MOAB: Mesh Oriented datABase
(version 5.2.1)
#include <TargetCalculator.hpp>
Public Member Functions | |
virtual | ~TargetCalculator () |
virtual void | initialize_queue (MeshDomainAssoc *mesh_and_domain, const Settings *settings, MsqError &err) |
Called at start of instruction queue processing. | |
virtual bool | get_3D_target (PatchData &pd, size_t element, Sample sample, MsqMatrix< 3, 3 > &W_out, MsqError &err)=0 |
Get a target matrix. | |
virtual bool | get_surface_target (PatchData &pd, size_t element, Sample sample, MsqMatrix< 3, 2 > &W_out, MsqError &err)=0 |
virtual bool | get_2D_target (PatchData &pd, size_t element, Sample sample, MsqMatrix< 2, 2 > &W_out, MsqError &err)=0 |
virtual bool | have_surface_orient () const =0 |
Use 3x2 W for surface elements if true, 2x2 W if false. | |
Static Public Member Functions | |
static bool | factor_3D (const MsqMatrix< 3, 3 > &W, double &Lambda, MsqMatrix< 3, 3 > &V, MsqMatrix< 3, 3 > &Q, MsqMatrix< 3, 3 > &Delta, MsqError &err) |
Factor some existing target or Jacobian matrix. | |
static bool | factor_surface (const MsqMatrix< 3, 2 > &W, double &Lambda, MsqMatrix< 3, 2 > &V, MsqMatrix< 2, 2 > &Q, MsqMatrix< 2, 2 > &Delta, MsqError &err) |
static bool | factor_2D (const MsqMatrix< 2, 2 > &W, double &Lambda, MsqMatrix< 2, 2 > &V, MsqMatrix< 2, 2 > &Q, MsqMatrix< 2, 2 > &Delta, MsqError &err) |
static double | size (const MsqMatrix< 3, 3 > &W) |
Get size component of W. | |
static double | size (const MsqMatrix< 3, 2 > &W) |
static double | size (const MsqMatrix< 2, 2 > &W) |
static MsqMatrix< 3, 3 > | skew (const MsqMatrix< 3, 3 > &W) |
Get skew component of W. | |
static MsqMatrix< 2, 2 > | skew (const MsqMatrix< 3, 2 > &W) |
static MsqMatrix< 2, 2 > | skew (const MsqMatrix< 2, 2 > &W) |
static MsqMatrix< 3, 3 > | aspect (const MsqMatrix< 3, 3 > &W) |
static MsqMatrix< 2, 2 > | aspect (const MsqMatrix< 3, 2 > &W) |
static MsqMatrix< 2, 2 > | aspect (const MsqMatrix< 2, 2 > &W) |
static MsqMatrix< 3, 3 > | shape (const MsqMatrix< 3, 3 > &W) |
Get shape (skew and aspect) component of W. | |
static MsqMatrix< 2, 2 > | shape (const MsqMatrix< 3, 2 > &W) |
static MsqMatrix< 2, 2 > | shape (const MsqMatrix< 2, 2 > &W) |
static MsqMatrix< 3, 3 > | new_orientation_3D (const MsqVector< 3 > &b1, const MsqVector< 3 > &b2) |
Create a new orientation matrix. | |
static MsqMatrix< 3, 2 > | new_orientation_2D (const MsqVector< 3 > &b1, const MsqVector< 3 > &b2) |
static void | ideal_skew_3D (EntityTopology element_type, Sample s, const PatchData &pd, MsqMatrix< 3, 3 > &W, MsqError &err) |
Get skew matrix for an ideally shaped element. | |
static void | ideal_skew_2D (EntityTopology element_type, Sample s, const PatchData &pd, MsqMatrix< 2, 2 > &W, MsqError &err) |
static void | ideal_shape_3D (EntityTopology element_type, Sample s, const PatchData &pd, MsqMatrix< 3, 3 > &W, MsqError &err) |
static void | ideal_shape_2D (EntityTopology element_type, Sample s, const PatchData &pd, MsqMatrix< 2, 2 > &W, MsqError &err) |
static MsqMatrix< 3, 3 > | new_aspect_3D (const MsqVector< 3 > &r) |
Create a new aspect ratio matrix. | |
static MsqMatrix< 2, 2 > | new_aspect_2D (const MsqVector< 2 > &r) |
static MsqMatrix< 2, 2 > | new_aspect_2D (double rho) |
static void | jacobian_3D (PatchData &pd, EntityTopology element_type, int num_nodes, Sample location, const Vector3D *coords, MsqMatrix< 3, 3 > &W_out, MsqError &err) |
Calculate the Jacobian given element vertex coordinates. | |
static void | jacobian_2D (PatchData &pd, EntityTopology element_type, int num_nodes, Sample location, const Vector3D *coords, MsqMatrix< 3, 2 > &W_out, MsqError &err) |
static void | get_refmesh_Jacobian_3D (ReferenceMeshInterface *ref_mesh, PatchData &active_mesh, size_t element_no, Sample sample_no, MsqMatrix< 3, 3 > &W_out, MsqError &err) |
static void | get_refmesh_Jacobian_2D (ReferenceMeshInterface *ref_mesh, PatchData &active_mesh, size_t element_no, Sample sample_no, MsqMatrix< 3, 2 > &W_out, MsqError &err) |
Definition at line 51 of file TargetCalculator.hpp.
MBMesquite::TargetCalculator::~TargetCalculator | ( | ) | [virtual] |
Definition at line 628 of file TargetCalculator.cpp.
MsqMatrix< 3, 3 > MBMesquite::TargetCalculator::aspect | ( | const MsqMatrix< 3, 3 > & | W | ) | [static] |
Definition at line 117 of file TargetCalculator.cpp.
