MOAB: Mesh Oriented datABase
(version 5.2.1)
Public Member Functions | |
void | setUp () |
void | tearDown () |
PlanarGeometryTest () | |
void | test_plane_tri_tangled () |
void | test_plane_quad_tangled () |
void | test_plane_tri_xz () |
void | test_fit_plane () |
Private Member Functions | |
CPPUNIT_TEST_SUITE (PlanarGeometryTest) | |
CPPUNIT_TEST (test_plane_tri_tangled) | |
CPPUNIT_TEST (test_plane_quad_tangled) | |
CPPUNIT_TEST (test_plane_tri_xz) | |
CPPUNIT_TEST (test_fit_plane) | |
CPPUNIT_TEST_SUITE_END () | |
Private Attributes | |
double | qualTol |
int | pF |
Definition at line 86 of file PlanarGeometryTest.cpp.
PlanarGeometryTest::PlanarGeometryTest | ( | ) | [inline] |
Definition at line 115 of file PlanarGeometryTest.cpp.
PlanarGeometryTest::CPPUNIT_TEST | ( | test_plane_tri_tangled | ) | [private] |
PlanarGeometryTest::CPPUNIT_TEST | ( | test_plane_quad_tangled | ) | [private] |
PlanarGeometryTest::CPPUNIT_TEST | ( | test_plane_tri_xz | ) | [private] |
PlanarGeometryTest::CPPUNIT_TEST | ( | test_fit_plane | ) | [private] |
PlanarGeometryTest::CPPUNIT_TEST_SUITE | ( | PlanarGeometryTest | ) | [private] |
PlanarGeometryTest::CPPUNIT_TEST_SUITE_END | ( | ) | [private] |
void PlanarGeometryTest::setUp | ( | ) | [inline] |
Definition at line 104 of file PlanarGeometryTest.cpp.
References MBMesquite::MSQ_MIN.
void PlanarGeometryTest::tearDown | ( | ) | [inline] |
Definition at line 112 of file PlanarGeometryTest.cpp.
void PlanarGeometryTest::test_fit_plane | ( | ) |
Definition at line 394 of file PlanarGeometryTest.cpp.
References ASSERT_NO_ERROR, CPPUNIT_ASSERT_DOUBLES_EQUAL, CPPUNIT_ASSERT_VECTORS_EQUAL, epsilon, MBMesquite::PlanarDomain::fit_vertices(), MBMesquite::PlanarDomain::get_coeff(), MBMesquite::PlanarDomain::get_normal(), MBMesquite::MeshImpl::read_vtk(), and MBMesquite::PlanarDomain::XY.
{ MsqPrintError err( std::cerr ); PlanarDomain plane( PlanarDomain::XY, -1 ); const double epsilon = 1e-8; MeshImpl mesh1; mesh1.read_vtk( MESH_FILES_DIR "2D/vtk/tris/untangled/bad_circle_tri.vtk", err ); ASSERT_NO_ERROR( err ); plane.fit_vertices( &mesh1, err, epsilon ); ASSERT_NO_ERROR( err ); CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 0, 0, 1 ), plane.get_normal(), epsilon ); CPPUNIT_ASSERT_DOUBLES_EQUAL( 5, plane.get_coeff(), epsilon ); MeshImpl mesh2; mesh2.read_vtk( MESH_FILES_DIR "2D/vtk/tris/untangled/equil_tri.vtk", err ); ASSERT_NO_ERROR( err ); plane.fit_vertices( &mesh2, err, epsilon ); ASSERT_NO_ERROR( err ); CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 0, 0, 1 ), plane.get_normal(), epsilon ); CPPUNIT_ASSERT_DOUBLES_EQUAL( 0, plane.get_coeff(), epsilon ); MeshImpl mesh3; mesh3.read_vtk( MESH_FILES_DIR "2D/vtk/quads/untangled/quads_4by2.vtk", err ); ASSERT_NO_ERROR( err ); plane.fit_vertices( &mesh3, err, epsilon ); ASSERT_NO_ERROR( err ); CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 0, 0, 1 ), plane.get_normal(), epsilon ); CPPUNIT_ASSERT_DOUBLES_EQUAL( -2, plane.get_coeff(), epsilon ); MeshImpl mesh4; mesh4.read_vtk( MESH_FILES_DIR "2D/vtk/tris/untangled/tri_5_xz.vtk", err ); ASSERT_NO_ERROR( err ); plane.fit_vertices( &mesh4, err, epsilon ); ASSERT_NO_ERROR( err ); CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 0, -1, 0 ), plane.get_normal(), epsilon ); CPPUNIT_ASSERT_DOUBLES_EQUAL( -5, plane.get_coeff(), epsilon ); }
void PlanarGeometryTest::test_plane_quad_tangled | ( | ) | [inline] |
Definition at line 225 of file PlanarGeometryTest.cpp.
