MOAB: Mesh Oriented datABase
(version 5.4.0)
00001 /* ***************************************************************** 00002 MESQUITE -- The Mesh Quality Improvement Toolkit 00003 00004 Copyright 2006 Sandia National Laboratories. Developed at the 00005 University of Wisconsin--Madison under SNL contract number 00006 624796. The U.S. Government and the University of Wisconsin 00007 retain certain rights to this software. 00008 00009 This library is free software; you can redistribute it and/or 00010 modify it under the terms of the GNU Lesser General Public 00011 License as published by the Free Software Foundation; either 00012 version 2.1 of the License, or (at your option) any later version. 00013 00014 This library is distributed in the hope that it will be useful, 00015 but WITHOUT ANY WARRANTY; without even the implied warranty of 00016 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00017 Lesser General Public License for more details. 00018 00019 You should have received a copy of the GNU Lesser General Public License 00020 (lgpl.txt) along with this library; if not, write to the Free Software 00021 Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA 00022 00023 (2006) kraftche@cae.wisc.edu 00024 00025 ***************************************************************** */ 00026 00027 /** \file TQualityMetric.cpp 00028 * \brief 00029 * \author Jason Kraftcheck 00030 */ 00031 00032 #undef PRINT_INFO 00033 00034 #include "Mesquite.hpp" 00035 #include "TQualityMetric.hpp" 00036 #include "MsqMatrix.hpp" 00037 #include "ElementQM.hpp" 00038 #include "MsqError.hpp" 00039 #include "Vector3D.hpp" 00040 #include "PatchData.hpp" 00041 #include "MappingFunction.hpp" 00042 #include "WeightCalculator.hpp" 00043 #include "TargetCalculator.hpp" 00044 #include "TMetric.hpp" 00045 #include "TMetricBarrier.hpp" 00046 #include "TargetMetricUtil.hpp" 00047 #include "TMPDerivs.hpp" 00048 00049 #ifdef PRINT_INFO 00050 #include <iostream> 00051 #endif 00052 00053 #include <functional> 00054 #include <algorithm> 00055 00056 #define NUMERICAL_2D_HESSIAN 00057 00058 namespace MBMesquite 00059 { 00060 00061 std::string TQualityMetric::get_name() const 00062 { 00063 return targetMetric->get_name(); 00064 } 00065 00066 bool TQualityMetric::evaluate_internal( PatchData& pd, 00067 size_t p_handle, 00068 double& value, 00069 size_t* indices, 00070 size_t& num_indices, 00071 MsqError& err ) 00072 { 00073 const Sample s = ElemSampleQM::sample( p_handle ); 00074 const size_t e = ElemSampleQM::elem( p_handle ); 00075 MsqMeshEntity& p_elem = pd.element_by_index( e ); 00076 EntityTopology type = p_elem.get_element_type(); 00077 unsigned edim = TopologyInfo::dimension( type ); 00078 const NodeSet bits = pd.non_slave_node_set( e ); 00079 00080 bool rval; 00081 if( edim == 3 ) 00082 { // 3x3 or 3x2 targets ? 00083 const MappingFunction3D* mf = pd.get_mapping_function_3D( type ); 00084 if( !mf ) 00085 { 00086 MSQ_SETERR( err ) 00087 ( "No mapping function for element type", MsqError::UNSUPPORTED_ELEMENT ); 00088 return false; 00089 } 00090 00091 MsqMatrix< 3, 3 > A, W; 00092 mf->jacobian( pd, e, bits, s, indices, mDerivs3D, num_indices, A, err ); 00093 MSQ_ERRZERO( err ); 00094 targetCalc->get_3D_target( pd, e, s, W, err ); 00095 MSQ_ERRZERO( err ); 00096 const MsqMatrix< 3, 3 > Winv = inverse( W ); 00097 const MsqMatrix< 3, 3 > T = A * Winv; 00098 rval = targetMetric->evaluate( T, value, err ); 00099 MSQ_ERRZERO( err ); 00100 #ifdef PRINT_INFO 00101 print_info< 3 >( e, s, A, W, A * inverse( W ) ); 00102 #endif 00103 } 