References MBMesquite::cbrt(), MBMesquite::MsqMatrix< R, C >::column(), and MBMesquite::length().
Referenced by TargetCalculatorTest::test_aspect_2D(), TargetCalculatorTest::test_aspect_3D(), and TargetCalculatorTest::test_aspect_surface().
{ double a1 = length( W.column( 0 ) ); double a2 = length( W.column( 1 ) ); double a3 = length( W.column( 2 ) ); double coeff = 1.0 / MBMesquite::cbrt( a1 * a2 * a3 ); MsqMatrix< 3, 3 > result( coeff ); result( 0, 0 ) *= a1; result( 1, 1 ) *= a2; result( 2, 2 ) *= a3; return result; }
MsqMatrix< 2, 2 > MBMesquite::TargetCalculator::aspect | ( | const MsqMatrix< 3, 2 > & | W | ) | [static] |
Definition at line 131 of file TargetCalculator.cpp.
References MBMesquite::MsqMatrix< R, C >::column().
{ double a1_sqr = W.column( 0 ) % W.column( 0 ); double a2_sqr = W.column( 1 ) % W.column( 1 ); double sqrt_rho = sqrt( sqrt( a1_sqr / a2_sqr ) ); MsqMatrix< 2, 2 > result; result( 0, 0 ) = sqrt_rho; result( 0, 1 ) = 0.0; result( 1, 0 ) = 0.0; result( 1, 1 ) = 1 / sqrt_rho; return result; }
MsqMatrix< 2, 2 > MBMesquite::TargetCalculator::aspect | ( | const MsqMatrix< 2, 2 > & | W | ) | [static] |
Definition at line 145 of file TargetCalculator.cpp.
bool MBMesquite::TargetCalculator::factor_2D | ( | const MsqMatrix< 2, 2 > & | W, |
double & | Lambda, | ||
MsqMatrix< 2, 2 > & | V, | ||
MsqMatrix< 2, 2 > & | Q, | ||
MsqMatrix< 2, 2 > & | Delta, | ||
MsqError & | err | ||
) | [static] |
Utility method for subclasses to use in their implementation of get_2D_target
W | The matrix to factor |
Lambda | Output: the size factor of W V Output: the orientation factor of V |
Q | Output: the skew factor of W |
Delta | Output: the aspect ratio factor of W |
Definition at line 297 of file TargetCalculator.cpp.
References MBMesquite::MsqMatrix< R, C >::column(), MBMesquite::det(), moab::dot(), MBMesquite::length(), and MBMesquite::MsqMatrix< R, C >::set_column().
Referenced by MBMesquite::LVQDTargetCalculator::evaluate_guide_2D(), TargetCalculatorTest::test_aspect_2D(), TargetCalculatorTest::test_factor_2D(), TargetCalculatorTest::test_factor_2D_zero(), TargetCalculatorTest::test_shape_2D(), TargetCalculatorTest::test_size_2D(), and TargetCalculatorTest::test_skew_2D().
{ double alpha = det( A ); Lambda = sqrt( fabs( alpha ) ); if( Lambda < DBL_EPSILON ) return false; double la1_sqr = A.column( 0 ) % A.column( 0 ); double la1 = sqrt( la1_sqr ); double la2 = length( A.column( 1 ) ); double inv_la1 = 1.0 / la1; double dot = A.column( 0 ) % A.column( 1 ); V.set_column( 0, A.column( 0 ) * inv_la1 ); V.set_column( 1, ( la1_sqr * A.column( 1 ) - dot * A.column( 0 ) ) / ( la1 * alpha ) ); double prod_rt2 = sqrt( la1 * la2 ); Q( 0, 0 ) = prod_rt2 / Lambda; Q( 0, 1 ) = dot / ( prod_rt2 * Lambda ); Q( 1, 0 ) = 0.0; Q( 1, 1 ) = 1.0 / Q( 0, 0 ); double inv_prod_rt2 = 1.0 / prod_rt2; Delta( 0, 0 ) = la1 * inv_prod_rt2; Delta( 0, 1 ) = 0.0; Delta( 1, 0 ) = 0.0; Delta( 1, 1 ) = la2 * inv_prod_rt2; return true; }
bool MBMesquite::TargetCalculator::factor_3D | ( | const MsqMatrix< 3, 3 > & | W, |
MsqMatrix< 3, 3 > & | V, | ||
MsqMatrix< 3, 3 > & | Q, | ||
MsqMatrix< 3, 3 > & | Delta, | ||
) | [static] |
Utility method for subclasses to use in their implementation of get_3D_target.
Definition at line 216 of file TargetCalculator.cpp.
References MBMesquite::cbrt(), MBMesquite::MsqMatrix< R, C >::column(), MBMesquite::length(), and MBMesquite::MsqMatrix< R, C >::set_column().
Referenced by MBMesquite::LVQDTargetCalculator::get_3D_target(), TargetCalculatorTest::test_aspect_3D(), TargetCalculatorTest::test_factor_3D(), TargetCalculatorTest::test_factor_3D_zero(), TargetCalculatorTest::test_shape_3D(), TargetCalculatorTest::test_size_3D(), and TargetCalculatorTest::test_skew_3D().
