MOAB: Mesh Oriented datABase
(version 5.4.0)
00001 /* ***************************************************************** 00002 MESQUITE -- The Mesh Quality Improvement Toolkit 00003 00004 Copyright 2004 Sandia Corporation and Argonne National 00005 Laboratory. Under the terms of Contract DE-AC04-94AL85000 00006 with Sandia Corporation, the U.S. Government retains certain 00007 rights in this software. 00008 00009 This library is free software; you can redistribute it and/or 00010 modify it under the terms of the GNU Lesser General Public 00011 License as published by the Free Software Foundation; either 00012 version 2.1 of the License, or (at your option) any later version. 00013 00014 This library is distributed in the hope that it will be useful, 00015 but WITHOUT ANY WARRANTY; without even the implied warranty of 00016 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00017 Lesser General Public License for more details. 00018 00019 You should have received a copy of the GNU Lesser General Public License 00020 (lgpl.txt) along with this library; if not, write to the Free Software 00021 Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA 00022 00023 diachin2@llnl.gov, djmelan@sandia.gov, mbrewer@sandia.gov, 00024 pknupp@sandia.gov, tleurent@mcs.anl.gov, tmunson@mcs.anl.gov 00025 00026 ***************************************************************** */ 00027 // 00028 // AUTHOR: Thomas Leurent <tleurent@mcs.anl.gov> 00029 // ORG: Argonne National Laboratory 00030 // E-MAIL: tleurent@mcs.anl.gov 00031 // 00032 // ORIG-DATE: 15-Jan-03 at 08:05:56 00033 // LAST-MOD: 15-Jun-04 at 15:45:00 by Thomas Leurent 00034 // 00035 // DESCRIPTION: 00036 // ============ 00037 /*! 00038 \file FeasibleNewton.cpp 00039 \brief 00040 00041 Implements the FeasibleNewton class member functions. 00042 00043 \author Thomas Leurent 00044 \author Todd Munson 00045 \date 2003-01-15 00046 */ 00047 // DESCRIP-END. 00048 // 00049 00050 #include "FeasibleNewton.hpp" 00051 #include "MsqFreeVertexIndexIterator.hpp" 00052 #include "MsqDebug.hpp" 00053 #include "XYPlanarDomain.hpp" 00054 00055 using namespace MBMesquite; 00056 00057 std::string FeasibleNewton::get_name() const 00058 { 00059 return "FeasibleNewton"; 00060 } 00061 00062 PatchSet* FeasibleNewton::get_patch_set() 00063 { 00064 return PatchSetUser::get_patch_set(); 00065 } 00066 00067 FeasibleNewton::FeasibleNewton( ObjectiveFunction* of ) 00068 : VertexMover( of ), PatchSetUser( true ), convTol( 1e-6 ), coordsMem( 0 ), havePrintedDirectionMessage( false ) 00069 { 00070 TerminationCriterion* default_crit = get_inner_termination_criterion(); 00071 default_crit->add_absolute_gradient_L2_norm( 5e-5 ); 00072 } 00073 00074 void FeasibleNewton::initialize( PatchData& pd, MsqError& err ) 00075 { 00076 // Cannot do anything. Variable sizes with maximum size dependent 00077 // upon the entire MeshSet. 00078 coordsMem = pd.create_vertices_memento( err );MSQ_CHKERR( err ); 00079 havePrintedDirectionMessage = false; 00080 } 00081 00082 void FeasibleNewton::initialize_mesh_iteration( PatchData& pd, MsqError& /*err*/ ) 00083 { 00084 pd.reorder(); 00085 } 00086 00087 void FeasibleNewton::optimize_vertex_positions( PatchData& pd, MsqError& err ) 00088 { 00089 MSQ_FUNCTION_TIMER( "FeasibleNewton::optimize_vertex_positions" ); 00090 MSQ_DBGOUT( 2 ) << "\no Performing Feasible Newton optimization.\n"; 00091 00092 // 00093 // the only valid 2D meshes that FeasibleNewton works for are truly planar which 00094 // lie in the X-Y coordinate plane. 00095 // 00096 00097 XYPlanarDomain* xyPlanarDomainPtr = dynamic_cast< XYPlanarDomain* >( pd.get_domain() ); 00098 // only optimize if input mesh is a volume or an XYPlanarDomain 00099 if( !pd.domain_set() || xyPlanarDomainPtr != NULL ) 00100 { 00101 const double sigma = 1e-4; 00102 const double beta0 = 0.25; 00103 const double beta1 = 0.80; 00104 const double tol1 = 1e-8; 00105 const double tol2 = 1e-12; 00106 const double epsilon = 1e-10; 00107 double original_value, new_value; 00108 double beta; 00109 00110 int nv = pd.num_free_vertices(); 00111 std::vector< Vector3D > grad( nv ), d( nv ); 00112 bool fn_bool = true; // bool used for determining validity of patch 00113 00114 OFEvaluator& objFunc = get_objective_function_evaluator(); 00115 00116 int i; 00117 00118 // TODD -- Don't blame the code for bad things happening when using a 00119 // bad termination test or requesting more accuracy than is 00120 // possible. 