MOAB: Mesh Oriented datABase
(version 5.4.0)
00001 /* ***************************************************************** 00002 MESQUITE -- The Mesh Quality Improvement Toolkit 00003 00004 Copyright 2007 Sandia National Laboratories. Developed at the 00005 University of Wisconsin--Madison under SNL contract number 00006 624796. The U.S. Government and the University of Wisconsin 00007 retain certain rights to this software. 00008 00009 This library is free software; you can redistribute it and/or 00010 modify it under the terms of the GNU Lesser General Public 00011 License as published by the Free Software Foundation; either 00012 version 2.1 of the License, or (at your option) any later version. 00013 00014 This library is distributed in the hope that it will be useful, 00015 but WITHOUT ANY WARRANTY; without even the implied warranty of 00016 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00017 Lesser General Public License for more details. 00018 00019 You should have received a copy of the GNU Lesser General Public License 00020 (lgpl.txt) along with this library; if not, write to the Free Software 00021 Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA 00022 00023 (2009) kraftche@cae.wisc.edu 00024 00025 ***************************************************************** */ 00026 00027 /** \file HigherOrderTest.cpp 00028 * \brief 00029 * \author Jason Kraftcheck 00030 */ 00031 00032 #define HAVE_HO_HEX 00033 #define TEST_HO_QUAD 00034 00035 #include "Mesquite.hpp" 00036 #include "MsqError.hpp" 00037 00038 #include "ArrayMesh.hpp" 00039 #include "DomainClassifier.hpp" 00040 #include "PlanarDomain.hpp" 00041 #include "MeshDomain1D.hpp" 00042 00043 #include "IdealShapeTarget.hpp" 00044 #include "TInverseMeanRatio.hpp" 00045 #include "TShapeSizeOrientNB1.hpp" 00046 #include "TShapeSizeNB3.hpp" 00047 #include "TQualityMetric.hpp" 00048 #include "PMeanPTemplate.hpp" 00049 #include "LPtoPTemplate.hpp" 00050 #include "SteepestDescent.hpp" 00051 #include "FeasibleNewton.hpp" 00052 #include "InstructionQueue.hpp" 00053 #include "TerminationCriterion.hpp" 00054 00055 //#include "TriLagrangeShape.hpp" 00056 //#include "TetLagrangeShape.hpp" 00057 //#include "QuadLagrangeShape.hpp" 00058 #ifdef HAVE_HO_HEX 00059 #include "HexLagrangeShape.hpp" 00060 #endif 00061 00062 #include "UnitUtil.hpp" 00063 00064 using namespace MBMesquite; 00065 00066 #include <iostream> 00067 using std::cerr; 00068 using std::cout; 00069 using std::endl; 00070 using std::vector; 00071 00072 const int MAX_ITERATIONS = 1000; 00073 const double QEL = 1.0; // edge length of ideal quad 00074 00075 class HigherOrderTest : public CppUnit::TestFixture 00076 { 00077 private: 00078 CPPUNIT_TEST_SUITE( HigherOrderTest ); 00079 CPPUNIT_TEST( test_tri_basic_ideal ); 00080 CPPUNIT_TEST( test_tri_basic_mid_spin ); 00081 CPPUNIT_TEST( test_tri_basic_mid_convex ); 00082 CPPUNIT_TEST( test_tri_basic_peak_up ); 00083 CPPUNIT_TEST( test_tri_basic_peak_down ); 00084 CPPUNIT_TEST( test_tri_basic_peak_over ); 00085 #ifdef TEST_HO_QUAD 00086 CPPUNIT_TEST( test_quad_basic_ideal ); 00087 CPPUNIT_TEST( test_quad_basic_mid_spin ); 00088 CPPUNIT_TEST( test_quad_basic_mid_convex ); 00089 CPPUNIT_TEST( test_quad_basic_left_down ); 00090 CPPUNIT_TEST( test_quad_basic_top_down ); 00091 CPPUNIT_TEST( test_quad_basic_right_up ); 00092 CPPUNIT_TEST( test_quad_basic_left_over ); 00093 #endif 00094 CPPUNIT_TEST( test_tet_basic_ideal ); 00095 CPPUNIT_TEST( test_tet_basic_mid_spin ); 00096 CPPUNIT_TEST( test_tet_basic_mid_convex ); 00097 CPPUNIT_TEST( test_tet_basic_apex_up ); 00098 CPPUNIT_TEST( test_tet_basic_apex_down ); 00099 CPPUNIT_TEST( test_tet_basic_apex_over ); 00100 #ifdef HAVE_HO_HEX 00101 CPPUNIT_TEST( test_hex_basic ); 00102 #endif 00103 // CPPUNIT_TEST (test_tri_open_domain); 00104 // CPPUNIT_TEST (test_tri_slac); 00105 CPPUNIT_TEST_SUITE_END(); 00106 00107 // TriLagrangeShape tri_shape; 00108 // TetLagrangeShape tet_shape; 00109 // QuadLagrangeShape quad_shape; 00110 #ifdef HAVE_HO_HEX 00111 HexLagrangeShape hex_shape; 00112 #endif 00113 InstructionQueue q; 00114 TShapeSizeNB3 tm; 00115 IdealShapeTarget tc; 00116 TQualityMetric metric; 00117 PMeanPTemplate func; 00118 SteepestDescent solver; 00119 TerminationCriterion crit, outer; 00120 00121 public: 00122 HigherOrderTest() : metric( &tc, &tm ), func( 1, &metric ), solver( &func ) 00123 { 00124 MsqError err; 00125 // q.set_mapping_function( &tri_shape ); 00126 // q.set_mapping_function( &tet_shape ); 00127 // q.set_mapping_function( &quad_shape ); 00128 #ifdef HAVE_HO_HEX 00129 q.set_mapping_function( &hex_shape ); 00130 #endif 00131 q.set_master_quality_improver( &solver, err ); 00132 00133 q.set_slaved_ho_node_mode( Settings::SLAVE_NONE ); 00134 00135 outer.add_iteration_limit( 1 ); 00136 crit.add_absolute_vertex_movement( 1e-6 ); 00137 crit.add_iteration_limit( MAX_ITERATIONS ); 00138 solver.set_outer_termination_criterion( &outer ); 00139 solver.set_inner_termination_criterion( &crit ); 00140 } 00141 00142 bool hit_iteration_limit() const 00143 { 00144 return crit.get_iteration_count() >= MAX_ITERATIONS; 00145 } 00146 00147 void test_tri_basic_ideal(); 00148 void test_tri_basic_mid_spin(); 00149 void test_tri_basic_mid_convex(); 00150 void test_tri_basic_peak_up(); 00151 void test_tri_basic_peak_down(); 00152 void test_tri_basic_peak_over(); 00153 void test_quad_basic_ideal(); 00154 void test_quad_basic_mid_spin(); 00155 