MOAB: Mesh Oriented datABase
(version 5.4.0)
00001 /* ***************************************************************** 00002 MESQUITE -- The Mesh Quality Improvement Toolkit 00003 00004 Copyright 2004 Sandia Corporation and Argonne National 00005 Laboratory. Under the terms of Contract DE-AC04-94AL85000 00006 with Sandia Corporation, the U.S. Government retains certain 00007 rights in this software. 00008 00009 This library is free software; you can redistribute it and/or 00010 modify it under the terms of the GNU Lesser General Public 00011 License as published by the Free Software Foundation; either 00012 version 2.1 of the License, or (at your option) any later version. 00013 00014 This library is distributed in the hope that it will be useful, 00015 but WITHOUT ANY WARRANTY; without even the implied warranty of 00016 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00017 Lesser General Public License for more details. 00018 00019 You should have received a copy of the GNU Lesser General Public License 00020 (lgpl.txt) along with this library; if not, write to the Free Software 00021 Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA 00022 00023 diachin2@llnl.gov, djmelan@sandia.gov, mbrewer@sandia.gov, 00024 pknupp@sandia.gov, tleurent@mcs.anl.gov, tmunson@mcs.anl.gov 00025 00026 ***************************************************************** */ 00027 // -*- Mode : c++; tab-width: 3; c-tab-always-indent: t; indent-tabs-mode: nil; c-basic-offset: 3 00028 // -*- 00029 // 00030 // SUMMARY: 00031 // USAGE: 00032 // 00033 // AUTHOR: Thomas Leurent <tleurent@mcs.anl.gov> 00034 // ORG: Argonne National Laboratory 00035 // E-MAIL: tleurent@mcs.anl.gov 00036 // 00037 // ORIG-DATE: 12-Nov-02 at 18:05:56 00038 // LAST-MOD: 7-May-03 at 13:28:47 by Thomas Leurent 00039 // 00040 // DESCRIPTION: 00041 // ============ 00042 /*! \file MsqMeshEntityTest.cpp 00043 00044 Unit testing of various functions in the MsqMeshEntity class. 00045 00046 \author Michael Brewer 00047 \author Thomas Leurent 00048 00049 */ 00050 // DESCRIP-END. 00051 // 00052 00053 #include "MsqMeshEntity.hpp" 00054 #include "Vector3D.hpp" 00055 #include "PatchData.hpp" 00056 #include "PatchDataInstances.hpp" 00057 #include <cmath> 00058 #include <iostream> 00059 #include <sstream> 00060 #include "UnitUtil.hpp" 00061 00062 using namespace MBMesquite; 00063 using std::cout; 00064 using std::endl; 00065 00066 class MsqMeshEntityTest : public CppUnit::TestFixture 00067 { 00068 00069 private: 00070 CPPUNIT_TEST_SUITE( MsqMeshEntityTest ); 00071 CPPUNIT_TEST( test_hex_vertices ); 00072 CPPUNIT_TEST( test_centroid_tri ); 00073 CPPUNIT_TEST( test_centroid_quad ); 00074 CPPUNIT_TEST( test_centroid_hex ); 00075 CPPUNIT_TEST( test_unsigned_area ); 00076 CPPUNIT_TEST( test_unsigned_area_poly ); 00077 CPPUNIT_TEST( test_unsigned_area_tet ); 00078 CPPUNIT_TEST( test_unsigned_area_pyr ); 00079 CPPUNIT_TEST( test_unsigned_area_pri ); 00080 CPPUNIT_TEST( test_unsigned_area_hex ); 00081 CPPUNIT_TEST( test_all_nodes ); 00082 CPPUNIT_TEST( test_check_element_orientation_linear ); 00083 CPPUNIT_TEST( test_check_element_orientation_quadratic ); 00084 CPPUNIT_TEST_SUITE_END(); 00085 00086 