MOAB: Mesh Oriented datABase
(version 5.2.1)
#include <PlanarDomain.hpp>
Public Types | |
enum | Plane { XY = 2, XZ = 1, YZ = 0 } |
Public Member Functions | |
PlanarDomain (Plane orient, double offset=0.0) | |
PlanarDomain () | |
PlanarDomain (const Vector3D &normal, const Vector3D &point) | |
virtual | ~PlanarDomain () |
void | fit_vertices (Mesh *mesh, MsqError &err, double epsilon=0.0) |
void | fit_vertices (Mesh *mesh, const Mesh::VertexHandle *vertex_array, size_t vertex_array_length, MsqError &err, double epsilon=0.0) |
void | set_plane (const Vector3D &normal, const Vector3D &point) |
void | flip () |
const Vector3D & | get_normal () const |
double | get_coeff () |
Vector3D | get_origin () const |
virtual void | snap_to (Mesh::VertexHandle entity_handle, Vector3D &coordinate) const |
virtual void | vertex_normal_at (Mesh::VertexHandle entity_handle, Vector3D &coordinate) const |
virtual void | element_normal_at (Mesh::ElementHandle entity_handle, Vector3D &coordinate) const |
virtual void | vertex_normal_at (const Mesh::VertexHandle *handle, Vector3D coords[], unsigned count, MsqError &err) const |
evaluate surface normals | |
virtual void | closest_point (Mesh::VertexHandle handle, const Vector3D &position, Vector3D &closest, Vector3D &normal, MsqError &err) const |
evaluate closest point and normal | |
virtual void | domain_DoF (const Mesh::VertexHandle *handle_array, unsigned short *dof_array, size_t num_vertices, MsqError &err) const |
Private Attributes | |
Vector3D | mNormal |
double | mCoeff |
This is a template for a planar domain. It will provide the normal information necessary for surface mesh optimization.
Definition at line 49 of file PlanarDomain.hpp.
MBMesquite::PlanarDomain::PlanarDomain | ( | Plane | orient, |
double | offset = 0.0 |
) | [inline] |
Definition at line 59 of file PlanarDomain.hpp.
{ Vector3D normal( 0, 0, 0 ), point( 0, 0, 0 ); normal[orient] = 1.0; point[orient] = offset; set_plane( normal, point ); }
MBMesquite::PlanarDomain::PlanarDomain | ( | ) | [inline] |
Definition at line 67 of file PlanarDomain.hpp.
MBMesquite::PlanarDomain::PlanarDomain | ( | const Vector3D & | normal, |
const Vector3D & | point | ||
) | [inline] |
Definition at line 69 of file PlanarDomain.hpp.
{ set_plane( normal, point ); }
MBMesquite::PlanarDomain::~PlanarDomain | ( | ) | [virtual] |
Definition at line 35 of file PlanarDomain.cpp.
void MBMesquite::PlanarDomain::closest_point | ( | Mesh::VertexHandle | handle, |
const Vector3D & | position, | ||
Vector3D & | closest, | ||
Vector3D & | normal, | ||
MsqError & | err | ||
) | const [virtual] |
Given a position in space, return the closest position in the domain and the domain normal at that point.
entity_handle | Evaluate the subset of the domain contianing this entity |
position | Input position for which to evaluate |
closest | Closest position in the domain. |
normal | Domain normal at the location of 'closest' |
Implements MBMesquite::MeshDomain.
Definition at line 68 of file PlanarDomain.cpp.
void MBMesquite::PlanarDomain::domain_DoF | ( | const Mesh::VertexHandle * | handle_array, |
unsigned short * | dof_array, | ||
size_t | num_vertices, | ||
Definition at line 76 of file PlanarDomain.cpp.
{ std::fill( dof_array, dof_array + num_vertices, 2 ); }
void MBMesquite::PlanarDomain::element_normal_at | ( | Mesh::ElementHandle | entity_handle, |
MBMesquite::Vector3D & | coordinate | ||
Definition at line 55 of file PlanarDomain.cpp.
{ coordinate = mNormal; }
void MBMesquite::PlanarDomain::fit_vertices | ( | Mesh * | mesh, |
MsqError & | err, | ||
double | epsilon = 0.0 |
Definition at line 88 of file PlanarDomain.cpp.
References MBMesquite::arrptr(), MBMesquite::MsqError::clear(), MBMesquite::Mesh::elements_get_attached_vertices(), MBMesquite::Mesh::elements_get_topologies(), epsilon, fixed, MBMesquite::Mesh::get_all_elements(), MBMesquite::Mesh::get_all_vertices(), MBMesquite::DomainUtil::get_fixed_vertices(), MSQ_ERRRTN, n, and MBMesquite::Mesh::vertices_get_coordinates().
Referenced by main(), and PlanarGeometryTest::test_fit_plane().