00104 else if( edim == 2 ) 00105 { 00106 MsqMatrix< 2, 2 > W, A; 00107 MsqMatrix< 3, 2 > S_a_transpose_Theta; 00108 rval = 00109 evaluate_surface_common( pd, s, e, bits, indices, num_indices, mDerivs2D, W, A, S_a_transpose_Theta, err ); 00110 if( MSQ_CHKERR( err ) || !rval ) return false; 00111 const MsqMatrix< 2, 2 > Winv = inverse( W ); 00112 const MsqMatrix< 2, 2 > T = A * Winv; 00113 rval = targetMetric->evaluate( T, value, err ); 00114 MSQ_ERRZERO( err ); 00115 00116 #ifdef PRINT_INFO 00117 print_info< 2 >( e, s, J, Wp, A * inverse( W ) ); 00118 #endif 00119 } 00120 else 00121 { 00122 assert( false ); 00123 return false; 00124 } 00125 00126 return rval; 00127 } 00128 00129 bool TQualityMetric::evaluate_with_gradient( PatchData& pd, 00130 size_t p_handle, 00131 double& value, 00132 std::vector< size_t >& indices, 00133 std::vector< Vector3D >& grad, 00134 MsqError& err ) 00135 { 00136 const Sample s = ElemSampleQM::sample( p_handle ); 00137 const size_t e = ElemSampleQM::elem( p_handle ); 00138 MsqMeshEntity& p_elem = pd.element_by_index( e ); 00139 EntityTopology type = p_elem.get_element_type(); 00140 unsigned edim = TopologyInfo::dimension( type ); 00141 size_t num_idx = 0; 00142 const NodeSet bits = pd.non_slave_node_set( e ); 00143 00144 bool rval; 00145 if( edim == 3 ) 00146 { // 3x3 or 3x2 targets ? 00147 const MappingFunction3D* mf = pd.get_mapping_function_3D( type ); 00148 if( !mf ) 00149 { 00150 MSQ_SETERR( err ) 00151 ( "No mapping function for element type", MsqError::UNSUPPORTED_ELEMENT ); 00152 return false; 00153 } 00154 00155 MsqMatrix< 3, 3 > A, W, dmdT; 00156 mf->jacobian( pd, e, bits, s, mIndices, mDerivs3D, num_idx, A, err ); 00157 MSQ_ERRZERO( err ); 00158 targetCalc->get_3D_target( pd, e, s, W, err ); 00159 MSQ_ERRZERO( err ); 00160 const MsqMatrix< 3, 3 > Winv = inverse( W ); 00161 const MsqMatrix< 3, 3 > T = A * Winv; 00162 rval = targetMetric->evaluate_with_grad( T, value, dmdT, err ); 00163 MSQ_ERRZERO( err ); 00164 gradient< 3 >( num_idx, mDerivs3D, dmdT * transpose( Winv ), grad ); 00165 #ifdef PRINT_INFO 00166 print_info< 3 >( e, s, A, W, A * inverse( W ) ); 00167 #endif 00168 } 00169 else if( edim == 2 ) 00170 { 00171 MsqMatrix< 2, 2 > W, A, dmdT; 00172 MsqMatrix< 3, 2 > S_a_transpose_Theta; 00173 rval = evaluate_surface_common( pd, s, e, bits, mIndices, num_idx, mDerivs2D, W, A, S_a_transpose_Theta, err ); 00174 if( MSQ_CHKERR( err ) || !rval ) return false; 00175 const MsqMatrix< 2, 2 > Winv = inverse( W ); 00176 const MsqMatrix< 2, 2 > T = A * Winv; 00177 rval = targetMetric->evaluate_with_grad( T, value, dmdT, err ); 00178 MSQ_ERRZERO( err ); 00179 gradient< 2 >( num_idx, mDerivs2D, S_a_transpose_Theta * dmdT * transpose( Winv ), grad ); 00180 #ifdef PRINT_INFO 00181 print_info< 2 >( e, s, J, Wp, A * inverse( W ) ); 00182 #endif 00183 } 00184 else 00185 { 00186 assert( false ); 00187 return false; 00188 } 00189 00190 // pass back index list 00191 indices.resize( num_idx ); 00192 std::copy( mIndices, mIndices + num_idx, indices.begin() ); 00193 00194 // apply target weight to value 00195 weight( pd, s, e, num_idx, value, grad.empty() ? 0 : arrptr( grad ), 0, 0, err ); 00196 MSQ_ERRZERO( err ); 00197 return rval; 00198 } 00199 00200 bool TQualityMetric::evaluate_with_Hessian( PatchData& pd, 00201 size_t p_handle, 00202 double& value, 00203 std::vector< size_t >& indices, 00204 std::vector< Vector3D >& grad, 00205 std::vector< Matrix3D >& Hessian, 00206 MsqError& err ) 00207 { 00208 const Sample s = ElemSampleQM::sample( p_handle ); 00209 const size_t e = ElemSampleQM::elem( p_handle ); 00210 MsqMeshEntity& p_elem = pd.element_by_index( e ); 00211 EntityTopology type = p_elem.get_element_type(); 00212 unsigned edim = TopologyInfo::dimension( type ); 00213 size_t num_idx = 0; 00214 const NodeSet bits = pd.non_slave_node_set( e ); 00215 00216 bool rval; 00217 if( edim == 3 ) 00218 { // 3x3 or 3x2 targets ? 