void test_all_nodes( EntityTopology type, unsigned num_nodes ); 00087 00088 private: 00089 PatchData oneHexPatch; 00090 PatchData oneTetPatch; 00091 PatchData oneQuadPatch; 00092 PatchData oneTriPatch; 00093 Vector3D e1, e2, e3; 00094 double tolEps; 00095 00096 public: 00097 void setUp() 00098 { 00099 tolEps = 1.e-12; 00100 00101 // sets up the unit vectors 00102 e1.set( 1, 0, 0 ); 00103 e2.set( 0, 1, 0 ); 00104 e3.set( 0, 0, 1 ); 00105 00106 MsqPrintError err( cout ); 00107 00108 // creates empty Patch 00109 create_one_hex_patch( oneHexPatch, err ); 00110 CPPUNIT_ASSERT( !err ); 00111 create_one_tet_patch( oneTetPatch, err ); 00112 CPPUNIT_ASSERT( !err ); 00113 create_one_tri_patch( oneTriPatch, err ); 00114 CPPUNIT_ASSERT( !err ); 00115 create_one_quad_patch( oneQuadPatch, err ); 00116 CPPUNIT_ASSERT( !err ); 00117 } 00118 00119 void tearDown() 00120 { 00121 destroy_patch_with_domain( oneTriPatch ); 00122 destroy_patch_with_domain( oneQuadPatch ); 00123 } 00124 00125 public: 00126 MsqMeshEntityTest() {} 00127 00128 void test_hex_vertices() 00129 { 00130 MsqPrintError err( cout ); 00131 // prints out the vertices. 00132 const MsqVertex* ideal_vertices = oneHexPatch.get_vertex_array( err ); 00133 CPPUNIT_ASSERT( !err ); 00134 size_t num_vtx = oneHexPatch.num_nodes(); 00135 CPPUNIT_ASSERT_EQUAL( size_t( 8 ), num_vtx ); 00136 00137 MsqVertex vtx; 00138 00139 vtx.set( 1, 1, 1 ); 00140 CPPUNIT_ASSERT_EQUAL( vtx, ideal_vertices[0] ); 00141 00142 vtx.set( 2, 2, 2 ); 00143 CPPUNIT_ASSERT_EQUAL( vtx, ideal_vertices[6] ); 00144 00145 vtx.set( 1, 2, 2 ); 00146 CPPUNIT_ASSERT_EQUAL( vtx, ideal_vertices[7] ); 00147 } 00148 00149 //! test the centroid of the first element in the Patch 00150 void test_centroid( PatchData& pd, Vector3D& correct ) 00151 { 00152 MsqPrintError err( cout ); 00153 double eps = 1e-6; 00154 Vector3D centroid; 00155 00156 MsqMeshEntity* elem = pd.get_element_array( err ); 00157 CPPUNIT_ASSERT( !err ); 00158 elem->get_centroid( centroid, pd, err ); 00159 CPPUNIT_ASSERT( !err ); 00160 00161 // cout << "centroid: "<< centroid <<endl; 00162 // cout << "correct: "<< correct <<endl; 00163 00164 for( int i = 0; i < 3; ++i ) 00165 CPPUNIT_ASSERT_DOUBLES_EQUAL( centroid[i], correct[i], eps ); 00166 } 00167 00168 void test_centroid_tri() 00169 { 00170 Vector3D correct( 1.5, 1 + 1 / ( 2.0 * sqrt( 3.0 ) ), 1.0 ); 00171 test_centroid( oneTriPatch, correct ); 00172 } 00173 00174 void test_centroid_quad() 00175 { 00176 Vector3D correct( 1.5, 1.5, 1.0 ); 00177 test_centroid( oneQuadPatch, correct ); 00178 } 00179 00180 void test_centroid_hex() 00181 { 00182 Vector3D correct( 1.5, 1.5, 1.5 ); 00183 test_centroid( oneHexPatch, correct ); 00184 } 00185 00186 void test_unsigned_area() 00187 { 00188 MsqPrintError err( cout ); 00189 MsqMeshEntity* tri = oneTriPatch.get_element_array( err ); 00190 CPPUNIT_ASSERT( !err ); 00191 CPPUNIT_ASSERT( fabs( tri->compute_unsigned_area( oneTriPatch, err ) - ( sqrt( 3.0 ) / 4.0 ) ) < tolEps ); 00192 MsqMeshEntity* quad = oneQuadPatch.get_element_array( err ); 00193 CPPUNIT_ASSERT( !err ); 00194 CPPUNIT_ASSERT( fabs( quad->compute_unsigned_area( oneQuadPatch, err ) - 1.0 ) < tolEps ); 00195 } 00196 00197 