MOAB: Mesh Oriented datABase
(version 5.3.1)
Cache target matrices on PatchData. More...
#include <CachingTargetCalculator.hpp>
Public Member Functions | |
CachingTargetCalculator (TargetCalculator *cached) | |
virtual | ~CachingTargetCalculator () |
TargetCalculator * | get_cached_calculator () const |
virtual bool | get_3D_target (PatchData &pd, size_t element, Sample sample, MsqMatrix< 3, 3 > &W_out, MsqError &err) |
Get a target matrix. | |
virtual bool | get_surface_target (PatchData &pd, size_t element, Sample sample, MsqMatrix< 3, 2 > &W_out, MsqError &err) |
virtual bool | get_2D_target (PatchData &pd, size_t element, Sample sample, MsqMatrix< 2, 2 > &W_out, MsqError &err) |
virtual bool | have_surface_orient () const |
Use 3x2 W for surface elements if true, 2x2 W if false. | |
Protected Member Functions | |
void | notify_patch_destroyed (CachedTargetData &d) |
void | notify_sub_patch (PatchData &orig_patch, CachedTargetData &data, PatchData &sub_patch, const size_t *vertex_index_map, const size_t *element_index_map, MsqError &err) |
void | notify_new_patch (PatchData &patch, CachedTargetData &data) |
Private Attributes | |
TargetCalculator *const | cachedCalculator |
This class is a decorator for concrete TargetCalculator that caches the previously calculated targets. This class should not be used if the target matrices produced by the concrete target calculator are a function of the vertex positions in the active mesh.
Definition at line 72 of file CachingTargetCalculator.hpp.
MBMesquite::CachingTargetCalculator::CachingTargetCalculator | ( | TargetCalculator * | cached | ) | [inline] |
Definition at line 75 of file CachingTargetCalculator.hpp.
: cachedCalculator( cached ) {}
Definition at line 42 of file CachingTargetCalculator.cpp.
bool MBMesquite::CachingTargetCalculator::get_2D_target | ( | PatchData & | pd, |
size_t | element, | ||
Sample | sample, | ||
MsqMatrix< 2, 2 > & | W_out, | ||
MsqError & | err | ||
) | [virtual] |
pd | The current PatchData |
element | The index an element within the patch data. |
sample | The sample point in the element. |
W_out | The resulting target matrix. |
Implements MBMesquite::TargetCalculator.
Definition at line 234 of file CachingTargetCalculator.cpp.
References cachedCalculator, MBMesquite::CachedTargetData::elementOffsets, MBMesquite::ExtraDataUser< CachedTargetData >::get_data(), MBMesquite::PatchData::get_samples(), have_surface_orient(), INTERNAL_ERROR, MBMesquite::MsqError::INVALID_STATE, MSQ_ERRZERO, MSQ_SETERR, MBMesquite::NodeSet::num_before(), MBMesquite::populate_data(), and MBMesquite::CachedTargetData::targets2D.
{ CachedTargetData& data = get_data( pd ); if( data.targets2D.empty() ) { if( have_surface_orient() ) { MSQ_SETERR( err )( "Incorrect surface mesh target type", MsqError::INTERNAL_ERROR ); return false; } populate_data( pd, &data, cachedCalculator, err ); MSQ_ERRZERO( err ); if( data.targets2D.empty() ) { MSQ_SETERR( err ) ( "Attempt to get 2D target for 3D element type", MsqError::INVALID_STATE ); return false; } } // calculate index of sample in array NodeSet all_samples = pd.get_samples( element ); unsigned offset = all_samples.num_before( sample ); W_out = data.targets2D[data.elementOffsets[element] + offset]; return true; }
bool MBMesquite::CachingTargetCalculator::get_3D_target | ( | PatchData & | pd, |
MsqMatrix< 3, 3 > & | W_out, | ||
) | [virtual] |
Definition at line 216 of file CachingTargetCalculator.cpp.
References cachedCalculator, MBMesquite::CachedTargetData::elementOffsets, MBMesquite::ExtraDataUser< CachedTargetData >::get_data(), MBMesquite::PatchData::get_samples(), MSQ_ERRZERO, MBMesquite::NodeSet::num_before(), MBMesquite::populate_data(), and MBMesquite::CachedTargetData::targets3D.
{ CachedTargetData& data = get_data( pd ); if( data.targets3D.empty() ) { populate_data( pd, &data, cachedCalculator, err ); MSQ_ERRZERO( err ); } // calculate index of sample in array NodeSet all_samples = pd.get_samples( element ); unsigned offset = all_samples.num_before( sample ); W_out = data.targets3D[data.elementOffsets[element] + offset]; return true; }
TargetCalculator* MBMesquite::CachingTargetCalculator::get_cached_calculator | ( | ) | const [inline] |
Definition at line 79 of file CachingTargetCalculator.hpp.
References cachedCalculator.
{ return cachedCalculator; }
bool MBMesquite::CachingTargetCalculator::get_surface_target | ( | PatchData & | pd, |
MsqMatrix< 3, 2 > & | W_out, | ||
) | [virtual] |
Definition at line 264 of file CachingTargetCalculator.cpp.
