MOAB: Mesh Oriented datABase
(version 5.4.0)
#include "TestUtil.hpp"
#include "Mesquite.hpp"
#include "PMeanPTemplate.hpp"
#include "AffineMapMetric.hpp"
#include "ConjugateGradient.hpp"
#include "TerminationCriterion.hpp"
#include "ElementPMeanP.hpp"
#include "MsqError.hpp"
#include "TSquared.hpp"
#include "MeshImpl.hpp"
#include "PlanarDomain.hpp"
#include "InstructionQueue.hpp"
#include "TargetCalculator.hpp"
#include "MetricWeight.hpp"
#include "InverseMetricWeight.hpp"
#include "TargetWriter.hpp"
#include "WeightReader.hpp"
#include <iostream>
#include <cstdlib>
Classes | |
class | IdentityTarget |
Defines | |
#define | USE_GLOBAL_PATCH |
#define | CHKERR(A) |
Enumerations | |
enum | Grouping { SAMPLE, ELEMENT, QUADRANT, HALF } |
enum | Weight { UNIT, METRIC, INV_METRIC } |
Functions | |
void | run_test (Grouping grouping, int of_power, Weight w, const string filename) |
int | main () |
Variables | |
const double | epsilon = 2e-2 |
const bool | write_results = true |
#define CHKERR | ( | A | ) |
if( A ) \
cerr << ( A ) << endl; \
exit( 1 ); \
Definition at line 63 of file 2d_formulation_test.cpp.
Referenced by run_test().
#define USE_GLOBAL_PATCH |
Definition at line 33 of file 2d_formulation_test.cpp.
enum Grouping |
enum Weight |
Definition at line 77 of file 2d_formulation_test.cpp.
{ UNIT, METRIC, INV_METRIC };
int main | ( | ) |
Definition at line 195 of file 2d_formulation_test.cpp.
References ELEMENT, INV_METRIC, METRIC, run_test(), SAMPLE, and UNIT.
{ run_test( SAMPLE, 1, UNIT, "1-1" ); run_test( SAMPLE, 2, UNIT, "1-2" ); run_test( SAMPLE, 4, UNIT, "1-4" ); run_test( SAMPLE, 8, UNIT, "1-8" ); run_test( SAMPLE, 1, UNIT, "2-NW" ); run_test( ELEMENT, 1, UNIT, "2-NE" ); run_test( SAMPLE, 1, UNIT, "3-Left" ); run_test( SAMPLE, 1, METRIC, "3-Mid" ); run_test( SAMPLE, 1, INV_METRIC, "3-Right" ); }
Definition at line 111 of file 2d_formulation_test.cpp.
References MBMesquite::TerminationCriterion::add_absolute_vertex_movement(), MBMesquite::TerminationCriterion::add_iteration_limit(), MBMesquite::InstructionQueue::add_target_calculator(), CHKERR, ELEMENT, INV_METRIC, mesh, METRIC, MBMesquite::MeshImpl::read_vtk(), MBMesquite::IQInterface::run_instructions(), MBMesquite::QualityImprover::set_inner_termination_criterion(), MBMesquite::InstructionQueue::set_master_quality_improver(), MBMesquite::QualityImprover::set_outer_termination_criterion(), MBMesquite::AffineMapMetric::set_weight_calculator(), STRINGIFY, MBMesquite::PatchSetUser::use_element_on_vertex_patch(), MBMesquite::PatchSetUser::use_global_patch(), write_results, MBMesquite::MeshImpl::write_vtk(), and MBMesquite::PlanarDomain::XY.
