MOAB: Mesh Oriented datABase
(version 5.2.1)
Compare targets to mapping function Jacobian matrices. More...
#include <TMPQualityMetric.hpp>
Public Member Functions | |
TMPQualityMetric (TargetCalculator *tc, WeightCalculator *wc) | |
virtual MESQUITE_EXPORT int | get_negate_flag () const |
1 if metric should be minimized, -1 if metric should be maximized. | |
virtual MESQUITE_EXPORT void | get_evaluations (PatchData &pd, std::vector< size_t > &handles, bool free_vertices_only, MsqError &err) |
Get locations at which metric can be evaluated. | |
virtual MESQUITE_EXPORT void | get_element_evaluations (PatchData &pd, size_t elem_index, std::vector< size_t > &handles, MsqError &err) |
Get evaluation point handles for a given element. | |
virtual MESQUITE_EXPORT bool | evaluate (PatchData &pd, size_t handle, double &value, MsqError &err) |
Get metric value at a logical location in the patch. | |
virtual MESQUITE_EXPORT bool | evaluate_with_indices (PatchData &pd, size_t handle, double &value, std::vector< size_t > &indices, MsqError &err) |
MESQUITE_EXPORT void | set_target_calculator (TargetCalculator *tc) |
MESQUITE_EXPORT void | set_weight_calculator (WeightCalculator *wc) |
MESQUITE_EXPORT TargetCalculator * | get_target_calculator () const |
MESQUITE_EXPORT WeightCalculator * | get_weight_calculator () const |
virtual MESQUITE_EXPORT void | initialize_queue (MeshDomainAssoc *mesh_and_domain, const Settings *settings, MsqError &err) |
Called at start of instruction queue processing. | |
Static Public Member Functions | |
static MESQUITE_EXPORT void | get_patch_evaluations (PatchData &pd, std::vector< size_t > &handles, bool free_vertices_only, MsqError &err) |
Protected Types | |
enum | { MAX_ELEM_NODES = 27 } |
Protected Member Functions | |
virtual MESQUITE_EXPORT bool | evaluate_internal (PatchData &pd, size_t handle, double &value, size_t *indices, size_t &num_indices, MsqError &err)=0 |
MESQUITE_EXPORT bool | evaluate_surface_common (PatchData &pd, Sample sample, size_t element_index, const NodeSet &bits, size_t *indices, size_t &num_indices, MsqVector< 2 > *derivs, MsqMatrix< 2, 2 > &W, MsqMatrix< 2, 2 > &A, MsqMatrix< 3, 2 > &S_a_transpose_Theta, MsqError &err) |
MESQUITE_EXPORT void | weight (PatchData &pd, Sample sample, size_t elem, int num_points, double &value, Vector3D *grad, SymMatrix3D *diag, Matrix3D *hess, MsqError &err) |
Protected Attributes | |
size_t | mIndices [MAX_ELEM_NODES] |
std::vector< MsqMatrix< 2, 2 > > | hess2d |
MsqVector< 3 > | mDerivs3D [MAX_ELEM_NODES] |
MsqVector< 2 > | mDerivs2D [MAX_ELEM_NODES] |
TargetCalculator * | targetCalc |
Private Attributes | |
WeightCalculator * | weightCalc |
Base class for various TMP QualityMetric implementations
Definition at line 55 of file TMPQualityMetric.hpp.
anonymous enum [protected] |
Definition at line 119 of file TMPQualityMetric.hpp.
{ MAX_ELEM_NODES = 27 };
MBMesquite::TMPQualityMetric::TMPQualityMetric | ( | TargetCalculator * | tc, |
WeightCalculator * | wc | ||
) | [inline] |
tc | The target calculator |
wc | The weight calculator |
Definition at line 62 of file TMPQualityMetric.hpp.
: targetCalc( tc ), weightCalc( wc ) {}
bool MBMesquite::TMPQualityMetric::evaluate | ( | PatchData & | pd, |
size_t | handle, | ||
double & | value, | ||
MsqError & | err | ||
) | [virtual] |
Evaluate the metric at one location in the PatchData.
pd | The patch. |
handle | The location in the patch (as passed back from get_evaluations). |
value | The output metric value. |
Implements MBMesquite::QualityMetric.
Definition at line 77 of file TMPQualityMetric.cpp.
References MBMesquite::ElemSampleQM::elem(), evaluate_internal(), MBMesquite::WeightCalculator::get_weight(), mIndices, MSQ_CHKERR, MSQ_ERRZERO, MBMesquite::ElemSampleQM::sample(), and weightCalc.
Referenced by MBMesquite::VertexMover::loop_over_mesh().
