MBMesquite::Mesh Class Reference
A MBMesquite::Mesh is a collection of mesh elements which are composed of mesh vertices. Intermediate objects are not accessible through this interface (where intermediate objects include things like the faces of a hex, or an element's edges). More...
#include <MeshInterface.hpp>
+ Inheritance diagram for MBMesquite::Mesh:
Public Types
enum  TagType {
  BYTE, BOOL, INT, DOUBLE,
  HANDLE
typedef void * EntityHandle
 Opaque EntityHandle type and tag type.
typedef EntityHandle VertexHandle
typedef EntityHandle ElementHandle
Public Member Functions
virtual int get_geometric_dimension (MsqError &err)=0
 Returns whether this mesh lies in a 2D or 3D coordinate system.
virtual void get_all_elements (std::vector< ElementHandle > &elements, MsqError &err)=0
 Get all elements in mesh.
virtual void get_all_vertices (std::vector< VertexHandle > &vertices, MsqError &err)=0
 Get all vertices in mesh.
virtual void vertices_get_fixed_flag (const VertexHandle vert_array[], std::vector< bool > &fixed_flag_array, size_t num_vtx, MsqError &err)=0
virtual void vertices_get_slaved_flag (const VertexHandle vert_array[], std::vector< bool > &slaved_flag_array, size_t num_vtx, MsqError &err)=0
virtual void vertices_get_coordinates (const VertexHandle vert_array[], MsqVertex *coordinates, size_t num_vtx, MsqError &err)=0
 Get/set location of a vertex.
virtual void vertex_set_coordinates (VertexHandle vertex, const Vector3D &coordinates, MsqError &err)=0
virtual void vertex_set_byte (VertexHandle vertex, unsigned char byte, MsqError &err)=0
virtual void vertices_set_byte (const VertexHandle *vert_array, const unsigned char *byte_array, size_t array_size, MsqError &err)=0
virtual void vertex_get_byte (const VertexHandle vertex, unsigned char *byte, MsqError &err)=0
virtual void vertices_get_byte (const VertexHandle *vertex, unsigned char *byte_array, size_t array_size, MsqError &err)=0
virtual void vertices_get_attached_elements (const VertexHandle *vertex_array, size_t num_vertex, std::vector< ElementHandle > &elements, std::vector< size_t > &offsets, MsqError &err)=0
 get elements adjacent to vertices
virtual void elements_get_attached_vertices (const ElementHandle *elem_handles, size_t num_elems, std::vector< VertexHandle > &vert_handles, std::vector< size_t > &offsets, MsqError &err)=0
 Get element connectivity.
virtual void elements_get_topologies (const ElementHandle *element_handle_array, EntityTopology *element_topologies, size_t num_elements, MsqError &err)=0
virtual TagHandle tag_create (const std::string &tag_name, TagType type, unsigned length, const void *default_value, MsqError &err)=0
 Create a tag.
virtual void tag_delete (TagHandle handle, MsqError &err)=0
 Remove a tag and all corresponding data.
virtual TagHandle tag_get (const std::string &name, MsqError &err)=0
 Get handle for existing tag, by name.
virtual void tag_properties (TagHandle handle, std::string &name_out, TagType &type_out, unsigned &length_out, MsqError &err)=0
 Get properites of tag.
virtual void tag_set_element_data (TagHandle handle, size_t num_elems, const ElementHandle *elem_array, const void *tag_data, MsqError &err)=0
 Set tag values on elements.
virtual void tag_set_vertex_data (TagHandle handle, size_t num_elems, const VertexHandle *node_array, const void *tag_data, MsqError &err)=0
 Set tag values on vertices.
virtual void tag_get_element_data (TagHandle handle, size_t num_elems, const ElementHandle *elem_array, void *tag_data, MsqError &err)=0
 Get tag values on elements.
virtual void tag_get_vertex_data (TagHandle handle, size_t num_elems, const VertexHandle *node_array, void *tag_data, MsqError &err)=0
 Get tag values on vertices.
virtual void release_entity_handles (const EntityHandle *handle_array, size_t num_handles, MsqError &err)=0
virtual void release ()=0
virtual ~Mesh ()
Detailed Description
Definition at line 76 of file MeshInterface.hpp.
