MOAB: Mesh Oriented datABase
(version 5.4.0)
Vector3D is the object that effeciently stores the objective function Hessian each entry is a Matrix3D object (i.e. a vertex Hessian). More...
#include <MsqHessian.hpp>
Public Member Functions | |
MsqHessian () | |
~MsqHessian () | |
void | initialize (PatchData &pd, MsqError &err) |
creates a sparse structure for a Hessian, based on the connectivity information contained in the PatchData. Only the upper triangular part of the Hessian is stored. | |
void | initialize (const MsqHessian &other) |
void | zero_out () |
size_t | size () const |
void | get_diagonal_blocks (std::vector< Matrix3D > &diag, MsqError &err) const |
returns the diagonal blocks, memory must be allocated before call. | |
Matrix3D * | get_block (size_t i, size_t j) |
const Matrix3D * | get_block (size_t i, size_t j) const |
void | compute_preconditioner (MsqError &err) |
void | apply_preconditioner (Vector3D zloc[], Vector3D rloc[], MsqError &err) |
void | cg_solver (Vector3D x[], Vector3D b[], MsqError &err) |
void | product (Vector3D *r, const Vector3D *x) const |
r = this * x, where r and x are arrays of length size(). | |
void | add (size_t row, size_t col, const Matrix3D &m, MsqError &err) |
void | scale (double value) |
void | add (const MsqHessian &other) |
void | clear () |
double | norm () const |
Frobenius norm. | |
Protected Attributes | |
Matrix3D * | mEntries |
CSR block entries. size: nb of nonzero blocks, i.e. mRowStart[mSize] . | |
size_t * | mRowStart |
start of each row in mEntries. size: nb of vertices (mSize). | |
size_t * | mColIndex |
CSR block structure: column indexes of the row entries. | |
size_t | mSize |
number of rows (or number of columns, this is a square matrix). | |
Matrix3D * | mPreconditioner |
size_t | precondArraySize |
Vector3D * | mR |
array used in the CG solver | |
Vector3D * | mZ |
Vector3D * | mP |
Vector3D * | mW |
size_t | cgArraySizes |
size of arrays allocated in the CG solver. | |
size_t | maxCGiter |
max nb of iterations of the CG solver. | |
Private Member Functions | |
MsqHessian & | operator= (const MsqHessian &h) |
MsqHessian (const MsqHessian ©) | |
Friends | |
void | axpy (Vector3D res[], size_t size_r, const MsqHessian &H, const Vector3D x[], size_t size_x, const Vector3D y[], size_t size_y, MsqError &err) |
Hessian - vector product, summed with a second vector (optional). | |
std::ostream & | operator<< (std::ostream &, const MsqHessian &) |
Prints out the MsqHessian blocks. |
Definition at line 68 of file MsqHessian.hpp.
Definition at line 54 of file MsqHessian.cpp.
: mEntries( 0 ), mRowStart( 0 ), mColIndex( 0 ), mSize( 0 ), mPreconditioner( 0 ), precondArraySize( 0 ), mR( 0 ), mZ( 0 ), mP( 0 ), mW( 0 ), cgArraySizes( 0 ), maxCGiter( 50 ) { }
MBMesquite::MsqHessian::MsqHessian | ( | const MsqHessian & | copy | ) | [private] |
void MBMesquite::MsqHessian::add | ( | size_t | row, |
size_t | col, | ||
const Matrix3D & | m, | ||
MsqError & | err | ||
) | [inline] |
Accumulates entries of an element hessian into an objective function hessian. Make sure to use zero_out() before starting the accumulation process.
pd,: | PatchData in that contains the element which Hessian we are accumulating in the Hessian matrix. This must be the same PatchData that was used in MsqHessian::initialize(). |
elem_index,: | index of the element in the PatchData. |
mat3d_array,: | This is the upper triangular part of the element Hessian for all nodes, including fixed nodes, for which the entries must be null Matrix3Ds. |
nb_mat3d. | The size of the mat3d_array: (n+1)n/2, where n is the number of nodes in the element. |
Definition at line 219 of file MsqHessian.hpp.
