MOAB: Mesh Oriented datABase
(version 5.2.1)
Classes | |
class | Transform2D |
Transform from coordinates in the XY-plane to graphics coordinates. More... | |
class | Projection |
Specify a projection to use for output. More... | |
Enumerations | |
enum | Axis { X = 0, Y = 1, Z = 2 } |
Enumeration of principal coordinate axes. More... | |
Functions | |
void | write_vtk (Mesh *mesh, const char *filename, MsqError &err) |
Write mesh as a VTK file. | |
void | write_vtk (PatchData &pd, const char *out_filename, MsqError &err, const Vector3D *OF_gradient) |
void | write_gnuplot (Mesh *mesh, const char *filename, MsqError &err) |
Write mesh as gnuplot data. | |
void | write_gnuplot (Mesh *mesh, std::vector< Mesh::ElementHandle > &elems, const char *out_filebase, MsqError &err) |
void | write_gnuplot (PatchData &pd, const char *out_filebase, MsqError &err) |
static void | find_gnuplot_agregate_range (int count, const char *basename, Vector3D &min, Vector3D &max, MsqError &err) |
void | write_gnuplot_animator (int count, const char *basename, MsqError &err) |
Write animator for sequence of gnuplot data files. | |
static unsigned | red (int i, int c) |
static unsigned | green (int i, int c) |
static unsigned | blue (int i, int c) |
void | write_gnuplot_overlay (int count, const char *basename, MsqError &err) |
Write GNU plot commands to overlay a set of mesh timesteps in a single plot. | |
void | write_stl (Mesh *mesh, const char *filename, MsqError &err) |
Write STL. | |
static void | write_eps_quadratic_edge (ostream &s, Transform2D &xform, Vector3D start, Vector3D mid, Vector3D end) |
void | write_eps (Mesh *mesh, const char *filename, Projection proj, MsqError &err, int width=in2pt(6.5), int height=in2pt(9)) |
Write an Encapsulate PostScript file. | |
static double | tN0 (double r, double s) |
static double | tN1 (double r, double) |
static double | tN2 (double, double s) |
static double | tN3 (double r, double s) |
static double | tN4 (double r, double s) |
static double | tN5 (double r, double s) |
static Vector3D | quad_tri_pt (double r, double s, const Vector3D *coords) |
void | write_eps_triangle (Mesh *mesh, Mesh::ElementHandle elem, const char *filename, bool draw_iso_lines, bool draw_nodes, MsqError &err, int width=in2pt(6.5), int height=in2pt(9)) |
Write EPS file containing single triangle in XY plane. | |
void | write_eps_triangle (const Vector3D *coords, size_t num_vtx, const char *filename, bool draw_iso_lines, bool draw_nodes, MsqError &err, const std::vector< bool > &fixed, int width, int height) |
void | write_svg (Mesh *mesh, const char *filename, Projection proj, MsqError &err) |
Write an SVG file. | |
int | in2pt (float inches) |
int | cm2pt (float cm) |
Definition at line 44 of file MeshWriter.hpp.
static unsigned MBMesquite::MeshWriter::blue | ( | int | i, |
int | c | ||
) | [static] |
Definition at line 379 of file MeshWriter.cpp.
Referenced by update_density(), and write_gnuplot_overlay().
{ if( i * 4 <= c ) return 0; else if( i * 4 >= 3 * c ) return 255; else return i * 511 / c - 127; }
int MBMesquite::MeshWriter::cm2pt | ( | float | cm | ) | [inline] |
Convert centimeters to points
Definition at line 135 of file MeshWriter.hpp.
{ return (int)( cm * 72.0f / 2.54f ); }
static void MBMesquite::MeshWriter::find_gnuplot_agregate_range | ( | int | count, |
const char * | basename, | ||
Vector3D & | min, | ||
Vector3D & | max, | ||
MsqError & | err | ||
) | [static] |
Helper function for write_gnuplot_animator and write_gnuplot_overlay
Read a set of input files to determine the bounding box of the combined data.
Definition at line 273 of file MeshWriter.cpp.
References MSQ_SETERR.
Referenced by write_gnuplot_animator(), and write_gnuplot_overlay().
{ // read all input files to determine extents min = Vector3D( HUGE_VAL, HUGE_VAL, HUGE_VAL ); max = Vector3D( -HUGE_VAL, -HUGE_VAL, -HUGE_VAL ); for( int i = 0; i <= count; ++i ) { stringstream s; s << basename << '.' << i << ".gpt"; ifstream infile( s.str().c_str() ); if( !infile ) { MSQ_SETERR( err )( s.str(), MsqError::FILE_ACCESS ); return; } double c[3]; while( infile >> c[0] >> c[1] >> c[2] ) { for( int j = 0; j < 3; ++j ) { if( c[j] < min[j] ) min[j] = c[j]; if( c[j] > max[j] ) max[j] = c[j]; } } } }
static unsigned MBMesquite::MeshWriter::green | ( | int | i, |
int | c | ||
) | [static] |
Definition at line 369 of file MeshWriter.cpp.