Member Typedef Documentation
Definition at line 81 of file MeshInterface.hpp.
Definition at line 88 of file MeshInterface.hpp.
Member Enumeration Documentation
The type of a tag
Enumerator:
BYTE
BOOL
INT
DOUBLE
HANDLE
Definition at line 226 of file MeshInterface.hpp.
virtual MBMesquite::Mesh::~Mesh ( ) [inline, virtual]
Definition at line 358 of file MeshInterface.hpp.
Member Function Documentation
virtual void MBMesquite::Mesh::elements_get_attached_vertices ( const ElementHandle elem_handles,
size_t  num_elems,
std::vector< VertexHandle > &  vert_handles,
std::vector< size_t > &  offsets,
MsqError err
) [pure virtual]
Get the connectivity (ordered list of vertex handles) for each element in the input array.
Parameters:
elem_handlesThe array of element handles for which to retrieve the connectivity list.
num_elemsThe length of #elem_handles
vert_handlesArray in which to place the vertex handles in each elements connectivity.
offsetsFor each element in #elem_handles, the value in the same position in this array is the index into #vert_handles at which the connectivity list for that element begins.
Implemented in MBMesquite::MeshImpl, MBMesquite::ArrayMesh, MBMesquite::MsqIMesh, MBMesquite::MsqMOAB, MBMesquite::ParallelMeshImpl, and MBMesquite::MeshDecorator.
Referenced by VtkTest::check_4quad_structured(), VtkTest::check_8hex_structured(), check_no_slaved_corners(), check_slaved_coords(), classify_boundary(), MBMesquite::TerminationCriterion::cull_vertices_global(), elem_areas(), MBMesquite::MeshDecorator::elements_get_attached_vertices(), MBMesquite::ParallelMeshImpl::elements_get_attached_vertices(), MBMesquite::find_skin(), find_z10_extreme_elements(), MBMesquite::PlanarDomain::fit_vertices(), MBMesquite::geom_classify_elements(), PatchDataTest::get_higher_order_vertices(), MBMesquite::VertexPatches::get_patch(), get_slaved_coords(), MBMesquite::Instruction::initialize_vertex_byte(), MBMesquite::ParallelHelperImpl::is_our_element(), MBMesquite::SlaveBoundaryVertices::loop_over_mesh(), MBMesquite::MeshUtil::meshes_are_different(), MBMesquite::next_vertex(), MBMesquite::PatchData::set_mesh_entities(), MBMesquite::ParallelHelperImpl::smoothing_init(), MBMesquite::DomainClassifier::test_valid_classification(), tet_dihedral_angle_ratios(), MBMesquite::vert_classify_elements(), MBMesquite::MeshWriter::write_eps_triangle(), and MBMesquite::MeshWriter::write_stl().
virtual void MBMesquite::Mesh::get_all_vertices ( std::vector< VertexHandle > &  vertices,
MsqError err
) [pure virtual]
Get the handles of every vertex in the active mesh
Implemented in MBMesquite::ArrayMesh, MBMesquite::MsqIMesh, MBMesquite::MsqMOAB, MBMesquite::MeshImpl, MBMesquite::ParallelMeshImpl, and MBMesquite::MeshDecorator.
