PatchData.cpp.
References domain_set(), MBMesquite::MeshDomain::element_normal_at(), get_domain(), MBMesquite::MsqError::INVALID_STATE, MSQ_ERRRTN, MSQ_SETERR, normalData, update_cached_normals(), vert_index(), vertexArray, and vertexNormalIndices.
Referenced by get_domain_normal_at_corner(), get_domain_normal_at_element(), and get_domain_normal_at_mid_edge().
{ if( !domain_set() ) { MSQ_SETERR( err )( "No domain constraint set.", MsqError::INVALID_STATE ); return; } if( normalData.empty() ) { update_cached_normals( err );MSQ_ERRRTN( err ); } if( vertexNormalIndices.empty() ) { normal = normalData[vert_index]; } else if( vertexNormalIndices[vert_index] < normalData.size() ) { normal = normalData[vertexNormalIndices[vert_index]]; } else { normal = vertexArray[vert_index]; get_domain()->element_normal_at( handle, normal ); } }
void MBMesquite::PatchData::get_domain_normals_at_corners | ( | size_t | element_index, |
Vector3D | normals_out[], | ||
Get surface normals at element corners. normals_out must be of sufficient size to hold the normals of all the corners.
Definition at line 1257 of file PatchData.cpp.
References domain_set(), MBMesquite::MeshDomain::element_normal_at(), elementArray, elementHandlesArray, get_domain(), MBMesquite::MsqMeshEntity::get_vertex_index_array(), MBMesquite::MsqError::INVALID_ARG, MBMesquite::MsqError::INVALID_STATE, MSQ_ERRRTN, MSQ_SETERR, normalData, update_cached_normals(), MBMesquite::MsqMeshEntity::vertex_count(), vertexArray, and vertexNormalIndices.
Referenced by MBMesquite::MsqMeshEntity::compute_corner_normals().
{ if( !domain_set() ) { MSQ_SETERR( err )( "No domain constraint set.", MsqError::INVALID_STATE ); return; } assert( elem_index < elementArray.size() ); if( 2 != TopologyInfo::dimension( elementArray[elem_index].get_element_type() ) ) { MSQ_SETERR( err )( "Attempt to get corners of non-surface element", MsqError::INVALID_ARG ); return; } if( normalData.empty() ) { update_cached_normals( err );MSQ_ERRRTN( err ); } MsqMeshEntity& elem = elementArray[elem_index]; const unsigned count = elem.vertex_count(); const size_t* const vertex_indices = elem.get_vertex_index_array(); for( size_t i = 0; i < count; ++i ) { const size_t v = vertex_indices[i]; if( vertexNormalIndices.empty() ) { normals_out[i] = normalData[v]; } else if( vertexNormalIndices[v] < normalData.size() ) { normals_out[i] = normalData[vertexNormalIndices[v]]; } else { normals_out[i] = vertexArray[v]; get_domain()->element_normal_at( elementHandlesArray[elem_index], normals_out[i] ); } } }
const MsqMeshEntity * MBMesquite::PatchData::get_element_array | ( | MsqError & | err | ) | const [inline] |
Returns the PatchData element array.
Definition at line 815 of file PatchData.hpp.
References MBMesquite::arrptr(), elementArray, MBMesquite::MsqError::INVALID_STATE, and MSQ_SETERR.
Referenced by MBMesquite::VertexConditionNumberQualityMetric::evaluate(), MBMesquite::LocalSizeQualityMetric::evaluate(), MBMesquite::VertexConditionNumberQualityMetric::evaluate_with_indices(), MBMesquite::MsqHessian::initialize(), MsqMeshEntityTest::test_centroid(), and VtkTest::test_elements().
{ if( elementArray.empty() ) MSQ_SETERR( err )( "No element array defined", MsqError::INVALID_STATE ); return arrptr( elementArray ); }
MsqMeshEntity * MBMesquite::PatchData::get_element_array | ( | MsqError & | err | ) | [inline] |
Definition at line 820 of file PatchData.hpp.
Definition at line 269 of file PatchData.hpp.
References MBMesquite::arrptr(), and elementHandlesArray.
Referenced by PatchDataTest::check_sub_patch(), MetricLogger::evaluate(), MBMesquite::TargetReader::get_2D_target(), FakeTargetCalc::get_2D_target(), MBMesquite::TargetReader::get_3D_target(), FakeTargetCalc::get_3D_target(), MBMesquite::TargetReader::get_surface_target(), FakeTargetCalc::get_surface_target(), MBMesquite::WeightReader::get_weight(), FakeTargetCalc::get_weight(), MBMesquite::TargetWriter::loop_over_mesh(), MBMesquite::QualityAssessor::loop_over_mesh_internal(), ExtraDataTest::test_notify_subpatch(), PatchDataTest::test_patch_contents(), and PatchDataTest::test_quad8_patch().
{ return arrptr( elementHandlesArray ); }
size_t MBMesquite::PatchData::get_element_index | ( | MsqMeshEntity * | element | ) | [inline] |
Definition at line 897 of file PatchData.hpp.
References MBMesquite::arrptr(), and elementArray.
Referenced by MBMesquite::MsqMeshEntity::compute_corner_normals(), MBMesquite::MsqMeshEntity::compute_signed_area(), MBMesquite::MsqMeshEntity::inverted_jacobian_2d(), and MBMesquite::MsqMeshEntity::inverted_jacobian_3d().
{ return element - arrptr( elementArray ); }
void MBMesquite::PatchData::get_element_vertex_coordinates | ( | size_t | elem_index, |
std::vector< Vector3D > & | coords, | ||
Get coordinates of element vertices, in canonical order.
elem_index | The element index in the Patch |
coords | This vector will have the coordinates appended to it. If necessary, make sure to clear the vector before calling the function. |
Definition at line 523 of file PatchData.cpp.
References elementArray, num_elements(), and vertexArray.
Referenced by MBMesquite::AspectRatioGammaQualityMetric::evaluate().
{ // Check index if( elem_index >= num_elements() ) return; // Ask the element for its vertex indices assert( elem_index < elementArray.size() ); const size_t* vertex_indices = elementArray[elem_index].get_vertex_index_array(); // Get the coords for each indicated vertex size_t num_verts = elementArray[elem_index].vertex_count(); coords.reserve( coords.size() + num_verts ); for( size_t i = 0; i < num_verts; i++ ) coords.push_back( Vector3D( vertexArray[vertex_indices[i]] ) ); }
void MBMesquite::PatchData::get_element_vertex_indices | ( | size_t | elem_index, |
std::vector< size_t > & | vertex_indices, | ||
Get the indices of vertices of specified element. !inefficient!
This is an inefficient way of retrieving vertex_indices. Use PatchData::get_element_array followed by MsqMeshEntity::get_vertex_index_array() if you don't need to fill an STL vector.
Definition at line 544 of file PatchData.cpp.
Referenced by get_adjacent_entities_via_n_dim().
{ // Ask the element for its vertex indices assert( elem_index < elementArray.size() ); elementArray[elem_index].get_vertex_indices( vertex_indices ); }
void MBMesquite::PatchData::get_free_vertex_coordinates | ( | std::vector< Vector3D > & | coords_out | ) | const [inline] |
Definition at line 902 of file PatchData.hpp.
References num_free_vertices(), and vertexArray.
Referenced by MBMesquite::QuasiNewton::optimize_vertex_positions().
{ coords_out.resize( num_free_vertices() ); std::copy( vertexArray.begin(), vertexArray.begin() + num_free_vertices(), coords_out.begin() ); }
MESQUITE_EXPORT const MappingFunction* MBMesquite::PatchData::get_mapping_function | ( | EntityTopology | type | ) | const [inline] |
Definition at line 560 of file PatchData.hpp.
References MBMesquite::Settings::get_mapping_function(), and mSettings.
Referenced by get_sample_location(), and update_slave_node_coordinates().
{ return mSettings->get_mapping_function( type ); }
MESQUITE_EXPORT const MappingFunction2D* MBMesquite::PatchData::get_mapping_function_2D | ( | EntityTopology | type | ) | const [inline] |
Definition at line 565 of file PatchData.hpp.
References MBMesquite::Settings::get_mapping_function_2D(), and mSettings.
Referenced by MBMesquite::MsqMeshEntity::check_element_orientation(), MBMesquite::TMPQualityMetric::evaluate_surface_common(), MBMesquite::TargetCalculator::ideal_shape_2D(), MBMesquite::TargetCalculator::ideal_skew_2D(), MBMesquite::MsqMeshEntity::inverted_jacobian_2d(), MBMesquite::TargetCalculator::jacobian_2D(), and MBMesquite::MeshUtil::lambda_distribution().
{ return mSettings->get_mapping_function_2D( type ); }
MESQUITE_EXPORT const MappingFunction3D* MBMesquite::PatchData::get_mapping_function_3D | ( | EntityTopology | type | ) | const [inline] |
Definition at line 570 of file PatchData.hpp.
References MBMesquite::Settings::get_mapping_function_3D(), and mSettings.
Referenced by MBMesquite::MsqMeshEntity::check_element_orientation(), MBMesquite::TQualityMetric::evaluate_internal(), MBMesquite::AWQualityMetric::evaluate_internal(), MBMesquite::AWQualityMetric::evaluate_with_gradient(), MBMesquite::TQualityMetric::evaluate_with_gradient(), MBMesquite::AWQualityMetric::evaluate_with_Hessian(), MBMesquite::TQualityMetric::evaluate_with_Hessian(), MBMesquite::AWQualityMetric::evaluate_with_Hessian_diagonal(), MBMesquite::TQualityMetric::evaluate_with_Hessian_diagonal(), MBMesquite::TargetCalculator::ideal_shape_3D(), MBMesquite::TargetCalculator::ideal_skew_3D(), MBMesquite::MsqMeshEntity::inverted_jacobian_3d(), MBMesquite::TargetCalculator::jacobian_3D(), and MBMesquite::MeshUtil::lambda_distribution().
{ return mSettings->get_mapping_function_3D( type ); }
double MBMesquite::PatchData::get_max_vertex_movement_squared | ( | PatchDataVerticesMemento * | memento, |
Calculates the distance each vertex has moved from its original position as defined by the PatchDataVerticesMememnto.
Finds the maximum movement (in the distance norm) of the vertices in a patch. The previous vertex positions are givena as a PatchDataVerticesMemento (memento). The distance squared which each vertex has moved is then calculated, and the largest of those distances is returned. This function only considers the movement of vertices that are currently 'free'.
memento | a memento of this patch's vertex position at some (prior) time in the optimization. |
Definition at line 480 of file PatchData.cpp.
References MBMesquite::length_squared(), vertexArray, and MBMesquite::PatchDataVerticesMemento::vertices.
Referenced by MBMesquite::TerminationCriterion::accumulate_inner(), MBMesquite::TerminationCriterion::accumulate_patch(), and MBMesquite::TerminationCriterion::cull_vertices().
{ double max_dist = 0.0; for( size_t i = 0; i < memento->vertices.size(); ++i ) { double temp_dist = ( vertexArray[i] - memento->vertices[i] ).length_squared(); if( temp_dist > max_dist ) max_dist = temp_dist; } return max_dist; }
MESQUITE_EXPORT Mesh* MBMesquite::PatchData::get_mesh | ( | ) | const [inline] |
Definition at line 540 of file PatchData.hpp.
References myMesh.
Referenced by fill_global_patch(), MBMesquite::TargetReader::get_2D_target(), MBMesquite::TargetReader::get_3D_target(), MBMesquite::PatchIterator::get_next_patch(), MBMesquite::TargetReader::get_surface_target(), MBMesquite::WeightReader::get_weight(), TCTFauxOptimizer::initialize(), set_mesh_entities(), and MBMesquite::TerminationCriterion::write_timestep().
{ return myMesh; }
void MBMesquite::PatchData::get_minmax_edge_length | ( | double & | min, |
double & | max | ||
) | const |
Definition at line 112 of file PatchData.cpp.
References conn, MBMesquite::edges, element_by_index(), MBMesquite::MsqMeshEntity::get_element_type(), MBMesquite::MsqMeshEntity::get_vertex_index_array(), MBMesquite::length_squared(), num_elements(), and vertex_by_index().
Referenced by MBMesquite::NonGradient::initialize_mesh_iteration(), UnOptimizer::optimize_vertex_positions(), MBMesquite::SteepestDescent::optimize_vertex_positions(), and MBMesquite::ShapeImprover::run_wrapper().
{ min = HUGE_VAL; max = -HUGE_VAL; for( size_t i = 0; i < num_elements(); ++i ) { const MsqMeshEntity& elem = element_by_index( i ); const size_t* conn = elem.get_vertex_index_array(); const unsigned num_edges = TopologyInfo::edges( elem.get_element_type() ); for( unsigned e = 0; e < num_edges; ++e ) { const unsigned* edge = TopologyInfo::edge_vertices( elem.get_element_type(), e ); const double len_sqr = ( vertex_by_index( conn[edge[0]] ) - vertex_by_index( conn[edge[1]] ) ).length_squared(); if( len_sqr < min ) min = len_sqr; if( len_sqr > max ) max = len_sqr; } } min = sqrt( min ); max = sqrt( max ); }
void MBMesquite::PatchData::get_minmax_element_unsigned_area | ( | double & | min, |
double & | max, | ||
Returns the maximum volume or area out of all the elements in the patch This information is stored in the patch and should not decrease performance when used properly. See also PatchData::clear_computed_info() .
Definition at line 83 of file PatchData.cpp.
References computedInfos, elementArray, have_computed_info(), INTERNAL_ERROR, MAX_UNSIGNED_AREA, MIN_UNSIGNED_AREA, MBMesquite::MSQ_DBL_MAX, MSQ_ERRRTN, MSQ_SETERR, note_have_info(), and num_elements().
{ if( !have_computed_info( MAX_UNSIGNED_AREA ) || !have_computed_info( MIN_UNSIGNED_AREA ) ) { max = 0; min = MSQ_DBL_MAX; size_t count = num_elements(); for( size_t i = 0; i < count; ++i ) { double vol; assert( i < elementArray.size() ); vol = elementArray[i].compute_unsigned_area( *this, err );MSQ_ERRRTN( err ); if( vol > max ) max = vol; if( vol < min ) min = vol; } note_have_info( MAX_UNSIGNED_AREA ); note_have_info( MIN_UNSIGNED_AREA ); computedInfos[MAX_UNSIGNED_AREA] = max; computedInfos[MIN_UNSIGNED_AREA] = min; } else { max = computedInfos[MAX_UNSIGNED_AREA]; min = computedInfos[MIN_UNSIGNED_AREA]; } if( max <= 0 || min < 0 || min == MSQ_DBL_MAX ) MSQ_SETERR( err )( MsqError::INTERNAL_ERROR ); }
void MBMesquite::PatchData::get_sample_location | ( | size_t | element_index, |
Sample | sample, | ||
Vector3D & | result, | ||
) | const |
Definition at line 1872 of file PatchData.cpp.