void test_quad_basic_mid_convex(); 00156 void test_quad_basic_left_down(); 00157 void test_quad_basic_top_down(); 00158 void test_quad_basic_right_up(); 00159 void test_quad_basic_left_over(); 00160 void test_tet_basic_ideal(); 00161 void test_tet_basic_mid_spin(); 00162 void test_tet_basic_mid_convex(); 00163 void test_tet_basic_apex_up(); 00164 void test_tet_basic_apex_down(); 00165 void test_tet_basic_apex_over(); 00166 void test_hex_basic(); 00167 void test_tri_open_domain(); 00168 void test_tri_slac(); 00169 00170 void test_tri_open_domain( double& x1, double& x3, double& x4, double y2, double y5, double& y4 ); 00171 00172 void basic_tri_test( double& x2, 00173 double& y2, 00174 double& x3, 00175 double& y3, 00176 double& x4, 00177 double& y4, 00178 double& x5, 00179 double& y5, 00180 MsqError& err ); 00181 00182 void basic_tet_test( Vector3D& p3, 00183 Vector3D& p4, 00184 Vector3D& p5, 00185 Vector3D& p6, 00186 Vector3D& p7, 00187 Vector3D& p8, 00188 Vector3D& p9, 00189 MsqError& err ); 00190 00191 void basic_quad_test( Vector3D& p2, 00192 Vector3D& p3, 00193 Vector3D& p4, 00194 Vector3D& p5, 00195 Vector3D& p6, 00196 Vector3D& p7, 00197 MsqError& err ); 00198 00199 void basic_hex_test( Vector3D& p4, 00200 Vector3D& p5, 00201 Vector3D& p6, 00202 Vector3D& p7, 00203 Vector3D& p8, 00204 Vector3D& p9, 00205 Vector3D& p10, 00206 Vector3D& p11, 00207 Vector3D& p12, 00208 Vector3D& p13, 00209 Vector3D& p14, 00210 Vector3D& p15, 00211 Vector3D& p16, 00212 Vector3D& p17, 00213 Vector3D& p18, 00214 Vector3D& p19, 00215 MsqError& err ); 00216 }; 00217 00218 CPPUNIT_TEST_SUITE_NAMED_REGISTRATION( HigherOrderTest, "HigherOrderTest" ); 00219 CPPUNIT_TEST_SUITE_NAMED_REGISTRATION( HigherOrderTest, "Regression" ); 00220 00221 static inline double dist( double x1, double y1, double x2, double y2 ) 00222 { 00223 return sqrt( ( x1 - x2 ) * ( x1 - x2 ) + ( y1 - y2 ) * ( y1 - y2 ) ); 00224 } 00225 00226 // ideal triangle is defined such that J has unit determinant 00227 const double IDEAL_TRI_SIDE = sqrt( 2.0 / sqrt( 3.0 ) ); 00228 const double IDEAL_TRI_HEIGHT = 1 / IDEAL_TRI_SIDE; 00229 00230 int tri_mid_edge_nodes_edge_center( double x2, 00231 double y2, 00232 double x3, 00233 double y3, 00234 double x4, 00235 double y4, 00236 double x5, 00237 double y5, 00238 double epsilon ) 00239 { 00240 double x0 = 0.0, y0 = 0.0; 00241 double x1 = IDEAL_TRI_SIDE, y1 = 0.0; 00242 double x01 = 0.5 * ( x0 + x1 ); 00243 double x12 = 0.5 * ( x1 + x2 ); 00244 double x20 = 0.5 * ( x2 + x0 ); 00245 double y01 = 0.5 * ( y0 + y1 ); 00246 double y12 = 0.5 * ( y1 + y2 ); 00247 double y20 = 0.5 * ( y2 + y0 ); 00248 00249 int result = 0; 00250 if( dist( x3, y3, x01, y01 ) > epsilon ) result |= 1; 00251 if( dist( x4, y4, x12, y12 ) > epsilon ) result |= 2; 00252 if( dist( x5, y5, x20, y20 ) > epsilon ) result |= 4; 00253 00254 return result; 00255 } 00256 00257 void HigherOrderTest::test_tri_basic_ideal() 00258 { 00259 MsqPrintError err( cerr ); 00260 const double eps = 1e-4; 00261 const double x2eq = 0.5 * IDEAL_TRI_SIDE; 00262 const double y2eq = IDEAL_TRI_HEIGHT; 00263 00264 // try starting with the optimal result 00265 double x2 = x2eq; 00266 double y2 = y2eq; 00267 double x3 = 0.5 * IDEAL_TRI_SIDE; 00268 double y3 = 0.0; 00269 double x4 = 0.75 * IDEAL_TRI_SIDE; 00270 double y4 = 0.5 * IDEAL_TRI_HEIGHT; 00271 double x5 = 0.25 * IDEAL_TRI_SIDE; 00272 double y5 = 0.5 * IDEAL_TRI_HEIGHT; 00273 // crit.write_mesh_steps( "test_tri_basic_ideal", TerminationCriterion::VTK ); 00274 basic_tri_test( x2, y2, x3, y3, x4, y4, x5, y5, err ); 00275 // crit.write_mesh_steps( "", TerminationCriterion::NOTYPE ); 00276 ASSERT_NO_ERROR( err ); 00277 CPPUNIT_ASSERT( !hit_iteration_limit() ); 00278 CPPUNIT_ASSERT_DOUBLES_EQUAL( x2eq, x2, eps ); 00279 CPPUNIT_ASSERT_DOUBLES_EQUAL( y2eq, y2, eps ); 00280 int midok = tri_mid_edge_nodes_edge_center( x2, y2, x3, y3, x4, y4, x5, y5, eps ); 00281 CPPUNIT_ASSERT_EQUAL( 0, midok ); 00282 } 00283 00284 void HigherOrderTest::test_tri_basic_mid_spin() 00285 { 00286 MsqPrintError err( cerr ); 00287 const double eps = 1e-4; 00288 const double x2eq = 0.5 * IDEAL_TRI_SIDE; 00289 const double y2eq = IDEAL_TRI_HEIGHT; 00290 00291 // try moving the mid-edge nodes along the edge away from the edge center 00292 double x0 = 0.0, y0 = 0.0; 00293 double x1 = IDEAL_TRI_SIDE, y1 = 0.0; 00294 double x2 = x2eq; 00295 double y2 = y2eq; 00296 const double f = 0.7; 00297 double x3 = f * x0 + ( 1 - f ) * x1; 00298 double y3 = f * y0 + ( 1 - f ) * y1; 00299 double x4 = f * x1 + ( 1 - f ) * x2; 00300 double y4 = f * y1 + ( 1 - f ) * y2; 00301 double x5 = f * x2 + ( 1 - f ) * x0; 00302 double y5 = f * y2 + ( 1 - f ) * y0; 00303 // crit.write_mesh_steps( "test_tri_basic_mid_spin", TerminationCriterion::VTK ); 00304 basic_tri_test( x2, y2, x3, y3, x4, y4, x5, y5, err ); 00305 // crit.write_mesh_steps( "", TerminationCriterion::NOTYPE ); 00306 ASSERT_NO_ERROR( err ); 00307 CPPUNIT_ASSERT( !hit_iteration_limit() ); 00308 CPPUNIT_ASSERT_DOUBLES_EQUAL( x2eq, x2, eps ); 00309 CPPUNIT_ASSERT_DOUBLES_EQUAL( y2eq, y2, eps ); 00310 int midok = tri_mid_edge_nodes_edge_center( x2, y2, x3, y3, x4, y4, x5, y5, eps ); 00311 CPPUNIT_ASSERT_EQUAL( 0, midok ); 00312 } 00313 00314 void HigherOrderTest::test_tri_basic_mid_convex() 00315 { 00316 MsqPrintError err( cerr ); 00317 const double eps = 1e-4; 00318 const double x2eq = 0.5 * IDEAL_TRI_SIDE; 00319 const double y2eq = IDEAL_TRI_HEIGHT; 