Referenced by write_gnuplot_overlay().
{ if( i * 4 < c ) return i * 510 / c; else if( i * 4 > 3 * c ) return 1023 - i * 1023 / c; else return 255; }
int MBMesquite::MeshWriter::in2pt | ( | float | inches | ) | [inline] |
Convert inches to points
Definition at line 130 of file MeshWriter.hpp.
{ return (int)( inches * 72.0f ); }
static Vector3D MBMesquite::MeshWriter::quad_tri_pt | ( | double | r, |
double | s, | ||
const Vector3D * | coords | ||
) | [static] |
Quadratic triangle shape function for use in write_eps_triangle
Definition at line 803 of file MeshWriter.cpp.
References tN0(), tN1(), tN2(), tN3(), tN4(), and tN5().
Referenced by write_eps_triangle().
static unsigned MBMesquite::MeshWriter::red | ( | int | i, |
int | c | ||
) | [static] |
Definition at line 359 of file MeshWriter.cpp.
{ if( i * 4 <= c ) return 255; else if( i * 4 >= 3 * c ) return 0; else return 384 - i * 511 / c; }
static double MBMesquite::MeshWriter::tN0 | ( | double | r, |
double | s | ||
) | [static] |
Definition at line 775 of file MeshWriter.cpp.
References t.
Referenced by quad_tri_pt().
{ double t = 1 - r - s; return t * ( 2 * t - 1 ); }
static double MBMesquite::MeshWriter::tN1 | ( | double | r, |
double | |||
) | [static] |
Definition at line 780 of file MeshWriter.cpp.
return r * ( 2 * r - 1 );
static double MBMesquite::MeshWriter::tN2 | ( | double | , |
double | s | ||
) | [static] |
Definition at line 784 of file MeshWriter.cpp.
return s * ( 2 * s - 1 );
static double MBMesquite::MeshWriter::tN3 | ( | double | r, |
double | s | ||
) | [static] |
static double MBMesquite::MeshWriter::tN4 | ( | double | r, |
double | s | ||
) | [static] |
static double MBMesquite::MeshWriter::tN5 | ( | double | r, |
double | s | ||
) | [static] |
MESQUITE_EXPORT void MBMesquite::MeshWriter::write_eps | ( | Mesh * | mesh, |
const char * | filename, | ||
Projection | proj, | ||
MsqError & | err, | ||
int | width = in2pt(6.5) , |
int | height = in2pt(9) |
Write encapsulated postscript.
proj | - PostScript is a 2-D drawing format. This argument specifies which 2-D projection of the 3-D mesh to write. |
width | - The width of the output image, in points. |
height | - The height of the output image, in points. |
Definition at line 701 of file MeshWriter.cpp.
References MBMesquite::EdgeIterator::end(), MBMesquite::MsqError::FILE_ACCESS, MBMesquite::PatchData::fill_global_patch(), MBMesquite::EdgeIterator::is_at_end(), MBMesquite::MeshWriter::Transform2D::max_horizontal(), MBMesquite::MeshWriter::Transform2D::max_vertical(), MBMesquite::EdgeIterator::mid(), MSQ_ERRRTN, MSQ_SETERR, MBMesquite::PatchData::set_mesh(), MBMesquite::EdgeIterator::start(), MBMesquite::EdgeIterator::step(), MBMesquite::MeshWriter::Transform2D::transform(), and write_eps_quadratic_edge().
Referenced by run().
{ // Get a global patch PatchData pd; pd.set_mesh( mesh ); pd.fill_global_patch( err );MSQ_ERRRTN( err ); Transform2D transf( &pd, proj, width, height, false ); // Open the file ofstream s( filename ); if( !s ) { MSQ_SETERR( err )( MsqError::FILE_ACCESS ); return; } // Write header s << "%!PS-Adobe-2.0 EPSF-2.0" << endl; s << "%%Creator: Mesquite" << endl; s << "%%Title: Mesquite " << endl; s << "%%DocumentData: Clean7Bit" << endl; s << "%%Origin: 0 0" << endl; s << "%%BoundingBox: 0 0 " << transf.max_horizontal() << ' ' << transf.max_vertical() << endl; s << "%%Pages: 1" << endl; s << "%%BeginProlog" << endl; s << "save" << endl; s << "countdictstack" << endl; s << "mark" << endl; s << "newpath" << endl; s << "/showpage {} def" << endl; s << "/setpagedevice {pop} def" << endl; s << "%%EndProlog" << endl; s << "%%Page: 1 1" << endl; s << "1 setlinewidth" << endl; s << "0.0 setgray" << endl; // Write mesh edges EdgeIterator iter( &pd, err );MSQ_ERRRTN( err ); while( !iter.is_at_end() ) { int s_w, s_h, e_w, e_h; transf.transform( iter.start(), s_w, s_h ); transf.transform( iter.end(), e_w, e_h ); s << "newpath" << endl; s << s_w << ' ' << s_h << " moveto" << endl; if( !iter.mid() ) { s << e_w << ' ' << e_h << " lineto" << endl; } else { write_eps_quadratic_edge( s, transf, iter.start(), *iter.mid(), iter.end() ); // draw rings at mid-edge node location // transf.transform( *(iter.mid()), w1, h1 ); // s << w1+2 << ' ' << h1 << " moveto" << endl; // s << w1 << ' ' << h1 << " 2 0 360 arc" << endl; } s << "stroke" << endl; iter.step( err );MSQ_ERRRTN( err ); } // Write footer s << "%%Trailer" << endl; s << "cleartomark" << endl; s << "countdictstack" << endl; s << "exch sub { end } repeat" << endl; s << "restore" << endl; s << "%%EOF" << endl; }
static void MBMesquite::MeshWriter::write_eps_quadratic_edge | ( | ostream & | s, |
Transform2D & | xform, | ||
Vector3D | start, | ||
Vector3D | mid, | ||
Vector3D | end | ||
) | [static] |
Write quadratic edge shape in PostScript format.
