MOAB: Mesh Oriented datABase
(version 5.3.1)
Read targets from tag data. More...
#include <TargetReader.hpp>
Public Member Functions | |
MESQUITE_EXPORT | TargetReader (bool oriented_2D_targets, std::string tag_base_name="MSQ_TARGET_MATRIX") |
virtual MESQUITE_EXPORT | ~TargetReader () |
virtual MESQUITE_EXPORT bool | get_3D_target (PatchData &pd, size_t element, Sample sample, MsqMatrix< 3, 3 > &W_out, MsqError &err) |
Get a target matrix. | |
virtual MESQUITE_EXPORT bool | get_2D_target (PatchData &pd, size_t element, Sample sample, MsqMatrix< 2, 2 > &W_out, MsqError &err) |
virtual MESQUITE_EXPORT bool | get_surface_target (PatchData &pd, size_t element, Sample sample, MsqMatrix< 3, 2 > &W_out, MsqError &err) |
virtual MESQUITE_EXPORT bool | have_surface_orient () const |
Use 3x2 W for surface elements if true, 2x2 W if false. | |
Private Member Functions | |
virtual void | notify_patch_destroyed (TargetReaderData &data) |
virtual void | notify_new_patch (PatchData &pd, TargetReaderData &data) |
virtual void | notify_sub_patch (PatchData &pd, TargetReaderData &data, PatchData &subpatch, const size_t *vert_map, const size_t *elem_map, MsqError &err) |
Private Attributes | |
std::string | tagBaseName |
Base name for tags used to store targets. | |
bool | orient2D |
2D targets included orientation (3x2 rather than 2x2) |
Definition at line 63 of file TargetReader.hpp.
MBMesquite::TargetReader::TargetReader | ( | bool | oriented_2D_targets, |
std::string | tag_base_name = "MSQ_TARGET_MATRIX" |
Definition at line 74 of file TargetReader.cpp.
: tagBaseName( name ), orient2D( orient2d ) {}
MBMesquite::TargetReader::~TargetReader | ( | ) | [virtual] |
Definition at line 76 of file TargetReader.cpp.
bool MBMesquite::TargetReader::get_2D_target | ( | PatchData & | pd, |
size_t | element, | ||
Sample | sample, | ||
MsqMatrix< 2, 2 > & | W_out, | ||
MsqError & | err | ||
) | [virtual] |
pd | The current PatchData |
element | The index an element within the patch data. |
sample | The sample point in the element. |
W_out | The resulting target matrix. |
Implements MBMesquite::TargetCalculator.
Definition at line 129 of file TargetReader.cpp.
References dim, MBMesquite::PatchData::element_by_index(), MBMesquite::TargetReaderData::elementIndex, MBMesquite::ExtraDataUser< TargetReaderData >::get_data(), MBMesquite::PatchData::get_element_handles_array(), MBMesquite::MsqMeshEntity::get_element_type(), MBMesquite::PatchData::get_mesh(), MBMesquite::PatchData::get_samples(), MBMesquite::get_tag(), MBMesquite::TargetReaderData::handles2D, INTERNAL_ERROR, MBMesquite::MsqError::INVALID_STATE, MSQ_CHKERR, MSQ_ERRZERO, MSQ_SETERR, MBMesquite::NodeSet::num_before(), MBMesquite::NodeSet::num_nodes(), orient2D, MBMesquite::Mesh::tag_get_element_data(), tagBaseName, and MBMesquite::TargetReaderData::targets2D.
Referenced by TargetReadWriteTest::read_write_2D_targets().
{ // which type of 2D target do we actually have if( orient2D ) { MSQ_SETERR( err )( "Incorrect surface mesh target type", MsqError::INTERNAL_ERROR ); return false; } // calculate index of sample in array NodeSet all_samples = pd.get_samples( element ); unsigned offset = all_samples.num_before( sample ); int dim = TopologyInfo::dimension( pd.element_by_index( element ).get_element_type() ); if( dim == 3 ) { MSQ_SETERR( err ) ( "Attempt to read surface target for region element", MsqError::INVALID_STATE ); return false; } TargetReaderData& data = get_data( pd ); if( !data.targets2D.empty() && data.elementIndex == element ) { assert( offset < data.targets2D.size() ); W_out = data.targets2D[offset]; return true; } const unsigned num_samples = all_samples.num_nodes(); const unsigned handle_idx = num_samples - 1; // get the tag handle const size_t INVALID_HANDLE = (size_t)-1; if( data.handles2D.size() <= handle_idx ) data.handles2D.resize( handle_idx + 1, (TagHandle)INVALID_HANDLE ); TagHandle& tag_handle = data.handles2D[handle_idx]; if( tag_handle == (TagHandle)INVALID_HANDLE ) { tag_handle = get_tag( pd.get_mesh(), num_samples, 2, tagBaseName.c_str(), orient2D, err ); MSQ_ERRZERO( err ); assert( tag_handle != (TagHandle)INVALID_HANDLE ); } // get the tag data data.targets2D.resize( num_samples ); pd.get_mesh()->tag_get_element_data( tag_handle, 1, pd.get_element_handles_array() + element, &data.targets2D[0], err ); if( MSQ_CHKERR( err ) ) { data.targets2D.clear(); return false; } data.elementIndex = element; W_out = data.targets2D[offset]; return true; }
bool MBMesquite::TargetReader::get_3D_target | ( | PatchData & | pd, |
MsqMatrix< 3, 3 > & | W_out, | ||
) | [virtual] |
Definition at line 78 of file TargetReader.cpp.
