MOAB: Mesh Oriented datABase
(version 5.2.1)
00001 /* ***************************************************************** 00002 MESQUITE -- The Mesh Quality Improvement Toolkit 00003 00004 Copyright 2006 Sandia National Laboratories. Developed at the 00005 University of Wisconsin--Madison under SNL contract number 00006 624796. The U.S. Government and the University of Wisconsin 00007 retain certain rights to this software. 00008 00009 This library is free software; you can redistribute it and/or 00010 modify it under the terms of the GNU Lesser General Public 00011 License as published by the Free Software Foundation; either 00012 version 2.1 of the License, or (at your option) any later version. 00013 00014 This library is distributed in the hope that it will be useful, 00015 but WITHOUT ANY WARRANTY; without even the implied warranty of 00016 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00017 Lesser General Public License for more details. 00018 00019 You should have received a copy of the GNU Lesser General Public License 00020 (lgpl.txt) along with this library; if not, write to the Free Software 00021 Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA 00022 00023 (2006) kraftche@cae.wisc.edu 00024 00025 ***************************************************************** */ 00026 00027 /** \file TargetCalculator.hpp 00028 * \brief 00029 * \author Jason Kraftcheck 00030 */ 00031 00032 #ifndef MSQ_TARGET_CALCULATOR_HPP 00033 #define MSQ_TARGET_CALCULATOR_HPP 00034 00035 #include "Mesquite.hpp" 00036 #include "Sample.hpp" 00037 #include "MsqMatrix.hpp" 00038 #include "MeshInterface.hpp" 00039 #include <stddef.h> 00040 00041 namespace MBMesquite 00042 { 00043 00044 class PatchData; 00045 class MsqError; 00046 class ReferenceMeshInterface; 00047 class Mesh; 00048 class MeshDomain; 00049 class Settings; 00050 00051 class MESQUITE_EXPORT TargetCalculator 00052 { 00053 public: 00054 virtual ~TargetCalculator(); 00055 00056 //!\brief Called at start of instruction queue processing 00057 //! 00058 //! Do any preliminary global initialization, consistency checking, 00059 //! etc. Default implementation does nothing. 00060 virtual void initialize_queue( MeshDomainAssoc* mesh_and_domain, const Settings* settings, MsqError& err ); 00061 00062 /**\brief Get a target matrix 00063 * 00064 *\param pd The current PatchData 00065 *\param element The index an element within the patch data. 00066 *\param sample The sample point in the element. 00067 *\param W_out The resulting target matrix. 00068 */ 00069 virtual bool get_3D_target( PatchData& pd, size_t element, Sample sample, MsqMatrix< 3, 3 >& W_out, 00070 MsqError& err ) = 0; 00071 00072 /**\brief Get a target matrix 00073 * 00074 *\param pd The current PatchData 00075 *\param element The index an element within the patch data. 00076 *\param sample The sample point in the element. 00077 *\param W_out The resulting target matrix. 00078 */ 00079 virtual bool get_surface_target( PatchData& pd, size_t element, Sample sample, MsqMatrix< 3, 2 >& W_out, 00080 MsqError& err ) = 0; 00081 00082 /**\brief Get a target matrix 00083 * 00084 *\param pd The current PatchData 00085 *\param element The index an element within the patch data. 00086 *\param sample The sample point in the element. 00087 *\param W_out The resulting target matrix. 