TargetCalculatorTest Class Reference
+ Inheritance diagram for TargetCalculatorTest:
+ Collaboration diagram for TargetCalculatorTest:
Public Member Functions
 TargetCalculatorTest ()
void setUp ()
void test_factor_2D ()
void test_factor_surface ()
void test_factor_3D ()
void test_factor_2D_zero ()
void test_factor_surface_zero ()
void test_factor_3D_zero ()
void test_size_2D ()
void test_size_surface ()
void test_size_3D ()
void test_skew_2D ()
void test_skew_surface ()
void test_skew_3D ()
void test_aspect_2D ()
void test_aspect_surface ()
void test_aspect_3D ()
void test_shape_2D ()
void test_shape_surface ()
void test_shape_3D ()
void test_ideal_skew_tri ()
void test_ideal_skew_quad ()
void test_ideal_skew_tet ()
void test_ideal_skew_prism ()
void test_ideal_skew_pyramid ()
void test_ideal_skew_hex ()
void test_ideal_shape_tri ()
void test_ideal_shape_quad ()
void test_ideal_shape_tet ()
void test_ideal_shape_prism ()
void test_ideal_shape_pyramid ()
void test_ideal_shape_hex ()
void test_new_orientatin_3D ()
void test_new_orientatin_2D ()
void test_new_aspect_3D ()
void test_new_aspect_2D ()
void test_jacobian_3D ()
void test_jacobian_2D ()
void test_get_refmesh_Jacobian_3D ()
void test_get_refmesh_Jacobian_2D ()
Static Public Member Functions
template<unsigned R, unsigned C>
static void check_valid_V (MsqMatrix< R, C > V)
template<unsigned D>
static void check_valid_Q (MsqMatrix< D, D > Q)
static void check_valid_delta (MsqMatrix< D, D > delta)
Private Member Functions
 CPPUNIT_TEST_SUITE (TargetCalculatorTest)
 CPPUNIT_TEST (test_factor_2D)
 CPPUNIT_TEST (test_factor_surface)
 CPPUNIT_TEST (test_factor_3D)
 CPPUNIT_TEST (test_factor_2D_zero)
 CPPUNIT_TEST (test_factor_surface_zero)
 CPPUNIT_TEST (test_factor_3D_zero)
 CPPUNIT_TEST (test_size_2D)
 CPPUNIT_TEST (test_size_surface)
 CPPUNIT_TEST (test_size_3D)
 CPPUNIT_TEST (test_skew_2D)
 CPPUNIT_TEST (test_skew_surface)
 CPPUNIT_TEST (test_skew_3D)
 CPPUNIT_TEST (test_aspect_2D)
 CPPUNIT_TEST (test_aspect_surface)
 CPPUNIT_TEST (test_aspect_3D)
 CPPUNIT_TEST (test_shape_2D)
 CPPUNIT_TEST (test_shape_surface)
 CPPUNIT_TEST (test_shape_3D)
 CPPUNIT_TEST (test_ideal_skew_tri)
 CPPUNIT_TEST (test_ideal_skew_quad)
 CPPUNIT_TEST (test_ideal_skew_tet)
 CPPUNIT_TEST (test_ideal_skew_prism)
 CPPUNIT_TEST (test_ideal_skew_pyramid)
 CPPUNIT_TEST (test_ideal_skew_hex)
 CPPUNIT_TEST (test_ideal_shape_tri)
 CPPUNIT_TEST (test_ideal_shape_quad)
 CPPUNIT_TEST (test_ideal_shape_tet)
 CPPUNIT_TEST (test_ideal_shape_prism)
 CPPUNIT_TEST (test_ideal_shape_pyramid)
 CPPUNIT_TEST (test_ideal_shape_hex)
 CPPUNIT_TEST (test_new_orientatin_3D)
 CPPUNIT_TEST (test_new_orientatin_2D)
 CPPUNIT_TEST (test_new_aspect_3D)
 CPPUNIT_TEST (test_new_aspect_2D)
 CPPUNIT_TEST (test_jacobian_3D)
 CPPUNIT_TEST (test_jacobian_2D)
 CPPUNIT_TEST (test_get_refmesh_Jacobian_3D)
 CPPUNIT_TEST (test_get_refmesh_Jacobian_2D)
 CPPUNIT_TEST_SUITE_END ()
Private Attributes
MsqMatrix< 3, 3 > V3D_Z45
MsqMatrix< 3, 3 > V3D_X90
MsqMatrix< 3, 3 > Q3D_45
MsqMatrix< 3, 3 > D3D_123
MsqMatrix< 3, 2 > V2D_Z45
MsqMatrix< 3, 2 > V2D_X90
MsqMatrix< 2, 2 > Q2D_45
MsqMatrix< 2, 2 > D2D_21
Detailed Description
Definition at line 48 of file TargetCalculatorTest.cpp.
Definition at line 175 of file TargetCalculatorTest.cpp.
