MOAB: Mesh Oriented datABase
(version 5.3.1)
00001 /* ***************************************************************** 00002 MESQUITE -- The Mesh Quality Improvement Toolkit 00003 00004 Copyright 2004 Sandia Corporation and Argonne National 00005 Laboratory. Under the terms of Contract DE-AC04-94AL85000 00006 with Sandia Corporation, the U.S. Government retains certain 00007 rights in this software. 00008 00009 This library is free software; you can redistribute it and/or 00010 modify it under the terms of the GNU Lesser General Public 00011 License as published by the Free Software Foundation; either 00012 version 2.1 of the License, or (at your option) any later version. 00013 00014 This library is distributed in the hope that it will be useful, 00015 but WITHOUT ANY WARRANTY; without even the implied warranty of 00016 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00017 Lesser General Public License for more details. 00018 00019 You should have received a copy of the GNU Lesser General Public License 00020 (lgpl.txt) along with this library; if not, write to the Free Software 00021 Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA 00022 00023 diachin2@llnl.gov, djmelan@sandia.gov, mbrewer@sandia.gov, 00024 pknupp@sandia.gov, tleurent@mcs.anl.gov, tmunson@mcs.anl.gov 00025 00026 ***************************************************************** */ 00027 // -*- Mode : c++; tab-width: 2; c-tab-always-indent: t; indent-tabs-mode: nil; c-basic-offset: 2 00028 // -*- 00029 // 00030 // SUMMARY: 00031 // USAGE: 00032 // 00033 // AUTHOR: Michael Brewer 00034 // ORG: Sandia National Labs 00035 // E-MAIL: mbrewer@sandia.gov 00036 // 00037 // ORIG-DATE: Jan. 29, 2003 00038 // LAST-MOD: 25-Feb-04 at 10:49:32 by Thomas Leurent 00039 // 00040 // DESCRIPTION: 00041 // ============ 00042 /*! \file PlanarGeometryTest.cpp 00043 00044 Regression testing using the planar geometry capabilities in 00045 SimplifiedGeometryEngine. 00046 */ 00047 // DESCRIP-END. 00048 // 00049 00050 #include "meshfiles.h" 00051 00052 #include "PatchDataInstances.hpp" 00053 #include "cppunit/extensions/HelperMacros.h" 00054 #include <cmath> 00055 00056 #include "Mesquite.hpp" 00057 #include "MsqError.hpp" 00058 #include "InstructionQueue.hpp" 00059 #include "PatchData.hpp" 00060 //#include "StoppingCriterion.hpp" 00061 #include "QualityAssessor.hpp" 00062 00063 #include "ConditionNumberQualityMetric.hpp" 00064 #include "LPtoPTemplate.hpp" 00065 #include "EdgeLengthQualityMetric.hpp" 00066 #include "LaplacianSmoother.hpp" 00067 #include "LInfTemplate.hpp" 00068 #include "SteepestDescent.hpp" 00069 #include "ConjugateGradient.hpp" 00070 #include "AspectRatioGammaQualityMetric.hpp" 00071 #include "UntangleBetaQualityMetric.hpp" 00072 #include "MultiplyQualityMetric.hpp" 00073 #include "PlanarDomain.hpp" 00074 00075 #include "MsqFPE.hpp" 00076 00077 #include "UnitUtil.hpp" 00078 00079 #include "MeshImpl.hpp" 00080 #include <iostream> 00081 using std::cout; 00082 using std::endl; 00083 00084 using namespace MBMesquite; 00085 00086 class PlanarGeometryTest : public CppUnit::TestFixture 00087 { 00088 private: 00089 CPPUNIT_TEST_SUITE( PlanarGeometryTest ); 00090 // run steepest descent on the tangled_tri.vtk mesh 00091 CPPUNIT_TEST( test_plane_tri_tangled ); 00092 // run cg on tangled_quad.vtk mesh 00093 