void test_unsigned_area_poly(); 00198 void test_unsigned_area_tet(); 00199 void test_unsigned_area_pyr(); 00200 void test_unsigned_area_pri(); 00201 void test_unsigned_area_hex(); 00202 void test_all_nodes(); 00203 00204 void test_unsigned_area_common( EntityTopology type, const double* coords, double expected ); 00205 00206 void test_check_element_orientation_linear(); 00207 void test_check_element_orientation_quadratic(); 00208 void test_check_element_orientation( EntityTopology type, int nodes ); 00209 }; 00210 00211 CPPUNIT_TEST_SUITE_NAMED_REGISTRATION( MsqMeshEntityTest, "MsqMeshEntityTest" ); 00212 CPPUNIT_TEST_SUITE_NAMED_REGISTRATION( MsqMeshEntityTest, "Unit" ); 00213 00214 const size_t conn[] = { 0, 1, 2, 3, 4, 5, 6, 7 }; 00215 const bool fixed[] = { false, false, false, false, false, false, false, false }; 00216 00217 void MsqMeshEntityTest::test_unsigned_area_poly() 00218 { 00219 const double coords[] = { 0, 0, 0, 1, 0, 0, 1, 1, 0, 0.5, 1.5, 0, 0, 1, 0 }; 00220 size_t n_vtx = 5; 00221 EntityTopology type = POLYGON; 00222 MsqError err; 00223 00224 PatchData pd; 00225 pd.fill( n_vtx, coords, 1, &type, &n_vtx, conn, fixed, err ); 00226 ASSERT_NO_ERROR( err ); 00227 00228 double a = pd.element_by_index( 0 ).compute_unsigned_area( pd, err ); 00229 ASSERT_NO_ERROR( err ); 00230 CPPUNIT_ASSERT_DOUBLES_EQUAL( 1.25, a, 1e-8 ); 00231 } 00232 00233 void MsqMeshEntityTest::test_unsigned_area_common( EntityTopology type, const double* coords, double expected ) 00234 { 00235 MsqError err; 00236 PatchData pd; 00237 00238 pd.fill( TopologyInfo::corners( type ), coords, 1, type, conn, fixed, err ); 00239 ASSERT_NO_ERROR( err ); 00240 00241 double a = pd.element_by_index( 0 ).compute_unsigned_area( pd, err ); 00242 ASSERT_NO_ERROR( err ); 00243 00244 CPPUNIT_ASSERT_DOUBLES_EQUAL( expected, a, 1e-8 ); 00245 } 00246 00247 void MsqMeshEntityTest::test_unsigned_area_tet() 00248 { 00249 const double coords[] = { 0, 0, 0, 1, 0, 0, 0, 1, 0, 0, 0, 1 }; 00250 test_unsigned_area_common( TETRAHEDRON, coords, 1.0 / 6.0 ); 00251 } 00252 00253 void MsqMeshEntityTest::test_unsigned_area_pyr() 00254 { 00255 const double coords[] = { 0, 0, 0, 1, 0, 0, 1, 1, 0, 0, 1, 0, 0, 0, 1 }; 00256 test_unsigned_area_common( PYRAMID, coords, 1.0 / 3.0 ); 00257 00258 const double pyr_coords[] = { -1, -1, -1, 1, -1, -1, 1, 1, -1, -1, 1, -1, 0, 0, 0 }; 00259 test_unsigned_area_common( PYRAMID, pyr_coords, 4.0 / 3.0 ); 00260 } 00261 00262 void MsqMeshEntityTest::test_unsigned_area_pri() 00263 { 00264 const double coords[] = { 0, 0, 0, 1, 0, 0, 0, 1, 0, 0, 0, 1, 1, 0, 1, 0, 1, 1 }; 00265 test_unsigned_area_common( PRISM, coords, 0.5 ); 00266 00267 const double tet_coords[] = { 0, 0, 0, 1, 0, 0, 0, 1, 0, 0, 0, 1, 0, 0, 1, 0, 0, 1 }; 00268 test_unsigned_area_common( PRISM, tet_coords, 1.0 / 6.0 ); 00269 } 00270 00271 void MsqMeshEntityTest::test_unsigned_area_hex() 00272 { 00273 const double coords[] = { 0, 0, 0, 1, 0, 0, 1, 1, 0, 0, 1, 0, 0, 0, 1, 1, 0, 1, 1, 1, 1, 0, 1, 1 }; 00274 test_unsigned_area_common( HEXAHEDRON, coords, 1.0 ); 00275 00276 const double coords2[] = { 0, 0, 0, 2, 0, 0, 2, 2, 0, 0, 2, 0, 0, 0, 2, 2, 0, 2, 2, 2, 2, 0, 2, 2 }; 00277 