MOAB: Mesh Oriented datABase
(version 5.2.1)
#include "Mesquite.hpp"
#include "TriLagrangeShape.hpp"
#include "TopologyInfo.hpp"
#include "MsqError.hpp"
#include "IdealElements.hpp"
#include "JacobianCalculator.hpp"
#include "UnitUtil.hpp"
#include <vector>
#include <algorithm>
#include <iostream>
#include <sstream>
Classes | |
class | TriLagrangeShapeTest |
Defines | |
#define | ASSERT_VALUES_EQUAL(v1, v2, location, bits) ASSERT_MESSAGE( value_message( ( location ), ( bits ), ( v1 ), ( v2 ) ), ( fabs( ( v1 ) - ( v2 ) ) < epsilon ) ) |
Typedefs | |
typedef double(* | N_t )(double, double) |
Functions | |
static CppUnit::Message | value_message (unsigned location, NodeSet bits, double v1, double v2) |
CPPUNIT_TEST_SUITE_NAMED_REGISTRATION (TriLagrangeShapeTest,"TriLagrangeShapeTest") | |
CPPUNIT_TEST_SUITE_NAMED_REGISTRATION (TriLagrangeShapeTest,"Unit") | |
double | N0 (double r, double s) |
double | N1 (double r, double) |
double | N2 (double, double s) |
double | N3 (double r, double s) |
double | N4 (double r, double s) |
double | N5 (double r, double s) |
double | dN0dr (double r, double s) |
double | dN0ds (double r, double s) |
double | dN1dr (double r, double) |
double | dN1ds (double, double) |
double | dN2dr (double, double) |
double | dN2ds (double, double s) |
double | dN3dr (double r, double s) |
double | dN3ds (double r, double) |
double | dN4dr (double, double s) |
double | dN4ds (double r, double) |
double | dN5dr (double, double s) |
double | dN5ds (double r, double s) |
static void | get_coeff (NodeSet nodeset, const double *rs, double *coeffs) |
static void | get_derivs (NodeSet nodeset, const double *rs, double *derivs) |
static void | check_valid_indices (const size_t *vtx_in, size_t num_vtx) |
static void | check_no_zeros (const MsqVector< 2 > *derivs, size_t num_vtx) |
static void | compare_coefficients (const double *coeffs, const size_t *indices, const double *expected_coeffs, size_t num_coeff, unsigned loc, NodeSet bits) |
static void | compare_derivatives (const size_t *vertices, size_t num_vtx, const MsqVector< 2 > *derivs, const double *expected_derivs, unsigned loc, NodeSet bits) |
Variables | |
const double | epsilon = 1e-6 |
const N_t | N [] = { &N0, &N1, &N2, &N3, &N4, &N5 } |
const N_t | dNdr [] = { &dN0dr, &dN1dr, &dN2dr, &dN3dr, &dN4dr, &dN5dr } |
const N_t | dNds [] = { &dN0ds, &dN1ds, &dN2ds, &dN3ds, &dN4ds, &dN5ds } |
const double | rs_corner [][2] = { { 0, 0 }, { 1, 0 }, { 0, 1 } } |
const double | rs_edge [][2] = { { 0.5, 0.0 }, { 0.5, 0.5 }, { 0.0, 0.5 } } |
const double | rs_mid [2] = { 1.0 / 3.0, 1.0 / 3.0 } |
Definition in file TriLagrangeShapeTest.cpp.
#define ASSERT_VALUES_EQUAL | ( | v1, | |
v2, | |||
location, | |||
bits | |||
) | ASSERT_MESSAGE( value_message( ( location ), ( bits ), ( v1 ), ( v2 ) ), ( fabs( ( v1 ) - ( v2 ) ) < epsilon ) ) |
Definition at line 49 of file TriLagrangeShapeTest.cpp.
Referenced by compare_coefficients(), and compare_derivatives().
typedef double( * N_t)(double, double) |
Definition at line 200 of file TriLagrangeShapeTest.cpp.
static void check_no_zeros | ( | const MsqVector< 2 > * | derivs, |
size_t | num_vtx | ||
) | [static] |
Definition at line 256 of file TriLagrangeShapeTest.cpp.
References CPPUNIT_ASSERT.
Referenced by compare_derivatives().
{ for( unsigned i = 0; i < num_vtx; ++i ) { double dr = derivs[i][0]; double ds = derivs[i][1]; CPPUNIT_ASSERT( ( fabs( dr ) > 1e-6 ) || ( fabs( ds ) > 1e-6 ) ); } }
static void check_valid_indices | ( | const size_t * | vtx_in, |
) | [static] |
Definition at line 242 of file TriLagrangeShapeTest.cpp.