CPPUNIT_TEST( test_plane_quad_tangled ); 00094 // run cg with asm metric on tri mesh in y=-5 plane 00095 CPPUNIT_TEST( test_plane_tri_xz ); 00096 // test fit plane 00097 CPPUNIT_TEST( test_fit_plane ); 00098 CPPUNIT_TEST_SUITE_END(); 00099 00100 private: 00101 double qualTol; // double used for double comparisons 00102 int pF; // PRINT_FLAG 00103 public: 00104 void setUp() 00105 { 00106 // pF=1;//PRINT_FLAG IS ON 00107 pF = 0; // PRINT_FLAG IS OFF 00108 // tolerance double 00109 qualTol = MSQ_MIN; 00110 } 00111 00112 void tearDown() {} 00113 00114 public: 00115 PlanarGeometryTest() {} 00116 00117 void test_plane_tri_tangled() 00118 { 00119 MBMesquite::MsqPrintError err( cout ); 00120 MBMesquite::MeshImpl mesh; 00121 00122 // This test doesn't use InstructionQueue, so 00123 // we need to set up trapping of floating-point 00124 // exceptions ourself. 00125 MsqFPE fpe_trap( true ); 00126 00127 mesh.read_vtk( MESH_FILES_DIR "2D/vtk/tris/tangled/tangled_tri.vtk", err ); 00128 CPPUNIT_ASSERT( !err ); 00129 00130 // create geometry: plane z=5, normal (0,0,1) 00131 Vector3D pnt( 0, 0, 5 ); 00132 Vector3D s_norm( 0, 0, 1 ); 00133 MBMesquite::PlanarDomain msq_geom( s_norm, pnt ); 00134 00135 // creates an intruction queue 00136 InstructionQueue queue1, queue2; 00137 00138 // creates a mean ratio quality metric ... 00139 ConditionNumberQualityMetric shape; 00140 UntangleBetaQualityMetric untan( .1 ); 00141 00142 // ... and builds an objective function with it (untangle) 00143 LInfTemplate untan_func( &untan ); 00144 LPtoPTemplate shape_func( &shape, 2, err ); 00145 // Make sure no errors 00146 CPPUNIT_ASSERT( !err ); 00147 // creates the steepest descent optimization procedures 00148 SteepestDescent pass1( &untan_func ); 00149 SteepestDescent pass2( &shape_func ); 00150 pass1.use_element_on_vertex_patch(); 00151 pass2.use_global_patch(); 00152 // Make sure no errors 00153 CPPUNIT_ASSERT( !err ); 00154 QualityAssessor stop_qa = QualityAssessor( &untan ); 00155 QualityAssessor qa = QualityAssessor( &shape ); 00156 if( pF == 0 ) 00157 { 00158 stop_qa.disable_printing_results(); 00159 qa.disable_printing_results(); 00160 } 00161 //**********Set stopping criterion untangle ver small ******** 00162 // StoppingCriterion sc_qa(&stop_qa,-100,MSQ_MIN); 00163 // pass1->set_stopping_criterion(&sc_qa); 00164 TerminationCriterion sc_of, sc_inner; 00165 sc_of.add_iteration_limit( 10 ); 00166 pass1.set_outer_termination_criterion( &sc_of ); 00167 sc_inner.add_iteration_limit( 6 ); 00168 // sc_inner.add_absolute_gradient_L2_norm( 0.01 ); 00169 pass1.set_inner_termination_criterion( &sc_inner ); 00170 00171 //**********Set stopping criterion 5 iterates **************** 00172 // StoppingCriterion sc5(StoppingCriterion::NUMBER_OF_PASSES,5); 00173 // pass2->set_stopping_criterion(&sc5); 00174 TerminationCriterion sc5; 00175 sc5.add_iteration_limit( 5 ); 00176 pass2.set_inner_termination_criterion( &sc5 ); 00177 // TerminationCriterion sc_inner; 00178 // sc_inner.add_iteration_limit( 5 ); 00179 // pass2->set_inner_termination_criterion(&sc_inner); 00180 // pass2->set_maximum_iteration(5); 00181 00182 queue1.set_master_quality_improver( &pass1, err ); 00183 CPPUNIT_ASSERT( !err ); 00184 queue2.set_master_quality_improver( &pass2, err ); 00185 CPPUNIT_ASSERT( !err ); 00186 //********************UNTANGLE******************************* 