MOAB: Mesh Oriented datABase
(version 5.3.1)
00001 /* ***************************************************************** 00002 MESQUITE -- The Mesh Quality Improvement Toolkit 00003 00004 Copyright 2004 Sandia Corporation and Argonne National 00005 Laboratory. Under the terms of Contract DE-AC04-94AL85000 00006 with Sandia Corporation, the U.S. Government retains certain 00007 rights in this software. 00008 00009 This library is free software; you can redistribute it and/or 00010 modify it under the terms of the GNU Lesser General Public 00011 License as published by the Free Software Foundation; either 00012 version 2.1 of the License, or (at your option) any later version. 00013 00014 This library is distributed in the hope that it will be useful, 00015 but WITHOUT ANY WARRANTY; without even the implied warranty of 00016 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00017 Lesser General Public License for more details. 00018 00019 You should have received a copy of the GNU Lesser General Public License 00020 (lgpl.txt) along with this library; if not, write to the Free Software 00021 Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA 00022 00023 diachin2@llnl.gov, djmelan@sandia.gov, mbrewer@sandia.gov, 00024 pknupp@sandia.gov, tleurent@mcs.anl.gov, tmunson@mcs.anl.gov 00025 00026 ***************************************************************** */ 00027 00028 /*! \file MsqMeshEntity.hpp 00029 00030 \author Darryl Melander 00031 \author Thomas Leurent 00032 \author Michael Brewer 00033 00034 */ 00035 00036 #ifndef MSQMESHENTITY_HPP 00037 #define MSQMESHENTITY_HPP 00038 00039 #include "Mesquite.hpp" 00040 #include "TopologyInfo.hpp" 00041 #include "Vector3D.hpp" 00042 #include "NodeSet.hpp" 00043 #include "Sample.hpp" 00044 00045 #include <vector> 00046 #include <cstring> 00047 #include <cassert> 00048 00049 namespace MBMesquite 00050 { 00051 class PatchData; 00052 class MsqVertex; 00053 00054 /*! 00055 \class MsqMeshEntity 00056 \brief MsqMeshEntity is the Mesquite object that stores information about 00057 the elements in the mesh. 00058 00059 00060 */ 00061 class MESQUITE_EXPORT MsqMeshEntity 00062 { 00063 public: 00064 MsqMeshEntity() : mType( MIXED ), vertexIndices( 0 ), numVertexIndices( 0 ) {} 00065 00066 //! Returns element type 00067 inline EntityTopology get_element_type() const 00068 { 00069 return mType; 00070 } 00071 00072 //! Returns the number of vertices in this element, 00073 //! based on its element type. 00074 inline std::size_t vertex_count() const; 00075 //! Return number of nodes in element (number of corner 00076 //! vertices + number of higher-order nodes). 00077 inline std::size_t node_count() const 00078 { 00079 return numVertexIndices; 00080 } 00081 //! Returns number of target matrices for this element type 00082 inline std::size_t corner_count() const 00083 { 00084 return mType == PYRAMID ? 4 : vertex_count(); 00085 } 00086 00087 //! gets the vertices of the mesh entity 00088 void get_vertex_indices( std::vector< std::size_t >& vertex_list ) const; 00089 void append_vertex_indices( std::vector< std::size_t >& vertex_list ) const; 00090 size_t get_local_matrix_map_about_vertex( PatchData& pd, MsqVertex* vert, size_t local_map_size, int* local_map, 00091 MsqError& err ) const; 00092 //! gets the vertices of the mesh entity 00093 void get_node_indices( std::vector< std::size_t >& vertex_list ) const; 00094 void append_node_indices( std::vector< std::size_t >& vertex_list ) const; 00095 //! Very efficient retrieval of vertices indexes 00096 //! (corresponding to the PatchData vertex array). 00097 inline const std::size_t* get_vertex_index_array() const; 00098 inline std::size_t* get_vertex_index_array(); 00099 00100 //! Sets element data 00101 void set_element_type( EntityTopology type ) 00102 { 00103 mType = type; 00104 } 00105 00106 //! Set connectivity data (vertex array) for element. 