MOAB: Mesh Oriented datABase
(version 5.2.1)
The untangle beta quality metric. More...
#include <UntangleBetaQualityMetric.hpp>
Public Member Functions | |
MESQUITE_EXPORT | UntangleBetaQualityMetric (double bet=0.05) |
For untangle beta, the constructor defaults to the SUM averaging method, and to the ELEMENT_VERTICES evaluation mode. | |
virtual MESQUITE_EXPORT | ~UntangleBetaQualityMetric () |
MESQUITE_EXPORT void | set_beta (double beta_in) |
MESQUITE_EXPORT double | get_beta () |
virtual MESQUITE_EXPORT std::string | get_name () const |
virtual MESQUITE_EXPORT int | get_negate_flag () const |
1 if metric should be minimized, -1 if metric should be maximized. | |
virtual MESQUITE_EXPORT bool | evaluate (PatchData &pd, size_t handle, double &value, MsqError &err) |
Get metric value at a logical location in the patch. | |
Private Attributes | |
double | mBeta |
Given a scalar value beta and local signed element volume alpha_i, define delta_i to be alpha_i minus beta. The Untangle beta value is then defined as square root of the sum over sample points of the absolute value of delta_i minus delta_i, difference squared. That is, the root mean square of the difference, abs(delta_i) minus delta_i.
The constructor defaults to RMS AveragingMethod and ELEMENT_VERTICES evaluationMode. The default beta value is .05.
Definition at line 61 of file UntangleBetaQualityMetric.hpp.
UntangleBetaQualityMetric::UntangleBetaQualityMetric | ( | double | bet = 0.05 | ) |
Definition at line 71 of file UntangleBetaQualityMetric.cpp.
: AveragingQM( RMS ), mBeta( bet ) {}
virtual MESQUITE_EXPORT MBMesquite::UntangleBetaQualityMetric::~UntangleBetaQualityMetric | ( | ) | [inline, virtual] |
Definition at line 67 of file UntangleBetaQualityMetric.hpp.
bool UntangleBetaQualityMetric::evaluate | ( | PatchData & | pd, |
size_t | handle, | ||
double & | value, | ||
MsqError & | err | ||
) | [virtual] |
Evaluate the metric at one location in the PatchData.
pd | The patch. |
handle | The location in the patch (as passed back from get_evaluations). |
value | The output metric value. |
Implements MBMesquite::QualityMetric.
Definition at line 83 of file UntangleBetaQualityMetric.cpp.
References MBMesquite::AveragingQM::average_metrics(), MBMesquite::PatchData::element_by_index(), MBMesquite::MsqMeshEntity::get_element_type(), MBMesquite::PatchData::get_vertex_array(), MBMesquite::MsqMeshEntity::get_vertex_index_array(), MBMesquite::HEXAHEDRON, mBeta, MSQ_ERRZERO, MBMesquite::MSQ_MAX_CAP, MBMesquite::MSQ_MAX_NUM_VERT_PER_ENT, MSQ_SETERR, MBMesquite::MSQ_SQRT_THREE, MBMesquite::MSQ_SQRT_THREE_INV, MBMesquite::MSQ_SQRT_TWO, MBMesquite::PRISM, MBMesquite::PYRAMID, MBMesquite::QUADRILATERAL, MBMesquite::TETRAHEDRON, MBMesquite::TRIANGLE, MBMesquite::MsqError::UNSUPPORTED_ELEMENT, untangle_function_2d(), and untangle_function_3d().