{ CPPUNIT_ASSERT( num_vtx < 7 ); CPPUNIT_ASSERT( num_vtx > 2 ); size_t vertices[6]; std::copy( vtx_in, vtx_in + num_vtx, vertices ); std::sort( vertices, vertices + num_vtx ); for( unsigned i = 1; i < num_vtx; ++i ) { CPPUNIT_ASSERT( vertices[i] != vertices[i - 1] ); CPPUNIT_ASSERT( vertices[i] < 6 ); } }
static void compare_coefficients | ( | const double * | coeffs, |
const size_t * | indices, | ||
const double * | expected_coeffs, | ||
size_t | num_coeff, | ||
unsigned | loc, | ||
NodeSet | bits | ||
) | [static] |
Definition at line 266 of file TriLagrangeShapeTest.cpp.
References ASSERT_VALUES_EQUAL, CPPUNIT_ASSERT, and MBMesquite::NodeSet::mid_edge_node().
Referenced by TriLagrangeShapeTest::test_corner_coeff(), TriLagrangeShapeTest::test_edge_coeff(), and TriLagrangeShapeTest::test_mid_coeff().
{ // find the location in the returned list for each node size_t revidx[6]; double test_vals[6]; for( size_t i = 0; i < 6; ++i ) { revidx[i] = std::find( indices, indices + num_coeff, i ) - indices; test_vals[i] = ( revidx[i] == num_coeff ) ? 0.0 : coeffs[revidx[i]]; } // Check that index list doesn't contain any nodes not actually // present in the element. CPPUNIT_ASSERT( bits.mid_edge_node( 0 ) || ( revidx[3] == num_coeff ) ); CPPUNIT_ASSERT( bits.mid_edge_node( 1 ) || ( revidx[4] == num_coeff ) ); CPPUNIT_ASSERT( bits.mid_edge_node( 2 ) || ( revidx[5] == num_coeff ) ); // compare expected and actual coefficient values ASSERT_VALUES_EQUAL( expected_coeffs[0], test_vals[0], loc, bits ); ASSERT_VALUES_EQUAL( expected_coeffs[1], test_vals[1], loc, bits ); ASSERT_VALUES_EQUAL( expected_coeffs[2], test_vals[2], loc, bits ); ASSERT_VALUES_EQUAL( expected_coeffs[3], test_vals[3], loc, bits ); ASSERT_VALUES_EQUAL( expected_coeffs[4], test_vals[4], loc, bits ); ASSERT_VALUES_EQUAL( expected_coeffs[5], test_vals[5], loc, bits ); }
static void compare_derivatives | ( | const size_t * | vertices, |
size_t | num_vtx, | ||
const MsqVector< 2 > * | derivs, | ||
const double * | expected_derivs, | ||
NodeSet | bits | ||
) | [static] |
Definition at line 293 of file TriLagrangeShapeTest.cpp.
References ASSERT_VALUES_EQUAL, check_no_zeros(), and check_valid_indices().
Referenced by TriLagrangeShapeTest::test_corner_derivs(), TriLagrangeShapeTest::test_edge_derivs(), and TriLagrangeShapeTest::test_mid_derivs().
{ check_valid_indices( vertices, num_vtx ); check_no_zeros( derivs, num_vtx ); double expanded_derivs[12] = { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 }; for( unsigned i = 0; i < num_vtx; ++i ) { expanded_derivs[2 * vertices[i]] = derivs[i][0]; expanded_derivs[2 * vertices[i] + 1] = derivs[i][1]; } ASSERT_VALUES_EQUAL( expected_derivs[0], expanded_derivs[0], loc, bits ); ASSERT_VALUES_EQUAL( expected_derivs[1], expanded_derivs[1], loc, bits ); ASSERT_VALUES_EQUAL( expected_derivs[2], expanded_derivs[2], loc, bits ); ASSERT_VALUES_EQUAL( expected_derivs[3], expanded_derivs[3], loc, bits ); ASSERT_VALUES_EQUAL( expected_derivs[4], expanded_derivs[4], loc, bits ); ASSERT_VALUES_EQUAL( expected_derivs[5], expanded_derivs[5], loc, bits ); ASSERT_VALUES_EQUAL( expected_derivs[6], expanded_derivs[6], loc, bits ); ASSERT_VALUES_EQUAL( expected_derivs[7], expanded_derivs[7], loc, bits ); ASSERT_VALUES_EQUAL( expected_derivs[8], expanded_derivs[8], loc, bits ); ASSERT_VALUES_EQUAL( expected_derivs[9], expanded_derivs[9], loc, bits ); ASSERT_VALUES_EQUAL( expected_derivs[10], expanded_derivs[10], loc, bits ); ASSERT_VALUES_EQUAL( expected_derivs[11], expanded_derivs[11], loc, bits ); }
CPPUNIT_TEST_SUITE_NAMED_REGISTRATION | ( | TriLagrangeShapeTest | , |
"TriLagrangeShapeTest" | |||
double dN0dr | ( | double | r, |
double | s | ||
Definition at line 151 of file TriLagrangeShapeTest.cpp.