00088 */ 00089 virtual bool get_2D_target( PatchData& pd, size_t element, Sample sample, MsqMatrix< 2, 2 >& W_out, 00090 MsqError& err ) = 0; 00091 00092 /**\brief Use 3x2 W for surface elements if true, 2x2 W if false 00093 * 00094 * If true, then the targets for surface elements attempt some 00095 * control of orientation and therefore get_surface_target must 00096 * be used to get the targets. If false, then the target contains 00097 * no orientation data and is therefore the same as the corresponding 00098 * 2D target for surface elements. In this case, get_2D_target should 00099 * be used. 00100 */ 00101 virtual bool have_surface_orient() const = 0; 00102 00103 /**\brief Factor some existing target or Jacobian matrix 00104 * 00105 * Utility method for subclasses to use in their implementation 00106 * of get_3D_target. 00107 *\param W The matrix to factor 00108 *\param Lambda Output: the size factor of W 00109 *\praam V Output: the orientation factor of V 00110 *\param Q Output: the skew factor of W 00111 *\param Delta Output: the aspect ratio factor of W 00112 *\return bool True if W can be factored, false otherwise. 00113 */ 00114 static bool factor_3D( const MsqMatrix< 3, 3 >& W, double& Lambda, MsqMatrix< 3, 3 >& V, MsqMatrix< 3, 3 >& Q, 00115 MsqMatrix< 3, 3 >& Delta, MsqError& err ); 00116 00117 /**\brief Factor some existing target or Jacobian matrix 00118 * 00119 * Utility method for subclasses to use in their implementation 00120 * of get_2D_target 00121 *\param W The matrix to factor 00122 *\param Lambda Output: the size factor of W 00123 *\praam V Output: the orientation factor of V 00124 *\param Q Output: the skew factor of W 00125 *\param Delta Output: the aspect ratio factor of W 00126 *\return bool True if W can be factored, false otherwise. 00127 */ 00128 static bool factor_surface( const MsqMatrix< 3, 2 >& W, double& Lambda, MsqMatrix< 3, 2 >& V, MsqMatrix< 2, 2 >& Q, 00129 MsqMatrix< 2, 2 >& Delta, MsqError& err ); 00130 00131 /**\brief Factor some existing target or Jacobian matrix 00132 * 00133 * Utility method for subclasses to use in their implementation 00134 * of get_2D_target 00135 *\param W The matrix to factor 00136 *\param Lambda Output: the size factor of W 00137 *\praam V Output: the orientation factor of V 00138 *\param Q Output: the skew factor of W 00139 *\param Delta Output: the aspect ratio factor of W 00140 *\return bool True if W can be factored, false otherwise. 00141 */ 00142 static bool factor_2D( const MsqMatrix< 2, 2 >& W, double& Lambda, MsqMatrix< 2, 2 >& V, MsqMatrix< 2, 2 >& Q, 00143 MsqMatrix< 2, 2 >& Delta, MsqError& err ); 00144 00145 /**\brief Get size component of W */ 00146 static double size( const MsqMatrix< 3, 3 >& W ); 00147 /**\brief Get size component of W */ 00148 static double size( const MsqMatrix< 3, 2 >& W ); 00149 /**\brief Get size component of W */ 00150 static double size( const MsqMatrix< 2, 2 >& W ); 00151 00152 /**\brief Get skew component of W */ 00153 static MsqMatrix< 3, 3 > skew( const MsqMatrix< 3, 3 >& W ); 00154 /**\brief Get skew component of W */ 00155 static MsqMatrix< 2, 2 > skew( const MsqMatrix< 3, 2 >& W ); 00156 /**\brief Get skew component of W */ 00157 static MsqMatrix< 2, 2 > skew( const MsqMatrix< 2, 2 >& W ); 00158 00159 /**\brief Get skew component of W */ 00160 static MsqMatrix< 3, 3 > aspect( const MsqMatrix< 3, 3 >& W ); 00161 /**\brief Get skew component of W */ 00162 static MsqMatrix< 2, 2 > aspect( const MsqMatrix< 3, 2 >& W ); 00163 /**\brief Get skew component of W */ 00164 static MsqMatrix< 2, 2 > aspect( const MsqMatrix< 2, 2 >& W ); 00165 00166 /**\brief Get shape (skew and aspect) component of W */ 00167 static MsqMatrix< 3, 3 > shape( const MsqMatrix< 3, 3 >& W ); 00168 /**\brief Get skew component of W */ 00169 static MsqMatrix< 2, 2 > shape( const MsqMatrix< 3, 2 >& W ); 00170 /**\brief Get skew component of W */ 00171 static MsqMatrix< 2, 2 > shape( const MsqMatrix< 2, 2 >& W ); 00172 00173 /**\brief Create a new orientation matrix 00174 * 00175 * Create an orientation matrix such that 00176 * the first and second Jacobian columns of W are aligned to 00177 * the passed vectors. 