References MBMesquite::MappingFunction::coefficients(), conn, MBMesquite::MappingFunction::convert_connectivity_indices(), element_by_index(), MBMesquite::MsqMeshEntity::get_element_type(), get_mapping_function(), MBMesquite::MsqMeshEntity::get_vertex_index_array(), MSQ_ERRRTN, MSQ_SETERR, MBMesquite::MsqMeshEntity::node_count(), non_slave_node_set(), MBMesquite::MsqError::UNSUPPORTED_ELEMENT, and vertex_by_index().
{ const MsqMeshEntity& elem = element_by_index( element_index ); const NodeSet ho_bits = non_slave_node_set( element_index ); const MappingFunction* const f = get_mapping_function( elem.get_element_type() ); if( !f ) { MSQ_SETERR( err )( "No mapping function", MsqError::UNSUPPORTED_ELEMENT ); return; } double coeff[27]; size_t num_coeff, index[27]; f->coefficients( sample, ho_bits, coeff, index, num_coeff, err );MSQ_ERRRTN( err ); f->convert_connectivity_indices( elem.node_count(), index, num_coeff, err );MSQ_ERRRTN( err ); const size_t* const conn = elem.get_vertex_index_array(); assert( num_coeff > 0 ); result = coeff[0] * vertex_by_index( conn[index[0]] ); for( unsigned i = 1; i < num_coeff; ++i ) result += coeff[i] * vertex_by_index( conn[index[i]] ); }
MESQUITE_EXPORT NodeSet MBMesquite::PatchData::get_samples | ( | size_t | element, |
NodeSet | non_slave_nodes | ||
Definition at line 585 of file PatchData.hpp.
References element_by_index(), MBMesquite::MsqMeshEntity::get_element_type(), MBMesquite::Settings::get_mapping_function(), mSettings, MBMesquite::MappingFunction::sample_points(), and MBMesquite::NodeSet::set_all_corner_nodes().
Referenced by MBMesquite::append_elem_samples(), MBMesquite::TargetReader::get_2D_target(), MBMesquite::CachingTargetCalculator::get_2D_target(), MBMesquite::TargetReader::get_3D_target(), MBMesquite::CachingTargetCalculator::get_3D_target(), get_samples(), MBMesquite::TargetReader::get_surface_target(), MBMesquite::CachingTargetCalculator::get_surface_target(), MBMesquite::WeightReader::get_weight(), MBMesquite::TargetWriter::loop_over_mesh(), MBMesquite::CachingTargetCalculator::notify_sub_patch(), MBMesquite::populate_data(), QualityAssessorTest::test_basic_stats_sample(), QualityMetricTester::test_get_sample_evaluations(), and QualityMetricTester::test_get_sample_indices().
{ // If we have a mapping function, use it const EntityTopology type = element_by_index( element ).get_element_type(); const MappingFunction* f; if( mSettings && ( f = mSettings->get_mapping_function( type ) ) ) return f->sample_points( non_slave_nodes ); // Otherwise default to sampling at all non-slave nodes non_slave_nodes.set_all_corner_nodes( type ); return non_slave_nodes; }
MESQUITE_EXPORT NodeSet MBMesquite::PatchData::get_samples | ( | size_t | element | ) | const [inline] |
Definition at line 597 of file PatchData.hpp.
References get_samples(), and non_slave_node_set().
{ return get_samples( element, non_slave_node_set( element ) ); }
void MBMesquite::PatchData::get_samples | ( | size_t | element, |
std::vector< Sample > & | samples_out, | ||
) | const |
Definition at line 1937 of file PatchData.cpp.
References MBMesquite::NodeSet::corner_node(), corners, MBMesquite::edges, element_by_index(), MBMesquite::faces, MBMesquite::MsqMeshEntity::get_element_type(), get_samples(), MBMesquite::NodeSet::mid_edge_node(), MBMesquite::NodeSet::mid_face_node(), MBMesquite::NodeSet::mid_region_node(), and MBMesquite::NodeSet::num_nodes().
{ NodeSet ns = get_samples( element ); samples.resize( ns.num_nodes() ); std::vector< Sample >::iterator i = samples.begin(); unsigned j; EntityTopology type = element_by_index( element ).get_element_type(); for( j = 0; j < TopologyInfo::corners( type ); ++j ) if( ns.corner_node( j ) ) *( i++ ) = Sample( 0, j ); for( j = 0; j < TopologyInfo::edges( type ); ++j ) if( ns.mid_edge_node( j ) ) *( i++ ) = Sample( 1, j ); if( TopologyInfo::dimension( type ) == 3 ) { for( j = 0; j < TopologyInfo::faces( type ); ++j ) if( ns.mid_face_node( j ) ) *( i++ ) = Sample( 2, j ); if( ns.mid_region_node() ) *( i++ ) = Sample( 3, 0 ); } else if( ns.mid_face_node( 0 ) ) *( i++ ) = Sample( 2, 0 ); assert( i == samples.end() ); }
MESQUITE_EXPORT const Settings* MBMesquite::PatchData::get_settings | ( | ) | const [inline] |
void MBMesquite::PatchData::get_subpatch | ( | size_t | center_vertex_index, |
unsigned | num_adj_elem_layers, | ||
PatchData & | pd_to_fill, | ||
Fills a PatchData with the elements attached to a center vertex. Note that all entities in the sub-patch are copies of the entities in 'this' patch. As such, moving a vertex in the sub-patch won't move the corresponding vertex in the source patch. Also, calling 'update_mesh()' on the sub-patch WILL modify the TSTT mesh, but the source patch won't see the changes.
Definition at line 1009 of file PatchData.cpp.
References MBMesquite::arrptr(), byteArray, elemConnectivityArray, element_by_index(), elementArray, elementHandlesArray, MBMesquite::MsqMeshEntity::get_element_type(), get_vertex_element_adjacencies(), MBMesquite::MsqMeshEntity::get_vertex_index_array(), initialize_data(), MBMesquite::MsqError::INVALID_ARG, mSettings, MSQ_CHKERR, MSQ_ERRRTN, MBMesquite::MsqVertex::MSQ_PATCH_FIXED, MSQ_SETERR, myDomain, myMesh, MBMesquite::MsqMeshEntity::node_count(), notify_new_patch(), notify_sub_patch(), num_free_vertices(), vert_index(), vertexArray, and vertexHandlesArray.
Referenced by MBMesquite::ObjectiveFunction::evaluate_with_gradient(), CachingTargetTest::test_2d_target_subpatch(), CachingTargetTest::test_3d_target_subpatch(), ExtraDataTest::test_notify_new_patch_sub(), ExtraDataTest::test_notify_subpatch(), PatchDataTest::test_sub_patch(), and CachingTargetTest::test_surface_target_subpatch().
{ // Make sure we're in range if( center_vertex_index >= num_free_vertices() ) { MSQ_SETERR( err )( "Invalid index for center vertex", MsqError::INVALID_ARG ); return; } // Notify any observers of the existing subpatch that the mesh // in the patch is to be changed. subpatch.notify_new_patch(); // Get list of vertices and elements in subpatch. // Ultimately, end up with arrays of unique, sorted indices. // It is important that the vertex indices be sorted so later // a reverse lookup can be done using a binary search (std::lower_bound). std::vector< size_t > elements, vertices, offsets; vertices.push_back( center_vertex_index ); for( unsigned i = 0; i < num_adj_elem_layers; ++i ) { elements.clear(); for( unsigned v = 0; v < vertices.size(); ++v ) { size_t num_elem; const size_t* vert_elems = get_vertex_element_adjacencies( vertices[v], num_elem, err );MSQ_ERRRTN( err ); elements.insert( elements.end(), vert_elems, vert_elems + num_elem ); } std::sort( elements.begin(), elements.end() ); elements.erase( std::unique( elements.begin(), elements.end() ), elements.end() ); vertices.clear(); for( unsigned e = 0; e < elements.size(); ++e ) { MsqMeshEntity& elem = element_by_index( elements[e] ); size_t num_vert = elem.node_count(); const size_t* elem_verts = elem.get_vertex_index_array(); vertices.insert( vertices.end(), elem_verts, elem_verts + num_vert ); } std::sort( vertices.begin(), vertices.end() ); vertices.erase( std::unique( vertices.begin(), vertices.end() ), vertices.end() ); } // Allocate space for element connectivity info. size_t num_vert_uses = 0; for( unsigned i = 0; i < elements.size(); ++i ) num_vert_uses += element_by_index( elements[i] ).node_count(); subpatch.elementArray.resize( elements.size() ); subpatch.elementHandlesArray.resize( elements.size() ); subpatch.elemConnectivityArray.resize( num_vert_uses ); offsets.resize( elements.size() + 1 ); // Construct element connectivity data in new patch, // and copy element type into new patch size_t curr_offset = 0; for( unsigned i = 0; i < elements.size(); ++i ) { MsqMeshEntity& elem = element_by_index( elements[i] ); assert( i < elementArray.size() ); subpatch.elementArray[i].set_element_type( elem.get_element_type() ); subpatch.elementHandlesArray[i] = elementHandlesArray[elements[i]]; const size_t* verts = elem.get_vertex_index_array(); offsets[i] = curr_offset; for( unsigned j = 0; j < elem.node_count(); ++j ) { subpatch.elemConnectivityArray[curr_offset++] = std::lower_bound( vertices.begin(), vertices.end(), verts[j] ) - vertices.begin(); } } offsets[elements.size()] = curr_offset; // Store index in this patch in vertex handle array of subpatch // so we can determine how vertices were reordered when setting // vertex coordinates. assert( sizeof( size_t ) == sizeof( void* ) ); subpatch.vertexHandlesArray.resize( vertices.size() ); size_t* vert_handles = reinterpret_cast< size_t* >( &subpatch.vertexHandlesArray[0] ); std::copy( vertices.begin(), vertices.end(), vert_handles ); // All vertices except vertex at center_vertex_index are fixed. subpatch.byteArray.resize( vertices.size() ); for( size_t pi = 0; pi < vertices.size(); ++pi ) { if( vertices[pi] == center_vertex_index ) subpatch.byteArray[pi] = vertexArray[vertices[pi]].get_flags() & ~MsqVertex::MSQ_PATCH_FIXED; else subpatch.byteArray[pi] = vertexArray[vertices[pi]].get_flags() | MsqVertex::MSQ_PATCH_FIXED; } // Re-order vertices and initialize other data in subpatch subpatch.initialize_data( arrptr( offsets ), &subpatch.byteArray[0], err );MSQ_ERRRTN( err ); // Copy vertex data into subpatch. subpatch.vertexHandlesArray contains // the indices into this PatchData for each vertex, as reordered by the // call to initialize_data. subpatch.vertexArray.resize( vertices.size() ); for( unsigned i = 0; i < vertices.size(); ++i ) { size_t vert_index = ( size_t )( subpatch.vertexHandlesArray[i] ); vertices[i] = vert_index; subpatch.vertexHandlesArray[i] = vertexHandlesArray[vert_index]; subpatch.vertexArray[i] = vertexArray[vert_index]; subpatch.vertexArray[i].flags() = subpatch.byteArray[i]; } subpatch.myMesh = myMesh; subpatch.myDomain = myDomain; subpatch.mSettings = mSettings; notify_sub_patch( subpatch, arrptr( vertices ), elements.empty() ? 0 : arrptr( elements ), err );MSQ_CHKERR( err ); }
const MsqVertex * MBMesquite::PatchData::get_vertex_array | ( | MsqError & | err | ) | const [inline] |
Returns a pointer to the start of the vertex array.
Returns an array of all vertices in the PatchData.
Definition at line 807 of file PatchData.hpp.
References MBMesquite::arrptr(), MBMesquite::MsqError::INVALID_STATE, MSQ_SETERR, and vertexArray.
Referenced by MBMesquite::TerminationCriterion::accumulate_patch(), MBMesquite::MsqMeshEntity::check_element_orientation_corners(), compute_corner_area(), compute_corner_volume(), MBMesquite::MsqMeshEntity::compute_signed_area(), MBMesquite::MsqMeshEntity::compute_unsigned_area(), MBMesquite::TerminationCriterion::cull_vertices_global(), MBMesquite::VertexConditionNumberQualityMetric::evaluate(), MBMesquite::ConditionNumberQualityMetric::evaluate(), MBMesquite::IdealWeightMeanRatio::evaluate(), MBMesquite::UntangleBetaQualityMetric::evaluate(), MBMesquite::IdealWeightInverseMeanRatio::evaluate(), MBMesquite::EdgeLengthQualityMetric::evaluate_common(), MBMesquite::EdgeLengthRangeQualityMetric::evaluate_common(), MBMesquite::IdealWeightMeanRatio::evaluate_with_gradient(), MBMesquite::IdealWeightInverseMeanRatio::evaluate_with_gradient(), MBMesquite::IdealWeightMeanRatio::evaluate_with_Hessian(), MBMesquite::IdealWeightInverseMeanRatio::evaluate_with_Hessian(), MBMesquite::IdealWeightMeanRatio::evaluate_with_Hessian_diagonal(), MBMesquite::IdealWeightInverseMeanRatio::evaluate_with_Hessian_diagonal(), MBMesquite::MsqMeshEntity::get_centroid(), QualityMetricTester::get_degenerate_element(), QualityMetricTester::get_inverted_element(), MBMesquite::MsqMeshEntity::get_local_matrix_map_about_vertex(), QualityMetricTester::get_nonideal_element(), QualityMetricTester::get_zero_element(), MBMesquite::NonSmoothDescent::init_max_step_length(), MBMesquite::NonGradient::initialize_mesh_iteration(), MBMesquite::move_vertex(), MBMesquite::SmartLaplacianSmoother::optimize_vertex_positions(), MBMesquite::LaplacianSmoother::optimize_vertex_positions(), MBMesquite::NonGradient::printPatch(), randomize_vertex(), MBMesquite::NonSmoothDescent::step_acceptance(), VtkTest::test_elements(), QualityMetricTester::test_gradient_reflects_quality(), QualityMetricTester::test_measures_quality(), MBMesquite::MeshWriter::Transform2D::Transform2D(), and MBMesquite::NonSmoothDescent::validity_check().
