MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include "moab/Core.hpp" 00002 #include "TestUtil.hpp" 00003 #include "moab/Range.hpp" 00004 #include "moab/ReadUtilIface.hpp" 00005 #include "WriteHDF5.hpp" 00006 #include "moab/FileOptions.hpp" 00007 00008 #ifdef MOAB_HAVE_MPI 00009 #include "moab_mpi.h" 00010 #endif 00011 00012 #include <algorithm> 00013 #include <iostream> 00014 #include <sstream> 00015 #include <cstdlib> 00016 #include <cmath> 00017 00018 using namespace moab; 00019 00020 const char filename[] = "bad.h5m"; 00021 00022 void test_write_invalid_elem(); 00023 void test_write_read_many_tags(); 00024 00025 int main( int argc, char* argv[] ) 00026 { 00027 #ifdef MOAB_HAVE_MPI 00028 int fail = MPI_Init( &argc, &argv ); 00029 if( fail ) return fail; 00030 #else 00031 argv[0] = argv[argc - argc]; // warning in serial 00032 #endif 00033 00034 int exitval = 0; 00035 exitval += RUN_TEST( test_write_invalid_elem ); 00036 exitval += RUN_TEST( test_write_read_many_tags ); 00037 00038 #ifdef MOAB_HAVE_MPI 00039 fail = MPI_Finalize(); 00040 if( fail ) return fail; 00041 #endif 00042 00043 return exitval; 00044 } 00045 00046 void test_write_invalid_elem() 00047 { 00048 Core mbcore; 00049 Interface& moab = mbcore; 00050 ReadUtilIface* readtool = 0; 00051 ErrorCode rval; 00052 00053 rval = moab.query_interface( readtool );CHECK_ERR( rval ); 00054 CHECK( readtool != 0 ); 00055 00056 // create two nodes 00057 EntityHandle first_node; 00058 std::vector< double* > coords; 00059 rval = readtool->get_node_coords( 3, 2, 1, first_node, coords );CHECK_ERR( rval ); 00060 // Cppcheck warning (false positive): variable coords is assigned a value that is never used 00061 coords[0][0] = coords[0][1] = 0.0; 00062 coords[1][0] = coords[1][1] = 0.0; 00063 coords[2][0] = coords[2][1] = 0.0; 00064 00065 // create a triangle with an invalid node handle for its 00066 // third vertex 00067 EntityHandle tri; 00068 EntityHandle* conn = 0; 00069 rval = readtool->get_element_connect( 1, 3, MBTRI, 1, tri, conn );CHECK_ERR( rval ); 00070 conn[0] = first_node; // valid 00071 conn[1] = first_node + 1; // valid 00072 conn[2] = first_node + 2; // invalid 00073 00074 // try to write the file (should fail) 00075 WriteHDF5 writer( &moab ); 00076 FileOptions opts( 0 ); 00077 rval = writer.write_file( filename, true, opts, 0, 0, std::vector< std::string >() ); 00078 CHECK( MB_SUCCESS != rval ); 00079 } 00080 00081 void test_write_read_many_tags() 00082 { 00083 const int N = 200; 00084 Core mbcore; 00085 Interface& mb = mbcore; 00086 ErrorCode rval; 00087 00088 double coords[3] = { 0, 0, 0 }; 00089 EntityHandle node; 00090 rval = mb.create_vertex( coords, node );CHECK_ERR( rval ); 00091 00092 // create a lot of tags 00093 std::vector< Tag > tags; 00094 for( int i = 0; i < N; ++i ) 00095 { 00096 Tag t; 00097 std::ostringstream name( "IntTag" ); 00098 name << i; 00099 rval = mb.tag_get_handle( name.str().c_str(), 1, MB_TYPE_INTEGER, t, 00100 ( i % 2 ? MB_TAG_SPARSE : MB_TAG_DENSE ) | MB_TAG_EXCL, &i );CHECK_ERR( rval ); 00101 tags.push_back( t ); 00102 } 00103 00104 // write the file 00105 rval = mb.write_file( filename, "MOAB" );CHECK_ERR( rval ); 00106 00107 // clear moab instance 00108 rval = mb.delete_mesh();CHECK_ERR( rval ); 00109 for( int i = 0; i < N; ++i ) 00110 { 00111 rval = mb.tag_delete( tags[i] );CHECK_ERR( rval ); 00112 } 00113 00114 // read the file 00115 rval = mb.load_file( filename );CHECK_ERR( rval ); 00116 remove( filename ); 00117 00118 // check that we have the expected tags 00119 for( int i = 0; i < N; ++i ) 00120 { 00121 Tag t; 00122 std::ostringstream name( "IntTag" ); 00123 name << i; 00124 rval = mb.tag_get_handle( name.str().c_str(), 1, MB_TYPE_INTEGER, t );CHECK_ERR( rval ); 00125 00126 TagType storage; 00127 rval = mb.tag_get_type( t, storage );CHECK_ERR( rval ); 00128 CHECK_EQUAL( ( i % 2 ) ? MB_TAG_SPARSE : MB_TAG_DENSE, storage ); 00129 00130 DataType type; 00131 rval = mb.tag_get_data_type( t, type );CHECK_ERR( rval ); 00132 CHECK_EQUAL( MB_TYPE_INTEGER, type ); 00133 00134 int size; 00135 rval = mb.tag_get_length( t, size );CHECK_ERR( rval ); 00136 CHECK_EQUAL( 1, size ); 00137 00138 int def; 00139 rval = mb.tag_get_default_value( t, &def );CHECK_ERR( rval ); 00140 CHECK_EQUAL( i, def ); 00141 } 00142 }