test_unsigned_area_common( HEXAHEDRON, coords2, 8.0 ); 00278 00279 const double pyr_coords[] = { -1, -1, 0, 1, -1, 0, 1, 1, 0, -1, 1, 0, 0, 0, 1, 0, 0, 1, 0, 0, 1, 0, 0, 1 }; 00280 test_unsigned_area_common( HEXAHEDRON, pyr_coords, 4.0 / 3.0 ); 00281 } 00282 00283 void MsqMeshEntityTest::test_all_nodes( EntityTopology type, unsigned num_nodes ) 00284 { 00285 const unsigned num_vtx = 27; 00286 double coords[3 * num_vtx] = { 0.0 }; 00287 size_t conn[num_vtx]; 00288 for( size_t i = 0; i < num_vtx; ++i ) 00289 conn[i] = i; 00290 bool fixed[num_vtx] = { false }; 00291 CPPUNIT_ASSERT( num_nodes <= num_vtx ); 00292 00293 MsqError err; 00294 PatchData pd; 00295 size_t n = num_nodes; 00296 pd.fill( num_nodes, coords, 1, &type, &n, conn, fixed, err ); 00297 ASSERT_NO_ERROR( err ); 00298 00299 MsqMeshEntity& elem = pd.element_by_index( 0 ); 00300 NodeSet all = elem.all_nodes( err ); 00301 ASSERT_NO_ERROR( err ); 00302 CPPUNIT_ASSERT_EQUAL( num_nodes, all.num_nodes() ); 00303 CPPUNIT_ASSERT( all.have_any_corner_node() ); 00304 bool mid_edge, mid_face, mid_reg; 00305 TopologyInfo::higher_order( type, num_nodes, mid_edge, mid_face, mid_reg, err ); 00306 ASSERT_NO_ERROR( err ); 00307 CPPUNIT_ASSERT_EQUAL( mid_edge, !!all.have_any_mid_edge_node() ); 00308 CPPUNIT_ASSERT_EQUAL( mid_face, !!all.have_any_mid_face_node() ); 00309 CPPUNIT_ASSERT_EQUAL( mid_reg, !!all.have_any_mid_region_node() ); 00310 } 00311 00312 void MsqMeshEntityTest::test_all_nodes() 00313 { 00314 test_all_nodes( TRIANGLE, 3 ); 00315 test_all_nodes( TRIANGLE, 4 ); 00316 test_all_nodes( TRIANGLE, 6 ); 00317 test_all_nodes( TRIANGLE, 7 ); 00318 00319 test_all_nodes( QUADRILATERAL, 4 ); 00320 test_all_nodes( QUADRILATERAL, 5 ); 00321 test_all_nodes( QUADRILATERAL, 8 ); 00322 test_all_nodes( QUADRILATERAL, 9 ); 00323 00324 test_all_nodes( TETRAHEDRON, 4 ); 00325 test_all_nodes( TETRAHEDRON, 5 ); 00326 test_all_nodes( TETRAHEDRON, 10 ); 00327 test_all_nodes( TETRAHEDRON, 11 ); 00328 test_all_nodes( TETRAHEDRON, 8 ); 00329 test_all_nodes( TETRAHEDRON, 9 ); 00330 test_all_nodes( TETRAHEDRON, 14 ); 00331 test_all_nodes( TETRAHEDRON, 15 ); 00332 00333 test_all_nodes( HEXAHEDRON, 8 ); 00334 test_all_nodes( HEXAHEDRON, 9 ); 00335 test_all_nodes( HEXAHEDRON, 20 ); 00336 test_all_nodes( HEXAHEDRON, 21 ); 00337 test_all_nodes( HEXAHEDRON, 14 ); 00338 test_all_nodes( HEXAHEDRON, 15 ); 00339 test_all_nodes( HEXAHEDRON, 26 ); 00340 test_all_nodes( HEXAHEDRON, 27 ); 00341 } 00342 00343 void MsqMeshEntityTest::test_check_element_orientation_linear() 00344 { 00345 const EntityTopology types[] = { TRIANGLE, QUADRILATERAL, TETRAHEDRON, PYRAMID, PRISM, HEXAHEDRON }; 00346 const int num_types = sizeof( types ) / sizeof( types[0] ); 00347 00348 for( int i = 0; i < num_types; ++i ) 00349 { 00350 test_check_element_orientation( types[i], TopologyInfo::corners( types[i] ) ); 00351 } 00352 } 00353 00354 void MsqMeshEntityTest::test_check_element_orientation_quadratic() 00355 { 00356 struct ElemType 00357 { 00358 EntityTopology topo; 00359 unsigned nodes; 00360 }; 00361 00362 const ElemType types[] = { { TRIANGLE, 6 }, { QUADRILATERAL, 8 }, { QUADRILATERAL, 9 }, { TETRAHEDRON, 10 } }; 00363 const int num_types = sizeof( types ) / sizeof( types[0] ); 00364 00365 for( int i = 0; i < num_types; ++i ) 00366 { 00367 test_check_element_orientation( types[i].topo, types[i].nodes ); 00368 } 00369 } 00370 00371 void MsqMeshEntityTest::test_check_element_orientation( EntityTopology type, int nodes ) 00372 { 00373 // get an ideal element 00374 MsqError err; 00375 PatchData pd; 00376 create_ideal_element_patch( pd, type, nodes, err ); 00377 ASSERT_NO_ERROR( err ); 00378 CPPUNIT_ASSERT_EQUAL( (size_t)1, pd.num_elements() ); 00379 CPPUNIT_ASSERT_EQUAL( (size_t)nodes, pd.num_nodes() ); 00380 MsqMeshEntity& elem = pd.element_by_index( 0 ); 00381 CPPUNIT_ASSERT_EQUAL( (size_t)nodes, elem.node_count() ); 00382 CPPUNIT_ASSERT_EQUAL( type, elem.get_element_type() ); 00383 const size_t* conn = elem.get_vertex_index_array(); 00384 00385 // test that ideal element is not reported as inverted 00386 int inverted, tested; 00387 elem.check_element_orientation( pd, inverted, tested, err ); 00388 ASSERT_NO_ERROR( err ); 00389 CPPUNIT_ASSERT_EQUAL( 0, inverted ); 00390 CPPUNIT_ASSERT( tested > 0 ); 00391 00392 bool mids[4] = { false }; 00393 TopologyInfo::higher_order( type, nodes, mids[1], mids[2], mids[3], err );MSQ_ERRRTN( err ); 00394 00395 // invert element at each vertex and test 00396 Vector3D centroid; 00397 elem.get_centroid( centroid, pd, err ); 00398 ASSERT_NO_ERROR( err ); 00399 for( int i = 0; i < nodes; ++i ) 00400 { 00401 unsigned dim, num; 00402 TopologyInfo::side_from_higher_order( type, nodes, i, dim, num, err ); 00403 ASSERT_NO_ERROR( err ); 00404 const Vector3D old_pos = pd.vertex_by_index( conn[i] ); 00405 Vector3D new_pos = old_pos; 00406 if( dim == TopologyInfo::dimension( type ) ) 00407 { 00408 // move mid-element node 3/4 of the way to corner 0 00409 new_pos += 3 * pd.vertex_by_index( conn[0] ); 00410 new_pos *= 0.25; 00411 } 00412 else if( dim == 0 ) 00413 { // if a corner vertex 00414 if( type == TRIANGLE || type == TETRAHEDRON ) 00415 { 00416 // move tri/tet vertex past opposite side of element 00417 new_pos += 2 * ( centroid - old_pos ); 00418 } 00419 else if( mids[1] ) 00420 { 00421 // if have mid-edge nodes move 3/4 of the way to center vertex 00422 new_pos += 3 * centroid; 00423 new_pos *= 0.25; 00424 } 00425 else 00426 { 00427 // move vertex past centroid 00428 new_pos += 1.5 * ( centroid - old_pos ); 00429 } 00430 } 00431 else 00432 { 00433 // otherwise move vertex past centroid 00434 new_pos += 2.5 * ( centroid - old_pos ); 00435 } 00436 00437 pd.set_vertex_coordinates( new_pos, conn[i], err ); 00438 ASSERT_NO_ERROR( err ); 00439 00440 // test that element is inverted 00441 inverted = tested = 0; 00442 elem.check_element_orientation( pd, inverted, tested, err ); 00443 ASSERT_NO_ERROR( err ); 00444 std::ostringstream str; 00445 str << TopologyInfo::short_name( type ) << nodes << " Vertex " << i << " (Dimension " << dim << " Index " << num 00446 << ")"; 00447 CppUnit::Message m( "MsqMeshEntity failed to detect inverted element" ); 00448 m.addDetail( str.str() ); 00449 ASSERT_MESSAGE( m, inverted > 0 ); 00450 00451 // move vertex back to ideal position 00452 pd.set_vertex_coordinates( old_pos, conn[i], err ); 00453 ASSERT_NO_ERROR( err ); 00454 } 00455 }