{ if( vertexArray.empty() ) MSQ_SETERR( err )( "No vertex array defined", MsqError::INVALID_STATE ); return arrptr( vertexArray ); }
MESQUITE_EXPORT const MsqVertex* MBMesquite::PatchData::get_vertex_array | ( | ) | const [inline] |
Definition at line 254 of file PatchData.hpp.
References MBMesquite::arrptr(), and vertexArray.
{ return arrptr( vertexArray ); }
const size_t * MBMesquite::PatchData::get_vertex_element_adjacencies | ( | size_t | vertex_index, |
size_t & | array_len_out, | ||
Get indices of elements attached to specified vertex
Definition at line 577 of file PatchData.cpp.
References generate_vertex_to_element_data(), vertAdjacencyArray, and vertAdjacencyOffsets.
Referenced by MBMesquite::VertexConditionNumberQualityMetric::evaluate(), MBMesquite::LocalSizeQualityMetric::evaluate(), MBMesquite::VertexConditionNumberQualityMetric::evaluate_with_indices(), MBMesquite::EdgeIterator::get_adjacent_vertices(), MBMesquite::EdgeQM::get_edge_evaluations(), get_subpatch(), MBMesquite::VertexQM::get_vertex_corner_handles(), get_vertex_element_indices(), move_vertex(), project_gradient(), and set_vertex_coordinates().
{ // Make sure we've got the data if( vertAdjacencyArray.empty() ) { generate_vertex_to_element_data(); } const size_t begin = vertAdjacencyOffsets[vertex_index]; const size_t end = vertAdjacencyOffsets[vertex_index + 1]; array_len_out = end - begin; return &vertAdjacencyArray[begin]; }
void MBMesquite::PatchData::get_vertex_element_indices | ( | size_t | vertex_index, |
std::vector< size_t > & | elem_indices, | ||
Get the indices of the elements attached to the specified vertex.
Definition at line 552 of file PatchData.cpp.
References get_vertex_element_adjacencies().
{ size_t count; const size_t* ptr; ptr = get_vertex_element_adjacencies( vertex_index, count, err ); elem_indices.resize( count ); std::copy( ptr, ptr + count, elem_indices.begin() ); }
unsigned | element_dimension, | ||
Get the indices of elements adjacent to the specified vertex, and having the specified dimension
Definition at line 561 of file PatchData.cpp.
References dim, elementArray, and get_vertex_element_adjacencies().
{ elem_indices.clear(); size_t count; const size_t* ptr; ptr = get_vertex_element_adjacencies( vertex_index, count, err ); for( const size_t* const end = ptr + count; ptr != end; ++ptr ) { assert( *ptr < elementArray.size() ); const EntityTopology type = elementArray[*ptr].get_element_type(); const unsigned dim = TopologyInfo::dimension( type ); if( dim == element_dimension ) elem_indices.push_back( *ptr ); } }
Definition at line 274 of file PatchData.hpp.
References MBMesquite::arrptr(), and vertexHandlesArray.
Referenced by MBMesquite::RefSizeTargetCalculator::average_edge_length(), check_global_patch_slaved(), PatchDataTest::check_higher_order_vertices_slaved(), PatchDataTest::check_sub_patch(), MBMesquite::TerminationCriterion::cull_vertices_global(), MetricLogger::evaluate(), MBMesquite::TargetCalculator::get_refmesh_Jacobian_2D(), MBMesquite::TargetCalculator::get_refmesh_Jacobian_3D(), TCTFauxOptimizer::optimize_vertex_positions(), tag_patch_slaved(), PatchDataTest::test_fixed_by_geom_dim(), ExtraDataTest::test_notify_subpatch(), PatchDataTest::test_patch_contents(), PatchDataTest::test_quad8_patch(), and update_slave_node_coordinates().
{ return arrptr( vertexHandlesArray ); }
size_t MBMesquite::PatchData::get_vertex_index | ( | MsqVertex * | vertex | ) | [inline] |
gets the index of a vertex in the PatchData vertex array, given a pointer to the vertex.
Definition at line 892 of file PatchData.hpp.
{ return vertex - arrptr( vertexArray ); }
MESQUITE_EXPORT bool MBMesquite::PatchData::have_computed_info | ( | ComputedInfo | info | ) | const [inline] |
Definition at line 182 of file PatchData.hpp.
References haveComputedInfos.
Referenced by get_minmax_element_unsigned_area(), and MBMesquite::operator<<().
{ return 0 != ( haveComputedInfos & ( 1 << info ) ); }
void MBMesquite::PatchData::initialize_data | ( | size_t * | elem_offset_array, |
) | [private] |
Call after filling vertex handle and connectivity arrays to finish initializing the PatchData. Reorders vertex handles array such that all higher-order nodes are at end of array, updates element connectivity array appropriately, initalizes numCornerVertices, and per-element vertex and node counts.
NOTE: If the patch contains higher-order elements, this function will re-order the nodes in the vertex array. Do *NOT* assume vertex indices are the same after calling this function!
NOTE: This function expects the following data to be initalized: vertexHandlesArray elemConnectivityArray the topology type for all elements in elementArray The function assumes the following data has not been initialized and therefore does not need to be updated: vertexArray
elem_offset_array | Offset into connectivity array for each element |
Definition at line 1536 of file PatchData.cpp.
References MBMesquite::arrptr(), elemConnectivityArray, elementArray, MBMesquite::MsqVertex::MSQ_DEPENDENT, MBMesquite::MsqVertex::MSQ_FIXED, normalData, notify_new_patch(), numFreeVertices, numSlaveVertices, swap(), vertAdjacencyArray, vertAdjacencyOffsets, vertexHandlesArray, and vertexNormalIndices.
Referenced by fill(), get_subpatch(), and set_mesh_entities().
{ // Clear out data specific to patch vertexNormalIndices.clear(); normalData.clear(); // vertexDomainDOF.clear(); // Clear any vertex->element adjacency data. It // is probably invalid, and certainly will be by the time // this function completes if the mesh contains higher-order // elements. vertAdjacencyArray.clear(); vertAdjacencyOffsets.clear(); size_t i, j; for( i = 0; i < elementArray.size(); ++i ) { size_t start = elem_offset_array[i]; size_t conn_len = elem_offset_array[i + 1] - start; assert( conn_len > 0 ); elementArray[i].set_connectivity( &elemConnectivityArray[start], conn_len ); } // Use vertAdjacencyOffsets array as temporary storage. vertAdjacencyOffsets.resize( vertexHandlesArray.size() + 1 ); size_t* vertex_index_map = arrptr( vertAdjacencyOffsets ); // Count number of free vertices and initialize vertex_index_map numFreeVertices = 0; for( i = 0; i < vertexHandlesArray.size(); ++i ) { if( !( vertex_flags[i] & MsqVertex::MSQ_FIXED ) ) ++numFreeVertices; vertex_index_map[i] = i; } // Re-order vertices such that all free vertices are // first in the list. Construct map from old to new // position in list for updating element connectivity. i = 0; j = numFreeVertices; for( ;; ++i, ++j ) { // find next fixed vertex in the range [i,numFreeVertices) for( ; i < numFreeVertices && !( vertex_flags[i] & MsqVertex::MSQ_FIXED ); ++i ) ; // if no more fixed vertices in the free vertex range [0,numFreeVertices) if( i == numFreeVertices ) break; // find the next free vertex in the range [j,num_nodes) for( ; vertex_flags[j] & MsqVertex::MSQ_FIXED; ++j ) ; // swap fixed (i) and free (j) vertices vertex_index_map[i] = j; vertex_index_map[j] = i; std::swap( vertexHandlesArray[i], vertexHandlesArray[j] ); std::swap( vertex_flags[i], vertex_flags[j] ); } assert( i == numFreeVertices ); assert( j <= vertexHandlesArray.size() ); // Update element connectivity data for new vertex indices for( i = 0; i < elemConnectivityArray.size(); ++i ) elemConnectivityArray[i] = vertex_index_map[elemConnectivityArray[i]]; // Reorder vertices such that free, slave vertices // occur after free, non-slave vertices in list. numSlaveVertices = 0; for( i = 0; i < vertexHandlesArray.size(); ++i ) { if( ( vertex_flags[i] & MsqVertex::MSQ_DEPENDENT ) && !( vertex_flags[i] & MsqVertex::MSQ_FIXED ) ) ++numSlaveVertices; } numFreeVertices -= numSlaveVertices; if( numSlaveVertices ) { // re-initialize vertex index map for( i = 0; i < vertexHandlesArray.size(); ++i ) vertex_index_map[i] = i; // Re-order free vertices such that all slave vertices are // last in the list. Construct map from old to new // position in list for updating element connectivity. i = 0; j = numFreeVertices; for( ;; ++i, ++j ) { // find next slave vertex in the range [i,numFreeVertices) for( ; i < numFreeVertices && !( vertex_flags[i] & MsqVertex::MSQ_DEPENDENT ); ++i ) ; // if no more slave vertices in [0,numFreeVertices), then done. if( i == numFreeVertices ) break; // find the next free (non-slave) vertex in the range // [numFreeVertices,numFreeVertices+numSlaveVertices) for( ; vertex_flags[j] & MsqVertex::MSQ_DEPENDENT; ++j ) ; // swap free (j) and slave (i) vertices vertex_index_map[i] = j; vertex_index_map[j] = i; std::swap( vertexHandlesArray[i], vertexHandlesArray[j] ); std::swap( vertex_flags[i], vertex_flags[j] ); } assert( i == numFreeVertices ); assert( j <= numFreeVertices + numSlaveVertices ); // Update element connectivity data for new vertex indices for( i = 0; i < elemConnectivityArray.size(); ++i ) elemConnectivityArray[i] = vertex_index_map[elemConnectivityArray[i]]; } // Clear temporary data vertAdjacencyOffsets.clear(); notify_new_patch(); }
MESQUITE_EXPORT bool MBMesquite::PatchData::is_vertex_fixed | ( | size_t | index | ) | const [inline] |
Definition at line 243 of file PatchData.hpp.
References numFreeVertices, and numSlaveVertices.
{ return index >= numFreeVertices + numSlaveVertices; }
MESQUITE_EXPORT bool MBMesquite::PatchData::is_vertex_free | ( | size_t | index | ) | const [inline] |
Definition at line 231 of file PatchData.hpp.
References numFreeVertices.
Referenced by TriTauMetric::evaluate_with_indices().
{ return index < numFreeVertices; }
MESQUITE_EXPORT bool MBMesquite::PatchData::is_vertex_not_free | ( | size_t | index | ) | const [inline] |
Definition at line 235 of file PatchData.hpp.
{ return index >= numFreeVertices; }
MESQUITE_EXPORT bool MBMesquite::PatchData::is_vertex_slave | ( | size_t | index | ) | const [inline] |
Definition at line 239 of file PatchData.hpp.
Referenced by update_slave_node_coordinates().
{ return index >= numFreeVertices && ( index - numFreeVertices ) < numSlaveVertices; }
void MBMesquite::PatchData::make_handles_unique | ( | Mesh::EntityHandle * | handles, |
size_t & | count, | ||
size_t * | index_map = 0 |
) | [static, private] |
Code common to misc. methods for populating patch data. Remove duplicates from an array of handles.
handles | The array of handles to uniquify. |
count | As input, the lenght of the #handles array. As output, the number of unique handles remaining in the array. |
index_map | If non-null, this must be an array of the same length as the handles array. If this array is passed, the entry cooresponding to each handle in the input #handles array will be set to the index of that handle in the output array. |
Definition at line 1751 of file PatchData.cpp.
Referenced by set_mesh_entities().
{ if( count < 2 ) { return; } // save this now, as we'll be changing count later const size_t* index_end = index_map + count; if( index_map ) { // Copy input handle list into index map as a temporary // copy of the input list. assert( sizeof( Mesh::EntityHandle ) == sizeof( size_t ) ); memcpy( index_map, handles, count * sizeof( size_t ) ); } // Make handles a unique list std::sort( handles, handles + count ); Mesh::EntityHandle* end = std::unique( handles, handles + count ); count = end - handles; if( index_map ) { // Replace each handle in index_map with the index of // its position in the handles array Mesh::EntityHandle* pos; for( size_t* iter = index_map; iter != index_end; ++iter ) { pos = std::lower_bound( handles, handles + count, (Mesh::EntityHandle)*iter ); *iter = pos - handles; } } }
void MBMesquite::PatchData::move_free_vertices_constrained | ( | Vector3D | dk[], |
size_t | nb_vtx, | ||
double | step_size, | ||
MsqError & | err | ||
Moves free vertices and then snaps the free vertices to the domain.
PatchData::move_free_vertices_constrained() moves the free vertices (see MsqVertex::is_free() ) as specified by the search direction (dk) and scale factor (step_size). After being moved, the vertices are projected onto the appropriate geometry. Fixed vertices are not moved regardless of their corresponding dk direction. It is often useful to use the create_coords_momento() function before calling this function. Compile with -DMSQ_DBG3 to check that fixed vertices are not moved with that call.
dk,: | must be a [nb_vtx] array of Vector3D that contains the direction in which to move each vertex. Fixed vertices moving direction should be zero, although fixed vertices will not be moved regardless of their corresponding dk value. |
nb_vtx | is the number of vertices to move. must corresponds to the number of vertices in the PatchData. |
step_size | will multiply the moving direction given in dk for each vertex. |
Definition at line 348 of file PatchData.cpp.
References MBMesquite::MsqError::INVALID_ARG, MSQ_CHKERR, MSQ_ERRRTN, MSQ_SETERR, num_free_vertices(), numSlaveVertices, snap_vertex_to_domain(), update_slave_node_coordinates(), and vertexArray.
Referenced by MBMesquite::QuasiNewton::optimize_vertex_positions(), MBMesquite::TrustRegion::optimize_vertex_positions(), MBMesquite::ConjugateGradient::optimize_vertex_positions(), MBMesquite::SteepestDescent::optimize_vertex_positions(), and MBMesquite::FeasibleNewton::optimize_vertex_positions().