References MBMesquite::MsqError::INVALID_ARG, mColIndex, mEntries, mRowStart, MSQ_SETERR, and MBMesquite::Matrix3D::plus_transpose_equal().
Referenced by MBMesquite::PatchPowerMeanP::evaluate_with_Hessian(), MBMesquite::CompositeOFAdd::evaluate_with_Hessian(), MBMesquite::LPtoPTemplate::evaluate_with_Hessian(), and MBMesquite::PMeanPTemplate::evaluate_with_Hessian().
{ if( row <= col ) { for( size_t i = mRowStart[row]; i != mRowStart[row + 1]; ++i ) if( mColIndex[i] == col ) { mEntries[i] += m; return; } } else { for( size_t i = mRowStart[col]; i != mRowStart[col + 1]; ++i ) if( mColIndex[i] == row ) { mEntries[i].plus_transpose_equal( m ); return; } } MSQ_SETERR( err ) ( MsqError::INVALID_ARG, "Hessian entry (%lu,%lu) does not exist.", (unsigned long)row, (unsigned long)col ); }
void MBMesquite::MsqHessian::add | ( | const MsqHessian & | other | ) |
Definition at line 407 of file MsqHessian.cpp.
void MBMesquite::MsqHessian::apply_preconditioner | ( | Vector3D | zloc[], |
Vector3D | rloc[], | ||
) | [inline] |
Computes \( z=M^{-1}r \) .
Definition at line 316 of file MsqHessian.hpp.
References mPreconditioner, and mSize.
Referenced by cg_solver().
{ size_t m; for( m = 0; m < mSize; ++m ) { #ifdef DIAGONAL_PRECONDITIONER // preconditioner is identity matrix for now. zloc[m][0] = mPreconditioner[m][0][0] * rloc[m][0]; zloc[m][1] = mPreconditioner[m][1][1] * rloc[m][1]; zloc[m][2] = mPreconditioner[m][2][2] * rloc[m][2]; #else // z = inv(L^T) * r zloc[m][0] = rloc[m][0]; zloc[m][1] = rloc[m][1] - mPreconditioner[m][0][1] * zloc[m][0]; zloc[m][2] = rloc[m][2] - mPreconditioner[m][0][2] * zloc[m][0] - mPreconditioner[m][1][2] * zloc[m][1]; // z = inv(D) * z zloc[m][0] *= mPreconditioner[m][0][0]; zloc[m][1] *= mPreconditioner[m][1][1]; zloc[m][2] *= mPreconditioner[m][2][2]; // z = inv(L) * z zloc[m][2] = zloc[m][2]; zloc[m][1] = zloc[m][1] - mPreconditioner[m][1][2] * zloc[m][2]; zloc[m][0] = zloc[m][0] - mPreconditioner[m][0][1] * zloc[m][1] - mPreconditioner[m][0][2] * zloc[m][2]; #endif } }
void MBMesquite::MsqHessian::cg_solver | ( | Vector3D | x[], |
Vector3D | b[], | ||
uses the preconditionned conjugate gradient algebraic solver to find d in \( H * d = -g \) .
x | : the solution, usually the descent direction d. |
b | : -b will be the right hand side. Usually b is the gradient. |
Definition at line 522 of file MsqHessian.cpp.
References apply_preconditioner(), axpy, beta, cgArraySizes, compute_preconditioner(), MBMesquite::inner(), MBMesquite::length(), maxCGiter, mP, mR, mSize, MSQ_CHKERR, MSQ_FUNCTION_TIMER, mW, and mZ.
Referenced by MBMesquite::FeasibleNewton::optimize_vertex_positions().