{ MsqVector< 3 > a1xa2 = A.column( 0 ) * A.column( 1 ); double alpha = a1xa2 % A.column( 2 ); Lambda = MBMesquite::cbrt( fabs( alpha ) ); if( Lambda < DBL_EPSILON ) return false; double la1_sqr = A.column( 0 ) % A.column( 0 ); double la1 = sqrt( la1_sqr ); double la2 = length( A.column( 1 ) ); double la3 = length( A.column( 2 ) ); double lx = length( a1xa2 ); double a1dota2 = A.column( 0 ) % A.column( 1 ); double inv_la1 = 1.0 / la1; double inv_lx = 1.0 / lx; V.set_column( 0, A.column( 0 ) * inv_la1 ); V.set_column( 1, ( la1_sqr * A.column( 1 ) - a1dota2 * A.column( 0 ) ) * inv_la1 * inv_lx ); V.set_column( 2, ( alpha / ( fabs( alpha ) * lx ) ) * a1xa2 ); double inv_la2 = 1.0 / la2; double inv_la3 = 1.0 / la3; double len_prod_rt3 = MBMesquite::cbrt( la1 * la2 * la3 ); Q( 0, 0 ) = 1.0; Q( 1, 0 ) = Q( 2, 0 ) = 0.0; Q( 0, 1 ) = a1dota2 * inv_la1 * inv_la2; Q( 1, 1 ) = lx * inv_la1 * inv_la2; Q( 2, 1 ) = 0.0; Q( 0, 2 ) = ( A.column( 0 ) % A.column( 2 ) ) * inv_la1 * inv_la3; Q( 1, 2 ) = ( a1xa2 % ( A.column( 0 ) * A.column( 2 ) ) ) * inv_lx * inv_la1 * inv_la3; Q( 2, 2 ) = fabs( alpha ) * inv_lx * inv_la3; Q *= len_prod_rt3 / Lambda; double inv_prod_rt3 = 1.0 / len_prod_rt3; ; Delta( 0, 0 ) = la1 * inv_prod_rt3; Delta( 0, 1 ) = 0.0; Delta( 0, 2 ) = 0.0; Delta( 1, 0 ) = 0.0; Delta( 1, 1 ) = la2 * inv_prod_rt3; Delta( 1, 2 ) = 0.0; Delta( 2, 0 ) = 0.0; Delta( 2, 1 ) = 0.0; Delta( 2, 2 ) = la3 * inv_prod_rt3; return true; }
bool MBMesquite::TargetCalculator::factor_surface | ( | const MsqMatrix< 3, 2 > & | W, |
MsqMatrix< 3, 2 > & | V, | ||
) | [static] |
Definition at line 265 of file TargetCalculator.cpp.
References MBMesquite::MsqMatrix< R, C >::column(), moab::cross(), moab::dot(), MBMesquite::length(), and MBMesquite::MsqMatrix< R, C >::set_column().
Referenced by MBMesquite::LVQDTargetCalculator::evaluate_guide_2D(), MBMesquite::RefMeshTargetCalculator::get_2D_target(), TargetCalculatorTest::test_aspect_surface(), TargetCalculatorTest::test_factor_surface(), TargetCalculatorTest::test_factor_surface_zero(), TargetCalculatorTest::test_shape_surface(), TargetCalculatorTest::test_size_surface(), and TargetCalculatorTest::test_skew_surface().
{ MsqVector< 3 > cross = A.column( 0 ) * A.column( 1 ); double alpha = length( cross ); Lambda = sqrt( alpha ); if( Lambda < DBL_EPSILON ) return false; double la1_sqr = A.column( 0 ) % A.column( 0 ); double la1 = sqrt( la1_sqr ); double la2 = length( A.column( 1 ) ); double inv_la1 = 1.0 / la1; double dot = A.column( 0 ) % A.column( 1 ); V.set_column( 0, A.column( 0 ) * inv_la1 ); V.set_column( 1, ( la1_sqr * A.column( 1 ) - dot * A.column( 0 ) ) / ( la1 * alpha ) ); double prod_rt2 = sqrt( la1 * la2 ); Q( 0, 0 ) = prod_rt2 / Lambda; Q( 0, 1 ) = dot / ( prod_rt2 * Lambda ); Q( 1, 0 ) = 0.0; Q( 1, 1 ) = 1.0 / Q( 0, 0 ); double inv_prod_rt2 = 1.0 / prod_rt2; Delta( 0, 0 ) = la1 * inv_prod_rt2; Delta( 0, 1 ) = 0.0; Delta( 1, 0 ) = 0.0; Delta( 1, 1 ) = la2 * inv_prod_rt2; return true; }
virtual bool MBMesquite::TargetCalculator::get_2D_target | ( | PatchData & | pd, |
size_t | element, | ||
Sample | sample, | ||
MsqMatrix< 2, 2 > & | W_out, | ||
) | [pure virtual] |
pd | The current PatchData |
element | The index an element within the patch data. |
sample | The sample point in the element. |
W_out | The resulting target matrix. |
Implemented in LVQDTargetTest::TargetError, FakeTargetCalc, LVQDTargetTest::ConstantTarget, CachedTargetCalculator, IdentityTarget, MBMesquite::CachingTargetCalculator, MBMesquite::RefMeshTargetCalculator, MBMesquite::TargetReader, MBMesquite::IdealShapeTarget, MBMesquite::LVQDTargetCalculator, MBMesquite::LambdaTarget, MBMesquite::LambdaConstant, and MBMesquite::RefSizeTargetCalculator.
Referenced by MBMesquite::LVQDTargetCalculator::evaluate_guide_2D(), MBMesquite::TMPQualityMetric::evaluate_surface_common(), MBMesquite::RefSizeTargetCalculator::get_2D_target(), MBMesquite::LambdaConstant::get_2D_target(), MBMesquite::LambdaTarget::get_2D_target(), MBMesquite::TargetWriter::loop_over_mesh(), and MBMesquite::populate_data().
virtual bool MBMesquite::TargetCalculator::get_3D_target | ( | PatchData & | pd, |
MsqMatrix< 3, 3 > & | W_out, | ||
Implemented in LVQDTargetTest::TargetError, FakeTargetCalc, LVQDTargetTest::ConstantTarget, CachedTargetCalculator, IdentityTarget, MBMesquite::CachingTargetCalculator, MBMesquite::TargetReader, MBMesquite::RefMeshTargetCalculator, MBMesquite::LambdaTarget, MBMesquite::LVQDTargetCalculator, MBMesquite::LambdaConstant, MBMesquite::IdealShapeTarget, and MBMesquite::RefSizeTargetCalculator.