Referenced by check_results(), MBMesquite::checkpoint_bytes(), classify_boundary(), MBMesquite::DomainClassifier::classify_by_handle(), MBMesquite::DomainClassifier::classify_by_tag(), MBMesquite::DomainClassifier::classify_geometrically(), MBMesquite::VertexMover::commit_jacobi_coords(), compare_node_coords(), MBMesquite::BoundedCylinderDomain::create_curve(), MBMesquite::TerminationCriterion::cull_vertices_global(), MBMesquite::SphericalDomain::fit_vertices(), MBMesquite::PlanarDomain::fit_vertices(), MBMesquite::MeshDecorator::get_all_vertices(), MBMesquite::ParallelMeshImpl::get_all_vertices(), MBMesquite::VertexMover::get_jacobi_coord_tag(), MBMesquite::VertexPatches::get_patch_handles(), horseshoe(), TCTFauxOptimizer::initialize(), MBMesquite::Instruction::initialize_vertex_byte(), MBMesquite::VertexMover::loop_over_mesh(), MBMesquite::MeshTransform::loop_over_mesh(), MBMesquite::SlaveBoundaryVertices::loop_over_mesh(), make_domain(), MBMesquite::MeshUtil::meshes_are_different(), MBMesquite::DeformingDomainWrapper::move_to_domain(), parabolic_squash(), quarter_annulus(), MBMesquite::restore_bytes(), MBMesquite::ShapeImprover::run_wrapper(), scale(), MBMesquite::XYRectangle::setup(), MBMesquite::ParallelHelperImpl::smoothing_init(), PatchDataTest::test_fixed_by_geom_dim(), and MBMesquite::DomainClassifier::test_valid_classification().
virtual void MBMesquite::Mesh::release ( ) [pure virtual]
Instead of deleting a Mesh when you think you are done, call release(). In simple cases, the implementation could just call the destructor. More sophisticated implementations may want to keep the Mesh object to live longer than Mesquite is using it.
Implemented in MBMesquite::MeshImpl, MBMesquite::ArrayMesh, MBMesquite::ParallelMeshImpl, MBMesquite::MsqIMesh, MBMesquite::MsqMOAB, MBMesquite::MeshDecorator, MBMesquite::TagVertexMesh, and FakeMesh.
Referenced by MBMesquite::MeshDecorator::release(), and MBMesquite::ParallelMeshImpl::release().
virtual void MBMesquite::Mesh::release_entity_handles ( const EntityHandle handle_array,
size_t  num_handles,
MsqError err
) [pure virtual]
virtual TagHandle MBMesquite::Mesh::tag_create ( const std::string &  tag_name,
TagType  type,
unsigned  length,
const void *  default_value,
MsqError err
) [pure virtual]
Create a tag.
Create a user-defined data type that can be attached to any element or vertex in the mesh. For an opaque or undefined type, use type=BYTE and length=sizeof(..).
Parameters:
tag_nameA unique name for the data object
typeThe type of the data
lengthNumber of values per entity (1->scalar, >1 ->vector)
default_valueDefault value to assign to all entities - may be NULL
Returns:
- Handle for tag definition
Implemented in MBMesquite::MeshImpl, MBMesquite::ArrayMesh, MBMesquite::MsqIMesh, MBMesquite::MsqMOAB, MBMesquite::ParallelMeshImpl, MBMesquite::TagVertexMesh, and MBMesquite::MeshDecorator.
Referenced by MBMesquite::TagVertexMesh::copy_all_coordinates(), MBMesquite::VertexMover::get_jacobi_coord_tag(), MBMesquite::QualityAssessor::get_tag(), MBMesquite::TargetWriter::get_tag_handle(), MBMesquite::ParallelHelperImpl::smoothing_init(), MBMesquite::DeformingCurveSmoother::store_initial_mesh(), MBMesquite::MeshDecorator::tag_create(), MBMesquite::TagVertexMesh::tag_create(), MBMesquite::ParallelMeshImpl::tag_create(), tag_patch_slaved(), and MBMesquite::TagVertexMesh::vertex_set_coordinates().
virtual void MBMesquite::Mesh::tag_get_element_data ( TagHandle  handle,
size_t  num_elems,
const ElementHandle elem_array,
void *  tag_data,
MsqError err
) [pure virtual]
Get the value of a tag for a list of mesh elements.
Parameters:
handleThe tag
num_elemsLength of elem_array
elem_arrayArray of elements for which to get the tag value.
tag_dataReturn buffer in which to copy tag data, contiguous in memory. This data is expected to be num_elems*tag_length*sizeof(tag_type) bytes.
Implemented in MBMesquite::MeshImpl, MBMesquite::MsqIMesh, MBMesquite::MsqMOAB, MBMesquite::ArrayMesh, MBMesquite::ParallelMeshImpl, MBMesquite::MeshDecorator, and FakeMesh.