{ if( nb_vtx != num_free_vertices() ) { MSQ_SETERR( err ) ( "The directional vector must be of length numVertices.", MsqError::INVALID_ARG ); return; } size_t i; for( i = 0; i < num_free_vertices(); ++i ) { vertexArray[i] += ( step_size * dk[i] ); snap_vertex_to_domain( i, err );MSQ_ERRRTN( err ); } if( numSlaveVertices ) { update_slave_node_coordinates( err );MSQ_CHKERR( err ); } }
void MBMesquite::PatchData::move_vertex | ( | const Vector3D & | delta, |
size_t | index, | ||
) | [inline] |
increment the coordinates of the index-th vertex in the raw array
Add delta to the index-th free vertex in the patch
Definition at line 848 of file PatchData.hpp.
References get_vertex_element_adjacencies(), MBMesquite::MsqError::INVALID_ARG, MSQ_ERRRTN, MSQ_SETERR, numSlaveVertices, update_slave_node_coordinates(), and vertexArray.
Referenced by ObjectiveFunctionTests::compare_numerical_hessian(), MBMesquite::NonSmoothDescent::compute_gradient(), MBMesquite::create_six_quads_patch_inverted_with_domain(), MBMesquite::ObjectiveFunction::get_eps(), MBMesquite::move_vertex(), TCTFauxOptimizer::optimize_vertex_positions(), randomize_vertex(), MBMesquite::NonSmoothDescent::step_acceptance(), TerminationCriterionTest::test_absolute_vertex_movement_edge_length(), QualityMetricTester::test_domain_deviation_gradient(), QualityMetricTester::test_measures_vertex_quality(), TerminationCriterionTest::test_untangled_mesh(), QualityMetricTester::test_vertex_gradient_reflects_quality(), TerminationCriterionTest::test_vertex_movement_common(), and PatchTranslate::xform().
{ if( index >= vertexArray.size() ) { MSQ_SETERR( err )( "Index bigger than numVertices.", MsqError::INVALID_ARG ); return; } vertexArray[index] += delta; if( numSlaveVertices ) { size_t num_elem; const size_t* indices; indices = get_vertex_element_adjacencies( index, num_elem, err );MSQ_ERRRTN( err ); update_slave_node_coordinates( indices, num_elem, err );MSQ_ERRRTN( err ); } }
NodeSet MBMesquite::PatchData::non_slave_node_set | ( | size_t | elem_idx | ) | const |
This function returns a NodeSet indicating which nodes in the specified element are not slaved.
Definition at line 1895 of file PatchData.cpp.
References conn, corners, MBMesquite::edges, element_by_index(), MBMesquite::faces, MBMesquite::MsqMeshEntity::get_element_type(), MBMesquite::MsqMeshEntity::get_vertex_index_array(), MBMesquite::MsqVertex::MSQ_DEPENDENT, n, MBMesquite::MsqMeshEntity::node_count(), MBMesquite::NodeSet::set_all_corner_nodes(), MBMesquite::NodeSet::set_mid_edge_node(), MBMesquite::NodeSet::set_mid_face_node(), MBMesquite::NodeSet::set_mid_region_node(), and vertex_by_index().
Referenced by MBMesquite::AWQualityMetric::evaluate_internal(), MBMesquite::TQualityMetric::evaluate_internal(), MBMesquite::AWQualityMetric::evaluate_with_gradient(), MBMesquite::TQualityMetric::evaluate_with_gradient(), MBMesquite::TQualityMetric::evaluate_with_Hessian(), MBMesquite::AWQualityMetric::evaluate_with_Hessian(), MBMesquite::AWQualityMetric::evaluate_with_Hessian_diagonal(), MBMesquite::TQualityMetric::evaluate_with_Hessian_diagonal(), get_sample_location(), get_samples(), MBMesquite::MeshUtil::lambda_distribution(), and update_slave_node_coordinates().
{ const MsqMeshEntity& elem = element_by_index( element_index ); EntityTopology type = elem.get_element_type(); const size_t* conn = elem.get_vertex_index_array(); const size_t n = elem.node_count(); MsqError err; bool have_midedge, have_midface, have_midelem; unsigned num_edge = 0, num_face = 0, num_corner = TopologyInfo::corners( type ); TopologyInfo::higher_order( type, n, have_midedge, have_midface, have_midelem, err ); num_edge = TopologyInfo::edges( type ); if( TopologyInfo::dimension( type ) == 2 ) num_face = 1; else num_face = TopologyInfo::faces( type ); NodeSet result; result.set_all_corner_nodes( type ); if( have_midedge ) { for( unsigned i = 0; i < num_edge; ++i ) { if( !( vertex_by_index( conn[num_corner + i] ).get_flags() & MsqVertex::MSQ_DEPENDENT ) ) result.set_mid_edge_node( i ); } } if( have_midface ) { for( unsigned i = 0; i < num_face; ++i ) { if( !( vertex_by_index( conn[num_corner + num_edge + i] ).get_flags() & MsqVertex::MSQ_DEPENDENT ) ) result.set_mid_face_node( i ); } } if( have_midelem && !( vertex_by_index( conn[num_corner + num_edge + num_face] ).get_flags() & MsqVertex::MSQ_DEPENDENT ) ) result.set_mid_region_node(); return result; }
void MBMesquite::PatchData::note_have_info | ( | ComputedInfo | info | ) | [inline, private] |
Definition at line 676 of file PatchData.hpp.
Referenced by get_minmax_element_unsigned_area().
{ haveComputedInfos |= ( 1 << info ); }
void MBMesquite::PatchData::notify_new_patch | ( | ) | [private] |
notify all attached ExtraData instances that patch contents have changed
Definition at line 1999 of file PatchData.cpp.
References dataList, and MBMesquite::ExtraData::patchNext.
Referenced by get_subpatch(), initialize_data(), and reorder().
void MBMesquite::PatchData::notify_patch_destroyed | ( | ) | [private] |
notify all attached ExtraData instances that this patch is being destroyed
Definition at line 2014 of file PatchData.cpp.
References dataList, MBMesquite::ExtraData::notify_patch_destroyed(), MBMesquite::ExtraData::patchNext, and MBMesquite::ExtraData::patchPtr.
Referenced by set_domain(), set_mesh(), and ~PatchData().
void MBMesquite::PatchData::notify_sub_patch | ( | PatchData & | sub_patch, |
const size_t * | vertex_index_map, | ||
const size_t * | element_index_map, | ||
) | [private] |
notify all attached ExtraData instances that a subpatch is being initalized
sub_patch | The new, already populated subpatch |
vertex_index_map | For the i-th vertex in the subpatch, the i-th entry in this list is the corresponding index in this patch. |
element_index_map | For the i-th element in the subpatch, the i-th entry in this list is the corresponding index in this patch. |
Definition at line 2005 of file PatchData.cpp.
References dataList, MSQ_ERRRTN, and MBMesquite::ExtraData::patchNext.
Referenced by get_subpatch().
{ for( ExtraData* iter = dataList; iter; iter = iter->patchNext ) { iter->notify_sub_patch( sub_patch, vertex_map, element_map, err );MSQ_ERRRTN( err ); } }
size_t MBMesquite::PatchData::num_corners | ( | ) | const |
number of element corners (number of vertex uses) in patch
Definition at line 1650 of file PatchData.cpp.
References elementArray.
Referenced by MBMesquite::NonGradient::printPatch().
{ size_t result = 0; for( unsigned i = 0; i < elementArray.size(); ++i ) result += elementArray[i].vertex_count(); return result; }
MESQUITE_EXPORT size_t MBMesquite::PatchData::num_elements | ( | ) | const [inline] |
number of elements in the Patch.
Definition at line 226 of file PatchData.hpp.
Referenced by PatchDataTest::check_sub_patch(), MBMesquite::TerminationCriterion::count_inverted(), MetricLogger::evaluate(), MBMesquite::ElementQM::get_element_evaluations(), get_element_vertex_coordinates(), FauxMetric< B >::get_evaluations(), get_minmax_edge_length(), get_minmax_element_unsigned_area(), MBMesquite::NonGradient::getPatchDimension(), MBMesquite::NonSmoothDescent::init_max_step_length(), MBMesquite::MsqHessian::initialize(), MBMesquite::TargetWriter::loop_over_mesh(), MBMesquite::QualityAssessor::loop_over_mesh_internal(), MBMesquite::CachingTargetCalculator::notify_sub_patch(), TestExtraData::notify_sub_patch(), MBMesquite::SmartLaplacianSmoother::num_inverted(), MBMesquite::operator<<(), MBMesquite::NonSmoothDescent::optimize_vertex_positions(), MBMesquite::populate_data(), MBMesquite::NonGradient::printPatch(), reorder(), QualityAssessorTest::test_basic_stats_sample(), MsqMeshEntityTest::test_check_element_orientation(), VtkTest::test_elements(), QualityMetricTester::test_get_element_evaluations(), QualityMetricTester::test_get_in_element_evaluations(), QualityMetricTester::test_get_sample_evaluations(), ExtraDataTest::test_notify_subpatch(), PatchDataTest::test_patch_contents(), PatchDataTest::test_quad8_patch(), update_slave_node_coordinates(), MBMesquite::NonSmoothDescent::validity_check(), and MBMesquite::MeshWriter::write_vtk().
{ return elementArray.size(); }
MESQUITE_EXPORT size_t MBMesquite::PatchData::num_fixed_vertices | ( | ) | const [inline] |
Definition at line 221 of file PatchData.hpp.
References num_free_vertices(), num_nodes(), and num_slave_vertices().
Referenced by PatchDataTest::test_fixed_by_geom_dim(), and PatchDataTest::test_quad8_patch().
{ return num_nodes() - num_free_vertices() - num_slave_vertices(); }
MESQUITE_EXPORT size_t MBMesquite::PatchData::num_free_vertices | ( | ) | const [inline] |
Definition at line 213 of file PatchData.hpp.
Referenced by MBMesquite::TerminationCriterion::accumulate_inner(), MBMesquite::TerminationCriterion::accumulate_patch(), check_global_patch_slaved(), ObjectiveFunctionTests::compare_diagonal_gradient(), ObjectiveFunctionTests::compare_hessian_diagonal(), ObjectiveFunctionTests::compare_hessian_gradient(), ObjectiveFunctionTests::compare_numerical_gradient(), ObjectiveFunctionTests::compare_numerical_hessian(), MBMesquite::ObjectiveFunction::compute_patch_numerical_gradient(), MBMesquite::ObjectiveFunction::compute_subpatch_numerical_gradient(), NumericalTestOF::evaluate(), MBMesquite::NonGradient::evaluate(), MBMesquite::EdgeLengthMetric::evaluate_with_gradient(), MBMesquite::PatchPowerMeanP::evaluate_with_gradient(), MBMesquite::CompositeOFMultiply::evaluate_with_gradient(), MBMesquite::VarianceTemplate::evaluate_with_gradient(), DummyOF::evaluate_with_gradient(), MBMesquite::CompositeOFAdd::evaluate_with_gradient(), MBMesquite::LPtoPTemplate::evaluate_with_gradient(), MBMesquite::PMeanPTemplate::evaluate_with_gradient(), MBMesquite::ObjectiveFunction::evaluate_with_gradient(), MBMesquite::PatchPowerMeanP::evaluate_with_Hessian(), MBMesquite::CompositeOFAdd::evaluate_with_Hessian(), MBMesquite::LPtoPTemplate::evaluate_with_Hessian(), MBMesquite::PMeanPTemplate::evaluate_with_Hessian(), MBMesquite::CompositeOFScalarMultiply::evaluate_with_Hessian_diagonal(), MBMesquite::CompositeOFMultiply::evaluate_with_Hessian_diagonal(), MBMesquite::VarianceTemplate::evaluate_with_Hessian_diagonal(), MBMesquite::CompositeOFAdd::evaluate_with_Hessian_diagonal(), MBMesquite::LPtoPTemplate::evaluate_with_Hessian_diagonal(), MBMesquite::PMeanPTemplate::evaluate_with_Hessian_diagonal(), MBMesquite::ElementQM::evaluate_with_indices(), MBMesquite::VertexConditionNumberQualityMetric::evaluate_with_indices(), MBMesquite::EdgeLengthQualityMetric::evaluate_with_indices(), MBMesquite::LocalSizeQualityMetric::evaluate_with_indices(), MBMesquite::EdgeLengthRangeQualityMetric::evaluate_with_indices(), MBMesquite::AffineMapMetric::evaluate_with_indices(), MBMesquite::EdgeQM::evaluate_with_indices(), ConstantElementMetric::evaluate_with_indices(), OFTestQM::evaluate_with_indices(), DistTestMetric::evaluate_with_indices(), MBMesquite::QualityMetric::fixed_vertex_bitmap(), MBMesquite::EdgeQM::get_edge_evaluations(), MBMesquite::ElementQM::get_element_evaluations(), get_free_vertex_coordinates(), MBMesquite::ConjugateGradient::get_step(), get_subpatch(), MBMesquite::VertexQM::get_vertex_evaluations(), MBMesquite::MsqHessian::initialize(), MBMesquite::NonGradient::initialize_mesh_iteration(), MBMesquite::MappingFunction2D::jacobian(), MBMesquite::MappingFunction3D::jacobian(), MBMesquite::QualityAssessor::loop_over_mesh_internal(), move_free_vertices_constrained(), MBMesquite::MsqFreeVertexIndexIterator::next(), num_fixed_vertices(), MBMesquite::SmartLaplacianSmoother::optimize_vertex_positions(), UnOptimizer::optimize_vertex_positions(), MBMesquite::QuasiNewton::optimize_vertex_positions(), MBMesquite::TrustRegion::optimize_vertex_positions(), MBMesquite::LaplacianSmoother::optimize_vertex_positions(), MBMesquite::ConjugateGradient::optimize_vertex_positions(), MBMesquite::SteepestDescent::optimize_vertex_positions(), MBMesquite::FeasibleNewton::optimize_vertex_positions(), MBMesquite::NonSmoothDescent::optimize_vertex_positions(), MBMesquite::NonGradient::optimize_vertex_positions(), MBMesquite::NonGradient::printPatch(), project_gradient(), recreate_vertices_memento(), MBMesquite::TerminationCriterion::reset_inner(), set_all_vertices_soft_fixed(), set_free_vertices_constrained(), set_free_vertices_soft_fixed(), set_to_vertices_memento(), tag_patch_slaved(), TerminationCriterionTest::test_absolute_vertex_movement_edge_length(), ObjectiveFunctionTest::test_compute_ana_hessian_tet(), ObjectiveFunctionTest::test_compute_ana_hessian_tet_scaled(), VtkTest::test_elements(), PatchDataTest::test_fixed_by_geom_dim(), QualityMetricTest::test_fixed_vertex_list(), QualityMetricTester::test_get_edge_indices(), QualityMetricTester::test_get_element_indices(), QualityMetricTester::test_get_indices_fixed(), QualityMetricTester::test_get_sample_indices(), QualityMetricTester::test_get_vertex_indices(), TerminationCriterionTest::test_gradient_common(), CompositeOFTest::test_multiply_hess_diagonal(), PatchDataTest::test_patch_contents(), PatchDataTest::test_quad8_patch(), PatchDataTest::test_sub_patch(), TerminationCriterionTest::test_vertex_bound(), TerminationCriterionTest::test_vertex_movement_common(), update_slave_node_coordinates(), and MBMesquite::MeshWriter::write_vtk().