00187 // Make sure no errors 00188 CPPUNIT_ASSERT( !err ); 00189 // launches optimization on mesh_set1 00190 MeshDomainAssoc mesh_and_domain = MeshDomainAssoc( &mesh, &msq_geom ); 00191 double orig_qa_val = stop_qa.loop_over_mesh( &mesh_and_domain, 0, err ); 00192 // Make sure no errors 00193 CPPUNIT_ASSERT( !err ); 00194 queue1.run_instructions( &mesh_and_domain, err ); 00195 CPPUNIT_ASSERT( !err ); 00196 // Make sure no errors 00197 CPPUNIT_ASSERT( !err ); 00198 double fin_qa_val = stop_qa.loop_over_mesh( &mesh_and_domain, 0, err ); 00199 // Make sure no errors 00200 CPPUNIT_ASSERT( !err ); 00201 // make sure 'quality' improved 00202 CPPUNIT_ASSERT( ( fin_qa_val - orig_qa_val ) <= 0.0 ); 00203 // make sure sc_qa really was satisfied 00204 CPPUNIT_ASSERT( fin_qa_val <= MSQ_MIN ); 00205 00206 //********************SMOOTH******************************* 00207 // Make sure no errors 00208 CPPUNIT_ASSERT( !err ); 00209 // launches optimization on mesh_set1 00210 orig_qa_val = qa.loop_over_mesh( &mesh_and_domain, 0, err ); 00211 // Make sure no errors 00212 CPPUNIT_ASSERT( !err ); 00213 queue2.run_instructions( &mesh_and_domain, err ); 00214 CPPUNIT_ASSERT( !err ); 00215 // Make sure no errors 00216 CPPUNIT_ASSERT( !err ); 00217 fin_qa_val = qa.loop_over_mesh( &mesh_and_domain, 0, err ); 00218 // Make sure no errors 00219 CPPUNIT_ASSERT( !err ); 00220 // make sure 'quality' improved 00221 CPPUNIT_ASSERT( ( fin_qa_val - orig_qa_val ) <= 0.0 ); 00222 print_timing_diagnostics( cout ); 00223 } 00224 00225 void test_plane_quad_tangled() 00226 { 00227 MBMesquite::MeshImpl mesh; 00228 MsqPrintError err( cout ); 00229 mesh.read_vtk( MESH_FILES_DIR "2D/vtk/quads/tangled/tangled_quad.vtk", err ); 00230 CPPUNIT_ASSERT( !err ); 00231 00232 // create geometry: plane z=5, normal (0,0,1) 00233 Vector3D pnt( 0, 0, 5 ); 00234 Vector3D s_norm( 0, 0, 1 ); 00235 MBMesquite::PlanarDomain msq_geom( s_norm, pnt ); 00236 00237 // creates an intruction queue 00238 InstructionQueue queue1, queue2; 00239 00240 // creates a mean ratio quality metric ... 00241 ConditionNumberQualityMetric shape; 00242 UntangleBetaQualityMetric untan( .1 ); 00243 00244 // ... and builds an objective function with it (untangle) 00245 LInfTemplate untan_func( &untan ); 00246 LPtoPTemplate shape_func( &shape, 2, err ); 00247 // Make sure no errors 00248 CPPUNIT_ASSERT( !err ); 00249 // creates the cg optimization procedures 00250 ConjugateGradient pass1( &untan_func, err ); 00251 ConjugateGradient pass2( &shape_func, err ); 00252 pass1.use_element_on_vertex_patch(); 00253 pass2.use_global_patch(); 00254 // Make sure no errors 00255 CPPUNIT_ASSERT( !err ); 00256 QualityAssessor stop_qa = QualityAssessor( &untan ); 00257 QualityAssessor qa = QualityAssessor( &shape ); 00258 // turn off printing if print flag not set. 00259 if( pF == 0 ) 00260 { 00261 stop_qa.disable_printing_results(); 00262 qa.disable_printing_results(); 00263 } 00264 //**********Set stopping criterion untangle ver small ******** 00265 // StoppingCriterion sc_qa(&stop_qa,-100,MSQ_MIN); 00266 // pass1->set_stopping_criterion(&sc_qa); 00267 TerminationCriterion sc_of; 00268 sc_of.add_iteration_limit( 10 ); 00269 pass1.set_outer_termination_criterion( &sc_of ); 00270 00271 //**********Set stopping criterion 5 iterates **************** 00272 // StoppingCriterion