References dim, MBMesquite::PatchData::element_by_index(), MBMesquite::TargetReaderData::elementIndex, MBMesquite::ExtraDataUser< TargetReaderData >::get_data(), MBMesquite::PatchData::get_element_handles_array(), MBMesquite::MsqMeshEntity::get_element_type(), MBMesquite::PatchData::get_mesh(), MBMesquite::PatchData::get_samples(), MBMesquite::get_tag(), MBMesquite::TargetReaderData::handles3D, MBMesquite::MsqError::INVALID_STATE, MSQ_CHKERR, MSQ_ERRZERO, MSQ_SETERR, MBMesquite::NodeSet::num_before(), MBMesquite::NodeSet::num_nodes(), orient2D, MBMesquite::Mesh::tag_get_element_data(), tagBaseName, and MBMesquite::TargetReaderData::targets3D.
Referenced by TargetReadWriteTest::read_write_3D_targets().
{ // calculate index of sample in array NodeSet all_samples = pd.get_samples( element ); unsigned offset = all_samples.num_before( sample ); int dim = TopologyInfo::dimension( pd.element_by_index( element ).get_element_type() ); if( dim == 2 ) { MSQ_SETERR( err ) ( "Attempt to read 3D target for surface element", MsqError::INVALID_STATE ); return false; } TargetReaderData& data = get_data( pd ); if( !data.targets3D.empty() && data.elementIndex == element ) { assert( offset < data.targets3D.size() ); W_out = data.targets3D[offset]; return true; } const unsigned num_samples = all_samples.num_nodes(); const unsigned handle_idx = num_samples - 1; // get the tag handle const size_t INVALID_HANDLE = (size_t)-1; if( data.handles3D.size() <= handle_idx ) data.handles3D.resize( handle_idx + 1, (TagHandle)INVALID_HANDLE ); TagHandle& tag_handle = data.handles3D[handle_idx]; if( tag_handle == (TagHandle)INVALID_HANDLE ) { tag_handle = get_tag( pd.get_mesh(), num_samples, 3, tagBaseName.c_str(), orient2D, err ); MSQ_ERRZERO( err ); assert( tag_handle != (TagHandle)INVALID_HANDLE ); } // get the tag data data.targets3D.resize( num_samples ); pd.get_mesh()->tag_get_element_data( tag_handle, 1, pd.get_element_handles_array() + element, &data.targets3D[0], err ); if( MSQ_CHKERR( err ) ) { data.targets3D.clear(); return false; } data.elementIndex = element; W_out = data.targets3D[offset]; return true; }
bool MBMesquite::TargetReader::get_surface_target | ( | PatchData & | pd, |
MsqMatrix< 3, 2 > & | W_out, | ||
) | [virtual] |
Definition at line 187 of file TargetReader.cpp.
References dim, MBMesquite::PatchData::element_by_index(), MBMesquite::TargetReaderData::elementIndex, MBMesquite::ExtraDataUser< TargetReaderData >::get_data(), MBMesquite::PatchData::get_element_handles_array(), MBMesquite::MsqMeshEntity::get_element_type(), MBMesquite::PatchData::get_mesh(), MBMesquite::PatchData::get_samples(), MBMesquite::get_tag(), MBMesquite::TargetReaderData::handles2D, INTERNAL_ERROR, MBMesquite::MsqError::INVALID_STATE, MSQ_CHKERR, MSQ_ERRZERO, MSQ_SETERR, MBMesquite::NodeSet::num_before(), MBMesquite::NodeSet::num_nodes(), orient2D, MBMesquite::Mesh::tag_get_element_data(), tagBaseName, and MBMesquite::TargetReaderData::targetsSurface.
