MOAB: Mesh Oriented datABase
(version 5.4.0)
00001 /* ***************************************************************** 00002 MESQUITE -- The Mesh Quality Improvement Toolkit 00003 00004 Copyright 2009 Sandia National Laboratories. Developed at the 00005 University of Wisconsin--Madison under SNL contract number 00006 624796. The U.S. Government and the University of Wisconsin 00007 retain certain rights to this software. 00008 00009 This library is free software; you can redistribute it and/or 00010 modify it under the terms of the GNU Lesser General Public 00011 License as published by the Free Software Foundation; either 00012 version 2.1 of the License, or (at your option) any later version. 00013 00014 This library is distributed in the hope that it will be useful, 00015 but WITHOUT ANY WARRANTY; without even the implied warranty of 00016 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00017 Lesser General Public License for more details. 00018 00019 You should have received a copy of the GNU Lesser General Public License 00020 (lgpl.txt) along with this library; if not, write to the Free Software 00021 Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA 00022 00023 (2009) kraftche@cae.wisc.edu 00024 00025 ***************************************************************** */ 00026 00027 /** \file TargetCalculatorTest.cpp 00028 * \brief 00029 * \author Jason Kraftcheck 00030 */ 00031 00032 #include "Mesquite.hpp" 00033 #include "UnitUtil.hpp" 00034 #include "TargetCalculator.hpp" 00035 #include "MsqError.hpp" 00036 #include "PatchData.hpp" 00037 #include "IdealElements.hpp" 00038 #include "LinearHexahedron.hpp" 00039 #include "LinearTriangle.hpp" 00040 #include "ReferenceMesh.hpp" 00041 #include <iostream> 00042 00043 using namespace MBMesquite; 00044 00045 double EPS = 0.05; 00046 double EPSBIG = 0.5; 00047 00048 class TargetCalculatorTest : public CppUnit::TestFixture 00049 { 00050 private: 00051 CPPUNIT_TEST_SUITE( TargetCalculatorTest ); 00052 00053 CPPUNIT_TEST( test_factor_2D ); 00054 CPPUNIT_TEST( test_factor_surface ); 00055 CPPUNIT_TEST( test_factor_3D ); 00056 CPPUNIT_TEST( test_factor_2D_zero ); 00057 CPPUNIT_TEST( test_factor_surface_zero ); 00058 CPPUNIT_TEST( test_factor_3D_zero ); 00059 00060 CPPUNIT_TEST( test_size_2D ); 00061 CPPUNIT_TEST( test_size_surface ); 00062 CPPUNIT_TEST( test_size_3D ); 00063 00064 CPPUNIT_TEST( test_skew_2D ); 00065 CPPUNIT_TEST( test_skew_surface ); 00066 CPPUNIT_TEST( test_skew_3D ); 00067 00068 CPPUNIT_TEST( test_aspect_2D ); 00069 CPPUNIT_TEST( test_aspect_surface ); 00070 CPPUNIT_TEST( test_aspect_3D ); 00071 00072 CPPUNIT_TEST( test_shape_2D ); 00073 CPPUNIT_TEST( test_shape_surface ); 00074 CPPUNIT_TEST( test_shape_3D ); 00075 00076 CPPUNIT_TEST( test_ideal_skew_tri ); 00077 CPPUNIT_TEST( test_ideal_skew_quad ); 00078 CPPUNIT_TEST( test_ideal_skew_tet ); 00079 CPPUNIT_TEST( test_ideal_skew_prism ); 00080 CPPUNIT_TEST( test_ideal_skew_pyramid ); 00081 CPPUNIT_TEST( test_ideal_skew_hex ); 00082 00083 CPPUNIT_TEST( test_ideal_shape_tri ); 00084 CPPUNIT_TEST( test_ideal_shape_quad ); 00085 CPPUNIT_TEST( test_ideal_shape_tet ); 00086 CPPUNIT_TEST( test_ideal_shape_prism ); 00087 CPPUNIT_TEST( test_ideal_shape_pyramid ); 00088 CPPUNIT_TEST( test_ideal_shape_hex ); 00089 00090 CPPUNIT_TEST( test_new_orientatin_3D ); 00091 CPPUNIT_TEST( test_new_orientatin_2D ); 00092 00093 CPPUNIT_TEST( test_new_aspect_3D ); 00094 CPPUNIT_TEST( test_new_aspect_2D ); 00095 00096 CPPUNIT_TEST( test_jacobian_3D ); 00097 CPPUNIT_TEST( test_jacobian_2D ); 00098 00099 CPPUNIT_TEST( test_get_refmesh_Jacobian_3D ); 00100 CPPUNIT_TEST( test_get_refmesh_Jacobian_2D ); 00101 00102 CPPUNIT_TEST_SUITE_END(); 00103 00104 // define some matrices for use in testing. 00105 MsqMatrix< 3, 3 > V3D_Z45, V3D_X90, Q3D_45, D3D_123; 00106 MsqMatrix< 3, 2 > V2D_Z45, V2D_X90; 00107 MsqMatrix< 2, 2 > Q2D_45, D2D_21; 00108 00109 public: 00110 TargetCalculatorTest(); 00111 void setUp(); 00112 00113 void test_factor_2D(); 00114 void test_factor_surface(); 00115 void test_factor_3D(); 00116 void test_factor_2D_zero(); 00117 void test_factor_surface_zero(); 00118 void test_factor_3D_zero(); 00119 00120 void test_size_2D(); 00121 void test_size_surface(); 00122 void test_size_3D(); 00123 00124 void test_skew_2D(); 00125 void test_skew_surface(); 00126 void test_skew_3D(); 00127 00128 void test_aspect_2D(); 00129 void test_aspect_surface(); 00130 void test_aspect_3D(); 00131 00132 void test_shape_2D(); 00133 void test_shape_surface(); 00134 void test_shape_3D(); 00135 00136 void test_ideal_skew_tri(); 00137 void test_ideal_skew_quad(); 00138 void test_ideal_skew_tet(); 00139 void test_ideal_skew_prism(); 00140 void test_ideal_skew_pyramid(); 00141 void test_ideal_skew_hex(); 00142 00143 void test_ideal_shape_tri(); 00144 void test_ideal_shape_quad(); 00145 void test_ideal_shape_tet(); 00146 void test_ideal_shape_prism(); 00147 void test_ideal_shape_pyramid(); 00148 void test_ideal_shape_hex(); 00149 00150 void test_new_orientatin_3D(); 00151 void test_new_orientatin_2D(); 00152 00153 void test_new_aspect_3D(); 00154 void test_new_aspect_2D(); 00155 00156 void test_jacobian_3D(); 00157 void test_jacobian_2D(); 00158 00159 void test_get_refmesh_Jacobian_3D(); 00160 void test_get_refmesh_Jacobian_2D(); 00161 00162 template < unsigned R, unsigned C > 00163 static inline void check_valid_V( MsqMatrix< R, C > V ); 00164 00165 template < unsigned D > 00166 static inline void check_valid_Q( MsqMatrix< D, D > Q ); 00167 00168 template < unsigned D > 00169 static inline void check_valid_delta( MsqMatrix< D, D > delta ); 00170 }; 00171 00172 CPPUNIT_TEST_SUITE_NAMED_REGISTRATION( TargetCalculatorTest, "TargetCalculatorTest" ); 