{ MSQ_FUNCTION_TIMER( "MsqHessian::cg_solver" ); // reallocates arrays if size of the Hessian has changed too much. if( mSize > cgArraySizes || mSize < cgArraySizes / 10 ) { delete[] mR; delete[] mZ; delete[] mP; delete[] mW; mR = new Vector3D[mSize]; mZ = new Vector3D[mSize]; mP = new Vector3D[mSize]; mW = new Vector3D[mSize]; cgArraySizes = mSize; } size_t i; double alpha_, alpha, beta; double cg_tol = 1e-2; // 1e-2 will give a reasonably good solution (~1%). double norm_g = length( b, mSize ); double norm_r = norm_g; double rzm1; // r^T_{k-1} z_{k-1} double rzm2; // r^T_{k-2} z_{k-2} this->compute_preconditioner( err );MSQ_CHKERR( err ); // get M^{-1} for diagonal blocks for( i = 0; i < mSize; ++i ) x[i] = 0.; for( i = 0; i < mSize; ++i ) mR[i] = -b[i]; // r = -b because x_0 = 0 and we solve H*x = -b norm_g *= cg_tol; this->apply_preconditioner( mZ, mR, err ); // solve Mz = r (computes z = M^-1 r) for( i = 0; i < mSize; ++i ) mP[i] = mZ[i]; // p_1 = z_0 rzm1 = inner( mZ, mR, mSize ); // inner product r_{k-1}^T z_{k-1} size_t cg_iter = 0; while( ( norm_r > norm_g ) && ( cg_iter < maxCGiter ) ) { ++cg_iter; axpy( mW, mSize, *this, mP, mSize, 0, 0, err ); // w = A * p_k alpha_ = inner( mP, mW, mSize ); // alpha_ = p_k^T A p_k if( alpha_ <= 0.0 ) { if( 1 == cg_iter ) { for( i = 0; i < mSize; ++i ) x[i] += mP[i]; // x_{k+1} = x_k + p_{k+1} } break; // Newton goes on with this direction of negative curvature } alpha = rzm1 / alpha_; for( i = 0; i < mSize; ++i ) x[i] += alpha * mP[i]; // x_{k+1} = x_k + alpha_{k+1} p_{k+1} for( i = 0; i < mSize; ++i ) mR[i] -= alpha * mW[i]; // r_{k+1} = r_k - alpha_{k+1} A p_{k+1} norm_r = length( mR, mSize ); this->apply_preconditioner( mZ, mR, err ); // solve Mz = r (computes z = M^-1 r) rzm2 = rzm1; rzm1 = inner( mZ, mR, mSize ); // inner product r_{k-1}^T z_{k-1} beta = rzm1 / rzm2; for( i = 0; i < mSize; ++i ) mP[i] = mZ[i] + beta * mP[i]; // p_k = z_{k-1} + Beta_k * p_{k-1} } }
void MBMesquite::MsqHessian::clear | ( | ) |
Definition at line 65 of file MsqHessian.cpp.
References cgArraySizes, mColIndex, mEntries, mP, mPreconditioner, mR, mRowStart, mSize, mW, mZ, and precondArraySize.
Referenced by MBMesquite::TrustRegion::cleanup(), and ~MsqHessian().
{ mSize = precondArraySize = cgArraySizes = 0; delete[] mEntries; mEntries = 0; delete[] mRowStart; mRowStart = 0; delete[] mColIndex; mColIndex = 0; delete[] mPreconditioner; mPreconditioner = 0; delete[] mR; mR = 0; delete[] mZ; mZ = 0; delete[] mP; mP = 0; delete[] mW; mW = 0; }
void MBMesquite::MsqHessian::compute_preconditioner | ( | MsqError & | err | ) |
compute a preconditioner used in the preconditioned conjugate gradient algebraic solver. In fact, this computes \( M^{-1} \) .
Definition at line 434 of file MsqHessian.cpp.
References mEntries, mPreconditioner, mRowStart, mSize, precondArraySize, and moab::sum().
Referenced by cg_solver(), and MsqHessianTest::test_cholesky_preconditioner().