Given the three points composing a quadratic mesh edge, write the cubic Bezier curve of the same shape in PostScript format. The formulas for P1 and P2 at the start of this function will result in the cubic terms of the Bezier curve dropping out, leaving the quadratic curve matching the edge shape function as described in Section 3.6 of Hughes. (If you're attempting to verify this, don't forget to adjust for the different parameter ranges: \( \xi = 2 t - 1 \)).
Definition at line 685 of file MeshWriter.cpp.
References MBMesquite::MeshWriter::Transform2D::transform().
Referenced by write_eps(), and write_eps_triangle().
{ Vector3D P1 = 1. / 3 * ( 4 * mid - end ); Vector3D P2 = 1. / 3 * ( 4 * mid - start ); int x, y; xform.transform( start, x, y ); s << x << ' ' << y << " moveto" << endl; xform.transform( P1, x, y ); s << x << ' ' << y << ' '; xform.transform( P2, x, y ); s << x << ' ' << y << ' '; xform.transform( end, x, y ); s << x << ' ' << y << " curveto" << endl; }
MESQUITE_EXPORT void MBMesquite::MeshWriter::write_eps_triangle | ( | Mesh * | mesh, |
Mesh::ElementHandle | elem, | ||
bool | draw_iso_lines, | ||
bool | draw_nodes, | ||
int | width, | ||
int | height | ||
Definition at line 814 of file MeshWriter.cpp.
References MBMesquite::arrptr(), MBMesquite::Mesh::elements_get_attached_vertices(), MBMesquite::Mesh::elements_get_topologies(), filename, fixed, MSQ_ERRRTN, MSQ_SETERR, MBMesquite::TRIANGLE, MBMesquite::MsqError::UNSUPPORTED_ELEMENT, MBMesquite::Mesh::vertices_get_coordinates(), MBMesquite::Mesh::vertices_get_fixed_flag(), and MBMesquite::width().
{ // Get triangle vertices MsqVertex coords[6]; EntityTopology type; mesh->elements_get_topologies( &elem, &type, 1, err );MSQ_ERRRTN( err ); if( type != TRIANGLE ) { MSQ_SETERR( err )( "Invalid element type", MsqError::UNSUPPORTED_ELEMENT ); return; } std::vector< Mesh::VertexHandle > verts; std::vector< size_t > junk; mesh->elements_get_attached_vertices( &elem, 1, verts, junk, err );MSQ_ERRRTN( err ); if( verts.size() != 3 && verts.size() != 6 ) { MSQ_SETERR( err )( "Invalid element type", MsqError::UNSUPPORTED_ELEMENT ); return; } mesh->vertices_get_coordinates( arrptr( verts ), coords, verts.size(), err );MSQ_ERRRTN( err ); Vector3D coords2[6]; std::copy( coords, coords + verts.size(), coords2 ); std::vector< bool > fixed( verts.size(), false ); if( draw_nodes ) { mesh->vertices_get_fixed_flag( arrptr( verts ), fixed, verts.size(), err );MSQ_ERRRTN( err ); } write_eps_triangle( coords2, verts.size(), filename, draw_iso_lines, draw_nodes, err, fixed, width, height ); }
MESQUITE_EXPORT void MBMesquite::MeshWriter::write_eps_triangle | ( | const Vector3D * | coords, |
size_t | num_vtx, | ||
const std::vector< bool > & | fixed, | ||
int | width, | ||
int | height | ||
Definition at line 847 of file MeshWriter.cpp.
References MBMesquite::MsqError::FILE_ACCESS, MBMesquite::MeshWriter::Transform2D::max_horizontal(), MBMesquite::MeshWriter::Transform2D::max_vertical(), MSQ_SETERR, quad_tri_pt(), moab::R, t, T, MBMesquite::MeshWriter::Transform2D::transform(), write_eps_quadratic_edge(), X, and Y.