00173 CPPUNIT_TEST_SUITE_NAMED_REGISTRATION( TargetCalculatorTest, "Unit" ); 00174 00175 TargetCalculatorTest::TargetCalculatorTest() 00176 { 00177 const double cos45 = MSQ_SQRT_TWO / 2.0; 00178 const double rotation_3D_Z45[9] = { cos45, -cos45, 0, cos45, cos45, 0, 0, 0, 1 }; 00179 const double rotation_2D_Z45[6] = { cos45, -cos45, cos45, cos45, 0, 0 }; 00180 00181 const double rotation_3D_X90[9] = { 1, 0, 0, 0, 0, -1, 0, 1, 0 }; 00182 const double rotation_2D_X90[6] = { 1, 0, 0, 0, 0, 1 }; 00183 00184 const double rc45 = sqrt( cos45 ); 00185 const double skew_2D_45[4] = { 1 / rc45, rc45, 0, rc45 }; 00186 const double skew_3D_45[9] = { 1, cos45, cos45, 0, cos45, 1 - cos45, 0, 0, sqrt( MSQ_SQRT_TWO - 1 ) }; 00187 00188 const double aspect_2D_2x[4] = { MSQ_SQRT_TWO, 0, 0, MSQ_SQRT_TWO / 2 }; 00189 const double r6 = MBMesquite::cbrt( 1.0 / 6.0 ); 00190 const double aspect_3D_123[9] = { r6, 0, 0, 0, 2 * r6, 0, 0, 0, 3 * r6 }; 00191 00192 V3D_Z45 = MsqMatrix< 3, 3 >( rotation_3D_Z45 ); 00193 V3D_X90 = MsqMatrix< 3, 3 >( rotation_3D_X90 ); 00194 Q3D_45 = MsqMatrix< 3, 3 >( skew_3D_45 ); 00195 Q3D_45 *= 1 / Mesquite::cbrt( det( Q3D_45 ) ); 00196 D3D_123 = MsqMatrix< 3, 3 >( aspect_3D_123 ); 00197 00198 V2D_Z45 = MsqMatrix< 3, 2 >( rotation_2D_Z45 ); 00199 V2D_X90 = MsqMatrix< 3, 2 >( rotation_2D_X90 ); 00200 Q2D_45 = MsqMatrix< 2, 2 >( skew_2D_45 ); 00201 D2D_21 = MsqMatrix< 2, 2 >( aspect_2D_2x ); 00202 } 00203 00204 template < unsigned R, unsigned C > 00205 inline void TargetCalculatorTest::check_valid_V( MsqMatrix< R, C > V ) 00206 { 00207 // check that it is a rotation 00208 MsqMatrix< C, C > I( 1.0 ); 00209 ASSERT_MATRICES_EQUAL( I, transpose( V ) * V, EPS ); 00210 } 00211 00212 template < unsigned D > 00213 inline void TargetCalculatorTest::check_valid_Q( MsqMatrix< D, D > Q ) 00214 { 00215 // must have unit determinant 00216 CPPUNIT_ASSERT_DOUBLES_EQUAL( 1.0, det( Q ), EPS ); 00217 00218 // must be upper-triangular 00219 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, Q( 1, 0 ), EPS ); 00220 if( D == 3 ) 00221 { 00222 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, Q( 2, 0 ), EPS ); 00223 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, Q( 2, 1 ), EPS ); 00224 } 00225 00226 // columns must be of equal length 00227 CPPUNIT_ASSERT_DOUBLES_EQUAL( length( Q.column( 0 ) ), length( Q.column( 1 ) ), EPSBIG ); 00228 if( D == 3 ) 00229 { 00230 CPPUNIT_ASSERT_DOUBLES_EQUAL( length( Q.column( 0 ) ), length( Q.column( 2 ) ), EPSBIG ); 00231 } 00232 00233 // diagonal elements must be greater than zero 00234 CPPUNIT_ASSERT( Q( 0, 0 ) - EPS >= 0.0 ); 00235 CPPUNIT_ASSERT( Q( 1, 1 ) - EPS >= 0.0 ); 00236 if( D == 3 ) 00237 { 00238 CPPUNIT_ASSERT( Q( 2, 2 ) - EPS >= 0.0 ); 00239 } 00240 } 00241 00242 template < unsigned D > 00243 inline void TargetCalculatorTest::check_valid_delta( MsqMatrix< D, D > delta ) 00244 { 00245 // must have unit determinant 00246 CPPUNIT_ASSERT_DOUBLES_EQUAL( 1.0, det( delta ), EPS ); 00247 00248 // must be diagonal 00249 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, delta( 1, 0 ), EPS ); 00250 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, delta( 0, 1 ), EPS ); 00251 if( D == 3 ) 00252 { 00253 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, delta( 2, 0 ), EPS ); 00254 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, delta( 0, 2 ), EPS ); 00255 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, delta( 1, 2 ), EPS ); 00256 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, delta( 2, 1 ), EPS ); 00257 } 00258 } 00259 00260 void TargetCalculatorTest::setUp() 00261 { 00262 // test the test: make sure we're testing with 00263 // valid matrix factors. 00264 00265 check_valid_V( V3D_Z45 ); 00266 check_valid_V( V3D_X90 ); 00267 check_valid_V( V2D_Z45 ); 00268 check_valid_V( V2D_X90 ); 00269 00270 check_valid_Q( Q3D_45 ); 00271 check_valid_Q( Q2D_45 ); 00272 00273 check_valid_delta( D3D_123 ); 00274 check_valid_delta( D2D_21 ); 00275 } 00276 00277 void TargetCalculatorTest::test_factor_2D() 00278 { 00279 MsqPrintError err( std::cout ); 00280 MsqMatrix< 2, 2 > I( 1.0 ), W, V; 00281 double lambda; 00282 MsqMatrix< 2, 2 > Q, delta; 00283 bool valid; 00284 00285 // first test with I 00286 valid = TargetCalculator::factor_2D( I, lambda, V, Q, delta, err ); 00287 CPPUNIT_ASSERT( valid && !err ); 00288 CPPUNIT_ASSERT_DOUBLES_EQUAL( 1.0, lambda, EPS ); 00289 check_valid_V( V ); 00290 check_valid_Q( Q ); 00291 check_valid_delta( delta ); 00292 W = lambda * V * Q * delta; 00293 ASSERT_MATRICES_EQUAL( I, W, EPS ); 00294 00295 // now test with 2*I 00296 valid = TargetCalculator::factor_2D( 2 * I, lambda, V, Q, delta, err ); 00297 CPPUNIT_ASSERT( valid && !err ); 00298 CPPUNIT_ASSERT_DOUBLES_EQUAL( 2.0, lambda, EPS ); 00299 check_valid_V( V ); 00300 check_valid_Q( Q ); 00301 check_valid_delta( delta ); 00302 W = lambda * V * Q * delta; 00303 ASSERT_MATRICES_EQUAL( 2 * I, W, EPS ); 00304 00305 // now rotate the matrix about the X axis by 90 degrees 00306 MsqMatrix< 2, 2 > I_rot( 0.0 ); 00307 I_rot( 0, 1 ) = 1.0; 00308 I_rot( 1, 0 ) = -1.0; 00309 valid = TargetCalculator::factor_2D( I_rot, lambda, V, Q, delta, err ); 00310 CPPUNIT_ASSERT( valid && !err ); 00311 CPPUNIT_ASSERT_DOUBLES_EQUAL( 1.0, lambda, EPS ); 00312 check_valid_V( V ); 00313 check_valid_Q( Q ); 00314 check_valid_delta( delta ); 00315 W = lambda * V * Q * delta; 00316 ASSERT_MATRICES_EQUAL( I_rot, W, EPS ); 00317 00318 // change the aspect ratio 00319 MsqMatrix< 2, 2 > A( 1.0 ); 00320 A( 1, 1 ) = 1.5; 00321 valid = TargetCalculator::factor_2D( A, lambda, V, Q, delta, err ); 00322 CPPUNIT_ASSERT( valid && !err ); 00323 