00219 const MappingFunction3D* mf = pd.get_mapping_function_3D( type ); 00220 if( !mf ) 00221 { 00222 MSQ_SETERR( err ) 00223 ( "No mapping function for element type", MsqError::UNSUPPORTED_ELEMENT ); 00224 return false; 00225 } 00226 00227 MsqMatrix< 3, 3 > A, W, dmdT, d2mdT2[6]; 00228 mf->jacobian( pd, e, bits, s, mIndices, mDerivs3D, num_idx, A, err ); 00229 MSQ_ERRZERO( err ); 00230 targetCalc->get_3D_target( pd, e, s, W, err ); 00231 MSQ_ERRZERO( err ); 00232 const MsqMatrix< 3, 3 > Winv = inverse( W ); 00233 const MsqMatrix< 3, 3 > T = A * Winv; 00234 rval = targetMetric->evaluate_with_hess( T, value, dmdT, d2mdT2, err ); 00235 MSQ_ERRZERO( err ); 00236 gradient< 3 >( num_idx, mDerivs3D, dmdT * transpose( Winv ), grad ); 00237 second_deriv_wrt_product_factor( d2mdT2, Winv ); 00238 Hessian.resize( num_idx * ( num_idx + 1 ) / 2 ); 00239 if( num_idx ) hessian< 3 >( num_idx, mDerivs3D, d2mdT2, arrptr( Hessian ) ); 00240 00241 #ifdef PRINT_INFO 00242 print_info< 3 >( e, s, A, W, A * inverse( W ) ); 00243 #endif 00244 } 00245 else if( edim == 2 ) 00246 { 00247 #ifdef NUMERICAL_2D_HESSIAN 00248 // return finite difference approximation for now 00249 00250 return QualityMetric::evaluate_with_Hessian( pd, p_handle, value, indices, grad, Hessian, err ); 00251 #else 00252 MsqMatrix< 2, 2 > W, A, dmdT, d2mdT2[3]; 00253 MsqMatrix< 3, 2 > M; 00254 rval = evaluate_surface_common( pd, s, e, bits, mIndices, num_idx, mDerivs2D, W, A, M, err ); 00255 if( MSQ_CHKERR( err ) || !rval ) return false; 00256 const MsqMatrix< 2, 2 > Winv = inverse( W ); 00257 const MsqMatrix< 2, 2 > T = A * Winv; 00258 rval = targetMetric->evaluate_with_hess( T, value, dmdT, d2mdT2, err ); 00259 MSQ_ERRZERO( err ); 00260 gradient< 2 >( num_idx, mDerivs2D, M * dmdT * transpose( Winv ), grad ); 00261 // calculate 2D hessian 00262 second_deriv_wrt_product_factor( d2mdT2, Winv ); 00263 const size_t n = num_idx * ( num_idx + 1 ) / 2; 00264 hess2d.resize( n ); 00265 if( n ) hessian< 2 >( num_idx, mDerivs2D, d2mdT2, arrptr( hess2d ) ); 00266 // calculate surface hessian as transform of 2D hessian 00267 Hessian.resize( n ); 00268 for( size_t i = 0; i < n; ++i ) 00269 Hessian[i] = Matrix3D( ( M * hess2d[i] * transpose( M ) ).data() ); 00270 #ifdef PRINT_INFO 00271 print_info< 2 >( e, s, J, Wp, A * inverse( W ) ); 00272 #endif 00273 #endif 00274 } 00275 else 00276 { 00277 assert( 0 ); 00278 return false; 00279 } 00280 00281 // pass back index list 00282 indices.resize( num_idx ); 00283 std::copy( mIndices, mIndices + num_idx, indices.begin() ); 00284 00285 // apply target weight to value 00286 if( !num_idx ) 00287 weight( pd, s, e, num_idx, value, 0, 0, 0, err ); 00288 else 00289 weight( pd, s, e, num_idx, value, arrptr( grad ), 0, arrptr( Hessian ), err ); 00290 MSQ_ERRZERO( err ); 00291 return rval; 00292 } 00293 00294 bool TQualityMetric::evaluate_with_Hessian_diagonal( PatchData& pd, 00295 size_t p_handle, 00296 double& value, 00297 std::vector< size_t >& indices, 00298 std::vector< Vector3D >& grad, 00299 std::vector< SymMatrix3D >& diagonal, 00300 MsqError& err ) 00301 { 00302 const Sample s = ElemSampleQM::sample( p_handle ); 00303 const size_t e = ElemSampleQM::elem( p_handle ); 00304 MsqMeshEntity& p_elem = pd.element_by_index( e ); 00305 EntityTopology type = p_elem.get_element_type(); 00306 unsigned edim = TopologyInfo::dimension( type ); 00307 size_t num_idx = 0; 00308 const NodeSet bits = pd.non_slave_node_set( e ); 00309 00310 bool rval; 00311 if( edim == 3 ) 00312 { // 3x3 or 3x2 targets ? 