{ const int PT_RAD = 3; // radius of circles for drawing nodes, in points const int PAD = PT_RAD + 2; // margin in points const double EDGE_GRAY = 0.0; // color for triangle edges, 0.0 => black const double ISO_GRAY = 0.7; // color for parameter iso-lines const double NODE_GRAY = 0.0; // color for node circle const double FIXED_GRAY = 1.0; // color to fill fixed nodes with, 1.0 => white const double FREE_GRAY = 0.0; // color to fill free nodes with Projection proj( X, Y ); Transform2D transf( coords, num_vtx, proj, width, height ); // Open the file ofstream str( filename ); if( !str ) { MSQ_SETERR( err )( MsqError::FILE_ACCESS ); return; } // Write header str << "%!PS-Adobe-2.0 EPSF-2.0" << endl; str << "%%Creator: Mesquite" << endl; str << "%%Title: Mesquite " << endl; str << "%%DocumentData: Clean7Bit" << endl; str << "%%Origin: 0 0" << endl; str << "%%BoundingBox: " << -PAD << ' ' << -PAD << ' ' << transf.max_horizontal() + PAD << ' ' << transf.max_vertical() + PAD << endl; str << "%%Pages: 1" << endl; str << "%%BeginProlog" << endl; str << "save" << endl; str << "countdictstack" << endl; str << "mark" << endl; str << "newpath" << endl; str << "/showpage {} def" << endl; str << "/setpagedevice {pop} def" << endl; str << "%%EndProlog" << endl; str << "%%Page: 1 1" << endl; str << "1 setlinewidth" << endl; str << EDGE_GRAY << " setgray" << endl; const double h = 0.5, t = 1.0 / 3.0, w = 2.0 / 3.0, s = 1. / 6, f = 5. / 6; const int NUM_ISO = 15; const double iso_params[NUM_ISO][2][2] = { { { h, 0 }, { h, h } }, // r = 1/2 { { t, 0 }, { t, w } }, // r = 1/3 { { w, 0 }, { w, t } }, // r = 2/3 { { s, 0 }, { s, f } }, // r = 1/6 { { f, 0 }, { f, s } }, // r = 5/6 { { 0, h }, { h, h } }, // s = 1/2 { { 0, t }, { w, t } }, // s = 1/3 { { 0, w }, { t, w } }, // s = 2/3 { { 0, s }, { f, s } }, // s = 1/6 { { 0, f }, { s, f } }, // s = 5/6 { { 0, h }, { h, 0 } }, // t = 1 - r - s = 1/2 { { 0, w }, { w, 0 } }, // t = 1 - r - s = 1/3 { { 0, t }, { t, 0 } }, // t = 1 - r - s = 2/3 { { 0, f }, { f, 0 } }, // t = 1 - r - s = 1/6 { { 0, s }, { s, 0 } } // t = 1 - r - s = 5/6 }; if( num_vtx == 3 ) { int x[3], y[3]; for( size_t i = 0; i < 3; ++i ) transf.transform( coords[i], x[i], y[i] ); str << "newpath" << endl; str << x[0] << ' ' << y[0] << " moveto" << endl; str << x[1] << ' ' << y[1] << " lineto" << endl; str << x[2] << ' ' << y[2] << " lineto" << endl; str << x[0] << ' ' << y[0] << " lineto" << endl; str << "stroke" << endl; if( draw_iso_lines ) { str << ISO_GRAY << " setgray" << endl; str << "newpath" << endl; for( int i = 0; i < NUM_ISO; ++i ) { double R[2] = { iso_params[i][0][0], iso_params[i][1][0] }; double S[2] = { iso_params[i][0][1], iso_params[i][1][1] }; double T[2] = { 1 - R[0] - S[0], 1 - R[1] - S[1] }; Vector3D p[2] = { T[0] * coords[0] + R[0] * coords[1] + S[0] * coords[2], T[1] * coords[0] + R[1] * coords[1] + S[1] * coords[2] }; transf.transform( p[0], x[0], y[0] ); transf.transform( p[1], x[1], y[1] ); str << x[0] << ' ' << y[0] << " moveto" << endl; str << x[1] << ' ' << y[1] << " lineto" << endl; } str << " stroke" << endl; } } else if( num_vtx == 6 ) { str << "newpath" << endl; write_eps_quadratic_edge( str, transf, coords[0], coords[3], coords[1] ); write_eps_quadratic_edge( str, transf, coords[1], coords[4], coords[2] ); write_eps_quadratic_edge( str, transf, coords[2], coords[5], coords[0] ); str << "stroke" << endl; if( draw_iso_lines ) { str << ISO_GRAY << " setgray" << endl; str << "newpath" << endl; for( int i = 0; i < NUM_ISO; ++i ) { double R[3] = { iso_params[i][0][0], 0, iso_params[i][1][0] }; double S[3] = { iso_params[i][0][1], 