CPPUNIT_ASSERT_DOUBLES_EQUAL( pow( det( transpose( A ) * A ), 0.25 ), lambda, EPS ); 00324 check_valid_V( V ); 00325 check_valid_Q( Q ); 00326 check_valid_delta( delta ); 00327 W = lambda * V * Q * delta; 00328 ASSERT_MATRICES_EQUAL( A, W, EPS ); 00329 00330 // try an arbitrary matrix 00331 double w[4] = { 3, 1, 4, 2 }; 00332 MsqMatrix< 2, 2 > W2( w ); 00333 valid = TargetCalculator::factor_2D( W2, lambda, V, Q, delta, err ); 00334 CPPUNIT_ASSERT( valid && !err ); 00335 CPPUNIT_ASSERT_DOUBLES_EQUAL( pow( det( transpose( W2 ) * W2 ), 0.25 ), lambda, EPS ); 00336 check_valid_V( V ); 00337 check_valid_Q( Q ); 00338 check_valid_delta( delta ); 00339 W = lambda * V * Q * delta; 00340 ASSERT_MATRICES_EQUAL( W2, W, EPS ); 00341 00342 // try a more elaborate test 00343 const double e = exp( (double)1 ); 00344 MsqMatrix< 2, 2 > Z45( V2D_Z45.data() ); // copy first two rows 00345 W2 = e * Z45 * Q2D_45 * D2D_21; 00346 valid = TargetCalculator::factor_2D( W2, lambda, V, Q, delta, err ); 00347 CPPUNIT_ASSERT( valid && !err ); 00348 CPPUNIT_ASSERT_DOUBLES_EQUAL( e, lambda, EPS ); 00349 ASSERT_MATRICES_EQUAL( Z45, V, EPS ); 00350 ASSERT_MATRICES_EQUAL( Q2D_45, Q, EPS ); 00351 ASSERT_MATRICES_EQUAL( D2D_21, delta, EPS ); 00352 } 00353 00354 void TargetCalculatorTest::test_factor_surface() 00355 { 00356 MsqPrintError err( std::cout ); 00357 MsqMatrix< 3, 2 > I( 1.0 ), W, V; 00358 double lambda; 00359 MsqMatrix< 2, 2 > Q, delta; 00360 bool valid; 00361 00362 // first test with I 00363 valid = TargetCalculator::factor_surface( I, lambda, V, Q, delta, err ); 00364 CPPUNIT_ASSERT( valid && !err ); 00365 CPPUNIT_ASSERT_DOUBLES_EQUAL( 1.0, lambda, EPS ); 00366 check_valid_V( V ); 00367 check_valid_Q( Q ); 00368 check_valid_delta( delta ); 00369 W = lambda * V * Q * delta; 00370 ASSERT_MATRICES_EQUAL( I, W, EPS ); 00371 00372 // now test with 2*I 00373 valid = TargetCalculator::factor_surface( 2 * I, lambda, V, Q, delta, err ); 00374 CPPUNIT_ASSERT( valid && !err ); 00375 CPPUNIT_ASSERT_DOUBLES_EQUAL( 2.0, lambda, EPS ); 00376 check_valid_V( V ); 00377 check_valid_Q( Q ); 00378 check_valid_delta( delta ); 00379 W = lambda * V * Q * delta; 00380 ASSERT_MATRICES_EQUAL( 2 * I, W, EPS ); 00381 00382 // now rotate the matrix about the X axis by 90 degrees 00383 MsqMatrix< 3, 2 > I_rot( 1.0 ); 00384 I_rot( 1, 1 ) = 0.0; 00385 I_rot( 2, 1 ) = 1.0; 00386 valid = TargetCalculator::factor_surface( I_rot, lambda, V, Q, delta, err ); 00387 CPPUNIT_ASSERT( valid && !err ); 00388 CPPUNIT_ASSERT_DOUBLES_EQUAL( 1.0, lambda, EPS ); 00389 check_valid_V( V ); 00390 check_valid_Q( Q ); 00391 check_valid_delta( delta ); 00392 W = lambda * V * Q * delta; 00393 ASSERT_MATRICES_EQUAL( I_rot, W, EPS ); 00394 00395 // change the aspect ratio 00396 MsqMatrix< 3, 2 > A( 1.0 ); 00397 A( 1, 1 ) = 1.5; 00398 valid = TargetCalculator::factor_surface( A, lambda, V, Q, delta, err ); 00399 CPPUNIT_ASSERT( valid && !err ); 00400 CPPUNIT_ASSERT_DOUBLES_EQUAL( pow( det( transpose( A ) * A ), 0.25 ), lambda, EPS ); 00401 check_valid_V( V ); 00402 check_valid_Q( Q ); 00403 check_valid_delta( delta ); 00404 W = lambda * V * Q * delta; 00405 ASSERT_MATRICES_EQUAL( A, W, EPS ); 00406 00407 // try an arbitrary matrix 00408 double w[6] = { 3, 1, 4, 2, -1, 5 }; 00409 MsqMatrix< 3, 2 > W2( w ); 00410 valid = TargetCalculator::factor_surface( W2, lambda, V, Q, delta, err ); 00411 CPPUNIT_ASSERT( valid && !err ); 00412 CPPUNIT_ASSERT_DOUBLES_EQUAL( pow( det( transpose( W2 ) * W2 ), 0.25 ), lambda, EPS ); 00413 check_valid_V( V ); 00414 check_valid_Q( Q ); 00415 check_valid_delta( delta ); 00416 W = lambda * V * Q * delta; 00417 ASSERT_MATRICES_EQUAL( W2, W, EPS ); 00418 00419 // try a more elaborate test 00420 const double e = exp( (double)1 ); 00421 W2 = e * V2D_Z45 * Q2D_45 * D2D_21; 00422 valid = TargetCalculator::factor_surface( W2, lambda, V, Q, delta, err ); 00423 CPPUNIT_ASSERT( valid && !err ); 00424 CPPUNIT_ASSERT_DOUBLES_EQUAL( e, lambda, EPS ); 00425 ASSERT_MATRICES_EQUAL( V2D_Z45, V, EPS ); 00426 ASSERT_MATRICES_EQUAL( Q2D_45, Q, EPS ); 00427 ASSERT_MATRICES_EQUAL( D2D_21, delta, EPS ); 00428 } 00429 00430 void TargetCalculatorTest::test_factor_3D() 00431 { 00432 MsqPrintError err( std::cout ); 00433 MsqMatrix< 3, 3 > I( 1.0 ), W, V, Q, delta; 00434 double lambda; 00435 bool valid; 00436 00437 // first test with I 00438 valid = TargetCalculator::factor_3D( I, lambda, V, Q, delta, err ); 00439 CPPUNIT_ASSERT( valid && !err ); 00440 CPPUNIT_ASSERT_DOUBLES_EQUAL( 1.0, lambda, EPS ); 00441 check_valid_V( V ); 00442 check_valid_Q( Q ); 00443 check_valid_delta( delta ); 00444 W = lambda * V * Q * delta; 00445 ASSERT_MATRICES_EQUAL( I, W, EPS ); 00446 00447 // now test with 2*I 00448 valid = TargetCalculator::factor_3D( 2 * I, lambda, V, Q, delta, err ); 00449 CPPUNIT_ASSERT( valid && !err ); 00450 CPPUNIT_ASSERT_DOUBLES_EQUAL( 2.0, lambda, EPS ); 00451 check_valid_V( V ); 00452 check_valid_Q( Q ); 00453 check_valid_delta( delta ); 00454 W = lambda * V * Q * delta; 00455 ASSERT_MATRICES_EQUAL( 2 * I, W, EPS ); 00456 00457 // now rotate the matrix about the X axis by 90 degrees 00458 MsqMatrix< 3, 3 > I_rot( 1.0 ); 00459 I_rot( 1, 1 ) = 0.0; 00460 I_rot( 2, 1 ) = 1.0; 00461 I_rot( 1, 2 ) = -1.0; 00462 I_rot( 2, 2 ) = 0.0; 00463 valid = TargetCalculator::factor_3D( I_rot, lambda, V, Q, delta, err ); 00464 CPPUNIT_ASSERT( valid && !err ); 00465 CPPUNIT_ASSERT_DOUBLES_EQUAL( 1.0, lambda, EPS ); 00466 check_valid_V( V ); 00467 check_valid_Q( Q ); 00468 check_valid_delta( delta ); 00469 W = lambda * V * Q * delta; 00470 ASSERT_MATRICES_EQUAL( I_rot, W, EPS ); 00471 00472 // change the aspect ratio 00473 MsqMatrix< 3, 3 > A( 1.0 ); 00474 A( 1, 1 ) = 1.5; 00475 valid = TargetCalculator::factor_3D( A, lambda, V, Q, delta, err ); 00476 CPPUNIT_ASSERT( valid && !err ); 00477 CPPUNIT_ASSERT_DOUBLES_EQUAL( MBMesquite::cbrt( det( A ) ), lambda, EPS ); 00478 check_valid_V( V ); 00479 check_valid_Q( Q ); 00480 check_valid_delta( delta ); 00481 W = lambda * V * Q * delta; 00482 ASSERT_MATRICES_EQUAL( A, W, EPS ); 00483 00484 // try an arbitrary matrix 00485 double vals[] = { 9, 8, 7, 1, 5, 4, 3, 2, 6 }; 00486 MsqMatrix< 3, 3 > W2( vals ); 00487 valid = TargetCalculator::factor_3D( W2, lambda, V, Q, delta, err ); 00488 CPPUNIT_ASSERT( valid && !err ); 00489 CPPUNIT_ASSERT_DOUBLES_EQUAL( MBMesquite::cbrt( det( W2 ) ), lambda, EPS ); 00490 check_valid_V( V ); 00491 check_valid_Q( Q ); 00492 check_valid_delta( delta ); 00493 W = lambda * V * Q * delta; 00494 ASSERT_MATRICES_EQUAL( W2, W, EPSBIG ); 00495 00496 // try a more elaborate test 00497 const double e = exp( (double)1 ); 00498 W2 = e * V3D_Z45 * Q3D_45 * D3D_123; 00499 valid = TargetCalculator::factor_3D( W2, lambda, V, Q, delta, err ); 00500 CPPUNIT_ASSERT( valid && !err ); 00501 CPPUNIT_ASSERT_DOUBLES_EQUAL( e, lambda, EPS ); 00502 ASSERT_MATRICES_EQUAL( V3D_Z45, V, EPS ); 00503 ASSERT_MATRICES_EQUAL( Q3D_45, Q, EPS ); 00504 ASSERT_MATRICES_EQUAL( D3D_123, delta, EPS ); 00505 } 00506 00507 void TargetCalculatorTest::test_factor_2D_zero() 00508 { 00509 MsqPrintError err( std::cout ); 00510 double lambda; 00511 MsqMatrix< 2, 2 > Q, delta; 00512 MsqMatrix< 2, 2 > V, Z( 0.0 ); 00513 Z( 0, 0 ) = 1.0; 00514 00515 bool valid = TargetCalculator::factor_2D( Z, lambda, V, Q, delta, err ); 00516 ASSERT_NO_ERROR( err ); 00517 CPPUNIT_ASSERT( !valid ); 00518 } 00519 00520 void TargetCalculatorTest::test_factor_surface_zero() 00521 { 00522 MsqPrintError err( std::cout ); 00523 double lambda; 00524 MsqMatrix< 2, 2 > Q, delta; 00525 MsqMatrix< 3, 2 > V, Z( 0.0 ); 00526 Z( 0, 0 ) = 1.0; 00527 00528 bool valid = TargetCalculator::factor_surface( Z, lambda, V, Q, delta, err ); 00529 ASSERT_NO_ERROR( err ); 00530 CPPUNIT_ASSERT( !valid ); 00531 } 00532 00533 void TargetCalculatorTest::test_factor_3D_zero() 00534 { 00535 MsqPrintError err( std::cout ); 00536 double lambda; 00537 MsqMatrix< 3, 3 > V, Q, delta, Z( 0.0 ); 00538 Z( 0, 0 ) = 1.0; 00539 00540 bool valid = TargetCalculator::factor_3D( Z, lambda, V, Q, delta, err ); 00541 ASSERT_NO_ERROR( err ); 00542 CPPUNIT_ASSERT( !valid ); 00543 } 00544 00545 void TargetCalculatorTest::test_size_2D() 00546 { 00547 MsqPrintError err( std::cout ); 00548 double lambda; 00549 MsqMatrix< 2, 2 > V, Q, delta; 00550 00551 MsqMatrix< 2, 2 > I( 1.0 ); 00552 TargetCalculator::factor_2D( I, lambda, V, Q, delta, err ); 00553 ASSERT_NO_ERROR( err ); 00554 CPPUNIT_ASSERT_DOUBLES_EQUAL( lambda, TargetCalculator::size( I ), EPS ); 00555 00556 double w[] = { 3, 1, 4, 2 }; 00557 MsqMatrix< 2, 2 > W( w ); 00558 TargetCalculator::factor_2D( W, lambda, V, Q, delta, err ); 00559 ASSERT_NO_ERROR( err ); 00560 CPPUNIT_ASSERT_DOUBLES_EQUAL( lambda, TargetCalculator::size( W ), EPS ); 00561 } 00562 00563 void TargetCalculatorTest::test_size_surface() 00564 { 00565 MsqPrintError err( std::cout ); 00566 double lambda; 00567 MsqMatrix< 3, 2 > V; 00568 MsqMatrix< 2, 2 > Q, delta; 00569 00570 MsqMatrix< 3, 2 > I( 1.0 ); 00571 TargetCalculator::factor_surface( I, lambda, V, Q, delta, err ); 00572 ASSERT_NO_ERROR( err ); 00573 CPPUNIT_ASSERT_DOUBLES_EQUAL( lambda, TargetCalculator::size( I ), EPS ); 00574 00575 double w[] = { 3, 1, 4, 2, -1, 5 }; 00576 MsqMatrix< 3, 2 > W( w ); 00577 TargetCalculator::factor_surface( W, lambda, V, Q, delta, err ); 00578 ASSERT_NO_ERROR( err ); 00579 CPPUNIT_ASSERT_DOUBLES_EQUAL( lambda, TargetCalculator::size( W ), EPS ); 00580 } 00581 00582 void TargetCalculatorTest::test_size_3D() 00583 { 00584 MsqPrintError err( std::cout ); 00585 double lambda; 00586 MsqMatrix< 3, 3 > V, Q, delta; 00587 00588 MsqMatrix< 3, 3 > I( 1.0 ); 00589 TargetCalculator::factor_3D( I, lambda, V, Q, delta, err ); 00590 ASSERT_NO_ERROR( err ); 00591 CPPUNIT_ASSERT_DOUBLES_EQUAL( lambda, TargetCalculator::size( I ), EPS ); 00592 00593 double w[] = { 9, 8, 7, 1, 5, 4, 3, 2, 6 }; 00594 MsqMatrix< 3, 3 > W( w ); 00595 TargetCalculator::factor_3D( W, lambda, V, Q, delta, err ); 00596 ASSERT_NO_ERROR( err ); 00597 CPPUNIT_ASSERT_DOUBLES_EQUAL( lambda, TargetCalculator::size( W ), EPS ); 00598 } 00599 00600 void TargetCalculatorTest::test_skew_2D() 00601 { 00602 MsqPrintError err( std::cout ); 00603 double lambda; 00604 MsqMatrix< 2, 2 > V, Q, delta; 00605 00606 MsqMatrix< 2, 2 > I( 1.0 ); 00607 TargetCalculator::factor_2D( I, lambda, V, Q, delta, err ); 00608 ASSERT_NO_ERROR( err ); 00609 ASSERT_MATRICES_EQUAL( Q, TargetCalculator::skew( I ), EPS ); 00610 00611 double r[] = { 0, -1, 2, 0 }; 00612 MsqMatrix< 2, 2 > R( r ); 00613 TargetCalculator::factor_2D( R, lambda, V, Q, delta, err ); 00614 ASSERT_NO_ERROR( err ); 00615 ASSERT_MATRICES_EQUAL( Q, TargetCalculator::skew( R ), EPS ); 00616 00617 double w[] = { 3, 1, 4, 2 }; 00618 MsqMatrix< 2, 2 > W( w ); 00619 TargetCalculator::factor_2D( W, lambda, V, Q, delta, err ); 00620 ASSERT_NO_ERROR( err ); 00621 ASSERT_MATRICES_EQUAL( Q, TargetCalculator::skew( W ), EPS ); 00622 00623 W = MsqMatrix< 2, 2 >( 6 ) * Q2D_45; 00624 ASSERT_MATRICES_EQUAL( Q2D_45, TargetCalculator::skew( W ), EPS ); 00625 } 00626 00627 void TargetCalculatorTest::test_skew_surface() 00628 { 00629 MsqPrintError err( std::cout ); 00630 double lambda; 00631 MsqMatrix< 3, 2 > V; 00632 MsqMatrix< 2, 2 > Q, delta; 00633 00634 MsqMatrix< 3, 2 > I( 1.0 ); 00635 TargetCalculator::factor_surface( I, lambda, V, Q, delta, err ); 00636 ASSERT_NO_ERROR( err ); 00637 ASSERT_MATRICES_EQUAL( Q, TargetCalculator::skew( I ), EPS ); 00638 00639 double r[] = { 1, 0, 0, 0, 0, 2 }; 00640 MsqMatrix< 3, 2 > R( r ); 00641 TargetCalculator::factor_surface( R, lambda, V, Q, delta, err ); 00642 ASSERT_NO_ERROR( err ); 00643 ASSERT_MATRICES_EQUAL( Q, TargetCalculator::skew( R ), EPS ); 00644 00645 double w[] = { 3, 1, 4, 2, -1, 5 }; 00646 MsqMatrix< 3, 2 > W( w ); 00647 TargetCalculator::factor_surface( W, lambda, V, Q, delta, err ); 00648 ASSERT_NO_ERROR( err ); 00649 ASSERT_MATRICES_EQUAL( Q, TargetCalculator::skew( W ), EPS ); 00650 00651 W = MsqMatrix< 3, 2 >( 6 ) * Q2D_45; 00652 ASSERT_MATRICES_EQUAL( Q2D_45, TargetCalculator::skew( W ), EPS ); 00653 } 00654 00655 void TargetCalculatorTest::test_skew_3D() 00656 { 00657 MsqPrintError err( std::cout ); 00658 double lambda; 00659 MsqMatrix< 3, 3 > V, Q, delta; 00660 00661 MsqMatrix< 3, 3 > I( 1.0 ); 00662 TargetCalculator::factor_3D( I, lambda, V, Q, delta, err ); 00663 ASSERT_NO_ERROR( err ); 00664 ASSERT_MATRICES_EQUAL( Q, TargetCalculator::skew( I ), EPS ); 00665 00666 double r[] = { 0.8, 0.0, 0.0, 0.0, 0.0, 1.13, 0.0, -0.5, 0.0 }; 00667 MsqMatrix< 3, 3 > R( r ); 00668 TargetCalculator::factor_3D( R, lambda, V, Q, delta, err ); 00669 ASSERT_NO_ERROR( err ); 00670 ASSERT_MATRICES_EQUAL( Q, TargetCalculator::skew( R ), EPS ); 00671 00672 double w[] = { 9, 8, 7, 1, 5, 4, 3, 2, 6 }; 00673 MsqMatrix< 3, 3 > W( w ); 00674 TargetCalculator::factor_3D( W, lambda, V, Q, delta, err ); 00675 ASSERT_NO_ERROR( err ); 00676 ASSERT_MATRICES_EQUAL( Q, TargetCalculator::skew( W ), 2 * EPS ); 00677 00678 W = MsqMatrix< 3, 3 >( 2.1 ) * Q3D_45; 00679 ASSERT_MATRICES_EQUAL( Q3D_45, TargetCalculator::skew( W ), EPS ); 00680 } 00681 00682 void TargetCalculatorTest::test_aspect_2D() 00683 { 00684 MsqPrintError err( std::cout ); 00685 double lambda; 00686 MsqMatrix< 2, 2 > V, Q, delta; 00687 00688 MsqMatrix< 2, 2 > I( 1.0 ); 00689 TargetCalculator::factor_2D( I, lambda, V, Q, delta, err ); 00690 ASSERT_NO_ERROR( err ); 00691 ASSERT_MATRICES_EQUAL( delta, TargetCalculator::aspect( I ), EPS ); 00692 00693 double r[] = { 0, -1, 2, 0 }; 00694 MsqMatrix< 2, 2 > R( r ); 00695 TargetCalculator::factor_2D( R, lambda, V, Q, delta, err ); 00696 ASSERT_NO_ERROR( err ); 00697 ASSERT_MATRICES_EQUAL( delta, TargetCalculator::aspect( R ), EPS ); 00698 00699 double w[] = { 3, 1, 4, 2 }; 00700 MsqMatrix< 2, 2 > W( w ); 00701 TargetCalculator::factor_2D( W, lambda, V, Q, delta, err ); 00702 ASSERT_NO_ERROR( err ); 00703 ASSERT_MATRICES_EQUAL( delta, TargetCalculator::aspect( W ), EPS ); 00704 00705 W = MsqMatrix< 2, 2 >( 6 ) * Q2D_45; 00706 ASSERT_MATRICES_EQUAL( I, TargetCalculator::aspect( W ), EPS ); 00707 } 00708 00709 void TargetCalculatorTest::test_aspect_surface() 00710 { 00711 MsqPrintError err( std::cout ); 00712 double lambda; 00713 MsqMatrix< 3, 2 > V; 00714 MsqMatrix< 2, 2 > Q, delta; 00715 00716 MsqMatrix< 3, 2 > I( 1.0 ); 00717 TargetCalculator::factor_surface( I, lambda, V, Q, delta, err ); 00718 ASSERT_NO_ERROR( err ); 00719 ASSERT_MATRICES_EQUAL( delta, TargetCalculator::aspect( I ), EPS ); 00720 00721 double r[] = { 1, 0, 0, 0, 0, 2 }; 00722 MsqMatrix< 3, 2 > R( r ); 00723 TargetCalculator::factor_surface( R, lambda, V, Q, delta, err ); 00724 ASSERT_NO_ERROR( err ); 00725 ASSERT_MATRICES_EQUAL( delta, TargetCalculator::aspect( R ), EPS ); 00726 00727 double w[] = { 3, 1, 4, 2, -1, 5 }; 00728 MsqMatrix< 3, 2 > W( w ); 00729 TargetCalculator::factor_surface( W, lambda, V, Q, delta, err ); 00730 ASSERT_NO_ERROR( err ); 00731 ASSERT_MATRICES_EQUAL( delta, TargetCalculator::aspect( W ), EPS ); 00732 00733 W = MsqMatrix< 3, 2 >( 6 ) * Q2D_45; 00734 ASSERT_MATRICES_EQUAL( ( MsqMatrix< 2, 2 >( 1.0 ) ), TargetCalculator::aspect( W ), EPS ); 00735 } 00736 00737 void TargetCalculatorTest::test_aspect_3D() 00738 { 00739 MsqPrintError err( std::cout ); 00740 double lambda; 00741 MsqMatrix< 3, 3 > V, Q, delta; 00742 00743 MsqMatrix< 3, 3 > I( 1.0 ); 00744 TargetCalculator::factor_3D( I, lambda, V, Q, delta, err ); 00745 ASSERT_NO_ERROR( err ); 00746 ASSERT_MATRICES_EQUAL( delta, TargetCalculator::aspect( I ), EPS ); 00747 00748 double r[] = { 0.8, 0.0, 0.0, 0.0, 0.0, 1.13, 0.0, -0.5, 0.0 }; 00749 MsqMatrix< 3, 3 > R( r ); 00750 TargetCalculator::factor_3D( R, lambda, V, Q, delta, err ); 00751 ASSERT_NO_ERROR( err ); 00752 ASSERT_MATRICES_EQUAL( delta, TargetCalculator::aspect( R ), EPS ); 00753 00754 double w[] = { 9, 8, 7, 1, 5, 4, 3, 2, 6 }; 00755 MsqMatrix< 3, 3 > W( w ); 00756 TargetCalculator::factor_3D( W, lambda, V, Q, delta, err ); 00757 ASSERT_NO_ERROR( err ); 00758 ASSERT_MATRICES_EQUAL( delta, TargetCalculator::aspect( W ), 2 * EPS ); 00759 00760 W = MsqMatrix< 3, 3 >( 2.1 ) * Q3D_45; 00761 ASSERT_MATRICES_EQUAL( I, TargetCalculator::aspect( W ), EPS ); 00762 } 00763 00764 void TargetCalculatorTest::test_shape_2D() 00765 { 00766 MsqPrintError err( std::cout ); 00767 double lambda; 00768 MsqMatrix< 2, 2 > V, Q, delta; 00769 00770 MsqMatrix< 2, 2 > I( 1.0 ); 00771 TargetCalculator::factor_2D( I, lambda, V, Q, delta, err ); 00772 ASSERT_NO_ERROR( err ); 00773 ASSERT_MATRICES_EQUAL( Q * delta, TargetCalculator::shape( I ), EPS ); 00774 00775 double r[] = { 0, -1, 2, 0 }; 00776 MsqMatrix< 2, 2 > R( r ); 00777 TargetCalculator::factor_2D( R, lambda, V, Q, delta, err ); 00778 ASSERT_NO_ERROR( err ); 00779 ASSERT_MATRICES_EQUAL( Q * delta, TargetCalculator::shape( R ), EPS ); 00780 00781 double w[] = { 3, 1, 4, 2 }; 00782 MsqMatrix< 2, 2 > W( w ); 00783 TargetCalculator::factor_2D( W, lambda, V, Q, delta, err ); 00784 ASSERT_NO_ERROR( err ); 00785 ASSERT_MATRICES_EQUAL( Q * delta, TargetCalculator::shape( W ), EPS ); 00786 00787 W = MsqMatrix< 2, 2 >( 6 ) * Q2D_45; 00788 ASSERT_MATRICES_EQUAL( Q2D_45, TargetCalculator::shape( W ), EPS ); 00789 } 00790 00791 void TargetCalculatorTest::test_shape_surface() 00792 { 00793 MsqPrintError err( std::cout ); 00794 double lambda; 00795 MsqMatrix< 3, 2 > V; 00796 MsqMatrix< 2, 2 > Q, delta; 00797 00798 MsqMatrix< 3, 2 > I( 1.0 ); 00799 TargetCalculator::factor_surface( I, lambda, V, Q, delta, err ); 00800 ASSERT_NO_ERROR( err ); 00801 ASSERT_MATRICES_EQUAL( Q * delta, TargetCalculator::shape( I ), EPS ); 00802 00803 double r[] = { 1, 0, 0, 0, 0, 2 }; 00804 MsqMatrix< 3, 2 > R( r ); 00805 TargetCalculator::factor_surface( R, lambda, V, Q, delta, err ); 00806 ASSERT_NO_ERROR( err ); 00807 ASSERT_MATRICES_EQUAL( Q * delta, TargetCalculator::shape( R ), EPS ); 00808 00809 double w[] = { 3, 1, 4, 2, -1, 5 }; 00810 MsqMatrix< 3, 2 > W( w ); 00811 TargetCalculator::factor_surface( W, lambda, V, Q, delta, err ); 00812 ASSERT_NO_ERROR( err ); 00813 ASSERT_MATRICES_EQUAL( Q * delta, TargetCalculator::shape( W ), EPS ); 00814 00815 W = MsqMatrix< 3, 2 >( 6 ) * Q2D_45; 00816 ASSERT_MATRICES_EQUAL( Q2D_45, TargetCalculator::shape( W ), EPS ); 00817 } 00818 00819 void TargetCalculatorTest::test_shape_3D() 00820 { 00821 MsqPrintError err( std::cout ); 00822 double lambda; 00823 MsqMatrix< 3, 3 > V, Q, delta; 00824 00825 MsqMatrix< 3, 3 > I( 1.0 ); 00826 TargetCalculator::factor_3D( I, lambda, V, Q, delta, err ); 00827 ASSERT_NO_ERROR( err ); 00828 ASSERT_MATRICES_EQUAL( Q * delta, TargetCalculator::shape( I ), EPS ); 00829 00830 double r[] = { 0.8, 0.0, 0.0, 0.0, 0.0, 1.13, 0.0, -0.5, 0.0 }; 00831 MsqMatrix< 3, 3 > R( r ); 00832 TargetCalculator::factor_3D( R, lambda, V, Q, delta, err ); 00833 ASSERT_NO_ERROR( err ); 00834 ASSERT_MATRICES_EQUAL( Q * delta, TargetCalculator::shape( R ), EPS ); 00835 00836 double w[] = { 9, 8, 7, 1, 5, 4, 3, 2, 6 }; 00837 MsqMatrix< 3, 3 > W( w ); 00838 TargetCalculator::factor_3D( W, lambda, V, Q, delta, err ); 00839 ASSERT_NO_ERROR( err ); 00840 ASSERT_MATRICES_EQUAL( Q * delta, TargetCalculator::shape( W ), 2 * EPS ); 00841 00842 W = MsqMatrix< 3, 3 >( 2.1 ) * Q3D_45; 00843 ASSERT_MATRICES_EQUAL( Q3D_45, TargetCalculator::shape( W ), EPS ); 00844 } 00845 00846 void TargetCalculatorTest::test_ideal_skew_tri() 00847 { 00848 MsqError err; 00849 PatchData pd; 00850 MsqMatrix< 2, 2 > Q, Q2; 00851 00852 TargetCalculator::ideal_skew_2D( TRIANGLE, Sample( 0, 0 ), pd, Q, err ); 00853 ASSERT_NO_ERROR( err ); 00854 check_valid_Q( Q ); 00855 00856 TargetCalculator::ideal_skew_2D( TRIANGLE, Sample( 2, 0 ), pd, Q2, err ); 00857 ASSERT_NO_ERROR( err ); 00858 ASSERT_MATRICES_EQUAL( Q, Q2, EPS ); 00859 00860 const Vector3D* coords = unit_edge_element( TRIANGLE ); 00861 MsqMatrix< 3, 2 > W; 00862 TargetCalculator::jacobian_2D( pd, TRIANGLE, 3, Sample( 0, 0 ), coords, W, err ); 00863 ASSERT_NO_ERROR( err ); 00864 Q = TargetCalculator::skew( W ); 00865 ASSERT_MATRICES_EQUAL( Q, Q2, EPS ); 00866 } 00867 00868 void TargetCalculatorTest::test_ideal_skew_quad() 00869 { 00870 MsqError err; 00871 PatchData pd; 00872 MsqMatrix< 2, 2 > Q; 00873 00874 TargetCalculator::ideal_skew_2D( QUADRILATERAL, Sample( 0, 0 ), pd, Q, err ); 00875 ASSERT_NO_ERROR( err ); 00876 ASSERT_IDENTITY_MATRIX( Q ); 00877 00878 TargetCalculator::ideal_skew_2D( QUADRILATERAL, Sample( 2, 0 ), pd, Q, err ); 00879 ASSERT_NO_ERROR( err ); 00880 ASSERT_IDENTITY_MATRIX( Q ); 00881 } 00882 00883 void TargetCalculatorTest::test_ideal_skew_tet() 00884 { 00885 MsqError err; 00886 PatchData pd; 00887 MsqMatrix< 3, 3 > Q, Q2; 00888 00889 TargetCalculator::ideal_skew_3D( TETRAHEDRON, Sample( 0, 0 ), pd, Q, err ); 00890 ASSERT_NO_ERROR( err ); 00891 check_valid_Q( Q ); 00892 00893 TargetCalculator::ideal_skew_3D( TETRAHEDRON, Sample( 3, 0 ), pd, Q2, err ); 00894 ASSERT_NO_ERROR( err ); 00895 ASSERT_MATRICES_EQUAL( Q, Q2, EPS ); 00896 00897 const Vector3D* coords = unit_edge_element( TETRAHEDRON ); 00898 MsqMatrix< 3, 3 > W; 00899 TargetCalculator::jacobian_3D( pd, TETRAHEDRON, 4, Sample( 0, 0 ), coords, W, err ); 00900 ASSERT_NO_ERROR( err ); 00901 Q = TargetCalculator::skew( W ); 00902 ASSERT_MATRICES_EQUAL( Q, Q2, EPS ); 00903 } 00904 00905 void TargetCalculatorTest::test_ideal_skew_prism() 00906 { 00907 Sample points[] = { Sample( 0, 0 ), Sample( 0, 1 ), Sample( 0, 2 ), 00908 Sample( 0, 3 ), Sample( 2, 0 ), Sample( 3, 0 ) }; 00909 const int num_pts = sizeof( points ) / sizeof( points[0] ); 00910 00911 MsqError err; 00912 PatchData pd; 00913 MsqMatrix< 3, 3 > Q, W; 00914 const Vector3D* coords = unit_edge_element( PRISM ); 00915 00916 for( int i = 0; i < num_pts; ++i ) 00917 { 00918 00919 TargetCalculator::ideal_skew_3D( PRISM, points[i], pd, Q, err ); 00920 ASSERT_NO_ERROR( err ); 00921 check_valid_Q( Q ); 00922 00923 TargetCalculator::jacobian_3D( pd, PRISM, 6, points[i], coords, W, err ); 00924 ASSERT_NO_ERROR( err ); 00925 00926 ASSERT_MATRICES_EQUAL( TargetCalculator::skew( W ), Q, EPS ); 00927 } 00928 } 00929 00930 void TargetCalculatorTest::test_ideal_skew_pyramid() 00931 { 00932 Sample points[] = { Sample( 0, 0 ), Sample( 0, 1 ), Sample( 0, 2 ), 00933 Sample( 0, 3 ), Sample( 2, 0 ), Sample( 3, 0 ) }; 00934 const int num_pts = sizeof( points ) / sizeof( points[0] ); 00935 00936 MsqError err; 00937 PatchData pd; 00938 MsqMatrix< 3, 3 > Q, W; 00939 const Vector3D* coords = unit_edge_element( PYRAMID, true ); 00940 00941 for( int i = 0; i < num_pts; ++i ) 00942 { 00943 00944 TargetCalculator::ideal_skew_3D( PYRAMID, points[i], pd, Q, err ); 00945 ASSERT_NO_ERROR( err ); 00946 check_valid_Q( Q ); 00947 00948 TargetCalculator::jacobian_3D( pd, PYRAMID, 5, points[i], coords, W, err ); 00949 ASSERT_NO_ERROR( err ); 00950 00951 ASSERT_MATRICES_EQUAL( TargetCalculator::skew( W ), Q, EPS ); 