References MBMesquite::cbrt(), MBMesquite::det(), and MBMesquite::MSQ_SQRT_TWO.
    const double cos45              = MSQ_SQRT_TWO / 2.0;
    const double rotation_3D_Z45[9] = { cos45, -cos45, 0, cos45, cos45, 0, 0, 0, 1 };
    const double rotation_2D_Z45[6] = { cos45, -cos45, cos45, cos45, 0, 0 };
    const double rotation_3D_X90[9] = { 1, 0, 0, 0, 0, -1, 0, 1, 0 };
    const double rotation_2D_X90[6] = { 1, 0, 0, 0, 0, 1 };
    const double rc45          = sqrt( cos45 );
    const double skew_2D_45[4] = { 1 / rc45, rc45, 0, rc45 };
    const double skew_3D_45[9] = { 1, cos45, cos45, 0, cos45, 1 - cos45, 0, 0, sqrt( MSQ_SQRT_TWO - 1 ) };
    const double aspect_2D_2x[4]  = { MSQ_SQRT_TWO, 0, 0, MSQ_SQRT_TWO / 2 };
    const double r6               = MBMesquite::cbrt( 1.0 / 6.0 );
    const double aspect_3D_123[9] = { r6, 0, 0, 0, 2 * r6, 0, 0, 0, 3 * r6 };
    V3D_Z45 = MsqMatrix< 3, 3 >( rotation_3D_Z45 );
    V3D_X90 = MsqMatrix< 3, 3 >( rotation_3D_X90 );
    Q3D_45  = MsqMatrix< 3, 3 >( skew_3D_45 );
    Q3D_45 *= 1 / Mesquite::cbrt( det( Q3D_45 ) );
    D3D_123 = MsqMatrix< 3, 3 >( aspect_3D_123 );
    V2D_Z45 = MsqMatrix< 3, 2 >( rotation_2D_Z45 );
    V2D_X90 = MsqMatrix< 3, 2 >( rotation_2D_X90 );
    Q2D_45  = MsqMatrix< 2, 2 >( skew_2D_45 );
    D2D_21  = MsqMatrix< 2, 2 >( aspect_2D_2x );
Member Function Documentation
void TargetCalculatorTest::check_valid_delta ( MsqMatrix< D, D >  delta) [inline, static]
Definition at line 243 of file TargetCalculatorTest.cpp.
References CPPUNIT_ASSERT_DOUBLES_EQUAL, MBMesquite::det(), and EPS.
    // must have unit determinant
    CPPUNIT_ASSERT_DOUBLES_EQUAL( 1.0, det( delta ), EPS );
    // must be diagonal
    CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, delta( 1, 0 ), EPS );
    CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, delta( 0, 1 ), EPS );
    if( D == 3 )
        CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, delta( 2, 0 ), EPS );
        CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, delta( 0, 2 ), EPS );
        CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, delta( 1, 2 ), EPS );
        CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, delta( 2, 1 ), EPS );
void TargetCalculatorTest::check_valid_Q ( MsqMatrix< D, D >  Q) [inline, static]
Definition at line 213 of file TargetCalculatorTest.cpp.
References MBMesquite::MsqMatrix< R, C >::column(), CPPUNIT_ASSERT, CPPUNIT_ASSERT_DOUBLES_EQUAL, MBMesquite::det(), EPS, EPSBIG, and MBMesquite::length().
    CPPUNIT_ASSERT_DOUBLES_EQUAL( 1.0, det( Q ), EPS );
    // must be upper-triangular
    CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, Q( 1, 0 ), EPS );
    if( D == 3 )
        CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, Q( 2, 0 ), EPS );
        CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, Q( 2, 1 ), EPS );
    // columns must be of equal length
    CPPUNIT_ASSERT_DOUBLES_EQUAL( length( Q.column( 0 ) ), length( Q.column( 1 ) ), EPSBIG );
    if( D == 3 )
        CPPUNIT_ASSERT_DOUBLES_EQUAL( length( Q.column( 0 ) ), length( Q.column( 2 ) ), EPSBIG );
    // diagonal elements must be greater than zero
    CPPUNIT_ASSERT( Q( 0, 0 ) - EPS >= 0.0 );
    CPPUNIT_ASSERT( Q( 1, 1 ) - EPS >= 0.0 );
    if( D == 3 )
        CPPUNIT_ASSERT( Q( 2, 2 ) - EPS >= 0.0 );
void TargetCalculatorTest::check_valid_V ( MsqMatrix< R, C V) [inline, static]
Definition at line 205 of file TargetCalculatorTest.cpp.
References ASSERT_MATRICES_EQUAL, EPS, and MBMesquite::transpose().
    // check that it is a rotation
    MsqMatrix< C, C > I( 1.0 );
    ASSERT_MATRICES_EQUAL( I, transpose( V ) * V, EPS );
Definition at line 260 of file TargetCalculatorTest.cpp.
    // test the test: make sure we're testing with
    // valid matrix factors.
    check_valid_V( V3D_Z45 );
    check_valid_V( V3D_X90 );
    check_valid_V( V2D_Z45 );
    check_valid_V( V2D_X90 );
    check_valid_Q( Q3D_45 );
    check_valid_Q( Q2D_45 );
    check_valid_delta( D3D_123 );
    check_valid_delta( D2D_21 );
Definition at line 682 of file TargetCalculatorTest.cpp.
References MBMesquite::TargetCalculator::aspect(), ASSERT_MATRICES_EQUAL, ASSERT_NO_ERROR, EPS, MBMesquite::TargetCalculator::factor_2D(), and moab::R.
    MsqPrintError err( std::cout );
    double lambda;
    MsqMatrix< 2, 2 > V, Q, delta;
    MsqMatrix< 2, 2 > I( 1.0 );
    TargetCalculator::factor_2D( I, lambda, V, Q, delta, err );
    ASSERT_NO_ERROR( err );
    ASSERT_MATRICES_EQUAL( delta, TargetCalculator::aspect( I ), EPS );
    double r[] = { 0, -1, 2, 0 };
    MsqMatrix< 2, 2 > R( r );
    TargetCalculator::factor_2D( R, lambda, V, Q, delta, err );
    ASSERT_MATRICES_EQUAL( delta, TargetCalculator::aspect( R ), EPS );
    double w[] = { 3, 1, 4, 2 };
    MsqMatrix< 2, 2 > W( w );
    TargetCalculator::factor_2D( W, lambda, V, Q, delta, err );
    ASSERT_MATRICES_EQUAL( delta, TargetCalculator::aspect( W ), EPS );
    W = MsqMatrix< 2, 2 >( 6 ) * Q2D_45;
    ASSERT_MATRICES_EQUAL( I, TargetCalculator::aspect( W ), EPS );
Definition at line 737 of file TargetCalculatorTest.cpp.