0, iso_params[i][1][1] }; R[1] = 0.5 * ( R[0] + R[2] ); S[1] = 0.5 * ( S[0] + S[2] ); Vector3D p[3] = { quad_tri_pt( R[0], S[0], coords ), quad_tri_pt( R[1], S[1], coords ), quad_tri_pt( R[2], S[2], coords ) }; write_eps_quadratic_edge( str, transf, p[0], p[1], p[2] ); } str << " stroke" << endl; } } if( draw_nodes ) { for( size_t i = 0; i < num_vtx; ++i ) { int iw, ih; // fill interior with either white or black depending // on whether or not the vertex is fixed. if( fixed[i] ) str << FIXED_GRAY << " setgray" << endl; else str << FREE_GRAY << " setgray" << endl; transf.transform( coords[i], iw, ih ); str << w + PT_RAD << ' ' << ih << " moveto" << endl; str << iw << ' ' << ih << ' ' << PT_RAD << " 0 360 arc" << endl; str << "closepath fill" << endl; str << NODE_GRAY << " setgray" << endl; str << "newpath" << endl; str << iw << ' ' << ih << ' ' << PT_RAD << " 0 360 arc" << endl; str << "stroke" << endl; } } // Write footer str << "%%Trailer" << endl; str << "cleartomark" << endl; str << "countdictstack" << endl; str << "exch sub { end } repeat" << endl; str << "restore" << endl; str << "%%EOF" << endl; }
MESQUITE_EXPORT void MBMesquite::MeshWriter::write_gnuplot | ( | Mesh * | mesh, |
Write a file that can be drawn in gnuplot with the command: "plot 'filename' with lines"
Definition at line 200 of file MeshWriter.cpp.
References MBMesquite::PatchData::fill_global_patch(), MSQ_ERRRTN, MBMesquite::PatchData::set_mesh(), and write_gnuplot().
{ // loads a global patch PatchData pd; pd.set_mesh( mesh ); pd.fill_global_patch( err );MSQ_ERRRTN( err ); write_gnuplot( pd, out_filebase, err ); }
std::vector< Mesh::ElementHandle > & | elems, | ||
const char * | out_filebase, | ||
Definition at line 209 of file MeshWriter.cpp.
References MSQ_ERRRTN, MBMesquite::PatchData::set_mesh(), MBMesquite::PatchData::set_mesh_entities(), and write_gnuplot().
{ // loads a global patch PatchData pd; pd.set_mesh( mesh ); std::vector< Mesh::VertexHandle > verts; pd.set_mesh_entities( elems, verts, err );MSQ_ERRRTN( err ); write_gnuplot( pd, out_filebase, err ); }
MESQUITE_EXPORT void MBMesquite::MeshWriter::write_gnuplot | ( | PatchData & | pd, |
Definition at line 233 of file MeshWriter.cpp.
References edges, MBMesquite::EdgeIterator::end(), MBMesquite::EdgeIterator::is_at_end(), MBMesquite::EdgeIterator::mid(), MSQ_ERRRTN, MSQ_SETERR, MBMesquite::EdgeIterator::start(), and MBMesquite::EdgeIterator::step().
{ // Open the file std::string out_filename = out_filebase; out_filename += ".gpt"; std::ofstream file( out_filename.c_str() ); if( !file ) { MSQ_SETERR( err )( MsqError::FILE_ACCESS ); return; } EdgeIterator edges( &pd, err );MSQ_ERRRTN( err ); // Write a header file << "\n"; while( !edges.is_at_end() ) { const Vector3D& s = edges.start(); const Vector3D& e = edges.end(); const Vector3D* m = edges.mid(); file << s[0] << ' ' << s[1] << ' ' << s[2] << std::endl; if( m ) file << ( *m )[0] << ' ' << ( *m )[1] << ' ' << ( *m )[2] << std::endl; file << e[0] << ' ' << e[1] << ' ' << e[2] << std::endl; file << std::endl << std::endl; edges.step( err );MSQ_ERRRTN( err ); } // Close the file file.close(); }
MESQUITE_EXPORT void MBMesquite::MeshWriter::write_gnuplot_animator | ( | int | count, |
Write a GNU Plot script to produce an animation from a sequence of data files
Given a set of files named foo.0.gpt, foo.1.gpt, ... foo.n.gpt, write a file foo.gnuplot that produces an animation of the data by calling write_gnuplot_animator( n, foo, err );
Definition at line 304 of file MeshWriter.cpp.
References find_gnuplot_agregate_range(), HEIGHT, MSQ_ERRRTN, MSQ_SETERR, and WIDTH.