Referenced by MBMesquite::AffineMapMetric::evaluate(), MBMesquite::AWQualityMetric::evaluate_internal(), MBMesquite::TQualityMetric::evaluate_internal(), MBMesquite::AWQualityMetric::evaluate_with_gradient(), MBMesquite::TQualityMetric::evaluate_with_gradient(), MBMesquite::AWQualityMetric::evaluate_with_Hessian(), MBMesquite::TQualityMetric::evaluate_with_Hessian(), MBMesquite::TQualityMetric::evaluate_with_Hessian_diagonal(), MBMesquite::AWQualityMetric::evaluate_with_Hessian_diagonal(), MBMesquite::RefSizeTargetCalculator::get_3D_target(), MBMesquite::LambdaConstant::get_3D_target(), MBMesquite::LVQDTargetCalculator::get_3D_target(), MBMesquite::LambdaTarget::get_3D_target(), MBMesquite::TargetWriter::loop_over_mesh(), and MBMesquite::populate_data().
void MBMesquite::TargetCalculator::get_refmesh_Jacobian_2D | ( | ReferenceMeshInterface * | ref_mesh, |
PatchData & | active_mesh, | ||
size_t | element_no, | ||
Sample | sample_no, | ||
MsqMatrix< 3, 2 > & | W_out, | ||
) | [static] |
Definition at line 602 of file TargetCalculator.cpp.
References MBMesquite::PatchData::element_by_index(), MBMesquite::MsqMeshEntity::get_element_type(), MBMesquite::ReferenceMeshInterface::get_reference_vertex_coordinates(), MBMesquite::PatchData::get_vertex_handles_array(), MBMesquite::MsqMeshEntity::get_vertex_index_array(), jacobian_2D(), moab::MAX_NODES, MSQ_ERRRTN, n, and MBMesquite::MsqMeshEntity::node_count().
Referenced by MBMesquite::RefMeshTargetCalculator::get_surface_target(), and TargetCalculatorTest::test_get_refmesh_Jacobian_2D().
{ // get element MsqMeshEntity& elem = pd.element_by_index( element ); const EntityTopology type = elem.get_element_type(); const unsigned n = elem.node_count(); const unsigned MAX_NODES = 9; assert( n <= MAX_NODES ); // get vertices Mesh::VertexHandle elem_verts[MAX_NODES]; const std::size_t* vtx_idx = elem.get_vertex_index_array(); const Mesh::VertexHandle* vtx_hdl = pd.get_vertex_handles_array(); for( unsigned i = 0; i < n; ++i ) elem_verts[i] = vtx_hdl[vtx_idx[i]]; // get vertex coordinates Vector3D vert_coords[MAX_NODES]; ref_mesh->get_reference_vertex_coordinates( elem_verts, n, vert_coords, err );MSQ_ERRRTN( err ); // calculate Jacobian jacobian_2D( pd, type, n, sample, vert_coords, W_out, err );MSQ_ERRRTN( err ); }
void MBMesquite::TargetCalculator::get_refmesh_Jacobian_3D | ( | ReferenceMeshInterface * | ref_mesh, |
) | [static] |
Definition at line 576 of file TargetCalculator.cpp.
References MBMesquite::PatchData::element_by_index(), MBMesquite::MsqMeshEntity::get_element_type(), MBMesquite::ReferenceMeshInterface::get_reference_vertex_coordinates(), MBMesquite::PatchData::get_vertex_handles_array(), MBMesquite::MsqMeshEntity::get_vertex_index_array(), jacobian_3D(), moab::MAX_NODES, MSQ_ERRRTN, n, and MBMesquite::MsqMeshEntity::node_count().
Referenced by MBMesquite::RefMeshTargetCalculator::get_3D_target(), and TargetCalculatorTest::test_get_refmesh_Jacobian_3D().
{ // get element MsqMeshEntity& elem = pd.element_by_index( element ); const EntityTopology type = elem.get_element_type(); const unsigned n = elem.node_count(); const unsigned MAX_NODES = 27; assert( n <= MAX_NODES ); // get vertices Mesh::VertexHandle elem_verts[MAX_NODES]; const std::size_t* vtx_idx = elem.get_vertex_index_array(); const Mesh::VertexHandle* vtx_hdl = pd.get_vertex_handles_array(); for( unsigned i = 0; i < n; ++i ) elem_verts[i] = vtx_hdl[vtx_idx[i]]; // get vertex coordinates Vector3D vert_coords[MAX_NODES]; ref_mesh->get_reference_vertex_coordinates( elem_verts, n, vert_coords, err );MSQ_ERRRTN( err ); // calculate Jacobian jacobian_3D( pd, type, n, sample, vert_coords, W_out, err );MSQ_ERRRTN( err ); }
virtual bool MBMesquite::TargetCalculator::get_surface_target | ( | PatchData & | pd, |
Implemented in IdealShapeXY, LVQDTargetTest::TargetError, FakeTargetCalc, LVQDTargetTest::ConstantTarget, CachedTargetCalculator, IdentityTarget, MBMesquite::CachingTargetCalculator, MBMesquite::RefMeshTargetCalculator, MBMesquite::TargetReader, MBMesquite::LambdaTarget, MBMesquite::IdealShapeTarget, MBMesquite::LambdaConstant, MBMesquite::LVQDTargetCalculator, and MBMesquite::RefSizeTargetCalculator.