00121 // 00122 // Also, 00123 00124 // 1. Allocate a hessian and calculate the sparsity pattern. 00125 mHessian.initialize( pd, err );MSQ_ERRRTN( err ); 00126 00127 // does the Feasible Newton iteration until stopping is required. 00128 // Terminate when inner termination criterion signals. 00129 00130 /* Computes the value of the stopping criterion*/ 00131 TerminationCriterion* term_crit = get_inner_termination_criterion(); 00132 while( !term_crit->terminate() ) 00133 { 00134 fn_bool = objFunc.update( pd, original_value, grad, mHessian, err );MSQ_ERRRTN( err ); 00135 if( !fn_bool ) 00136 { 00137 MSQ_SETERR( err ) 00138 ( "invalid patch for hessian calculation", MsqError::INTERNAL_ERROR ); 00139 return; 00140 } 00141 00142 if( MSQ_DBG( 3 ) ) 00143 { // avoid expensive norm calculations if debug flag is off 00144 MSQ_DBGOUT( 3 ) << " o objective function: " << original_value << std::endl; 00145 MSQ_DBGOUT( 3 ) << " o gradient norm: " << length( grad ) << std::endl; 00146 MSQ_DBGOUT( 3 ) << " o Hessian norm: " << mHessian.norm() << std::endl; 00147 } 00148 00149 // Prints out free vertices coordinates. 00150 // 00151 // Comment out the following because it is way to verbose for larger 00152 // problems. Consider doing: 00153 // inner_term_crit->write_mesh_steps( "filename.vtk" ); 00154 // instead. 00155 // - j.kraftcheck 2010-11-17 00156 // if (MSQ_DBG(3)) { 00157 // MSQ_DBGOUT(3) << "\n o Free vertices ("<< pd.num_free_vertices() 00158 // <<")original coordinates:\n "; 00159 // MSQ_ERRRTN(err); 00160 // const MsqVertex* toto1 = pd.get_vertex_array(err); MSQ_ERRRTN(err); 00161 // MsqFreeVertexIndexIterator ind1(pd, err); MSQ_ERRRTN(err); 00162 // ind1.reset(); 00163 // while (ind1.next()) { 00164 // MSQ_DBGOUT(3) << "\t\t\t" << toto1[ind1.value()]; 00165 // } 00166 // } 00167 00168 // 4. Calculate a direction using preconditionned conjugate gradients 00169 // to find a zero of the Newton system of equations (H*d = -g) 00170 // (a) stop if conjugate iteration limit reached 00171 // (b) stop if relative residual is small 00172 // (c) stop if direction of negative curvature is obtained 00173 00174 mHessian.cg_solver( arrptr( d ), arrptr( grad ), err );MSQ_ERRRTN( err ); 00175 00176 // 5. Check for descent direction (inner produce of gradient and 00177 // direction is negative. 00178 double alpha = inner( grad, d ); 00179 // TODD -- Add back in if you encounter problems -- do a gradient 00180 // step if the direction from the conjugate gradient solver 00181 // is not a descent direction for the objective function. We 00182 // SHOULD always get a descent direction from the conjugate 00183 // method though, unless the preconditioner is not positive 00184 // definite. 00185 // If direction is positive, does a gradient (steepest descent) step. 00186 00187 if( alpha > -epsilon ) 00188 { 00189 00190 MSQ_DBGOUT( 3 ) << " o alpha = " << alpha << " (rejected)" << std::endl; 00191 00192 if( !havePrintedDirectionMessage ) 00193 { 00194 MSQ_PRINT( 1 ) 00195 ( "Newton direction not guaranteed descent. Ensure preconditioner is positive " 00196 "definite.\n" ); 00197 havePrintedDirectionMessage = true; 00198 } 00199 00200 // TODD: removed performing gradient step here since we will use 00201 // gradient if step does not produce descent. Instead we set 00202 // alpha to a small negative value. 