{ size_t num_idx; bool valid = evaluate_internal( pd, p_handle, value, mIndices, num_idx, err ); if( MSQ_CHKERR( err ) || !valid ) return false; // apply target weight to value if( weightCalc ) { const Sample s = ElemSampleQM::sample( p_handle ); const size_t e = ElemSampleQM::elem( p_handle ); double ck = weightCalc->get_weight( pd, e, s, err ); MSQ_ERRZERO( err ); value *= ck; } return true; }
virtual MESQUITE_EXPORT bool MBMesquite::TMPQualityMetric::evaluate_internal | ( | PatchData & | pd, |
size_t * | indices, | ||
size_t & | num_indices, | ||
) | [protected, pure virtual] |
Implemented in MBMesquite::AWQualityMetric, and MBMesquite::TQualityMetric.
Referenced by evaluate(), and evaluate_with_indices().
bool MBMesquite::TMPQualityMetric::evaluate_surface_common | ( | PatchData & | pd, |
Sample | sample, | ||
size_t | element_index, | ||
const NodeSet & | bits, | ||
MsqVector< 2 > * | derivs, | ||
MsqMatrix< 2, 2 > & | W, | ||
MsqMatrix< 2, 2 > & | A, | ||
MsqMatrix< 3, 2 > & | S_a_transpose_Theta, | ||
) | [protected] |
Definition at line 239 of file TMPQualityMetric.cpp.
References MBMesquite::MsqMatrix< R, C >::column(), MBMesquite::MsqMatrix< R, C >::data(), MBMesquite::PatchData::domain_set(), MBMesquite::PatchData::element_by_index(), MBMesquite::TargetCalculator::get_2D_target(), MBMesquite::PatchData::get_domain_normal_at_sample(), MBMesquite::MsqMeshEntity::get_element_type(), MBMesquite::PatchData::get_mapping_function_2D(), MBMesquite::TargetCalculator::get_surface_target(), MBMesquite::TargetCalculator::have_surface_orient(), MBMesquite::MappingFunction2D::jacobian(), MSQ_ERRZERO, MSQ_SETERR, n, MBMesquite::project_to_matrix_plane(), MBMesquite::project_to_perp_plane(), MBMesquite::MsqMatrix< R, C >::row(), MBMesquite::MsqMatrix< R, C >::set_column(), MBMesquite::MsqMatrix< R, C >::set_row(), targetCalc, u, and MBMesquite::MsqError::UNSUPPORTED_ELEMENT.
Referenced by MBMesquite::AWQualityMetric::evaluate_internal(), MBMesquite::TQualityMetric::evaluate_internal(), MBMesquite::AWQualityMetric::evaluate_with_gradient(), MBMesquite::TQualityMetric::evaluate_with_gradient(), MBMesquite::TQualityMetric::evaluate_with_Hessian(), MBMesquite::AWQualityMetric::evaluate_with_Hessian(), MBMesquite::AWQualityMetric::evaluate_with_Hessian_diagonal(), and MBMesquite::TQualityMetric::evaluate_with_Hessian_diagonal().
{ EntityTopology type = pd.element_by_index( e ).get_element_type(); const MappingFunction2D* mf = pd.get_mapping_function_2D( type ); if( !mf ) { MSQ_SETERR( err )( "No mapping function for element type", MsqError::UNSUPPORTED_ELEMENT ); return false; } MsqMatrix< 3, 2 > J; mf->jacobian( pd, e, bits, s, indices, derivs, num_indices, J, err ); // If we have a 3x2 target matrix if( targetCalc->have_surface_orient() ) { MsqVector< 3 > u, u_perp; MsqMatrix< 3, 2 > W_hat; targetCalc->get_surface_target( pd, e, s, W_hat, err ); MSQ_ERRZERO( err ); // Use the cross product of the columns of W as the normal of the // plane to work in (i.e. u.). W should have been constructed such // that said cross product is in the direction of (n_s)_init. And if // for some reason it as not, then using something other than said // cross product is likely to produce very wrong results. project_to_matrix_plane( W_hat, W, u, u_perp ); // Do the transforms on A to align it with W and project into the plane. if( !project_to_perp_plane( J, u, u_perp, A, S_a_transpose_Theta ) ) return false; } // Otherwise if we have a 2x2 target matrix (i.e. the target does // not contain orientation information), project into the plane // tangent to J. else { MsqVector< 3 > u, u_perp; targetCalc->get_2D_target( pd, e, s, W, err ); MSQ_ERRZERO( err ); project_to_matrix_plane( J, A, u, u_perp ); S_a_transpose_Theta.set_column( 0, u_perp ); S_a_transpose_Theta.set_column( 1, u * u_perp ); // If the domain is set, adjust the sign of things correctly // for the case where the element is inverted with respect // to the domain. if( pd.domain_set() ) { Vector3D n; pd.get_domain_normal_at_sample( e, s, n, err ); MSQ_ERRZERO( err ); // if sigma == -1 if( Vector3D( u.data() ) % n < 0.0 ) { // flip u u = -u; // S_a_transpose_Theta == Theta, because S_a == I here. // u_perp is unaffected by flipping u, so only the second // column of S_a_transpose_Theta and the second row of A // are flipped because u x u_perp will be flipped. S_a_transpose_Theta.set_column( 1, -S_a_transpose_Theta.column( 1 ) ); A.set_row( 1, -A.row( 1 ) ); } } } return true; }
bool MBMesquite::TMPQualityMetric::evaluate_with_indices | ( | PatchData & | pd, |
std::vector< size_t > & | indices, | ||
) | [virtual] |
pd | The patch. |
indices | The free vertices that the evaluation is a function of, specified as vertex indices in the PatchData. |
Definition at line 95 of file TMPQualityMetric.cpp.