Referenced by MBMesquite::AffineMapMetric::evaluate(), MBMesquite::LVQDTargetCalculator::evaluate_guide_2D(), MBMesquite::TMPQualityMetric::evaluate_surface_common(), MBMesquite::RefSizeTargetCalculator::get_surface_target(), MBMesquite::LambdaConstant::get_surface_target(), MBMesquite::LambdaTarget::get_surface_target(), MBMesquite::TargetWriter::loop_over_mesh(), and MBMesquite::populate_data().
virtual bool MBMesquite::TargetCalculator::have_surface_orient | ( | ) | const [pure virtual] |
If true, then the targets for surface elements attempt some control of orientation and therefore get_surface_target must be used to get the targets. If false, then the target contains no orientation data and is therefore the same as the corresponding 2D target for surface elements. In this case, get_2D_target should be used.
Implemented in IdealShapeXY, LVQDTargetTest::TargetError, FakeTargetCalc, CachedTargetCalculator, LVQDTargetTest::ConstantTarget, IdentityTarget, MBMesquite::CachingTargetCalculator, MBMesquite::RefMeshTargetCalculator, MBMesquite::TargetReader, MBMesquite::IdealShapeTarget, MBMesquite::LambdaTarget, MBMesquite::LVQDTargetCalculator, MBMesquite::LambdaConstant, and MBMesquite::RefSizeTargetCalculator.
Referenced by MBMesquite::TMPQualityMetric::evaluate_surface_common(), MBMesquite::TargetWriter::get_target_tag(), MBMesquite::RefSizeTargetCalculator::have_surface_orient(), MBMesquite::LambdaConstant::have_surface_orient(), MBMesquite::LambdaTarget::have_surface_orient(), MBMesquite::CachingTargetCalculator::have_surface_orient(), MBMesquite::TargetWriter::loop_over_mesh(), and MBMesquite::populate_data().
void MBMesquite::TargetCalculator::ideal_shape_2D | ( | EntityTopology | element_type, |
Sample | s, | ||
const PatchData & | pd, | ||
MsqMatrix< 2, 2 > & | W, | ||
) | [static] |
Definition at line 467 of file TargetCalculator.cpp.
References MBMesquite::PatchData::get_mapping_function_2D(), MBMesquite::MappingFunction2D::ideal(), MBMesquite::ideal_constant_skew_I_2D(), MSQ_ERRRTN, MSQ_SETERR, shape(), and MBMesquite::MsqError::UNSUPPORTED_ELEMENT.
Referenced by MBMesquite::IdealShapeTarget::get_2D_target(), TargetCalculatorTest::test_ideal_shape_quad(), and TargetCalculatorTest::test_ideal_shape_tri().
{ if( !ideal_constant_skew_I_2D( element_type, q ) ) { const MappingFunction2D* map = pd.get_mapping_function_2D( element_type ); if( !map ) { MSQ_SETERR( err )( MsqError::UNSUPPORTED_ELEMENT ); return; } MsqMatrix< 3, 2 > J; map->ideal( s, J, err );MSQ_ERRRTN( err ); q = TargetCalculator::shape( J ); } }
void MBMesquite::TargetCalculator::ideal_shape_3D | ( | EntityTopology | element_type, |
Sample | s, | ||
MsqMatrix< 3, 3 > & | W, | ||
) | [static] |
Definition at line 451 of file TargetCalculator.cpp.
References MBMesquite::PatchData::get_mapping_function_3D(), MBMesquite::MappingFunction3D::ideal(), MBMesquite::ideal_constant_skew_I_3D(), MSQ_ERRRTN, MSQ_SETERR, shape(), and MBMesquite::MsqError::UNSUPPORTED_ELEMENT.
Referenced by MBMesquite::IdealShapeTarget::get_3D_target(), TargetCalculatorTest::test_ideal_shape_hex(), TargetCalculatorTest::test_ideal_shape_prism(), TargetCalculatorTest::test_ideal_shape_pyramid(), and TargetCalculatorTest::test_ideal_shape_tet().
{ if( !ideal_constant_skew_I_3D( element_type, q ) ) { const MappingFunction3D* map = pd.get_mapping_function_3D( element_type ); if( !map ) { MSQ_SETERR( err )( MsqError::UNSUPPORTED_ELEMENT ); return; } map->ideal( s, q, err );MSQ_ERRRTN( err ); q = TargetCalculator::shape( q ); } }
void MBMesquite::TargetCalculator::ideal_skew_2D | ( | EntityTopology | element_type, |
Sample | s, | ||
) | [static] |
Definition at line 434 of file TargetCalculator.cpp.
References MBMesquite::PatchData::get_mapping_function_2D(), MBMesquite::MappingFunction2D::ideal(), MBMesquite::ideal_constant_skew_I_2D(), MSQ_ERRRTN, MSQ_SETERR, skew(), and MBMesquite::MsqError::UNSUPPORTED_ELEMENT.
Referenced by TargetCalculatorTest::test_ideal_shape_tri(), TargetCalculatorTest::test_ideal_skew_quad(), and TargetCalculatorTest::test_ideal_skew_tri().
{ if( !ideal_constant_skew_I_2D( element_type, q ) ) { const MappingFunction2D* map = pd.get_mapping_function_2D( element_type ); if( !map ) { MSQ_SETERR( err )( MsqError::UNSUPPORTED_ELEMENT ); return; } MsqMatrix< 3, 2 > J; map->ideal( s, J, err );MSQ_ERRRTN( err ); q = TargetCalculator::skew( J ); } }
void MBMesquite::TargetCalculator::ideal_skew_3D | ( | EntityTopology | element_type, |
Sample | s, | ||
) | [static] |
Definition at line 418 of file TargetCalculator.cpp.