Referenced by MBMesquite::DomainClassifier::classify_by_tag(), MBMesquite::TargetReader::get_2D_target(), MBMesquite::TargetReader::get_3D_target(), MBMesquite::TargetReader::get_surface_target(), MBMesquite::WeightReader::get_weight(), MBMesquite::MeshDecorator::tag_get_element_data(), and MBMesquite::ParallelMeshImpl::tag_get_element_data().
virtual void MBMesquite::Mesh::tag_get_vertex_data ( TagHandle  handle,
size_t  num_elems,
const VertexHandle node_array,
void *  tag_data,
MsqError err
) [pure virtual]
Get the value of a tag for a list of mesh vertices.
Parameters:
handleThe tag
elem_arrayArray of vertices for which to get the tag value.
Referenced by MBMesquite::DomainClassifier::classify_by_tag(), MBMesquite::VertexMover::commit_jacobi_coords(), MBMesquite::DeformingCurveSmoother::smooth_curve(), MBMesquite::ParallelHelperImpl::smoothing_init(), MBMesquite::MeshDecorator::tag_get_vertex_data(), MBMesquite::ParallelMeshImpl::tag_get_vertex_data(), MBMesquite::TagVertexMesh::vertices_get_coordinates(), and MBMesquite::ParallelMeshImpl::vertices_get_global_id().
virtual void MBMesquite::Mesh::tag_properties ( TagHandle  handle,
std::string &  name_out,
TagType type_out,
unsigned &  length_out,
MsqError err
) [pure virtual]
Get data type and number of values per entity for tag.
Parameters:
handleTag to get properties of.
name_outPassed back tag name.
type_outPassed back tag type.
length_outPassed back number of values per entity.
Referenced by MBMesquite::DomainClassifier::classify_by_tag(), MBMesquite::get_tag(), MBMesquite::DeformingCurveSmoother::get_tag(), MBMesquite::QualityAssessor::get_tag(), MBMesquite::TargetWriter::get_tag_handle(), MBMesquite::MeshDecorator::tag_properties(), and MBMesquite::ParallelMeshImpl::tag_properties().
virtual void MBMesquite::Mesh::tag_set_element_data ( TagHandle  handle,
size_t  num_elems,
const void *  tag_data,
MsqError err
) [pure virtual]
Set the value of a tag for a list of mesh elements.
Parameters:
handleThe tag
elem_arrayArray of elements for which to set the tag value.
tag_dataTag data for each element, contiguous in memory. This data is expected to be num_elems*tag_length*sizeof(tag_type) bytes.
Referenced by MBMesquite::TargetWriter::loop_over_mesh(), MBMesquite::QualityAssessor::loop_over_mesh_internal(), MBMesquite::MeshDecorator::tag_set_element_data(), and MBMesquite::ParallelMeshImpl::tag_set_element_data().
virtual void MBMesquite::Mesh::tag_set_vertex_data ( TagHandle  handle,
size_t  num_elems,
MsqError err
) [pure virtual]
Set the value of a tag for a list of mesh vertices.
Parameters:
handleThe tag
num_elemsLength of node_array
node_arrayArray of vertices for which to set the tag value.
Referenced by MBMesquite::VertexMover::get_jacobi_coord_tag(), MBMesquite::QualityAssessor::loop_over_mesh_internal(), MBMesquite::ParallelHelperImpl::smoothing_init(), MBMesquite::DeformingCurveSmoother::store_initial_mesh(), tag_patch_slaved(), MBMesquite::MeshDecorator::tag_set_vertex_data(), MBMesquite::ParallelMeshImpl::tag_set_vertex_data(), MBMesquite::PatchData::update_mesh(), and MBMesquite::TagVertexMesh::vertex_set_coordinates().
virtual void MBMesquite::Mesh::vertex_get_byte ( const VertexHandle  vertex,
unsigned char *  byte,
MsqError err
) [pure virtual]
Retrieve the byte value for the specified vertex or vertices. The byte value is 0 if it has not yet been set via one of the _set_byte() functions.