References MBMesquite::arrptr(), MBMesquite::ElemSampleQM::elem(), evaluate_internal(), MBMesquite::WeightCalculator::get_weight(), MAX_ELEM_NODES, MSQ_CHKERR, MSQ_ERRZERO, MBMesquite::ElemSampleQM::sample(), and weightCalc.
{ indices.resize( MAX_ELEM_NODES ); size_t num_idx = 0; bool result = evaluate_internal( pd, p_handle, value, arrptr( indices ), num_idx, err ); if( MSQ_CHKERR( err ) || !result ) return false; indices.resize( num_idx ); // apply target weight to value if( weightCalc ) { const Sample s = ElemSampleQM::sample( p_handle ); const size_t e = ElemSampleQM::elem( p_handle ); double ck = weightCalc->get_weight( pd, e, s, err ); MSQ_ERRZERO( err ); value *= ck; } return true; }
void MBMesquite::TMPQualityMetric::get_element_evaluations | ( | PatchData & | pd, |
size_t | elem_index, | ||
std::vector< size_t > & | handles, | ||
) | [virtual] |
Similar to QualityMetric::get_evaluations, this method returns a list of handles corresponding to sample points at which the metric may be evaluated. While QualityMetric::get_evaluations returns sample points for all elements in a PatchData, this method returns only the subset corresponding to a single element.
Implements MBMesquite::ElemSampleQM.
Definition at line 71 of file TMPQualityMetric.cpp.
References MBMesquite::get_elem_sample_points().
{ get_elem_sample_points( pd, p_elem, handles, err ); }
void MBMesquite::TMPQualityMetric::get_evaluations | ( | PatchData & | pd, |
bool | free_vertices_only, | ||
) | [virtual] |
Different metrics are evaluated for different things within a patch. For example, an element-based metric will be evaluated once for each element in patch, a vertex-based metric once for each veretx, and a target/sample-point based metric will be evaluated once for each samle point in each element. This method returns a list of handles, one for each location in the patch at which the metric can be evaluated. The handle values are used as input to the evaluate methods.
pd | The patch |
handles | Output list of handles |
free_vertices_only | If true, only pass back evaluation points that depend on at least one free vertex. |
Definition at line 61 of file TMPQualityMetric.cpp.
References MBMesquite::get_sample_pt_evaluations().
Referenced by TQualityMetricTest::regression_inverse_mean_ratio_grad(), and TQualityMetricTest::regression_inverse_mean_ratio_hess().
{ get_sample_pt_evaluations( pd, handles, free, err ); }
int MBMesquite::TMPQualityMetric::get_negate_flag | ( | ) | const [virtual] |
Definition at line 56 of file TMPQualityMetric.cpp.
return 1;
void MBMesquite::TMPQualityMetric::get_patch_evaluations | ( | PatchData & | pd, |
) | [static] |
Definition at line 66 of file TMPQualityMetric.cpp.
Referenced by MBMesquite::MeshUtil::lambda_distribution().
MESQUITE_EXPORT TargetCalculator* MBMesquite::TMPQualityMetric::get_target_calculator | ( | ) | const [inline] |
MESQUITE_EXPORT WeightCalculator* MBMesquite::TMPQualityMetric::get_weight_calculator | ( | ) | const [inline] |
void MBMesquite::TMPQualityMetric::initialize_queue | ( | MeshDomainAssoc * | mesh_and_domain, |
const Settings * | settings, | ||
) | [virtual] |
Do any preliminary global initialization, consistency checking, etc. Default implementation does nothing.
Reimplemented from MBMesquite::QualityMetric.
