BOOL enum value | MBMesquite::Mesh | |
BYTE enum value | MBMesquite::Mesh | |
byteTag | MBMesquite::MsqIMesh | [private] |
check_valid_flag_tag(iBase_TagHandle tag, const char *which_flag, MsqError &err) | MBMesquite::MsqIMesh | [protected] |
clear_fixed_tag() | MBMesquite::MsqIMesh | |
clear_slaved_tag() | MBMesquite::MsqIMesh | |
createdByteTag | MBMesquite::MsqIMesh | [private] |
DOUBLE enum value | MBMesquite::Mesh | |
ElementHandle typedef | MBMesquite::Mesh | |
elements_get_attached_vertices(const ElementHandle *elem_handles, size_t num_elems, std::vector< VertexHandle > &vertices, std::vector< size_t > &offsets, MsqError &err) | MBMesquite::MsqIMesh | [virtual] |
elements_get_topologies(const ElementHandle *element_handle_array, EntityTopology *element_topologies, size_t num_elements, MsqError &err) | MBMesquite::MsqIMesh | [virtual] |
EntityHandle typedef | MBMesquite::Mesh | |
fixedTag | MBMesquite::MsqIMesh | [private] |
fixedTagType | MBMesquite::MsqIMesh | [private] |
geometricDimension | MBMesquite::MsqIMesh | [private] |
get_adjacent_entities(const iBase_EntityHandle *source, size_t num_source, iBase_EntityType target_type, std::vector< EntityHandle > &target, std::vector< size_t > &offsets, MsqError &err) | MBMesquite::MsqIMesh | [protected] |
get_all_elements(std::vector< ElementHandle > &elements, MsqError &err) | MBMesquite::MsqIMesh | [virtual] |
get_all_vertices(std::vector< VertexHandle > &vertices, MsqError &err) | MBMesquite::MsqIMesh | [virtual] |
get_entity_set() const | MBMesquite::MsqIMesh | [virtual] |
get_fixed_tag() const | MBMesquite::MsqIMesh | |
get_flag_data(iBase_TagHandle tag, bool have_tag, iBase_TagValueType type, const VertexHandle vert_array[], std::vector< bool > &flag_array, size_t num_vtx, MsqError &err) | MBMesquite::MsqIMesh | [private] |
get_geometric_dimension(MBMesquite::MsqError &) | MBMesquite::MsqIMesh | [virtual] |
get_imesh_instance() const | MBMesquite::MsqIMesh | [virtual] |
get_slaved_tag() const | MBMesquite::MsqIMesh | |
HANDLE enum value | MBMesquite::Mesh | |
haveFixedTag | MBMesquite::MsqIMesh | [private] |
haveMesh | MBMesquite::MsqIMesh | [private] |
haveSlavedTag | MBMesquite::MsqIMesh | [private] |
init_active_mesh(iMesh_Instance mesh, MsqError &err, const iBase_TagHandle *fixed_tag, const iBase_TagHandle *slaved_tag) | MBMesquite::MsqIMesh | [private] |
inputSet | MBMesquite::MsqIMesh | [private] |
inputSetType | MBMesquite::MsqIMesh | [private] |
INT enum value | MBMesquite::Mesh | |
meshInstance | MBMesquite::MsqIMesh | [protected] |
MsqIMesh() | MBMesquite::MsqIMesh | |
MsqIMesh(iMesh_Instance imesh, iBase_EntitySetHandle meshset, iBase_EntityType element_dimension, MsqError &err, const iBase_TagHandle *fixed_tag=0, const iBase_TagHandle *slaved_tag=0) | MBMesquite::MsqIMesh | |
MsqIMesh(iMesh_Instance imesh, iBase_EntityType element_dimension, MsqError &err, const iBase_TagHandle *fixed_tag=0, const iBase_TagHandle *slaved_tag=0) | MBMesquite::MsqIMesh | |
release() | MBMesquite::MsqIMesh | [virtual] |
release_entity_handles(const EntityHandle *handle_array, size_t num_handles, MsqError &err) | MBMesquite::MsqIMesh | [virtual] |
set_active_set(iBase_EntitySetHandle meshset, iBase_EntityType element_dimension, MsqError &err) | MBMesquite::MsqIMesh | |