Referenced by TargetReadWriteTest::read_write_surface_targets().
{ // which type of 2D target do we actually have if( !orient2D ) { MSQ_SETERR( err )( "Incorrect surface mesh target type", MsqError::INTERNAL_ERROR ); return false; } // calculate index of sample in array NodeSet all_samples = pd.get_samples( element ); unsigned offset = all_samples.num_before( sample ); int dim = TopologyInfo::dimension( pd.element_by_index( element ).get_element_type() ); if( dim == 3 ) { MSQ_SETERR( err ) ( "Attempt to read surface target for region element", MsqError::INVALID_STATE ); return false; } TargetReaderData& data = get_data( pd ); if( !data.targetsSurface.empty() && data.elementIndex == element ) { assert( offset < data.targetsSurface.size() ); W_out = data.targetsSurface[offset]; return true; } const unsigned num_samples = all_samples.num_nodes(); const unsigned handle_idx = num_samples - 1; // get the tag handle const size_t INVALID_HANDLE = (size_t)-1; if( data.handles2D.size() <= handle_idx ) data.handles2D.resize( handle_idx + 1, (TagHandle)INVALID_HANDLE ); TagHandle& tag_handle = data.handles2D[handle_idx]; if( tag_handle == (TagHandle)INVALID_HANDLE ) { tag_handle = get_tag( pd.get_mesh(), num_samples, 2, tagBaseName.c_str(), orient2D, err ); MSQ_ERRZERO( err ); assert( tag_handle != (TagHandle)INVALID_HANDLE ); } // get the tag data data.targetsSurface.resize( num_samples ); pd.get_mesh()->tag_get_element_data( tag_handle, 1, pd.get_element_handles_array() + element, &data.targetsSurface[0], err ); if( MSQ_CHKERR( err ) ) { data.targetsSurface.clear(); return false; } data.elementIndex = element; W_out = data.targetsSurface[offset]; return true; }
virtual MESQUITE_EXPORT bool MBMesquite::TargetReader::have_surface_orient | ( | ) | const [inline, virtual] |
If true, then the targets for surface elements attempt some control of orientation and therefore get_surface_target must be used to get the targets. If false, then the target contains no orientation data and is therefore the same as the corresponding 2D target for surface elements. In this case, get_2D_target should be used.
Definition at line 80 of file TargetReader.hpp.
References orient2D.
{ return orient2D; }
void MBMesquite::TargetReader::notify_new_patch | ( | PatchData & | pd, |
TargetReaderData & | data | ||
) | [private, virtual] |
Implements MBMesquite::ExtraDataUser< TargetReaderData >.
Definition at line 254 of file TargetReader.cpp.
References MBMesquite::TargetReaderData::targets2D, MBMesquite::TargetReaderData::targets3D, and MBMesquite::TargetReaderData::targetsSurface.
{ data.targets3D.clear(); data.targets2D.clear(); data.targetsSurface.clear(); }
void MBMesquite::TargetReader::notify_patch_destroyed | ( | TargetReaderData & | data | ) | [private, virtual] |
Definition at line 245 of file TargetReader.cpp.
References MBMesquite::TargetReaderData::handles2D, MBMesquite::TargetReaderData::handles3D, MBMesquite::TargetReaderData::targets2D, MBMesquite::TargetReaderData::targets3D, and MBMesquite::TargetReaderData::targetsSurface.
{ data.handles2D.clear(); data.handles3D.clear(); data.targets3D.clear(); data.targets2D.clear(); data.targetsSurface.clear(); }
void MBMesquite::TargetReader::notify_sub_patch | ( | PatchData & | pd, |
TargetReaderData & | data, | ||
PatchData & | subpatch, | ||
const size_t * | vert_map, | ||
const size_t * | elem_map, | ||
Definition at line 261 of file TargetReader.cpp.
References MBMesquite::ExtraDataUser< TargetReaderData >::get_data(), MBMesquite::TargetReaderData::handles2D, and MBMesquite::TargetReaderData::handles3D.
{ TargetReaderData& other = get_data( subpatch ); if( other.handles2D.empty() && other.handles3D.empty() ) { other.handles2D = data.handles2D; other.handles3D = data.handles3D; } }
bool MBMesquite::TargetReader::orient2D [private] |
Definition at line 92 of file TargetReader.hpp.
Referenced by get_2D_target(), get_3D_target(), get_surface_target(), and have_surface_orient().
std::string MBMesquite::TargetReader::tagBaseName [private] |
Definition at line 91 of file TargetReader.hpp.
Referenced by get_2D_target(), get_3D_target(), and get_surface_target().
