MOAB: Mesh Oriented datABase
(version 5.3.1)
#include "Mesquite.hpp"
#include "MsqIGeom.hpp"
#include "FacetModifyEngine.hpp"
#include "MeshImpl.hpp"
#include "MsqError.hpp"
#include "ShapeImprovementWrapper.hpp"
#include "MsqVertex.hpp"
#include "QualityAssessor.hpp"
#include "SphericalDomain.hpp"
#include "TestUtil.hpp"
#include <memory>
#include <iostream>
#include "MsqIBase.hpp"
Defines | |
#define | CHKIGEOM if( chk_igeom_error( ierr, __FILE__, __LINE__ ) ) return 0 |
Functions | |
bool | chk_igeom_error (int ierr, const char *file, int line) |
void | usage () |
void | run_smoother (Mesh &mesh, MeshDomain *domain, MsqError &err) |
bool | check_results (Mesh &mesh, MeshDomain *domain, MsqError &err) |
MeshDomain * | get_itaps_domain () |
MeshDomain * | get_mesquite_domain () |
int | main (int argc, char *argv[]) |
Variables | |
const double | SPHERE_RADIUS = 3.0 |
const Vector3D | SPHERE_CENTER (2.0, 2.0, 0.0) |
std::string | default_file_name = "unittest/mesquite/2D/vtk/quads/untangled/quads_on_sphere_529.vtk" |
#define CHKIGEOM if( chk_igeom_error( ierr, __FILE__, __LINE__ ) ) return 0 |
Definition at line 49 of file test/mesquite/igeom/main.cpp.
Referenced by get_itaps_domain().
bool check_results | ( | Mesh & | mesh, |
MeshDomain * | domain, | ||
MsqError & | err | ||
Definition at line 167 of file test/mesquite/igeom/main.cpp.
References MBMesquite::arrptr(), dof(), MBMesquite::MeshDomain::domain_DoF(), EPS, MBMesquite::Mesh::get_all_vertices(), MBMesquite::Vector3D::length(), MBMesquite::length(), MSQ_ERRZERO, SPHERE_CENTER, SPHERE_RADIUS, MBMesquite::MeshDomain::vertex_normal_at(), and MBMesquite::Mesh::vertices_get_coordinates().
Referenced by main().
{ double EPS = 1e-2; std::vector< Mesh::VertexHandle > handles; mesh.get_all_vertices( handles, err ); MSQ_ERRZERO( err ); std::vector< MsqVertex > coords( handles.size() ); mesh.vertices_get_coordinates( arrptr( handles ), arrptr( coords ), handles.size(), err ); MSQ_ERRZERO( err ); bool valid = true; size_t c = 0; for( size_t i = 0; i < coords.size(); ++i ) { double d = ( coords[i] - SPHERE_CENTER ).length(); if( fabs( d - SPHERE_RADIUS ) > EPS ) ++c; } if( c ) { std::cerr << c << " vertices not on domain" << std::endl; valid = false; } std::vector< unsigned short > dof( handles.size() ), exp_dof( handles.size(), 2 ); dom->domain_DoF( arrptr( handles ), arrptr( dof ), handles.size(), err ); MSQ_ERRZERO( err ); if( dof != exp_dof ) { std::cerr << "Invalid domain dimension for one or more vertices" << std::endl; valid = false; } c = 0; std::vector< Vector3D > normals( coords.begin(), coords.end() ); dom->vertex_normal_at( arrptr( handles ), arrptr( normals ), handles.size(), err ); MSQ_ERRZERO( err ); for( size_t i = 0; i < handles.size(); ++i ) { Vector3D exp_norm = ~( coords[i] - SPHERE_CENTER ); Vector3D act_norm = ~normals[i]; Vector3D diff = exp_norm - act_norm; if( diff.length() > EPS ) ++c; } if( c ) { std::cerr << c << " invalid vertex normals" << std::endl; valid = false; } return valid; }
bool chk_igeom_error | ( | int | ierr, |
const char * | file, | ||
int | line | ||
Definition at line 52 of file test/mesquite/igeom/main.cpp.
References iBase_SUCCESS, and MBMesquite::process_itaps_error().
{ if( iBase_SUCCESS == ierr ) return false; std::cerr << "iGeom call failed at " << file << ":" << line << std::endl; std::cerr << process_itaps_error( ierr ) << std::endl; return true; }
MeshDomain * get_itaps_domain | ( | ) |
Definition at line 220 of file test/mesquite/igeom/main.cpp.
References center(), CHKIGEOM, EPS, iBase_FACE, ierr, size, SPHERE_CENTER, and SPHERE_RADIUS.