00203 00204 alpha = -epsilon; 00205 00206 // alpha = inner(grad, grad, nv); // compute norm squared of gradient 00207 // if (alpha < 1) alpha = 1; // take max with constant 00208 // for (i = 0; i < nv; ++i) { 00209 // d[i] = -grad[i] / alpha; // compute scaled gradient 00210 // } 00211 // alpha = inner(grad, d, nv); // recompute alpha 00212 // // equal to one for large gradient 00213 } 00214 else 00215 { 00216 MSQ_DBGOUT( 3 ) << " o alpha = " << alpha << std::endl; 00217 } 00218 00219 alpha *= sigma; 00220 beta = 1.0; 00221 pd.recreate_vertices_memento( coordsMem, err );MSQ_ERRRTN( err ); 00222 00223 // TODD: Unrolling the linesearch loop. We do a function and 00224 // gradient evaluation when beta = 1. Otherwise, we end up 00225 // in the linesearch regime. We expect that several 00226 // evaluations will be made, so we only do a function evaluation 00227 // and finish with a gradient evaluation. When beta = 1, we also 00228 // check the gradient for stability. 00229 00230 // TODD -- the Armijo linesearch is based on the objective function, 00231 // so theoretically we only need to evaluate the objective 00232 // function. However, near a very accurate solution, say with 00233 // the two norm of the gradient of the objective function less 00234 // than 1e-5, the numerical error in the objective function 00235 // calculation is enough that the Armijo linesearch will 00236 // fail. To correct this situation, the iterate is accepted 00237 // when the norm of the gradient is also small. If you need 00238 // high accuracy and have a large mesh, talk with Todd about 00239 // the numerical issues so that we can fix it. 00240 00241 // TODD -- the Armijo linesearch here is only good for differentiable 00242 // functions. When projections are involved, you should change 00243 // to a form of the linesearch meant for nondifferentiable 00244 // functions. 00245 00246 pd.move_free_vertices_constrained( arrptr( d ), nv, beta, err );MSQ_ERRRTN( err ); 00247 fn_bool = objFunc.evaluate( pd, new_value, grad, err ); 00248 if( err.error_code() == err.BARRIER_VIOLATED ) 00249 err.clear(); // barrier violated does not represent an actual error here 00250 MSQ_ERRRTN( err ); 00251 00252 if( ( fn_bool && ( original_value - new_value >= -alpha * beta - epsilon ) ) || 00253 ( fn_bool && ( length( arrptr( grad ), nv ) < 100 * convTol ) ) ) 00254 { 00255 // Armijo linesearch rules passed. 00256 MSQ_DBGOUT( 3 ) << " o beta = " << beta << " (accepted without line search)" << std::endl; 00257 } 00258 else 00259 { 00260 if( !fn_bool ) 00261 { 00262 // Function undefined. Use the higher decrease rate. 00263 beta *= beta0; 00264 MSQ_DBGOUT( 3 ) << " o beta = " << beta << " (invalid step)" << std::endl; 00265 } 00266 else 00267 { 00268 // Function defined, but not sufficient decrease 00269 // Use the lower decrease rate. 00270 beta *= beta1; 00271 MSQ_DBGOUT( 3 ) << " o beta = " << beta << " (insufficient decrease)" << std::endl; 00272 } 00273 pd.set_to_vertices_memento( coordsMem, err );MSQ_ERRRTN( err ); 00274 00275 // Standard Armijo linesearch rules 00276 00277 MSQ_DBGOUT( 3 ) << " o Doing line search" << std::endl; 00278 while( beta >= tol1 ) 00279 { 00280 // 6. Search along the direction 00281 // (a) trial = x + beta*d 00282 pd.move_free_vertices_constrained( arrptr( d ), nv, beta, err );MSQ_ERRRTN( err ); 00283 // (b) function evaluation 00284 fn_bool = objFunc.evaluate( pd, new_value, err ); 00285 if( err.error_code() == err.BARRIER_VIOLATED ) 00286 err.clear(); // barrier violated does not represent an actual error here 00287 MSQ_ERRRTN( err ); 00288 00289 // (c) check for sufficient decrease and stop 00290 if( !fn_bool ) 00291 { 00292 // function not defined at trial point 00293 beta *= beta0; 00294 } 00295 else if( original_value - new_value >= -alpha * beta - epsilon ) 00296 { 00297 // iterate is acceptable. 00298 break; 00299 } 00300 else 00301 { 00302 // iterate is not acceptable -- shrink beta 00303 beta *= beta1; 00304 } 00305 pd.set_to_vertices_memento( coordsMem, err );MSQ_ERRRTN( err ); 00306 } 00307 00308 if( beta < tol1 ) 00309 { 00310 // assert(pd.set_to_vertices_memento called last) 00311 00312 // TODD -- Lower limit on steplength reached. Direction does not 00313 // appear to make sufficient progress decreasing the 00314 // objective function. This can happen when you are 00315 // very near a solution due to numerical errors in 00316 // computing the objective function. It can also happen 00317 // when the direction is not a descent direction and when 00318 // you are projecting the iterates onto a surface. 