References cachedCalculator, MBMesquite::CachedTargetData::elementOffsets, MBMesquite::ExtraDataUser< CachedTargetData >::get_data(), MBMesquite::PatchData::get_samples(), have_surface_orient(), INTERNAL_ERROR, MBMesquite::MsqError::INVALID_STATE, MSQ_ERRZERO, MSQ_SETERR, MBMesquite::NodeSet::num_before(), MBMesquite::populate_data(), and MBMesquite::CachedTargetData::targetsSurface.
{ CachedTargetData& data = get_data( pd ); if( data.targetsSurface.empty() ) { if( !have_surface_orient() ) { MSQ_SETERR( err )( "Incorrect surface mesh target type", MsqError::INTERNAL_ERROR ); return false; } populate_data( pd, &data, cachedCalculator, err ); MSQ_ERRZERO( err ); if( data.targetsSurface.empty() ) { MSQ_SETERR( err ) ( "Attempt to get 2D target for 3D element type", MsqError::INVALID_STATE ); return false; } } // calculate index of sample in array NodeSet all_samples = pd.get_samples( element ); unsigned offset = all_samples.num_before( sample ); W_out = data.targetsSurface[data.elementOffsets[element] + offset]; return true; }
virtual bool MBMesquite::CachingTargetCalculator::have_surface_orient | ( | ) | const [inline, virtual] |
If true, then the targets for surface elements attempt some control of orientation and therefore get_surface_target must be used to get the targets. If false, then the target contains no orientation data and is therefore the same as the corresponding 2D target for surface elements. In this case, get_2D_target should be used.
Definition at line 91 of file CachingTargetCalculator.hpp.
References cachedCalculator, and MBMesquite::TargetCalculator::have_surface_orient().
Referenced by get_2D_target(), get_surface_target(), and notify_sub_patch().
{ return cachedCalculator->have_surface_orient(); }
void MBMesquite::CachingTargetCalculator::notify_new_patch | ( | PatchData & | patch, |
CachedTargetData & | data | ||
) | [protected, virtual] |
Implements MBMesquite::ExtraDataUser< CachedTargetData >.
Definition at line 44 of file CachingTargetCalculator.cpp.
References MBMesquite::CachedTargetData::clear().
{ data.clear(); }
void MBMesquite::CachingTargetCalculator::notify_patch_destroyed | ( | CachedTargetData & | d | ) | [protected, virtual] |
Definition at line 49 of file CachingTargetCalculator.cpp.
{ data.clear(); }
void MBMesquite::CachingTargetCalculator::notify_sub_patch | ( | PatchData & | orig_patch, |
CachedTargetData & | data, | ||
PatchData & | sub_patch, | ||
const size_t * | vertex_index_map, | ||
const size_t * | element_index_map, | ||
Definition at line 54 of file CachingTargetCalculator.cpp.
References MBMesquite::CachedTargetData::clear(), MBMesquite::PatchData::element_by_index(), MBMesquite::CachedTargetData::elementOffsets, MBMesquite::ExtraDataUser< CachedTargetData >::get_data(), MBMesquite::MsqMeshEntity::get_element_type(), MBMesquite::PatchData::get_samples(), MBMesquite::CachedTargetData::has_data(), have_surface_orient(), MBMesquite::PatchData::num_elements(), MBMesquite::NodeSet::num_nodes(), MBMesquite::CachedTargetData::targets2D, MBMesquite::CachedTargetData::targets3D, and MBMesquite::CachedTargetData::targetsSurface.
{ // If no cached data for this patch, just return if( data.has_data() ) return; // Create a new cached data object on the subpatch CachedTargetData& sub_data = get_data( subpatch ); sub_data.clear(); // populate the element offset list, and count the total // number of cached target matrices. sub_data.elementOffsets.resize( subpatch.num_elements() ); size_t count_2D = 0, count_3D = 0; for( size_t i = 0; i < subpatch.num_elements(); ++i ) { EntityTopology type = subpatch.element_by_index( i ).get_element_type(); size_t& count = ( TopologyInfo::dimension( type ) == 2 ) ? count_2D : count_3D; sub_data.elementOffsets[i] = count; NodeSet samples = subpatch.get_samples( i ); count += samples.num_nodes(); } const bool orient = have_surface_orient(); sub_data.targets3D.resize( count_3D ); if( orient ) sub_data.targetsSurface.resize( count_2D ); else sub_data.targets2D.resize( count_2D ); for( size_t i = 0; i < subpatch.num_elements(); ++i ) { EntityTopology type = subpatch.element_by_index( i ).get_element_type(); size_t off = sub_data.elementOffsets[i]; size_t old_off = data.elementOffsets[element_map[i]]; NodeSet samples = subpatch.get_samples( i ); size_t count = samples.num_nodes(); if( TopologyInfo::dimension( type ) == 3 ) memcpy( &sub_data.targets3D[off], &data.targets3D[old_off], count * sizeof( MsqMatrix< 3, 3 > ) ); else if( orient ) memcpy( &sub_data.targetsSurface[off], &data.targetsSurface[old_off], count * sizeof( MsqMatrix< 3, 2 > ) ); else memcpy( &sub_data.targets2D[off], &data.targets2D[old_off], count * sizeof( MsqMatrix< 2, 2 > ) ); } }
TargetCalculator* const MBMesquite::CachingTargetCalculator::cachedCalculator [private] |
Definition at line 105 of file CachingTargetCalculator.hpp.
Referenced by get_2D_target(), get_3D_target(), get_cached_calculator(), get_surface_target(), and have_surface_orient().
