MBMesquite::CachingTargetCalculator Member List
This is the complete list of members for MBMesquite::CachingTargetCalculator, including all inherited members.
aspect(const MsqMatrix< 3, 3 > &W)MBMesquite::TargetCalculator [static]
aspect(const MsqMatrix< 3, 2 > &W)MBMesquite::TargetCalculator [static]
aspect(const MsqMatrix< 2, 2 > &W)MBMesquite::TargetCalculator [static]
cachedCalculatorMBMesquite::CachingTargetCalculator [private]
CachingTargetCalculator(TargetCalculator *cached)MBMesquite::CachingTargetCalculator [inline]
DataType typedefMBMesquite::ExtraDataUser< CachedTargetData > [private]
ExtraDataUser()MBMesquite::ExtraDataUser< CachedTargetData > [private]
factor_2D(const MsqMatrix< 2, 2 > &W, double &Lambda, MsqMatrix< 2, 2 > &V, MsqMatrix< 2, 2 > &Q, MsqMatrix< 2, 2 > &Delta, MsqError &err)MBMesquite::TargetCalculator [static]
factor_3D(const MsqMatrix< 3, 3 > &W, double &Lambda, MsqMatrix< 3, 3 > &V, MsqMatrix< 3, 3 > &Q, MsqMatrix< 3, 3 > &Delta, MsqError &err)MBMesquite::TargetCalculator [static]
factor_surface(const MsqMatrix< 3, 2 > &W, double &Lambda, MsqMatrix< 3, 2 > &V, MsqMatrix< 2, 2 > &Q, MsqMatrix< 2, 2 > &Delta, MsqError &err)MBMesquite::TargetCalculator [static]
get_2D_target(PatchData &pd, size_t element, Sample sample, MsqMatrix< 2, 2 > &W_out, MsqError &err)MBMesquite::CachingTargetCalculator [virtual]
get_3D_target(PatchData &pd, size_t element, Sample sample, MsqMatrix< 3, 3 > &W_out, MsqError &err)MBMesquite::CachingTargetCalculator [virtual]
get_cached_calculator() const MBMesquite::CachingTargetCalculator [inline]
get_data(PatchData &patch)MBMesquite::ExtraDataUser< CachedTargetData > [private]
get_data_ptr(PatchData &patch)MBMesquite::ExtraDataUser< CachedTargetData > [private]
get_refmesh_Jacobian_2D(ReferenceMeshInterface *ref_mesh, PatchData &active_mesh, size_t element_no, Sample sample_no, MsqMatrix< 3, 2 > &W_out, MsqError &err)MBMesquite::TargetCalculator [static]
get_refmesh_Jacobian_3D(ReferenceMeshInterface *ref_mesh, PatchData &active_mesh, size_t element_no, Sample sample_no, MsqMatrix< 3, 3 > &W_out, MsqError &err)MBMesquite::TargetCalculator [static]
get_surface_target(PatchData &pd, size_t element, Sample sample, MsqMatrix< 3, 2 > &W_out, MsqError &err)MBMesquite::CachingTargetCalculator [virtual]
have_surface_orient() const MBMesquite::CachingTargetCalculator [inline, virtual]
ideal_shape_2D(EntityTopology element_type, Sample s, const PatchData &pd, MsqMatrix< 2, 2 > &W, MsqError &err)MBMesquite::TargetCalculator [static]
ideal_shape_3D(EntityTopology element_type, Sample s, const PatchData &pd, MsqMatrix< 3, 3 > &W, MsqError &err)MBMesquite::TargetCalculator [static]
ideal_skew_2D(EntityTopology element_type, Sample s, const PatchData &pd, MsqMatrix< 2, 2 > &W, MsqError &err)MBMesquite::TargetCalculator [static]
ideal_skew_3D(EntityTopology element_type, Sample s, const PatchData &pd, MsqMatrix< 3, 3 > &W, MsqError &err)MBMesquite::TargetCalculator [static]
initialize_queue(MeshDomainAssoc *mesh_and_domain, const Settings *settings, MsqError &err)MBMesquite::TargetCalculator [virtual]
jacobian_2D(PatchData &pd, EntityTopology element_type, int num_nodes, Sample location, const Vector3D *coords, MsqMatrix< 3, 2 > &W_out, MsqError &err)MBMesquite::TargetCalculator [static]
jacobian_3D(PatchData &pd, EntityTopology element_type, int num_nodes, Sample location, const Vector3D *coords, MsqMatrix< 3, 3 > &W_out, MsqError &err)MBMesquite::TargetCalculator [static]
new_aspect_2D(const MsqVector< 2 > &r)MBMesquite::TargetCalculator [static]
new_aspect_2D(double rho)MBMesquite::TargetCalculator [static]
new_aspect_3D(const MsqVector< 3 > &r)MBMesquite::TargetCalculator [static]
new_orientation_2D(const MsqVector< 3 > &b1, const MsqVector< 3 > &b2)MBMesquite::TargetCalculator [static]
new_orientation_3D(const MsqVector< 3 > &b1, const MsqVector< 3 > &b2)MBMesquite::TargetCalculator [static]
notify_new_patch(PatchData &patch, CachedTargetData &data)MBMesquite::CachingTargetCalculator [protected, virtual]
notify_patch_destroyed(CachedTargetData &d)MBMesquite::CachingTargetCalculator [protected, virtual]
ExtraDataUser< CachedTargetData >::notify_patch_destroyed(ExtraUserData< CachedTargetData > *data)MBMesquite::ExtraDataUser< CachedTargetData > [private]
notify_sub_patch(PatchData &orig_patch, CachedTargetData &data, PatchData &sub_patch, const size_t *vertex_index_map, const size_t *element_index_map, MsqError &err)MBMesquite::CachingTargetCalculator [protected, virtual]
set_data(PatchData &patch, const CachedTargetData &data)MBMesquite::ExtraDataUser< CachedTargetData > [private]
shape(const MsqMatrix< 3, 3 > &W)MBMesquite::TargetCalculator [static]
shape(const MsqMatrix< 3, 2 > &W)MBMesquite::TargetCalculator [static]
shape(const MsqMatrix< 2, 2 > &W)MBMesquite::TargetCalculator [static]
size(const MsqMatrix< 3, 3 > &W)MBMesquite::TargetCalculator [static]
size(const MsqMatrix< 3, 2 > &W)MBMesquite::TargetCalculator [static]
size(const MsqMatrix< 2, 2 > &W)MBMesquite::TargetCalculator [static]
skew(const MsqMatrix< 3, 3 > &W)MBMesquite::TargetCalculator [static]
skew(const MsqMatrix< 3, 2 > &W)MBMesquite::TargetCalculator [static]
skew(const MsqMatrix< 2, 2 > &W)MBMesquite::TargetCalculator [static]
~CachingTargetCalculator()MBMesquite::CachingTargetCalculator [virtual]
~ExtraDataUser()MBMesquite::ExtraDataUser< CachedTargetData > [private, virtual]
~TargetCalculator()MBMesquite::TargetCalculator [virtual]