00320 00321 // try equilateral corners with all egdes convex 00322 double x2 = x2eq; 00323 double y2 = y2eq; 00324 double x3 = 0.5 * IDEAL_TRI_SIDE; 00325 double y3 = -0.3; 00326 double x4 = IDEAL_TRI_SIDE; 00327 double y4 = 0.5; 00328 double x5 = 0.0; 00329 double y5 = 0.5; 00330 basic_tri_test( x2, y2, x3, y3, x4, y4, x5, y5, err ); 00331 ASSERT_NO_ERROR( err ); 00332 CPPUNIT_ASSERT( !hit_iteration_limit() ); 00333 CPPUNIT_ASSERT_DOUBLES_EQUAL( x2eq, x2, eps ); 00334 // CPPUNIT_ASSERT_DOUBLES_EQUAL( y2eq, y2, eps ); 00335 int midok = tri_mid_edge_nodes_edge_center( x2, y2, x3, y3, x4, y4, x5, y5, eps ); 00336 CPPUNIT_ASSERT_EQUAL( 0, midok ); 00337 } 00338 00339 void HigherOrderTest::test_tri_basic_peak_up() 00340 { 00341 MsqPrintError err( cerr ); 00342 const double eps = 1e-4; 00343 const double x2eq = 0.5 * IDEAL_TRI_SIDE; 00344 const double y2eq = IDEAL_TRI_HEIGHT; 00345 00346 // try moving the top vertex up, also move mid-edge nodes proportionally 00347 double x2 = x2eq; 00348 double y2 = 2.0 * y2eq; 00349 double x3 = 0.5 * IDEAL_TRI_SIDE; 00350 double y3 = 0.0; 00351 double x4 = 1.5 * x2; 00352 double y4 = 0.5 * y2; 00353 double x5 = 0.5 * x2; 00354 double y5 = 0.5 * y2; 00355 basic_tri_test( x2, y2, x3, y3, x4, y4, x5, y5, err ); 00356 ASSERT_NO_ERROR( err ); 00357 CPPUNIT_ASSERT( !hit_iteration_limit() ); 00358 CPPUNIT_ASSERT_DOUBLES_EQUAL( x2eq, x2, eps ); 00359 CPPUNIT_ASSERT_DOUBLES_EQUAL( y2eq, y2, eps ); 00360 int midok = tri_mid_edge_nodes_edge_center( x2, y2, x3, y3, x4, y4, x5, y5, eps ); 00361 CPPUNIT_ASSERT_EQUAL( 0, midok ); 00362 } 00363 00364 void HigherOrderTest::test_tri_basic_peak_down() 00365 { 00366 MsqPrintError err( cerr ); 00367 const double eps = 1e-4; 00368 const double x2eq = 0.5 * IDEAL_TRI_SIDE; 00369 const double y2eq = IDEAL_TRI_HEIGHT; 00370 00371 // try moving the top vertex down, also move mid-edge nodes proportionally 00372 double x2 = x2eq; 00373 double y2 = 0.5 * y2eq; 00374 double x3 = 0.5 * IDEAL_TRI_SIDE; 00375 double y3 = 0.0; 00376 double x4 = 1.5 * x2; 00377 double y4 = 0.5 * y2; 00378 double x5 = 0.5 * x2; 00379 double y5 = 0.5 * y2; 00380 basic_tri_test( x2, y2, x3, y3, x4, y4, x5, y5, err ); 00381 ASSERT_NO_ERROR( err ); 00382 CPPUNIT_ASSERT( !hit_iteration_limit() ); 00383 CPPUNIT_ASSERT_DOUBLES_EQUAL( x2eq, x2, eps ); 00384 CPPUNIT_ASSERT_DOUBLES_EQUAL( y2eq, y2, eps ); 00385 int midok = tri_mid_edge_nodes_edge_center( x2, y2, x3, y3, x4, y4, x5, y5, eps ); 00386 CPPUNIT_ASSERT_EQUAL( 0, midok ); 00387 } 00388 00389 void HigherOrderTest::test_tri_basic_peak_over() 00390 { 00391 MsqPrintError err( cerr ); 00392 const double eps = 1e-4; 00393 const double x2eq = 0.5 * IDEAL_TRI_SIDE; 00394 const double y2eq = IDEAL_TRI_HEIGHT; 00395 00396 // try moving the top vertex to the right, also move mid-edge nodes proportionally 00397 double x2 = x2eq + 0.5; 00398 double y2 = y2eq; 00399 double x3 = 0.5 * IDEAL_TRI_SIDE; 00400 double y3 = 0.0; 00401 double x4 = 1.5 * x2; 00402 double y4 = 0.5 * y2; 00403 double x5 = 0.5 * x2; 00404 double y5 = 0.5 * y2; 00405 basic_tri_test( x2, y2, x3, y3, x4, y4, x5, y5, err ); 00406 ASSERT_NO_ERROR( err ); 00407 CPPUNIT_ASSERT( !hit_iteration_limit() ); 00408 CPPUNIT_ASSERT_DOUBLES_EQUAL( x2eq, x2, eps ); 00409 CPPUNIT_ASSERT_DOUBLES_EQUAL( y2eq, y2, eps ); 00410 int midok = tri_mid_edge_nodes_edge_center( x2, y2, x3, y3, x4, y4, x5, y5, eps ); 00411 CPPUNIT_ASSERT_EQUAL( 0, midok ); 00412 } 00413 00414 int quad_all_in_xy_plane( const Vector3D& p2, 00415 const Vector3D& p3, 00416 const Vector3D& p4, 00417 const Vector3D& p5, 00418 const Vector3D& p6, 00419 const Vector3D& p7, 00420 double epsilon ) 00421 { 00422 Vector3D list[] = { p2, p3, p4, p5, p6, p7 }; 00423 const int n = sizeof( list ) / sizeof( list[0] ); 00424 int result = 0; 00425 for( int i = 0; i < n; ++i ) 00426 if( fabs( list[i].z() ) > epsilon ) result |= ( 1 << i ); 00427 return result; 00428 } 00429 00430 int quad_mid_edge_nodes_edge_center( const Vector3D& p2, 00431 const Vector3D& p3, 00432 const Vector3D& p4, 00433 const Vector3D& p5, 00434 const Vector3D& p6, 00435 const Vector3D& p7, 00436 double epsilon ) 00437 { 00438 const Vector3D p0( 0.0, 0.0, 0.0 ); 00439 const Vector3D p1( QEL, 0.0, 0.0 ); 00440 const Vector3D e0 = 0.5 * ( p0 + p1 ); 00441 const Vector3D e1 = 0.5 * ( p1 + p2 ); 00442 const Vector3D e2 = 0.5 * ( p2 + p3 ); 00443 const Vector3D e3 = 0.5 * ( p3 + p0 ); 00444 00445 int result = 0; 00446 if( ( p4 - e0 ).length() > epsilon ) result |= 1; 00447 if( ( p5 - e1 ).length() > epsilon ) result |= 2; 00448 if( ( p6 - e2 ).length() > epsilon ) result |= 4; 00449 if( ( p7 - e3 ).length() > epsilon ) result |= 8; 00450 00451 return result; 00452 } 00453 00454 static void get_ideal_quad( Vector3D& p2, Vector3D& p3, Vector3D& p4, Vector3D& p5, Vector3D& p6, Vector3D& p7 ) 00455 { 00456 p2.set( QEL, QEL, 0 ); 00457 p3.set( 0.0, QEL, 0 ); 00458 p4.set( QEL / 2, 0.0, 0 ); 00459 p5.set( QEL, QEL / 2, 0 ); 00460 p6.set( QEL / 2, QEL, 0 ); 00461 p7.set( 0.0, QEL / 2, 0 ); 00462 } 00463 00464 void HigherOrderTest::test_quad_basic_ideal() 00465 { 00466 MsqPrintError err( cerr ); 00467 const double eps = 5e-2; 00468 Vector3D p2, p3, p4, p5, p6, p7; 00469 const Vector3D p0( 0.0, 0.0, 0.0 ); 00470 const Vector3D p1( QEL, 0.0, 0.0 ); 00471 00472 // try starting with the optimal result 00473 get_ideal_quad( p2, p3, p4, p5, p6, p7 ); 00474 basic_quad_test( p2, p3, p4, p5, p6, p7, err ); 00475 ASSERT_NO_ERROR( err ); 00476 CPPUNIT_ASSERT( !hit_iteration_limit() ); 00477 CPPUNIT_ASSERT_EQUAL( 0, quad_all_in_xy_plane( p2, p3, p4, p5, p6, p7, eps ) ); 00478 CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( QEL, QEL, 0 ), p2, eps ); 00479 CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 0, QEL, 0 ), p3, eps ); 00480 int midok = quad_mid_edge_nodes_edge_center( p2, p3, p4, p5, p6, p7, eps ); 00481 CPPUNIT_ASSERT_EQUAL( 0, midok ); 00482 } 00483 00484 void HigherOrderTest::test_quad_basic_mid_spin() 00485 { 00486 MsqPrintError err( cerr ); 00487 const double eps = 5e-2; 00488 Vector3D p2, p3, p4, p5, p6, p7; 00489 const Vector3D p0( 0.0, 0.0, 0.0 ); 00490 const Vector3D p1( QEL, 0.0, 0.0 ); 00491 00492 // try moving the mid-edge nodes along the edge away from the edge center 00493 p2.set( QEL, QEL, 0 ); 00494 p3.set( 0, QEL, 0 ); 00495 double f = 0.4; 00496 p4 = f * p0 + ( 1 - f ) * p1; 00497 p5 = f * p1 + ( 1 - f ) * p2; 00498 p6 = f * p2 + ( 1 - f ) * p3; 00499 p7 = f * p3 + ( 1 - f ) * p0; 00500 // crit.write_mesh_steps( "quad_basic_mid_spin", TerminationCriterion::VTK ); 00501 basic_quad_test( p2, p3, p4, p5, p6, p7, err ); 00502 // crit.write_mesh_steps( "", TerminationCriterion::NOTYPE ); 00503 ASSERT_NO_ERROR( err ); 00504 CPPUNIT_ASSERT( !hit_iteration_limit() ); 00505 CPPUNIT_ASSERT_EQUAL( 0, quad_all_in_xy_plane( p2, p3, p4, p5, p6, p7, eps ) ); 00506 CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( QEL, QEL, 0 ), p2, eps ); 00507 CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 0, QEL, 0 ), p3, eps ); 00508 int midok = quad_mid_edge_nodes_edge_center( p2, p3, p4, p5, p6, p7, eps ); 00509 CPPUNIT_ASSERT_EQUAL( 0, midok ); 00510 } 00511 00512 void HigherOrderTest::test_quad_basic_mid_convex() 00513 { 00514 MsqPrintError err( cerr ); 00515 const double eps = 5e-2; 00516 Vector3D p2, p3, p4, p5, p6, p7; 00517 const Vector3D p0( 0.0, 0.0, 0.0 ); 00518 const Vector3D p1( QEL, 0.0, 0.0 ); 00519 00520 // try square corners with all egdes convex 00521 get_ideal_quad( p2, p3, p4, p5, p6, p7 ); 00522 p4 += Vector3D( 0.0, -0.2 * QEL, 0 ); 00523 p5 += Vector3D( 0.2 * QEL, 0.0, 0 ); 00524 p6 += Vector3D( 0.0, 0.2 * QEL, 0 ); 00525 p7 += Vector3D( -0.2 * QEL, 0.0, 0 ); 00526 // crit.write_mesh_steps( "quad_basic_mid_convex", TerminationCriterion::VTK ); 00527 basic_quad_test( p2, p3, p4, p5, p6, p7, err ); 00528 // crit.write_mesh_steps( "", TerminationCriterion::NOTYPE ); 00529 ASSERT_NO_ERROR( err ); 00530 CPPUNIT_ASSERT( !hit_iteration_limit() ); 00531 CPPUNIT_ASSERT_EQUAL( 0, quad_all_in_xy_plane( p2, p3, p4, p5, p6, p7, eps ) ); 00532 CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( QEL, QEL, 0 ), p2, eps ); 00533 CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 0, QEL, 0 ), p3, eps ); 00534 int midok = quad_mid_edge_nodes_edge_center( p2, p3, p4, p5, p6, p7, eps ); 00535 CPPUNIT_ASSERT_EQUAL( 0, midok ); 00536 } 00537 00538 void HigherOrderTest::test_quad_basic_left_down() 00539 { 00540 MsqPrintError err( cerr ); 00541 const double eps = 5e-2; 00542 Vector3D p2, p3, p4, p5, p6, p7; 00543 const Vector3D p0( 0.0, 0.0, 0.0 ); 00544 const Vector3D p1( QEL, 0.0, 0.0 ); 00545 00546 // try moving the top left vertex down, also move mid-edge nodes proportionally 00547 get_ideal_quad( p2, p3, p4, p5, p6, p7 ); 00548 p3 -= Vector3D( 0.0, 0.0, QEL / 2 ); 00549 p6 = 0.5 * ( p2 + p3 ); 00550 p7 = 0.5 * ( p0 + p3 ); 00551 basic_quad_test( p2, p3, p4, p5, p6, p7, err ); 00552 ASSERT_NO_ERROR( err ); 00553 CPPUNIT_ASSERT( !hit_iteration_limit() ); 00554 CPPUNIT_ASSERT_EQUAL( 0, quad_all_in_xy_plane( p2, p3, p4, p5, p6, p7, eps ) ); 00555 CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( QEL, QEL, 0 ), p2, eps ); 00556 CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 0, QEL, 0 ), p3, eps ); 00557 int midok = quad_mid_edge_nodes_edge_center( p2, p3, p4, p5, p6, p7, eps ); 00558 CPPUNIT_ASSERT_EQUAL( 0, midok ); 00559 } 00560 00561 void HigherOrderTest::test_quad_basic_top_down() 00562 { 00563 MsqPrintError err( cerr ); 00564 const double eps = 5e-2; 00565 Vector3D p2, p3, p4, p5, p6, p7; 00566 const Vector3D p0( 0.0, 0.0, 0.0 ); 00567 const Vector3D p1( QEL, 0.0, 0.0 ); 00568 00569 // try moving the top two vertices down, also move mid-edge nodes proportionally 00570 get_ideal_quad( p2, p3, p4, p5, p6, p7 ); 00571 p2 -= Vector3D( 0.0, QEL / 2, 0.0 ); 00572 p3 -= Vector3D( 0.0, QEL / 2, 0.0 ); 00573 p5 = 0.5 * ( p1 + p2 ); 00574 p6 = 0.5 * ( p2 + p3 ); 00575 p7 = 0.5 * ( p0 + p3 ); 00576 basic_quad_test( p2, p3, p4, p5, p6, p7, err ); 00577 ASSERT_NO_ERROR( err ); 00578 CPPUNIT_ASSERT( !hit_iteration_limit() ); 00579 CPPUNIT_ASSERT_EQUAL( 0, quad_all_in_xy_plane( p2, p3, p4, p5, p6, p7, eps ) ); 00580 CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( QEL, QEL, 0 ), p2, eps ); 00581 CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 0, QEL, 0 ), p3, eps ); 00582 int midok = quad_mid_edge_nodes_edge_center( p2, p3, p4, p5, p6, p7, eps ); 00583 CPPUNIT_ASSERT_EQUAL( 0, midok ); 00584 } 00585 00586 void HigherOrderTest::test_quad_basic_right_up() 00587 { 00588 MsqPrintError err( cerr ); 00589 const double eps = 5e-2; 00590 Vector3D p2, p3, p4, p5, p6, p7; 00591 const Vector3D p0( 0.0, 0.0, 0.0 ); 00592 const Vector3D p1( QEL, 0.0, 0.0 ); 00593 00594 // try moving the top right vertex up, also move mid-edge nodes proportionally 00595 get_ideal_quad( p2, p3, p4, p5, p6, p7 ); 00596 p2 += Vector3D( 0.0, QEL * 2, 0.0 ); 00597 p5 = 0.5 * ( p1 + p2 ); 00598 p6 = 0.5 * ( p2 + p3 ); 00599 basic_quad_test( p2, p3, p4, p5, p6, p7, err ); 00600 ASSERT_NO_ERROR( err ); 00601 CPPUNIT_ASSERT( !hit_iteration_limit() ); 00602 CPPUNIT_ASSERT_EQUAL( 0, quad_all_in_xy_plane( p2, p3, p4, p5, p6, p7, eps ) ); 00603 CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( QEL, QEL, 0 ), p2, eps ); 00604 CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 0, QEL, 0 ), p3, eps ); 00605 int midok = quad_mid_edge_nodes_edge_center( p2, p3, p4, p5, p6, p7, eps ); 00606 CPPUNIT_ASSERT_EQUAL( 0, midok ); 00607 } 00608 00609 void HigherOrderTest::test_quad_basic_left_over() 00610 { 00611 MsqPrintError err( cerr ); 00612 const double eps = 5e-2; 00613 Vector3D p2, p3, p4, p5, p6, p7; 00614 const Vector3D p0( 0.0, 0.0, 0.0 ); 00615 const Vector3D p1( QEL, 0.0, 0.0 ); 00616 00617 // try moving the top left vertex to the right, also move mid-edge nodes proportionally 00618 get_ideal_quad( p2, p3, p4, p5, p6, p7 ); 00619 p3 -= Vector3D( QEL / 2, 0.0, 0.0 ); 00620 p6 = 0.5 * ( p2 + p3 ); 00621 p7 = 0.5 * ( p0 + p3 ); 00622 basic_quad_test( p2, p3, p4, p5, p6, p7, err ); 00623 ASSERT_NO_ERROR( err ); 00624 CPPUNIT_ASSERT( !hit_iteration_limit() ); 00625 CPPUNIT_ASSERT_EQUAL( 0, quad_all_in_xy_plane( p2, p3, p4, p5, p6, p7, eps ) ); 00626 CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( QEL, QEL, 0 ), p2, eps ); 00627 CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 0, QEL, 0 ), p3, eps ); 00628 int midok = quad_mid_edge_nodes_edge_center( p2, p3, p4, p5, p6, p7, eps ); 00629 CPPUNIT_ASSERT_EQUAL( 0, midok ); 00630 } 00631 00632 // ideal tet is defined to have unit lambda (cube root of det == 1) 00633 // const double IDEAL_TET_SIDE = sqrt(2.0) * pow(3.0, 1.0/3.0); // this was for unit area 00634 const double IDEAL_TET_SIDE = 2.0 / pow( 33, 1.0 / 6.0 ); 00635 const double IDEAL_TET_BASE = sqrt( 3.0 ) * 0.5 * IDEAL_TET_SIDE; 00636 const double IDEAL_TET_HEIGHT = sqrt( 2.0 / 3.0 ) * IDEAL_TET_SIDE; 00637 00638 int tet_mid_edge_nodes_edge_center( const Vector3D& p3, 00639 const Vector3D& p4, 00640 const Vector3D& p5, 00641 const Vector3D& p6, 00642 const Vector3D& p7, 00643 const Vector3D& p8, 00644 const Vector3D& p9, 00645 double epsilon ) 00646 { 00647 const Vector3D p0( 0.0, 0.0, 0.0 ); 00648 const Vector3D p1( IDEAL_TET_SIDE, 0.0, 0.0 ); 00649 const Vector3D p2( 0.5 * IDEAL_TET_SIDE, IDEAL_TET_BASE, 0.0 ); 00650 const Vector3D e0 = 0.5 * ( p0 + p1 ); 00651 const Vector3D e1 = 0.5 * ( p1 + p2 ); 00652 const Vector3D e2 = 0.5 * ( p2 + p0 ); 00653 const Vector3D e3 = 0.5 * ( p0 + p3 ); 00654 const Vector3D e4 = 0.5 * ( p1 + p3 ); 00655 const Vector3D e5 = 0.5 * ( p2 + p3 ); 00656 00657 int result = 0; 00658 if( ( p4 - e0 ).length() > epsilon ) result |= 1; 00659 if( ( p5 - e1 ).length() > epsilon ) result |= 2; 00660 if( ( p6 - e2 ).length() > epsilon ) result |= 4; 00661 if( ( p7 - e3 ).length() > epsilon ) result |= 8; 00662 if( ( p8 - e4 ).length() > epsilon ) result |= 16; 00663 if( ( p9 - e5 ).length() > epsilon ) result |= 32; 00664 00665 return result; 00666 } 00667 00668 inline static void get_ideal_tet( Vector3D& p3, 00669 Vector3D& p4, 00670 Vector3D& p5, 00671 Vector3D& p6, 00672 Vector3D& p7, 00673 Vector3D& p8, 00674 Vector3D& p9 ) 00675 { 00676 const Vector3D p0( 0.0, 0.0, 0.0 ); 00677 const Vector3D p1( IDEAL_TET_SIDE, 0.0, 0.0 ); 00678 const Vector3D p2( 0.5 * IDEAL_TET_SIDE, IDEAL_TET_BASE, 0.0 ); 00679 p3.set( 0.5 * IDEAL_TET_SIDE, IDEAL_TET_BASE / 3.0, IDEAL_TET_HEIGHT ); 00680 p4.set( 0.5 * ( p0 + p1 ) ); 00681 p5.set( 0.5 * ( p1 + p2 ) ); 00682 p6.set( 0.5 * ( p2 + p0 ) ); 00683 p7.set( 0.5 * ( p0 + p3 ) ); 00684 p8.set( 0.5 * ( p1 + p3 ) ); 00685 p9.set( 0.5 * ( p2 + p3 ) ); 00686 } 00687 00688 void HigherOrderTest::test_tet_basic_ideal() 00689 { 00690 MsqPrintError err( cerr ); 00691 const double eps = 5e-2; 00692 const Vector3D p3eq( 0.5 * IDEAL_TET_SIDE, IDEAL_TET_BASE / 3.0, IDEAL_TET_HEIGHT ); 00693 Vector3D p3, p4, p5, p6, p7, p8, p9; 00694 const Vector3D p0( 0.0, 0.0, 0.0 ); 00695 const Vector3D p1( IDEAL_TET_SIDE, 0.0, 0.0 ); 00696 const Vector3D p2( 0.5 * IDEAL_TET_SIDE, IDEAL_TET_BASE, 0.0 ); 00697 00698 // try starting with the optimal result 00699 get_ideal_tet( p3, p4, p5, p6, p7, p8, p9 ); 00700 basic_tet_test( p3, p4, p5, p6, p7, p8, p9, err ); 00701 ASSERT_NO_ERROR( err ); 00702 CPPUNIT_ASSERT( !hit_iteration_limit() ); 00703 CPPUNIT_ASSERT_VECTORS_EQUAL( p3eq, p3, eps ); 00704 int midok = tet_mid_edge_nodes_edge_center( p3, p4, p5, p6, p7, p8, p9, eps ); 00705 CPPUNIT_ASSERT_EQUAL( 0, midok ); 00706 } 00707 00708 void HigherOrderTest::test_tet_basic_mid_spin() 00709 { 00710 MsqPrintError err( cerr ); 00711 const double eps = 5e-2; 00712 const Vector3D p3eq( 0.5 * IDEAL_TET_SIDE, IDEAL_TET_BASE / 3.0, IDEAL_TET_HEIGHT ); 00713 Vector3D p3, p4, p5, p6, p7, p8, p9; 00714 const Vector3D p0( 0.0, 0.0, 0.0 ); 00715 const Vector3D p1( IDEAL_TET_SIDE, 0.0, 0.0 ); 00716 const Vector3D p2( 0.5 * IDEAL_TET_SIDE, IDEAL_TET_BASE, 0.0 ); 00717 00718 // try moving the mid-edge nodes along the edge away from the edge center 00719 p3 = p3eq; 00720 p4 = 0.6 * p0 + 0.4 * p1; 00721 p5 = 0.6 * p1 + 0.4 * p2; 00722 p6 = 0.6 * p2 + 0.4 * p0; 00723 p7 = 0.6 * p0 + 0.4 * p3; 00724 p8 = 0.4 * p1 + 0.6 * p3; 00725 p9 = 0.3 * p2 + 0.7 * p3; 00726 basic_tet_test( p3, p4, p5, p6, p7, p8, p9, err ); 00727 