MOAB: Mesh Oriented datABase
(version 5.3.1)
Mesquite iMesh Adapter. More...
#include <MsqIMesh.hpp>
Public Member Functions | |
MsqIMesh () | |
virtual | ~MsqIMesh () |
MsqIMesh (iMesh_Instance imesh, iBase_EntitySetHandle meshset, iBase_EntityType element_dimension, MsqError &err, const iBase_TagHandle *fixed_tag=0, const iBase_TagHandle *slaved_tag=0) | |
Create iMesh adaptor instance. | |
MsqIMesh (iMesh_Instance imesh, iBase_EntityType element_dimension, MsqError &err, const iBase_TagHandle *fixed_tag=0, const iBase_TagHandle *slaved_tag=0) | |
void | set_active_set (iBase_EntitySetHandle meshset, iBase_EntityType element_dimension, MsqError &err) |
set mesh to be smoothed. | |
void | set_fixed_tag (iBase_TagHandle tag, MsqError &err) |
Set tag for vertex fixed flag. | |
void | set_slaved_tag (iBase_TagHandle tag, MsqError &err) |
Set tag for vertex slaved flag. | |
void | clear_fixed_tag () |
No tag for vertex fixed flag. | |
void | clear_slaved_tag () |
const iBase_TagHandle * | get_fixed_tag () const |
Get tag for vertex fixed flag. | |
const iBase_TagHandle * | get_slaved_tag () const |
Get tag for vertex slaved flag. | |
virtual iMesh_Instance | get_imesh_instance () const |
virtual iBase_EntitySetHandle | get_entity_set () const |
virtual int | get_geometric_dimension (MBMesquite::MsqError &) |
Get dimension of vertex coordinates (2D vs. 3D). | |
virtual void | get_all_elements (std::vector< ElementHandle > &elements, MsqError &err) |
Get handles for all elemnents. | |
virtual void | get_all_vertices (std::vector< VertexHandle > &vertices, MsqError &err) |
Get handles for all vertices. | |
virtual void | vertices_get_fixed_flag (const VertexHandle vert_array[], std::vector< bool > &fixed_flag_array, size_t num_vtx, MsqError &err) |
Query "fixed" flag for a vertex. | |
virtual void | vertices_get_slaved_flag (const VertexHandle vert_array[], std::vector< bool > &slaved_flag_array, size_t num_vtx, MsqError &err) |
virtual void | vertices_get_coordinates (const VertexHandle vert_array[], MsqVertex *coordinates, size_t num_vtx, MsqError &err) |
Get vertex coordinates. | |
virtual void | vertex_set_coordinates (VertexHandle vertex, const Vector3D &coordinates, MsqError &err) |
Set vertex coordinates. | |
virtual void | vertex_set_byte (VertexHandle vertex, unsigned char byte, MsqError &err) |
Set vertex mark. | |
virtual void | vertices_set_byte (const VertexHandle *vert_array, const unsigned char *byte_array, size_t array_size, MsqError &err) |
virtual void | vertex_get_byte (VertexHandle vertex, unsigned char *byte, MsqError &err) |
Get vertex mark. | |
virtual void | vertices_get_byte (const VertexHandle *vert_array, unsigned char *byte_array, size_t array_size, MsqError &err) |
virtual void | vertices_get_attached_elements (const VertexHandle *vertex_array, size_t num_vertices, std::vector< ElementHandle > &elements, std::vector< size_t > &offsets, MsqError &err) |
Get vertex-to-element adjacencies. | |
virtual void | elements_get_attached_vertices (const ElementHandle *elem_handles, size_t num_elems, std::vector< VertexHandle > &vertices, std::vector< size_t > &offsets, MsqError &err) |
Get element connectivity. | |
virtual void | elements_get_topologies (const ElementHandle *element_handle_array, EntityTopology *element_topologies, size_t num_elements, MsqError &err) |
Return topology type enum for an array of elements. | |
virtual void | release_entity_handles (const EntityHandle *handle_array, size_t num_handles, MsqError &err) |
no-op | |
virtual void | release () |
virtual TagHandle | tag_create (const std::string &tag_name, TagType type, unsigned length, const void *default_value, MsqError &err) |
Create a tag. | |
virtual void | tag_delete (TagHandle handle, MsqError &err) |
Remove a tag and all corresponding data. | |
virtual TagHandle | tag_get (const std::string &name, MsqError &err) |
Get handle for existing tag, by name. | |
virtual void | tag_properties (TagHandle handle, std::string &name_out, TagType &type_out, unsigned &length_out, MsqError &err) |
Get properites of tag. | |
virtual void | tag_set_element_data (TagHandle handle, size_t num_elems, const ElementHandle *elem_array, const void *tag_data, MsqError &err) |
Set tag values on elements. | |
virtual void | tag_set_vertex_data (TagHandle handle, size_t num_elems, const VertexHandle *node_array, const void *tag_data, MsqError &err) |
Set tag values on vertices. | |
virtual void | tag_get_element_data (TagHandle handle, size_t num_elems, const ElementHandle *elem_array, void *tag_data, MsqError &err) |
Get tag values on elements. | |
virtual void | tag_get_vertex_data (TagHandle handle, size_t num_elems, const VertexHandle *node_array, void *tag_data, MsqError &err) |
Get tag values on vertices. | |
Protected Member Functions | |
iBase_TagValueType | check_valid_flag_tag (iBase_TagHandle tag, const char *which_flag, MsqError &err) |
void | set_int_tag (void *tag, void *meshset, int value, MsqError &err) |
void | get_adjacent_entities (const iBase_EntityHandle *source, size_t num_source, iBase_EntityType target_type, std::vector< EntityHandle > &target, std::vector< size_t > &offsets, MsqError &err) |
Call TSTTM::Arr::getEntArrAdj. | |
Protected Attributes | |
iMesh_Instance | meshInstance |
Private Member Functions | |
void | init_active_mesh (iMesh_Instance mesh, MsqError &err, const iBase_TagHandle *fixed_tag, const iBase_TagHandle *slaved_tag) |
void | get_flag_data (iBase_TagHandle tag, bool have_tag, iBase_TagValueType type, const VertexHandle vert_array[], std::vector< bool > &flag_array, size_t num_vtx, MsqError &err) |
void | tag_set_data (TagHandle handle, size_t num_elems, const EntityHandle *handle_array, const void *tag_data, MsqError &err) |
Set tag values. | |
void | tag_get_data (TagHandle handle, size_t num_elems, const EntityHandle *handle_array, void *tag_data, MsqError &err) |
Get tag values. | |
Private Attributes | |
bool | haveMesh |
iBase_EntityType | inputSetType |
iBase_EntitySetHandle | inputSet |
iBase_TagHandle | byteTag |
bool | createdByteTag |
iBase_TagHandle | fixedTag |
bool | haveFixedTag |
iBase_TagValueType | fixedTagType |
iBase_TagHandle | slavedTag |
bool | haveSlavedTag |
iBase_TagValueType | slavedTagType |
int | geometricDimension |
EntityTopology | topologyMap [iMesh_ALL_TOPOLOGIES+1] |
Adpater for interfacing Mesquite with an application that provides the ITAPS iMesh interface for interacting with mesh data.
Definition at line 52 of file MsqIMesh.hpp.
MBMesquite::MsqIMesh::~MsqIMesh | ( | ) | [virtual] |
Definition at line 82 of file MsqIMesh.cpp.