References MBMesquite::TargetCalculator::aspect(), ASSERT_MATRICES_EQUAL, ASSERT_NO_ERROR, EPS, MBMesquite::TargetCalculator::factor_3D(), and moab::R.
    double lambda;
    MsqMatrix< 3, 3 > V, Q, delta;
    MsqMatrix< 3, 3 > I( 1.0 );
    TargetCalculator::factor_3D( I, lambda, V, Q, delta, err );
    double r[] = { 0.8, 0.0, 0.0, 0.0, 0.0, 1.13, 0.0, -0.5, 0.0 };
    MsqMatrix< 3, 3 > R( r );
    TargetCalculator::factor_3D( R, lambda, V, Q, delta, err );
    double w[] = { 9, 8, 7, 1, 5, 4, 3, 2, 6 };
    MsqMatrix< 3, 3 > W( w );
    TargetCalculator::factor_3D( W, lambda, V, Q, delta, err );
    ASSERT_MATRICES_EQUAL( delta, TargetCalculator::aspect( W ), 2 * EPS );
    W = MsqMatrix< 3, 3 >( 2.1 ) * Q3D_45;
Definition at line 709 of file TargetCalculatorTest.cpp.
References MBMesquite::TargetCalculator::aspect(), ASSERT_MATRICES_EQUAL, ASSERT_NO_ERROR, EPS, MBMesquite::TargetCalculator::factor_surface(), and moab::R.
    double lambda;
    MsqMatrix< 3, 2 > V;
    MsqMatrix< 2, 2 > Q, delta;
    MsqMatrix< 3, 2 > I( 1.0 );
    TargetCalculator::factor_surface( I, lambda, V, Q, delta, err );
    double r[] = { 1, 0, 0, 0, 0, 2 };
    MsqMatrix< 3, 2 > R( r );
    TargetCalculator::factor_surface( R, lambda, V, Q, delta, err );
    double w[] = { 3, 1, 4, 2, -1, 5 };
    MsqMatrix< 3, 2 > W( w );
    TargetCalculator::factor_surface( W, lambda, V, Q, delta, err );
    W = MsqMatrix< 3, 2 >( 6 ) * Q2D_45;
    ASSERT_MATRICES_EQUAL( ( MsqMatrix< 2, 2 >( 1.0 ) ), TargetCalculator::aspect( W ), EPS );
Definition at line 277 of file TargetCalculatorTest.cpp.
References ASSERT_MATRICES_EQUAL, CPPUNIT_ASSERT, CPPUNIT_ASSERT_DOUBLES_EQUAL, MBMesquite::det(), EPS, MBMesquite::TargetCalculator::factor_2D(), and MBMesquite::transpose().
    MsqMatrix< 2, 2 > I( 1.0 ), W, V;
    double lambda;
    bool valid;
    // first test with I
    valid = TargetCalculator::factor_2D( I, lambda, V, Q, delta, err );
    CPPUNIT_ASSERT( valid && !err );
    CPPUNIT_ASSERT_DOUBLES_EQUAL( 1.0, lambda, EPS );
    check_valid_V( V );
    check_valid_Q( Q );
    check_valid_delta( delta );
    W = lambda * V * Q * delta;
    ASSERT_MATRICES_EQUAL( I, W, EPS );
    // now test with 2*I
    valid = TargetCalculator::factor_2D( 2 * I, lambda, V, Q, delta, err );
    CPPUNIT_ASSERT_DOUBLES_EQUAL( 2.0, lambda, EPS );
    check_valid_V( V );
    check_valid_Q( Q );
    ASSERT_MATRICES_EQUAL( 2 * I, W, EPS );
    // now rotate the matrix about the X axis by 90 degrees
    MsqMatrix< 2, 2 > I_rot( 0.0 );
    I_rot( 0, 1 ) = 1.0;
    I_rot( 1, 0 ) = -1.0;
    valid         = TargetCalculator::factor_2D( I_rot, lambda, V, Q, delta, err );
    check_valid_V( V );
    check_valid_Q( Q );
    ASSERT_MATRICES_EQUAL( I_rot, W, EPS );
    // change the aspect ratio
    MsqMatrix< 2, 2 > A( 1.0 );
    A( 1, 1 ) = 1.5;
    valid     = TargetCalculator::factor_2D( A, lambda, V, Q, delta, err );
    CPPUNIT_ASSERT_DOUBLES_EQUAL( pow( det( transpose( A ) * A ), 0.25 ), lambda, EPS );
    check_valid_V( V );
    check_valid_Q( Q );
    ASSERT_MATRICES_EQUAL( A, W, EPS );
    // try an arbitrary matrix
    double w[4] = { 3, 1, 4, 2 };
    MsqMatrix< 2, 2 > W2( w );
    valid = TargetCalculator::factor_2D( W2, lambda, V, Q, delta, err );
    CPPUNIT_ASSERT_DOUBLES_EQUAL( pow( det( transpose( W2 ) * W2 ), 0.25 ), lambda, EPS );
    check_valid_V( V );
    check_valid_Q( Q );
    ASSERT_MATRICES_EQUAL( W2, W, EPS );
    // try a more elaborate test
    const double e = exp( (double)1 );
    MsqMatrix< 2, 2 > Z45( V2D_Z45.data() );  // copy first two rows
    W2    = e * Z45 * Q2D_45 * D2D_21;
    CPPUNIT_ASSERT_DOUBLES_EQUAL( e, lambda, EPS );
    ASSERT_MATRICES_EQUAL( Z45, V, EPS );
    ASSERT_MATRICES_EQUAL( Q2D_45, Q, EPS );
    ASSERT_MATRICES_EQUAL( D2D_21, delta, EPS );
Definition at line 507 of file TargetCalculatorTest.cpp.