{ // reallocates arrays if size of the Hessian has changed too much. if( mSize > precondArraySize || mSize < precondArraySize / 10 ) { delete[] mPreconditioner; mPreconditioner = new Matrix3D[mSize]; } Matrix3D* diag_block; double sum, tmp; size_t m; // For each diagonal block, the (inverted) preconditioner is // the inverse of the sum of the diagonal entries. for( m = 0; m < mSize; ++m ) { diag_block = mEntries + mRowStart[m]; // Gets block at position m,m . #if !DIAGONAL_PRECONDITIONER // calculate LDL^T factorization of the diagonal block // L = [1 pre[0][1] pre[0][2]] // [0 1 pre[1][2]] // [0 0 1 ] // inv(D) = [pre[0][0] 0 0 ] // [0 pre[1][1] 0 ] // [0 0 pre[2][2]] // If the first method of calculating a preconditioner fails, // use the diagonal method. bool use_diag = false; if( fabs( ( *diag_block )[0][0] ) < DBL_EPSILON ) { use_diag = true; } else { mPreconditioner[m][0][0] = 1.0 / ( *diag_block )[0][0]; mPreconditioner[m][0][1] = ( *diag_block )[0][1] * mPreconditioner[m][0][0]; mPreconditioner[m][0][2] = ( *diag_block )[0][2] * mPreconditioner[m][0][0]; sum = ( ( *diag_block )[1][1] - ( *diag_block )[0][1] * mPreconditioner[m][0][1] ); if( fabs( sum ) <= DBL_EPSILON ) use_diag = true; else { mPreconditioner[m][1][1] = 1.0 / sum; tmp = ( *diag_block )[1][2] - ( *diag_block )[0][2] * mPreconditioner[m][0][1]; mPreconditioner[m][1][2] = mPreconditioner[m][1][1] * tmp; sum = ( ( *diag_block )[2][2] - ( *diag_block )[0][2] * mPreconditioner[m][0][2] - mPreconditioner[m][1][2] * tmp ); if( fabs( sum ) <= DBL_EPSILON ) use_diag = true; else mPreconditioner[m][2][2] = 1.0 / sum; } } if( use_diag ) #endif { // Either this is a fixed vertex or the diagonal block is not // invertible. Switch to the diagonal preconditioner in this // case. sum = ( *diag_block )[0][0] + ( *diag_block )[1][1] + ( *diag_block )[2][2]; if( fabs( sum ) > DBL_EPSILON ) sum = 1 / sum; else sum = 0.0; mPreconditioner[m][0][0] = sum; mPreconditioner[m][0][1] = 0.0; mPreconditioner[m][0][2] = 0.0; mPreconditioner[m][1][1] = sum; mPreconditioner[m][1][2] = 0.0; mPreconditioner[m][2][2] = sum; } } }
Matrix3D * MBMesquite::MsqHessian::get_block | ( | size_t | i, |
size_t | j | ||
) | [inline] |
Returns a pointer to the Matrix3D block at position i,j if it exist. Returns the NULL pointer if position i,j (0-based) is a NULL entry. Note that block i,j must be in the upper triangular part of the (symetric) hessian.
Definition at line 350 of file MsqHessian.hpp.
References mColIndex, mEntries, mRowStart, and mSize.
Referenced by ObjectiveFunctionTests::compare_hessian_diagonal(), ObjectiveFunctionTests::compare_numerical_hessian(), MBMesquite::TrustRegion::compute_preconditioner(), MBMesquite::ObjectiveFunction::evaluate_with_Hessian_diagonal(), get_block(), CompositeOFTest::test_add_hessian(), ObjectiveFunctionTest::test_compute_ana_hessian_tet(), ObjectiveFunctionTest::test_compute_ana_hessian_tet_scaled(), PMeanPTemplateTest::test_Hessian(), ObjectiveFunctionTests::test_negate_flag(), CompositeOFTest::test_scalar_add_hessian(), and CompositeOFTest::test_scalar_multiply_hessian().
const Matrix3D * MBMesquite::MsqHessian::get_block | ( | size_t | i, |
size_t | j | ||
) | const [inline] |
Definition at line 364 of file MsqHessian.hpp.
References get_block().
{ return const_cast< MsqHessian* >( this )->get_block( i, j ); }
void MBMesquite::MsqHessian::get_diagonal_blocks | ( | std::vector< Matrix3D > & | diag, |
) | const |
diag | is an STL vector of size MsqHessian::size() . |
Definition at line 417 of file MsqHessian.cpp.
void MBMesquite::MsqHessian::initialize | ( | PatchData & | pd, |
Definition at line 92 of file MsqHessian.cpp.