{ return numFreeVertices; }
MESQUITE_EXPORT size_t MBMesquite::PatchData::num_nodes | ( | ) | const [inline] |
number of vertices in the patch.
Definition at line 209 of file PatchData.hpp.
References vertexArray.
Referenced by check_global_patch_slaved(), PatchDataTest::check_higher_order_vertices_slaved(), PatchDataTest::check_sub_patch(), MBMesquite::TerminationCriterion::cull_vertices_global(), MBMesquite::EdgeIterator::EdgeIterator(), NumericalTestOF::evaluate(), generate_vertex_to_element_data(), get_adjacent_vertex_indices(), MBMesquite::EdgeQM::get_edge_evaluations(), TMPQualityMetricTest< AWQualityMetric >::get_nonideal_element(), MBMesquite::VertexQM::get_vertex_evaluations(), MBMesquite::NonSmoothDescent::init_max_step_length(), MBMesquite::EdgeIterator::is_at_end(), MBMesquite::EdgeIterator::mid(), MBMesquite::move_vertex(), TestExtraData::notify_sub_patch(), num_fixed_vertices(), MBMesquite::operator<<(), MBMesquite::NonSmoothDescent::optimize_vertex_positions(), TCTFauxOptimizer::optimize_vertex_positions(), MBMesquite::NonGradient::printPatch(), randomize_vertex(), reorder(), set_all_vertices_soft_free(), set_free_vertices_constrained(), MBMesquite::EdgeIterator::step(), MsqMeshEntityTest::test_check_element_orientation(), QualityMetricTester::test_domain_deviation_quality(), VtkTest::test_elements(), TMPQualityMetricTest< QMType >::test_evaluate_2D(), TMPQualityMetricTest< QMType >::test_evaluate_3D(), TMPQualityMetricTest< QMType >::test_evaluate_surface(), ExtraDataTest::test_notify_subpatch(), PatchDataTest::test_patch_contents(), PatchDataTest::test_quad8_patch(), TerminationCriterionTest::test_vertex_bound(), MBMesquite::MeshWriter::Transform2D::Transform2D(), update_cached_normals(), MBMesquite::MeshWriter::write_vtk(), PatchTranslate::xform(), PatchScale::xform(), and PatchRotate::xform().
{ return vertexArray.size(); }
MESQUITE_EXPORT size_t MBMesquite::PatchData::num_slave_vertices | ( | ) | const [inline] |
Definition at line 217 of file PatchData.hpp.
References numSlaveVertices.
Referenced by check_global_patch_slaved(), num_fixed_vertices(), MBMesquite::NonGradient::printPatch(), recreate_vertices_memento(), set_to_vertices_memento(), tag_patch_slaved(), PatchDataTest::test_fixed_by_geom_dim(), PatchDataTest::test_quad8_patch(), and update_slave_node_coordinates().
{ return numSlaveVertices; }
Doesn't allow a PatchData object to be assigned to another. Mementos such as PatchDataVerticesMemento should be used when necessary.
void MBMesquite::PatchData::project_gradient | ( | std::vector< Vector3D > & | gradient, |
Project gradient vector terms onto geometric domain.
Definition at line 426 of file PatchData.cpp.
References domain_set(), element_by_index(), MBMesquite::MeshDomain::element_normal_at(), elementHandlesArray, get_domain(), get_vertex_element_adjacencies(), MBMesquite::MsqError::INVALID_ARG, MSQ_ERRRTN, MSQ_SETERR, normalData, num_free_vertices(), MBMesquite::project_to_plane(), update_cached_normals(), vertexArray, vertexDomainDOF, and vertexNormalIndices.
Referenced by MBMesquite::SteepestDescent::optimize_vertex_positions().
{ if( !domain_set() ) return; if( gradient.size() != num_free_vertices() ) { MSQ_SETERR( err )( MsqError::INVALID_ARG ); return; } if( normalData.empty() ) { update_cached_normals( err );MSQ_ERRRTN( err ); } Vector3D norm; for( size_t i = 0; i < num_free_vertices(); ++i ) { if( vertexNormalIndices.empty() ) { // whole mesh on single 2D domain norm = normalData[i]; project_to_plane( gradient[i], norm ); } else if( vertexDomainDOF[i] == 2 ) { // vertex on surface norm = normalData[vertexNormalIndices[i]]; project_to_plane( gradient[i], norm ); } else if( vertexDomainDOF[i] == 1 ) { size_t j, num_elem; const size_t* elems = get_vertex_element_adjacencies( i, num_elem, err );MSQ_ERRRTN( err ); for( j = 0; j < num_elem; ++j ) { if( 2 == TopologyInfo::dimension( element_by_index( elems[j] ).get_element_type() ) ) { norm = vertexArray[i]; get_domain()->element_normal_at( elementHandlesArray[elems[j]], norm ); project_to_plane( gradient[i], norm ); } } } } }
void MBMesquite::PatchData::recreate_vertices_memento | ( | PatchDataVerticesMemento * | memento, |
) | [inline] |
reinstantiates a memento to holds the current state of the PatchData coordinates. Improves memory management.
This function reuses an existing PatchDataVerticesMemento object. The PatchDataVerticesMemento contains the current state of the PatchData coordinates. It can be used to restore the same PatchData object to those coordinates.
It is the responsibility of the caller to delete the PatchDataVerticesMemento when it is no longer needed.
Definition at line 936 of file PatchData.hpp.
References normalData, MBMesquite::PatchDataVerticesMemento::normalData, num_free_vertices(), num_slave_vertices(), MBMesquite::PatchDataVerticesMemento::originator, vertexArray, vertexNormalIndices, and MBMesquite::PatchDataVerticesMemento::vertices.
Referenced by MBMesquite::TerminationCriterion::accumulate_patch(), create_vertices_memento(), MBMesquite::ConjugateGradient::get_step(), MBMesquite::TrustRegion::optimize_vertex_positions(), MBMesquite::QuasiNewton::optimize_vertex_positions(), MBMesquite::SteepestDescent::optimize_vertex_positions(), MBMesquite::FeasibleNewton::optimize_vertex_positions(), MBMesquite::TerminationCriterion::reset_inner(), and MBMesquite::TerminationCriterion::reset_patch().
{ memento->originator = this; size_t num_vtx = num_free_vertices() + num_slave_vertices(); memento->vertices.resize( num_vtx ); std::copy( vertexArray.begin(), vertexArray.begin() + num_vtx, memento->vertices.begin() ); int num_normal; if( normalData.empty() ) num_normal = 0; else if( vertexNormalIndices.empty() ) num_normal = num_vtx; else { num_normal = num_vtx; while( num_normal != 0 && vertexNormalIndices[--num_normal] >= normalData.size() ) ; if( num_normal == 0 ) { if( vertexNormalIndices[0] < normalData.size() ) num_normal = vertexNormalIndices[0] + 1; } else num_normal = vertexNormalIndices[num_normal] + 1; } memento->normalData.resize( num_normal ); std::copy( normalData.begin(), normalData.begin() + num_normal, memento->normalData.begin() ); }
bool MBMesquite::PatchData::remove_extra_data | ( | ExtraData * | data | ) | [private] |
Remove an ExtraData object from this PatchData.
Definition at line 1975 of file PatchData.cpp.
References dataList, MBMesquite::ExtraData::patchNext, and MBMesquite::ExtraData::patchPtr.
Referenced by MBMesquite::ExtraData::~ExtraData().
{ if( data->patchPtr != this ) return false; if( dataList == data ) { dataList = data->patchNext; data->patchNext = 0; data->patchPtr = 0; return true; } for( ExtraData* iter = dataList; iter; iter = iter->patchNext ) if( iter->patchNext == data ) { iter->patchNext = data->patchNext; data->patchNext = 0; data->patchPtr = 0; return true; } return false; }
void MBMesquite::PatchData::reorder | ( | ) |
Reorders the mesh data.
Physically reorder the vertices and elements in the PatchData to improve the locality of reference. This method implements a Reverse Breadth First Search order starting with the vertex furthest from the origin. Other orderings can also be implemented.
Definition at line 173 of file PatchData.cpp.
References dist(), elementArray, elementHandlesArray, generate_vertex_to_element_data(), normalData, notify_new_patch(), num_elements(), num_nodes(), numFreeVertices, numSlaveVertices, vertAdjacencyArray, vertAdjacencyOffsets, vertexArray, vertexHandlesArray, and vertexNormalIndices.
Referenced by MBMesquite::FeasibleNewton::initialize_mesh_iteration(), PatchDataTest::test_patch_contents(), and PatchDataTest::test_quad8_patch().
{ size_t i, j; const size_t num_vertex = num_nodes(); const size_t num_elem = num_elements(); // Step 1: Clear any cached data that will be invalidated by this vertexNormalIndices.clear(); normalData.clear(); // vertexDomainDOF.clear(); // Step 2: Make sure we have vertex-to-element adjacencies if( !vertAdjacencyArray.size() ) generate_vertex_to_element_data(); // Step 3: Do breadth-first search std::vector< bool > visited( num_vertex, false ); std::vector< size_t > vertex_order( num_vertex ); std::vector< size_t >::iterator q1_beg, q1_end, q2_end; q1_beg = q1_end = q2_end = vertex_order.begin(); // Outer loop will be done once for each disconnected chunk of mesh. while( q1_beg != vertex_order.end() ) { // Find vertex furthest from the origin double max = -1.0; size_t vtx_idx = num_vertex; for( i = 0; i < num_vertex; ++i ) if( !visited[i] ) { double dist = vertexArray[i].length_squared(); if( dist > max ) { max = dist; vtx_idx = i; } } assert( vtx_idx < num_vertex ); *q2_end++ = vtx_idx; ; visited[vtx_idx] = true; do { q1_end = q2_end; for( ; q1_beg != q1_end; ++q1_beg ) { size_t vtx_adj_offset = vertAdjacencyOffsets[*q1_beg]; size_t vtx_adj_end = vertAdjacencyOffsets[*q1_beg + 1]; for( i = vtx_adj_offset; i < vtx_adj_end; ++i ) { size_t elem = vertAdjacencyArray[i]; assert( elem < elementArray.size() ); size_t num_elem_verts = elementArray[elem].node_count(); size_t* elem_verts = elementArray[elem].get_vertex_index_array(); for( j = 0; j < num_elem_verts; ++j ) { size_t elem_vert = elem_verts[j]; if( !visited[elem_vert] ) { *q2_end++ = elem_vert; ; visited[elem_vert] = true; } } } } } while( q2_end != q1_end ); } // Step 4: vertex_order contains the list of current vertex indices // in the opposite of the order that they will occur in the // reorderd patch. The following code will construct veretx_map // from vertex_order with the following properties // - vertex_map will be indexed by the current vertex index and // contain the new index of that vertex (inverse of vertex_order) // - the vertices will be grouped by their free/slave/fixed flag. std::vector< size_t > vertex_map( num_vertex ); const size_t fixed_vtx_offset = numFreeVertices + numSlaveVertices; size_t free_idx = 0, slave_idx = numFreeVertices, fixed_idx = fixed_vtx_offset; for( i = 1; i <= num_vertex; ++i ) { size_t vtx_idx = vertex_order[num_vertex - i]; if( vtx_idx < numFreeVertices ) vertex_map[vtx_idx] = free_idx++; else if( vtx_idx < fixed_vtx_offset ) vertex_map[vtx_idx] = slave_idx++; else vertex_map[vtx_idx] = fixed_idx++; } // make sure everything adds up assert( free_idx == numFreeVertices ); assert( slave_idx == fixed_vtx_offset ); assert( fixed_idx == num_vertex ); // Step 5: compute element permutation // initialize all to "num_elem" to indicate unvisited std::vector< size_t > element_map( num_elem, num_elem ); size_t elem_idx = 0; for( i = 1; i <= num_vertex; ++i ) { size_t vtx_idx = vertex_order[num_vertex - i]; size_t vtx_adj_offset = vertAdjacencyOffsets[vtx_idx]; size_t vtx_adj_end = vertAdjacencyOffsets[vtx_idx + 1]; for( j = vtx_adj_offset; j < vtx_adj_end; ++j ) { size_t elem = vertAdjacencyArray[j]; if( element_map[elem] == num_elem ) element_map[elem] = elem_idx++; } } // make sure everything adds up assert( elem_idx == num_elem ); // Step 6: Permute the vertices std::vector< MsqVertex > new_vertex_array( num_vertex ); std::vector< Mesh::VertexHandle > new_vtx_handle_array( num_vertex ); for( i = 0; i < num_vertex; ++i ) { size_t new_idx = vertex_map[i]; new_vertex_array[new_idx] = vertexArray[i]; new_vtx_handle_array[new_idx] = vertexHandlesArray[i]; } vertexArray.swap( new_vertex_array ); vertexHandlesArray.swap( new_vtx_handle_array ); // Step 7: Permute the elements and vertex indices for the elements std::vector< MsqMeshEntity > new_elem_array( num_elem ); std::vector< Mesh::ElementHandle > new_elem_handle_array( num_elem ); for( i = 0; i < num_elem; ++i ) { assert( i < elementArray.size() ); size_t vert_count = elementArray[i].node_count(); size_t* conn_array = elementArray[i].get_vertex_index_array(); for( j = 0; j < vert_count; ++j ) { conn_array[j] = vertex_map[conn_array[j]]; } size_t new_idx = element_map[i]; assert( new_idx < num_elem ); new_elem_array[new_idx] = elementArray[i]; new_elem_handle_array[new_idx] = elementHandlesArray[i]; } elementArray.swap( new_elem_array ); elementHandlesArray.swap( new_elem_handle_array ); // Step 8: Clear no-longer-valid vertex-to-element adjacency info. if( vertAdjacencyOffsets.size() ) { vertAdjacencyOffsets.clear(); vertAdjacencyArray.clear(); generate_vertex_to_element_data(); } notify_new_patch(); }
void MBMesquite::PatchData::set_all_vertices_soft_fixed | ( | MsqError & | err | ) |
Add a soft_fixed flag to all vertices in the patch.