ASSERT_NO_ERROR( err ); 00728 CPPUNIT_ASSERT( !hit_iteration_limit() ); 00729 CPPUNIT_ASSERT_VECTORS_EQUAL( p3eq, p3, eps ); 00730 int midok = tet_mid_edge_nodes_edge_center( p3, p4, p5, p6, p7, p8, p9, eps ); 00731 CPPUNIT_ASSERT_EQUAL( 0, midok ); 00732 } 00733 00734 void HigherOrderTest::test_tet_basic_mid_convex() 00735 { 00736 MsqPrintError err( cerr ); 00737 const double eps = 5e-2; 00738 const Vector3D p3eq( 0.5 * IDEAL_TET_SIDE, IDEAL_TET_BASE / 3.0, IDEAL_TET_HEIGHT ); 00739 Vector3D p3, p4, p5, p6, p7, p8, p9; 00740 const Vector3D p0( 0.0, 0.0, 0.0 ); 00741 const Vector3D p1( IDEAL_TET_SIDE, 0.0, 0.0 ); 00742 const Vector3D p2( 0.5 * IDEAL_TET_SIDE, IDEAL_TET_BASE, 0.0 ); 00743 00744 // try equilateral corners with all egdes convex 00745 get_ideal_tet( p3, p4, p5, p6, p7, p8, p9 ); 00746 p4 += Vector3D( 0.0, -0.2, -0.2 ); 00747 p5 += Vector3D( 0.2, 0.2, -0.2 ); 00748 p6 += Vector3D( -0.2, 0.2, -0.2 ); 00749 p7 += Vector3D( -0.2, -0.2, 0.2 ); 00750 p8 += Vector3D( 0.2, -0.2, 0.2 ); 00751 p9 += Vector3D( 0.0, 0.2, 0.2 ); 00752 basic_tet_test( p3, p4, p5, p6, p7, p8, p9, err ); 00753 ASSERT_NO_ERROR( err ); 00754 CPPUNIT_ASSERT( !hit_iteration_limit() ); 00755 CPPUNIT_ASSERT_VECTORS_EQUAL( p3eq, p3, eps ); 00756 int midok = tet_mid_edge_nodes_edge_center( p3, p4, p5, p6, p7, p8, p9, eps ); 00757 CPPUNIT_ASSERT_EQUAL( 0, midok ); 00758 } 00759 00760 void HigherOrderTest::test_tet_basic_apex_down() 00761 { 00762 MsqPrintError err( cerr ); 00763 const double eps = 5e-2; 00764 const Vector3D p3eq( 0.5 * IDEAL_TET_SIDE, IDEAL_TET_BASE / 3.0, IDEAL_TET_HEIGHT ); 00765 Vector3D p3, p4, p5, p6, p7, p8, p9; 00766 const Vector3D p0( 0.0, 0.0, 0.0 ); 00767 const Vector3D p1( IDEAL_TET_SIDE, 0.0, 0.0 ); 00768 const Vector3D p2( 0.5 * IDEAL_TET_SIDE, IDEAL_TET_BASE, 0.0 ); 00769 00770 // try moving the top vertex down, also move mid-edge nodes proportionally 00771 get_ideal_tet( p3, p4, p5, p6, p7, p8, p9 ); 00772 p3 -= Vector3D( 0.0, 0.0, 0.5 ); 00773 p7 -= Vector3D( 0.0, 0.0, 0.25 ); 00774 p8 -= Vector3D( 0.0, 0.0, 0.25 ); 00775 p9 -= Vector3D( 0.0, 0.0, 0.25 ); 00776 basic_tet_test( p3, p4, p5, p6, p7, p8, p9, err ); 00777 ASSERT_NO_ERROR( err ); 00778 CPPUNIT_ASSERT( !hit_iteration_limit() ); 00779 CPPUNIT_ASSERT_VECTORS_EQUAL( p3eq, p3, eps ); 00780 int midok = tet_mid_edge_nodes_edge_center( p3, p4, p5, p6, p7, p8, p9, eps ); 00781 CPPUNIT_ASSERT_EQUAL( 0, midok ); 00782 } 00783 00784 void HigherOrderTest::test_tet_basic_apex_up() 00785 { 00786 MsqPrintError err( cerr ); 00787 const double eps = 5e-2; 00788 const Vector3D p3eq( 0.5 * IDEAL_TET_SIDE, IDEAL_TET_BASE / 3.0, IDEAL_TET_HEIGHT ); 00789 Vector3D p3, p4, p5, p6, p7, p8, p9; 00790 const Vector3D p0( 0.0, 0.0, 0.0 ); 00791 const Vector3D p1( IDEAL_TET_SIDE, 0.0, 0.0 ); 00792 const Vector3D p2( 0.5 * IDEAL_TET_SIDE, IDEAL_TET_BASE, 0.0 ); 00793 00794 // try moving the top vertex up, also move mid-edge nodes proportionally 00795 get_ideal_tet( p3, p4, p5, p6, p7, p8, p9 ); 00796 p3 += Vector3D( 0.0, 0.0, 3.0 ); 00797 p7 += Vector3D( 0.0, 0.0, 1.5 ); 00798 p8 += Vector3D( 0.0, 0.0, 1.5 ); 00799 p9 += Vector3D( 0.0, 0.0, 1.5 ); 00800 basic_tet_test( p3, p4, p5, p6, p7, p8, p9, err ); 00801 ASSERT_NO_ERROR( err ); 00802 CPPUNIT_ASSERT( !hit_iteration_limit() ); 00803 CPPUNIT_ASSERT_VECTORS_EQUAL( p3eq, p3, eps ); 00804 int midok = tet_mid_edge_nodes_edge_center( p3, p4, p5, p6, p7, p8, p9, eps ); 00805 CPPUNIT_ASSERT_EQUAL( 0, midok ); 00806 } 00807 00808 void HigherOrderTest::test_tet_basic_apex_over() 00809 { 00810 MsqPrintError err( cerr ); 00811 const double eps = 5e-2; 00812 const Vector3D p3eq( 0.5 * IDEAL_TET_SIDE, IDEAL_TET_BASE / 3.0, IDEAL_TET_HEIGHT ); 00813 Vector3D p3, p4, p5, p6, p7, p8, p9; 00814 const Vector3D p0( 0.0, 0.0, 0.0 ); 00815 const Vector3D p1( IDEAL_TET_SIDE, 0.0, 0.0 ); 00816 const Vector3D p2( 0.5 * IDEAL_TET_SIDE, IDEAL_TET_BASE, 0.0 ); 00817 00818 // try moving the top vertex to the right, also move mid-edge nodes proportionally 00819 get_ideal_tet( p3, p4, p5, p6, p7, p8, p9 ); 00820 p3 -= Vector3D( 0.3, 0.0, 0.0 ); 00821 p7 = 0.5 * ( p0 + p3 ); 00822 p8 = 0.5 * ( p1 + p3 ); 00823 p9 = 0.5 * ( p2 + p3 ); 00824 basic_tet_test( p3, p4, p5, p6, p7, p8, p9, err ); 00825 ASSERT_NO_ERROR( err ); 00826 CPPUNIT_ASSERT( !hit_iteration_limit() ); 00827 CPPUNIT_ASSERT_VECTORS_EQUAL( p3eq, p3, eps ); 00828 int midok = tet_mid_edge_nodes_edge_center( p3, p4, p5, p6, p7, p8, p9, eps ); 00829 CPPUNIT_ASSERT_EQUAL( 0, midok ); 00830 } 00831 00832 void HigherOrderTest::test_hex_basic() 00833 { 00834 MsqError err; 00835 const double P = 0.25; // fraction to perturb higher-order nodes: 0.5->optimal 00836 const double Q = 1 - P; 00837 const double EPSILON = 1e-4; 00838 const unsigned long num_vtx = 27; 00839 00840 // Define a 27-node hex with corner nodes fixed and higher-order 00841 // nodes perturbed a bit. Smooth to see if HO nodes are moved 00842 // to center of edge/face/volume. 