Definition at line 334 of file TMPQualityMetric.cpp.
References MBMesquite::WeightCalculator::initialize_queue(), MBMesquite::TargetCalculator::initialize_queue(), MSQ_ERRRTN, targetCalc, and weightCalc.
{ targetCalc->initialize_queue( mesh_and_domain, settings, err );MSQ_ERRRTN( err ); if( weightCalc ) { weightCalc->initialize_queue( mesh_and_domain, settings, err );MSQ_ERRRTN( err ); } }
MESQUITE_EXPORT void MBMesquite::TMPQualityMetric::set_target_calculator | ( | TargetCalculator * | tc | ) | [inline] |
MESQUITE_EXPORT void MBMesquite::TMPQualityMetric::set_weight_calculator | ( | WeightCalculator * | wc | ) | [inline] |
void MBMesquite::TMPQualityMetric::weight | ( | PatchData & | pd, |
size_t | elem, | ||
int | num_points, | ||
Vector3D * | grad, | ||
SymMatrix3D * | diag, | ||
Matrix3D * | hess, | ||
) | [protected] |
Definition at line 309 of file TMPQualityMetric.cpp.
References MBMesquite::WeightCalculator::get_weight(), MSQ_ERRRTN, n, and weightCalc.
Referenced by MBMesquite::AWQualityMetric::evaluate_with_gradient(), MBMesquite::TQualityMetric::evaluate_with_gradient(), MBMesquite::TQualityMetric::evaluate_with_Hessian(), MBMesquite::AWQualityMetric::evaluate_with_Hessian(), MBMesquite::AWQualityMetric::evaluate_with_Hessian_diagonal(), and MBMesquite::TQualityMetric::evaluate_with_Hessian_diagonal().
{ if( !weightCalc ) return; double ck = weightCalc->get_weight( pd, p_elem, p_sample, err );MSQ_ERRRTN( err ); value *= ck; if( grad ) { for( int i = 0; i < num_idx; ++i ) grad[i] *= ck; } if( diag ) { for( int i = 0; i < num_idx; ++i ) diag[i] *= ck; } if( hess ) { const int n = num_idx * ( num_idx + 1 ) / 2; for( int i = 0; i < n; ++i ) hess[i] *= ck; } }
std::vector< MsqMatrix< 2, 2 > > MBMesquite::TMPQualityMetric::hess2d [protected] |
Definition at line 124 of file TMPQualityMetric.hpp.
Referenced by MBMesquite::AWQualityMetric::evaluate_with_Hessian(), and MBMesquite::TQualityMetric::evaluate_with_Hessian().
MsqVector< 2 > MBMesquite::TMPQualityMetric::mDerivs2D[MAX_ELEM_NODES] [protected] |
Definition at line 126 of file TMPQualityMetric.hpp.
MsqVector< 3 > MBMesquite::TMPQualityMetric::mDerivs3D[MAX_ELEM_NODES] [protected] |
Definition at line 125 of file TMPQualityMetric.hpp.
size_t MBMesquite::TMPQualityMetric::mIndices[MAX_ELEM_NODES] [protected] |
Definition at line 123 of file TMPQualityMetric.hpp.
Referenced by evaluate(), MBMesquite::AWQualityMetric::evaluate_with_gradient(), MBMesquite::TQualityMetric::evaluate_with_gradient(), MBMesquite::AWQualityMetric::evaluate_with_Hessian(), MBMesquite::TQualityMetric::evaluate_with_Hessian(), MBMesquite::AWQualityMetric::evaluate_with_Hessian_diagonal(), and MBMesquite::TQualityMetric::evaluate_with_Hessian_diagonal().
TargetCalculator* MBMesquite::TMPQualityMetric::targetCalc [protected] |
Definition at line 128 of file TMPQualityMetric.hpp.
Referenced by MBMesquite::AWQualityMetric::evaluate_internal(), MBMesquite::TQualityMetric::evaluate_internal(), evaluate_surface_common(), MBMesquite::AWQualityMetric::evaluate_with_gradient(), MBMesquite::TQualityMetric::evaluate_with_gradient(), MBMesquite::TQualityMetric::evaluate_with_Hessian(), MBMesquite::AWQualityMetric::evaluate_with_Hessian(), MBMesquite::AWQualityMetric::evaluate_with_Hessian_diagonal(), MBMesquite::TQualityMetric::evaluate_with_Hessian_diagonal(), get_target_calculator(), initialize_queue(), and set_target_calculator().
Definition at line 131 of file TMPQualityMetric.hpp.
Referenced by evaluate(), evaluate_with_indices(), get_weight_calculator(), initialize_queue(), set_weight_calculator(), and weight().