00952 } 00953 } 00954 00955 void TargetCalculatorTest::test_ideal_skew_hex() 00956 { 00957 MsqError err; 00958 PatchData pd; 00959 MsqMatrix< 3, 3 > Q; 00960 00961 TargetCalculator::ideal_skew_3D( HEXAHEDRON, Sample( 0, 0 ), pd, Q, err ); 00962 ASSERT_NO_ERROR( err ); 00963 ASSERT_IDENTITY_MATRIX( Q ); 00964 00965 TargetCalculator::ideal_skew_3D( HEXAHEDRON, Sample( 3, 0 ), pd, Q, err ); 00966 ASSERT_NO_ERROR( err ); 00967 ASSERT_IDENTITY_MATRIX( Q ); 00968 } 00969 00970 void TargetCalculatorTest::test_ideal_shape_tri() 00971 { 00972 // Ideal triangle should have Aspect (i.e. delta) == identity, 00973 // so shape should be equal to skew. 00974 00975 MsqError err; 00976 PatchData pd; 00977 MsqMatrix< 2, 2 > Q, Q2; 00978 00979 TargetCalculator::ideal_shape_2D( TRIANGLE, Sample( 0, 0 ), pd, Q, err ); 00980 ASSERT_NO_ERROR( err ); 00981 TargetCalculator::ideal_skew_2D( TRIANGLE, Sample( 0, 0 ), pd, Q2, err ); 00982 ASSERT_NO_ERROR( err ); 00983 ASSERT_MATRICES_EQUAL( Q2, Q, EPS ); 00984 00985 TargetCalculator::ideal_shape_2D( TRIANGLE, Sample( 2, 0 ), pd, Q, err ); 00986 ASSERT_NO_ERROR( err ); 00987 TargetCalculator::ideal_skew_2D( TRIANGLE, Sample( 2, 0 ), pd, Q2, err ); 00988 ASSERT_NO_ERROR( err ); 00989 ASSERT_MATRICES_EQUAL( Q2, Q, EPS ); 00990 } 00991 00992 void TargetCalculatorTest::test_ideal_shape_quad() 00993 { 00994 MsqError err; 00995 PatchData pd; 00996 MsqMatrix< 2, 2 > Q; 00997 00998 TargetCalculator::ideal_shape_2D( QUADRILATERAL, Sample( 0, 0 ), pd, Q, err ); 00999 ASSERT_NO_ERROR( err ); 01000 ASSERT_IDENTITY_MATRIX( Q ); 01001 01002 TargetCalculator::ideal_shape_2D( QUADRILATERAL, Sample( 2, 0 ), pd, Q, err ); 01003 ASSERT_NO_ERROR( err ); 01004 ASSERT_IDENTITY_MATRIX( Q ); 01005 } 01006 01007 void TargetCalculatorTest::test_ideal_shape_tet() 01008 { 01009 // Ideal tetrahedron should have Aspect (i.e. delta) == identity, 01010 // so shape should be equal to skew. 01011 01012 MsqError err; 01013 PatchData pd; 01014 MsqMatrix< 3, 3 > Q, Q2; 01015 01016 TargetCalculator::ideal_shape_3D( TETRAHEDRON, Sample( 0, 0 ), pd, Q, err ); 01017 ASSERT_NO_ERROR( err ); 01018 TargetCalculator::ideal_skew_3D( TETRAHEDRON, Sample( 0, 0 ), pd, Q2, err ); 01019 ASSERT_NO_ERROR( err ); 01020 ASSERT_MATRICES_EQUAL( Q2, Q, EPS ); 01021 01022 TargetCalculator::ideal_shape_3D( TETRAHEDRON, Sample( 3, 0 ), pd, Q, err ); 01023 ASSERT_NO_ERROR( err ); 01024 TargetCalculator::ideal_skew_3D( TETRAHEDRON, Sample( 3, 0 ), pd, Q2, err ); 01025 ASSERT_NO_ERROR( err ); 01026 ASSERT_MATRICES_EQUAL( Q2, Q, EPS ); 01027 } 01028 01029 void TargetCalculatorTest::test_ideal_shape_prism() 01030 { 01031 // Ideal wedge should have Aspect (i.e. delta) == identity, 01032 // so shape should be equal to skew. 01033 01034 Sample points[] = { Sample( 0, 0 ), Sample( 0, 1 ), Sample( 0, 2 ), 01035 Sample( 0, 3 ), Sample( 2, 0 ), Sample( 3, 0 ) }; 01036 const int num_pts = sizeof( points ) / sizeof( points[0] ); 01037 01038 MsqError err; 01039 PatchData pd; 01040 MsqMatrix< 3, 3 > Q, W; 01041 01042 for( int i = 0; i < num_pts; ++i ) 01043 { 01044 TargetCalculator::ideal_shape_3D( PRISM, points[i], pd, Q, err ); 01045 ASSERT_NO_ERROR( err ); 01046 TargetCalculator::ideal_skew_3D( PRISM, points[i], pd, W, err ); 01047 ASSERT_NO_ERROR( err ); 01048 ASSERT_MATRICES_EQUAL( W, Q, EPS ); 01049 } 01050 } 01051 01052 void TargetCalculatorTest::test_ideal_shape_pyramid() 01053 { 01054 Sample points[] = { Sample( 0, 0 ), Sample( 0, 1 ), Sample( 0, 2 ), 01055 Sample( 0, 3 ), Sample( 2, 0 ), Sample( 3, 0 ) }; 01056 const int num_pts = sizeof( points ) / sizeof( points[0] ); 01057 01058 MsqError err; 01059 PatchData pd; 01060 MsqMatrix< 3, 3 > Q, W; 01061 const Vector3D* coords = unit_edge_element( PYRAMID, true ); 01062 01063 for( int i = 0; i < num_pts; ++i ) 01064 { 01065 01066 TargetCalculator::ideal_shape_3D( PYRAMID, points[i], pd, Q, err ); 01067 ASSERT_NO_ERROR( err ); 01068 01069 TargetCalculator::jacobian_3D( pd, PYRAMID, 5, points[i], coords, W, err ); 01070 ASSERT_NO_ERROR( err ); 01071 01072 ASSERT_MATRICES_EQUAL( TargetCalculator::shape( W ), Q, EPS ); 01073 } 01074 } 01075 01076 void TargetCalculatorTest::test_ideal_shape_hex() 01077 { 01078 MsqError err; 01079 PatchData pd; 01080 MsqMatrix< 3, 3 > Q; 01081 01082 TargetCalculator::ideal_shape_3D( HEXAHEDRON, Sample( 0, 0 ), pd, Q, err ); 01083 ASSERT_NO_ERROR( err ); 01084 ASSERT_IDENTITY_MATRIX( Q ); 01085 01086 TargetCalculator::ideal_shape_3D( HEXAHEDRON, Sample( 3, 0 ), pd, Q, err ); 01087 ASSERT_NO_ERROR( err ); 01088 ASSERT_IDENTITY_MATRIX( Q ); 01089 } 01090 01091 void TargetCalculatorTest::test_new_orientatin_3D() 01092 { 01093 MsqVector< 3 > x( 0.0 ), y( 0.0 ), z( 0.0 ); 01094 x[0] = y[1] = z[2] = 1; 01095 01096 MsqMatrix< 3, 3 > V = TargetCalculator::new_orientation_3D( x, y ); 01097 check_valid_V( V ); 01098 ASSERT_MATRICES_EQUAL( z, V.column( 0 ) * V.column( 1 ), EPS ); 01099 ASSERT_MATRICES_EQUAL( z, V.column( 2 ), EPS ); 01100 } 01101 01102 void TargetCalculatorTest::test_new_orientatin_2D() 01103 { 01104 MsqVector< 3 > x( 0.0 ), y( 0.0 ), z( 0.0 ); 01105 x[0] = y[1] = z[2] = 1; 01106 01107 MsqMatrix< 3, 2 > V = TargetCalculator::new_orientation_2D( x, y ); 01108 check_valid_V( V ); 01109 ASSERT_MATRICES_EQUAL( z, V.column( 0 ) * V.column( 1 ), EPS ); 01110 } 01111 01112 void TargetCalculatorTest::test_new_aspect_3D() 01113 { 01114 MsqVector< 3 > r; 01115 r[0] = 2; 01116 r[1] = 4; 01117 r[2] = 6; 01118 MsqMatrix< 3, 3 > delta = TargetCalculator::new_aspect_3D( r ); 01119 check_valid_delta( delta ); 01120 CPPUNIT_ASSERT_DOUBLES_EQUAL( r[0] / r[1], delta( 0, 0 ) / delta( 1, 1 ), EPS ); 01121 CPPUNIT_ASSERT_DOUBLES_EQUAL( r[0] / r[2], delta( 0, 0 ) / delta( 2, 