{ double met_vals[MSQ_MAX_NUM_VERT_PER_ENT]; fval = MSQ_MAX_CAP; const MsqMeshEntity* element = &pd.element_by_index( e_ind ); const size_t* v_i = element->get_vertex_index_array(); // only 3 temp_vec will be sent to untangle calculator, but the // additional vector3Ds may be needed during the calculations Vector3D temp_vec[5]; const MsqVertex* vertices = pd.get_vertex_array( err ); MSQ_ERRZERO( err ); EntityTopology type = element->get_element_type(); switch( type ) { case TRIANGLE: temp_vec[0] = vertices[v_i[1]] - vertices[v_i[0]]; temp_vec[2] = vertices[v_i[2]] - vertices[v_i[0]]; // make relative to equilateral temp_vec[1] = ( ( 2 * temp_vec[2] ) - temp_vec[0] ) * MSQ_SQRT_THREE_INV; untangle_function_2d( mBeta, temp_vec, e_ind, pd, fval, err ); break; case QUADRILATERAL: temp_vec[0] = vertices[v_i[1]] - vertices[v_i[0]]; temp_vec[1] = vertices[v_i[3]] - vertices[v_i[0]]; untangle_function_2d( mBeta, temp_vec, e_ind, pd, met_vals[0], err ); MSQ_ERRZERO( err ); temp_vec[0] = vertices[v_i[2]] - vertices[v_i[1]]; temp_vec[1] = vertices[v_i[0]] - vertices[v_i[1]]; untangle_function_2d( mBeta, temp_vec, e_ind, pd, met_vals[1], err ); MSQ_ERRZERO( err ); temp_vec[0] = vertices[v_i[3]] - vertices[v_i[2]]; temp_vec[1] = vertices[v_i[1]] - vertices[v_i[2]]; untangle_function_2d( mBeta, temp_vec, e_ind, pd, met_vals[2], err ); MSQ_ERRZERO( err ); temp_vec[0] = vertices[v_i[0]] - vertices[v_i[3]]; temp_vec[1] = vertices[v_i[2]] - vertices[v_i[3]]; untangle_function_2d( mBeta, temp_vec, e_ind, pd, met_vals[3], err ); MSQ_ERRZERO( err ); fval = average_metrics( met_vals, 4, err ); MSQ_ERRZERO( err ); break; case TETRAHEDRON: temp_vec[0] = vertices[v_i[1]] - vertices[v_i[0]]; temp_vec[3] = vertices[v_i[2]] - vertices[v_i[0]]; temp_vec[4] = vertices[v_i[3]] - vertices[v_i[0]]; // transform to equilateral tet temp_vec[1] = ( ( 2 * temp_vec[3] ) - temp_vec[0] ) / MSQ_SQRT_THREE; temp_vec[2] = ( ( 3 * temp_vec[4] ) - temp_vec[0] - temp_vec[3] ) / ( MSQ_SQRT_THREE * MSQ_SQRT_TWO ); untangle_function_3d( mBeta, temp_vec, fval ); break; case HEXAHEDRON: // transform to v_i[0] temp_vec[0] = vertices[v_i[1]] - vertices[v_i[0]]; temp_vec[1] = vertices[v_i[3]] - vertices[v_i[0]]; temp_vec[2] = vertices[v_i[4]] - vertices[v_i[0]]; untangle_function_3d( mBeta, temp_vec, met_vals[0] ); temp_vec[0] = vertices[v_i[2]] - vertices[v_i[1]]; temp_vec[1] = vertices[v_i[0]] - vertices[v_i[1]]; temp_vec[2] = vertices[v_i[5]] - vertices[v_i[1]]; untangle_function_3d( mBeta, temp_vec, met_vals[1] ); temp_vec[0] = vertices[v_i[3]] - vertices[v_i[2]]; temp_vec[1] = vertices[v_i[1]] - vertices[v_i[2]]; temp_vec[2] = vertices[v_i[6]] - vertices[v_i[2]]; untangle_function_3d( mBeta, temp_vec, met_vals[2] ); temp_vec[0] = vertices[v_i[0]] - vertices[v_i[3]]; temp_vec[1] = vertices[v_i[2]] - vertices[v_i[3]]; temp_vec[2] = vertices[v_i[7]] - vertices[v_i[3]]; untangle_function_3d( mBeta, temp_vec, met_vals[3] ); temp_vec[0] = vertices[v_i[7]] - vertices[v_i[4]]; temp_vec[1] = vertices[v_i[5]] - vertices[v_i[4]]; temp_vec[2] = vertices[v_i[0]] - vertices[v_i[4]]; untangle_function_3d( mBeta, temp_vec, met_vals[4] ); temp_vec[0] = vertices[v_i[4]] - vertices[v_i[5]]; temp_vec[1] = vertices[v_i[6]] - vertices[v_i[5]]; temp_vec[2] = vertices[v_i[1]] - vertices[v_i[5]]; untangle_function_3d( mBeta, temp_vec, met_vals[5] ); temp_vec[0] = vertices[v_i[5]] - vertices[v_i[6]]; temp_vec[1] = vertices[v_i[7]] - vertices[v_i[6]]; temp_vec[2] = vertices[v_i[2]] - vertices[v_i[6]]; untangle_function_3d( mBeta, temp_vec, met_vals[6] ); temp_vec[0] = vertices[v_i[6]] - vertices[v_i[7]]; temp_vec[1] = vertices[v_i[4]] - vertices[v_i[7]]; temp_vec[2] = vertices[v_i[3]] - vertices[v_i[7]]; untangle_function_3d( mBeta, temp_vec, met_vals[7] ); fval = average_metrics( met_vals, 8, err ); MSQ_ERRZERO( err ); break; case PYRAMID: for( unsigned i = 0; i < 4; ++i ) { temp_vec[0] = vertices[v_i[( i + 1 ) % 4]] - vertices[v_i[i]]; temp_vec[1] = vertices[v_i[( i + 3 ) % 4]] - vertices[v_i[i]]; temp_vec[3] = vertices[v_i[4]] - vertices[v_i[i]]; temp_vec[2] = ( 4 * temp_vec[3] - temp_vec[0] - temp_vec[1] ) / ( 2.0 - MSQ_SQRT_TWO ); untangle_function_3d( mBeta, temp_vec, met_vals[i] ); } fval = average_metrics( met_vals, 4, err ); MSQ_ERRZERO( err ); break; case PRISM: temp_vec[0] = vertices[v_i[1]] - vertices[v_i[0]]; temp_vec[3] = vertices[v_i[2]] - vertices[v_i[0]]; temp_vec[1] = ( ( 2 * temp_vec[3] ) - temp_vec[0] ) * MSQ_SQRT_THREE_INV; temp_vec[2] = vertices[v_i[3]] - vertices[v_i[0]]; untangle_function_3d( mBeta, temp_vec, met_vals[0] ); temp_vec[0] = vertices[v_i[2]] - vertices[v_i[1]]; temp_vec[3] = vertices[v_i[0]] - vertices[v_i[1]]; temp_vec[1] = ( ( 2 * temp_vec[3] ) - temp_vec[0] ) * MSQ_SQRT_THREE_INV; temp_vec[2] = vertices[v_i[4]] - vertices[v_i[1]]; untangle_function_3d( mBeta, temp_vec, met_vals[1] ); temp_vec[0] = vertices[v_i[0]] - vertices[v_i[2]]; temp_vec[3] = vertices[v_i[1]] - vertices[v_i[2]]; temp_vec[1] = ( ( 2 * temp_vec[3] ) - temp_vec[0] ) * MSQ_SQRT_THREE_INV; temp_vec[2] = vertices[v_i[5]] - vertices[v_i[2]]; untangle_function_3d( mBeta, temp_vec, met_vals[2] ); temp_vec[0] = vertices[v_i[5]] - vertices[v_i[3]]; temp_vec[3] = vertices[v_i[4]] - vertices[v_i[3]]; temp_vec[1] = ( ( 2 * temp_vec[3] ) - temp_vec[0] ) * MSQ_SQRT_THREE_INV; temp_vec[2] = vertices[v_i[0]] - vertices[v_i[3]]; untangle_function_3d( mBeta, temp_vec, met_vals[3] ); temp_vec[0] = vertices[v_i[3]] - vertices[v_i[4]]; temp_vec[3] = vertices[v_i[5]] - vertices[v_i[4]]; temp_vec[1] = ( ( 2 * temp_vec[3] ) - temp_vec[0] ) * MSQ_SQRT_THREE_INV; temp_vec[2] = vertices[v_i[1]] - vertices[v_i[4]]; untangle_function_3d( mBeta, temp_vec, met_vals[4] ); temp_vec[0] = vertices[v_i[4]] - vertices[v_i[5]]; temp_vec[3] = vertices[v_i[3]] - vertices[v_i[5]]; temp_vec[1] = ( ( 2 * temp_vec[3] ) - temp_vec[0] ) * MSQ_SQRT_THREE_INV; temp_vec[2] = vertices[v_i[2]] - vertices[v_i[5]]; untangle_function_3d( mBeta, temp_vec, met_vals[5] ); fval = average_metrics( met_vals, 6, err ); MSQ_ERRZERO( err ); break; default: MSQ_SETERR( err ) ( MsqError::UNSUPPORTED_ELEMENT, "Unsupported cell type (%d) for Untangle quality metric.", type ); fval = MSQ_MAX_CAP; return false; } // end switch over element type return true; }
MESQUITE_EXPORT double MBMesquite::UntangleBetaQualityMetric::get_beta | ( | ) | [inline] |
Function to allow the user to check the value of beta.
Definition at line 76 of file UntangleBetaQualityMetric.hpp.
References mBeta.
{ return mBeta; }
std::string UntangleBetaQualityMetric::get_name | ( | ) | const [virtual] |
Definition at line 73 of file UntangleBetaQualityMetric.cpp.
{ return "Untangle Beta"; }
int UntangleBetaQualityMetric::get_negate_flag | ( | ) | const [virtual] |
Definition at line 78 of file UntangleBetaQualityMetric.cpp.
return 1;
MESQUITE_EXPORT void MBMesquite::UntangleBetaQualityMetric::set_beta | ( | double | beta_in | ) | [inline] |
Function to allow users to set the beta value after the metric has already been created.
Definition at line 71 of file UntangleBetaQualityMetric.hpp.
References mBeta.
{ mBeta = beta_in; }
double MBMesquite::UntangleBetaQualityMetric::mBeta [private] |
Definition at line 88 of file UntangleBetaQualityMetric.hpp.
Referenced by evaluate(), get_beta(), and set_beta().