References byteTag, createdByteTag, ierr, iMesh_destroyTag, and meshInstance.
{ int ierr; if( createdByteTag ) iMesh_destroyTag( meshInstance, byteTag, true, &ierr ); }
MBMesquite::MsqIMesh::MsqIMesh | ( | iMesh_Instance | imesh, |
iBase_EntitySetHandle | meshset, | ||
iBase_EntityType | element_dimension, | ||
MsqError & | err, | ||
const iBase_TagHandle * | fixed_tag = 0 , |
const iBase_TagHandle * | slaved_tag = 0 |
imesh | The iMesh instance to interact with |
meshset | The set of elements for which to optimize the quality |
element_dimension | Optimize the subset of the elements in 'meshset' with this dimension. Pass iBase_ALL_TYPES for both iBase_FACE and iBase_REGION elements. If 'meshset' is the root set, then this argument is typically either iBase_FACE or iBase_REGION. |
fixed_tag | A pointer to the tag handle designating a tag containing fixed flags for vertices. The tag must have size==1 and type==iBase_INTEGER or iBase_BYTES. A value of one for a vertex indicates that the vertex position is fixed. A value of zero indicates a free vertex (a vertex that Mesquite may move to improve mesh quality.) If this tag is not specified, then the boundary constraints of the optimization must be specified using an MsqIRel instance. |
slaved_tag | A pointer to the tag handle designating a tag containing slaved flags for vertices. The tag must have size==1 and type==iBase_INTEGER or iBase_BYTES. This tag value is ignored for corner vertices of elements. The concept of 'slaved' is applicable only to non-corner vertices in higher-order elements. A value of one for a vertex indicates that the vertex position should is a fucntion of the element shape function, while a zero value indicates that the element shape function is a function of the vertex position. |
Definition at line 55 of file MsqIMesh.cpp.
References init_active_mesh(), MSQ_ERRRTN, and set_active_set().
: meshInstance( mesh ), inputSetType( iBase_ALL_TYPES ), inputSet( 0 ), byteTag( 0 ), createdByteTag( false ), geometricDimension( 0 ) { init_active_mesh( mesh, err, fixed_tag, slaved_tag );MSQ_ERRRTN( err ); set_active_set( meshset, type, err );MSQ_ERRRTN( err ); }
This constructor is provided for the creation of an MsqIMesh instance that is to be re-used for multiple optimization calls for different sets of elements. set_active_set must be called to define the subset of the mesh to optimize before an instance constructed with this constructor may be used in an optimization.
element_dimension | Optimize the subset of the elements in root set with this dimension. Pass iBase_ALL_TYPES for both iBase_FACE and iBase_REGION elements. If 'meshset' is the root set, then this argument is typically either iBase_FACE or iBase_REGION. |
Definition at line 64 of file MsqIMesh.cpp.
References iBase_SUCCESS, ierr, iMesh_getRootSet, init_active_mesh(), MBMesquite::MsqError::INVALID_STATE, MSQ_ERRRTN, MSQ_SETERR, root_set, and set_active_set().
: meshInstance( mesh ), inputSetType( iBase_ALL_TYPES ), inputSet( 0 ), byteTag( 0 ), createdByteTag( false ), geometricDimension( 0 ) { init_active_mesh( mesh, err, fixed_tag, slaved_tag );MSQ_ERRRTN( err ); int ierr; iBase_EntitySetHandle root_set; iMesh_getRootSet( mesh, &root_set, &ierr ); if( ierr != iBase_SUCCESS ) { MSQ_SETERR( err )( "Invalid iMesh instance.", MsqError::INVALID_STATE ); return; } set_active_set( root_set, type, err );MSQ_ERRRTN( err ); }
iBase_TagValueType MBMesquite::MsqIMesh::check_valid_flag_tag | ( | iBase_TagHandle | tag, |
const char * | which_flag, | ||
MsqError & | err | ||
) | [protected] |
Definition at line 98 of file MsqIMesh.cpp.
References iBase_BYTES, iBase_ENTITY_HANDLE, iBase_INTEGER, iBase_SUCCESS, ierr, iMesh_getTagName, iMesh_getTagSizeBytes, iMesh_getTagType, MBMesquite::MsqError::INVALID_ARG, MBMesquite::MsqError::INVALID_STATE, meshInstance, MSQ_SETERR, and size.
Referenced by init_active_mesh(), set_fixed_tag(), and set_slaved_tag().
{ int ierr, size, type; const int MAX_NAME_LEN = 127; char name[MAX_NAME_LEN + 1]; std::fill( name, name + sizeof( name ), '\0' ); iMesh_getTagName( meshInstance, tag, name, &ierr, MAX_NAME_LEN ); name[MAX_NAME_LEN - 1] = '\0'; // make sure strings are null-terminated if( iBase_SUCCESS != ierr ) { MSQ_SETERR( err ) ( MsqError::INVALID_ARG, "Invalid tag handle for vertex %s flag", which_flag ); return iBase_ENTITY_HANDLE; } iMesh_getTagSizeBytes( meshInstance, tag, &size, &ierr ); if( iBase_SUCCESS != ierr || size != sizeof( int ) ) { MSQ_SETERR( err )( MsqError::INVALID_STATE, "Tag \"%s\" exists with invalid size", name ); return iBase_ENTITY_HANDLE; } iMesh_getTagType( meshInstance, tag, &type, &ierr ); if( iBase_SUCCESS != ierr || ( type != iBase_INTEGER && type != iBase_BYTES ) ) { MSQ_SETERR( err )( MsqError::INVALID_STATE, "Tag \"%s\" exists with invalid type", name ); return iBase_ENTITY_HANDLE; } return static_cast< iBase_TagValueType >( type ); }
Definition at line 219 of file MsqIMesh.cpp.
References haveFixedTag.
{ haveFixedTag = false; }
Definition at line 237 of file MsqIMesh.cpp.
References haveSlavedTag.
{ haveSlavedTag = false; }
void MBMesquite::MsqIMesh::elements_get_attached_vertices | ( | const ElementHandle * | elements, |
size_t | num_elems, | ||
std::vector< VertexHandle > & | vertices, | ||
std::vector< size_t > & | offsets, | ||
MBMesquite::MsqError & | err | ||
) | [virtual] |
Get connectivity
elements | - Array of length num_elems containing elements handles of elements for which connectivity is to be queried. |
vertices | - Array of vertex handles in connectivity list. |
offsets | - Indices into vertex_handles, one per element |
Implements MBMesquite::Mesh.
Definition at line 590 of file MsqIMesh.cpp.
References get_adjacent_entities(), iBase_VERTEX, and MSQ_CHKERR.
Referenced by get_all_vertices().
{ assert( sizeof( iBase_EntityHandle ) == sizeof( EntityHandle ) ); const iBase_EntityHandle* elems = reinterpret_cast< const iBase_EntityHandle* >( elements ); get_adjacent_entities( elems, num_elems, iBase_VERTEX, vertices, offsets, err );MSQ_CHKERR( err ); }
void MBMesquite::MsqIMesh::elements_get_topologies | ( | const ElementHandle * | element_handle_array, |
EntityTopology * | element_topologies, | ||
size_t | num_elements, | ||
) | [virtual] |
Definition at line 691 of file MsqIMesh.cpp.