set_fixed_tag(iBase_TagHandle tag, MsqError &err) | MBMesquite::MsqIMesh | |
set_int_tag(void *tag, void *meshset, int value, MsqError &err) | MBMesquite::MsqIMesh | [protected] |
set_slaved_tag(iBase_TagHandle tag, MsqError &err) | MBMesquite::MsqIMesh | |
slavedTag | MBMesquite::MsqIMesh | [private] |
slavedTagType | MBMesquite::MsqIMesh | [private] |
tag_create(const std::string &tag_name, TagType type, unsigned length, const void *default_value, MsqError &err) | MBMesquite::MsqIMesh | [virtual] |
tag_delete(TagHandle handle, MsqError &err) | MBMesquite::MsqIMesh | [virtual] |
tag_get(const std::string &name, MsqError &err) | MBMesquite::MsqIMesh | [virtual] |
tag_get_data(TagHandle handle, size_t num_elems, const EntityHandle *handle_array, void *tag_data, MsqError &err) | MBMesquite::MsqIMesh | [private] |
tag_get_element_data(TagHandle handle, size_t num_elems, const ElementHandle *elem_array, void *tag_data, MsqError &err) | MBMesquite::MsqIMesh | [virtual] |
tag_get_vertex_data(TagHandle handle, size_t num_elems, const VertexHandle *node_array, void *tag_data, MsqError &err) | MBMesquite::MsqIMesh | [virtual] |
tag_properties(TagHandle handle, std::string &name_out, TagType &type_out, unsigned &length_out, MsqError &err) | MBMesquite::MsqIMesh | [virtual] |
tag_set_data(TagHandle handle, size_t num_elems, const EntityHandle *handle_array, const void *tag_data, MsqError &err) | MBMesquite::MsqIMesh | [private] |
tag_set_element_data(TagHandle handle, size_t num_elems, const ElementHandle *elem_array, const void *tag_data, MsqError &err) | MBMesquite::MsqIMesh | [virtual] |
tag_set_vertex_data(TagHandle handle, size_t num_elems, const VertexHandle *node_array, const void *tag_data, MsqError &err) | MBMesquite::MsqIMesh | [virtual] |
TagType enum name | MBMesquite::Mesh | |
topologyMap | MBMesquite::MsqIMesh | [private] |
vertex_get_byte(VertexHandle vertex, unsigned char *byte, MsqError &err) | MBMesquite::MsqIMesh | [virtual] |
vertex_set_byte(VertexHandle vertex, unsigned char byte, MsqError &err) | MBMesquite::MsqIMesh | [virtual] |
vertex_set_coordinates(VertexHandle vertex, const Vector3D &coordinates, MsqError &err) | MBMesquite::MsqIMesh | [virtual] |
VertexHandle typedef | MBMesquite::Mesh | |
vertices_get_attached_elements(const VertexHandle *vertex_array, size_t num_vertices, std::vector< ElementHandle > &elements, std::vector< size_t > &offsets, MsqError &err) | MBMesquite::MsqIMesh | [virtual] |
vertices_get_byte(const VertexHandle *vert_array, unsigned char *byte_array, size_t array_size, MsqError &err) | MBMesquite::MsqIMesh | [virtual] |
vertices_get_coordinates(const VertexHandle vert_array[], MsqVertex *coordinates, size_t num_vtx, MsqError &err) | MBMesquite::MsqIMesh | [virtual] |
vertices_get_fixed_flag(const VertexHandle vert_array[], std::vector< bool > &fixed_flag_array, size_t num_vtx, MsqError &err) | MBMesquite::MsqIMesh | [virtual] |
vertices_get_slaved_flag(const VertexHandle vert_array[], std::vector< bool > &slaved_flag_array, size_t num_vtx, MsqError &err) | MBMesquite::MsqIMesh | [virtual] |
vertices_set_byte(const VertexHandle *vert_array, const unsigned char *byte_array, size_t array_size, MsqError &err) | MBMesquite::MsqIMesh | [virtual] |
~Mesh() | MBMesquite::Mesh | [inline, virtual] |
~MsqIMesh() | MBMesquite::MsqIMesh | [virtual] |