sc5(StoppingCriterion::NUMBER_OF_PASSES,5); 00273 // pass2->set_stopping_criterion(&sc5); 00274 TerminationCriterion sc5; 00275 sc5.add_iteration_limit( 5 ); 00276 pass2.set_inner_termination_criterion( &sc5 ); 00277 // pass2->set_maximum_iteration(5); 00278 // TerminationCriterion sc_inner; 00279 // sc_inner.add_iteration_limit( 5 ); 00280 // pass2->set_inner_termination_criterion(&sc_inner); 00281 queue1.set_master_quality_improver( &pass1, err ); 00282 CPPUNIT_ASSERT( !err ); 00283 queue2.set_master_quality_improver( &pass2, err ); 00284 CPPUNIT_ASSERT( !err ); 00285 //********************UNTANGLE******************************* 00286 // Make sure no errors 00287 CPPUNIT_ASSERT( !err ); 00288 // launches optimization on mesh_set1 00289 MeshDomainAssoc mesh_and_domain = MeshDomainAssoc( &mesh, &msq_geom ); 00290 double orig_qa_val = stop_qa.loop_over_mesh( &mesh_and_domain, 0, err ); 00291 // Make sure no errors 00292 CPPUNIT_ASSERT( !err ); 00293 queue1.run_instructions( &mesh_and_domain, err ); 00294 CPPUNIT_ASSERT( !err ); 00295 // Make sure no errors 00296 CPPUNIT_ASSERT( !err ); 00297 double fin_qa_val = stop_qa.loop_over_mesh( &mesh_and_domain, 0, err ); 00298 // Make sure no errors 00299 CPPUNIT_ASSERT( !err ); 00300 // make sure 'quality' improved 00301 CPPUNIT_ASSERT( ( fin_qa_val - orig_qa_val ) <= 0.0 ); 00302 // make sure sc_qa really was satisfied 00303 CPPUNIT_ASSERT( fin_qa_val <= MSQ_MIN ); 00304 00305 //********************SMOOTH******************************* 00306 // Make sure no errors 00307 CPPUNIT_ASSERT( !err ); 00308 // launches optimization on mesh_set1 00309 orig_qa_val = qa.loop_over_mesh( &mesh_and_domain, 0, err ); 00310 // Make sure no errors 00311 CPPUNIT_ASSERT( !err ); 00312 queue2.run_instructions( &mesh_and_domain, err ); 00313 CPPUNIT_ASSERT( !err ); 00314 // Make sure no errors 00315 CPPUNIT_ASSERT( !err ); 00316 fin_qa_val = qa.loop_over_mesh( &mesh_and_domain, 0, err ); 00317 // Make sure no errors 00318 CPPUNIT_ASSERT( !err ); 00319 // make sure 'quality' improved 00320 CPPUNIT_ASSERT( ( fin_qa_val - orig_qa_val ) <= 0.0 ); 00321 print_timing_diagnostics( cout ); 00322 } 00323 00324 void test_plane_tri_xz() 00325 { 00326 MsqPrintError err( cout ); 00327 MBMesquite::MeshImpl mesh; 00328 mesh.read_vtk( MESH_FILES_DIR "2D/vtk/tris/untangled/tri_5_xz.vtk", err ); 00329 CPPUNIT_ASSERT( !err ); 00330 00331 // create geometry: plane y=5, normal (0,1,0) 00332 Vector3D pnt( 0, -5, 0 ); 00333 Vector3D s_norm( 0, -1, 0 ); 00334 MBMesquite::PlanarDomain msq_geom( s_norm, pnt ); 00335 00336 // creates an intruction queue 00337 InstructionQueue queue1; 00338 00339 // creates a asm quality metric ... 00340 ConditionNumberQualityMetric smooth; 00341 00342 // ... and builds an objective function with it (untangle) 00343 LPtoPTemplate smooth_func( &smooth, 1, err ); 00344 // Make sure no errors 00345 CPPUNIT_ASSERT( !err ); 00346 // creates the cg optimization procedures 00347 ConjugateGradient pass1( &smooth_func, err ); 00348 // pass1->set_patch_type(PatchData::ELEMENTS_ON_VERTEX_PATCH, err,1 ,1); 00349 pass1.use_global_patch(); 00350 pass1.set_debugging_level( 1 ); 00351 // Make sure no errors 00352 CPPUNIT_ASSERT( !err ); 00353 QualityAssessor qa = QualityAssessor( &smooth ); 00354 00355 //**********Set stopping criterion 5 iterates **************** 