return 4 * r + 4 * s - 3;
double dN0ds | ( | double | r, |
double | s | ||
Definition at line 155 of file TriLagrangeShapeTest.cpp.
double dN1dr | ( | double | r, |
double | |||
Definition at line 159 of file TriLagrangeShapeTest.cpp.
return 4 * r - 1;
double dN1ds | ( | double | , |
double | |||
Definition at line 163 of file TriLagrangeShapeTest.cpp.
return 0;
double dN2dr | ( | double | , |
double | |||
Definition at line 167 of file TriLagrangeShapeTest.cpp.
return 0;
double dN2ds | ( | double | , |
double | s | ||
Definition at line 171 of file TriLagrangeShapeTest.cpp.
return 4 * s - 1;
double dN3dr | ( | double | r, |
double | s | ||
Definition at line 175 of file TriLagrangeShapeTest.cpp.
return 4 * ( 1 - s - 2 * r );
double dN3ds | ( | double | r, |
double | |||
Definition at line 179 of file TriLagrangeShapeTest.cpp.
return -4 * r;
double dN4dr | ( | double | , |
double | s | ||
Definition at line 183 of file TriLagrangeShapeTest.cpp.
return 4 * s;
double dN4ds | ( | double | r, |
double | |||
Definition at line 187 of file TriLagrangeShapeTest.cpp.
return 4 * r;
double dN5dr | ( | double | , |
double | s | ||
Definition at line 191 of file TriLagrangeShapeTest.cpp.
return -4 * s;
double dN5ds | ( | double | r, |
double | s | ||
Definition at line 195 of file TriLagrangeShapeTest.cpp.
return 4 * ( 1 - r - 2 * s );
Definition at line 209 of file TriLagrangeShapeTest.cpp.
References MBMesquite::NodeSet::mid_edge_node(), and N.
{ for( int i = 0; i < 6; ++i ) coeffs[i] = ( *N[i] )( rs[0], rs[1] ); for( int i = 0; i < 3; ++i ) if( !nodeset.mid_edge_node( i ) ) { coeffs[i] += 0.5 * coeffs[i + 3]; coeffs[( i + 1 ) % 3] += 0.5 * coeffs[i + 3]; coeffs[i + 3] = 0; } }
static void get_derivs | ( | NodeSet | nodeset, |
const double * | rs, | ||
double * | derivs | ||
) | [static] |
Definition at line 222 of file TriLagrangeShapeTest.cpp.
References dNdr, dNds, and MBMesquite::NodeSet::mid_edge_node().
{ for( int i = 0; i < 6; ++i ) { derivs[2 * i] = ( *dNdr[i] )( rs[0], rs[1] ); derivs[2 * i + 1] = ( *dNds[i] )( rs[0], rs[1] ); } for( int i = 0; i < 3; ++i ) if( !nodeset.mid_edge_node( i ) ) { derivs[2 * i] += 0.5 * derivs[2 * i + 6]; derivs[2 * i + 1] += 0.5 * derivs[2 * i + 7]; int j = ( i + 1 ) % 3; derivs[2 * j] += 0.5 * derivs[2 * i + 6]; derivs[2 * j + 1] += 0.5 * derivs[2 * i + 7]; derivs[2 * i + 6] = 0; derivs[2 * i + 7] = 0; } }
double N0 | ( | double | r, |
double | s | ||
Definition at line 124 of file TriLagrangeShapeTest.cpp.
References t.
Referenced by moab::SmoothFace::init_edge_control_points(), and moab::SmoothFace::init_facet_control_points().
{ double t = 1 - r - s; return t * ( 2 * t - 1 ); }
double N1 | ( | double | r, |
double | |||
Definition at line 129 of file TriLagrangeShapeTest.cpp.