References ASSERT_NO_ERROR, CPPUNIT_ASSERT, MBMesquite::TargetCalculator::factor_2D(), and MBMesquite::MeshWriter::Z.
    double lambda;
    MsqMatrix< 2, 2 > V, Z( 0.0 );
    Z( 0, 0 ) = 1.0;
    bool valid = TargetCalculator::factor_2D( Z, lambda, V, Q, delta, err );
    CPPUNIT_ASSERT( !valid );
Definition at line 430 of file TargetCalculatorTest.cpp.
References ASSERT_MATRICES_EQUAL, MBMesquite::cbrt(), CPPUNIT_ASSERT, CPPUNIT_ASSERT_DOUBLES_EQUAL, MBMesquite::det(), EPS, EPSBIG, and MBMesquite::TargetCalculator::factor_3D().
    MsqMatrix< 3, 3 > I( 1.0 ), W, V, Q, delta;
    double lambda;
    bool valid;
    valid = TargetCalculator::factor_3D( I, lambda, V, Q, delta, err );
    check_valid_V( V );
    check_valid_Q( Q );
    valid = TargetCalculator::factor_3D( 2 * I, lambda, V, Q, delta, err );
    check_valid_V( V );
    check_valid_Q( Q );
    MsqMatrix< 3, 3 > I_rot( 1.0 );
    I_rot( 1, 1 ) = 0.0;
    I_rot( 2, 1 ) = 1.0;
    I_rot( 1, 2 ) = -1.0;
    I_rot( 2, 2 ) = 0.0;
    valid         = TargetCalculator::factor_3D( I_rot, lambda, V, Q, delta, err );
    check_valid_V( V );
    check_valid_Q( Q );
    MsqMatrix< 3, 3 > A( 1.0 );
    A( 1, 1 ) = 1.5;
    valid     = TargetCalculator::factor_3D( A, lambda, V, Q, delta, err );
    CPPUNIT_ASSERT_DOUBLES_EQUAL( MBMesquite::cbrt( det( A ) ), lambda, EPS );
    check_valid_V( V );
    check_valid_Q( Q );
    double vals[] = { 9, 8, 7, 1, 5, 4, 3, 2, 6 };
    MsqMatrix< 3, 3 > W2( vals );
    valid = TargetCalculator::factor_3D( W2, lambda, V, Q, delta, err );
    CPPUNIT_ASSERT_DOUBLES_EQUAL( MBMesquite::cbrt( det( W2 ) ), lambda, EPS );
    check_valid_V( V );
    check_valid_Q( Q );
    ASSERT_MATRICES_EQUAL( W2, W, EPSBIG );
    W2             = e * V3D_Z45 * Q3D_45 * D3D_123;
    ASSERT_MATRICES_EQUAL( V3D_Z45, V, EPS );
    ASSERT_MATRICES_EQUAL( Q3D_45, Q, EPS );
    ASSERT_MATRICES_EQUAL( D3D_123, delta, EPS );
Definition at line 533 of file TargetCalculatorTest.cpp.
References ASSERT_NO_ERROR, CPPUNIT_ASSERT, MBMesquite::TargetCalculator::factor_3D(), and MBMesquite::MeshWriter::Z.
    double lambda;
    MsqMatrix< 3, 3 > V, Q, delta, Z( 0.0 );
    Z( 0, 0 ) = 1.0;
    bool valid = TargetCalculator::factor_3D( Z, lambda, V, Q, delta, err );
Definition at line 354 of file TargetCalculatorTest.cpp.
References ASSERT_MATRICES_EQUAL, CPPUNIT_ASSERT, CPPUNIT_ASSERT_DOUBLES_EQUAL, MBMesquite::det(), EPS, MBMesquite::TargetCalculator::factor_surface(), and MBMesquite::transpose().
    MsqMatrix< 3, 2 > I( 1.0 ), W, V;
    double lambda;
    bool valid;
    valid = TargetCalculator::factor_surface( I, lambda, V, Q, delta, err );
    check_valid_V( V );
    check_valid_Q( Q );
    valid = TargetCalculator::factor_surface( 2 * I, lambda, V, Q, delta, err );
    check_valid_V( V );
    check_valid_Q( Q );
    MsqMatrix< 3, 2 > I_rot( 1.0 );
    valid         = TargetCalculator::factor_surface( I_rot, lambda, V, Q, delta, err );
    check_valid_V( V );
    check_valid_Q( Q );
    MsqMatrix< 3, 2 > A( 1.0 );
    A( 1, 1 ) = 1.5;
    valid     = TargetCalculator::factor_surface( A, lambda, V, Q, delta, err );
    check_valid_V( V );
    check_valid_Q( Q );
    double w[6] = { 3, 1, 4, 2, -1, 5 };
    MsqMatrix< 3, 2 > W2( w );
    valid = TargetCalculator::factor_surface( W2, lambda, V, Q, delta, err );
    check_valid_V( V );
    check_valid_Q( Q );
    W2             = e * V2D_Z45 * Q2D_45 * D2D_21;
    ASSERT_MATRICES_EQUAL( V2D_Z45, V, EPS );
Definition at line 520 of file TargetCalculatorTest.cpp.