00107 //! MsqMeshEntity keeps the pointer to the passed array, it 00108 //! does not copy it. The caller is still responsible for 00109 //! releasing the memory for the passed index array after 00110 //! the MsqMeshEntity is destroyed. The intention is that 00111 //! this is a pointer to a portion of a larger connectivity array 00112 //! managed by the owning PatchData. 00113 void set_connectivity( std::size_t* indices, size_t num_vertices ); 00114 00115 std::size_t get_vertex_index( std::size_t vertex_in_element ) const; 00116 00117 //! Returns the centroid of the element. 00118 void get_centroid( Vector3D& centroid, const PatchData& pd, MsqError& err ) const; 00119 00120 //! Fills a vector<size_t> with vertices connected to the given 00121 //! vertex through the edges of this MsqMeshEntity. 00122 void get_connected_vertices( std::size_t vertex_index, std::vector< std::size_t >& vert_indices, MsqError& err ); 00123 00124 //! Computes the area of the element. 00125 //! The returned value is always non-negative. 00126 double compute_unsigned_area( PatchData& pd, MsqError& err ); 00127 00128 //! Computes the signed area of the element. 00129 double compute_signed_area( PatchData& pd, MsqError& err ); 00130 00131 //! Check sign of the determinant mapping fuction Jacobian 00132 //! at representative sample points in the element. 00133 //!\param inverted_count Number of sampling locations within the 00134 //! element for which the determinant of the 00135 //! mapping function Jacobian was negative. 00136 //!\param tested_count The number of sampling locations in the 00137 //! element for which the Jacobian was tested. 00138 void check_element_orientation( PatchData& pd, int& inverted_count, int& tested_count, MsqError& err ); 00139 void check_element_orientation_corners( PatchData& pd, int& inverted_count, int& tested_count, MsqError& err ); 00140 00141 //! Uses a MeshDomain call-back function to compute the normal at the corner. 00142 // void compute_corner_normal( std::size_t corner_pt, 00143 // Vector3D &normal, 00144 // PatchData &pd, 00145 // MsqError &err); 00146 void compute_corner_normals( Vector3D normals[], PatchData& pd, MsqError& err ); 00147 00148 //! Get NodeSet indicating all nodes present for this element type. 00149 NodeSet all_nodes( MsqError& err ) const; 00150 00151 private: 00152 //! Check for a negative Jacobian at the specified sample point 00153 //! of a volume element. 00154 bool inverted_jacobian_3d( PatchData& pd, NodeSet nodes, Sample sample, MsqError& err ); 00155 00156 //! Check for a negative Jacobian at the specified sample point 00157 //! of a surface element. 00158 bool inverted_jacobian_2d( PatchData& pd, NodeSet nodes, Sample sample, MsqError& err ); 00159 00160 EntityTopology mType; 00161 /** Pointer to connectivity array. 00162 * NOTE: The memory occupied by this array is assumed to be 00163 * owned/managed by the owning PatchData. Do not try 00164 * to delete/resize/etc. this array directly! 00165 */ 00166 size_t* vertexIndices; 00167 size_t numVertexIndices; 00168 00169 // output operator for debugging. 00170 friend std::ostream& operator<<( std::ostream& stream, const MsqMeshEntity& entity ); 00171 }; 00172 00173 // Returns the number of vertices in this type 00174 // of element, or 0 if a variable number. 00175 inline size_t MsqMeshEntity::vertex_count() const 00176 { 00177 return mType == POLYGON || mType == POLYHEDRON ? node_count() : TopologyInfo::corners( mType ); 00178 } 00179 00180 inline void MsqMeshEntity::set_connectivity( std::size_t* indices, size_t num_vertices ) 00181 { 00182 vertexIndices = indices; 00183 numVertexIndices = num_vertices; 00184 } 00185 00186 inline const std::size_t* MsqMeshEntity::get_vertex_index_array() const 00187 { 00188 return vertexIndices; 00189 } 00190 00191 inline std::size_t* MsqMeshEntity::get_vertex_index_array() 00192 { 00193 return vertexIndices; 00194 } 00195 00196 inline std::size_t MsqMeshEntity::get_vertex_index( std::size_t vertex_in_element ) const 00197 { 00198 // Make sure we're in range 00199 assert( vertex_in_element < vertex_count() ); 00200 // Return the index 00201 return vertexIndices[vertex_in_element]; 00202 } 00203 } // namespace MBMesquite 00204 00205 #endif // MsqMeshEntity_hpp