{ if( count <= 0 ) return; const int DELAY = 10; const int WIDTH = 640; const int HEIGHT = 480; // read all input files to determine extents Vector3D min, max; find_gnuplot_agregate_range( count, basename, min, max, err );MSQ_ERRRTN( err ); // chose coordinate plane to plot in Vector3D range = max - min; int haxis = 0, vaxis = 1; if( range[0] < range[1] && range[1] < range[2] ) { haxis = 1; vaxis = 2; } else if( range[1] < range[2] ) { vaxis = 2; } // open output file string base( basename ); ofstream file( ( string( basename ) + ".gnuplot" ).c_str() ); if( !file ) { MSQ_SETERR( err )( MsqError::FILE_ACCESS ); return; } // write header file << "#!gnuplot" << endl; file << "#" << endl; file << "# Mesquite Animation of " << basename << ".0 to " << basename << '.' << count << endl; file << "#" << endl; // write plot settings file << "set term gif animate transparent opt delay " << DELAY << " size " << WIDTH << "," << HEIGHT << endl; file << "set xrange [" << min[haxis] - 0.05 * range[haxis] << ":" << max[haxis] + 0.05 * range[haxis] << "]" << endl; file << "set yrange [" << min[vaxis] - 0.05 * range[vaxis] << ":" << max[vaxis] + 0.05 * range[vaxis] << "]" << endl; file << "set title '" << basename << "'" << endl; file << "set output '" << basename << ".gif'" << endl; // plot data for( int i = 0; i <= count; ++i ) file << "plot '" << basename << '.' << i << ".gpt'" << " using " << haxis + 1 << ":" << vaxis + 1 << " w l" << endl; }
MESQUITE_EXPORT void MBMesquite::MeshWriter::write_gnuplot_overlay | ( | int | count, |
Write a GNU Plot script to produce a single plot from a sequence of data files
Given a set of files named foo.0.gpt, foo.1.gpt, ... foo.n.gpt, write a file foo.gnuplot that produces an overlay of the meshes in each file by calling write_gnuplot_animator( n, foo, err );
Definition at line 392 of file MeshWriter.cpp.
References blue(), find_gnuplot_agregate_range(), green(), HEIGHT, MSQ_ERRRTN, MSQ_SETERR, red(), and WIDTH.
Referenced by MBMesquite::TerminationCriterion::terminate().
{ if( count <= 0 ) return; const int WIDTH = 640; const int HEIGHT = 480; // read all input files to determine extents Vector3D min, max; find_gnuplot_agregate_range( count, basename, min, max, err );MSQ_ERRRTN( err ); // chose coordinate plane to plot in Vector3D range = max - min; int haxis = 0, vaxis = 1; if( range[0] < range[1] && range[1] < range[2] ) { haxis = 1; vaxis = 2; } else if( range[1] < range[2] ) { vaxis = 2; } // open output file string base( basename ); FILE* file = fopen( ( string( basename ) + ".gnuplot" ).c_str(), "w" ); if( !file ) { MSQ_SETERR( err )( MsqError::FILE_ACCESS ); return; } // write header fprintf( file, "#!gnuplot\n" ); fprintf( file, "#\n" ); fprintf( file, "# Mesquite Overlay of %s.0 to %s.%d\n", basename, basename, count ); fprintf( file, "#\n" ); // write plot settings fprintf( file, "set term gif size %d,%d\n", WIDTH, HEIGHT ); fprintf( file, "set xrange [%f:%f]\n", min[haxis] - 0.05 * range[haxis], max[haxis] + 0.05 * range[haxis] ); fprintf( file, "set yrange [%f:%f]\n", min[vaxis] - 0.05 * range[vaxis], max[vaxis] + 0.05 * range[vaxis] ); fprintf( file, "set title '%s'\n", basename ); fprintf( file, "set output '%s.gif'\n", basename ); // plot data fprintf( file, "plot '%s.0.gpt' using %d:%d w l lc rgb '#%02x%02x%02x' title 't0'", basename, haxis + 1, vaxis + 1, red( 0, count ), green( 0, count ), blue( 0, count ) ); for( int i = 1; i <= count; ++i ) { fprintf( file, ", \\\n '%s.%d.gpt' using %d:%d w l lc rgb '#%02x%02x%02x' title 't%d'", basename, i, haxis + 1, vaxis + 1, red( i, count ), green( i, count ), blue( i, count ), i ); } fprintf( file, "\n" ); fclose( file ); }
MESQUITE_EXPORT void MBMesquite::MeshWriter::write_stl | ( | Mesh * | mesh, |
Write STL.
Write the mesh as an ASCII STL (Stereo Lithography) file. The STL format only supports writing triangles. This writer will write only the triangles contained in the passed mesh. Any non-triangle elements will be ignored.
Definition at line 451 of file MeshWriter.cpp.
References MBMesquite::arrptr(), MBMesquite::Mesh::elements_get_attached_vertices(), MBMesquite::Mesh::elements_get_topologies(), MBMesquite::Mesh::get_all_elements(), MSQ_ERRRTN, MSQ_SETERR, n, MBMesquite::Vector3D::normalize(), MBMesquite::TRIANGLE, MBMesquite::Mesh::vertices_get_coordinates(), MBMesquite::Vector3D::x(), MBMesquite::Vector3D::y(), and MBMesquite::Vector3D::z().