00843 double coords[3 * num_vtx] = { // bottom corners 00844 0, 0, 0, 1, 0, 0, 1, 1, 0, 0, 1, 0, 00845 // top corners 00846 0, 0, 1, 1, 0, 1, 1, 1, 1, 0, 1, 1, 00847 // bottom mid-edge 00848 P, 0, 0, 1, Q, 0, Q, 1, 0, 0, P, 0, 00849 // vertical mid-edge 00850 0, 0, P, 1, 0, P, 1, 1, Q, 0, 1, Q, 00851 // top mid-edge 00852 Q, 0, 1, 1, P, 1, P, 1, 1, 0, Q, 1, 00853 // vertical faces 00854 P, 0, Q, 1, Q, P, Q, 1, P, 0, P, Q, 00855 // bottom and top mid-face 00856 P, Q, 0, Q, P, 1, 00857 // mid-element 00858 P, Q, P }; 00859 unsigned long conn[num_vtx]; 00860 for( unsigned i = 0; i < num_vtx; i++ ) 00861 conn[i] = i; 00862 int fixed[num_vtx]; 00863 std::fill( fixed, fixed + 8, 1 ); 00864 std::fill( fixed + 8, fixed + num_vtx, 0 ); 00865 const EntityTopology type = HEXAHEDRON; 00866 unsigned long offsets[] = { 0, num_vtx }; 00867 ArrayMesh one_hex( 3, num_vtx, coords, fixed, 1, &type, conn, offsets ); 00868 00869 // smooth 00870 q.run_instructions( &one_hex, err ); 00871 ASSERT_NO_ERROR( err ); 00872 00873 // test that higher-order nodes were moved to the expected locations 00874 // bottom mid-edge 00875 CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 0.5, 0.0, 0 ), Vector3D( coords + 3 * 8 ), EPSILON ); 00876 CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 1.0, 0.5, 0 ), Vector3D( coords + 3 * 9 ), EPSILON ); 00877 CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 0.5, 1.0, 0 ), Vector3D( coords + 3 * 10 ), EPSILON ); 00878 CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 0.0, 0.5, 0 ), Vector3D( coords + 3 * 11 ), EPSILON ); 00879 // vertical mid-edge 00880 CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 0, 0, 0.5 ), Vector3D( coords + 3 * 12 ), EPSILON ); 00881 CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 1, 0, 0.5 ), Vector3D( coords + 3 * 13 ), EPSILON ); 00882 CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 1, 1, 0.5 ), Vector3D( coords + 3 * 14 ), EPSILON ); 00883 CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 0, 1, 0.5 ), Vector3D( coords + 3 * 15 ), EPSILON ); 00884 // top mid-edge 00885 CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 0.5, 0.0, 1 ), Vector3D( coords + 3 * 16 ), EPSILON ); 00886 CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 1.0, 0.5, 1 ), Vector3D( coords + 3 * 17 ), EPSILON ); 00887 CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 0.5, 1.0, 1 ), Vector3D( coords + 3 * 18 ), EPSILON ); 00888 CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 0.0, 0.5, 1 ), Vector3D( coords + 3 * 19 ), EPSILON ); 00889 // vertical faces 00890 CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 0.5, 0.0, 0.5 ), Vector3D( coords + 3 * 20 ), EPSILON ); 00891 CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 1.0, 0.5, 0.5 ), Vector3D( coords + 3 * 21 ), EPSILON ); 00892 CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 0.5, 1.0, 0.5 ), Vector3D( coords + 3 * 22 ), EPSILON ); 00893 CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 0.0, 0.5, 0.5 ), Vector3D( coords + 3 * 23 ), EPSILON ); 00894 // bottom and top mid-face 00895 CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 0.5, 0.5, 0 ), Vector3D( coords + 3 * 24 ), EPSILON ); 00896 CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 0.5, 0.5, 1 ), Vector3D( coords + 3 * 25 ), EPSILON ); 00897 // mid-element 00898 CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 0.5, 0.5, 0.5 ), Vector3D( coords + 3 * 26 ), EPSILON ); 00899 } 00900 00901 /* 00902 Jason, 00903 00904 Here is a very simple test we should run. 00905 00906 A single quadratic triangle. IMR metric with W = equilateral ideal No geometry. 00907 00908 Nodes: 00909 00910 (x,y) Type F/S/F 00911 ----------------------------------------------------------- 00912 (0,0) Corner Fixed 00913 (1,0) Corner Fixed 00914 (x2,y2) Corner Free 00915 (x3,y3) Mid Free 00916 (x4,y4) Mid Free 00917 (x5,y5) Mid Free 00918 -------------------------------------------------------- 00919 00920 Start with sample points at each of the node. 00921 The optimal element should be equilateral. 00922 Try different initial values for x2,y2,x3, etc. 00923 Try only including some of the sample points to see if still get equilateral. 00924 Probably should add this one to the testSuite. 00925 00926 -- Pat 00927 */ 00928 void HigherOrderTest::basic_tri_test( double& x2, 00929 double& y2, 00930 double& x3, 00931 double& y3, 00932 double& x4, 00933 double& y4, 00934 double& x5, 00935 double& y5, 00936 MsqError& err ) 00937 { 00938 // Construct Mesh instance 00939 const int DIM = 3; 00940 const int NVTX = 6; 00941 const int NELEM = 1; 00942 double coords[DIM * NVTX] = { 0., 0., 0, IDEAL_TRI_SIDE, 0., 0, x2, y2, 0, x3, y3, 0, x4, y4, 0, x5, y5, 0 }; 00943 const int fixed[NVTX] = { 1, 1, 0, 0, 0, 0 }; 00944 const unsigned long conn[NVTX * NELEM] = { 00945 0, 1, 2, 3, 4, 5, 00946 }; 00947 ArrayMesh mesh( DIM, NVTX, coords, fixed, NELEM, TRIANGLE, conn, false, NVTX ); 00948 PlanarDomain xy( PlanarDomain::XY ); 00949 00950 // Solve 00951 MeshDomainAssoc mesh_and_domain = MeshDomainAssoc( &mesh, &xy ); 00952 q.run_instructions( &mesh_and_domain, err );MSQ_ERRRTN( err ); 00953 00954 // Pass back modified coordinates 00955 x2 = coords[2 * DIM + 0]; 00956 y2 = coords[2 * DIM + 1]; 00957 x3 = coords[3 * DIM + 0]; 00958 y3 = coords[3 * DIM + 1]; 00959 x4 = coords[4 * DIM + 0]; 00960 y4 = coords[4 * DIM + 1]; 00961 x5 = coords[5 * DIM + 0]; 00962 y5 = coords[5 * DIM + 1]; 00963 } 00964 00965 void HigherOrderTest::basic_tet_test( Vector3D& p3, 00966 Vector3D& p4, 00967 Vector3D& p5, 00968 Vector3D& p6, 00969 Vector3D& p7, 00970 Vector3D& p8, 00971 Vector3D& p9, 00972 MsqError& err ) 00973 { 00974 // Construct Mesh instance 00975 const int DIM = 3; 00976 const int NVTX = 10; 00977 const int NELEM = 1; 00978 const Vector3D p0( 0.0, 0.0, 0.0 ); 00979 const Vector3D p1( IDEAL_TET_SIDE, 0.0, 0.0 ); 00980 const Vector3D p2( 0.5 * IDEAL_TET_SIDE, IDEAL_TET_BASE, 