References MBMesquite::TerminationCriterion::add_iteration_limit(), CPPUNIT_ASSERT, MBMesquite::QualityAssessor::disable_printing_results(), MBMesquite::QualityAssessor::loop_over_mesh(), mesh, MBMesquite::MSQ_MIN, MBMesquite::print_timing_diagnostics(), MBMesquite::MeshImpl::read_vtk(), MBMesquite::IQInterface::run_instructions(), MBMesquite::QualityImprover::set_inner_termination_criterion(), MBMesquite::InstructionQueue::set_master_quality_improver(), MBMesquite::QualityImprover::set_outer_termination_criterion(), MBMesquite::PatchSetUser::use_element_on_vertex_patch(), and MBMesquite::PatchSetUser::use_global_patch().
{ MBMesquite::MeshImpl mesh; MsqPrintError err( cout ); mesh.read_vtk( MESH_FILES_DIR "2D/vtk/quads/tangled/tangled_quad.vtk", err ); CPPUNIT_ASSERT( !err ); // create geometry: plane z=5, normal (0,0,1) Vector3D pnt( 0, 0, 5 ); Vector3D s_norm( 0, 0, 1 ); MBMesquite::PlanarDomain msq_geom( s_norm, pnt ); // creates an intruction queue InstructionQueue queue1, queue2; // creates a mean ratio quality metric ... ConditionNumberQualityMetric shape; UntangleBetaQualityMetric untan( .1 ); // ... and builds an objective function with it (untangle) LInfTemplate untan_func( &untan ); LPtoPTemplate shape_func( &shape, 2, err ); // Make sure no errors CPPUNIT_ASSERT( !err ); // creates the cg optimization procedures ConjugateGradient pass1( &untan_func, err ); ConjugateGradient pass2( &shape_func, err ); pass1.use_element_on_vertex_patch(); pass2.use_global_patch(); // Make sure no errors CPPUNIT_ASSERT( !err ); QualityAssessor stop_qa = QualityAssessor( &untan ); QualityAssessor qa = QualityAssessor( &shape ); // turn off printing if print flag not set. if( pF == 0 ) { stop_qa.disable_printing_results(); qa.disable_printing_results(); } //**********Set stopping criterion untangle ver small ******** // StoppingCriterion sc_qa(&stop_qa,-100,MSQ_MIN); // pass1->set_stopping_criterion(&sc_qa); TerminationCriterion sc_of; sc_of.add_iteration_limit( 10 ); pass1.set_outer_termination_criterion( &sc_of ); //**********Set stopping criterion 5 iterates **************** // StoppingCriterion sc5(StoppingCriterion::NUMBER_OF_PASSES,5); // pass2->set_stopping_criterion(&sc5); TerminationCriterion sc5; sc5.add_iteration_limit( 5 ); pass2.set_inner_termination_criterion( &sc5 ); // pass2->set_maximum_iteration(5); // TerminationCriterion sc_inner; // sc_inner.add_iteration_limit( 5 ); // pass2->set_inner_termination_criterion(&sc_inner); queue1.set_master_quality_improver( &pass1, err ); CPPUNIT_ASSERT( !err ); queue2.set_master_quality_improver( &pass2, err ); CPPUNIT_ASSERT( !err ); //********************UNTANGLE******************************* // Make sure no errors CPPUNIT_ASSERT( !err ); // launches optimization on mesh_set1 MeshDomainAssoc mesh_and_domain = MeshDomainAssoc( &mesh, &msq_geom ); double orig_qa_val = stop_qa.loop_over_mesh( &mesh_and_domain, 0, err ); // Make sure no errors CPPUNIT_ASSERT( !err ); queue1.run_instructions( &mesh_and_domain, err ); CPPUNIT_ASSERT( !err ); // Make sure no errors CPPUNIT_ASSERT( !err ); double fin_qa_val = stop_qa.loop_over_mesh( &mesh_and_domain, 0, err ); // Make sure no errors CPPUNIT_ASSERT( !err ); // make sure 'quality' improved CPPUNIT_ASSERT( ( fin_qa_val - orig_qa_val ) <= 0.0 ); // make sure sc_qa really was satisfied CPPUNIT_ASSERT( fin_qa_val <= MSQ_MIN ); //********************SMOOTH******************************* // Make sure no errors CPPUNIT_ASSERT( !err ); // launches optimization on mesh_set1 orig_qa_val = qa.loop_over_mesh( &mesh_and_domain, 0, err ); // Make sure no errors CPPUNIT_ASSERT( !err ); queue2.run_instructions( &mesh_and_domain, err ); CPPUNIT_ASSERT( !err ); // Make sure no errors CPPUNIT_ASSERT( !err ); fin_qa_val = qa.loop_over_mesh( &mesh_and_domain, 0, err ); // Make sure no errors CPPUNIT_ASSERT( !err ); // make sure 'quality' improved CPPUNIT_ASSERT( ( fin_qa_val - orig_qa_val ) <= 0.0 ); print_timing_diagnostics( cout ); }
void PlanarGeometryTest::test_plane_tri_tangled | ( | ) | [inline] |
Definition at line 117 of file PlanarGeometryTest.cpp.