References ASSERT_NO_ERROR, CPPUNIT_ASSERT, MBMesquite::TargetCalculator::factor_surface(), and MBMesquite::MeshWriter::Z.
    double lambda;
    MsqMatrix< 3, 2 > V, Z( 0.0 );
    Z( 0, 0 ) = 1.0;
    bool valid = TargetCalculator::factor_surface( Z, lambda, V, Q, delta, err );
Definition at line 1249 of file TargetCalculatorTest.cpp.
References ASSERT_MATRICES_EQUAL, ASSERT_NO_ERROR, conn, EPS, MBMesquite::PatchData::fill(), fixed, MBMesquite::TargetCalculator::get_refmesh_Jacobian_2D(), MBMesquite::TargetCalculator::jacobian_2D(), tri_coords(), and MBMesquite::TRIANGLE.
    MsqError err;
    const Vector3D tri_coords[] = { Vector3D( 0, 0, 0 ), Vector3D( 3, 0, 1 ), Vector3D( 1, 0, 3 ) };
    DummyRefMesh ref_mesh( tri_coords, 3 );
    const Vector3D right_coords[] = { Vector3D( 0, 0, 0 ), Vector3D( 5, 0, 0 ), Vector3D( 5, 1, 0 ) };
    size_t conn[]                 = { 0, 1, 2 };
    bool fixed[3];
    std::fill( fixed, fixed + sizeof( fixed ) / sizeof( fixed[0] ), false );
    PatchData pd;
    pd.fill( 3, right_coords[0].to_array(), 1, TRIANGLE, conn, fixed, err );
    Sample pts[]      = { Sample( 0, 0 ), Sample( 1, 1 ), Sample( 2, 0 ) };
    const int num_pts = sizeof( pts ) / sizeof( pts[0] );
    for( int i = 0; i < num_pts; ++i )
        MsqMatrix< 3, 2 > J, W;
        TargetCalculator::jacobian_2D( pd, TRIANGLE, 3, pts[i], tri_coords, J, err );
        TargetCalculator::get_refmesh_Jacobian_2D( &ref_mesh, pd, 0, pts[i], W, err );
        ASSERT_MATRICES_EQUAL( J, W, EPS );
Definition at line 1215 of file TargetCalculatorTest.cpp.
References ASSERT_MATRICES_EQUAL, ASSERT_NO_ERROR, conn, EPS, MBMesquite::PatchData::fill(), fixed, MBMesquite::TargetCalculator::get_refmesh_Jacobian_3D(), MBMesquite::HEXAHEDRON, and MBMesquite::TargetCalculator::jacobian_3D().
    MsqError err;
    const Vector3D hex_coords[] = { Vector3D( 0, 0, 0 ), Vector3D( 2, 0, 0 ), Vector3D( 3, 2, 0 ),
                                    Vector3D( 1, 2, 0 ), Vector3D( 1, 0, 1 ), Vector3D( 3, 0, 2 ),
                                    Vector3D( 3, 2, 2 ), Vector3D( 2, 2, 2 ) };
    DummyRefMesh ref_mesh( hex_coords, 8 );
    const Vector3D rect_coords[] = { Vector3D( 0, 0, 0 ), Vector3D( 1, 0, 0 ), Vector3D( 1, 1, 0 ),
                                     Vector3D( 0, 1, 0 ), Vector3D( 0, 0, 5 ), Vector3D( 1, 0, 5 ),
                                     Vector3D( 1, 1, 5 ), Vector3D( 0, 1, 5 ) };
    size_t conn[]                = { 0, 1, 2, 3, 4, 5, 6, 7 };
    bool fixed[8];
    PatchData pd;
    pd.fill( 8, rect_coords[0].to_array(), 1, HEXAHEDRON, conn, fixed, err );
    Sample pts[]      = { Sample( 0, 0 ), Sample( 1, 6 ), Sample( 3, 0 ) };
        MsqMatrix< 3, 3 > J, W;
        TargetCalculator::jacobian_3D( pd, HEXAHEDRON, 8, pts[i], hex_coords, J, err );
        TargetCalculator::get_refmesh_Jacobian_3D( &ref_mesh, pd, 0, pts[i], W, err );
Definition at line 1076 of file TargetCalculatorTest.cpp.
References ASSERT_IDENTITY_MATRIX, ASSERT_NO_ERROR, MBMesquite::HEXAHEDRON, and MBMesquite::TargetCalculator::ideal_shape_3D().
    MsqError err;
    PatchData pd;
    MsqMatrix< 3, 3 > Q;
    TargetCalculator::ideal_shape_3D( HEXAHEDRON, Sample( 0, 0 ), pd, Q, err );
    ASSERT_IDENTITY_MATRIX( Q );
    TargetCalculator::ideal_shape_3D( HEXAHEDRON, Sample( 3, 0 ), pd, Q, err );
Definition at line 1029 of file TargetCalculatorTest.cpp.
References ASSERT_MATRICES_EQUAL, ASSERT_NO_ERROR, EPS, MBMesquite::TargetCalculator::ideal_shape_3D(), MBMesquite::TargetCalculator::ideal_skew_3D(), and MBMesquite::PRISM.
    // Ideal wedge should have Aspect (i.e. delta) == identity,
    // so shape should be equal to skew.