00319 // 00320 // The latter cases require the use of a linesearch on 00321 // a gradient step. If this linesearch terminate with 00322 // insufficient decrease, then you are at a critical 00323 // point and should stop! 00324 // 00325 // The numerical errors with the objective function cannot 00326 // be overcome. Eventually, the gradient step will 00327 // fail to compute a new direction and you will stop. 00328 00329 MSQ_PRINT( 1 ) 00330 ( "Sufficient decrease not obtained in linesearch; switching to gradient.\n" ); 00331 00332 alpha = inner( arrptr( grad ), arrptr( grad ), 00333 nv ); // compute norm squared of gradient 00334 if( alpha < 1 ) alpha = 1; // take max with constant 00335 for( i = 0; i < nv; ++i ) 00336 { 00337 d[i] = -grad[i] / alpha; // compute scaled gradient 00338 } 00339 alpha = inner( arrptr( grad ), arrptr( d ), nv ); // recompute alpha 00340 alpha *= sigma; // equal to one for large gradient 00341 beta = 1.0; 00342 00343 // Standard Armijo linesearch rules 00344 while( beta >= tol2 ) 00345 { 00346 // 6. Search along the direction 00347 // (a) trial = x + beta*d 00348 pd.move_free_vertices_constrained( arrptr( d ), nv, beta, err );MSQ_ERRRTN( err ); 00349 // (b) function evaluation 00350 fn_bool = objFunc.evaluate( pd, new_value, err ); 00351 if( err.error_code() == err.BARRIER_VIOLATED ) 00352 err.clear(); // barrier violated does not represent an actual error 00353 // here 00354 MSQ_ERRRTN( err ); 00355 00356 // (c) check for sufficient decrease and stop 00357 if( !fn_bool ) 00358 { 00359 // function not defined at trial point 00360 beta *= beta0; 00361 } 00362 else if( original_value - new_value >= -alpha * beta - epsilon ) 00363 { 00364 // iterate is acceptable. 00365 break; 00366 } 00367 else 00368 { 00369 // iterate is not acceptable -- shrink beta 00370 beta *= beta1; 00371 } 00372 pd.set_to_vertices_memento( coordsMem, err );MSQ_ERRRTN( err ); 00373 } 00374 00375 if( beta < tol2 ) 00376 { 00377 // assert(pd.set_to_vertices_memento called last) 00378 00379 // TODD -- Lower limit on steplength reached. Gradient does not 00380 // appear to make sufficient progress decreasing the 00381 // objective function. This can happen when you are 00382 // very near a solution due to numerical errors in 00383 // computing the objective function. Most likely you 00384 // are at a critical point for the problem. 00385 00386 MSQ_PRINT( 1 ) 00387 ( "Sufficient decrease not obtained with gradient; critical point likely " 00388 "found.\n" ); 00389 break; 00390 } 00391 } 00392 00393 // Compute the gradient at the new point -- needed by termination check 00394 fn_bool = objFunc.update( pd, new_value, grad, err );MSQ_ERRRTN( err ); 00395 } 00396 00397 // Prints out free vertices coordinates. 00398 // if (MSQ_DBG(3)) { 00399 // MSQ_DBGOUT(3) << " o Free vertices new coordinates: \n"; 00400 // const MsqVertex* toto1 = pd.get_vertex_array(err); MSQ_ERRRTN(err); 00401 // MsqFreeVertexIndexIterator ind(pd, err); MSQ_ERRRTN(err); 00402 // ind.reset(); 00403 // while (ind.next()) { 00404 // MSQ_DBGOUT(3) << "\t\t\t" << toto1[ind.value()]; 00405 // } 00406 // } 00407 00408 // checks stopping criterion 00409 term_crit->accumulate_patch( pd, err );MSQ_ERRRTN( err ); 00410 term_crit->accumulate_inner( pd, new_value, arrptr( grad ), err );MSQ_ERRRTN( err ); 00411 } 00412 MSQ_PRINT( 2 )( "FINISHED\n" ); 00413 } 00414 else 00415 { 00416 std::cout << "WARNING: Feasible Newton optimization only supported for volume meshes" << std::endl 00417 << " and XYPlanarDomain surface meshes." << std::endl 00418 << std::endl 00419 << "Try a different solver such as Steepest Descent." << std::endl; 00420 } 00421 } 00422 00423 void FeasibleNewton::terminate_mesh_iteration( PatchData& /*pd*/, MsqError& /*err*/ ) 00424 { 00425 00426 // Michael:: Should the vertices memento be delete here??? 00427 // cout << "- Executing FeasibleNewton::iteration_complete()\n"; 00428 } 00429 00430 void FeasibleNewton::cleanup() 00431 { 00432 delete coordsMem; 00433 coordsMem = NULL; 00434 }