2 ), EPS ); 01122 } 01123 01124 void TargetCalculatorTest::test_new_aspect_2D() 01125 { 01126 MsqVector< 2 > r; 01127 r[0] = 7; 01128 r[1] = 3; 01129 MsqMatrix< 2, 2 > delta = TargetCalculator::new_aspect_2D( r ); 01130 check_valid_delta( delta ); 01131 CPPUNIT_ASSERT_DOUBLES_EQUAL( r[0] / r[1], delta( 0, 0 ) / delta( 1, 1 ), EPS ); 01132 } 01133 01134 void TargetCalculatorTest::test_jacobian_3D() 01135 { 01136 MsqError err; 01137 PatchData pd; 01138 LinearHexahedron map; 01139 const Vector3D hex_coords[] = { Vector3D( 0, 0, 0 ), Vector3D( 2, 0, 0 ), Vector3D( 3, 2, 0 ), 01140 Vector3D( 1, 2, 0 ), Vector3D( 1, 0, 1 ), Vector3D( 3, 0, 2 ), 01141 Vector3D( 3, 2, 2 ), Vector3D( 2, 2, 2 ) }; 01142 const MsqVector< 3 >* coords = reinterpret_cast< const MsqVector< 3 >* >( hex_coords ); 01143 01144 Sample pts[] = { Sample( 0, 0 ), Sample( 1, 6 ), Sample( 3, 0 ) }; 01145 const int num_pts = sizeof( pts ) / sizeof( pts[0] ); 01146 for( int i = 0; i < num_pts; ++i ) 01147 { 01148 MsqMatrix< 3, 3 > J( 0.0 ), W; 01149 size_t indices[8], n; 01150 MsqVector< 3 > derivs[8]; 01151 map.derivatives( pts[i], NodeSet(), indices, derivs, n, err ); 01152 ASSERT_NO_ERROR( err ); 01153 for( size_t j = 0; j < n; ++j ) 01154 J += outer( coords[indices[j]], derivs[j] ); 01155 01156 TargetCalculator::jacobian_3D( pd, HEXAHEDRON, 8, pts[i], hex_coords, W, err ); 01157 ASSERT_NO_ERROR( err ); 01158 01159 ASSERT_MATRICES_EQUAL( J, W, EPS ); 01160 } 01161 } 01162 01163 void TargetCalculatorTest::test_jacobian_2D() 01164 { 01165 MsqError err; 01166 PatchData pd; 01167 LinearTriangle map; 01168 const Vector3D tri_coords[] = { Vector3D( 0, 0, 0 ), Vector3D( 2, 0, 0 ), Vector3D( 0, 0, 1 ) }; 01169 const MsqVector< 3 >* coords = reinterpret_cast< const MsqVector< 3 >* >( tri_coords ); 01170 01171 Sample pts[] = { Sample( 0, 0 ), Sample( 1, 1 ), Sample( 2, 0 ) }; 01172 const int num_pts = sizeof( pts ) / sizeof( pts[0] ); 01173 for( int i = 0; i < num_pts; ++i ) 01174 { 01175 MsqMatrix< 3, 2 > J( 0.0 ), W; 01176 size_t indices[3], n; 01177 MsqVector< 2 > derivs[3]; 01178 map.derivatives( pts[i], NodeSet(), indices, derivs, n, err ); 01179 ASSERT_NO_ERROR( err ); 01180 for( size_t j = 0; j < n; ++j ) 01181 J += outer( coords[indices[j]], derivs[j] ); 01182 01183 TargetCalculator::jacobian_2D( pd, TRIANGLE, 3, pts[i], tri_coords, W, err ); 01184 ASSERT_NO_ERROR( err ); 01185 01186 ASSERT_MATRICES_EQUAL( J, W, EPS ); 01187 } 01188 } 01189 01190 class DummyRefMesh : public ReferenceMeshInterface 01191 { 01192 std::vector< Vector3D > mCoords; 01193 01194 public: 01195 DummyRefMesh( const Vector3D* coords, int num_verts ) : mCoords( coords, coords + num_verts ) {} 01196 01197 void get_reference_vertex_coordinates( const Mesh::VertexHandle* handles, 01198 const size_t num_vertices, 01199 Vector3D* coords, 01200 MsqError& err ) 01201 { 01202 const size_t* indices = reinterpret_cast< const size_t* >( handles ); 01203 for( size_t i = 0; i < num_vertices; ++i ) 01204 { 01205 if( i >= mCoords.size() ) 01206 { 01207 MSQ_SETERR( err )( MsqError::INVALID_ARG ); 01208 return; 01209 } 01210 coords[i] = mCoords[indices[i]]; 01211 } 01212 } 01213 }; 01214 01215 void TargetCalculatorTest::test_get_refmesh_Jacobian_3D() 01216 { 01217 MsqError err; 01218 01219 const Vector3D hex_coords[] = { Vector3D( 0, 0, 0 ), Vector3D( 2, 0, 0 ), Vector3D( 3, 2, 0 ), 01220 Vector3D( 1, 2, 0 ), Vector3D( 1, 0, 1 ), Vector3D( 3, 0, 2 ), 01221 Vector3D( 3, 2, 2 ), Vector3D( 2, 2, 2 ) }; 01222 DummyRefMesh ref_mesh( hex_coords, 8 ); 01223 01224 const Vector3D rect_coords[] = { Vector3D( 0, 0, 0 ), Vector3D( 1, 0, 0 ), Vector3D( 1, 1, 0 ), 01225 Vector3D( 0, 1, 0 ), Vector3D( 0, 0, 5 ), Vector3D( 1, 0, 5 ), 01226 Vector3D( 1, 1, 5 ), Vector3D( 0, 1, 5 ) }; 01227 size_t conn[] = { 0, 1, 2, 3, 4, 5, 6, 7 }; 01228 bool fixed[8]; 01229 std::fill( fixed, fixed + sizeof( fixed ) / sizeof( fixed[0] ), false ); 01230 PatchData pd; 01231 pd.fill( 8, rect_coords[0].to_array(), 1, HEXAHEDRON, conn, fixed, err ); 01232 ASSERT_NO_ERROR( err ); 01233 01234 Sample pts[] = { Sample( 0, 0 ), Sample( 1, 6 ), Sample( 3, 0 ) }; 01235 const int num_pts = sizeof( pts ) / sizeof( pts[0] ); 01236 for( int i = 0; i < num_pts; ++i ) 01237 { 01238 MsqMatrix< 3, 3 > J, W; 01239 TargetCalculator::jacobian_3D( pd, HEXAHEDRON, 8, pts[i], hex_coords, J, err ); 01240 ASSERT_NO_ERROR( err ); 01241 01242 TargetCalculator::get_refmesh_Jacobian_3D( &ref_mesh, pd, 0, pts[i], W, err ); 01243 ASSERT_NO_ERROR( err ); 01244 01245 ASSERT_MATRICES_EQUAL( J, W, EPS ); 01246 } 01247 } 01248 01249 void TargetCalculatorTest::test_get_refmesh_Jacobian_2D() 01250 { 01251 MsqError err; 01252 01253 const Vector3D tri_coords[] = { Vector3D( 0, 0, 0 ), Vector3D( 3, 0, 1 ), Vector3D( 1, 0, 3 ) }; 01254 DummyRefMesh ref_mesh( tri_coords, 3 ); 01255 01256 const Vector3D right_coords[] = { Vector3D( 0, 0, 0 ), Vector3D( 5, 0, 0 ), Vector3D( 5, 1, 0 ) }; 01257 size_t conn[] = { 0, 1, 2 }; 01258 bool fixed[3]; 01259 std::fill( fixed, fixed + sizeof( fixed ) / sizeof( fixed[0] ), false ); 01260 PatchData pd; 01261 pd.fill( 3, right_coords[0].to_array(), 1, TRIANGLE, conn, fixed, err ); 01262 ASSERT_NO_ERROR( err ); 01263 01264 Sample pts[] = { Sample( 0, 0 ), Sample( 1, 1 ), Sample( 2, 0 ) }; 01265 const int num_pts = sizeof( pts ) / sizeof( pts[0] ); 01266 for( int i = 0; i < num_pts; ++i ) 01267 { 01268 MsqMatrix< 3, 2 > J, W; 01269 TargetCalculator::jacobian_2D( pd, TRIANGLE, 3, pts[i], tri_coords, J, err ); 01270 ASSERT_NO_ERROR( err ); 01271 01272 TargetCalculator::get_refmesh_Jacobian_2D( &ref_mesh, pd, 0, pts[i], W, err ); 01273 ASSERT_NO_ERROR( err ); 01274 01275 ASSERT_MATRICES_EQUAL( J, W, EPS ); 01276 } 01277 }