References MBMesquite::arrptr(), iBase_SUCCESS, ierr, iMesh_getEntArrTopo, INTERNAL_ERROR, meshInstance, MSQ_SETERR, MBMesquite::process_itaps_error(), and topologyMap.
{ if( !num_elements ) return; // don't copy unless we have to std::vector< int > topo_store; int* topo_array; if( sizeof( EntityTopology ) == sizeof( int ) ) topo_array = (int*)element_topologies; else { topo_store.resize( num_elements ); topo_array = arrptr( topo_store ); } int ierr, junk1 = num_elements, junk2; assert( sizeof( ElementHandle ) == sizeof( iBase_EntityHandle ) ); const iBase_EntityHandle* arr = reinterpret_cast< const iBase_EntityHandle* >( element_handle_array ); iMesh_getEntArrTopo( meshInstance, arr, num_elements, &topo_array, &junk1, &junk2, &ierr ); if( iBase_SUCCESS != ierr ) { MSQ_SETERR( err )( process_itaps_error( ierr ), MsqError::INTERNAL_ERROR ); return; } for( size_t i = 0; i < num_elements; ++i ) element_topologies[i] = topologyMap[topo_array[i]]; }
void MBMesquite::MsqIMesh::get_adjacent_entities | ( | const iBase_EntityHandle * | source, |
size_t | num_source, | ||
iBase_EntityType | target_type, | ||
std::vector< EntityHandle > & | target, | ||
) | [protected] |
Common code for vertices_get_attached_elements and elements_get_attached_vertices
source | Array of handles of source entities to query from |
num_source | The length of source |
target_type | The type of entity to query for |
target | The output list of adjacent entities |
offsets | For each entity in source, the offset in target at which the corresponding adjacent entities are stored. (output) |
Definition at line 447 of file MsqIMesh.cpp.
References MBMesquite::arrptr(), iBase_SUCCESS, ierr, iMesh_getEntArrAdj, INTERNAL_ERROR, meshInstance, MSQ_SETERR, and MBMesquite::process_itaps_error().
Referenced by elements_get_attached_vertices(), and vertices_get_attached_elements().
{ if( num_source == 0 ) { target.clear(); offsets.clear(); offsets.reserve( 1 ); offsets.push_back( 0 ); return; } int ierr, num_adj = 0, num_offset; assert( sizeof( size_t ) >= sizeof( int ) ); offsets.resize( num_source + 1 ); int* ptr2; bool expand = false; if( sizeof( size_t ) > sizeof( int ) ) { ptr2 = (int*)malloc( sizeof( int ) * ( num_source + 1 ) ); expand = true; } else { // sizeof(int) == sizeof(size_t) ptr2 = (int*)arrptr( offsets ); } assert( sizeof( iBase_EntityHandle ) == sizeof( EntityHandle ) ); bool have_adj = false; // If passed vector has allocated storage, try to use existing space if( target.capacity() >= num_source ) { target.resize( target.capacity() ); int junk1 = target.capacity(), junk3 = offsets.size(); iBase_EntityHandle* ptr = reinterpret_cast< iBase_EntityHandle* >( arrptr( target ) ); iMesh_getEntArrAdj( meshInstance, source, num_source, target_type, &ptr, &junk1, &num_adj, &ptr2, &junk3, &num_offset, &ierr ); if( iBase_SUCCESS == ierr ) { have_adj = true; target.resize( num_adj ); } } // If implementation passed back a size, try that if( !have_adj && num_adj && (unsigned)num_adj > target.capacity() ) { target.resize( num_adj ); int junk1 = target.capacity(), junk3 = offsets.size(); iBase_EntityHandle* ptr = reinterpret_cast< iBase_EntityHandle* >( arrptr( target ) ); iMesh_getEntArrAdj( meshInstance, source, num_source, target_type, &ptr, &junk1, &num_adj, &ptr2, &junk3, &num_offset, &ierr ); if( iBase_SUCCESS == ierr ) have_adj = true; } // Try with empty sidl array, and copy into elements vector if( !have_adj ) { iBase_EntityHandle* mArray = 0; int junk1 = 0, junk3 = offsets.size(); iMesh_getEntArrAdj( meshInstance, source, num_source, target_type, &mArray, &junk1, &num_adj, &ptr2, &junk3, &num_offset, &ierr ); if( iBase_SUCCESS != ierr ) { MSQ_SETERR( err )( process_itaps_error( ierr ), MsqError::INTERNAL_ERROR ); return; } target.resize( num_adj ); std::copy( mArray, mArray + num_adj, reinterpret_cast< iBase_EntityHandle* >( arrptr( target ) ) ); free( mArray ); } if( expand ) { for( size_t i = num_offset; i > 0; --i ) offsets[i - 1] = static_cast< size_t >( ptr2[i - 1] ); free( ptr2 ); } // iMesh implementations seem to be inconsistent with regard to // placing the last value on this list. if( offsets.size() - num_offset == 1 ) offsets[num_offset++] = num_adj; assert( (unsigned)num_offset == offsets.size() ); }
void MBMesquite::MsqIMesh::get_all_elements | ( | std::vector< ElementHandle > & | elements, |
) | [virtual] |
Definition at line 599 of file MsqIMesh.cpp.
References MBMesquite::arrptr(), iBase_ALL_TYPES, iBase_FACE, iBase_REGION, iBase_SUCCESS, ierr, iMesh_ALL_TOPOLOGIES, iMesh_getEntities, iMesh_getNumOfType, inputSet, inputSetType, INTERNAL_ERROR, meshInstance, MSQ_SETERR, and MBMesquite::process_itaps_error().
{ int ierr, count_in, count_out; if( inputSetType == iBase_ALL_TYPES ) { int num_vol, num_face; iMesh_getNumOfType( meshInstance, inputSet, iBase_FACE, &num_face, &ierr ); if( iBase_SUCCESS != ierr ) { MSQ_SETERR( err )( process_itaps_error( ierr ), MsqError::INTERNAL_ERROR ); return; } iMesh_getNumOfType( meshInstance, inputSet, iBase_REGION, &num_vol, &ierr ); if( iBase_SUCCESS != ierr ) { MSQ_SETERR( err )( process_itaps_error( ierr ), MsqError::INTERNAL_ERROR ); return; } elements.resize( num_face + num_vol ); if( elements.empty() ) return; iBase_EntityHandle* ptr = reinterpret_cast< iBase_EntityHandle* >( arrptr( elements ) ); if( num_face ) { count_in = num_face + num_vol; iMesh_getEntities( meshInstance, inputSet, iBase_FACE, iMesh_ALL_TOPOLOGIES, &ptr, &count_in, &count_out, &ierr ); if( iBase_SUCCESS != ierr ) { MSQ_SETERR( err )( process_itaps_error( ierr ), MsqError::INTERNAL_ERROR ); return; } assert( count_out == num_face ); } if( num_vol ) { ptr += num_face; count_in = num_vol; iMesh_getEntities( meshInstance, inputSet, iBase_REGION, iMesh_ALL_TOPOLOGIES, &ptr, &count_in, &count_out, &ierr ); if( iBase_SUCCESS != ierr ) { MSQ_SETERR( err )( process_itaps_error( ierr ), MsqError::INTERNAL_ERROR ); return; } assert( count_out == num_vol ); } } else { int count; iMesh_getNumOfType( meshInstance, inputSet, inputSetType, &count, &ierr ); if( iBase_SUCCESS != ierr ) { MSQ_SETERR( err )( process_itaps_error( ierr ), MsqError::INTERNAL_ERROR ); return; } if( !count ) return; elements.resize( count ); iBase_EntityHandle* ptr = reinterpret_cast< iBase_EntityHandle* >( arrptr( elements ) ); count_in = count; iMesh_getEntities( meshInstance, inputSet, inputSetType, iMesh_ALL_TOPOLOGIES, &ptr, &count_in, &count_out, &ierr ); if( iBase_SUCCESS != ierr ) { MSQ_SETERR( err )( process_itaps_error( ierr ), MsqError::INTERNAL_ERROR ); return; } assert( count_out == count ); } }
void MBMesquite::MsqIMesh::get_all_vertices | ( | std::vector< VertexHandle > & | vertices, |
) | [virtual] |
Definition at line 676 of file MsqIMesh.cpp.