00356 TerminationCriterion sc5; 00357 sc5.add_iteration_limit( 5 ); 00358 pass1.set_inner_termination_criterion( &sc5 ); 00359 // StoppingCriterion sc5(StoppingCriterion::NUMBER_OF_PASSES,5); 00360 // pass1->set_stopping_criterion(&sc5); 00361 TerminationCriterion sc_inner; 00362 sc_inner.add_iteration_limit( 5 ); 00363 pass1.set_inner_termination_criterion( &sc_inner ); 00364 // pass1->set_maximum_iteration(5); 00365 00366 queue1.set_master_quality_improver( &pass1, err ); 00367 CPPUNIT_ASSERT( !err ); 00368 //********************UNTANGLE******************************* 00369 // Make sure no errors 00370 CPPUNIT_ASSERT( !err ); 00371 // launches optimization on mesh_set1 00372 MeshDomainAssoc mesh_and_domain = MeshDomainAssoc( &mesh, &msq_geom ); 00373 double orig_qa_val = qa.loop_over_mesh( &mesh_and_domain, 0, err ); 00374 // Make sure no errors 00375 CPPUNIT_ASSERT( !err ); 00376 queue1.run_instructions( &mesh_and_domain, err ); 00377 CPPUNIT_ASSERT( !err ); 00378 // Make sure no errors 00379 CPPUNIT_ASSERT( !err ); 00380 double fin_qa_val = qa.loop_over_mesh( &mesh_and_domain, 0, err ); 00381 // Make sure no errors 00382 CPPUNIT_ASSERT( !err ); 00383 // make sure 'quality' improved 00384 CPPUNIT_ASSERT( ( fin_qa_val - orig_qa_val ) <= 0.0 ); 00385 print_timing_diagnostics( cout ); 00386 } 00387 00388 void test_fit_plane(); 00389 }; 00390 00391 CPPUNIT_TEST_SUITE_NAMED_REGISTRATION( PlanarGeometryTest, "PlanarGeometryTest" ); 00392 CPPUNIT_TEST_SUITE_NAMED_REGISTRATION( PlanarGeometryTest, "Regression" ); 00393 00394 void PlanarGeometryTest::test_fit_plane() 00395 { 00396 MsqPrintError err( std::cerr ); 00397 PlanarDomain plane( PlanarDomain::XY, -1 ); 00398 const double epsilon = 1e-8; 00399 00400 MeshImpl mesh1; 00401 mesh1.read_vtk( MESH_FILES_DIR "2D/vtk/tris/untangled/bad_circle_tri.vtk", err ); 00402 ASSERT_NO_ERROR( err ); 00403 plane.fit_vertices( &mesh1, err, epsilon ); 00404 ASSERT_NO_ERROR( err ); 00405 CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 0, 0, 1 ), plane.get_normal(), epsilon ); 00406 CPPUNIT_ASSERT_DOUBLES_EQUAL( 5, plane.get_coeff(), epsilon ); 00407 00408 MeshImpl mesh2; 00409 mesh2.read_vtk( MESH_FILES_DIR "2D/vtk/tris/untangled/equil_tri.vtk", err ); 00410 ASSERT_NO_ERROR( err ); 00411 plane.fit_vertices( &mesh2, err, epsilon ); 00412 ASSERT_NO_ERROR( err ); 00413 CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 0, 0, 1 ), plane.get_normal(), epsilon ); 00414 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0, plane.get_coeff(), epsilon ); 00415 00416 MeshImpl mesh3; 00417 mesh3.read_vtk( MESH_FILES_DIR "2D/vtk/quads/untangled/quads_4by2.vtk", err ); 00418 ASSERT_NO_ERROR( err ); 00419 plane.fit_vertices( &mesh3, err, epsilon ); 00420 ASSERT_NO_ERROR( err ); 00421 CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 0, 0, 1 ), plane.get_normal(), epsilon ); 00422 CPPUNIT_ASSERT_DOUBLES_EQUAL( -2, plane.get_coeff(), epsilon ); 00423 00424 MeshImpl mesh4; 00425 mesh4.read_vtk( MESH_FILES_DIR "2D/vtk/tris/untangled/tri_5_xz.vtk", err ); 00426 ASSERT_NO_ERROR( err ); 00427 plane.fit_vertices( &mesh4, err, epsilon ); 00428 ASSERT_NO_ERROR( err ); 00429 CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 0, -1, 0 ), plane.get_normal(), epsilon ); 00430 CPPUNIT_ASSERT_DOUBLES_EQUAL( -5, plane.get_coeff(), epsilon ); 00431 }