{ // Open the file ofstream file( filename ); if( !file ) { MSQ_SETERR( err )( MsqError::FILE_ACCESS ); return; } // Write header char header[70]; sprintf( header, "Mesquite%d", rand() ); file << "solid " << header << endl; MsqVertex coords[3]; std::vector< Mesh::VertexHandle > verts( 3 ); std::vector< size_t > offsets( 2 ); // Iterate over all elements size_t count = 0; std::vector< Mesh::ElementHandle > elems; std::vector< Mesh::ElementHandle >::iterator iter; mesh->get_all_elements( elems, err );MSQ_ERRRTN( err ); for( iter = elems.begin(); iter != elems.end(); ++iter ) { // Skip non-triangles Mesh::ElementHandle elem = *iter; EntityTopology type; mesh->elements_get_topologies( &elem, &type, 1, err );MSQ_ERRRTN( err ); if( type != TRIANGLE ) continue; ++count; // Get vertex coordinates mesh->elements_get_attached_vertices( &elem, 1, verts, offsets, err );MSQ_ERRRTN( err ); mesh->vertices_get_coordinates( arrptr( verts ), coords, 3, err );MSQ_ERRRTN( err ); // Get triagnle normal Vector3D n = ( coords[0] - coords[1] ) * ( coords[0] - coords[2] ); n.normalize(); // Write triangle file << "facet normal " << n.x() << " " << n.y() << " " << n.z() << endl; file << "outer loop" << endl; for( unsigned i = 0; i < 3; ++i ) file << "vertex " << coords[i].x() << " " << coords[i].y() << " " << coords[i].z() << endl; file << "endloop" << endl; file << "endfacet" << endl; } file << "endsolid " << header << endl; file.close(); if( count == 0 ) { std::remove( filename ); MSQ_SETERR( err )( "Mesh contains no triangles", MsqError::INVALID_STATE ); } }
MESQUITE_EXPORT void MBMesquite::MeshWriter::write_svg | ( | Mesh * | mesh, |
Write an SVG file.
Write a 2-D projection of the mesh to a Scalable Vector Graphics file. (W3C standard).
proj | - SVG is a 2-D drawing format. This argument specifies which 2-D projection of the 3-D mesh to write. |
Definition at line 1001 of file MeshWriter.cpp.
References MBMesquite::EdgeIterator::end(), MBMesquite::MsqError::FILE_ACCESS, MBMesquite::PatchData::fill_global_patch(), MBMesquite::EdgeIterator::is_at_end(), MBMesquite::MeshWriter::Transform2D::max_horizontal(), MBMesquite::MeshWriter::Transform2D::max_vertical(), MSQ_ERRRTN, MSQ_SETERR, MBMesquite::PatchData::set_mesh(), MBMesquite::EdgeIterator::start(), MBMesquite::EdgeIterator::step(), and MBMesquite::MeshWriter::Transform2D::transform().
{ // Get a global patch PatchData pd; pd.set_mesh( mesh ); pd.fill_global_patch( err );MSQ_ERRRTN( err ); Transform2D transf( &pd, proj, 400, 400, true ); // Open the file ofstream file( filename ); if( !file ) { MSQ_SETERR( err )( MsqError::FILE_ACCESS ); return; } // Write header file << "<?xml version=\"1.0\" standalone=\"no\"?>" << endl; file << "<!DOCTYPE svg PUBLIC \"-//W3C//DTD SVG 1.1//EN\" " << "\"http://www.w3.org/Graphics/SVG/1.1/DTD/svg11.dtd\">" << endl; file << endl; file << "<svg width=\"" << transf.max_horizontal() << "\" height=\"" << transf.max_vertical() << "\" version=\"1.1\" xmlns=\"http://www.w3.org/2000/svg\">" << endl; // Write mesh edges EdgeIterator iter( &pd, err );MSQ_ERRRTN( err ); while( !iter.is_at_end() ) { int s_w, s_h, e_w, e_h; transf.transform( iter.start(), s_w, s_h ); transf.transform( iter.end(), e_w, e_h ); file << "<line " << "x1=\"" << s_w << "\" " << "y1=\"" << s_h << "\" " << "x2=\"" << e_w << "\" " << "y2=\"" << e_h << "\" " << " style=\"stroke:rgb(99,99,99);stroke-width:2\"" << "/>" << endl; iter.step( err );MSQ_ERRRTN( err ); } // Write footer file << "</svg>" << endl; }
MESQUITE_EXPORT void MBMesquite::MeshWriter::write_vtk | ( | Mesh * | mesh, |
Write a simple VTK file for viewing. The file written by this function is intended for viewing. It contains only a minimal decription of the mesh. It does not contain other data such as tags/attributes. If the Mesh is a MeshImpl, use the VTK writing function provided in MeshImpl for a complete mesh export.
