MBMesquite::AveragingQM Class Reference
Averaging functionality for use in quality metrics. More...
#include <AveragingQM.hpp>
+ Inheritance diagram for MBMesquite::AveragingQM:
Public Member Functions
MESQUITE_EXPORT AveragingQM (QualityMetric::AveragingMethod method)
virtual ~AveragingQM ()
MESQUITE_EXPORT void set_averaging_method (QualityMetric::AveragingMethod method)
MESQUITE_EXPORT void set_averaging_method (QualityMetric::AveragingMethod method, MsqError &)
MESQUITE_EXPORT
get_averaging_method () const
bool analytical_average_gradient ()
bool analytical_average_hessian ()
double average_metrics (const double metric_values[], int num_values, MsqError &err)
double average_metric_and_weights (double metric_values[], int num_metric_values, MsqError &err)
double average_corner_gradients (EntityTopology element_type, uint32_t fixed_vertices, unsigned num_corners, double corner_values[], const Vector3D corner_grads[], Vector3D vertex_grads[], MsqError &err)
 Average metric values and gradients for per-corner evaluation.
double average_corner_hessian_diagonals (EntityTopology element_type, uint32_t fixed_vertices, unsigned num_corners, const double corner_values[], const Vector3D corner_grads[], const Matrix3D corner_hessians[], Vector3D vertex_grads[], SymMatrix3D vertex_hessians[], MsqError &err)
 Average metric values, gradients, and Hessian diagonal blocks for per-corner evaluation.
double average_corner_hessian_diagonals (EntityTopology element_type, uint32_t fixed_vertices, unsigned num_corners, const double corner_values[], const Vector3D corner_grads[], const SymMatrix3D corner_hess_diag[], Vector3D vertex_grads[], SymMatrix3D vertex_hessians[], MsqError &err)
double average_corner_hessians (EntityTopology element_type, uint32_t fixed_vertices, unsigned num_corners, const double corner_values[], const Vector3D corner_grads[], const Matrix3D corner_hessians[], Vector3D vertex_grads[], Matrix3D vertex_hessians[], MsqError &err)
 Average metric values, gradients, and Hessians for per-corner evaluation.
Private Attributes
QualityMetric::AveragingMethod avgMethod
Detailed Description
Definition at line 55 of file AveragingQM.hpp.
virtual MBMesquite::AveragingQM::~AveragingQM ( ) [inline, virtual]
Definition at line 60 of file AveragingQM.hpp.
Member Function Documentation
Return true if the requested averaging scheme is supported for analytical calculation of gradients.
Definition at line 80 of file AveragingQM.hpp.
References avgMethod, and MBMesquite::QualityMetric::LAST_WITH_GRADIENT.
Referenced by MBMesquite::IdealWeightMeanRatio::evaluate_with_gradient(), and MBMesquite::IdealWeightInverseMeanRatio::evaluate_with_gradient().
double MBMesquite::AveragingQM::average_corner_gradients ( EntityTopology  element_type,
MsqError err
Parameters:
element_typeThe element type
num_cornersThe number of corners (e.g. pass 4 for a pyramid if the metric couldn't be evaluated for the apex)
corner_valuesAn array of metric values, one per element corner
corner_gradsThe corner gradients, 4 for each corner
vertex_gradsOutput. Gradient at each vertex.
Returns:
average metric value for element
Definition at line 49 of file AveragingQM.cpp.
References average_metric_and_weights(), corners, dim, and MSQ_ERRZERO.
Referenced by AveragingQMTest::check_average_gradient_fails(), AveragingQMTest::check_average_gradients(), MBMesquite::IdealWeightMeanRatio::evaluate_with_gradient(), and MBMesquite::IdealWeightInverseMeanRatio::evaluate_with_gradient().
    const unsigned num_vertex = TopologyInfo::corners( type );
    const unsigned dim        = TopologyInfo::dimension( type );
    const unsigned per_vertex = dim + 1;
    unsigned i, j, num_adj;
    const unsigned *adj_idx, *rev_idx;
    // NOTE: This function changes the corner_values array such that
    //       it contains the gradient coefficients.