{ MsqError err; IdentityTarget target; TSquared target_metric; AffineMapMetric qual_metric( &target, &target_metric ); ElementPMeanP elem_metric( of_power, &qual_metric ); QualityMetric* qm_ptr = ( grouping == ELEMENT ) ? (QualityMetric*)&elem_metric : (QualityMetric*)&qual_metric; PMeanPTemplate OF( of_power, qm_ptr ); ConjugateGradient solver( &OF ); TerminationCriterion tc; TerminationCriterion itc; tc.add_absolute_vertex_movement( 1e-4 ); itc.add_iteration_limit( 2 ); #ifdef USE_GLOBAL_PATCH solver.use_global_patch(); solver.set_inner_termination_criterion( &tc ); #else solver.use_element_on_vertex_patch(); solver.set_inner_termination_criterion( &itc ); solver.set_outer_termination_criterion( &tc ); #endif MeshImpl mesh, expected_mesh; std::string initfname = std::string( STRINGIFY( SRCDIR ) ) + "/2d_formulation_initial.vtk"; mesh.read_vtk( initfname.c_str(), err );CHKERR( err ) // expected_mesh.read_vtk( (filename + ".vtk").c_str(), err ); CHKERR(err) PlanarDomain plane( PlanarDomain::XY ); MeshDomainAssoc mesh_and_domain = MeshDomainAssoc( &mesh, &plane ); MetricWeight mw( &qual_metric ); InverseMetricWeight imw( &qual_metric ); WeightReader reader; if( w == METRIC ) { TargetWriter writer( 0, &mw ); InstructionQueue tq; tq.add_target_calculator( &writer, err ); tq.run_instructions( &mesh_and_domain, err );CHKERR( err ); qual_metric.set_weight_calculator( &reader ); } else if( w == INV_METRIC ) { TargetWriter writer( 0, &imw ); InstructionQueue tq; tq.add_target_calculator( &writer, err ); tq.run_instructions( &mesh_and_domain, err );CHKERR( err ); qual_metric.set_weight_calculator( &reader ); } InstructionQueue q; q.set_master_quality_improver( &solver, err ); q.run_instructions( &mesh_and_domain, err );CHKERR( err ) /* vector<Mesh::VertexHandle> vemain.cpprts; vector<MsqVertex> mesh_coords, expected_coords; mesh.get_all_vertices( verts, err ); CHKERR(err) mesh_coords.resize(verts.size()); mesh.vertices_get_coordinates( arrptr(verts), arrptr(mesh_coords), verts.size(), err );CHKERR(err) expected_mesh.get_all_vertices( verts, err ); CHKERR(err) expected_coords.resize(verts.size()); expected_mesh.vertices_get_coordinates( arrptr(verts), arrptr(expected_coords), verts.size(), err ); CHKERR(err) if (expected_coords.size() != mesh_coords.size()) { cerr << "Invlid expected mesh. Vertex count doesn't match" << endl; exit(1); } unsigned error_count = 0; for (size_t i = 0; i < mesh_coords.size(); ++i) if ((expected_coords[i] - mesh_coords[i]).length_squared() > epsilon*epsilon) ++error_count; if (!error_count) cout << filename << " : SUCCESS" << endl; else cout << filename << " : FAILURE (" << error_count << " vertices differ by more than " << epsilon << ")" << endl; */ if( write_results ) mesh.write_vtk( ( filename + ".results.vtk" ).c_str(), err );CHKERR( err ) }
const double epsilon = 2e-2 |
Definition at line 60 of file 2d_formulation_test.cpp.
Referenced by moab::GeomUtil::box_hex_overlap(), moab::GeomUtil::box_linear_elem_overlap(), moab::GeomUtil::box_tet_overlap_edge(), moab::HiReconstruction::compute_weights(), moab::BSPTreePoly::cut_polyhedron(), MBMesquite::do_finite_difference(), MBMesquite::do_numerical_hessian(), CompareMetric::equal(), MBMesquite::BoundedCylinderDomain::evaluate(), MBMesquite::CylinderDomain::evaluate(), CompareMetric::evaluate(), moab::LinearTet::evaluate_reverse(), moab::LinearTri::evaluate_reverse(), moab::EvalSet::evaluate_reverse(), CompareMetric::evaluate_with_gradient(), CompareMetric::evaluate_with_Hessian(), CompareMetric::evaluate_with_Hessian_diagonal(), CompareMetric::evaluate_with_indices(), MBMesquite::SphericalDomain::fit_vertices(), MBMesquite::PlanarDomain::fit_vertices(), MBMesquite::geom_classify_elements(), MBMesquite::geom_classify_vertices(), CompareMetric::get_mask_axis(), moab::Element::Map::ievaluate(), MBMesquite::MsqLine::intersect(), limit_absolute_quality(), limit_absolute_sucessive(), main(), moab::Util::normal(), moab::LinearHex::normalFcn(), moab::LinearQuad::normalFcn(), moab::LinearTet::normalFcn(), moab::LinearTri::normalFcn(), MBMesquite::QuasiNewton::optimize_vertex_positions(), MBMesquite::FeasibleNewton::optimize_vertex_positions(), overlap_test_measure_area(), overlap_test_measure_volume(), moab::GeomUtil::plucker_edge_test(), quad_all_in_xy_plane(), quad_mid_edge_nodes_edge_center(), moab::GeomUtil::ray_box_intersect(), moab::ray_intersect_halfspaces(), moab::AffineXform::rotation(), moab::AffineXform::scale(), moab::BSPTree::set_split_plane(), MBMesquite::XYRectangle::setup(), moab::BSPTreeBoxIter::side_on_plane(), moab::ElemUtil::VolMap::solve_inverse(), moab::GeomUtil::VolMap::solve_inverse(), PlanarGeometryTest::test_fit_plane(), test_measure_area(), test_measure_volume(), test_real_arg(), test_real_opt(), test_value(), tet_mid_edge_nodes_edge_center(), tri_mid_edge_nodes_edge_center(), v_tet_minimum_angle(), and TreeValidator::visit().
const bool write_results = true |
Definition at line 61 of file 2d_formulation_test.cpp.