{ // Our goal here is to consider only the boundary (fixed) vertices // when calculating the plane. If for some reason the user wants // to snap a not-quite-planar mesh to a plane during optimization, // if possible we want to start with the plane containing the fixed // vertices, as those won't get snapped. If no vertices are fixed, // then treat them all as fixed for the purpose calculating the plane // (consider them all.) std::vector< Mesh::VertexHandle > verts, fixed; mesh->get_all_vertices( verts, err );MSQ_ERRRTN( err ); DomainUtil::get_fixed_vertices( mesh, arrptr( verts ), verts.size(), fixed, err );MSQ_ERRRTN( err ); bool do_all_verts = true; if( fixed.size() > 2 ) { do_all_verts = false; fit_vertices( mesh, arrptr( fixed ), fixed.size(), err, epsilon ); // if we failed with only the fixed vertices, try again with all of the // vertices if( err ) { err.clear(); do_all_verts = true; } } if( do_all_verts ) { fit_vertices( mesh, arrptr( verts ), verts.size(), err, epsilon );MSQ_ERRRTN( err ); } // now count inverted elements size_t inverted_count = 0, total_count = 0; std::vector< Mesh::ElementHandle > elems; std::vector< size_t > junk; std::vector< MsqVertex > coords; mesh->get_all_elements( elems, err );MSQ_ERRRTN( err ); for( size_t i = 0; i < elems.size(); ++i ) { EntityTopology type; mesh->elements_get_topologies( &elems[i], &type, 1, err ); if( TopologyInfo::dimension( type ) != 2 ) continue; verts.clear(); mesh->elements_get_attached_vertices( arrptr( elems ), 1, verts, junk, err );MSQ_ERRRTN( err ); if( verts.size() < 3 ) continue; coords.resize( verts.size() ); mesh->vertices_get_coordinates( arrptr( verts ), arrptr( coords ), 3, err );MSQ_ERRRTN( err ); Vector3D n = ( coords[1] - coords[0] ) * ( coords[2] - coords[0] ); ++total_count; if( n % mNormal < 0.0 ) ++inverted_count; } // if most elements are inverted, flip normal if( 2 * inverted_count > total_count ) this->flip(); }
void MBMesquite::PlanarDomain::fit_vertices | ( | MBMesquite::Mesh * | mesh, |
const Mesh::VertexHandle * | vertex_array, | ||
size_t | vertex_array_length, | ||
MBMesquite::MsqError & | err, | ||
Definition at line 150 of file PlanarDomain.cpp.
References MBMesquite::arrptr(), MBMesquite::DomainUtil::default_tolerance(), MBMesquite::MsqError::INVALID_MESH, MSQ_ERRRTN, MSQ_SETERR, MBMesquite::DomainUtil::non_colinear_vertices(), and MBMesquite::Mesh::vertices_get_coordinates().
{ std::vector< MsqVertex > coords( num_verts ); mesh->vertices_get_coordinates( verts, arrptr( coords ), num_verts, err );MSQ_ERRRTN( err ); if( epsilon <= 0.0 ) epsilon = DomainUtil::default_tolerance( arrptr( coords ), num_verts ); Vector3D pts[3]; if( !DomainUtil::non_colinear_vertices( arrptr( coords ), num_verts, pts, epsilon ) ) { MSQ_SETERR( err )( "All vertices are colinear", MsqError::INVALID_MESH ); return; } this->set_plane( ( pts[1] - pts[0] ) * ( pts[2] - pts[0] ), pts[0] ); }
void MBMesquite::PlanarDomain::flip | ( | ) |
double MBMesquite::PlanarDomain::get_coeff | ( | ) | [inline] |
Definition at line 90 of file PlanarDomain.hpp.
Referenced by PlanarGeometryTest::test_fit_plane().
{ return mCoeff; }
const Vector3D& MBMesquite::PlanarDomain::get_normal | ( | ) | const [inline] |
Definition at line 85 of file PlanarDomain.hpp.
Referenced by CompareMetric::get_mask_axis(), PlanarGeometryTest::test_fit_plane(), PatchTranslate::xform(), PatchScale::xform(), and PatchRotate::xform().
{ return mNormal; }
Vector3D MBMesquite::PlanarDomain::get_origin | ( | ) | const [inline] |
Definition at line 95 of file PlanarDomain.hpp.
Referenced by PatchTranslate::xform(), PatchScale::xform(), and PatchRotate::xform().
void MBMesquite::PlanarDomain::set_plane | ( | const Vector3D & | normal, |
Definition at line 37 of file PlanarDomain.cpp.
References MBMesquite::Vector3D::normalize().
void MBMesquite::PlanarDomain::snap_to | ( | Mesh::VertexHandle | entity_handle, |
Modifies "coordinate" so that it lies on the domain to which "entity_handle" is constrained. The handle determines the domain. The coordinate is the proposed new position on that domain.
Definition at line 44 of file PlanarDomain.cpp.
void MBMesquite::PlanarDomain::vertex_normal_at | ( | Mesh::VertexHandle | entity_handle, |
Returns the normal of the domain to which "entity_handle" is constrained. For non-planar surfaces, the normal is calculated at the point on the domain that is closest to the passed in value of "coordinate". If the domain does not have a normal, or the normal cannot be determined, "coordinate" is set to (0,0,0). Otherwise, "coordinate" is set to the domain's normal at the appropriate point. In summary, the handle determines the domain. The coordinate determines the point of interest on that domain.
User should see also PatchData::get_domain_normal_at_vertex and PatchData::get_domain_normal_at_element .
Definition at line 49 of file PlanarDomain.cpp.
Referenced by MBMesquite::MeshWriter::Projection::Projection().
void MBMesquite::PlanarDomain::vertex_normal_at | ( | const Mesh::VertexHandle * | handles, |
Vector3D | coordinates[], | ||
unsigned | count, | ||
Returns normals for a domain.
handles | The domain evaluated is the one in which this mesh entity is constrained. |
coordinates | As input, a list of positions at which to evaluate the domain. As output, the resulting domain normals. |
count | The length of the coordinates array. |
Definition at line 61 of file PlanarDomain.cpp.
{ for( unsigned i = 0; i < count; ++i ) coords[i] = mNormal; }
double MBMesquite::PlanarDomain::mCoeff [private] |
Definition at line 117 of file PlanarDomain.hpp.
Vector3D MBMesquite::PlanarDomain::mNormal [private] |
Definition at line 116 of file PlanarDomain.hpp.