Definition at line 94 of file MeshWriter.cpp.
References MBMesquite::PatchData::fill_global_patch(), MSQ_CHKERR, MSQ_ERRRTN, MBMesquite::PatchData::set_mesh(), and write_vtk.
Referenced by main(), run(), run_global_smoother(), and run_local_smoother().
{ if( MeshImpl* msq_mesh = dynamic_cast< MeshImpl* >( mesh ) ) { msq_mesh->write_vtk( out_filename, err );MSQ_CHKERR( err ); return; } // loads a global patch PatchData pd; pd.set_mesh( mesh ); pd.fill_global_patch( err );MSQ_ERRRTN( err ); // write mesh write_vtk( pd, out_filename, err );MSQ_CHKERR( err ); }
MESQUITE_EXPORT void MBMesquite::MeshWriter::write_vtk | ( | PatchData & | pd, |
const char * | out_filename, | ||
const Vector3D * | OF_gradient | ||
Definition at line 111 of file MeshWriter.cpp.
References MBMesquite::PatchData::element_by_index(), MBMesquite::MsqMeshEntity::get_element_type(), MBMesquite::MsqVertex::get_flags(), MBMesquite::MsqMeshEntity::get_node_indices(), MBMesquite::MsqVertex::is_free_vertex(), MBMesquite::VtkTypeInfo::mesquiteToVtkOrder(), MSQ_ERRRTN, MSQ_SETERR, MBMesquite::MsqMeshEntity::node_count(), MBMesquite::PatchData::num_elements(), MBMesquite::PatchData::num_free_vertices(), MBMesquite::PatchData::num_nodes(), MBMesquite::PatchData::vertex_by_index(), MBMesquite::VtkTypeInfo::vtkType, MBMesquite::Vector3D::y(), and MBMesquite::Vector3D::z().
{ // Open the file std::ofstream file( out_filename ); if( !file ) { MSQ_SETERR( err )( MsqError::FILE_ACCESS ); return; } // Write a header file << "# vtk DataFile Version 2.0\n"; file << "Mesquite Mesh " << out_filename << " .\n"; file << "ASCII\n"; file << "DATASET UNSTRUCTURED_GRID\n"; // Write vertex coordinates file << "POINTS " << pd.num_nodes() << " float\n"; size_t i; for( i = 0; i < pd.num_nodes(); i++ ) { file << pd.vertex_by_index( i )[0] << ' ' << pd.vertex_by_index( i )[1] << ' ' << pd.vertex_by_index( i )[2] << '\n'; } // Write out the connectivity table size_t connectivity_size = 0; for( i = 0; i < pd.num_elements(); ++i ) connectivity_size += pd.element_by_index( i ).node_count() + 1; file << "CELLS " << pd.num_elements() << ' ' << connectivity_size << '\n'; for( i = 0; i < pd.num_elements(); i++ ) { std::vector< size_t > vtx_indices; pd.element_by_index( i ).get_node_indices( vtx_indices ); // Convert native to VTK node order, if not the same const VtkTypeInfo* info = VtkTypeInfo::find_type( pd.element_by_index( i ).get_element_type(), vtx_indices.size(), err );MSQ_ERRRTN( err ); info->mesquiteToVtkOrder( vtx_indices ); file << vtx_indices.size(); for( std::size_t j = 0; j < vtx_indices.size(); ++j ) { file << ' ' << vtx_indices[j]; } file << '\n'; } // Write out the element types file << "CELL_TYPES " << pd.num_elements() << '\n'; for( i = 0; i < pd.num_elements(); i++ ) { const VtkTypeInfo* info = VtkTypeInfo::find_type( pd.element_by_index( i ).get_element_type(), pd.element_by_index( i ).node_count(), err );MSQ_ERRRTN( err ); file << info->vtkType << '\n'; } // Write out which points are fixed. file << "POINT_DATA " << pd.num_nodes() << "\nSCALARS fixed int\nLOOKUP_TABLE default\n"; for( i = 0; i < pd.num_nodes(); ++i ) { if( pd.vertex_by_index( i ).get_flags() & MsqVertex::MSQ_CULLED ) file << "1\n"; else file << "0\n"; } file << "SCALARS culled short\nLOOKUP_TABLE default\n"; for( i = 0; i < pd.num_nodes(); ++i ) { if( pd.vertex_by_index( i ).is_free_vertex() ) file << "0\n"; else file << "1\n"; } if( OF_gradient ) { file << "VECTORS gradient double\n"; for( i = 0; i < pd.num_free_vertices(); ++i ) file << OF_gradient[i].x() << " " << OF_gradient[i].y() << " " << OF_gradient[i].z() << "\n"; for( i = pd.num_free_vertices(); i < pd.num_nodes(); ++i ) file << "0.0 0.0 0.0\n"; } // Close the file file.close(); }