Definition at line 493 of file PatchData.cpp.
{ for( size_t i = 0; i < num_free_vertices(); ++i ) vertexArray[i].set_soft_fixed_flag(); }
void MBMesquite::PatchData::set_all_vertices_soft_free | ( | MsqError & | err | ) |
Remove the soft_fixed flag from all vertices in the patch.
Definition at line 511 of file PatchData.cpp.
References num_nodes(), and vertexArray.
Referenced by MBMesquite::TerminationCriterion::cull_vertices().
{ for( size_t i = 0; i < num_nodes(); ++i ) vertexArray[i].remove_soft_fixed_flag(); }
void MBMesquite::PatchData::set_domain | ( | MeshDomain * | dm | ) |
Definition at line 1344 of file PatchData.cpp.
References myDomain, normalData, notify_patch_destroyed(), and vertexNormalIndices.
Referenced by MBMesquite::TerminationCriterion::accumulate_outer(), MBMesquite::create_ideal_element_patch(), MBMesquite::create_one_tri_patch(), MBMesquite::create_qm_two_quad_patch_with_domain(), MBMesquite::create_qm_two_tri_patch_with_domain(), MBMesquite::create_six_quads_patch_with_domain(), MBMesquite::create_two_tri_patch(), MBMesquite::TerminationCriterion::cull_vertices_global(), MBMesquite::destroy_patch_with_domain(), QualityMetricTester::get_ideal_element(), QualityMetricTester::get_ideal_quads(), QualityMetricTester::get_ideal_tris(), MBMesquite::PatchPowerMeanP::initialize_block_coordinate_descent(), MBMesquite::TargetWriter::loop_over_mesh(), MBMesquite::VertexMover::loop_over_mesh(), MBMesquite::QualityAssessor::loop_over_mesh_internal(), TQualityMetricTest::regression_inverse_mean_ratio_grad(), TQualityMetricTest::regression_inverse_mean_ratio_hess(), MBMesquite::TerminationCriterion::reset_outer(), MBMesquite::ShapeImprover::run_wrapper(), QualityAssessorTest::test_basic_stats_sample(), PatchDataTest::test_fixed_by_geom_dim(), TMPQualityMetricTest< QMType >::test_gradient_common(), PatchTranslate::xform(), PatchScale::xform(), and PatchRotate::xform().
{ myDomain = d; // clear all cached data from the previous domain vertexNormalIndices.clear(); normalData.clear(); // vertexDomainDOF.clear(); // observers should treat this the same as if the // instance of this object wzs being deleted. notify_patch_destroyed(); }
void MBMesquite::PatchData::set_free_vertices_constrained | ( | PatchDataVerticesMemento * | memento, |
Vector3D | dk[], | ||
Moves free vertices from a memento position along a certain direction and then snaps the free vertices to the domain.
dk | an array of directions, ordered like the vertices in the PatchData. |
nb_vtx | number of vertices. |
step_size | a scalar that multiplies the vectors given in dk. |
set_free_vertices_constrained is similar to PatchData::move_free_vertices_constrained() except the original vertex positions are those stored in the PatchDataVerticesMemento instead of the actual vertex position stored in the PatchData Vertex array. The final location is stored in the PatchData; the PatchDataVerticesMemento is unchanged.
Definition at line 385 of file PatchData.cpp.
References MBMesquite::MsqError::INVALID_ARG, MBMesquite::length_squared(), MSQ_CHKERR, MSQ_DBG, MSQ_DBGOUT, MSQ_ERRRTN, MSQ_SETERR, num_free_vertices(), num_nodes(), numSlaveVertices, MBMesquite::PatchDataVerticesMemento::originator, snap_vertex_to_domain(), update_slave_node_coordinates(), vertexArray, and MBMesquite::PatchDataVerticesMemento::vertices.
Referenced by MBMesquite::ConjugateGradient::get_step(), UnOptimizer::optimize_vertex_positions(), and MBMesquite::QuasiNewton::optimize_vertex_positions().
{ if( memento->originator != this || nb_vtx != num_free_vertices() ) { MSQ_SETERR( err )( MsqError::INVALID_ARG ); return; } size_t i; for( i = 0; i < num_free_vertices(); ++i ) { vertexArray[i] = memento->vertices[i] + ( step_size * dk[i] ); snap_vertex_to_domain( i, err );MSQ_ERRRTN( err ); } if( numSlaveVertices ) { update_slave_node_coordinates( err );MSQ_CHKERR( err ); } // Checks that moving direction is zero for fixed vertices. if( MSQ_DBG( 3 ) ) { for( i = 0; i < num_nodes(); ++i ) { if( dk[i].length_squared() != 0.0 ) { MSQ_DBGOUT( 3 ) << "dk[" << i << "]: " << dk[i] << endl; MSQ_DBGOUT( 3 ) << "moving a fixed vertex." << endl; } } } }
void MBMesquite::PatchData::set_free_vertices_soft_fixed | ( | MsqError & | err | ) |
Add a soft_fixed flag to all free vertices in the patch.
Definition at line 501 of file PatchData.cpp.
References num_free_vertices(), and vertexArray.
{ for( size_t i = 0; i < num_free_vertices(); ++i ) { if( vertexArray[i].is_free_vertex() ) vertexArray[i].set_soft_fixed_flag(); } }
void MBMesquite::PatchData::set_mesh | ( | Mesh * | ms | ) |
Sets the originating meshSet. This is normally done in MeshSet::get_next_patch(). This function is only for tests purposes.
Definition at line 1336 of file PatchData.cpp.
References myMesh, and notify_patch_destroyed().
Referenced by MBMesquite::TerminationCriterion::accumulate_outer(), check_global_patch_slaved(), PatchDataTest::check_higher_order_vertices_slaved(), MBMesquite::TerminationCriterion::cull_vertices_global(), MBMesquite::MeshUtil::get_global_patch(), MBMesquite::PatchIterator::get_next_patch(), MBMesquite::ObjectiveFunctionTemplate::initialize_block_coordinate_descent(), MBMesquite::PatchPowerMeanP::initialize_block_coordinate_descent(), MBMesquite::TargetWriter::loop_over_mesh(), MBMesquite::VertexMover::loop_over_mesh(), MBMesquite::QualityAssessor::loop_over_mesh_internal(), MBMesquite::TerminationCriterion::reset_outer(), MBMesquite::ShapeImprover::run_wrapper(), tag_patch_slaved(), TerminationCriterionTest::test_absolute_vertex_movement_edge_length(), QualityAssessorTest::test_basic_stats_sample(), VtkTest::test_elements(), PatchDataTest::test_fixed_by_geom_dim(), MBMesquite::MeshWriter::write_eps(), MBMesquite::MeshWriter::write_gnuplot(), MBMesquite::MeshWriter::write_svg(), and MBMesquite::MeshWriter::write_vtk().
{ myMesh = ms; // observers should treat this the same as if the // instance of this object wzs being deleted. notify_patch_destroyed(); }
void MBMesquite::PatchData::set_mesh_entities | ( | std::vector< Mesh::ElementHandle > & | patch_elems, |
std::vector< Mesh::VertexHandle > & | free_vertices, | ||
Definition at line 1793 of file PatchData.cpp.
References MBMesquite::arrptr(), byteArray, clear(), elemConnectivityArray, elementArray, elementHandlesArray, MBMesquite::Mesh::elements_get_attached_vertices(), MBMesquite::Mesh::elements_get_topologies(), get_mesh(), initialize_data(), MBMesquite::MsqError::INVALID_STATE, make_handles_unique(), MBMesquite::MsqVertex::MSQ_DEPENDENT, MSQ_ERRRTN, MBMesquite::MsqVertex::MSQ_PATCH_FIXED, MSQ_SETERR, offsetArray, vertexArray, vertexHandlesArray, MBMesquite::Mesh::vertices_get_byte(), and MBMesquite::Mesh::vertices_get_coordinates().
Referenced by PatchDataTest::check_higher_order_vertices_slaved(), MBMesquite::TerminationCriterion::cull_vertices_global(), MBMesquite::PatchIterator::get_next_patch(), MBMesquite::TargetWriter::loop_over_mesh(), MBMesquite::VertexMover::loop_over_mesh(), MBMesquite::QualityAssessor::loop_over_mesh_internal(), MBMesquite::ShapeImprover::run_wrapper(), QualityAssessorTest::test_basic_stats_sample(), PatchDataTest::test_fixed_by_geom_dim(), and MBMesquite::MeshWriter::write_gnuplot().
{ Mesh* current_mesh = get_mesh(); if( !current_mesh ) { MSQ_SETERR( err )( "No Mesh associated with PatchData.", MsqError::INVALID_STATE ); return; } if( elements.empty() ) { clear(); return; } elementHandlesArray = elements; get_mesh()->elements_get_attached_vertices( arrptr( elementHandlesArray ), elementHandlesArray.size(), vertexHandlesArray, offsetArray, err );MSQ_ERRRTN( err ); // Construct CSR-rep element connectivity data size_t num_vert = vertexHandlesArray.size(); elemConnectivityArray.resize( num_vert ); make_handles_unique( arrptr( vertexHandlesArray ), num_vert, arrptr( elemConnectivityArray ) ); vertexHandlesArray.resize( num_vert ); // Get element topologies std::vector< EntityTopology > elem_topologies( elementHandlesArray.size() ); get_mesh()->elements_get_topologies( arrptr( elementHandlesArray ), arrptr( elem_topologies ), elementHandlesArray.size(), err );MSQ_ERRRTN( err ); // get vertex bits from mesh byteArray.resize( vertexHandlesArray.size() ); get_mesh()->vertices_get_byte( arrptr( vertexHandlesArray ), arrptr( byteArray ), vertexHandlesArray.size(), err );MSQ_ERRRTN( err ); // if free_vertices is not empty, then we need to mark as // fixed any vertices *not* in that list. if( free_vertices.size() == 1 ) { for( size_t i = 0; i < vertexHandlesArray.size(); ++i ) if( vertexHandlesArray[i] == free_vertices.front() ) byteArray[i] &= ~MsqVertex::MSQ_PATCH_FIXED; else byteArray[i] |= MsqVertex::MSQ_PATCH_FIXED; } else if( !free_vertices.empty() ) { // sort and remove duplicates from free_vertices list. std::sort( free_vertices.begin(), free_vertices.end() ); free_vertices.erase( std::unique( free_vertices.begin(), free_vertices.end() ), free_vertices.end() ); for( size_t i = 0; i < vertexHandlesArray.size(); ++i ) { if( ( byteArray[i] & MsqVertex::MSQ_DEPENDENT ) || std::binary_search( free_vertices.begin(), free_vertices.end(), vertexHandlesArray[i] ) ) byteArray[i] &= ~MsqVertex::MSQ_PATCH_FIXED; else byteArray[i] |= MsqVertex::MSQ_PATCH_FIXED; } } // set element types elementArray.resize( elementHandlesArray.size() ); for( size_t i = 0; i < elementHandlesArray.size(); ++i ) elementArray[i].set_element_type( elem_topologies[i] ); // get element connectivity, group vertices by free/slave/fixed state initialize_data( arrptr( offsetArray ), arrptr( byteArray ), err );MSQ_ERRRTN( err ); // get vertex coordinates vertexArray.resize( vertexHandlesArray.size() ); get_mesh()->vertices_get_coordinates( arrptr( vertexHandlesArray ), arrptr( vertexArray ), vertexHandlesArray.size(), err );MSQ_ERRRTN( err ); // set vertex flags for( size_t i = 0; i < vertexArray.size(); ++i ) vertexArray[i].flags() = byteArray[i]; }
void MBMesquite::PatchData::set_to_vertices_memento | ( | PatchDataVerticesMemento * | memento, |
) | [inline] |
Restore the PatchData coordinates to the state contained in the memento.
This function restores a PatchData object coordinates to a previous state hold in a PatchDataVerticesMemento object (see create_vertices_memento() ).
The function checks whether the memento originates from this particular PatchData object. The function does not destroy the memento object: this is the caller responsibility.
Definition at line 974 of file PatchData.hpp.
References MBMesquite::MsqError::INVALID_ARG, MBMesquite::MsqError::INVALID_STATE, MSQ_SETERR, normalData, MBMesquite::PatchDataVerticesMemento::normalData, num_free_vertices(), num_slave_vertices(), MBMesquite::PatchDataVerticesMemento::originator, vertexArray, and MBMesquite::PatchDataVerticesMemento::vertices.
Referenced by MBMesquite::ConjugateGradient::get_step(), UnOptimizer::optimize_vertex_positions(), MBMesquite::TrustRegion::optimize_vertex_positions(), MBMesquite::QuasiNewton::optimize_vertex_positions(), MBMesquite::SteepestDescent::optimize_vertex_positions(), and MBMesquite::FeasibleNewton::optimize_vertex_positions().
{ if( memento->originator != this ) { MSQ_SETERR( err ) ( "Memento may only be used to restore the PatchData " "object from which it was created.", MsqError::INVALID_ARG ); return; } if( memento->vertices.size() != num_free_vertices() + num_slave_vertices() ) { MSQ_SETERR( err ) ( "Unable to restore patch coordinates. Number of " "vertices in PatchData has changed.", MsqError::INVALID_STATE ); return; } // copies the memento array into the PatchData array. std::copy( memento->vertices.begin(), memento->vertices.end(), vertexArray.begin() ); std::copy( memento->normalData.begin(), memento->normalData.end(), normalData.begin() ); }
void MBMesquite::PatchData::set_vertex_coordinates | ( | const Vector3D & | coords, |
) | [inline] |
set the coordinates of the index-th vertex in the raw array
Definition at line 828 of file PatchData.hpp.
