MOAB: Mesh Oriented datABase
(version 5.2.1)
00001 /* ***************************************************************** 00002 MESQUITE -- The Mesh Quality Improvement Toolkit 00003 00004 Copyright 2007 Sandia National Laboratories. Developed at the 00005 University of Wisconsin--Madison under SNL contract number 00006 624796. The U.S. Government and the University of Wisconsin 00007 retain certain rights to this software. 00008 00009 This library is free software; you can redistribute it and/or 00010 modify it under the terms of the GNU Lesser General Public 00011 License as published by the Free Software Foundation; either 00012 version 2.1 of the License, or (at your option) any later version. 00013 00014 This library is distributed in the hope that it will be useful, 00015 but WITHOUT ANY WARRANTY; without even the implied warranty of 00016 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00017 Lesser General Public License for more details. 00018 00019 You should have received a copy of the GNU Lesser General Public License 00020 (lgpl.txt) along with this library; if not, write to the Free Software 00021 Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA 00022 00023 (2007) kraftche@cae.wisc.edu 00024 00025 ***************************************************************** */ 00026 00027 /** \file XYRectangle.hpp 00028 * \brief Define simple domain for 2D test problems 00029 * \author Jason Kraftcheck 00030 */ 00031 00032 #ifndef MSQ_XY_RECTANGLE_HPP 00033 #define MSQ_XY_RECTANGLE_HPP 00034 00035 #include "Mesquite.hpp" 00036 #include "MeshInterface.hpp" 00037 00038 #include <map> 00039 00040 namespace MBMesquite 00041 { 00042 00043 /**\brief Simple 2D Domain for free-smooth testing 00044 * 00045 * Define a simple bounded rectangular domain in the XY-plane. 00046 * Mesh vertices are classified as one of the following: 00047 * - 0 DoF : On a corner of the rectangle 00048 * - 1 DoF : On an edge of the rectangle 00049 * - 2 DoF : In the interior of the rectangle 00050 */ 00051 class XYRectangle : public MBMesquite::MeshDomain 00052 { 00053 public: 00054 enum Plane 00055 { 00056 XY = 2, 00057 YZ = 0, 00058 ZX = 1 00059 }; 00060 00061 /**\brief Define rectangular domain 00062 * 00063 *\param w Width of rectangle (X-range) 00064 *\param h Height of rectangle (Y-range) 00065 *\param x Minimum X coordinate of rectangle 00066 *\param y Minimum Y coordinate of rectangle 00067 *\param z Minimum Z coordinate of rectangle 00068 *\param plane Which plane (default is XY). 00069 * 00070 * Create w x h rectangle with, if plane is XY: X range of [x, x+w] and 00071 * Y range of [y, y+h]. 00072 */ 00073 MESQUITE_EXPORT 00074 XYRectangle( double w, double h, double x = 0, double y = 0, double z = 0, Plane plane = XY ); 00075 00076 /**\brief Classify mesh vertices against domain 00077 * 00078 * Figure out which input mesh vertices like on corners 00079 * or edges of the domain. Will fail if any vertex is outside 00080 * of the rectangle. 00081 */ 00082 MESQUITE_EXPORT 00083 void setup( MBMesquite::Mesh* mesh, MBMesquite::MsqError& err ); 00084 00085 MESQUITE_EXPORT 00086 void snap_to( MBMesquite::Mesh::VertexHandle entity_handle, MBMesquite::Vector3D& coordinate ) const; 00087 00088 MESQUITE_EXPORT 00089 void vertex_normal_at( MBMesquite::Mesh::VertexHandle entity_handle, MBMesquite::Vector3D& coordinate ) const; 00090 00091 MESQUITE_EXPORT 00092 void element_normal_at( MBMesquite::Mesh::ElementHandle entity_handle, MBMesquite::Vector3D& coordinate ) const; 00093 00094 MESQUITE_EXPORT 00095 void vertex_normal_at( const MBMesquite::Mesh::VertexHandle* handles, MBMesquite::Vector3D coordinates[], 00096 unsigned count, MBMesquite::MsqError& err ) const; 00097 00098 MESQUITE_EXPORT 00099 void closest_point( MBMesquite::Mesh::VertexHandle handle, const MBMesquite::Vector3D& position, 00100 MBMesquite::Vector3D& closest, MBMesquite::Vector3D& normal, MBMesquite::MsqError& err ) const; 00101 00102 MESQUITE_EXPORT 00103 void domain_DoF( const MBMesquite::Mesh::VertexHandle* handle_array, unsigned short* dof_array, size_t num_handles, 00104 MBMesquite::MsqError& err ) const; 00105 00106 private: 00107 double minCoords[3], maxCoords[3]; //!< corner coords 00108 const int normalDir, widthDir, heightDir; 00109 00110 //! Single constraint on a vertex (reduces degrees of freedom by 1) 00111 struct VertexConstraint 00112 { 00113 enum Constraint 00114 { 00115 XC = 0, 00116 YC = 1, 00117 ZC = 2 00118 }; 00119 VertexConstraint( int a, double c ) : axis( (Constraint)a ), coord( c ) {} 00120 Constraint axis; 00121 double coord; 00122 }; 00123 00124 //! Map vertex handles to constraints 00125 typedef std::multimap< Mesh::VertexHandle, VertexConstraint > constraint_t; 00126 constraint_t mConstraints; 00127 }; 00128 00129 } // namespace MBMesquite 00130 00131 #endif
