attach_extra_data(ExtraData *data) | MBMesquite::PatchData | [private] |
attach_settings(const Settings *p_settings) | MBMesquite::PatchData | [inline] |
AVERAGE_DET3D enum value | MBMesquite::PatchData | |
bitMap | MBMesquite::PatchData | [mutable, private] |
byteArray | MBMesquite::PatchData | [private] |
check_vertex_culled(size_t vtx_index) const | MBMesquite::PatchData | [inline] |
clear() | MBMesquite::PatchData | [inline] |
clear_computed_info() | MBMesquite::PatchData | [inline] |
clear_vertex_culled(size_t vtx_index) | MBMesquite::PatchData | [inline] |
ComputedInfo enum name | MBMesquite::PatchData | |
computedInfos | MBMesquite::PatchData | [private] |
create_vertices_memento(MsqError &err) | MBMesquite::PatchData | [inline] |
dataList | MBMesquite::PatchData | [private] |
defaultSettings | MBMesquite::PatchData | [private, static] |
domain_set() const | MBMesquite::PatchData | [inline] |
elemConnectivityArray | MBMesquite::PatchData | [private] |
element_by_index(size_t index) | MBMesquite::PatchData | [inline] |
element_by_index(size_t index) const | MBMesquite::PatchData | [inline] |
elementArray | MBMesquite::PatchData | [private] |
elementHandlesArray | MBMesquite::PatchData | [private] |
enslave_higher_order_nodes(const size_t *element_offset_array, unsigned char *vertex_flags, MsqError &err) const | MBMesquite::PatchData | [private] |
fill(size_t num_vertex, const double *vtx_coords, size_t num_elem, EntityTopology type, const size_t *connectivity, const bool *vertex_fixed_flags, MsqError &err) | MBMesquite::PatchData | |
fill(size_t num_vertex, const double *vtx_coords, size_t num_elem, const EntityTopology *elem_types, const size_t *connectivity, const bool *vertex_fixed_flags, MsqError &err) | MBMesquite::PatchData | |
fill(size_t num_vertex, const double *vtx_coords, size_t num_elem, const EntityTopology *elem_types, const size_t *vertex_per_elem, const size_t *elem_connectivity, const bool *vertex_fixed_flags, MsqError &err) | MBMesquite::PatchData | |
fill_global_patch(MsqError &err) | MBMesquite::PatchData | |
generate_vertex_to_element_data() | MBMesquite::PatchData | |
get_adjacent_entities_via_n_dim(int n, size_t ent_ind, std::vector< size_t > &adj_ents, MsqError &err) | MBMesquite::PatchData | |
get_adjacent_vertex_indices(size_t vertex_index, std::vector< size_t > &vert_indices, MsqError &err) const | MBMesquite::PatchData | |
get_connectivity_array() | MBMesquite::PatchData | [inline] |
get_domain() const | MBMesquite::PatchData | [inline] |
get_domain_normal_at_corner(size_t elemen_index, unsigned corner, Vector3D &normal, MsqError &err) | MBMesquite::PatchData | |
get_domain_normal_at_element(size_t elem_index, Vector3D &surf_norm, MsqError &err) | MBMesquite::PatchData | |
get_domain_normal_at_element(const MsqMeshEntity *elem_ptr, Vector3D &surf_norm, MsqError &err) | MBMesquite::PatchData | [inline] |
get_domain_normal_at_mid_edge(size_t element_index, unsigned edge_number, Vector3D &normal, MsqError &err) | MBMesquite::PatchData | |
get_domain_normal_at_sample(size_t element_index, Sample location, Vector3D &surf_norm, MsqError &err) | MBMesquite::PatchData | [inline] |
get_domain_normal_at_vertex(size_t vert_index, Mesh::ElementHandle element, Vector3D &normal_out, MsqError &err) | MBMesquite::PatchData | |
get_domain_normals_at_corners(size_t element_index, Vector3D normals_out[], MsqError &err) | MBMesquite::PatchData | |
get_element_array(MsqError &err) const | MBMesquite::PatchData | [inline] |
get_element_array(MsqError &err) | MBMesquite::PatchData | [inline] |
get_element_handles_array() | MBMesquite::PatchData | [inline] |