References MBMesquite::PatchData::get_mapping_function_3D(), MBMesquite::MappingFunction3D::ideal(), MBMesquite::ideal_constant_skew_I_3D(), MSQ_ERRRTN, MSQ_SETERR, skew(), and MBMesquite::MsqError::UNSUPPORTED_ELEMENT.
Referenced by TargetCalculatorTest::test_ideal_shape_prism(), TargetCalculatorTest::test_ideal_shape_tet(), TargetCalculatorTest::test_ideal_skew_hex(), TargetCalculatorTest::test_ideal_skew_prism(), TargetCalculatorTest::test_ideal_skew_pyramid(), and TargetCalculatorTest::test_ideal_skew_tet().
{ if( !ideal_constant_skew_I_3D( element_type, q ) ) { const MappingFunction3D* map = pd.get_mapping_function_3D( element_type ); if( !map ) { MSQ_SETERR( err )( MsqError::UNSUPPORTED_ELEMENT ); return; } map->ideal( s, q, err );MSQ_ERRRTN( err ); q = TargetCalculator::skew( q ); } }
void MBMesquite::TargetCalculator::initialize_queue | ( | MeshDomainAssoc * | mesh_and_domain, |
const Settings * | settings, | ||
) | [virtual] |
Do any preliminary global initialization, consistency checking, etc. Default implementation does nothing.
Definition at line 630 of file TargetCalculator.cpp.
Referenced by MBMesquite::TMPQualityMetric::initialize_queue().
void MBMesquite::TargetCalculator::jacobian_2D | ( | PatchData & | pd, |
EntityTopology | element_type, | ||
int | num_nodes, | ||
Sample | location, | ||
const Vector3D * | coords, | ||
) | [static] |
Definition at line 548 of file TargetCalculator.cpp.
References MBMesquite::MappingFunction2D::derivatives(), MBMesquite::PatchData::get_mapping_function_2D(), MBMesquite::get_nodeset(), moab::MAX_NODES, MSQ_ERRRTN, MSQ_SETERR, n, MBMesquite::outer(), and MBMesquite::MsqError::UNSUPPORTED_ELEMENT.
Referenced by get_refmesh_Jacobian_2D(), TargetCalculatorTest::test_get_refmesh_Jacobian_2D(), TargetCalculatorTest::test_ideal_skew_tri(), and TargetCalculatorTest::test_jacobian_2D().
{ // Get element properties NodeSet bits = get_nodeset( type, num_nodes, err );MSQ_ERRRTN( err ); const MappingFunction2D* mf = pd.get_mapping_function_2D( type ); if( !mf ) { MSQ_SETERR( err )( MsqError::UNSUPPORTED_ELEMENT ); return; } // Get mapping function derivatives const int MAX_NODES = 9; assert( num_nodes <= MAX_NODES ); size_t indices[MAX_NODES], n; MsqVector< 2 > derivs[MAX_NODES]; mf->derivatives( location, bits, indices, derivs, n, err );MSQ_ERRRTN( err ); // calculate Jacobian assert( sizeof( Vector3D ) == sizeof( MsqVector< 3 > ) ); const MsqVector< 3 >* verts = reinterpret_cast< const MsqVector< 3 >* >( coords ); assert( n > 0 ); J = outer( verts[indices[0]], derivs[0] ); for( size_t i = 1; i < n; ++i ) J += outer( verts[indices[i]], derivs[i] ); }
void MBMesquite::TargetCalculator::jacobian_3D | ( | PatchData & | pd, |
) | [static] |
Definition at line 520 of file TargetCalculator.cpp.
References MBMesquite::MappingFunction3D::derivatives(), MBMesquite::PatchData::get_mapping_function_3D(), MBMesquite::get_nodeset(), moab::MAX_NODES, MSQ_ERRRTN, MSQ_SETERR, n, MBMesquite::outer(), and MBMesquite::MsqError::UNSUPPORTED_ELEMENT.
Referenced by get_refmesh_Jacobian_3D(), TargetCalculatorTest::test_get_refmesh_Jacobian_3D(), TargetCalculatorTest::test_ideal_shape_pyramid(), TargetCalculatorTest::test_ideal_skew_prism(), TargetCalculatorTest::test_ideal_skew_pyramid(), TargetCalculatorTest::test_ideal_skew_tet(), and TargetCalculatorTest::test_jacobian_3D().
{ // Get element properties NodeSet bits = get_nodeset( type, num_nodes, err );MSQ_ERRRTN( err ); const MappingFunction3D* mf = pd.get_mapping_function_3D( type ); if( !mf ) { MSQ_SETERR( err )( MsqError::UNSUPPORTED_ELEMENT ); return; } // Get mapping function derivatives const int MAX_NODES = 27; assert( num_nodes <= MAX_NODES ); size_t indices[MAX_NODES], n; MsqVector< 3 > derivs[MAX_NODES]; mf->derivatives( location, bits, indices, derivs, n, err );MSQ_ERRRTN( err ); // calculate Jacobian assert( sizeof( Vector3D ) == sizeof( MsqVector< 3 > ) ); const MsqVector< 3 >* verts = reinterpret_cast< const MsqVector< 3 >* >( coords ); assert( n > 0 ); J = outer( verts[indices[0]], derivs[0] ); for( size_t i = 1; i < n; ++i ) J += outer( verts[indices[i]], derivs[i] ); }
MsqMatrix< 2, 2 > MBMesquite::TargetCalculator::new_aspect_2D | ( | const MsqVector< 2 > & | r | ) | [static] |
Create an aspect ratio matrix such that the ratio of column lengths is proportional to the ratio of the corresponding pair of values in the passed vector.