References MBMesquite::arrptr(), elements_get_attached_vertices(), get_all_elements(), and MSQ_CHKERR.
Referenced by set_active_set().
{ std::vector< ElementHandle > elems; get_all_elements( elems, err );MSQ_CHKERR( err ); if( elems.empty() ) return; std::vector< size_t > offsets; elements_get_attached_vertices( arrptr( elems ), elems.size(), vertices, offsets, err );MSQ_CHKERR( err ); std::sort( vertices.begin(), vertices.end() ); vertices.erase( std::unique( vertices.begin(), vertices.end() ), vertices.end() ); }
iBase_EntitySetHandle MBMesquite::MsqIMesh::get_entity_set | ( | ) | const [virtual] |
const iBase_TagHandle * MBMesquite::MsqIMesh::get_fixed_tag | ( | ) | const |
Definition at line 224 of file MsqIMesh.cpp.
References fixedTag, and haveFixedTag.
{ return haveFixedTag ? &fixedTag : 0; }
void MBMesquite::MsqIMesh::get_flag_data | ( | iBase_TagHandle | tag, |
bool | have_tag, | ||
iBase_TagValueType | type, | ||
const VertexHandle | vert_array[], | ||
std::vector< bool > & | flag_array, | ||
size_t | num_vtx, | ||
) | [private] |
Definition at line 270 of file MsqIMesh.cpp.
References MBMesquite::arrptr(), iBase_BYTES, iBase_INTEGER, iBase_SUCCESS, ierr, iMesh_getArrData, iMesh_getIntArrData, INTERNAL_ERROR, MBMesquite::MsqError::INVALID_STATE, meshInstance, MSQ_SETERR, MBMesquite::process_itaps_error(), and size.
Referenced by vertices_get_fixed_flag(), and vertices_get_slaved_flag().
{ if( !num_vtx ) return; if( !have_tag ) { flag_array.clear(); flag_array.resize( num_vtx, false ); return; } flag_array.resize( num_vtx ); assert( sizeof( VertexHandle ) == sizeof( iBase_EntityHandle ) ); const iBase_EntityHandle* arr = reinterpret_cast< const iBase_EntityHandle* >( vert_array ); int ierr, alloc = num_vtx, size = 0; assert( (size_t)alloc == num_vtx ); // size_t can hold larger values than int if 64-bit if( type == iBase_INTEGER ) { std::vector< int > values( num_vtx ); int* ptr = arrptr( values ); iMesh_getIntArrData( meshInstance, arr, num_vtx, tag, &ptr, &alloc, &size, &ierr ); for( int i = 0; i < size; ++i ) flag_array[i] = !!values[i]; } else if( type == iBase_BYTES ) { std::vector< char > values( num_vtx ); void* ptr = arrptr( values ); iMesh_getArrData( meshInstance, arr, num_vtx, tag, &ptr, &alloc, &size, &ierr ); for( int i = 0; i < size; ++i ) flag_array[i] = !!values[i]; } else { MSQ_SETERR( err )( "Invalid tag type for vertex flag data", MsqError::INVALID_STATE ); return; } // check if query for tag data failed if( iBase_SUCCESS != ierr ) { MSQ_SETERR( err )( process_itaps_error( ierr ), MsqError::INTERNAL_ERROR ); return; } // make sure we got back the requested number of values assert( static_cast< size_t >( size ) == num_vtx ); }
int MBMesquite::MsqIMesh::get_geometric_dimension | ( | MBMesquite::MsqError & | ) | [virtual] |
Definition at line 263 of file MsqIMesh.cpp.
References geometricDimension.
{ return geometricDimension; }
iMesh_Instance MBMesquite::MsqIMesh::get_imesh_instance | ( | ) | const [virtual] |
const iBase_TagHandle * MBMesquite::MsqIMesh::get_slaved_tag | ( | ) | const |
Definition at line 242 of file MsqIMesh.cpp.
References haveSlavedTag, and slavedTag.
{ return haveSlavedTag ? &slavedTag : 0; }
void MBMesquite::MsqIMesh::init_active_mesh | ( | iMesh_Instance | mesh, |
const iBase_TagHandle * | fixed_tag, | ||
const iBase_TagHandle * | slaved_tag | ||
) | [private] |
Definition at line 129 of file MsqIMesh.cpp.
References byteTag, check_valid_flag_tag(), createdByteTag, fixedTag, fixedTagType, geometricDimension, haveFixedTag, haveSlavedTag, MBMesquite::HEXAHEDRON, iBase_INTEGER, iBase_SUCCESS, ierr, iMesh_ALL_TOPOLOGIES, iMesh_createTag, iMesh_getGeometricDimension, iMesh_getTagHandle, iMesh_getTagSizeBytes, iMesh_getTagType, iMesh_HEXAHEDRON, iMesh_PRISM, iMesh_PYRAMID, iMesh_QUADRILATERAL, iMesh_TETRAHEDRON, iMesh_TRIANGLE, INTERNAL_ERROR, MBMesquite::MsqError::INVALID_STATE, meshInstance, MBMesquite::MIXED, MSQ_ERRRTN, MSQ_SETERR, MBMesquite::PRISM, MBMesquite::process_itaps_error(), MBMesquite::PYRAMID, MBMesquite::QUADRILATERAL, size, slavedTag, slavedTagType, MBMesquite::TETRAHEDRON, topologyMap, MBMesquite::TRIANGLE, and MBMesquite::VERTEX_BYTE_TAG_NAME.
Referenced by MsqIMesh().