get_element_index(MsqMeshEntity *element) | MBMesquite::PatchData | [inline] |
get_element_vertex_coordinates(size_t elem_index, std::vector< Vector3D > &coords, MsqError &err) | MBMesquite::PatchData | |
get_element_vertex_indices(size_t elem_index, std::vector< size_t > &vertex_indices, MsqError &err) | MBMesquite::PatchData | |
get_free_vertex_coordinates(std::vector< Vector3D > &coords_out) const | MBMesquite::PatchData | [inline] |
get_mapping_function(EntityTopology type) const | MBMesquite::PatchData | [inline] |
get_mapping_function_2D(EntityTopology type) const | MBMesquite::PatchData | [inline] |
get_mapping_function_3D(EntityTopology type) const | MBMesquite::PatchData | [inline] |
get_max_vertex_movement_squared(PatchDataVerticesMemento *memento, MsqError &err) | MBMesquite::PatchData | |
get_mesh() const | MBMesquite::PatchData | [inline] |
get_minmax_edge_length(double &min, double &max) const | MBMesquite::PatchData | |
get_minmax_element_unsigned_area(double &min, double &max, MsqError &err) | MBMesquite::PatchData | |
get_sample_location(size_t element_index, Sample sample, Vector3D &result, MsqError &err) const | MBMesquite::PatchData | |
get_samples(size_t element, NodeSet non_slave_nodes) const | MBMesquite::PatchData | [inline] |
get_samples(size_t element) const | MBMesquite::PatchData | [inline] |
get_samples(size_t element, std::vector< Sample > &samples_out, MsqError &err) const | MBMesquite::PatchData | |
get_settings() const | MBMesquite::PatchData | [inline] |
get_subpatch(size_t center_vertex_index, unsigned num_adj_elem_layers, PatchData &pd_to_fill, MsqError &err) | MBMesquite::PatchData | |
get_vertex_array(MsqError &err) const | MBMesquite::PatchData | [inline] |
get_vertex_array() const | MBMesquite::PatchData | [inline] |
get_vertex_element_adjacencies(size_t vertex_index, size_t &array_len_out, MsqError &err) | MBMesquite::PatchData | |
get_vertex_element_indices(size_t vertex_index, std::vector< size_t > &elem_indices, MsqError &err) | MBMesquite::PatchData | |
get_vertex_element_indices(size_t vertex_index, unsigned element_dimension, std::vector< size_t > &elem_indices, MsqError &err) | MBMesquite::PatchData | |
get_vertex_handles_array() | MBMesquite::PatchData | [inline] |
get_vertex_index(MsqVertex *vertex) | MBMesquite::PatchData | [inline] |
have_computed_info(ComputedInfo info) const | MBMesquite::PatchData | [inline] |
haveComputedInfos | MBMesquite::PatchData | [private] |
initialize_data(size_t *elem_offset_array, unsigned char *vertex_flags, MsqError &err) | MBMesquite::PatchData | [private] |
is_vertex_fixed(size_t index) const | MBMesquite::PatchData | [inline] |
is_vertex_free(size_t index) const | MBMesquite::PatchData | [inline] |
is_vertex_not_free(size_t index) const | MBMesquite::PatchData | [inline] |
is_vertex_slave(size_t index) const | MBMesquite::PatchData | [inline] |
make_handles_unique(Mesh::EntityHandle *handles, size_t &count, size_t *index_map=0) | MBMesquite::PatchData | [private, static] |
MAX_COMPUTED_INFO_ENUM enum value | MBMesquite::PatchData | |
MAX_EDGE_LENGTH enum value | MBMesquite::PatchData | |
MAX_UNSIGNED_AREA enum value | MBMesquite::PatchData | |
MBMesquite::ExtraData class | MBMesquite::PatchData | [friend] |
MIN_EDGE_LENGTH enum value | MBMesquite::PatchData | |
MIN_UNSIGNED_AREA enum value | MBMesquite::PatchData | |
MINMAX_SIGNED_DET2D enum value | MBMesquite::PatchData | |
MINMAX_SIGNED_DET3D enum value | MBMesquite::PatchData | |
move_free_vertices_constrained(Vector3D dk[], size_t nb_vtx, double step_size, MsqError &err) | MBMesquite::PatchData | |