    Sample points[]   = { Sample( 0, 0 ), Sample( 0, 1 ), Sample( 0, 2 ),
                        Sample( 0, 3 ), Sample( 2, 0 ), Sample( 3, 0 ) };
    const int num_pts = sizeof( points ) / sizeof( points[0] );
    MsqError err;
    PatchData pd;
    MsqMatrix< 3, 3 > Q, W;
        TargetCalculator::ideal_shape_3D( PRISM, points[i], pd, Q, err );
        TargetCalculator::ideal_skew_3D( PRISM, points[i], pd, W, err );
        ASSERT_MATRICES_EQUAL( W, Q, EPS );
Definition at line 1052 of file TargetCalculatorTest.cpp.
References ASSERT_MATRICES_EQUAL, ASSERT_NO_ERROR, EPS, MBMesquite::TargetCalculator::ideal_shape_3D(), MBMesquite::TargetCalculator::jacobian_3D(), MBMesquite::PYRAMID, MBMesquite::TargetCalculator::shape(), and MBMesquite::unit_edge_element().
    MsqError err;
    PatchData pd;
    const Vector3D* coords = unit_edge_element( PYRAMID, true );
        TargetCalculator::ideal_shape_3D( PYRAMID, points[i], pd, Q, err );
        TargetCalculator::jacobian_3D( pd, PYRAMID, 5, points[i], coords, W, err );
        ASSERT_MATRICES_EQUAL( TargetCalculator::shape( W ), Q, EPS );
Definition at line 992 of file TargetCalculatorTest.cpp.
References ASSERT_IDENTITY_MATRIX, ASSERT_NO_ERROR, MBMesquite::TargetCalculator::ideal_shape_2D(), and MBMesquite::QUADRILATERAL.
    MsqError err;
    PatchData pd;
    MsqMatrix< 2, 2 > Q;
    TargetCalculator::ideal_shape_2D( QUADRILATERAL, Sample( 0, 0 ), pd, Q, err );
    TargetCalculator::ideal_shape_2D( QUADRILATERAL, Sample( 2, 0 ), pd, Q, err );
Definition at line 1007 of file TargetCalculatorTest.cpp.
References ASSERT_MATRICES_EQUAL, ASSERT_NO_ERROR, EPS, MBMesquite::TargetCalculator::ideal_shape_3D(), MBMesquite::TargetCalculator::ideal_skew_3D(), and MBMesquite::TETRAHEDRON.
    // Ideal tetrahedron should have Aspect (i.e. delta) == identity,
    MsqError err;
    PatchData pd;
    MsqMatrix< 3, 3 > Q, Q2;
    TargetCalculator::ideal_shape_3D( TETRAHEDRON, Sample( 0, 0 ), pd, Q, err );
    TargetCalculator::ideal_skew_3D( TETRAHEDRON, Sample( 0, 0 ), pd, Q2, err );
    ASSERT_MATRICES_EQUAL( Q2, Q, EPS );
    TargetCalculator::ideal_shape_3D( TETRAHEDRON, Sample( 3, 0 ), pd, Q, err );
    TargetCalculator::ideal_skew_3D( TETRAHEDRON, Sample( 3, 0 ), pd, Q2, err );
Definition at line 970 of file TargetCalculatorTest.cpp.
References ASSERT_MATRICES_EQUAL, ASSERT_NO_ERROR, EPS, MBMesquite::TargetCalculator::ideal_shape_2D(), MBMesquite::TargetCalculator::ideal_skew_2D(), and MBMesquite::TRIANGLE.
    // Ideal triangle should have Aspect (i.e. delta) == identity,
    MsqError err;
    PatchData pd;
    MsqMatrix< 2, 2 > Q, Q2;
    TargetCalculator::ideal_shape_2D( TRIANGLE, Sample( 0, 0 ), pd, Q, err );
    TargetCalculator::ideal_skew_2D( TRIANGLE, Sample( 0, 0 ), pd, Q2, err );
    TargetCalculator::ideal_shape_2D( TRIANGLE, Sample( 2, 0 ), pd, Q, err );
    TargetCalculator::ideal_skew_2D( TRIANGLE, Sample( 2, 0 ), pd, Q2, err );
Definition at line 955 of file TargetCalculatorTest.cpp.
References ASSERT_IDENTITY_MATRIX, ASSERT_NO_ERROR, MBMesquite::HEXAHEDRON, and MBMesquite::TargetCalculator::ideal_skew_3D().
    MsqError err;
    PatchData pd;
    TargetCalculator::ideal_skew_3D( HEXAHEDRON, Sample( 0, 0 ), pd, Q, err );
    TargetCalculator::ideal_skew_3D( HEXAHEDRON, Sample( 3, 0 ), pd, Q, err );
Definition at line 905 of file TargetCalculatorTest.cpp.
References ASSERT_MATRICES_EQUAL, ASSERT_NO_ERROR, EPS, MBMesquite::TargetCalculator::ideal_skew_3D(), MBMesquite::TargetCalculator::jacobian_3D(), MBMesquite::PRISM, MBMesquite::TargetCalculator::skew(), and MBMesquite::unit_edge_element().
    MsqError err;
    PatchData pd;
    const Vector3D* coords = unit_edge_element( PRISM );
        TargetCalculator::ideal_skew_3D( PRISM, points[i], pd, Q, err );
        check_valid_Q( Q );
        TargetCalculator::jacobian_3D( pd, PRISM, 6, points[i], coords, W, err );
        ASSERT_MATRICES_EQUAL( TargetCalculator::skew( W ), Q, EPS );
Definition at line 930 of file TargetCalculatorTest.cpp.
References ASSERT_MATRICES_EQUAL, ASSERT_NO_ERROR, EPS, MBMesquite::TargetCalculator::ideal_skew_3D(), MBMesquite::TargetCalculator::jacobian_3D(), MBMesquite::PYRAMID, MBMesquite::TargetCalculator::skew(), and MBMesquite::unit_edge_element().