References MBMesquite::PatchData::get_element_array(), MBMesquite::MsqMeshEntity::get_vertex_index_array(), MBMesquite::MsqError::INVALID_ARG, mColIndex, mEntries, mRowStart, mSize, MSQ_CHKERR, MSQ_FUNCTION_TIMER, MSQ_SETERR, MBMesquite::MsqMeshEntity::node_count(), MBMesquite::PatchData::num_elements(), and MBMesquite::PatchData::num_free_vertices().
Referenced by ObjectiveFunctionTests::compare_hessian_diagonal(), ObjectiveFunctionTests::compare_hessian_gradient(), ObjectiveFunctionTests::compare_numerical_hessian(), ObjectiveFunctionTests::evaluate_internal(), MBMesquite::CompositeOFAdd::evaluate_with_Hessian(), MBMesquite::ObjectiveFunction::evaluate_with_Hessian_diagonal(), CompositeOFTest::get_hessians(), MBMesquite::TrustRegion::optimize_vertex_positions(), MBMesquite::FeasibleNewton::optimize_vertex_positions(), ObjectiveFunctionTest::test_compute_ana_hessian_tet(), ObjectiveFunctionTest::test_compute_ana_hessian_tet_scaled(), ObjectiveFunctionTests::test_handles_invalid_qm(), ObjectiveFunctionTests::test_handles_qm_error(), PMeanPTemplateTest::test_Hessian(), StdDevTemplateTest::test_hessian_fails(), StdDevTemplateTest::test_hessian_fails_sqr(), CompositeOFTest::test_multiply_hessian(), and ObjectiveFunctionTests::test_negate_flag().
{ MSQ_FUNCTION_TIMER( "MsqHession::initialize" ); delete[] mEntries; delete[] mRowStart; delete[] mColIndex; size_t num_vertices = pd.num_free_vertices(); size_t num_elements = pd.num_elements(); size_t const* vtx_list; size_t e, r, rs, re, c, cs, ce, nz, nnz, nve, i, j; MsqMeshEntity* patchElemArray = pd.get_element_array( err );MSQ_CHKERR( err ); if( num_vertices == 0 ) { MSQ_SETERR( err )( "No vertices in PatchData", MsqError::INVALID_ARG ); return; } mSize = num_vertices; // Calculate the offsets for a CSC representation of the accumulation // pattern. size_t* col_start = new size_t[num_vertices + 1]; // mAccumElemStart = new size_t[num_elements+1]; // mAccumElemStart[0] = 0; for( i = 0; i < num_vertices; ++i ) { col_start[i] = 0; } for( e = 0; e < num_elements; ++e ) { nve = patchElemArray[e].node_count(); vtx_list = patchElemArray[e].get_vertex_index_array(); int nfe = 0; for( i = 0; i < nve; ++i ) { r = vtx_list[i]; if( r < num_vertices ) ++nfe; for( j = i; j < nve; ++j ) { c = vtx_list[j]; if( r <= c ) { if( c < num_vertices ) ++col_start[c]; } else { if( r < num_vertices ) ++col_start[r]; } } } // mAccumElemStart[e+1] = mAccumElemStart[e] + (nfe+1)*nfe/2; } nz = 0; for( i = 0; i < num_vertices; ++i ) { j = col_start[i]; col_start[i] = nz; nz += j; } col_start[i] = nz; // Finished putting matrix into CSC representation int* row_instr = new int[5 * nz]; size_t* row_index = new size_t[nz]; nz = 0; for( e = 0; e < num_elements; ++e ) { nve = patchElemArray[e].node_count(); vtx_list = patchElemArray[e].get_vertex_index_array(); for( i = 0; i < nve; ++i ) { r = vtx_list[i]; for( j = i; j < nve; ++j ) { c = vtx_list[j]; if( r <= c ) { if( c < num_vertices ) { row_index[col_start[c]] = r; row_instr[col_start[c]] = nz++; ++col_start[c]; } } else { if( r < num_vertices ) { row_index[col_start[r]] = c; // can't use -nz, but can negate row_instr[col_start[r]] row_instr[col_start[r]] = nz++; row_instr[col_start[r]] = -row_instr[col_start[r]]; ++col_start[r]; } } } } } for( i = num_vertices - 1; i > 0; --i ) { col_start[i + 1] = col_start[i]; } col_start[1] = col_start[0]; col_start[0] = 0; // cout << "col_start: "; // for (int t=0; t<num_vertices+1; ++t) // cout << col_start[t] << " "; // cout << endl; // cout << "row_index: "; // for (int t=0; t<nz; ++t) // cout << row_index[t] << " "; // cout << endl; // cout << "row_instr: "; // for (int t=0; t<nz; ++t) // cout << row_instr[t] << " "; // cout << endl; // Convert CSC to CSR // First calculate the offsets in the row size_t* row_start = new size_t[num_vertices + 1]; for( i = 0; i < num_vertices; ++i ) { row_start[i] = 0; } for( i = 0; i < nz; ++i ) { ++row_start[row_index[i]]; } nz = 0; for( i = 0; i < num_vertices; ++i ) { j = row_start[i]; row_start[i] = nz; nz += j; } row_start[i] = nz; // Now calculate the pattern size_t* col_index = new size_t[nz]; int* col_instr = new int[nz]; for( i = 0; i < num_vertices; ++i ) { cs = col_start[i]; ce = col_start[i + 1]; while( cs < ce ) { r = row_index[cs]; col_index[row_start[r]] = i; col_instr[row_start[r]] = row_instr[cs]; ++row_start[r]; ++cs; } } for( i = num_vertices - 1; i > 0; --i ) { row_start[i + 1] = row_start[i]; } row_start[1] = row_start[0]; row_start[0] = 0; delete[] row_index; // Now that the matrix is CSR // Column indices for each row are sorted // Compaction -- count the number of nonzeros mRowStart = col_start; // don't need to reallocate // mAccumulation = row_instr; // don't need to reallocate delete[] row_instr; for( i = 0; i <= num_vertices; ++i ) { mRowStart[i] = 0; } nnz = 0; for( i = 0; i < num_vertices; ++i ) { rs = row_start[i]; re = row_start[i + 1]; c = num_vertices; while( rs < re ) { if( c != col_index[rs] ) { // This is an unseen nonzero c = col_index[rs]; ++mRowStart[i]; ++nnz; } // if (col_instr[rs] >= 0) { // mAccumulation[col_instr[rs]] = nnz - 1; //} // else { // mAccumulation[-col_instr[rs]] = 1 - nnz; //} ++rs; } } nnz = 0; for( i = 0; i < num_vertices; ++i ) { j = mRowStart[i]; mRowStart[i] = nnz; nnz += j; } mRowStart[i] = nnz; delete[] col_instr; // Fill in the compacted hessian matrix mColIndex = new size_t[nnz]; for( i = 0; i < num_vertices; ++i ) { rs = row_start[i]; re = row_start[i + 1]; c = num_vertices; while( rs < re ) { if( c != col_index[rs] ) { // This is an unseen nonzero c = col_index[rs]; mColIndex[mRowStart[i]] = c; mRowStart[i]++; } ++rs; } } for( i = num_vertices - 1; i > 0; --i ) { mRowStart[i + 1] = mRowStart[i]; } mRowStart[1] = mRowStart[0]; mRowStart[0] = 0; delete[] row_start; delete[] col_index; mEntries = new Matrix3D[nnz]; // On Solaris, no initializer allowed for new of an array for( i = 0; i < nnz; ++i ) mEntries[i] = 0.; // so we initialize all entries manually. // origin_pd = &pd; return; }
void MBMesquite::MsqHessian::initialize | ( | const MsqHessian & | other | ) |
Definition at line 376 of file MsqHessian.cpp.
{ if( !other.mSize ) { delete[] mEntries; delete[] mRowStart; delete[] mColIndex; mEntries = 0; mRowStart = 0; mColIndex = 0; mSize = 0; return; } if( mSize != other.mSize || mRowStart[mSize] != other.mRowStart[mSize] ) { delete[] mEntries; delete[] mRowStart; delete[] mColIndex; mSize = other.mSize; mRowStart = new size_t[mSize + 1]; mEntries = new Matrix3D[other.mRowStart[mSize]]; mColIndex = new size_t[other.mRowStart[mSize]]; } memcpy( mRowStart, other.mRowStart, sizeof( size_t ) * ( mSize + 1 ) ); memcpy( mColIndex, other.mColIndex, sizeof( size_t ) * mRowStart[mSize] ); }
double MBMesquite::MsqHessian::norm | ( | ) | const [inline] |
Frobenius norm.