{ MBMesquite::MsqPrintError err( cout ); MBMesquite::MeshImpl mesh; // This test doesn't use InstructionQueue, so // we need to set up trapping of floating-point // exceptions ourself. MsqFPE fpe_trap( true ); mesh.read_vtk( MESH_FILES_DIR "2D/vtk/tris/tangled/tangled_tri.vtk", err ); CPPUNIT_ASSERT( !err ); // create geometry: plane z=5, normal (0,0,1) Vector3D pnt( 0, 0, 5 ); Vector3D s_norm( 0, 0, 1 ); MBMesquite::PlanarDomain msq_geom( s_norm, pnt ); // creates an intruction queue InstructionQueue queue1, queue2; // creates a mean ratio quality metric ... ConditionNumberQualityMetric shape; UntangleBetaQualityMetric untan( .1 ); // ... and builds an objective function with it (untangle) LInfTemplate untan_func( &untan ); LPtoPTemplate shape_func( &shape, 2, err ); // Make sure no errors CPPUNIT_ASSERT( !err ); // creates the steepest descent optimization procedures SteepestDescent pass1( &untan_func ); SteepestDescent pass2( &shape_func ); pass1.use_element_on_vertex_patch(); pass2.use_global_patch(); // Make sure no errors CPPUNIT_ASSERT( !err ); QualityAssessor stop_qa = QualityAssessor( &untan ); QualityAssessor qa = QualityAssessor( &shape ); if( pF == 0 ) { stop_qa.disable_printing_results(); qa.disable_printing_results(); } //**********Set stopping criterion untangle ver small ******** // StoppingCriterion sc_qa(&stop_qa,-100,MSQ_MIN); // pass1->set_stopping_criterion(&sc_qa); TerminationCriterion sc_of, sc_inner; sc_of.add_iteration_limit( 10 ); pass1.set_outer_termination_criterion( &sc_of ); sc_inner.add_iteration_limit( 6 ); // sc_inner.add_absolute_gradient_L2_norm( 0.01 ); pass1.set_inner_termination_criterion( &sc_inner ); //**********Set stopping criterion 5 iterates **************** // StoppingCriterion sc5(StoppingCriterion::NUMBER_OF_PASSES,5); // pass2->set_stopping_criterion(&sc5); TerminationCriterion sc5; sc5.add_iteration_limit( 5 ); pass2.set_inner_termination_criterion( &sc5 ); // TerminationCriterion sc_inner; // sc_inner.add_iteration_limit( 5 ); // pass2->set_inner_termination_criterion(&sc_inner); // pass2->set_maximum_iteration(5); queue1.set_master_quality_improver( &pass1, err ); CPPUNIT_ASSERT( !err ); queue2.set_master_quality_improver( &pass2, err ); CPPUNIT_ASSERT( !err ); //********************UNTANGLE******************************* // Make sure no errors CPPUNIT_ASSERT( !err ); // launches optimization on mesh_set1 MeshDomainAssoc mesh_and_domain = MeshDomainAssoc( &mesh, &msq_geom ); double orig_qa_val = stop_qa.loop_over_mesh( &mesh_and_domain, 0, err ); // Make sure no errors CPPUNIT_ASSERT( !err ); queue1.run_instructions( &mesh_and_domain, err ); CPPUNIT_ASSERT( !err ); // Make sure no errors CPPUNIT_ASSERT( !err ); double fin_qa_val = stop_qa.loop_over_mesh( &mesh_and_domain, 0, err ); // Make sure no errors CPPUNIT_ASSERT( !err ); // make sure 'quality' improved CPPUNIT_ASSERT( ( fin_qa_val - orig_qa_val ) <= 0.0 ); // make sure sc_qa really was satisfied CPPUNIT_ASSERT( fin_qa_val <= MSQ_MIN ); //********************SMOOTH******************************* // Make sure no errors CPPUNIT_ASSERT( !err ); // launches optimization on mesh_set1 orig_qa_val = qa.loop_over_mesh( &mesh_and_domain, 0, err ); // Make sure no errors CPPUNIT_ASSERT( !err ); queue2.run_instructions( &mesh_and_domain, err ); CPPUNIT_ASSERT( !err ); // Make sure no errors CPPUNIT_ASSERT( !err ); fin_qa_val = qa.loop_over_mesh( &mesh_and_domain, 0, err ); // Make sure no errors CPPUNIT_ASSERT( !err ); // make sure 'quality' improved CPPUNIT_ASSERT( ( fin_qa_val - orig_qa_val ) <= 0.0 ); print_timing_diagnostics( cout ); }
void PlanarGeometryTest::test_plane_tri_xz | ( | ) | [inline] |
Definition at line 324 of file PlanarGeometryTest.cpp.