Definition at line 493 of file TargetCalculator.cpp.
Referenced by TargetCalculatorTest::test_new_aspect_2D().
{ return new_aspect_2D( r[0] / r[1] ); }
MsqMatrix< 2, 2 > MBMesquite::TargetCalculator::new_aspect_2D | ( | double | rho | ) | [static] |
Create an aspect ratio matrix such that the ratio of column lengths is the passed value.
Definition at line 498 of file TargetCalculator.cpp.
MsqMatrix< 2, 2 > W( sqrt( rho ) );
W( 1, 1 ) = 1.0 / W( 0, 0 );
return W;
MsqMatrix< 3, 3 > MBMesquite::TargetCalculator::new_aspect_3D | ( | const MsqVector< 3 > & | r | ) | [static] |
Definition at line 484 of file TargetCalculator.cpp.
References MBMesquite::cbrt().
Referenced by TargetCalculatorTest::test_new_aspect_3D().
{ MsqMatrix< 3, 3 > W( 0.0 ); W( 0, 0 ) = MBMesquite::cbrt( r[0] * r[0] / ( r[1] * r[2] ) ); W( 1, 1 ) = MBMesquite::cbrt( r[1] * r[1] / ( r[0] * r[2] ) ); W( 2, 2 ) = MBMesquite::cbrt( r[2] * r[2] / ( r[1] * r[0] ) ); return W; }
MsqMatrix< 3, 2 > MBMesquite::TargetCalculator::new_orientation_2D | ( | const MsqVector< 3 > & | b1, |
const MsqVector< 3 > & | b2 | ||
) | [static] |
Create an orientation matrix such that the first and second Jacobian columns of W are aligned to the passed vectors.
Definition at line 342 of file TargetCalculator.cpp.
References b1, MBMesquite::length(), and MBMesquite::MsqMatrix< R, C >::set_column().
Referenced by TargetCalculatorTest::test_new_orientatin_2D().
MsqMatrix< 3, 3 > MBMesquite::TargetCalculator::new_orientation_3D | ( | const MsqVector< 3 > & | b1, |
) | [static] |
Definition at line 328 of file TargetCalculator.cpp.
References b1, b2, moab::cross(), MBMesquite::length(), and MBMesquite::MsqMatrix< R, C >::set_column().
Referenced by TargetCalculatorTest::test_new_orientatin_3D().
{ double lb1_sqr = b1 % b1; MsqVector< 3 > cross = b1 * b2; double lb1 = sqrt( lb1_sqr ); double inv_lb1 = 1.0 / lb1; double inv_lx = 1.0 / length( cross ); MsqMatrix< 3, 3 > V; V.set_column( 0, inv_lb1 * b1 ); V.set_column( 1, ( lb1_sqr * b2 - ( b1 % b2 ) * lb1 ) * inv_lb1 * inv_lx ); V.set_column( 2, cross * inv_lx ); return V; }
MsqMatrix< 3, 3 > MBMesquite::TargetCalculator::shape | ( | const MsqMatrix< 3, 3 > & | W | ) | [static] |
Definition at line 159 of file TargetCalculator.cpp.
Referenced by ideal_shape_2D(), ideal_shape_3D(), TargetCalculatorTest::test_ideal_shape_pyramid(), TargetCalculatorTest::test_shape_2D(), TargetCalculatorTest::test_shape_3D(), and TargetCalculatorTest::test_shape_surface().
{ MsqVector< 3 > a1 = W.column( 0 ); MsqVector< 3 > a2 = W.column( 1 ); MsqVector< 3 > a3 = W.column( 2 ); MsqVector< 3 > a1xa2 = a1 * a2; double len1 = length( a1 ); double lenx = length( a1xa2 ); double alpha = fabs( a1xa2 % a3 ); double coeff = MBMesquite::cbrt( 1 / alpha ); double inv1 = 1.0 / len1; double invx = 1.0 / lenx; MsqMatrix< 3, 3 > q; q( 0, 0 ) = coeff * len1; q( 0, 1 ) = coeff * inv1 * ( a1 % a2 ); q( 0, 2 ) = coeff * inv1 * ( a1 % a3 ); q( 1, 0 ) = 0.0; q( 1, 1 ) = coeff * inv1 * lenx; q( 1, 2 ) = coeff * invx * inv1 * ( a1xa2 % ( a1 * a3 ) ); q( 2, 0 ) = 0.0; q( 2, 1 ) = 0.0; q( 2, 2 ) = coeff * alpha * invx; return q; }
MsqMatrix< 2, 2 > MBMesquite::TargetCalculator::shape | ( | const MsqMatrix< 3, 2 > & | W | ) | [static] |
Definition at line 186 of file TargetCalculator.cpp.
References MBMesquite::MsqMatrix< R, C >::column(), and MBMesquite::length().
{ double len1 = length( W.column( 0 ) ); double inv1 = 1.0 / len1; double root_alpha = sqrt( length( W.column( 0 ) * W.column( 1 ) ) ); double coeff = 1.0 / root_alpha; MsqMatrix< 2, 2 > result; result( 0, 0 ) = coeff * len1; result( 0, 1 ) = coeff * inv1 * ( W.column( 0 ) % W.column( 1 ) ); result( 1, 0 ) = 0.0; result( 1, 1 ) = root_alpha * inv1; return result; }
MsqMatrix< 2, 2 > MBMesquite::TargetCalculator::shape | ( | const MsqMatrix< 2, 2 > & | W | ) | [static] |
Definition at line 201 of file TargetCalculator.cpp.