Implemented in MBMesquite::ArrayMesh, MBMesquite::MeshImpl, MBMesquite::MsqIMesh, MBMesquite::MsqMOAB, MBMesquite::ParallelMeshImpl, FakeMesh, and MBMesquite::MeshDecorator.
Referenced by MBMesquite::TerminationCriterion::cull_vertices_global(), MBMesquite::MeshDecorator::vertex_get_byte(), and MBMesquite::ParallelMeshImpl::vertex_get_byte().
virtual void MBMesquite::Mesh::vertex_set_byte ( VertexHandle  vertex,
unsigned char  byte,
MsqError err
) [pure virtual]
Each vertex has a byte-sized flag that can be used to store flags. This byte's value is neither set nor used by the mesh implementation. It is intended to be used by Mesquite algorithms. Until a vertex's byte has been explicitly set, its value is 0.
Referenced by MBMesquite::PatchData::update_mesh(), MBMesquite::MeshDecorator::vertex_set_byte(), and MBMesquite::ParallelMeshImpl::vertex_set_byte().
virtual void MBMesquite::Mesh::vertices_get_attached_elements ( const VertexHandle vertex_array,
size_t  num_vertex,
std::vector< ElementHandle > &  elements,
MsqError err
) [pure virtual]
Get adjacency data for vertices
Parameters:
vertex_arrayArray of vertex handles specifying the list of vertices to retrieve adjacency data for.
num_vertexNumber of vertex handles in #vertex_array
elementsThe array in which to place the handles of elements adjacent to the input vertices.
offsetsFor each vertex in #vertex_array, the value in the corresponding position in this array is the index into #elem_array at which the adjacency list begins for that vertex.
Implemented in MBMesquite::ArrayMesh, MBMesquite::MeshImpl, MBMesquite::MsqIMesh, MBMesquite::MsqMOAB, MBMesquite::ParallelMeshImpl, and MBMesquite::MeshDecorator.
Referenced by classify_boundary(), MBMesquite::TerminationCriterion::cull_vertices_global(), MBMesquite::find_skin(), MBMesquite::VertexPatches::get_patch(), get_slaved_coords(), MBMesquite::VertexMover::loop_over_mesh(), MBMesquite::next_vertex(), MBMesquite::ParallelHelperImpl::smoothing_init(), MBMesquite::DomainClassifier::test_valid_classification(), MBMesquite::MeshDecorator::vertices_get_attached_elements(), and MBMesquite::ParallelMeshImpl::vertices_get_attached_elements().
virtual void MBMesquite::Mesh::vertices_get_coordinates ( const VertexHandle  vert_array[],
MsqVertex coordinates,
size_t  num_vtx,
MsqError err
) [pure virtual]
Implemented in MBMesquite::ArrayMesh, MBMesquite::MeshImpl, MBMesquite::MsqIMesh, MBMesquite::MsqMOAB, MBMesquite::TagVertexMesh, MBMesquite::ParallelMeshImpl, and MBMesquite::MeshDecorator.