    MsqError err;
    PatchData pd;
        TargetCalculator::ideal_skew_3D( PYRAMID, points[i], pd, Q, err );
        check_valid_Q( Q );
Definition at line 868 of file TargetCalculatorTest.cpp.
References ASSERT_IDENTITY_MATRIX, ASSERT_NO_ERROR, MBMesquite::TargetCalculator::ideal_skew_2D(), and MBMesquite::QUADRILATERAL.
    MsqError err;
    PatchData pd;
    TargetCalculator::ideal_skew_2D( QUADRILATERAL, Sample( 0, 0 ), pd, Q, err );
    TargetCalculator::ideal_skew_2D( QUADRILATERAL, Sample( 2, 0 ), pd, Q, err );
Definition at line 883 of file TargetCalculatorTest.cpp.
References ASSERT_MATRICES_EQUAL, ASSERT_NO_ERROR, EPS, MBMesquite::TargetCalculator::ideal_skew_3D(), MBMesquite::TargetCalculator::jacobian_3D(), MBMesquite::TargetCalculator::skew(), MBMesquite::TETRAHEDRON, and MBMesquite::unit_edge_element().
    MsqError err;
    PatchData pd;
    TargetCalculator::ideal_skew_3D( TETRAHEDRON, Sample( 0, 0 ), pd, Q, err );
    check_valid_Q( Q );
    ASSERT_MATRICES_EQUAL( Q, Q2, EPS );
    const Vector3D* coords = unit_edge_element( TETRAHEDRON );
    MsqMatrix< 3, 3 > W;
    TargetCalculator::jacobian_3D( pd, TETRAHEDRON, 4, Sample( 0, 0 ), coords, W, err );
    Q = TargetCalculator::skew( W );
Definition at line 846 of file TargetCalculatorTest.cpp.
References ASSERT_MATRICES_EQUAL, ASSERT_NO_ERROR, EPS, MBMesquite::TargetCalculator::ideal_skew_2D(), MBMesquite::TargetCalculator::jacobian_2D(), MBMesquite::TargetCalculator::skew(), MBMesquite::TRIANGLE, and MBMesquite::unit_edge_element().
    MsqError err;
    PatchData pd;
    TargetCalculator::ideal_skew_2D( TRIANGLE, Sample( 0, 0 ), pd, Q, err );
    check_valid_Q( Q );
    const Vector3D* coords = unit_edge_element( TRIANGLE );
    MsqMatrix< 3, 2 > W;
    TargetCalculator::jacobian_2D( pd, TRIANGLE, 3, Sample( 0, 0 ), coords, W, err );
Definition at line 1163 of file TargetCalculatorTest.cpp.
References ASSERT_MATRICES_EQUAL, ASSERT_NO_ERROR, MBMesquite::LinearTriangle::derivatives(), EPS, MBMesquite::TargetCalculator::jacobian_2D(), n, MBMesquite::outer(), tri_coords(), and MBMesquite::TRIANGLE.
    MsqError err;
    PatchData pd;
    LinearTriangle map;
    const Vector3D tri_coords[]  = { Vector3D( 0, 0, 0 ), Vector3D( 2, 0, 0 ), Vector3D( 0, 0, 1 ) };
    const MsqVector< 3 >* coords = reinterpret_cast< const MsqVector< 3 >* >( tri_coords );
        MsqMatrix< 3, 2 > J( 0.0 ), W;
        size_t indices[3], n;
        MsqVector< 2 > derivs[3];
        map.derivatives( pts[i], NodeSet(), indices, derivs, n, err );
        for( size_t j = 0; j < n; ++j )
            J += outer( coords[indices[j]], derivs[j] );
        TargetCalculator::jacobian_2D( pd, TRIANGLE, 3, pts[i], tri_coords, W, err );
Definition at line 1134 of file TargetCalculatorTest.cpp.
References ASSERT_MATRICES_EQUAL, ASSERT_NO_ERROR, MBMesquite::LinearHexahedron::derivatives(), EPS, MBMesquite::HEXAHEDRON, MBMesquite::TargetCalculator::jacobian_3D(), n, and MBMesquite::outer().
    MsqError err;
    PatchData pd;
    LinearHexahedron map;
    const MsqVector< 3 >* coords = reinterpret_cast< const MsqVector< 3 >* >( hex_coords );
        MsqMatrix< 3, 3 > J( 0.0 ), W;
        size_t indices[8], n;
        MsqVector< 3 > derivs[8];
        TargetCalculator::jacobian_3D( pd, HEXAHEDRON, 8, pts[i], hex_coords, W, err );
Definition at line 1124 of file TargetCalculatorTest.cpp.
References CPPUNIT_ASSERT_DOUBLES_EQUAL, EPS, and MBMesquite::TargetCalculator::new_aspect_2D().
    MsqVector< 2 > r;
    r[0]                    = 7;
    r[1]                    = 3;
    MsqMatrix< 2, 2 > delta = TargetCalculator::new_aspect_2D( r );
    CPPUNIT_ASSERT_DOUBLES_EQUAL( r[0] / r[1], delta( 0, 0 ) / delta( 1, 1 ), EPS );
Definition at line 1112 of file TargetCalculatorTest.cpp.
References CPPUNIT_ASSERT_DOUBLES_EQUAL, EPS, and MBMesquite::TargetCalculator::new_aspect_3D().
    MsqVector< 3 > r;
    r[0]                    = 2;
    r[1]                    = 4;
    r[2]                    = 6;
    MsqMatrix< 3, 3 > delta = TargetCalculator::new_aspect_3D( r );
    CPPUNIT_ASSERT_DOUBLES_EQUAL( r[0] / r[2], delta( 0, 0 ) / delta( 2, 2 ), EPS );
Definition at line 1102 of file TargetCalculatorTest.cpp.