00313 const MappingFunction3D* mf = pd.get_mapping_function_3D( type ); 00314 if( !mf ) 00315 { 00316 MSQ_SETERR( err ) 00317 ( "No mapping function for element type", MsqError::UNSUPPORTED_ELEMENT ); 00318 return false; 00319 } 00320 00321 MsqMatrix< 3, 3 > A, W, dmdT, d2mdT2[6]; 00322 mf->jacobian( pd, e, bits, s, mIndices, mDerivs3D, num_idx, A, err ); 00323 MSQ_ERRZERO( err ); 00324 targetCalc->get_3D_target( pd, e, s, W, err ); 00325 MSQ_ERRZERO( err ); 00326 const MsqMatrix< 3, 3 > Winv = inverse( W ); 00327 const MsqMatrix< 3, 3 > T = A * Winv; 00328 rval = targetMetric->evaluate_with_hess( T, value, dmdT, d2mdT2, err ); 00329 MSQ_ERRZERO( err ); 00330 gradient< 3 >( num_idx, mDerivs3D, dmdT * transpose( Winv ), grad ); 00331 second_deriv_wrt_product_factor( d2mdT2, Winv ); 00332 00333 diagonal.resize( num_idx ); 00334 hessian_diagonal< 3 >( num_idx, mDerivs3D, d2mdT2, arrptr( diagonal ) ); 00335 #ifdef PRINT_INFO 00336 print_info< 3 >( e, s, A, W, A * inverse( W ) ); 00337 #endif 00338 } 00339 else if( edim == 2 ) 00340 { 00341 #ifdef NUMERICAL_2D_HESSIAN 00342 // use finite diference approximation for now 00343 return QualityMetric::evaluate_with_Hessian_diagonal( pd, p_handle, value, indices, grad, diagonal, err ); 00344 #else 00345 MsqMatrix< 2, 2 > W, A, dmdT, d2mdT2[3]; 00346 MsqMatrix< 3, 2 > M; 00347 rval = evaluate_surface_common( pd, s, e, bits, mIndices, num_idx, mDerivs2D, W, A, M, err ); 00348 if( MSQ_CHKERR( err ) || !rval ) return false; 00349 const MsqMatrix< 2, 2 > Winv = inverse( W ); 00350 const MsqMatrix< 2, 2 > T = A * Winv; 00351 rval = targetMetric->evaluate_with_hess( T, value, dmdT, d2mdT2, err ); 00352 MSQ_ERRZERO( err ); 00353 gradient< 2 >( num_idx, mDerivs2D, M * dmdT * transpose( Winv ), grad ); 00354 second_deriv_wrt_product_factor( d2mdT2, Winv ); 00355 00356 diagonal.resize( num_idx ); 00357 for( size_t i = 0; i < num_idx; ++i ) 00358 { 00359 MsqMatrix< 2, 2 > block2d; 00360 block2d( 0, 0 ) = transpose( mDerivs2D[i] ) * d2mdT2[0] * mDerivs2D[i]; 00361 block2d( 0, 1 ) = transpose( mDerivs2D[i] ) * d2mdT2[1] * mDerivs2D[i]; 00362 block2d( 1, 0 ) = block2d( 0, 1 ); 00363 block2d( 1, 1 ) = transpose( mDerivs2D[i] ) * d2mdT2[2] * mDerivs2D[i]; 00364 MsqMatrix< 3, 2 > p = M * block2d; 00365 00366 SymMatrix3D& H = diagonal[i]; 00367 H[0] = p.row( 0 ) * transpose( M.row( 0 ) ); 00368 H[1] = p.row( 0 ) * transpose( M.row( 1 ) ); 00369 H[2] = p.row( 0 ) * transpose( M.row( 2 ) ); 00370 H[3] = p.row( 1 ) * transpose( M.row( 1 ) ); 00371 H[4] = p.row( 1 ) * transpose( M.row( 2 ) ); 00372 H[5] = p.row( 2 ) * transpose( M.row( 2 ) ); 00373 } 00374 #ifdef PRINT_INFO 00375 print_info< 2 >( e, s, J, Wp, A * inverse( W ) ); 00376 #endif 00377 #endif 00378 } 00379 else 00380 { 00381 assert( 0 ); 00382 return false; 00383 } 00384 00385 // pass back index list 00386 indices.resize( num_idx ); 00387 std::copy( mIndices, mIndices + num_idx, indices.begin() ); 00388 00389 // apply target weight to value 00390 if( !num_idx ) 00391 weight( pd, s, e, num_idx, value, 0, 0, 0, err ); 00392 else 00393 weight( pd, s, e, num_idx, value, arrptr( grad ), arrptr( diagonal ), 0, err ); 00394 MSQ_ERRZERO( err ); 00395 return rval; 00396 } 00397 00398 } // namespace MBMesquite