Referenced by ObjectiveFunctionTests::compare_numerical_hessian(), MBMesquite::NonSmoothDescent::compute_gradient(), MBMesquite::NonGradient::evaluate(), MBMesquite::QualityMetric::evaluate_with_gradient(), MBMesquite::QualityMetric::evaluate_with_Hessian(), QualityMetricTester::get_degenerate_element(), MBMesquite::ObjectiveFunction::get_eps(), QualityMetricTester::get_inverted_element(), QualityMetricTester::get_nonideal_element(), QualityMetricTester::get_zero_element(), MBMesquite::SmartLaplacianSmoother::optimize_vertex_positions(), MBMesquite::LaplacianSmoother::optimize_vertex_positions(), MBMesquite::NonGradient::optimize_vertex_positions(), MBMesquite::NonSmoothDescent::step_acceptance(), MsqMeshEntityTest::test_check_element_orientation(), QualityMetricTester::test_domain_deviation_quality(), TMPQualityMetricTest< QMType >::test_evaluate_2D(), TMPQualityMetricTest< QMType >::test_evaluate_3D(), TMPQualityMetricTest< QMType >::test_evaluate_surface(), QualityMetricTester::test_gradient_reflects_quality(), QualityMetricTester::test_measures_quality(), TerminationCriterionTest::test_untangled_mesh(), TerminationCriterionTest::test_vertex_bound(), PatchScale::xform(), and PatchRotate::xform().
{ if( index >= vertexArray.size() ) { MSQ_SETERR( err )( "Index bigger than numVertices.", MsqError::INVALID_ARG ); return; } vertexArray[index] = coords; if( numSlaveVertices ) { size_t num_elem; const size_t* indices; indices = get_vertex_element_adjacencies( index, num_elem, err );MSQ_ERRRTN( err ); update_slave_node_coordinates( indices, num_elem, err );MSQ_ERRRTN( err ); } }
MESQUITE_EXPORT void MBMesquite::PatchData::set_vertex_culled | ( | size_t | vtx_index | ) | [inline] |
Mark vertex as culled (soft fixed)
Definition at line 489 of file PatchData.hpp.
References MBMesquite::MsqVertex::MSQ_CULLED, and vertexArray.
Referenced by MBMesquite::TerminationCriterion::cull_vertices_global().
{ vertexArray[vtx_index].flags() |= MsqVertex::MSQ_CULLED; }
MESQUITE_EXPORT const Settings* MBMesquite::PatchData::settings | ( | ) | const [inline] |
void MBMesquite::PatchData::snap_vertex_to_domain | ( | size_t | vertex_index, |
Adjust the position of the specified vertex so that it lies on its constraining domain. The actual domain constraint is managed by the MeshSet's MeshDomain object.
Adjust the position of the specified vertex so that it lies on its constraining domain. The actual domain constraint is managed by the TSTT mesh implementation
Definition at line 1125 of file PatchData.cpp.
References MBMesquite::MeshDomain::closest_point(), domain_set(), get_domain(), MSQ_ERRRTN, normalData, MBMesquite::MeshDomain::snap_to(), vertexArray, vertexHandlesArray, and vertexNormalIndices.
Referenced by MBMesquite::NonGradient::evaluate(), move_free_vertices_constrained(), MBMesquite::SmartLaplacianSmoother::optimize_vertex_positions(), MBMesquite::LaplacianSmoother::optimize_vertex_positions(), MBMesquite::Randomize::optimize_vertex_positions(), MBMesquite::NonGradient::optimize_vertex_positions(), set_free_vertices_constrained(), and update_slave_node_coordinates().
{ if( domain_set() ) { // if not doing normal caching or vertex is not on a single surface if( normalData.empty() ) { get_domain()->snap_to( vertexHandlesArray[vertex_index], vertexArray[vertex_index] ); } // entire domain is 2-D (all vertices have a single normal) else if( vertexNormalIndices.empty() ) { get_domain()->closest_point( vertexHandlesArray[vertex_index], Vector3D( vertexArray[vertex_index] ), vertexArray[vertex_index], normalData[vertex_index], err );MSQ_ERRRTN( err ); } else if( vertexNormalIndices[vertex_index] < normalData.size() ) { // vertex has a unique normal get_domain()->closest_point( vertexHandlesArray[vertex_index], Vector3D( vertexArray[vertex_index] ), vertexArray[vertex_index], normalData[vertexNormalIndices[vertex_index]], err );MSQ_ERRRTN( err ); } else { // vertex has multiple normals get_domain()->snap_to( vertexHandlesArray[vertex_index], vertexArray[vertex_index] ); } } }
void MBMesquite::PatchData::update_cached_normals | ( | MsqError & | err | ) | [private] |
Definition at line 1151 of file PatchData.cpp.
References MBMesquite::arrptr(), MBMesquite::MeshDomain::domain_DoF(), get_domain(), MBMesquite::MsqError::INVALID_STATE, MSQ_ERRRTN, MSQ_SETERR, n, normalData, num_nodes(), MBMesquite::MeshDomain::vertex_normal_at(), vertexArray, vertexDomainDOF, vertexHandlesArray, and vertexNormalIndices.
Referenced by get_domain_normal_at_vertex(), get_domain_normals_at_corners(), and project_gradient().
{ size_t i; MeshDomain* domain = get_domain(); if( !domain ) { MSQ_SETERR( err )( "No domain constraint set.", MsqError::INVALID_STATE ); return; } // Determine which vertices lie on surfaces vertexDomainDOF.resize( num_nodes() ); domain->domain_DoF( arrptr( vertexHandlesArray ), arrptr( vertexDomainDOF ), num_nodes(), err );MSQ_ERRRTN( err ); // Count how many vertices have a single normal // Sun doesn't support partial template specialization, so can't use std::count // size_t n = std::count( vertexDomainDOF.begin(), vertexDomainDOF.end(), 2 ); size_t n = 0; std::vector< unsigned short >::iterator k; for( k = vertexDomainDOF.begin(); k != vertexDomainDOF.end(); ++k ) if( *k == 2 ) ++n; normalData.resize( n ); // If all vertices are on a surface, pass in the existing handles array // and store a single normal per vertex. if( n == num_nodes() ) { std::copy( vertexArray.begin(), vertexArray.end(), normalData.begin() ); domain->vertex_normal_at( arrptr( vertexHandlesArray ), arrptr( normalData ), num_nodes(), err ); vertexNormalIndices.clear(); vertexDomainDOF.clear();MSQ_ERRRTN( err ); } else { vertexNormalIndices.resize( num_nodes() ); size_t nn = 0; for( i = 0; i < num_nodes(); ++i ) { if( vertexDomainDOF[i] == 2 ) { normalData[nn] = vertexArray[i]; domain->vertex_normal_at( vertexHandlesArray[i], normalData[nn] ); vertexNormalIndices[i] = nn; ++nn; } else { vertexNormalIndices[i] = n + 1; } } assert( nn == n ); } }
void MBMesquite::PatchData::update_mesh | ( | MsqError & | err, |
const TagHandle * | tag = 0 |
This function copies to the TSTT mesh the changes made to the free vertices / elements of the PatchData object.
Updates the underlying mesh (the MBMesquite::Mesh implementation) with new node coordinates and flag values.
tag | If non-null, store vertex coords in tag rather than updating the coords in the mesh database. Used for Jacobi optimizations. |
Definition at line 752 of file PatchData.cpp.
References INTERNAL_ERROR, MSQ_ERRRTN, MSQ_SETERR, myMesh, numFreeVertices, numSlaveVertices, MBMesquite::Mesh::tag_set_vertex_data(), MBMesquite::Mesh::vertex_set_byte(), MBMesquite::Mesh::vertex_set_coordinates(), vertexArray, and vertexHandlesArray.
Referenced by MBMesquite::VertexMover::loop_over_mesh().
{ if( !myMesh ) { MSQ_SETERR( err )( "Cannot update mesh on temporary patch.\n", MsqError::INTERNAL_ERROR ); return; } const size_t not_fixed = numFreeVertices + numSlaveVertices; if( tag ) { for( size_t i = 0; i < not_fixed; ++i ) { myMesh->tag_set_vertex_data( *tag, 1, &vertexHandlesArray[i], vertexArray[i].to_array(), err );MSQ_ERRRTN( err ); } } else { for( size_t i = 0; i < not_fixed; ++i ) { myMesh->vertex_set_coordinates( vertexHandlesArray[i], vertexArray[i], err );MSQ_ERRRTN( err ); } } for( size_t i = 0; i < vertexArray.size(); ++i ) { myMesh->vertex_set_byte( vertexHandlesArray[i], vertexArray[i].get_flags(), err );MSQ_ERRRTN( err ); } }
void MBMesquite::PatchData::update_slave_node_coordinates | ( | MsqError & | err | ) |
Calculate new location for all slave higher-order nodes using mapping function. Called by update_mesh().
Definition at line 782 of file PatchData.cpp.
References MBMesquite::MappingFunction::coefficients(), conn, MBMesquite::MappingFunction::convert_connectivity_indices(), domain_set(), element_by_index(), MBMesquite::MsqVertex::flags(), MBMesquite::MsqMeshEntity::get_element_type(), get_mapping_function(), get_vertex_handles_array(), MBMesquite::MsqMeshEntity::get_vertex_index_array(), MBMesquite::MsqError::INVALID_MESH, MBMesquite::MsqVertex::is_flag_set(), is_vertex_slave(), MSQ_ERRRTN, MBMesquite::MsqVertex::MSQ_MARK, MSQ_SETERR, MBMesquite::MsqMeshEntity::node_count(), non_slave_node_set(), num_elements(), num_free_vertices(), num_slave_vertices(), snap_vertex_to_domain(), vertex_by_index(), MBMesquite::MsqMeshEntity::vertex_count(), and vertexArray.
Referenced by move_free_vertices_constrained(), move_vertex(), set_free_vertices_constrained(), set_vertex_coordinates(), and PatchDataTest::test_update_slave_node_coords().
{ // update slave vertices if( 0 == num_slave_vertices() ) return; // Set a mark on every slave vertex. We'll clear the marks as we // set the vertex coordinates. This way we can check that all // vertices got updated. const size_t vert_end = num_free_vertices() + num_slave_vertices(); for( size_t i = num_free_vertices(); i < vert_end; ++i ) vertexArray[i].flags() |= MsqVertex::MSQ_MARK; // For each element, calculate slave vertex coordinates from // mapping function. const int ARR_SIZE = 27; double coeff[ARR_SIZE]; size_t index[ARR_SIZE]; for( size_t i = 0; i < num_elements(); ++i ) { MsqMeshEntity& elem = element_by_index( i ); const int num_corner = elem.vertex_count(); const int num_node = elem.node_count(); assert( num_node < ARR_SIZE ); const EntityTopology type = elem.get_element_type(); const MappingFunction* const mf = get_mapping_function( type ); if( 0 == mf || num_node == num_corner ) continue; const size_t* conn = elem.get_vertex_index_array(); // for each higher-order non-slave node, set bit indicating // that mapping function is a function of the non-slave node // coordinates NodeSet ho_bits = non_slave_node_set( i ); // for each higher-order slave node for( int k = num_corner; k < num_node; ++k ) { if( !is_vertex_slave( conn[k] ) ) continue; // check if we already did this one for an adjacent element MsqVertex& vert = vertexArray[conn[k]]; if( !vert.is_flag_set( MsqVertex::MSQ_MARK ) ) continue; // what is this node a mid node of (i.e. face 1, edge 2, etc.) Sample loc = TopologyInfo::sample_from_node( type, elem.node_count(), k, err );MSQ_ERRRTN( err ); // evaluate mapping function at logical loction of HO node. size_t num_coeff; mf->coefficients( loc, ho_bits, coeff, index, num_coeff, err );MSQ_ERRRTN( err ); mf->convert_connectivity_indices( num_node, index, num_coeff, err );MSQ_ERRRTN( err ); // calulate new coordinates for slave node assert( num_coeff > 0 ); vert = coeff[0] * vertex_by_index( conn[index[0]] ); for( size_t j = 1; j < num_coeff; ++j ) vert += coeff[j] * vertex_by_index( conn[index[j]] ); // clear mark vert.flags() &= ~MsqVertex::MSQ_MARK; } } // make sure we set the coordinates for every slave node for( size_t i = num_free_vertices(); i < vert_end; ++i ) { if( vertex_by_index( i ).is_flag_set( MsqVertex::MSQ_MARK ) ) { MSQ_SETERR( err ) ( MsqError::INVALID_MESH, "No element with mapping function adjacent to slave vertex %lu (%lu)\n", (unsigned long)i, (unsigned long)get_vertex_handles_array()[i] ); // make sure we finish with all marks cleared vertexArray[i].flags() &= ~MsqVertex::MSQ_MARK; } } // snap vertices to domain if( domain_set() ) { for( size_t i = num_free_vertices(); i < vert_end; ++i ) { snap_vertex_to_domain( i, err );MSQ_ERRRTN( err ); } } }
void MBMesquite::PatchData::update_slave_node_coordinates | ( | const size_t * | elem_indices, |
size_t | num_elem, | ||
Definition at line 868 of file PatchData.cpp.
References MBMesquite::MappingFunction::coefficients(), conn, MBMesquite::MappingFunction::convert_connectivity_indices(), domain_set(), element_by_index(), MBMesquite::MsqVertex::flags(), MBMesquite::MsqMeshEntity::get_element_type(), get_mapping_function(), MBMesquite::MsqMeshEntity::get_vertex_index_array(), MBMesquite::MsqVertex::is_flag_set(), is_vertex_slave(), MSQ_ERRRTN, MBMesquite::MsqVertex::MSQ_MARK, MBMesquite::MsqMeshEntity::node_count(), non_slave_node_set(), num_slave_vertices(), snap_vertex_to_domain(), vertex_by_index(), MBMesquite::MsqMeshEntity::vertex_count(), and vertexArray.