References ASSERT_MATRICES_EQUAL, MBMesquite::MsqMatrix< R, C >::column(), EPS, MBMesquite::TargetCalculator::new_orientation_2D(), and z.
    MsqVector< 3 > x( 0.0 ), y( 0.0 ), z( 0.0 );
    x[0] = y[1] = z[2] = 1;
    MsqMatrix< 3, 2 > V = TargetCalculator::new_orientation_2D( x, y );
    check_valid_V( V );
    ASSERT_MATRICES_EQUAL( z, V.column( 0 ) * V.column( 1 ), EPS );
Definition at line 1091 of file TargetCalculatorTest.cpp.
References ASSERT_MATRICES_EQUAL, MBMesquite::MsqMatrix< R, C >::column(), EPS, MBMesquite::TargetCalculator::new_orientation_3D(), and z.
    MsqMatrix< 3, 3 > V = TargetCalculator::new_orientation_3D( x, y );
    check_valid_V( V );
    ASSERT_MATRICES_EQUAL( z, V.column( 2 ), EPS );
Definition at line 764 of file TargetCalculatorTest.cpp.
References ASSERT_MATRICES_EQUAL, ASSERT_NO_ERROR, EPS, MBMesquite::TargetCalculator::factor_2D(), moab::R, and MBMesquite::TargetCalculator::shape().
    double lambda;
    ASSERT_MATRICES_EQUAL( Q * delta, TargetCalculator::shape( I ), EPS );
    ASSERT_MATRICES_EQUAL( Q * delta, TargetCalculator::shape( R ), EPS );
    ASSERT_MATRICES_EQUAL( Q * delta, TargetCalculator::shape( W ), EPS );
    ASSERT_MATRICES_EQUAL( Q2D_45, TargetCalculator::shape( W ), EPS );
Definition at line 819 of file TargetCalculatorTest.cpp.
References ASSERT_MATRICES_EQUAL, ASSERT_NO_ERROR, EPS, MBMesquite::TargetCalculator::factor_3D(), moab::R, and MBMesquite::TargetCalculator::shape().
    double lambda;
    ASSERT_MATRICES_EQUAL( Q * delta, TargetCalculator::shape( W ), 2 * EPS );
    ASSERT_MATRICES_EQUAL( Q3D_45, TargetCalculator::shape( W ), EPS );
Definition at line 791 of file TargetCalculatorTest.cpp.
References ASSERT_MATRICES_EQUAL, ASSERT_NO_ERROR, EPS, MBMesquite::TargetCalculator::factor_surface(), moab::R, and MBMesquite::TargetCalculator::shape().
    double lambda;
Definition at line 545 of file TargetCalculatorTest.cpp.
References ASSERT_NO_ERROR, CPPUNIT_ASSERT_DOUBLES_EQUAL, EPS, MBMesquite::TargetCalculator::factor_2D(), and MBMesquite::TargetCalculator::size().
    double lambda;
    CPPUNIT_ASSERT_DOUBLES_EQUAL( lambda, TargetCalculator::size( I ), EPS );
    CPPUNIT_ASSERT_DOUBLES_EQUAL( lambda, TargetCalculator::size( W ), EPS );
Definition at line 582 of file TargetCalculatorTest.cpp.
References ASSERT_NO_ERROR, CPPUNIT_ASSERT_DOUBLES_EQUAL, EPS, MBMesquite::TargetCalculator::factor_3D(), and MBMesquite::TargetCalculator::size().
    double lambda;
Definition at line 563 of file TargetCalculatorTest.cpp.
References ASSERT_NO_ERROR, CPPUNIT_ASSERT_DOUBLES_EQUAL, EPS, MBMesquite::TargetCalculator::factor_surface(), and MBMesquite::TargetCalculator::size().
    double lambda;
Definition at line 600 of file TargetCalculatorTest.cpp.
References ASSERT_MATRICES_EQUAL, ASSERT_NO_ERROR, EPS, MBMesquite::TargetCalculator::factor_2D(), moab::R, and MBMesquite::TargetCalculator::skew().
    double lambda;
    ASSERT_MATRICES_EQUAL( Q, TargetCalculator::skew( I ), EPS );
    ASSERT_MATRICES_EQUAL( Q, TargetCalculator::skew( R ), EPS );
    ASSERT_MATRICES_EQUAL( Q, TargetCalculator::skew( W ), EPS );
    ASSERT_MATRICES_EQUAL( Q2D_45, TargetCalculator::skew( W ), EPS );
Definition at line 655 of file TargetCalculatorTest.cpp.
References ASSERT_MATRICES_EQUAL, ASSERT_NO_ERROR, EPS, MBMesquite::TargetCalculator::factor_3D(), moab::R, and MBMesquite::TargetCalculator::skew().
    double lambda;
    ASSERT_MATRICES_EQUAL( Q, TargetCalculator::skew( W ), 2 * EPS );
    ASSERT_MATRICES_EQUAL( Q3D_45, TargetCalculator::skew( W ), EPS );
Definition at line 627 of file TargetCalculatorTest.cpp.
References ASSERT_MATRICES_EQUAL, ASSERT_NO_ERROR, EPS, MBMesquite::TargetCalculator::factor_surface(), moab::R, and MBMesquite::TargetCalculator::skew().
    double lambda;
Member Data Documentation
Definition at line 107 of file TargetCalculatorTest.cpp.
Definition at line 105 of file TargetCalculatorTest.cpp.
Definition at line 106 of file TargetCalculatorTest.cpp.
List of all members.
