MOAB: Mesh Oriented datABase
(version 5.2.1)
Public Member Functions | |
TargetError (bool flag_error=true, bool orient=false) | |
bool | get_3D_target (PatchData &, size_t, Sample, MsqMatrix< 3, 3 > &, MsqError &err) |
Get a target matrix. | |
bool | get_2D_target (PatchData &, size_t, Sample, MsqMatrix< 2, 2 > &, MsqError &err) |
bool | get_surface_target (PatchData &, size_t, Sample, MsqMatrix< 3, 2 > &, MsqError &err) |
virtual bool | have_surface_orient () const |
Use 3x2 W for surface elements if true, 2x2 W if false. | |
Private Attributes | |
bool | flagError |
bool | surfOrient |
Definition at line 157 of file LVQDTargetTest.cpp.
LVQDTargetTest::TargetError::TargetError | ( | bool | flag_error = true , |
bool | orient = false |
) | [inline] |
Definition at line 163 of file LVQDTargetTest.cpp.
: flagError( flag_error ), surfOrient( orient ) {}
bool LVQDTargetTest::TargetError::get_2D_target | ( | PatchData & | pd, |
size_t | element, | ||
Sample | sample, | ||
MsqMatrix< 2, 2 > & | W_out, | ||
MsqError & | err | ||
) | [inline, virtual] |
pd | The current PatchData |
element | The index an element within the patch data. |
sample | The sample point in the element. |
W_out | The resulting target matrix. |
Implements MBMesquite::TargetCalculator.
Definition at line 171 of file LVQDTargetTest.cpp.
References MBMesquite::MsqError::INVALID_MESH, and MSQ_SETERR.
{ if( flagError ) MSQ_SETERR( err )( MsqError::INVALID_MESH ); return false; }
bool LVQDTargetTest::TargetError::get_3D_target | ( | PatchData & | pd, |
MsqMatrix< 3, 3 > & | W_out, | ||
Definition at line 165 of file LVQDTargetTest.cpp.
bool LVQDTargetTest::TargetError::get_surface_target | ( | PatchData & | pd, |
MsqMatrix< 3, 2 > & | W_out, | ||
Definition at line 177 of file LVQDTargetTest.cpp.
virtual bool LVQDTargetTest::TargetError::have_surface_orient | ( | ) | const [inline, virtual] |
If true, then the targets for surface elements attempt some control of orientation and therefore get_surface_target must be used to get the targets. If false, then the target contains no orientation data and is therefore the same as the corresponding 2D target for surface elements. In this case, get_2D_target should be used.
Definition at line 183 of file LVQDTargetTest.cpp.
{ return surfOrient; }
bool LVQDTargetTest::TargetError::flagError [private] |
Definition at line 159 of file LVQDTargetTest.cpp.
bool LVQDTargetTest::TargetError::surfOrient [private] |
Definition at line 160 of file LVQDTargetTest.cpp.