{ int ierr; // Initialize topology map const size_t mapsize = sizeof( topologyMap ) / sizeof( MBMesquite::EntityTopology ); if( mapsize < iMesh_ALL_TOPOLOGIES ) { MSQ_SETERR( err ) ( "MsqIMesh needs to be updated for new iMesh element topologies.", MsqError::INTERNAL_ERROR ); } for( size_t i = 0; i <= iMesh_ALL_TOPOLOGIES; ++i ) topologyMap[i] = MBMesquite::MIXED; topologyMap[iMesh_TRIANGLE] = MBMesquite::TRIANGLE; topologyMap[iMesh_QUADRILATERAL] = MBMesquite::QUADRILATERAL; topologyMap[iMesh_TETRAHEDRON] = MBMesquite::TETRAHEDRON; topologyMap[iMesh_HEXAHEDRON] = MBMesquite::HEXAHEDRON; topologyMap[iMesh_PRISM] = MBMesquite::PRISM; topologyMap[iMesh_PYRAMID] = MBMesquite::PYRAMID; // Check that fixed tag is valid haveFixedTag = false; if( fixed_tag ) { fixedTagType = check_valid_flag_tag( *fixed_tag, "fixed", err );MSQ_ERRRTN( err ); haveFixedTag = true; fixedTag = *fixed_tag; } // Check that slaved tag is valid haveSlavedTag = false; if( slaved_tag ) { slavedTagType = check_valid_flag_tag( *slaved_tag, "slaved", err );MSQ_ERRRTN( err ); haveSlavedTag = true; slavedTag = *slaved_tag; } // Get/create tag for vertex byte iMesh_getTagHandle( meshInstance, VERTEX_BYTE_TAG_NAME, &byteTag, &ierr, strlen( VERTEX_BYTE_TAG_NAME ) ); if( iBase_SUCCESS != ierr ) { iMesh_createTag( meshInstance, VERTEX_BYTE_TAG_NAME, 1, iBase_INTEGER, &byteTag, &ierr, strlen( VERTEX_BYTE_TAG_NAME ) ); if( iBase_SUCCESS != ierr ) { MSQ_SETERR( err ) ( MsqError::INVALID_STATE, "Tag \"%s\" could not be created", VERTEX_BYTE_TAG_NAME ); return; } createdByteTag = true; } else { int size, type; iMesh_getTagSizeBytes( meshInstance, byteTag, &size, &ierr ); if( iBase_SUCCESS != ierr || size != sizeof( int ) ) { MSQ_SETERR( err ) ( MsqError::INVALID_STATE, "Tag \"%s\" exists with invalid size", VERTEX_BYTE_TAG_NAME ); return; } iMesh_getTagType( meshInstance, byteTag, &type, &ierr ); if( iBase_SUCCESS != ierr || type != iBase_INTEGER ) { MSQ_SETERR( err ) ( MsqError::INVALID_STATE, "Tag \"%s\" exists with invalid type", VERTEX_BYTE_TAG_NAME ); return; } } iMesh_getGeometricDimension( meshInstance, &geometricDimension, &ierr ); if( iBase_SUCCESS != ierr ) { MSQ_SETERR( err )( process_itaps_error( ierr ), MsqError::INTERNAL_ERROR ); return; } }
void MBMesquite::MsqIMesh::release | ( | ) | [virtual] |
Instead of deleting a Mesh when you think you are done, call release(). In simple cases, the implementation could just call the destructor. More sophisticated implementations may want to keep the Mesh object to live longer than Mesquite is using it.
Definition at line 735 of file MsqIMesh.cpp.
void MBMesquite::MsqIMesh::release_entity_handles | ( | const EntityHandle * | handle_array, |
size_t | num_handles, | ||
) | [virtual] |
void MBMesquite::MsqIMesh::set_active_set | ( | iBase_EntitySetHandle | meshset, |
Set the mesh which Mesquite is to smooth. Optionally specify fixed vertices. NOTE: If an active set is not specified, the default is to use the global set (the ENTIRE mesh.)
element_set | ITAPS entity set handle for set containing mesh elements and vertices for which quality is to be improved. |
Definition at line 247 of file MsqIMesh.cpp.
References MBMesquite::arrptr(), get_all_vertices(), inputSet, inputSetType, MSQ_CHKERR, MSQ_ERRRTN, vertices_set_byte(), and MBMesquite::zeros.
{ inputSetType = type_in; inputSet = elem_set; // clear vertex byte std::vector< VertexHandle > verts; get_all_vertices( verts, err );MSQ_ERRRTN( err ); if( !verts.empty() ) { std::vector< unsigned char > zeros( verts.size(), 0 ); vertices_set_byte( arrptr( verts ), arrptr( zeros ), verts.size(), err );MSQ_CHKERR( err ); } }
void MBMesquite::MsqIMesh::set_fixed_tag | ( | iBase_TagHandle | tag, |
Definition at line 211 of file MsqIMesh.cpp.
References check_valid_flag_tag(), fixedTag, fixedTagType, haveFixedTag, MSQ_ERRRTN, and t.
{ iBase_TagValueType t = check_valid_flag_tag( tag, "fixed", err );MSQ_ERRRTN( err ); fixedTag = tag; fixedTagType = t; haveFixedTag = true; }
void MBMesquite::MsqIMesh::set_int_tag | ( | void * | tag, |
void * | meshset, | ||
int | value, | ||
) | [protected] |
void MBMesquite::MsqIMesh::set_slaved_tag | ( | iBase_TagHandle | tag, |
Definition at line 229 of file MsqIMesh.cpp.
References check_valid_flag_tag(), haveSlavedTag, MSQ_ERRRTN, slavedTag, slavedTagType, and t.
{ iBase_TagValueType t = check_valid_flag_tag( tag, "slaved", err );MSQ_ERRRTN( err ); slavedTag = tag; slavedTagType = t; haveSlavedTag = true; }
TagHandle MBMesquite::MsqIMesh::tag_create | ( | const std::string & | tag_name, |
TagType | type, | ||
unsigned | length, | ||
const void * | default_value, | ||
) | [virtual] |
Create a tag.
Create a user-defined data type that can be attached to any element or vertex in the mesh. For an opaque or undefined type, use type=BYTE and length=sizeof(..).
tag_name | A unique name for the data object |
type | The type of the data |
length | Number of values per entity (1->scalar, >1 ->vector) |
default_value | Default value to assign to all entities - may be NULL |
Definition at line 738 of file MsqIMesh.cpp.
References MBMesquite::Mesh::BYTE, MBMesquite::Mesh::DOUBLE, MBMesquite::Mesh::HANDLE, iBase_BYTES, iBase_DOUBLE, iBase_ENTITY_HANDLE, iBase_INTEGER, iBase_SUCCESS, ierr, iMesh_createTag, MBMesquite::Mesh::INT, INTERNAL_ERROR, MBMesquite::MsqError::INVALID_ARG, MBMesquite::length(), meshInstance, MSQ_SETERR, and MBMesquite::process_itaps_error().
{ int itaps_type; switch( type ) { case MBMesquite::Mesh::BYTE: itaps_type = iBase_BYTES; break; case MBMesquite::Mesh::INT: itaps_type = iBase_INTEGER; break; case MBMesquite::Mesh::DOUBLE: itaps_type = iBase_DOUBLE; break; case MBMesquite::Mesh::HANDLE: itaps_type = iBase_ENTITY_HANDLE; break; default: MSQ_SETERR( err )( "Invalid tag type", MsqError::INVALID_ARG ); return 0; } int ierr; iBase_TagHandle result; iMesh_createTag( meshInstance, name.c_str(), length, itaps_type, &result, &ierr, name.size() ); if( iBase_SUCCESS != ierr ) { MSQ_SETERR( err )( process_itaps_error( ierr ), MsqError::INTERNAL_ERROR ); return 0; } return static_cast< TagHandle >( result ); }
void MBMesquite::MsqIMesh::tag_delete | ( | TagHandle | handle, |
) | [virtual] |
Delete a tag.
Definition at line 772 of file MsqIMesh.cpp.
References iBase_SUCCESS, ierr, iMesh_destroyTag, INTERNAL_ERROR, meshInstance, MSQ_SETERR, and MBMesquite::process_itaps_error().