{ // update slave vertices if( 0 == num_slave_vertices() ) return; // set a mark on each vertex so we don't update shared // vertices more than once. for( size_t i = 0; i < num_elems; ++i ) { MsqMeshEntity& elem = element_by_index( elements[i] ); const int num_corner = elem.vertex_count(); const int num_node = elem.node_count(); const size_t* conn = elem.get_vertex_index_array(); for( int j = num_corner; j < num_node; ++j ) vertexArray[conn[j]].flags() |= MsqVertex::MSQ_MARK; } // For each element, calculate slave vertex coordinates from // mapping function. const int ARR_SIZE = 27; double coeff[ARR_SIZE]; size_t index[ARR_SIZE]; for( size_t i = 0; i < num_elems; ++i ) { MsqMeshEntity& elem = element_by_index( elements[i] ); const int num_corner = elem.vertex_count(); const int num_node = elem.node_count(); assert( num_node < ARR_SIZE ); const EntityTopology type = elem.get_element_type(); const MappingFunction* const mf = get_mapping_function( type ); if( 0 == mf || num_node == num_corner ) continue; const size_t* conn = elem.get_vertex_index_array(); // for each higher-order non-slave node, set bit indicating // that mapping function is a function of the non-slave node // coordinates NodeSet ho_bits = non_slave_node_set( i ); // for each higher-order slave node for( int k = num_corner; k < num_node; ++k ) { if( !is_vertex_slave( conn[k] ) ) continue; // check if we already did this one for an adjacent element MsqVertex& vert = vertexArray[conn[k]]; if( !vert.is_flag_set( MsqVertex::MSQ_MARK ) ) continue; // what is this node a mid node of (i.e. face 1, edge 2, etc.) Sample loc = TopologyInfo::sample_from_node( type, elem.node_count(), k, err );MSQ_ERRRTN( err ); // evaluate mapping function at logical loction of HO node. size_t num_coeff; mf->coefficients( loc, ho_bits, coeff, index, num_coeff, err );MSQ_ERRRTN( err ); mf->convert_connectivity_indices( num_node, index, num_coeff, err );MSQ_ERRRTN( err ); // calulate new coordinates for slave node assert( num_coeff > 0 ); vert = coeff[0] * vertex_by_index( conn[index[0]] ); for( size_t j = 1; j < num_coeff; ++j ) vert += coeff[j] * vertex_by_index( conn[index[j]] ); // snap vertices to domain if( domain_set() ) { snap_vertex_to_domain( conn[k], err );MSQ_ERRRTN( err ); } // clear mark vert.flags() &= ~MsqVertex::MSQ_MARK; } } }
const MsqVertex & MBMesquite::PatchData::vertex_by_index | ( | size_t | index | ) | const [inline] |
Returns the start of the vertex->element array. For each vertex in the patch, this array holds the number of elements the vertex is attached to, followed by the indices of those elements. Returns the start of the vertex->element offset array (v2e_o). For vertex i, v2e_o[i] is the index into the vertex->element array (v2e) where vertex i's data begins. So, v2e[v2e_o[i]] gives you the number of elements vertex i is attached to, and v2e[v2e_o[i]+1] gives you the index of the first element attached to vertex i.
Definition at line 872 of file PatchData.hpp.
Referenced by PatchDataTest::check_higher_order_vertices_slaved(), PatchDataTest::check_sub_patch(), ObjectiveFunctionTests::compare_numerical_hessian(), MBMesquite::MsqMeshEntity::compute_corner_normals(), MBMesquite::NonSmoothDescent::compute_gradient(), MBMesquite::EdgeIterator::end(), MBMesquite::EdgeLengthMetric::evaluate(), MBMesquite::AffineMapMetric::evaluate(), NumericalTestOF::evaluate(), MBMesquite::NonGradient::evaluate(), LinearVertexMetric::evaluate(), ParabolicVertexMetric::evaluate(), DistTestMetric::evaluate(), MBMesquite::EdgeLengthMetric::evaluate_with_gradient(), MBMesquite::QualityMetric::evaluate_with_gradient(), MBMesquite::QualityMetric::evaluate_with_Hessian(), LinearVertexMetric::evaluate_with_indices(), ParabolicVertexMetric::evaluate_with_indices(), DistTestMetric::evaluate_with_indices(), MBMesquite::get_delta_C(), get_domain_normal_at_mid_edge(), MBMesquite::EdgeQM::get_edge_evaluations(), MBMesquite::ObjectiveFunction::get_eps(), get_minmax_edge_length(), TMPQualityMetricTest< AWQualityMetric >::get_nonideal_element(), get_sample_location(), MBMesquite::VertexQM::get_vertex_evaluations(), MBMesquite::MappingFunction2D::jacobian(), MBMesquite::MappingFunction3D::jacobian(), TriTauMetric::matrix(), MBMesquite::EdgeIterator::mid(), MBMesquite::MsqFreeVertexIndexIterator::next(), non_slave_node_set(), UnOptimizer::optimize_vertex_positions(), MBMesquite::EdgeIterator::start(), MsqMeshEntityTest::test_check_element_orientation(), QualityMetricTester::test_domain_deviation_quality(), TMPQualityMetricTest< QMType >::test_evaluate_2D(), TMPQualityMetricTest< QMType >::test_evaluate_3D(), TMPQualityMetricTest< QMType >::test_evaluate_surface(), MappingFunctionTest::test_jacobian_2d(), MappingFunctionTest::test_jacobian_3d(), PatchDataTest::test_patch_contents(), PatchDataTest::test_quad8_patch(), TerminationCriterionTest::test_untangled_mesh(), PatchDataTest::test_update_slave_node_coords(), TerminationCriterionTest::test_vertex_bound(), update_slave_node_coordinates(), MBMesquite::MeshWriter::write_vtk(), PatchScale::xform(), and PatchRotate::xform().
{ assert( index < vertexArray.size() ); return vertexArray[index]; }
friend class MBMesquite::ExtraData [friend] |
Definition at line 610 of file PatchData.hpp.
std::ostream& operator<< | ( | std::ostream & | , |
const PatchData & | |||
) | [friend] |
Display the coordinates and connectivity information.
std::vector< bool > MBMesquite::PatchData::bitMap [mutable, private] |
Definition at line 744 of file PatchData.hpp.
Referenced by get_adjacent_vertex_indices().
std::vector< unsigned char > MBMesquite::PatchData::byteArray [private] |
Definition at line 743 of file PatchData.hpp.
Referenced by fill(), get_subpatch(), and set_mesh_entities().
double MBMesquite::PatchData::computedInfos[MAX_COMPUTED_INFO_ENUM] [private] |
Definition at line 747 of file PatchData.hpp.
Referenced by get_minmax_element_unsigned_area(), and MBMesquite::operator<<().
ExtraData* MBMesquite::PatchData::dataList [private] |
Definition at line 752 of file PatchData.hpp.
Referenced by attach_extra_data(), notify_new_patch(), notify_patch_destroyed(), notify_sub_patch(), and remove_extra_data().
const Settings MBMesquite::PatchData::defaultSettings [static, private] |
Definition at line 755 of file PatchData.hpp.
std::vector< size_t > MBMesquite::PatchData::elemConnectivityArray [private] |
Element connectivity data. The concatenation of the connectivity list of each element in PatchData::elementArray. Each element in PatchData::elementArray has a pointer into this array at the correct offset for that element's connectivity data.
Definition at line 714 of file PatchData.hpp.
Referenced by clear(), enslave_higher_order_nodes(), fill(), generate_vertex_to_element_data(), get_connectivity_array(), get_subpatch(), initialize_data(), and set_mesh_entities().
std::vector< MsqMeshEntity > MBMesquite::PatchData::elementArray [private] |
Cached data for elements in PatchData::elementHandlesArray or element data for a temporary patch.
Definition at line 706 of file PatchData.hpp.
Referenced by clear(), element_by_index(), enslave_higher_order_nodes(), fill(), generate_vertex_to_element_data(), get_adjacent_vertex_indices(), get_domain_normal_at_corner(), get_domain_normal_at_element(), get_domain_normals_at_corners(), get_element_array(), get_element_index(), get_element_vertex_coordinates(), get_element_vertex_indices(), get_minmax_element_unsigned_area(), get_subpatch(), get_vertex_element_indices(), initialize_data(), num_corners(), num_elements(), MBMesquite::operator<<(), reorder(), and set_mesh_entities().
std::vector< Mesh::ElementHandle > MBMesquite::PatchData::elementHandlesArray [private] |
The hist of handles for elements in this patch. May be empty if PatchData::myMesh is NULL
Definition at line 709 of file PatchData.hpp.
Referenced by clear(), fill(), get_domain_normal_at_corner(), get_domain_normal_at_element(), get_domain_normal_at_mid_edge(), get_domain_normals_at_corners(), get_element_handles_array(), get_subpatch(), MBMesquite::operator<<(), project_gradient(), reorder(), and set_mesh_entities().
unsigned MBMesquite::PatchData::haveComputedInfos [private] |
Definition at line 750 of file PatchData.hpp.
Referenced by clear(), clear_computed_info(), have_computed_info(), note_have_info(), and MBMesquite::operator<<().
const Settings* MBMesquite::PatchData::mSettings [private] |
Definition at line 754 of file PatchData.hpp.
Referenced by attach_settings(), fill(), get_mapping_function(), get_mapping_function_2D(), get_mapping_function_3D(), get_samples(), get_settings(), get_subpatch(), and settings().
MeshDomain* MBMesquite::PatchData::myDomain [private] |
The geometric domain of the mesh [may be NULL].
Definition at line 685 of file PatchData.hpp.
Referenced by clear(), domain_set(), get_domain(), get_subpatch(), MBMesquite::operator<<(), and set_domain().
Mesh* MBMesquite::PatchData::myMesh [private] |
The Mesh used to fill this PatchData [may be NULL].
Definition at line 684 of file PatchData.hpp.
Referenced by clear(), get_mesh(), get_subpatch(), MBMesquite::operator<<(), set_mesh(), and update_mesh().
std::vector< Vector3D > MBMesquite::PatchData::normalData [private] |
Storage space for cached domain normal data. Pointers in PatchData::vertexNormalPointers point into this list.
Definition at line 733 of file PatchData.hpp.
Referenced by clear(), get_domain_normal_at_vertex(), get_domain_normals_at_corners(), initialize_data(), project_gradient(), recreate_vertices_memento(), reorder(), set_domain(), set_to_vertices_memento(), snap_vertex_to_domain(), and update_cached_normals().
size_t MBMesquite::PatchData::numFreeVertices [private] |
The number of vertices in PatchData::vertexArray that are free vertices. The vertex array is sorted such that free vertices are first in the array. This value is therefore the offset at which slave vertices begin in the array.
Definition at line 698 of file PatchData.hpp.
Referenced by clear(), fill(), initialize_data(), is_vertex_fixed(), is_vertex_free(), is_vertex_not_free(), is_vertex_slave(), num_free_vertices(), reorder(), and update_mesh().
size_t MBMesquite::PatchData::numSlaveVertices [private] |
The number of slave vertices in vertexArray. The vertices are ordered such that all fixed vertices occur after the slave vertices. Therefore the offset at which the fixed vertices begin is numFreeVertices+numSlaveVertices
Definition at line 703 of file PatchData.hpp.
Referenced by clear(), fill(), initialize_data(), is_vertex_fixed(), is_vertex_slave(), move_free_vertices_constrained(), move_vertex(), num_slave_vertices(), reorder(), set_free_vertices_constrained(), set_vertex_coordinates(), and update_mesh().
std::vector< size_t > MBMesquite::PatchData::offsetArray [private] |
Definition at line 742 of file PatchData.hpp.
Referenced by set_mesh_entities().
std::vector< size_t > MBMesquite::PatchData::vertAdjacencyArray [private] |
The concatenation of the adjacency lists of all the vertices in PatchData::vertexArray. Each value in the array is an index into PatchData::elementArray indicating that the corresponding element uses the vertex. May be empty if vertex adjacency data has not been requested.
Definition at line 720 of file PatchData.hpp.
Referenced by clear(), generate_vertex_to_element_data(), get_vertex_element_adjacencies(), initialize_data(), MBMesquite::operator<<(), and reorder().
std::vector< size_t > MBMesquite::PatchData::vertAdjacencyOffsets [private] |
This array is indexed by vertex indices and specifies the offset in at which the adjacency list for the corresponding vertex begins. May be empty if vertex adjacency data has not been requested.
Definition at line 725 of file PatchData.hpp.
std::vector< MsqVertex > MBMesquite::PatchData::vertexArray [private] |
Cached data for vertices in PatchData::vertexHandlesArray, or vertex data for a temporary patch.
Definition at line 689 of file PatchData.hpp.
Referenced by check_vertex_culled(), clear(), clear_vertex_culled(), fill(), get_domain_normal_at_vertex(), get_domain_normals_at_corners(), get_element_vertex_coordinates(), get_free_vertex_coordinates(), get_max_vertex_movement_squared(), get_subpatch(), get_vertex_array(), get_vertex_index(), move_free_vertices_constrained(), move_vertex(), num_nodes(), MBMesquite::operator<<(), project_gradient(), recreate_vertices_memento(), reorder(), set_all_vertices_soft_fixed(), set_all_vertices_soft_free(), set_free_vertices_constrained(), set_free_vertices_soft_fixed(), set_mesh_entities(), set_to_vertices_memento(), set_vertex_coordinates(), set_vertex_culled(), snap_vertex_to_domain(), update_cached_normals(), update_mesh(), update_slave_node_coordinates(), and vertex_by_index().
std::vector< unsigned short > MBMesquite::PatchData::vertexDomainDOF [private] |
Storage space for cached domain DOF for vertices. IF a domain exists and PatchData::normalData is not empty, but this array is, it may be assumed that all vertices have have a DOF == 2.
Definition at line 738 of file PatchData.hpp.
Referenced by project_gradient(), and update_cached_normals().
std::vector< Mesh::VertexHandle > MBMesquite::PatchData::vertexHandlesArray [private] |
The list of handles for the vertices in this patch May be empty if PatchData::myMesh is NULL
Definition at line 692 of file PatchData.hpp.
Referenced by clear(), enslave_higher_order_nodes(), fill(), get_subpatch(), get_vertex_handles_array(), initialize_data(), MBMesquite::operator<<(), reorder(), set_mesh_entities(), snap_vertex_to_domain(), update_cached_normals(), and update_mesh().
std::vector< unsigned > MBMesquite::PatchData::vertexNormalIndices [private] |
Index into normalData at which the normal for the corresponding vertex index is located. Only vertices constrained to a single domain with a topological dimension of 2 have a unique domain normal.
Definition at line 730 of file PatchData.hpp.
Referenced by clear(), get_domain_normal_at_vertex(), get_domain_normals_at_corners(), initialize_data(), project_gradient(), recreate_vertices_memento(), reorder(), set_domain(), snap_vertex_to_domain(), and update_cached_normals().
