MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /* ***************************************************************** 00002 MESQUITE -- The Mesh Quality Improvement Toolkit 00003 00004 Copyright 2004 Sandia Corporation and Argonne National 00005 Laboratory. Under the terms of Contract DE-AC04-94AL85000 00006 with Sandia Corporation, the U.S. Government retains certain 00007 rights in this software. 00008 00009 This library is free software; you can redistribute it and/or 00010 modify it under the terms of the GNU Lesser General Public 00011 License as published by the Free Software Foundation; either 00012 version 2.1 of the License, or (at your option) any later version. 00013 00014 This library is distributed in the hope that it will be useful, 00015 but WITHOUT ANY WARRANTY; without even the implied warranty of 00016 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00017 Lesser General Public License for more details. 00018 00019 You should have received a copy of the GNU Lesser General Public License 00020 (lgpl.txt) along with this library; if not, write to the Free Software 00021 Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA 00022 00023 diachin2@llnl.gov, djmelan@sandia.gov, mbrewer@sandia.gov, 00024 pknupp@sandia.gov, tleurent@mcs.anl.gov, tmunson@mcs.anl.gov 00025 00026 ***************************************************************** */ 00027 /*! \file LocalSizeQualityMetric.cpp 00028 \author Michael Brewer 00029 \date April 9, 2003 00030 Evaluates the corner volume (or areas) of the element corners 00031 attached to a given vertiex and then averages those values 00032 together. 00033 */ 00034 00035 #include "LocalSizeQualityMetric.hpp" 00036 #include "PatchData.hpp" 00037 00038 using namespace MBMesquite; 00039 00040 //! Calculate the area of the triangle formed by the three vertices. 00041 static inline double compute_corner_area( PatchData& pd, size_t vert_1, size_t vert_2, size_t vert_3, MsqError& err ) 00042 { 00043 const MsqVertex* verts = pd.get_vertex_array( err ); 00044 Vector3D vec_1 = verts[vert_2] - verts[vert_1]; 00045 Vector3D vec_2 = verts[vert_3] - verts[vert_1]; 00046 Vector3D cross_vec = vec_1 * vec_2; 00047 return ( cross_vec.length() / 2.0 ); 00048 } 00049 00050 //! Calculate the volume of the tetrahedron formed by the four vertices. 00051 static inline double compute_corner_volume( PatchData& pd, 00052 size_t vert_1, 00053 size_t vert_2, 00054 size_t vert_3, 00055 size_t vert_4, 00056 MsqError& err ) 00057 { 00058 const MsqVertex* verts = pd.get_vertex_array( err ); 00059 Vector3D vec_1 = verts[vert_2] - verts[vert_1]; 00060 Vector3D vec_2 = verts[vert_3] - verts[vert_1]; 00061 Vector3D vec_3 = verts[vert_4] - verts[vert_1]; 00062 return fabs( ( vec_3 % ( vec_1 * vec_2 ) ) / 6.0 ); 00063 } 00064 00065 LocalSizeQualityMetric::~LocalSizeQualityMetric() {} 00066 00067 std::string LocalSizeQualityMetric::get_name() const 00068 { 00069 return "Local Size"; 00070 } 00071 00072 int LocalSizeQualityMetric::get_negate_flag() const 00073 { 00074 return 1; 00075 } 00076 00077 /*!For the given vertex, vert, with connected elements, e_i for i=1...K, 00078 the LocalSizeQualityMetric computes the corner volumes (or areas) of 00079 each e_i at the corner defined by vert. The corner volume is defined 00080 as the volume of the tet defined by the edges of an element which contain 00081 the common vertex, vert. That volume is then diveded by the average corner 00082 volume of all the element corners connected to this vertex. For 00083 vertices attached to pyramid elements, this metric is undefined. 