{ int ierr; iMesh_destroyTag( meshInstance, static_cast< iBase_TagHandle >( handle ), true, &ierr ); if( iBase_SUCCESS != ierr ) { MSQ_SETERR( err )( process_itaps_error( ierr ), MsqError::INTERNAL_ERROR ); return; } }
TagHandle MBMesquite::MsqIMesh::tag_get | ( | const std::string & | name, |
) | [virtual] |
Definition at line 783 of file MsqIMesh.cpp.
References iBase_SUCCESS, iBase_TAG_NOT_FOUND, ierr, iMesh_getTagHandle, INTERNAL_ERROR, meshInstance, MSQ_SETERR, MBMesquite::process_itaps_error(), and MBMesquite::MsqError::TAG_NOT_FOUND.
{ iBase_TagHandle handle = 0; int ierr; iMesh_getTagHandle( meshInstance, name.c_str(), &handle, &ierr, name.length() ); if( iBase_TAG_NOT_FOUND == ierr ) { MSQ_SETERR( err )( process_itaps_error( ierr ), MsqError::TAG_NOT_FOUND ); return 0; } else if( iBase_SUCCESS != ierr ) { MSQ_SETERR( err )( process_itaps_error( ierr ), MsqError::INTERNAL_ERROR ); return 0; } return static_cast< TagHandle >( handle ); }
void MBMesquite::MsqIMesh::tag_get_data | ( | TagHandle | handle, |
const EntityHandle * | handle_array, | ||
void * | tag_data, | ||
) | [private] |
Get tag values.
Definition at line 892 of file MsqIMesh.cpp.
References iBase_SUCCESS, ierr, iMesh_getArrData, iMesh_getTagSizeBytes, INTERNAL_ERROR, meshInstance, MSQ_SETERR, MBMesquite::process_itaps_error(), and size.
Referenced by tag_get_element_data(), and tag_get_vertex_data().
{ int ierr, size; iMesh_getTagSizeBytes( meshInstance, static_cast< iBase_TagHandle >( tag ), &size, &ierr ); if( iBase_SUCCESS != ierr ) { MSQ_SETERR( err )( process_itaps_error( ierr ), MsqError::INTERNAL_ERROR ); return; } #if IMESH_VERSION_ATLEAST( 1, 1 ) void* ptr = data; #else char* ptr = static_cast< char* >( data ); #endif int junk1 = size * num_elems, junk2; assert( sizeof( EntityHandle ) == sizeof( iBase_EntityHandle ) ); const iBase_EntityHandle* arr = reinterpret_cast< const iBase_EntityHandle* >( array ); iMesh_getArrData( meshInstance, arr, num_elems, static_cast< iBase_TagHandle >( tag ), &ptr, &junk1, &junk2, &ierr ); if( iBase_SUCCESS != ierr ) { MSQ_SETERR( err )( process_itaps_error( ierr ), MsqError::INTERNAL_ERROR ); return; } }
void MBMesquite::MsqIMesh::tag_get_element_data | ( | TagHandle | handle, |
const ElementHandle * | elem_array, | ||
) | [virtual] |
Get the value of a tag for a list of mesh elements.
handle | The tag |
num_elems | Length of elem_array |
elem_array | Array of elements for which to get the tag value. |
tag_data | Return buffer in which to copy tag data, contiguous in memory. This data is expected to be num_elems*tag_length*sizeof(tag_type) bytes. |
Definition at line 880 of file MsqIMesh.cpp.
References tag_get_data().
{ tag_get_data( tag, num_elems, array, data, err ); }
void MBMesquite::MsqIMesh::tag_get_vertex_data | ( | TagHandle | handle, |
const VertexHandle * | node_array, | ||
) | [virtual] |
Get the value of a tag for a list of mesh vertices.
handle | The tag |
elem_array | Array of vertices for which to get the tag value. |
Definition at line 886 of file MsqIMesh.cpp.
void MBMesquite::MsqIMesh::tag_properties | ( | TagHandle | handle, |
std::string & | name_out, | ||
TagType & | type_out, | ||
unsigned & | length_out, | ||
) | [virtual] |
Get data type and number of values per entity for tag.
handle | Tag to get properties of. |
name_out | Passed back tag name. |
type_out | Passed back tag type. |
length_out | Passed back number of values per entity. |
Definition at line 801 of file MsqIMesh.cpp.
References buffer, MBMesquite::Mesh::BYTE, MBMesquite::Mesh::DOUBLE, MBMesquite::Mesh::HANDLE, iBase_BYTES, iBase_DOUBLE, iBase_ENTITY_HANDLE, iBase_INTEGER, iBase_SUCCESS, ierr, iMesh_getTagName, iMesh_getTagSizeValues, iMesh_getTagType, MBMesquite::Mesh::INT, INTERNAL_ERROR, meshInstance, MSQ_SETERR, NOT_IMPLEMENTED, and MBMesquite::process_itaps_error().
{ char buffer[256]; int ierr1, ierr2, ierr3, itype; iBase_TagHandle th = static_cast< iBase_TagHandle >( handle ); iMesh_getTagName( meshInstance, th, buffer, &ierr1, sizeof( buffer ) ); iMesh_getTagSizeValues( meshInstance, th, (int*)&length_out, &ierr2 ); iMesh_getTagType( meshInstance, th, &itype, &ierr3 ); int ierr = iBase_SUCCESS; if( ierr1 != iBase_SUCCESS ) ierr = ierr1; else if( ierr2 != iBase_SUCCESS ) ierr = ierr2; else if( ierr3 != iBase_SUCCESS ) ierr = ierr3; if( iBase_SUCCESS != ierr ) { MSQ_SETERR( err )( process_itaps_error( ierr ), MsqError::INTERNAL_ERROR ); return; } buffer[255] = '\0'; name_out = buffer; switch( itype ) { case iBase_BYTES: type_out = MBMesquite::Mesh::BYTE; break; case iBase_INTEGER: type_out = MBMesquite::Mesh::INT; break; case iBase_DOUBLE: type_out = MBMesquite::Mesh::DOUBLE; break; case iBase_ENTITY_HANDLE: type_out = MBMesquite::Mesh::HANDLE; break; default: MSQ_SETERR( err )( "Unsupported iMesh tag type", MsqError::NOT_IMPLEMENTED ); return; } }
void MBMesquite::MsqIMesh::tag_set_data | ( | TagHandle | handle, |
const void * | tag_data, | ||
) | [private] |
Set tag values.
Definition at line 859 of file MsqIMesh.cpp.
References iBase_SUCCESS, ierr, iMesh_getTagSizeBytes, iMesh_setArrData, INTERNAL_ERROR, meshInstance, MSQ_SETERR, MBMesquite::process_itaps_error(), and size.
Referenced by tag_set_element_data(), and tag_set_vertex_data().
{ int ierr, size; iMesh_getTagSizeBytes( meshInstance, static_cast< iBase_TagHandle >( tag ), &size, &ierr ); if( iBase_SUCCESS != ierr ) { MSQ_SETERR( err )( process_itaps_error( ierr ), MsqError::INTERNAL_ERROR ); return; } assert( sizeof( EntityHandle ) == sizeof( iBase_EntityHandle ) ); const iBase_EntityHandle* arr = reinterpret_cast< const iBase_EntityHandle* >( array ); iMesh_setArrData( meshInstance, arr, num_elems, static_cast< iBase_TagHandle >( tag ), static_cast< const char* >( data ), size * num_elems, &ierr ); if( iBase_SUCCESS != ierr ) { MSQ_SETERR( err )( process_itaps_error( ierr ), MsqError::INTERNAL_ERROR ); return; } }
void MBMesquite::MsqIMesh::tag_set_element_data | ( | TagHandle | handle, |
) | [virtual] |
Set the value of a tag for a list of mesh elements.
handle | The tag |
elem_array | Array of elements for which to set the tag value. |
tag_data | Tag data for each element, contiguous in memory. This data is expected to be |
Definition at line 847 of file MsqIMesh.cpp.
