MOAB: Mesh Oriented datABase
(version 5.4.0)
00001 /* ***************************************************************** 00002 MESQUITE -- The Mesh Quality Improvement Toolkit 00003 00004 Copyright 2009 Sandia National Laboratories. Developed at the 00005 University of Wisconsin--Madison under SNL contract number 00006 624796. The U.S. Government and the University of Wisconsin 00007 retain certain rights to this software. 00008 00009 This library is free software; you can redistribute it and/or 00010 modify it under the terms of the GNU Lesser General Public 00011 License as published by the Free Software Foundation; either 00012 version 2.1 of the License, or (at your option) any later version. 00013 00014 This library is distributed in the hope that it will be useful, 00015 but WITHOUT ANY WARRANTY; without even the implied warranty of 00016 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00017 Lesser General Public License for more details. 00018 00019 You should have received a copy of the GNU Lesser General Public License 00020 (lgpl.txt) along with this library; if not, write to the Free Software 00021 Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA 00022 00023 (2010) kraftche@cae.wisc.edu 00024 00025 ***************************************************************** */ 00026 00027 #include "Mesquite.hpp" 00028 #include "MsqIGeom.hpp" 00029 #include "FacetModifyEngine.hpp" 00030 #include "MeshImpl.hpp" 00031 #include "MsqError.hpp" 00032 #include "ShapeImprovementWrapper.hpp" 00033 #include "MsqVertex.hpp" 00034 #include "QualityAssessor.hpp" 00035 #include "SphericalDomain.hpp" 00036 #include "TestUtil.hpp" 00037 00038 #include <memory> 00039 #include <iostream> 00040 00041 #include "MsqIBase.hpp" 00042 00043 using namespace MBMesquite; 00044 00045 // characteristics of geometry 00046 const double SPHERE_RADIUS = 3.0; 00047 const Vector3D SPHERE_CENTER( 2.0, 2.0, 0.0 ); 00048 00049 #define CHKIGEOM \ 00050 if( chk_igeom_error( ierr, __FILE__, __LINE__ ) ) return 0 00051 00052 bool chk_igeom_error( int ierr, const char* file, int line ) 00053 { 00054 if( iBase_SUCCESS == ierr ) return false; 00055 std::cerr << "iGeom call failed at " << file << ":" << line << std::endl; 00056 std::cerr << process_itaps_error( ierr ) << std::endl; 00057 return true; 00058 } 00059 00060 std::string default_file_name = TestDir + "unittest/mesquite/2D/vtk/quads/untangled/quads_on_sphere_529.vtk"; 00061 00062 void usage() 00063 { 00064 std::cout << "main [-N] [filename] [-o <output_file>]" << std::endl; 00065 std::cout << " -N : Use native representation instead of iGeom implementation\n" << std::endl; 00066 std::cout << " If no file name is specified, will use \"" << default_file_name << '"' << std::endl; 00067 exit( 1 ); 00068 } 00069 00070 void run_smoother( Mesh& mesh, MeshDomain* domain, MsqError& err ); 00071 bool check_results( Mesh& mesh, MeshDomain* domain, MsqError& err ); 00072 MeshDomain* get_itaps_domain(); 00073 MeshDomain* get_mesquite_domain(); 00074 00075 int main( int argc, char* argv[] ) 00076 { 00077 // command line arguments 00078 const char* file_name = 0; 00079 const char* output_file = 0; 00080 bool use_native = false, opts_done = false; 00081 for( int arg = 1; arg < argc; ++arg ) 00082 { 00083 if( !opts_done && argv[arg][0] == '-' ) 00084 { 00085 if( !strcmp( argv[arg], "-N" ) ) 00086 use_native = true; 00087 else if( !strcmp( argv[arg], "-o" ) ) 00088 output_file = argv[arg++]; 00089 else if( !strcmp( argv[arg], "--" ) ) 00090 opts_done = true; 00091 else 00092 usage(); 00093 } 00094 else if( !file_name ) 00095 file_name = argv[arg]; 00096 else 00097 usage(); 00098 } 00099 if( !file_name ) 00100 { 00101 file_name = default_file_name.c_str(); 00102 std::cout << "No file specified: using default: " << default_file_name << std::endl; 00103 } 00104 00105 MsqError err; 00106 MeshImpl mesh; 00107 mesh.read_vtk( file_name, err ); 00108 if( MSQ_CHKERR( err ) ) 00109 { 00110 std::cerr << err << std::endl; 00111 std::cerr << "Failed to read input file: " << file_name << std::endl; 00112 return 1; 00113 } 00114 00115 std::unique_ptr< MeshDomain > dom( use_native ? get_mesquite_domain() : get_itaps_domain() ); 00116 00117 if( !dom.get() ) 00118 { 00119 MSQ_SETERR( err )( "Domain creation failed", MsqError::INTERNAL_ERROR ); 00120 std::cerr << err << std::endl; 00121 return 1; 00122 } 00123 00124 run_smoother( mesh, dom.get(), err ); 00125 if( MSQ_CHKERR( err ) ) 00126 { 00127 std::cerr << err << std::endl; 00128 std::cerr << "Smoother failed." << std::endl; 00129 return 1; 00130 } 00131 