    double avg = average_metric_and_weights( corner_values, num_corner, err );
    MSQ_ERRZERO( err );
    for( i = 0; i < num_vertex; ++i )
        if( fixed_vertices & ( 1 << i ) )  // skip fixed vertices
            continue;
        adj_idx = TopologyInfo::adjacent_vertices( type, i, num_adj );
        rev_idx = TopologyInfo::reverse_vertex_adjacency_offsets( type, i, num_adj );
        if( i < num_corner )  // not all vertices are corners (e.g. pyramid)
            vertex_grads[i] = corner_values[i] * corner_grads[per_vertex * i];
        else
            vertex_grads[i] = 0;
        for( j = 0; j < num_adj; ++j )
            const unsigned v = adj_idx[j], c = rev_idx[j] + 1;
            if( v >= num_corner )  // if less corners than vertices (e.g. pyramid apex)
                continue;
            vertex_grads[i] += corner_values[v] * corner_grads[per_vertex * v + c];
    return avg;
double MBMesquite::AveragingQM::average_corner_hessian_diagonals ( EntityTopology  element_type,
MsqError err
Parameters:
corner_hessiansThe hessians, 10 for each corner
vertex_hessiansOutput. Hessian diagonal block for each vertex.
Returns:
Definition at line 354 of file AveragingQM.cpp.
References MBMesquite::average_corner_diagonals(), and avgMethod.
Referenced by AveragingQMTest::check_hessian_diagonal_fails(), AveragingQMTest::check_pmean_hessian_diagonals(), MBMesquite::IdealWeightMeanRatio::evaluate_with_Hessian_diagonal(), and MBMesquite::IdealWeightInverseMeanRatio::evaluate_with_Hessian_diagonal().
    return average_corner_diagonals( element_type, avgMethod, num_corners, corner_values, corner_grads,
                                     CornerHessDiagIterator( corner_hessians, element_type ), vertex_grads,
                                     vertex_hessians, err );
MsqError err
Parameters:
corner_hess_diagThe diagonal blocks of the Hessian: 4 for each corner.
Returns:
Definition at line 369 of file AveragingQM.cpp.
                                     corner_hess_diag, vertex_grads, vertex_hessians, err );
double MBMesquite::AveragingQM::average_corner_hessians ( EntityTopology  element_type,
MsqError err
Parameters:
vertex_hessiansOutput. Hessians. Length must be (n*(n+1))/2, where n is the number of vertices in the element.
Returns:
Definition at line 559 of file AveragingQM.cpp.
References avgMethod, corners, MBMesquite::QualityMetric::HARMONIC, MBMesquite::QualityMetric::HMS, MBMesquite::inv(), MBMesquite::MsqError::INVALID_STATE, MBMesquite::QualityMetric::LINEAR, MSQ_SETERR, MBMesquite::pmean_corner_hessians(), MBMesquite::QualityMetric::RMS, MBMesquite::QualityMetric::SUM, MBMesquite::sum_corner_hessians(), MBMesquite::sum_sqr_corner_hessians(), and MBMesquite::QualityMetric::SUM_SQUARED.
Referenced by AveragingQMTest::check_hessian_fails(), AveragingQMTest::check_pmean_hessian(), MBMesquite::IdealWeightMeanRatio::evaluate_with_Hessian(), and MBMesquite::IdealWeightInverseMeanRatio::evaluate_with_Hessian().
    unsigned i;
    double avg, inv;
    // Zero gradients and Hessians
        vertex_grads[i].set( 0.0 );
    const unsigned num_hess = num_vertex * ( num_vertex + 1 ) / 2;
    for( i = 0; i < num_hess; ++i )
        vertex_hessians[i].zero();
    switch( avgMethod )
        case QualityMetric::SUM:
            avg = sum_corner_hessians( type, num_corner, corner_values, corner_grads, corner_hessians, vertex_grads,
                                       vertex_hessians );
            break;
        case QualityMetric::LINEAR:
                                       vertex_hessians );
            inv = 1.0 / num_corner;
            avg *= inv;
                vertex_grads[i] *= inv;
                vertex_hessians[i] *= inv;
            break;
        case QualityMetric::SUM_SQUARED:
            avg = sum_sqr_corner_hessians( type, num_corner, corner_values, corner_grads, corner_hessians, vertex_grads,
                                           vertex_hessians );
            break;
        case QualityMetric::RMS:
            avg = pmean_corner_hessians( type, num_corner, corner_values, corner_grads, corner_hessians, vertex_grads,
                                         vertex_hessians, 2.0 );
            break;
        case QualityMetric::HARMONIC:
                                         vertex_hessians, -1.0 );
            break;
        case QualityMetric::HMS:
                                         vertex_hessians, -2.0 );
            break;
        default:
            MSQ_SETERR( err )( "averaging method not available.", MsqError::INVALID_STATE );
            return 0.0;
    return avg;
double MBMesquite::AveragingQM::average_metric_and_weights ( double  metric_values[],
MsqError err
Given a list of metric values, calculate the average metric valude according to the current avgMethod and write into the passed metric_values array the the value weight/count to use when averaging gradient vectors for the metric.