Referenced by VtkTest::check_4quad_block(), VtkTest::check_8hex_block(), check_results(), check_slaved_coords(), classify_boundary(), MBMesquite::ParallelHelperImpl::comm_smoothed_vtx_b(), MBMesquite::ParallelHelperImpl::comm_smoothed_vtx_b_no_all(), MBMesquite::ParallelHelperImpl::comm_smoothed_vtx_nb(), MBMesquite::ParallelHelperImpl::comm_smoothed_vtx_nb_no_all(), MBMesquite::ParallelHelperImpl::comm_smoothed_vtx_tnb(), MBMesquite::ParallelHelperImpl::comm_smoothed_vtx_tnb_no_all(), compare_node_coords(), compare_nodes(), MBMesquite::TagVertexMesh::copy_all_coordinates(), MBMesquite::BoundedCylinderDomain::create_curve(), elem_areas(), find_z10_extreme_elements(), MBMesquite::SphericalDomain::fit_vertices(), MBMesquite::PlanarDomain::fit_vertices(), MBMesquite::geom_classify_elements(), MBMesquite::geom_classify_vertices(), MBMesquite::VertexMover::get_jacobi_coord_tag(), MBMesquite::ReferenceMesh::get_reference_vertex_coordinates(), get_slaved_coords(), horseshoe(), MBMesquite::MeshTransform::loop_over_mesh(), make_domain(), MBMesquite::MeshUtil::meshes_are_different(), MBMesquite::DeformingDomainWrapper::move_to_domain(), parabolic_squash(), quarter_annulus(), scale(), MBMesquite::PatchData::set_mesh_entities(), MBMesquite::XYRectangle::setup(), MBMesquite::DeformingCurveSmoother::smooth_curve(), smooth_mesh(), MBMesquite::ParallelHelperImpl::smoothing_close(), MBMesquite::DeformingCurveSmoother::store_initial_mesh(), tet_dihedral_angle_ratios(), MBMesquite::MeshDecorator::vertices_get_coordinates(), MBMesquite::ParallelMeshImpl::vertices_get_coordinates(), MBMesquite::TagVertexMesh::vertices_get_coordinates(), MBMesquite::MeshWriter::write_eps_triangle(), and MBMesquite::MeshWriter::write_stl().
virtual void MBMesquite::Mesh::vertices_get_fixed_flag ( const VertexHandle  vert_array[],
std::vector< bool > &  fixed_flag_array,
size_t  num_vtx,
MsqError err
) [pure virtual]
Returns a pointer to an iterator that iterates over the set of all vertices in this mesh. The calling code should delete the returned iterator when it is finished with it. If vertices are added or removed from the Mesh after obtaining an iterator, the behavior of that iterator is undefined. Returns a pointer to an iterator that iterates over the set of all top-level elements in this mesh. The calling code should delete the returned iterator when it is finished with it. If elements are added or removed from the Mesh after obtaining an iterator, the behavior of that iterator is undefined. Returns true or false, indicating whether the vertex is allowed to be repositioned. True indicates that the vertex is fixed and cannot be moved. Note that this is a read-only property; this flag can't be modified by users of the MBMesquite::Mesh interface.
Referenced by check_global_patch_slaved(), check_slaved_coords(), MBMesquite::VertexMover::commit_jacobi_coords(), MBMesquite::DomainUtil::get_fixed_vertices(), PatchDataTest::get_higher_order_vertices(), MBMesquite::VertexMover::get_jacobi_coord_tag(), TCTFauxOptimizer::initialize(), MBMesquite::Instruction::initialize_vertex_byte(), MBMesquite::MeshTransform::loop_over_mesh(), MBMesquite::SlaveBoundaryVertices::loop_over_mesh(), MBMesquite::MeshDecorator::vertices_get_fixed_flag(), MBMesquite::ParallelMeshImpl::vertices_get_fixed_flag(), and MBMesquite::MeshWriter::write_eps_triangle().
virtual void MBMesquite::Mesh::vertices_get_slaved_flag ( const VertexHandle  vert_array[],
std::vector< bool > &  slaved_flag_array,
size_t  num_vtx,
MsqError err
) [pure virtual]
Returns true or false, indicating whether the vertex is a higher-order node that should be slaved to the logical mid-point of the element side it lies on or not, respectively.
Note: This function will never be called unless this behavior is requested by calling: InstructionQueue::set_slaved_ho_node_mode( Settings::SLAVE_FLAG )
Implemented in HoSlavedMesh, MBMesquite::ArrayMesh, MBMesquite::MeshImpl, MBMesquite::MsqIMesh, MBMesquite::MsqMOAB, MBMesquite::ParallelMeshImpl, and MBMesquite::MeshDecorator.
Referenced by check_global_patch_slaved(), check_no_slaved_corners(), check_slaved_coords(), MBMesquite::Instruction::initialize_vertex_byte(), MBMesquite::MeshDecorator::vertices_get_slaved_flag(), and MBMesquite::ParallelMeshImpl::vertices_get_slaved_flag().
List of all members.