Referenced by moab::FBEngine::weave_lateral_face_from_edges().
return r * ( 2 * r - 1 );
double N2 | ( | double | , |
double | s | ||
Definition at line 133 of file TriLagrangeShapeTest.cpp.
return s * ( 2 * s - 1 );
double N3 | ( | double | r, |
double | s | ||
Definition at line 137 of file TriLagrangeShapeTest.cpp.
References t.
double N4 | ( | double | r, |
double | s | ||
Definition at line 142 of file TriLagrangeShapeTest.cpp.
return 4 * r * s;
double N5 | ( | double | r, |
double | s | ||
Definition at line 146 of file TriLagrangeShapeTest.cpp.
References t.
static CppUnit::Message value_message | ( | unsigned | location, |
NodeSet | bits, | ||
double | v1, | ||
double | v2 | ||
) | [inline, static] |
Definition at line 52 of file TriLagrangeShapeTest.cpp.
{ CppUnit::Message m( "equality assertion failed" ); std::ostringstream buffer1; buffer1 << "Expected : " << v1; m.addDetail( buffer1.str() ); std::ostringstream buffer2; buffer2 << "Actual : " << v2; m.addDetail( buffer2.str() ); std::ostringstream buffer3; buffer3 << "Location : "; if( location < 3 ) buffer3 << "Corner " << location; else if( location < 6 ) buffer3 << "Edge " << location - 3; else if( location == 6 ) buffer3 << "Mid-element"; else buffer3 << "INVALID!!"; m.addDetail( buffer3.str() ); std::ostringstream buffer4; buffer4 << "Node Bits: " << bits; m.addDetail( buffer4.str() ); return m; }
Definition at line 202 of file TriLagrangeShapeTest.cpp.
Referenced by get_derivs().
Definition at line 203 of file TriLagrangeShapeTest.cpp.
const double epsilon = 1e-6 |
Definition at line 48 of file TriLagrangeShapeTest.cpp.
Definition at line 201 of file TriLagrangeShapeTest.cpp.
Referenced by moab::IntxAreaUtils::area_spherical_polygon_girard(), MBMesquite::PMeanPMetric::average_with_Hessian(), moab::MeshGeneration::BrickInstance(), MBMesquite::CompareQM::check_hess(), closedsurface_uref_hirec_convergence_study(), MBMesquite::MsqLine::closest(), moab::SmoothCurve::compute_control_points_on_boundary_edges(), moab::NestedRefine::compute_coordinates(), moab::SmoothFace::compute_internal_control_points_on_facets(), do_test_mode(), moab::SmoothFace::DumpModelControlPoints(), moab::Matrix3::eigen_decomposition(), MBMesquite::AddQualityMetric::evaluate_with_Hessian(), MBMesquite::MultiplyQualityMetric::evaluate_with_Hessian(), get_coeff(), moab::SmoothFace::init_bezier_edge(), MBMesquite::MsqMeshEntity::inverted_jacobian_2d(), MBMesquite::MeshUtil::lambda_distribution(), main(), mb_vertex_coordinate_test(), moab::EntitySourceRecord::operator<(), MBMesquite::pmean_corner_diagonals(), MBMesquite::pmean_corner_hessians(), moab::point_in_box(), MBMesquite::sum_corner_hessians(), MBMesquite::sum_sqr_corner_hessians(), PMeanPMetricTest::test_hessian(), test_huge_var_length(), test_write_read_many_tags(), and v_tet_collapse_ratio().
const double rs_corner[][2] = { { 0, 0 }, { 1, 0 }, { 0, 1 } } |
Definition at line 205 of file TriLagrangeShapeTest.cpp.
Referenced by TriLagrangeShapeTest::test_corner_coeff(), and TriLagrangeShapeTest::test_corner_derivs().
const double rs_edge[][2] = { { 0.5, 0.0 }, { 0.5, 0.5 }, { 0.0, 0.5 } } |
Definition at line 206 of file TriLagrangeShapeTest.cpp.
Referenced by TriLagrangeShapeTest::test_edge_coeff(), and TriLagrangeShapeTest::test_edge_derivs().
const double rs_mid[2] = { 1.0 / 3.0, 1.0 / 3.0 } |
Definition at line 207 of file TriLagrangeShapeTest.cpp.
Referenced by TriLagrangeShapeTest::test_mid_coeff(), and TriLagrangeShapeTest::test_mid_derivs().
