MOAB: Mesh Oriented datABase
(version 5.4.0)
00001 /* ***************************************************************** 00002 MESQUITE -- The Mesh Quality Improvement Toolkit 00003 00004 Copyright 2010 Sandia National Laboratories. Developed at the 00005 University of Wisconsin--Madison under SNL contract number 00006 624796. The U.S. Government and the University of Wisconsin 00007 retain certain rights to this software. 00008 00009 This library is free software; you can redistribute it and/or 00010 modify it under the terms of the GNU Lesser General Public 00011 License as published by the Free Software Foundation; either 00012 version 2.1 of the License, or (at your option) any later version. 00013 00014 This library is distributed in the hope that it will be useful, 00015 but WITHOUT ANY WARRANTY; without even the implied warranty of 00016 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00017 Lesser General Public License for more details. 00018 00019 You should have received a copy of the GNU Lesser General Public License 00020 (lgpl.txt) along with this library; if not, write to the Free Software 00021 Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA 00022 00023 (2010) kraftche@cae.wisc.edu 00024 00025 ***************************************************************** */ 00026 00027 /** \file MeshUtil.cpp 00028 * \brief Implement MeshUtil class 00029 * \author Jason Kraftcheck 00030 */ 00031 00032 #include "Mesquite.hpp" 00033 #include "MeshUtil.hpp" 00034 #include "MeshInterface.hpp" 00035 #include "EdgeIterator.hpp" 00036 #include "SimpleStats.hpp" 00037 #include "MsqError.hpp" 00038 #include "TMPQualityMetric.hpp" 00039 #include "MappingFunction.hpp" 00040 #include "TargetCalculator.hpp" 00041 00042 #include <vector> 00043 #include <algorithm> 00044 #include <limits> 00045 #include <sstream> 00046 00047 namespace MBMesquite 00048 { 00049 00050 MeshUtil::~MeshUtil() 00051 { 00052 delete globalPatch; 00053 } 00054 00055 PatchData* MeshUtil::get_global_patch( MsqError& err ) 00056 { 00057 if( !globalPatch ) 00058 { 00059 globalPatch = new PatchData; 00060 globalPatch->set_mesh( myMesh ); 00061 if( mySettings ) globalPatch->attach_settings( mySettings ); 00062 globalPatch->fill_global_patch( err ); 00063 if( MSQ_CHKERR( err ) ) 00064 { 00065 delete globalPatch; 00066 globalPatch = 0; 00067 } 00068 } 00069 return globalPatch; 00070 } 00071 00072 void MeshUtil::edge_length_distribution( SimpleStats& results, MsqError& err ) 00073 { 00074 PatchData* pd = get_global_patch( err );MSQ_ERRRTN( err ); 00075 EdgeIterator iter( pd, err );MSQ_ERRRTN( err ); 00076 while( !iter.is_at_end() ) 00077 { 00078 Vector3D diff = iter.start() - iter.end(); 00079 results.add_squared( diff % diff ); 00080 iter.step( err );MSQ_ERRRTN( err ); 00081 } 00082 00083 if( results.empty() ) 00084 { // no mesh 00085 MSQ_SETERR( err )( "Mesh contains no elements", MsqError::INVALID_MESH ); 00086 } 00087 } 00088 00089 void MeshUtil::lambda_distribution( SimpleStats& results, MsqError& err ) 00090 { 00091 PatchData& pd = *get_global_patch( err );MSQ_ERRRTN( err ); 00092 00093 std::vector< size_t > handles; 00094 TMPQualityMetric::get_patch_evaluations( pd, handles, false, err ); 00095 00096 const size_t N = 64; 00097 size_t count; 00098 size_t indices[N]; 00099 MsqVector< 2 > derivs2D[N]; 00100 MsqVector< 3 > derivs3D[N]; 00101 00102 for( size_t i = 0; i < handles.size(); ++i ) 00103 { 00104 double lambda; 00105 const Sample s = ElemSampleQM::sample( handles[i] ); 00106 const size_t e = ElemSampleQM::elem( handles[i] ); 00107 EntityTopology type = pd.element_by_index( e ).get_element_type(); 00108 const NodeSet bits = pd.non_slave_node_set( e ); 00109 00110 if( TopologyInfo::dimension( type ) == 3 ) 00111 { 00112 const MappingFunction3D* mf = pd.get_mapping_function_3D( type ); 00113 if( !mf ) 00114 { 00115 MSQ_SETERR( err ) 00116 ( "No mapping function for element type", MsqError::UNSUPPORTED_ELEMENT ); 00117 return; 00118 } 00119 00120 MsqMatrix< 3, 3 > W; 00121 mf->jacobian( pd, e, bits, s, indices, derivs3D, count, W, err );MSQ_ERRRTN( err ); 00122 assert( N >= count ); 00123 lambda = TargetCalculator::size( W ); 00124 } 00125 else 00126 { 00127 assert( TopologyInfo::dimension( type ) == 2 ); 00128 const MappingFunction2D* mf = pd.get_mapping_function_2D( type ); 00129 if( !mf ) 00130 { 00131 MSQ_SETERR( err ) 00132 ( "No mapping function for element type", MsqError::UNSUPPORTED_ELEMENT ); 00133 return; 00134 } 00135 00136 MsqMatrix< 3, 2 > W; 00137 mf->jacobian( pd, e, bits, s, indices, derivs2D, count, W, err );MSQ_ERRRTN( err ); 00138 assert( N >= count ); 00139 lambda = TargetCalculator::size( W ); 00140 } 00141 00142 results.add_value( lambda ); 00143 } 00144 00145 if( results.empty() ) 00146 { // no mesh 00147 MSQ_SETERR( err )( "Mesh contains no elements", MsqError::INVALID_MESH ); 00148 } 00149 } 00150 00151 bool MeshUtil::meshes_are_different( Mesh& mesh1, Mesh& mesh2, MsqError& err, double tol, bool do_print ) 00152 { 00153 // MsqError& err = (do_print ? MsqPrintError(cout) : MsqError()); 00154 00155 // mesh 1 00156 std::vector< Mesh::ElementHandle > elements1; 00157 std::vector< Mesh::VertexHandle > vertices1; 00158 std::vector< Mesh::VertexHandle > connectivity1; 00159 std::vector< size_t > offsets1; 00160 00161 mesh1.get_all_elements( elements1, err ); 00162 MSQ_ERRZERO( err ); 00163 mesh1.get_all_vertices( vertices1, err ); 00164 MSQ_ERRZERO( err ); 00165 mesh1.elements_get_attached_vertices( arrptr( elements1 ), elements1.size(), connectivity1, offsets1, err ); 00166 MSQ_ERRZERO( err ); 00167 std::vector< EntityTopology > types1( elements1.size() ); 00168 mesh1.elements_get_topologies( arrptr( elements1 ), arrptr( types1 ), elements1.size(), err ); 00169 MSQ_ERRZERO( err ); 00170 00171 // mesh 2 00172 std::vector< Mesh::ElementHandle > elements2; 00173 std::vector< Mesh::VertexHandle > vertices2; 00174 std::vector< Mesh::VertexHandle > connectivity2; 00175 std::vector< size_t > offsets2; 00176 00177 mesh2.get_all_elements( elements2, err ); 00178 MSQ_ERRZERO( err ); 00179 mesh2.get_all_vertices( vertices2, err ); 00180 MSQ_ERRZERO( err ); 00181 mesh2.elements_get_attached_vertices( arrptr( elements2 ), elements2.size(), connectivity2, offsets2, err ); 00182 MSQ_ERRZERO( err ); 00183 std::vector< EntityTopology > types2( elements2.size() ); 00184 mesh2.elements_get_topologies( arrptr( elements2 ), arrptr( types2 ), elements2.size(), err ); 00185 MSQ_ERRZERO( err ); 00186 00187 #define MDRET( msg ) \ 00188 do \ 00189 { \ 00190 if( do_print ) std::cout << "MeshUtil::mesh_diff meshes are different: " << ( msg ) << std::endl; \ 00191 return true; \ 00192 } while( 0 ) 00193 if( elements1.size() != elements2.size() ) MDRET( "elements sizes differ" ); 00194 if( vertices1.size() != vertices2.size() ) MDRET( "vertices sizes differ" ); 00195 if( offsets1.size() != offsets2.size() ) MDRET( "offsets sizes differ" ); 00196 if( connectivity1.size() != connectivity2.size() ) MDRET( "connectivity sizes differ" ); 00197 00198 for( unsigned i = 0; i < offsets1.size(); i++ ) 00199 { 00200 if( offsets1[i] != offsets2[i] ) MDRET( "offets differ" ); 00201 } 00202 00203 for( unsigned i = 0; i < vertices1.size(); i++ ) 00204 { 00205 MsqVertex vert1, vert2; 00206 mesh1.vertices_get_coordinates( &vertices1[i], &vert1, 1, err ); 00207 MSQ_ERRZERO( err ); 00208 mesh2.vertices_get_coordinates( &vertices2[i], &vert2, 1, err ); 00209 MSQ_ERRZERO( err ); 00210 double dist = Vector3D::distance_between( vert1, vert2 ); 00211 double v1 = vert1.length(); 00212 double v2 = vert2.length(); 00213 if( dist > 0.5 * ( v1 + v2 ) * tol ) 00214 { 00215 std::ostringstream ost; 00216 ost << "vertices coordinates differ more than tolerance [" << tol << "], vert1= " << vert1 00217 << " vert2= " << vert2; 00218 MDRET( ost.str() ); 00219 } 00220 } 00221 00222 for( unsigned i = 0; i < connectivity1.size(); i++ ) 00223 { 00224 MsqVertex vert1, vert2; 00225 mesh1.vertices_get_coordinates( &connectivity1[i], &vert1, 1, err ); 00226 MSQ_ERRZERO( err ); 00227 mesh2.vertices_get_coordinates( &connectivity2[i], &vert2, 1, err ); 00228 MSQ_ERRZERO( err ); 00229 double dist = Vector3D::distance_between( vert1, vert2 ); 00230 double v1 = vert1.length(); 00231 double v2 = vert2.length(); 00232 if( dist > 0.5 * ( v1 + v2 ) * tol ) 00233 { 00234 std::ostringstream ost; 00235 ost << "connectivity coordinates differ more than tolerance [" << tol << "], vert1= " << vert1 00236 << " vert2= " << vert2; 00237 MDRET( ost.str() ); 00238 } 00239 } 00240 00241 return false; 00242 } 00243 00244 } // namespace MBMesquite