00178 */ 00179 static MsqMatrix< 3, 3 > new_orientation_3D( const MsqVector< 3 >& b1, const MsqVector< 3 >& b2 ); 00180 /**\brief Create a new orientation matrix 00181 * 00182 * Create an orientation matrix such that 00183 * the first and second Jacobian columns of W are aligned to 00184 * the passed vectors. 00185 */ 00186 static MsqMatrix< 3, 2 > new_orientation_2D( const MsqVector< 3 >& b1, const MsqVector< 3 >& b2 ); 00187 00188 /**\brief Get skew matrix for an ideally shaped element */ 00189 static void ideal_skew_3D( EntityTopology element_type, Sample s, const PatchData& pd, MsqMatrix< 3, 3 >& W, 00190 MsqError& err ); 00191 00192 /**\brief Get skew matrix for an ideally shaped element */ 00193 static void ideal_skew_2D( EntityTopology element_type, Sample s, const PatchData& pd, MsqMatrix< 2, 2 >& W, 00194 MsqError& err ); 00195 00196 /**\brief Get skew matrix for an ideally shaped element */ 00197 static void ideal_shape_3D( EntityTopology element_type, Sample s, const PatchData& pd, MsqMatrix< 3, 3 >& W, 00198 MsqError& err ); 00199 00200 /**\brief Get skew matrix for an ideally shaped element */ 00201 static void ideal_shape_2D( EntityTopology element_type, Sample s, const PatchData& pd, MsqMatrix< 2, 2 >& W, 00202 MsqError& err ); 00203 00204 /**\brief Create a new aspect ratio matrix 00205 * 00206 * Create an aspect ratio matrix such that the ratio of column 00207 * lengths is proportional to the ratio of the corresponding pair 00208 * of values in the passed vector. 00209 */ 00210 static MsqMatrix< 3, 3 > new_aspect_3D( const MsqVector< 3 >& r ); 00211 00212 /**\brief Create a new aspect ratio matrix 00213 * 00214 * Create an aspect ratio matrix such that the ratio of column 00215 * lengths is proportional to the ratio of the corresponding pair 00216 * of values in the passed vector. 00217 */ 00218 static MsqMatrix< 2, 2 > new_aspect_2D( const MsqVector< 2 >& r ); 00219 00220 /**\brief Create a new aspect ratio matrix 00221 * 00222 * Create an aspect ratio matrix such that the ratio of column 00223 * lengths is the passed value. 00224 */ 00225 static MsqMatrix< 2, 2 > new_aspect_2D( double rho ); 00226 00227 /**\brief Calculate the Jacobian given element vertex coordinates */ 00228 static void jacobian_3D( PatchData& pd, // for mapping function list 00229 EntityTopology element_type, int num_nodes, Sample location, const Vector3D* coords, 00230 MsqMatrix< 3, 3 >& W_out, MsqError& err ); 00231 00232 /**\brief Calculate the Jacobian given element vertex coordinates */ 00233 static void jacobian_2D( PatchData& pd, // for mapping function list 00234 EntityTopology element_type, int num_nodes, Sample location, const Vector3D* coords, 00235 MsqMatrix< 3, 2 >& W_out, MsqError& err ); 00236 00237 static void get_refmesh_Jacobian_3D( ReferenceMeshInterface* ref_mesh, PatchData& active_mesh, size_t element_no, 00238 Sample sample_no, MsqMatrix< 3, 3 >& W_out, MsqError& err ); 00239 00240 static void get_refmesh_Jacobian_2D( ReferenceMeshInterface* ref_mesh, PatchData& active_mesh, size_t element_no, 00241 Sample sample_no, MsqMatrix< 3, 2 >& W_out, MsqError& err ); 00242 }; 00243 00244 } // namespace MBMesquite 00245 00246 #endif