Definition at line 146 of file MsqHessian.hpp.
References MBMesquite::Frobenius_2(), mEntries, mRowStart, mSize, and moab::sum().
{ double sum = 0.0; for( size_t i = 0; i < mRowStart[mSize]; ++i ) sum += Frobenius_2( mEntries[i] ); return sqrt( sum ); }
MsqHessian& MBMesquite::MsqHessian::operator= | ( | const MsqHessian & | h | ) | [private] |
void MBMesquite::MsqHessian::product | ( | Vector3D * | r, |
const Vector3D * | x | ||
) | const |
Definition at line 597 of file MsqHessian.cpp.
References mColIndex, mEntries, mRowStart, MBMesquite::plusEqAx(), MBMesquite::plusEqTransAx(), and size().
Referenced by MBMesquite::TrustRegion::optimize_vertex_positions().
{ // zero output array memset( v, 0, size() * sizeof( *v ) ); // for each row const Matrix3D* m_iter = mEntries; const size_t* c_iter = mColIndex; for( size_t r = 0; r < size(); ++r ) { // diagonal entry plusEqAx( v[r], *m_iter, x[r] ); ++m_iter; ++c_iter; // off-diagonal entires for( size_t c = mRowStart[r] + 1; c != mRowStart[r + 1]; ++c ) { plusEqAx( v[r], *m_iter, x[*c_iter] ); plusEqTransAx( v[*c_iter], *m_iter, x[r] ); ++m_iter; ++c_iter; } } }
void MBMesquite::MsqHessian::scale | ( | double | value | ) | [inline] |
Definition at line 168 of file MsqHessian.hpp.
References mEntries, mRowStart, and mSize.
Referenced by MBMesquite::PatchPowerMeanP::evaluate_with_Hessian(), MBMesquite::CompositeOFScalarMultiply::evaluate_with_Hessian(), MBMesquite::LPtoPTemplate::evaluate_with_Hessian(), and MBMesquite::PMeanPTemplate::evaluate_with_Hessian().
size_t MBMesquite::MsqHessian::size | ( | ) | const [inline] |
Definition at line 96 of file MsqHessian.hpp.
Referenced by ObjectiveFunctionTests::compare_hessian_diagonal(), MBMesquite::TrustRegion::compute_preconditioner(), MBMesquite::ObjectiveFunction::evaluate_with_Hessian_diagonal(), get_diagonal_blocks(), product(), CompositeOFTest::test_add_hessian(), PMeanPTemplateTest::test_Hessian(), ObjectiveFunctionTests::test_negate_flag(), CompositeOFTest::test_scalar_add_hessian(), and CompositeOFTest::test_scalar_multiply_hessian().
{ return mSize; }
void MBMesquite::MsqHessian::zero_out | ( | ) | [inline] |
Sets all Hessian entries to zero. This is usually used before starting to accumulate elements hessian in the objective function hessian.
Definition at line 157 of file MsqHessian.hpp.
References mEntries, mRowStart, mSize, and MBMesquite::Matrix3D::zero().
Referenced by MBMesquite::PatchPowerMeanP::evaluate_with_Hessian(), MBMesquite::LPtoPTemplate::evaluate_with_Hessian(), MBMesquite::PMeanPTemplate::evaluate_with_Hessian(), and MsqHessianTest::test_cholesky_preconditioner().
void axpy | ( | Vector3D | res[], |
size_t | size_r, | ||
const MsqHessian & | H, | ||
const Vector3D | x[], | ||
size_t | size_x, | ||
const Vector3D | y[], | ||
size_t | size_y, | ||
) | [friend] |
res,: | array of Vector3D in which the result is stored. |
size_r,: | size of the res array. |
x,: | vector multiplied by the Hessian. |
size_x,: | size of the x array. |
y,: | vector added to the Hessian vector product. Set to 0 (NULL) if not needed. |
size_y,: | size of the y array. Set to 0 if not needed. |
Definition at line 252 of file MsqHessian.hpp.