00132 if( output_file ) 00133 { 00134 mesh.write_vtk( output_file, err ); 00135 if( MSQ_CHKERR( err ) ) 00136 { 00137 std::cerr << err << std::endl; 00138 std::cerr << "Failed to write file: " << output_file << std::endl; 00139 return 1; 00140 } 00141 } 00142 00143 bool valid = check_results( mesh, dom.get(), err ); 00144 if( MSQ_CHKERR( err ) ) 00145 { 00146 std::cerr << err << std::endl; 00147 std::cerr << "Error while validating results." << std::endl; 00148 return 1; 00149 } 00150 00151 return !valid; 00152 } 00153 00154 void run_smoother( Mesh& mesh, MeshDomain* dom, MsqError& err ) 00155 { 00156 ShapeImprovementWrapper smoother; 00157 MeshDomainAssoc mesh_and_domain = MeshDomainAssoc( &mesh, dom ); 00158 smoother.run_instructions( &mesh_and_domain, err );MSQ_CHKERR( err ); 00159 00160 if( smoother.quality_assessor().invalid_elements() ) 00161 { 00162 MSQ_SETERR( err )( "Smoothing produced invalid elements", MsqError::INVALID_MESH ); 00163 return; 00164 } 00165 } 00166 00167 bool check_results( Mesh& mesh, MeshDomain* dom, MsqError& err ) 00168 { 00169 double EPS = 1e-2; 00170 00171 std::vector< Mesh::VertexHandle > handles; 00172 mesh.get_all_vertices( handles, err ); 00173 MSQ_ERRZERO( err ); 00174 std::vector< MsqVertex > coords( handles.size() ); 00175 mesh.vertices_get_coordinates( arrptr( handles ), arrptr( coords ), handles.size(), err ); 00176 MSQ_ERRZERO( err ); 00177 00178 bool valid = true; 00179 size_t c = 0; 00180 for( size_t i = 0; i < coords.size(); ++i ) 00181 { 00182 double d = ( coords[i] - SPHERE_CENTER ).length(); 00183 if( fabs( d - SPHERE_RADIUS ) > EPS ) ++c; 00184 } 00185 if( c ) 00186 { 00187 std::cerr << c << " vertices not on domain" << std::endl; 00188 valid = false; 00189 } 00190 00191 std::vector< unsigned short > dof( handles.size() ), exp_dof( handles.size(), 2 ); 00192 dom->domain_DoF( arrptr( handles ), arrptr( dof ), handles.size(), err ); 00193 MSQ_ERRZERO( err ); 00194 if( dof != exp_dof ) 00195 { 00196 std::cerr << "Invalid domain dimension for one or more vertices" << std::endl; 00197 valid = false; 00198 } 00199 00200 c = 0; 00201 std::vector< Vector3D > normals( coords.begin(), coords.end() ); 00202 dom->vertex_normal_at( arrptr( handles ), arrptr( normals ), handles.size(), err ); 00203 MSQ_ERRZERO( err ); 00204 for( size_t i = 0; i < handles.size(); ++i ) 00205 { 00206 Vector3D exp_norm = ~( coords[i] - SPHERE_CENTER ); 00207 Vector3D act_norm = ~normals[i]; 00208 Vector3D diff = exp_norm - act_norm; 00209 if( diff.length() > EPS ) ++c; 00210 } 00211 if( c ) 00212 { 00213 std::cerr << c << " invalid vertex normals" << std::endl; 00214 valid = false; 00215 } 00216 00217 return valid; 00218 } 00219 00220 MeshDomain* get_itaps_domain() 00221 { 00222 const double EPS = 1e-2; 00223 int ierr; 00224 iGeom_Instance igeom; 00225 iGeom_newGeom( "", &igeom, &ierr, 0 ); 00226 CHKIGEOM; 00227 00228 #ifdef MOAB_HAVE_CGM_FACET 00229 FacetModifyEngine::set_modify_enabled( CUBIT_TRUE ); 00230 #endif 00231 00232 iBase_EntityHandle sphere_vol; 00233 iGeom_createSphere( igeom, SPHERE_RADIUS, &sphere_vol, &ierr ); 00234 CHKIGEOM; 00235 iGeom_moveEnt( igeom, sphere_vol, SPHERE_CENTER[0], SPHERE_CENTER[1], SPHERE_CENTER[2], &ierr ); 00236 CHKIGEOM; 00237 00238 iBase_EntityHandle sphere_surf; 00239 iBase_EntityHandle* ptr = &sphere_surf; 00240 int size = 0, alloc = 1; 00241 iGeom_getEntAdj( igeom, sphere_vol, iBase_FACE, &ptr, &alloc, &size, &ierr ); 00242 CHKIGEOM; 00243 if( size != 1 ) 00244 { 00245 std::cerr << "Failed to get spherical surface from iGeom instance" << std::endl; 00246 return 0; 00247 } 00248 00249 Vector3D bmin, bmax; 00250 iGeom_getEntBoundBox( igeom, sphere_surf, &bmin[0], &bmin[1], &bmin[2], &bmax[0], &bmax[1], &bmax[2], &ierr ); 00251 CHKIGEOM; 00252 Vector3D center = 0.5 * ( bmin + bmax ); 00253 Vector3D rad = 0.5 * ( bmax - bmin ); 00254 if( ( center - SPHERE_CENTER ).length() > EPS || fabs( rad[0] - SPHERE_RADIUS ) > EPS || 00255 fabs( rad[1] - SPHERE_RADIUS ) > EPS || fabs( rad[2] - SPHERE_RADIUS ) > EPS ) 00256 { 00257 std::cerr << "iGeom implementation returned invalid box for sphere" << std::endl 00258 << " Expected Sphere Center: " << SPHERE_CENTER << std::endl 00259 << " Expected Sphere Radius: " << SPHERE_RADIUS << std::endl 00260 << " Actual Box Minimum : " << bmin << std::endl 00261 << " Actual Box Maximum : " << bmax << std::endl; 00262 return 0; 00263 } 00264 00265 return new MsqIGeom( igeom, sphere_surf ); 00266 } 00267 00268 MeshDomain* get_mesquite_domain() 00269 { 00270 return new SphericalDomain( SPHERE_CENTER, SPHERE_RADIUS ); 00271 }