00084 */ 00085 bool LocalSizeQualityMetric::evaluate( PatchData& pd, size_t this_vert, double& fval, MsqError& err ) 00086 { 00087 fval = 0.0; 00088 // get the element array 00089 MsqMeshEntity* elems = pd.get_element_array( err ); 00090 MSQ_ERRZERO( err ); 00091 // get the vertex to element array and the offset array 00092 // const size_t* elem_offset = pd.get_vertex_to_elem_offset(err); MSQ_ERRZERO(err); 00093 // const size_t* v_to_e_array = pd.get_vertex_to_elem_array(err); MSQ_ERRZERO(err); 00094 // find the offset for this vertex 00095 // size_t this_offset = elem_offset[this_vert]; 00096 // get the number of elements attached to this vertex (given by the 00097 // first entry in the vertex to element array) 00098 // size_t num_elems = v_to_e_array[this_offset]; 00099 // PRINT_INFO("\nIN LOCAL SIZE CPP, num_elements = %i",num_elems); 00100 size_t num_elems; 00101 const size_t* v_to_e_array = pd.get_vertex_element_adjacencies( this_vert, num_elems, err ); 00102 MSQ_ERRZERO( err ); 00103 00104 if( num_elems <= 0 ) 00105 { 00106 return true; 00107 } 00108 00109 // create an array to store the local metric values before averaging 00110 // Can we remove this dynamic allocatio? 00111 double* met_vals = new double[num_elems]; 00112 // vector to hold the other verts which form a corner. 00113 std::vector< size_t > other_vertices; 00114 other_vertices.reserve( 4 ); 00115 double total_val = 0.0; 00116 size_t i = 0; 00117 // loop over the elements attached to this vertex 00118 for( i = 0; i < num_elems; ++i ) 00119 { 00120 // get the vertices which (with this_vert) form the corner of 00121 // the ith element. 00122 elems[v_to_e_array[i]].get_connected_vertices( this_vert, other_vertices, err ); 00123 MSQ_ERRZERO( err ); 00124 ////PRINT_INFO("\nINSIDE LOCAL SIZE CPP other_vertices size = %i",other_vertices.size()); 00125 00126 switch( other_vertices.size() ) 00127 { 00128 // if a surface element, compute the corner area 00129 case 2: 00130 met_vals[i] = compute_corner_area( pd, this_vert, other_vertices[0], other_vertices[1], err ); 00131 MSQ_ERRZERO( err ); 00132 break; 00133 // if a volume element, compute the corner volume 00134 case 3: 00135 met_vals[i] = compute_corner_volume( pd, this_vert, other_vertices[0], other_vertices[1], 00136 other_vertices[2], err ); 00137 MSQ_ERRZERO( err ); 00138 break; 00139 default: 00140 // otherwise, there is was an error. Either the wrong number 00141 // of vertices were returned fom get_connected_vertices or 00142 // the element does not have the correct number of edges 00143 // connected to this vertex (possibly a pyramid element). 00144 met_vals[i] = 0.0; 00145 MSQ_SETERR( err ) 00146 ( "Incorrect number of vertices returned from " 00147 "get_connected_vertices.", 00148 MsqError::UNSUPPORTED_ELEMENT ); 00149 return false; 00150 }; 00151 // keep track of total so that we can compute the linear average 00152 total_val += met_vals[i]; 00153 // PRINT_INFO("\nIN LOCAL SIZE CPP, total_val = %f, i = %i",total_val,i); 00154 // clear the vector of other_vertices for re-use. 00155 other_vertices.clear(); 00156 // PRINT_INFO("\nIN LOCAL SIZE CPP, after clean size = %f",other_vertices.size()); 00157 } 00158 // calculate the linear average... num_elems is non-zero here. 00159 total_val /= (double)num_elems; 00160 // PRINT_INFO("\nIN LOCAL SIZE CPP, average = %f",total_val); 00161 // if the average is non-zero 00162 // divide each entry by the linear average 00163 if( total_val != 0 ) 00164 { 00165 for( i = 0; i < num_elems; ++i ) 00166 { 00167 met_vals[i] /= total_val; 00168 } 00169 // calculate fval by averaging the corner values 00170 fval = average_metrics( met_vals, num_elems, err ); 00171 MSQ_ERRZERO( err ); 00172 // PRINT_INFO("\nIN LOCAL SIZE CPP, inside if statement"); 00173 } 00174 // PRINT_INFO("\nIN LOCAL SIZE CPP, fval = %f",fval); 00175 // clean up the dynamically allocated array 00176 delete[] met_vals; 00177 // always return true... the vertex position is never invalid 00178 return true; 00179 } 00180 00181 bool LocalSizeQualityMetric::evaluate_with_indices( PatchData& pd, 00182 size_t vertex, 00183 double& value, 00184 std::vector< size_t >& indices, 00185 MsqError& err ) 00186 { 00187 indices.clear(); 00188 pd.get_adjacent_vertex_indices( vertex, indices, err ); 00189 MSQ_ERRZERO( err ); 00190 00191 std::vector< size_t >::iterator r, w; 00192 for( r = w = indices.begin(); r != indices.end(); ++r ) 00193 { 00194 if( *r < pd.num_free_vertices() ) 00195 { 00196 *w = *r; 00197 ++w; 00198 } 00199 } 00200 indices.erase( w, indices.end() ); 00201 if( vertex < pd.num_free_vertices() ) indices.push_back( vertex ); 00202 00203 bool rval = evaluate( pd, vertex, value, err ); 00204 return !MSQ_CHKERR( err ) && rval; 00205 }