References MBMesquite::TerminationCriterion::add_iteration_limit(), CPPUNIT_ASSERT, MBMesquite::QualityAssessor::loop_over_mesh(), mesh, MBMesquite::print_timing_diagnostics(), MBMesquite::MeshImpl::read_vtk(), MBMesquite::IQInterface::run_instructions(), MBMesquite::ConjugateGradient::set_debugging_level(), MBMesquite::QualityImprover::set_inner_termination_criterion(), MBMesquite::InstructionQueue::set_master_quality_improver(), and MBMesquite::PatchSetUser::use_global_patch().
{ MsqPrintError err( cout ); MBMesquite::MeshImpl mesh; mesh.read_vtk( MESH_FILES_DIR "2D/vtk/tris/untangled/tri_5_xz.vtk", err ); CPPUNIT_ASSERT( !err ); // create geometry: plane y=5, normal (0,1,0) Vector3D pnt( 0, -5, 0 ); Vector3D s_norm( 0, -1, 0 ); MBMesquite::PlanarDomain msq_geom( s_norm, pnt ); // creates an intruction queue InstructionQueue queue1; // creates a asm quality metric ... ConditionNumberQualityMetric smooth; // ... and builds an objective function with it (untangle) LPtoPTemplate smooth_func( &smooth, 1, err ); // Make sure no errors CPPUNIT_ASSERT( !err ); // creates the cg optimization procedures ConjugateGradient pass1( &smooth_func, err ); // pass1->set_patch_type(PatchData::ELEMENTS_ON_VERTEX_PATCH, err,1 ,1); pass1.use_global_patch(); pass1.set_debugging_level( 1 ); // Make sure no errors CPPUNIT_ASSERT( !err ); QualityAssessor qa = QualityAssessor( &smooth ); //**********Set stopping criterion 5 iterates **************** TerminationCriterion sc5; sc5.add_iteration_limit( 5 ); pass1.set_inner_termination_criterion( &sc5 ); // StoppingCriterion sc5(StoppingCriterion::NUMBER_OF_PASSES,5); // pass1->set_stopping_criterion(&sc5); TerminationCriterion sc_inner; sc_inner.add_iteration_limit( 5 ); pass1.set_inner_termination_criterion( &sc_inner ); // pass1->set_maximum_iteration(5); queue1.set_master_quality_improver( &pass1, err ); CPPUNIT_ASSERT( !err ); //********************UNTANGLE******************************* // Make sure no errors CPPUNIT_ASSERT( !err ); // launches optimization on mesh_set1 MeshDomainAssoc mesh_and_domain = MeshDomainAssoc( &mesh, &msq_geom ); double orig_qa_val = qa.loop_over_mesh( &mesh_and_domain, 0, err ); // Make sure no errors CPPUNIT_ASSERT( !err ); queue1.run_instructions( &mesh_and_domain, err ); CPPUNIT_ASSERT( !err ); // Make sure no errors CPPUNIT_ASSERT( !err ); double fin_qa_val = qa.loop_over_mesh( &mesh_and_domain, 0, err ); // Make sure no errors CPPUNIT_ASSERT( !err ); // make sure 'quality' improved CPPUNIT_ASSERT( ( fin_qa_val - orig_qa_val ) <= 0.0 ); print_timing_diagnostics( cout ); }
int PlanarGeometryTest::pF [private] |
Definition at line 102 of file PlanarGeometryTest.cpp.
double PlanarGeometryTest::qualTol [private] |
Definition at line 101 of file PlanarGeometryTest.cpp.