Parameters:
metric_values: As input, a set of quality metric values to average. As output, the fraction of the corresponding gradient vector that contributes to the average gradient.
num_metric_valuesThe number of values in the passed array.
Definition at line 626 of file AveragingQM.cpp.
References avgMethod, MBMesquite::QualityMetric::GEOMETRIC, MBMesquite::QualityMetric::HARMONIC, MBMesquite::QualityMetric::HMS, MBMesquite::MsqError::INVALID_STATE, MBMesquite::QualityMetric::LINEAR, MBMesquite::QualityMetric::MAXIMUM, MBMesquite::QualityMetric::MINIMUM, MSQ_DBGOUT, MBMesquite::MSQ_MIN, MSQ_SETERR, MBMesquite::QualityMetric::RMS, MBMesquite::QualityMetric::SUM, and MBMesquite::QualityMetric::SUM_SQUARED.
Referenced by average_corner_gradients(), AveragingQMTest::check_average_and_weights(), AveragingQMTest::check_average_and_weights_fails(), and AveragingQMTest::check_average_gradients().
    static bool min_max_warning = false;
    double avg                  = 0.0;
    int i, tmp_count;
    double f;
    switch( avgMethod )
        case QualityMetric::MINIMUM:
            if( !min_max_warning )
                MSQ_DBGOUT( 1 ) << "Minimum and maximum not continuously differentiable.\n"
                                   "Element of subdifferential will be returned.\n";
                min_max_warning = true;
            avg = metrics[0];
            for( i = 1; i < count; ++i )
                if( metrics[i] < avg ) avg = metrics[i];
            tmp_count = 0;
            for( i = 0; i < count; ++i )
                if( metrics[i] - avg <= MSQ_MIN )
                    metrics[i] = 1.0;
                    ++tmp_count;
                else
                    metrics[i] = 0.0;
            f = 1.0 / tmp_count;
                metrics[i] *= f;
            break;
        case QualityMetric::MAXIMUM:
            avg = metrics[0];
                if( metrics[i] > avg ) avg = metrics[i];
            tmp_count = 0;
                if( avg - metrics[i] <= MSQ_MIN )
                    metrics[i] = 1.0;
                    ++tmp_count;
                else
                    metrics[i] = 0.0;
                metrics[i] *= f;
            break;
                avg += metrics[i];
                metrics[i] = 1.0;
            break;
                avg += ( metrics[i] * metrics[i] );
                metrics[i] *= 2;
            break;
            f = 1.0 / count;
                avg += metrics[i];
                metrics[i] = f;
            avg *= f;
            break;
        case QualityMetric::GEOMETRIC:
            avg = 1.0;
                avg *= metrics[i];
            avg = pow( avg, 1.0 / count );
            f = avg / count;
                metrics[i] = f / metrics[i];
            break;
                avg += metrics[i] * metrics[i];
            avg = sqrt( avg / count );
            f = 1. / ( avg * count );
                metrics[i] *= f;
            break;
                avg += 1.0 / metrics[i];
            avg = count / avg;
                metrics[i] = ( avg * avg ) / ( count * metrics[i] * metrics[i] );
            break;
                avg += 1. / ( metrics[i] * metrics[i] );
            avg = sqrt( count / avg );
            f = avg * avg * avg / count;
                metrics[i] = f / ( metrics[i] * metrics[i] * metrics[i] );
            break;
        default:
    return avg;
double MBMesquite::AveragingQM::average_metrics ( const double  metric_values[],
int  num_values,
MsqError err
average_metrics takes an array of length num_values and averages the contents using averaging method data member avgMethod .
average_metrics takes an array of length num_value and averages the contents using averaging method 'method'.
Definition at line 784 of file AveragingQM.cpp.
References avgMethod, MBMesquite::QualityMetric::GEOMETRIC, MBMesquite::QualityMetric::HARMONIC, MBMesquite::QualityMetric::HMS, MBMesquite::QualityMetric::LINEAR, MBMesquite::QualityMetric::MAX_MINUS_MIN, MBMesquite::QualityMetric::MAX_OVER_MIN, MBMesquite::QualityMetric::MAXIMUM, MBMesquite::QualityMetric::MINIMUM, MBMesquite::MSQ_MAX_CAP, MBMesquite::MSQ_MIN, MSQ_SETERR, NOT_IMPLEMENTED, MBMesquite::QualityMetric::RMS, MBMesquite::QualityMetric::STANDARD_DEVIATION, MBMesquite::QualityMetric::SUM, MBMesquite::QualityMetric::SUM_OF_RATIOS_SQUARED, and MBMesquite::QualityMetric::SUM_SQUARED.