{ const double EPS = 1e-2; int ierr; iGeom_Instance igeom; iGeom_newGeom( "", &igeom, &ierr, 0 ); CHKIGEOM; #ifdef MOAB_HAVE_CGM_FACET FacetModifyEngine::set_modify_enabled( CUBIT_TRUE ); #endif iBase_EntityHandle sphere_vol; iGeom_createSphere( igeom, SPHERE_RADIUS, &sphere_vol, &ierr ); CHKIGEOM; iGeom_moveEnt( igeom, sphere_vol, SPHERE_CENTER[0], SPHERE_CENTER[1], SPHERE_CENTER[2], &ierr ); CHKIGEOM; iBase_EntityHandle sphere_surf; iBase_EntityHandle* ptr = &sphere_surf; int size = 0, alloc = 1; iGeom_getEntAdj( igeom, sphere_vol, iBase_FACE, &ptr, &alloc, &size, &ierr ); CHKIGEOM; if( size != 1 ) { std::cerr << "Failed to get spherical surface from iGeom instance" << std::endl; return 0; } Vector3D bmin, bmax; iGeom_getEntBoundBox( igeom, sphere_surf, &bmin[0], &bmin[1], &bmin[2], &bmax[0], &bmax[1], &bmax[2], &ierr ); CHKIGEOM; Vector3D center = 0.5 * ( bmin + bmax ); Vector3D rad = 0.5 * ( bmax - bmin ); if( ( center - SPHERE_CENTER ).length() > EPS || fabs( rad[0] - SPHERE_RADIUS ) > EPS || fabs( rad[1] - SPHERE_RADIUS ) > EPS || fabs( rad[2] - SPHERE_RADIUS ) > EPS ) { std::cerr << "iGeom implementation returned invalid box for sphere" << std::endl << " Expected Sphere Center: " << SPHERE_CENTER << std::endl << " Expected Sphere Radius: " << SPHERE_RADIUS << std::endl << " Actual Box Minimum : " << bmin << std::endl << " Actual Box Maximum : " << bmax << std::endl; return 0; } return new MsqIGeom( igeom, sphere_surf ); }
Definition at line 268 of file test/mesquite/igeom/main.cpp.
References SPHERE_CENTER, and SPHERE_RADIUS.
{ return new SphericalDomain( SPHERE_CENTER, SPHERE_RADIUS ); }
int main | ( | int | argc, |
char * | argv[] | ||
Definition at line 75 of file test/mesquite/igeom/main.cpp.
References check_results(), default_file_name, get_itaps_domain(), get_mesquite_domain(), MBMesquite::MsqError::INTERNAL_ERROR, mesh, MSQ_CHKERR, MSQ_SETERR, MBMesquite::MeshImpl::read_vtk(), run_smoother(), usage, and MBMesquite::MeshImpl::write_vtk().
{ // command line arguments const char* file_name = 0; const char* output_file = 0; bool use_native = false, opts_done = false; for( int arg = 1; arg < argc; ++arg ) { if( !opts_done && argv[arg][0] == '-' ) { if( !strcmp( argv[arg], "-N" ) ) use_native = true; else if( !strcmp( argv[arg], "-o" ) ) output_file = argv[arg++]; else if( !strcmp( argv[arg], "--" ) ) opts_done = true; else usage(); } else if( !file_name ) file_name = argv[arg]; else usage(); } if( !file_name ) { file_name = default_file_name.c_str(); std::cout << "No file specified: using default: " << default_file_name << std::endl; } MsqError err; MeshImpl mesh; mesh.read_vtk( file_name, err ); if( MSQ_CHKERR( err ) ) { std::cerr << err << std::endl; std::cerr << "Failed to read input file: " << file_name << std::endl; return 1; } std::unique_ptr< MeshDomain > dom( use_native ? get_mesquite_domain() : get_itaps_domain() ); if( !dom.get() ) { MSQ_SETERR( err )( "Domain creation failed", MsqError::INTERNAL_ERROR ); std::cerr << err << std::endl; return 1; } run_smoother( mesh, dom.get(), err ); if( MSQ_CHKERR( err ) ) { std::cerr << err << std::endl; std::cerr << "Smoother failed." << std::endl; return 1; } if( output_file ) { mesh.write_vtk( output_file, err ); if( MSQ_CHKERR( err ) ) { std::cerr << err << std::endl; std::cerr << "Failed to write file: " << output_file << std::endl; return 1; } } bool valid = check_results( mesh, dom.get(), err ); if( MSQ_CHKERR( err ) ) { std::cerr << err << std::endl; std::cerr << "Error while validating results." << std::endl; return 1; } return !valid; }
void run_smoother | ( | Mesh & | mesh, |
Definition at line 154 of file test/mesquite/igeom/main.cpp.
References MBMesquite::QualityAssessor::invalid_elements(), MBMesquite::MsqError::INVALID_MESH, MSQ_CHKERR, MSQ_SETERR, MBMesquite::Wrapper::quality_assessor(), and MBMesquite::IQInterface::run_instructions().
{ ShapeImprovementWrapper smoother; MeshDomainAssoc mesh_and_domain = MeshDomainAssoc( &mesh, dom ); smoother.run_instructions( &mesh_and_domain, err );MSQ_CHKERR( err ); if( smoother.quality_assessor().invalid_elements() ) { MSQ_SETERR( err )( "Smoothing produced invalid elements", MsqError::INVALID_MESH ); return; } }
void usage | ( | ) |
Definition at line 62 of file test/mesquite/igeom/main.cpp.
References default_file_name.
{ std::cout << "main [-N] [filename] [-o <output_file>]" << std::endl; std::cout << " -N : Use native representation instead of iGeom implementation\n" << std::endl; std::cout << " If no file name is specified, will use \"" << default_file_name << '"' << std::endl; exit( 1 ); }
std::string default_file_name = "unittest/mesquite/2D/vtk/quads/untangled/quads_on_sphere_529.vtk" |
Definition at line 60 of file test/mesquite/igeom/main.cpp.
const Vector3D SPHERE_CENTER(2.0, 2.0, 0.0) |
Referenced by check_results(), get_itaps_domain(), and get_mesquite_domain().
const double SPHERE_RADIUS = 3.0 |
Definition at line 46 of file test/mesquite/igeom/main.cpp.