References tag_set_data().
{ tag_set_data( tag, num_elems, array, data, err ); }
void MBMesquite::MsqIMesh::tag_set_vertex_data | ( | TagHandle | handle, |
) | [virtual] |
Set the value of a tag for a list of mesh vertices.
handle | The tag |
num_elems | Length of node_array |
node_array | Array of vertices for which to set the tag value. |
tag_data | Tag data for each element, contiguous in memory. This data is expected to be num_elems*tag_length*sizeof(tag_type) bytes. |
Definition at line 853 of file MsqIMesh.cpp.
void MBMesquite::MsqIMesh::vertex_get_byte | ( | VertexHandle | vertex, |
unsigned char * | byte, | ||
) | [virtual] |
Get vertex mark.
Definition at line 420 of file MsqIMesh.cpp.
References byteTag, iBase_SUCCESS, ierr, iMesh_getIntData, INTERNAL_ERROR, meshInstance, MSQ_SETERR, MBMesquite::process_itaps_error(), and value().
{ int ierr, value; iBase_EntityHandle bh = static_cast< iBase_EntityHandle >( vertex ); iMesh_getIntData( meshInstance, bh, byteTag, &value, &ierr ); if( iBase_SUCCESS != ierr ) MSQ_SETERR( err )( process_itaps_error( ierr ), MsqError::INTERNAL_ERROR ); *byte = value; }
void MBMesquite::MsqIMesh::vertex_set_byte | ( | VertexHandle | vertex, |
unsigned char | byte, | ||
) | [virtual] |
Set vertex mark.
Definition at line 395 of file MsqIMesh.cpp.
References byteTag, iBase_SUCCESS, ierr, iMesh_setIntData, INTERNAL_ERROR, meshInstance, MSQ_SETERR, MBMesquite::process_itaps_error(), and value().
{ int ierr, value = byte; iBase_EntityHandle bh = static_cast< iBase_EntityHandle >( vertex ); iMesh_setIntData( meshInstance, bh, byteTag, value, &ierr ); if( iBase_SUCCESS != ierr ) MSQ_SETERR( err )( process_itaps_error( ierr ), MsqError::INTERNAL_ERROR ); }
void MBMesquite::MsqIMesh::vertex_set_coordinates | ( | VertexHandle | vertex, |
const Vector3D & | coordinates, | ||
) | [virtual] |
Definition at line 383 of file MsqIMesh.cpp.
References iBase_SUCCESS, ierr, iMesh_setVtxCoord, INTERNAL_ERROR, meshInstance, MSQ_SETERR, and MBMesquite::process_itaps_error().
{ int ierr; iBase_EntityHandle bh = static_cast< iBase_EntityHandle >( vertex ); iMesh_setVtxCoord( meshInstance, bh, coords[0], coords[1], coords[2], &ierr ); if( iBase_SUCCESS != ierr ) MSQ_SETERR( err )( process_itaps_error( ierr ), MsqError::INTERNAL_ERROR ); }
void MBMesquite::MsqIMesh::vertices_get_attached_elements | ( | const VertexHandle * | vertex_array, |
size_t | num_vertices, | ||
std::vector< ElementHandle > & | elements, | ||
) | [virtual] |
Definition at line 536 of file MsqIMesh.cpp.
References get_adjacent_entities(), iBase_SUCCESS, ierr, iMesh_getRootSet, iMesh_isEntContained, inputSet, inputSetType, INTERNAL_ERROR, meshInstance, MSQ_ERRRTN, MSQ_SETERR, MBMesquite::process_itaps_error(), and root_set.
{ int ierr, cont; assert( sizeof( EntityHandle ) == sizeof( iBase_EntityHandle ) ); const iBase_EntityHandle* verts = reinterpret_cast< const iBase_EntityHandle* >( vertices ); get_adjacent_entities( verts, num_vertex, inputSetType, elements, offsets, err );MSQ_ERRRTN( err ); iBase_EntitySetHandle root_set; iMesh_getRootSet( meshInstance, &root_set, &ierr ); if( iBase_SUCCESS != ierr ) { MSQ_SETERR( err )( process_itaps_error( ierr ), MsqError::INTERNAL_ERROR ); return; } // Remove all elements not in inputSet if( root_set != inputSet ) { std::vector< size_t >::iterator offset_iter = offsets.begin(); size_t read_idx, write_idx; for( read_idx = write_idx = 0; read_idx < elements.size(); ++read_idx ) { if( *offset_iter == read_idx ) { *offset_iter = write_idx; ++offset_iter; } iBase_EntityHandle bh = static_cast< iBase_EntityHandle >( elements[read_idx] ); iMesh_isEntContained( meshInstance, inputSet, bh, &cont, &ierr ); if( iBase_SUCCESS != ierr ) { MSQ_SETERR( err )( process_itaps_error( ierr ), MsqError::INTERNAL_ERROR ); return; } if( cont ) elements[write_idx++] = elements[read_idx]; } *offset_iter = write_idx; elements.resize( write_idx ); } }
void MBMesquite::MsqIMesh::vertices_get_byte | ( | const VertexHandle * | vert_array, |
unsigned char * | byte_array, | ||
size_t | array_size, | ||
) | [virtual] |
Get vertex mark.
Definition at line 429 of file MsqIMesh.cpp.
References MBMesquite::arrptr(), byteTag, iBase_SUCCESS, ierr, iMesh_getIntArrData, INTERNAL_ERROR, meshInstance, MSQ_SETERR, and MBMesquite::process_itaps_error().
{ if( !array_size ) return; std::vector< int > data( array_size ); int ierr; int* ptr = arrptr( data ); int junk1 = data.size(), junk2; assert( sizeof( VertexHandle ) == sizeof( iBase_EntityHandle ) ); const iBase_EntityHandle* arr = reinterpret_cast< const iBase_EntityHandle* >( vert_array ); iMesh_getIntArrData( meshInstance, arr, array_size, byteTag, &ptr, &junk1, &junk2, &ierr ); if( iBase_SUCCESS != ierr ) MSQ_SETERR( err )( process_itaps_error( ierr ), MsqError::INTERNAL_ERROR ); std::copy( data.begin(), data.end(), byte_array ); }
void MBMesquite::MsqIMesh::vertices_get_coordinates | ( | const VertexHandle | vert_array[], |
MsqVertex * | coordinates, | ||
) | [virtual] |
Definition at line 342 of file MsqIMesh.cpp.
References MBMesquite::arrptr(), geometricDimension, iBase_INTERLEAVED, iBase_SUCCESS, ierr, iMesh_getVtxArrCoords, INTERNAL_ERROR, meshInstance, MSQ_SETERR, MBMesquite::process_itaps_error(), MBMesquite::Vector3D::set(), MBMesquite::Vector3D::x(), MBMesquite::Vector3D::y(), and MBMesquite::Vector3D::z().