move_vertex(const Vector3D &delta, size_t index, MsqError &err) | MBMesquite::PatchData | [inline] |
mSettings | MBMesquite::PatchData | [private] |
myDomain | MBMesquite::PatchData | [private] |
myMesh | MBMesquite::PatchData | [private] |
non_slave_node_set(size_t elem_idx) const | MBMesquite::PatchData | |
normalData | MBMesquite::PatchData | [private] |
note_have_info(ComputedInfo info) | MBMesquite::PatchData | [inline, private] |
notify_new_patch() | MBMesquite::PatchData | [private] |
notify_patch_destroyed() | MBMesquite::PatchData | [private] |
notify_sub_patch(PatchData &sub_patch, const size_t *vertex_index_map, const size_t *element_index_map, MsqError &err) | MBMesquite::PatchData | [private] |
num_corners() const | MBMesquite::PatchData | |
num_elements() const | MBMesquite::PatchData | [inline] |
num_fixed_vertices() const | MBMesquite::PatchData | [inline] |
num_free_vertices() const | MBMesquite::PatchData | [inline] |
num_nodes() const | MBMesquite::PatchData | [inline] |
num_slave_vertices() const | MBMesquite::PatchData | [inline] |
numFreeVertices | MBMesquite::PatchData | [private] |
numSlaveVertices | MBMesquite::PatchData | [private] |
offsetArray | MBMesquite::PatchData | [private] |
operator<<(std::ostream &, const PatchData &) | MBMesquite::PatchData | [friend] |
operator=(const PatchData &pd) | MBMesquite::PatchData | [private] |
PatchData() | MBMesquite::PatchData | |
PatchData(const PatchData &pd) | MBMesquite::PatchData | [private] |
project_gradient(std::vector< Vector3D > &gradient, MsqError &err) | MBMesquite::PatchData | |
recreate_vertices_memento(PatchDataVerticesMemento *memento, MsqError &err) | MBMesquite::PatchData | [inline] |
remove_extra_data(ExtraData *data) | MBMesquite::PatchData | [private] |
reorder() | MBMesquite::PatchData | |
set_all_vertices_soft_fixed(MsqError &err) | MBMesquite::PatchData | |
set_all_vertices_soft_free(MsqError &err) | MBMesquite::PatchData | |
set_domain(MeshDomain *dm) | MBMesquite::PatchData | |
set_free_vertices_constrained(PatchDataVerticesMemento *memento, Vector3D dk[], size_t nb_vtx, double step_size, MsqError &err) | MBMesquite::PatchData | |
set_free_vertices_soft_fixed(MsqError &err) | MBMesquite::PatchData | |
set_mesh(Mesh *ms) | MBMesquite::PatchData | |
set_mesh_entities(std::vector< Mesh::ElementHandle > &patch_elems, std::vector< Mesh::VertexHandle > &free_vertices, MsqError &err) | MBMesquite::PatchData | |
set_to_vertices_memento(PatchDataVerticesMemento *memento, MsqError &err) | MBMesquite::PatchData | [inline] |
set_vertex_coordinates(const Vector3D &coords, size_t index, MsqError &err) | MBMesquite::PatchData | [inline] |
set_vertex_culled(size_t vtx_index) | MBMesquite::PatchData | [inline] |
snap_vertex_to_domain(size_t vertex_index, MsqError &err) | MBMesquite::PatchData | |
update_cached_normals(MsqError &) | MBMesquite::PatchData | [private] |
update_mesh(MsqError &err, const TagHandle *tag=0) | MBMesquite::PatchData | |
update_slave_node_coordinates(MsqError &err) | MBMesquite::PatchData | |
update_slave_node_coordinates(const size_t *elem_indices, size_t num_elem, MsqError &err) | MBMesquite::PatchData | |
vertAdjacencyArray | MBMesquite::PatchData | [private] |
vertAdjacencyOffsets | MBMesquite::PatchData | [private] |
vertex_by_index(size_t index) const | MBMesquite::PatchData | [inline] |
vertexArray | MBMesquite::PatchData | [private] |
vertexDomainDOF | MBMesquite::PatchData | [private] |
vertexHandlesArray | MBMesquite::PatchData | [private] |
vertexNormalIndices | MBMesquite::PatchData | [private] |
~PatchData() | MBMesquite::PatchData | |
