MOAB: Mesh Oriented datABase
(version 5.2.1)
#include "Mesquite.hpp"
#include "XYRectangle.hpp"
#include "ArrayMesh.hpp"
#include "MsqVertex.hpp"
#include "UnitUtil.hpp"
#include "MsqError.hpp"
Classes | |
class | XYRectangleTest |
Functions | |
CPPUNIT_TEST_SUITE_NAMED_REGISTRATION (XYRectangleTest,"Unit") | |
CPPUNIT_TEST_SUITE_NAMED_REGISTRATION (XYRectangleTest,"XYRectangleTest") | |
Vector3D | snap_to (const Vector3D &vertex, const Vector3D &point) |
unsigned short | dof (const Vector3D &point) |
Variables | |
const double | WIDTH = 4 |
const double | HEIGHT = 2 |
const double | XMIN = 0 |
const double | YMIN = 0 |
double | TEST_MESH_COORDS [] |
const int | NUM_TEST_MESH_VERTS = sizeof( TEST_MESH_COORDS ) / sizeof( double ) / 3 |
const unsigned long | TEST_MESH_CONN [] |
const int | NUM_TEST_MESH_TRIS = sizeof( TEST_MESH_CONN ) / sizeof( TEST_MESH_CONN[0] ) / 3 |
Definition in file XYRectangleTest.cpp.
CPPUNIT_TEST_SUITE_NAMED_REGISTRATION | ( | XYRectangleTest | , |
"Unit" | |||
"XYRectangleTest" | |||
Definition at line 265 of file XYRectangleTest.cpp.
References HEIGHT, WIDTH, XMIN, and YMIN.
Referenced by check_results(), MBMesquite::Instruction::initialize_vertex_byte(), MBMesquite::SlaveBoundaryVertices::loop_over_mesh(), main(), ConicDomainTest::test_domain_DoF(), SphericalDomainTest::test_domain_DoF(), XYRectangleTest::test_domain_DoF(), and MBMesquite::DomainClassifier::test_valid_classification().
Definition at line 142 of file XYRectangleTest.cpp.
Referenced by XYRectangleTest::test_snap_to().
{ Vector3D result; result[2] = 0.0; if( fabs( vertex[0] - XMIN ) < 1e-6 ) result[0] = XMIN; else if( fabs( vertex[0] - XMIN - WIDTH ) < 1e-6 ) result[0] = XMIN + WIDTH; else result[0] = point[0]; if( fabs( vertex[1] - YMIN ) < 1e-6 ) result[1] = YMIN; else if( fabs( vertex[1] - YMIN - HEIGHT ) < 1e-6 ) result[1] = YMIN + HEIGHT; else result[1] = point[1]; return result; }
const double HEIGHT = 2 |
Definition at line 43 of file XYRectangleTest.cpp.
Referenced by dof(), snap_to(), MBMesquite::MeshWriter::write_gnuplot_animator(), and MBMesquite::MeshWriter::write_gnuplot_overlay().
const int NUM_TEST_MESH_TRIS = sizeof( TEST_MESH_CONN ) / sizeof( TEST_MESH_CONN[0] ) / 3 |
Definition at line 125 of file XYRectangleTest.cpp.
Referenced by XYRectangleTest::setUp().
const int NUM_TEST_MESH_VERTS = sizeof( TEST_MESH_COORDS ) / sizeof( double ) / 3 |
Definition at line 122 of file XYRectangleTest.cpp.
const unsigned long TEST_MESH_CONN[] |
{ 0, 1, 4, 1, 2, 5, 0, 4, 3, 1, 5, 4, 2, 6, 5, 3, 4, 7, 4, 5, 8, 5, 6, 9, 4, 8, 7, 5, 9, 8 }
Definition at line 123 of file XYRectangleTest.cpp.
double TEST_MESH_COORDS[] |
{ XMIN, YMIN, 0, XMIN + 0.5 * WIDTH, YMIN, 0, XMIN + WIDTH, YMIN, 0, XMIN, YMIN + 0.5 * HEIGHT, 0, XMIN + .25 * WIDTH, YMIN + 0.5 * HEIGHT, 0, XMIN + .75 * WIDTH, YMIN + 0.5 * HEIGHT, 0, XMIN + WIDTH, YMIN + 0.5 * HEIGHT, 0, XMIN, YMIN + HEIGHT, 0, XMIN + 0.5 * WIDTH, YMIN + HEIGHT, 0, XMIN + WIDTH, YMIN + HEIGHT, 0 }
Definition at line 92 of file XYRectangleTest.cpp.
const double WIDTH = 4 |
const double XMIN = 0 |
const double YMIN = 0 |