References MBMesquite::MsqMatrix< R, C >::column(), MBMesquite::det(), and MBMesquite::length().
{ double len1 = length( W.column( 0 ) ); double inv1 = 1.0 / len1; double root_alpha = sqrt( fabs( det( W ) ) ); double coeff = 1.0 / root_alpha; MsqMatrix< 2, 2 > result; result( 0, 0 ) = coeff * len1; result( 0, 1 ) = coeff * inv1 * ( W.column( 0 ) % W.column( 1 ) ); result( 1, 0 ) = 0.0; result( 1, 1 ) = root_alpha * inv1; return result; }
double MBMesquite::TargetCalculator::size | ( | const MsqMatrix< 3, 3 > & | W | ) | [static] |
Definition at line 43 of file TargetCalculator.cpp.
References MBMesquite::cbrt(), and MBMesquite::det().
Referenced by MBMesquite::LambdaConstant::get_2D_target(), MBMesquite::LambdaConstant::get_3D_target(), MBMesquite::LambdaConstant::get_surface_target(), TargetCalculatorTest::test_size_2D(), TargetCalculatorTest::test_size_3D(), and TargetCalculatorTest::test_size_surface().
{ return MBMesquite::cbrt( fabs( det( W ) ) ); }
double MBMesquite::TargetCalculator::size | ( | const MsqMatrix< 3, 2 > & | W | ) | [static] |
Definition at line 48 of file TargetCalculator.cpp.
{ return sqrt( length( W.column( 0 ) * W.column( 1 ) ) ); }
double MBMesquite::TargetCalculator::size | ( | const MsqMatrix< 2, 2 > & | W | ) | [static] |
Definition at line 53 of file TargetCalculator.cpp.
References MBMesquite::det().
{ return sqrt( fabs( det( W ) ) ); }
MsqMatrix< 3, 3 > MBMesquite::TargetCalculator::skew | ( | const MsqMatrix< 3, 3 > & | W | ) | [static] |
Definition at line 58 of file TargetCalculator.cpp.
References MBMesquite::cbrt(), MBMesquite::MsqMatrix< R, C >::column(), moab::dot(), and MBMesquite::length().
Referenced by IdealTargetTest::get_ideal_target(), ideal_skew_2D(), ideal_skew_3D(), TargetCalculatorTest::test_ideal_skew_prism(), TargetCalculatorTest::test_ideal_skew_pyramid(), TargetCalculatorTest::test_ideal_skew_tet(), TargetCalculatorTest::test_ideal_skew_tri(), TargetCalculatorTest::test_skew_2D(), TargetCalculatorTest::test_skew_3D(), and TargetCalculatorTest::test_skew_surface().
{ MsqVector< 3 > a1 = W.column( 0 ) * ( 1.0 / length( W.column( 0 ) ) ); MsqVector< 3 > a2 = W.column( 1 ) * ( 1.0 / length( W.column( 1 ) ) ); MsqVector< 3 > a3 = W.column( 2 ) * ( 1.0 / length( W.column( 2 ) ) ); MsqVector< 3 > a1xa2 = a1 * a2; double lenx = length( a1xa2 ); double alpha = fabs( a1xa2 % a3 ); double coeff = MBMesquite::cbrt( 1 / alpha ); double dot = a1xa2 % ( a1 * a3 ); MsqMatrix< 3, 3 > q; q( 0, 0 ) = coeff; q( 0, 1 ) = coeff * ( a1 % a2 ); q( 0, 2 ) = coeff * ( a1 % a3 ); q( 1, 0 ) = 0.0; q( 1, 1 ) = coeff * lenx; q( 1, 2 ) = coeff * dot / lenx; q( 2, 0 ) = 0.0; q( 2, 1 ) = 0.0; q( 2, 2 ) = coeff * alpha / lenx; return q; }
MsqMatrix< 2, 2 > MBMesquite::TargetCalculator::skew | ( | const MsqMatrix< 3, 2 > & | W | ) | [static] |
Definition at line 83 of file TargetCalculator.cpp.
References MBMesquite::MsqMatrix< R, C >::column(), moab::dot(), and MBMesquite::length().
{ MsqVector< 3 > alpha = W.column( 0 ) * W.column( 1 ); double a1_sqr = W.column( 0 ) % W.column( 0 ); double a2_sqr = W.column( 1 ) % W.column( 1 ); double dot = W.column( 0 ) % W.column( 1 ); double a1a2 = sqrt( a1_sqr * a2_sqr ); double coeff = sqrt( a1a2 / length( alpha ) ); MsqMatrix< 2, 2 > result; result( 0, 0 ) = coeff; result( 0, 1 ) = coeff * dot / a1a2; result( 1, 0 ) = 0.0; result( 1, 1 ) = 1 / coeff; return result; }
MsqMatrix< 2, 2 > MBMesquite::TargetCalculator::skew | ( | const MsqMatrix< 2, 2 > & | W | ) | [static] |
Definition at line 100 of file TargetCalculator.cpp.
References MBMesquite::MsqMatrix< R, C >::column(), MBMesquite::det(), and moab::dot().
{ double alpha = fabs( det( W ) ); double a1_sqr = W.column( 0 ) % W.column( 0 ); double a2_sqr = W.column( 1 ) % W.column( 1 ); double dot = W.column( 0 ) % W.column( 1 ); double a1a2 = sqrt( a1_sqr * a2_sqr ); double coeff = sqrt( a1a2 / alpha ); MsqMatrix< 2, 2 > result; result( 0, 0 ) = coeff; result( 0, 1 ) = coeff * dot / a1a2; result( 1, 0 ) = 0.0; result( 1, 1 ) = 1 / coeff; return result; }