Referenced by AveragingQMTest::check_average_and_weights(), MBMesquite::VertexConditionNumberQualityMetric::evaluate(), MBMesquite::LocalSizeQualityMetric::evaluate(), MBMesquite::ConditionNumberQualityMetric::evaluate(), MBMesquite::IdealWeightMeanRatio::evaluate(), MBMesquite::UntangleBetaQualityMetric::evaluate(), MBMesquite::IdealWeightInverseMeanRatio::evaluate(), MBMesquite::EdgeLengthQualityMetric::evaluate_common(), MBMesquite::EdgeLengthRangeQualityMetric::evaluate_common(), AveragingQMTest::test_average_metrics_geometric(), AveragingQMTest::test_average_metrics_harmonic(), AveragingQMTest::test_average_metrics_hms(), AveragingQMTest::test_average_metrics_liner(), AveragingQMTest::test_average_metrics_max_minus_min(), AveragingQMTest::test_average_metrics_max_over_min(), AveragingQMTest::test_average_metrics_maximum(), AveragingQMTest::test_average_metrics_minimum(), AveragingQMTest::test_average_metrics_rms(), AveragingQMTest::test_average_metrics_standard_deviation(), AveragingQMTest::test_average_metrics_sum(), AveragingQMTest::test_average_metrics_sum_of_ratios_squared(), and AveragingQMTest::test_average_metrics_sum_squared().
    // MSQ_MAX needs to be made global?
    // double MSQ_MAX=1e10;
    double total_value = 0.0;
    double temp_value  = 0.0;
    int i              = 0;
    int j              = 0;
    // if no values, return zero
    if( num_values <= 0 )
        return 0.0;
    switch( avgMethod )
            total_value = 1.0;
            for( i = 0; i < num_values; ++i )
                total_value *= ( metric_values[i] );
            total_value = pow( total_value, 1.0 / num_values );
            break;
            // ensure no divide by zero, return zero
                if( metric_values[i] < MSQ_MIN )
                    if( metric_values[i] > MSQ_MIN )
                        return 0.0;
                total_value += ( 1 / metric_values[i] );
            // ensure no divide by zero, return MSQ_MAX_CAP
            if( total_value < MSQ_MIN )
                if( total_value > MSQ_MIN )
                    return MSQ_MAX_CAP;
            total_value = num_values / total_value;
            break;
                total_value += metric_values[i];
            total_value /= (double)num_values;
            break;
            total_value = metric_values[0];
            for( i = 1; i < num_values; ++i )
                if( metric_values[i] > total_value )
                    total_value = metric_values[i];
            break;
                if( metric_values[i] < total_value )
            break;
                total_value += ( metric_values[i] * metric_values[i] );
            total_value = sqrt( total_value );
            break;
                if( metric_values[i] * metric_values[i] < MSQ_MIN )
                    return 0.0;
                total_value += ( 1.0 / ( metric_values[i] * metric_values[i] ) );
                return MSQ_MAX_CAP;
            total_value = sqrt( num_values / total_value );
            break;
        case QualityMetric::STANDARD_DEVIATION:
            total_value = 0;
            temp_value  = 0;
                temp_value += metric_values[i];
            temp_value /= (double)num_values;
            temp_value *= temp_value;
            total_value = total_value - temp_value;
            break;
            break;
            break;
        case QualityMetric::MAX_MINUS_MIN:
            // total_value used to store the maximum
            // temp_value used to store the minimum
            temp_value = MSQ_MAX_CAP;
                if( metric_values[i] < temp_value )
                    temp_value = metric_values[i];
            total_value -= temp_value;
            break;
        case QualityMetric::MAX_OVER_MIN:
            if( fabs( temp_value ) < MSQ_MIN )
                return MSQ_MAX_CAP;
            total_value /= temp_value;
            break;
        case QualityMetric::SUM_OF_RATIOS_SQUARED:
            for( j = 0; j < num_values; ++j )
                if( fabs( metric_values[j] ) < MSQ_MIN )
                    return MSQ_MAX_CAP;
                    total_value +=
                        ( ( metric_values[i] / metric_values[j] ) * ( metric_values[i] / metric_values[j] ) );
            total_value /= (double)( num_values * num_values );
            break;
        default:
            // Return error saying Averaging Method mode not implemented
            MSQ_SETERR( err )
            ( "Requested Averaging Method Not Implemented", MsqError::NOT_IMPLEMENTED );
            return 0;
    return total_value;
Member Data Documentation
List of all members.