{ if( !num_vtx ) return; std::vector< double > dbl_store( 3 * num_vtx ); double* dbl_array = arrptr( dbl_store ); int ierr, junk = 3 * num_vtx, junk2; assert( sizeof( VertexHandle ) == sizeof( iBase_EntityHandle ) ); const iBase_EntityHandle* arr = reinterpret_cast< const iBase_EntityHandle* >( vert_array ); iMesh_getVtxArrCoords( meshInstance, arr, num_vtx, iBase_INTERLEAVED, &dbl_array, &junk, &junk2, &ierr ); if( iBase_SUCCESS != ierr ) { MSQ_SETERR( err )( process_itaps_error( ierr ), MsqError::INTERNAL_ERROR ); return; } if( geometricDimension == 2 ) { double* iter = dbl_array; for( size_t i = 0; i < num_vtx; ++i ) { coordinates[i].x( *iter ); ++iter; coordinates[i].y( *iter ); ++iter; coordinates[i].z( 0 ); } } else { double* iter = dbl_array; for( size_t i = 0; i < num_vtx; ++i ) { coordinates[i].set( iter ); iter += 3; } } }
void MBMesquite::MsqIMesh::vertices_get_fixed_flag | ( | const VertexHandle | vert_array[], |
std::vector< bool > & | fixed_flag_array, | ||
) | [virtual] |
Definition at line 329 of file MsqIMesh.cpp.
References fixedTag, fixedTagType, get_flag_data(), and haveFixedTag.
{ get_flag_data( fixedTag, haveFixedTag, fixedTagType, vert_array, bool_array, num_vtx, err ); }
void MBMesquite::MsqIMesh::vertices_get_slaved_flag | ( | const VertexHandle | vert_array[], |
std::vector< bool > & | slaved_flag_array, | ||
) | [virtual] |
Returns true or false, indicating whether the vertex is a higher-order node that should be slaved to the logical mid-point of the element side it lies on or not, respectively.
Note: This function will never be called unless this behavior is requested by calling: InstructionQueue::set_slaved_ho_node_mode( Settings::SLAVE_FLAG )
Definition at line 335 of file MsqIMesh.cpp.
References get_flag_data(), haveSlavedTag, slavedTag, and slavedTagType.
{ get_flag_data( slavedTag, haveSlavedTag, slavedTagType, vert_array, bool_array, num_vtx, err ); }
void MBMesquite::MsqIMesh::vertices_set_byte | ( | const VertexHandle * | vert_array, |
const unsigned char * | byte_array, | ||
) | [virtual] |
Set vertex mark.
Definition at line 403 of file MsqIMesh.cpp.
References MBMesquite::arrptr(), byteTag, iBase_SUCCESS, ierr, iMesh_setIntArrData, INTERNAL_ERROR, meshInstance, MSQ_SETERR, and MBMesquite::process_itaps_error().
{ if( !array_size ) return; std::vector< int > data( array_size ); std::copy( byte_array, byte_array + array_size, data.begin() ); int ierr; assert( sizeof( VertexHandle ) == sizeof( iBase_EntityHandle ) ); const iBase_EntityHandle* arr = reinterpret_cast< const iBase_EntityHandle* >( vert_array ); iMesh_setIntArrData( meshInstance, arr, array_size, byteTag, arrptr( data ), array_size, &ierr ); if( iBase_SUCCESS != ierr ) MSQ_SETERR( err )( process_itaps_error( ierr ), MsqError::INTERNAL_ERROR ); }
iBase_TagHandle MBMesquite::MsqIMesh::byteTag [private] |
Handle for tag used to hold vertex byte
Definition at line 372 of file MsqIMesh.hpp.
Referenced by init_active_mesh(), vertex_get_byte(), vertex_set_byte(), vertices_get_byte(), vertices_set_byte(), and ~MsqIMesh().
bool MBMesquite::MsqIMesh::createdByteTag [private] |
Tag was created in constructor
Definition at line 374 of file MsqIMesh.hpp.
Referenced by init_active_mesh(), and ~MsqIMesh().
Handle for tag used to hold vertex-fixed flag
Definition at line 376 of file MsqIMesh.hpp.
Referenced by get_fixed_tag(), init_active_mesh(), set_fixed_tag(), and vertices_get_fixed_flag().
iBase_TYPE for fixed tag
Definition at line 380 of file MsqIMesh.hpp.
Referenced by init_active_mesh(), set_fixed_tag(), and vertices_get_fixed_flag().
int MBMesquite::MsqIMesh::geometricDimension [private] |
Dimension is queried once during create and cached
Definition at line 388 of file MsqIMesh.hpp.
Referenced by get_geometric_dimension(), init_active_mesh(), and vertices_get_coordinates().
bool MBMesquite::MsqIMesh::haveFixedTag [private] |
fixedTag handle is valid
Definition at line 378 of file MsqIMesh.hpp.
Referenced by clear_fixed_tag(), get_fixed_tag(), init_active_mesh(), set_fixed_tag(), and vertices_get_fixed_flag().
bool MBMesquite::MsqIMesh::haveMesh [private] |
Have mesh
Definition at line 350 of file MsqIMesh.hpp.
bool MBMesquite::MsqIMesh::haveSlavedTag [private] |
slavedTag handle is valid
Definition at line 384 of file MsqIMesh.hpp.
Referenced by clear_slaved_tag(), get_slaved_tag(), init_active_mesh(), set_slaved_tag(), and vertices_get_slaved_flag().
The meshset containing the elements to optimize
Definition at line 369 of file MsqIMesh.hpp.
Referenced by get_all_elements(), get_entity_set(), set_active_set(), and vertices_get_attached_elements().
ITAPS entity set handle for elements to improve ITAPS entity set handle for nodes to move std::set containing elements in elementSet, used to constrain vertex->element adjaceny queries to only those elements that are in the input element set. The type of elements contained in the input element set. Should be one of:
Definition at line 367 of file MsqIMesh.hpp.
Referenced by get_all_elements(), set_active_set(), and vertices_get_attached_elements().
iMesh_Instance MBMesquite::MsqIMesh::meshInstance [protected] |
The IMesh instance
Definition at line 332 of file MsqIMesh.hpp.
Referenced by check_valid_flag_tag(), elements_get_topologies(), get_adjacent_entities(), get_all_elements(), get_flag_data(), get_imesh_instance(), init_active_mesh(), tag_create(), tag_delete(), tag_get(), tag_get_data(), tag_properties(), tag_set_data(), vertex_get_byte(), vertex_set_byte(), vertex_set_coordinates(), vertices_get_attached_elements(), vertices_get_byte(), vertices_get_coordinates(), MBMesquite::MsqIMeshP::vertices_get_global_id(), MBMesquite::MsqIMeshP::vertices_get_processor_id(), vertices_set_byte(), and ~MsqIMesh().
Handle for tag used to hold vertex-slaved flag
Definition at line 382 of file MsqIMesh.hpp.
Referenced by get_slaved_tag(), init_active_mesh(), set_slaved_tag(), and vertices_get_slaved_flag().
iBase_TYPE for slaved tag
Definition at line 386 of file MsqIMesh.hpp.
Referenced by init_active_mesh(), set_slaved_tag(), and vertices_get_slaved_flag().
Map iMesh_EntityTopology to MBMesquite::EntityTopology
Definition at line 390 of file MsqIMesh.hpp.
Referenced by elements_get_topologies(), and init_active_mesh().