{ if( ( size_r != H.mSize ) || ( size_x != H.mSize ) || ( size_y != H.mSize && size_y != 0 ) ) { // throw an error } Vector3D tmpx, tmpm; // for cache opt. size_t* col = H.mColIndex; const size_t nn = H.mSize; size_t rl; // row length size_t el; // entries index size_t lo; size_t c; // column index size_t i, j; if( y != 0 ) { for( i = 0; i < nn; ++i ) { res[i] = y[i]; } } else { // y == 0 for( i = 0; i < nn; ++i ) { res[i] = 0.; } } el = 0; for( i = 0; i < nn; ++i ) { rl = H.mRowStart[i + 1] - H.mRowStart[i]; lo = *col++; // Diagonal entry tmpx = x[i]; eqAx( tmpm, H.mEntries[el], tmpx ); ++el; // Non-diagonal entries for( j = 1; j < rl; ++j ) { c = *col++; // res[i] += H.mEntries[e] * x[c]; plusEqAx( tmpm, H.mEntries[el], x[c] ); // res[c] += transpose(H.mEntries[e]) * tmpxi; plusEqTransAx( res[c], H.mEntries[el], tmpx ); ++el; } res[lo] += tmpm; } }
std::ostream& operator<< | ( | std::ostream & | , |
const MsqHessian & | |||
) | [friend] |
Definition at line 627 of file MsqHessian.cpp.
{ size_t i, j; s << "MsqHessian of size: " << h.mSize << "x" << h.mSize << "\n"; for( i = 0; i < h.mSize; ++i ) { s << " ROW " << i << " ------------------------\n"; for( j = h.mRowStart[i]; j < h.mRowStart[i + 1]; ++j ) { s << " column " << h.mColIndex[j] << " ----\n"; s << h.mEntries[j]; } } return s; }
size_t MBMesquite::MsqHessian::cgArraySizes [protected] |
Definition at line 84 of file MsqHessian.hpp.
Referenced by cg_solver(), and clear().
size_t MBMesquite::MsqHessian::maxCGiter [protected] |
Definition at line 85 of file MsqHessian.hpp.
size_t* MBMesquite::MsqHessian::mColIndex [protected] |
Definition at line 73 of file MsqHessian.hpp.
Referenced by add(), MBMesquite::axpy(), clear(), get_block(), initialize(), MBMesquite::operator<<(), and product().
Matrix3D* MBMesquite::MsqHessian::mEntries [protected] |
Definition at line 71 of file MsqHessian.hpp.
Referenced by add(), MBMesquite::axpy(), clear(), compute_preconditioner(), get_block(), get_diagonal_blocks(), initialize(), norm(), MBMesquite::operator<<(), product(), scale(), and zero_out().
Vector3D* MBMesquite::MsqHessian::mP [protected] |
Definition at line 82 of file MsqHessian.hpp.
Matrix3D* MBMesquite::MsqHessian::mPreconditioner [protected] |
Definition at line 77 of file MsqHessian.hpp.
Referenced by apply_preconditioner(), clear(), and compute_preconditioner().
Vector3D* MBMesquite::MsqHessian::mR [protected] |
Definition at line 80 of file MsqHessian.hpp.
size_t* MBMesquite::MsqHessian::mRowStart [protected] |
Definition at line 72 of file MsqHessian.hpp.
size_t MBMesquite::MsqHessian::mSize [protected] |
Definition at line 75 of file MsqHessian.hpp.
Referenced by add(), apply_preconditioner(), MBMesquite::axpy(), cg_solver(), clear(), compute_preconditioner(), get_block(), initialize(), norm(), MBMesquite::operator<<(), scale(), and zero_out().
Vector3D* MBMesquite::MsqHessian::mW [protected] |
Definition at line 83 of file MsqHessian.hpp.
Vector3D* MBMesquite::MsqHessian::mZ [protected] |
Definition at line 81 of file MsqHessian.hpp.
size_t MBMesquite::MsqHessian::precondArraySize [protected] |
Definition at line 78 of file MsqHessian.hpp.
Referenced by clear(), and compute_preconditioner().