0.0 ); 00981 double coords[DIM * NVTX] = { p0.x(), p0.y(), p0.z(), p1.x(), p1.y(), p1.z(), p2.x(), p2.y(), p2.z(), p3.x(), 00982 p3.y(), p3.z(), p4.x(), p4.y(), p4.z(), p5.x(), p5.y(), p5.z(), p6.x(), p6.y(), 00983 p6.z(), p7.x(), p7.y(), p7.z(), p8.x(), p8.y(), p8.z(), p9.x(), p9.y(), p9.z() }; 00984 00985 const int fixed[NVTX] = { 1, 1, 1, 0, 0, 0, 0, 0, 0, 0 }; 00986 const unsigned long conn[NVTX * NELEM] = { 0, 1, 2, 3, 4, 5, 6, 7, 8, 9 }; 00987 ArrayMesh mesh( DIM, NVTX, coords, fixed, NELEM, TETRAHEDRON, conn, false, NVTX ); 00988 00989 // Solve 00990 q.run_instructions( &mesh, err );MSQ_ERRRTN( err ); 00991 00992 // Pass back modified coordinates 00993 p3.set( coords + 3 * DIM ); 00994 p4.set( coords + 4 * DIM ); 00995 p5.set( coords + 5 * DIM ); 00996 p6.set( coords + 6 * DIM ); 00997 p7.set( coords + 7 * DIM ); 00998 p8.set( coords + 8 * DIM ); 00999 p9.set( coords + 9 * DIM ); 01000 } 01001 01002 void HigherOrderTest::basic_quad_test( Vector3D& p2, 01003 Vector3D& p3, 01004 Vector3D& p4, 01005 Vector3D& p5, 01006 Vector3D& p6, 01007 Vector3D& p7, 01008 MsqError& err ) 01009 { 01010 // Construct Mesh instance 01011 const int DIM = 3; 01012 const int NVTX = 8; 01013 const int NELEM = 1; 01014 double coords[DIM * NVTX] = { 0.0, 0.0, 0.0, QEL, 0.0, 0.0, p2.x(), p2.y(), 01015 p2.z(), p3.x(), p3.y(), p3.z(), p4.x(), p4.y(), p4.z(), p5.x(), 01016 p5.y(), p5.z(), p6.x(), p6.y(), p6.z(), p7.x(), p7.y(), p7.z() }; 01017 01018 const int fixed[NVTX] = { 1, 1, 0, 0, 0, 0, 0, 0 }; 01019 const unsigned long conn[NVTX * NELEM] = { 0, 1, 2, 3, 4, 5, 6, 7 }; 01020 ArrayMesh mesh( DIM, NVTX, coords, fixed, NELEM, QUADRILATERAL, conn, false, NVTX ); 01021 PlanarDomain xy( PlanarDomain::XY ); 01022 01023 // Solve 01024 MeshDomainAssoc mesh_and_domain = MeshDomainAssoc( &mesh, &xy ); 01025 q.run_instructions( &mesh_and_domain, err ); 01026 ASSERT_NO_ERROR( err ); 01027 CPPUNIT_ASSERT( !hit_iteration_limit() ); 01028 01029 // Pass back modified coordinates 01030 p2.set( coords + 2 * DIM ); 01031 p3.set( coords + 3 * DIM ); 01032 p4.set( coords + 4 * DIM ); 01033 p5.set( coords + 5 * DIM ); 01034 p6.set( coords + 6 * DIM ); 01035 p7.set( coords + 7 * DIM ); 01036 } 01037 01038 void HigherOrderTest::basic_hex_test( Vector3D& p4, 01039 Vector3D& p5, 01040 Vector3D& p6, 01041 Vector3D& p7, 01042 Vector3D& p8, 01043 Vector3D& p9, 01044 Vector3D& p10, 01045 Vector3D& p11, 01046 Vector3D& p12, 01047 Vector3D& p13, 01048 Vector3D& p14, 01049 Vector3D& p15, 01050 Vector3D& p16, 01051 Vector3D& p17, 01052 Vector3D& p18, 01053 Vector3D& p19, 01054 MsqError& err ) 01055 { 01056 // Construct Mesh instance 01057 const int DIM = 3; 01058 const int NVTX = 20; 01059 const int NELEM = 1; 01060 double coords[DIM * NVTX] = { 0.0, 0.0, 0, 2.0, 0.0, 0, 2.0, 2.0, 0, 01061 0.0, 2.0, 0, p4.x(), p4.y(), p4.z(), p5.x(), p5.y(), p5.z(), 01062 p6.x(), p6.y(), p6.z(), p7.x(), p7.y(), p7.z(), p8.x(), p8.y(), p8.z(), 01063 p9.x(), p9.y(), p9.z(), p10.x(), p10.y(), p10.z(), p11.x(), p11.y(), p11.z(), 01064 p12.x(), p12.y(), p12.z(), p13.x(), p13.y(), p13.z(), p14.x(), p14.y(), p14.z(), 01065 p15.x(), p15.y(), p15.z(), p16.x(), p16.y(), p16.z(), p17.x(), p17.y(), p17.z(), 01066 p18.x(), p18.y(), p18.z(), p19.x(), p19.y(), p19.z() }; 01067 const int fixed[NVTX] = { 1, 1, 1, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 }; 01068 const unsigned long conn[NVTX * NELEM] = { 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19 }; 01069 ArrayMesh mesh( DIM, NVTX, coords, fixed, NELEM, HEXAHEDRON, conn, false, NVTX ); 01070 01071 // Solve 01072 q.run_instructions( &mesh, err );MSQ_ERRRTN( err ); 01073 CPPUNIT_ASSERT( !hit_iteration_limit() ); 01074 01075 // Pass back modified coordinates 01076 p4.set( coords + 4 * DIM ); 01077 p5.set( coords + 5 * DIM ); 01078 p6.set( coords + 6 * DIM ); 01079 p7.set( coords + 7 * DIM ); 01080 p8.set( coords + 8 * DIM ); 01081 p9.set( coords + 9 * DIM ); 01082 p10.set( coords + 10 * DIM ); 01083 p11.set( coords + 11 * DIM ); 01084 p12.set( coords + 12 * DIM ); 01085 p13.set( coords + 13 * DIM ); 01086 p14.set( coords + 14 * DIM ); 01087 p15.set( coords + 15 * DIM ); 01088 p16.set( coords + 16 * DIM ); 01089 p17.set( coords + 17 * DIM ); 01090 p18.set( coords + 18 * DIM ); 01091 p19.set( coords + 19 * DIM ); 01092 } 01093 01094 /* The mesh consists of a single triangle with 3 corner 01095 and 3 mid-side nodes. Two sides of the triangle are 01096 on the boundary, which consists of two curves (maybe 01097 just straight lines), so one side is on each curve. 01098 The corner vertex at the intersection of the two curves is 01099 fixed, the two mid-side nodes on the boundary are 01100 free (with snap-to), one of the other two corner vertices 01101 is fixed, the other free (with snap-to). The remaining 01102 mid-node vertex is free, being in the interior. To close 01103 the domain, I leave up to you... 01104 01105 ----2* 01106 | | 01107 | | 01108 | --5 4 01109 y2 | | 01110 |y5 | 01111 | | | 01112 ----0*------3-----------1----- 01113 |<--x3->| | 01114 |<-------x1-------->| 01115 01116 * Fixed vertices 01117 01118 */ 01119 void HigherOrderTest::test_tri_open_domain( double& x1, double& x3, double& x4, double y2, double y5, double& y4 ) 01120 { 01121 MsqPrintError err( cerr ); 01122 01123 // Validate input 01124 CPPUNIT_ASSERT( x3 < x1 ); 01125 CPPUNIT_ASSERT( y5 < y2 ); 01126 CPPUNIT_ASSERT( x3 > 0.0 ); 01127 CPPUNIT_ASSERT( y5 > 0.0 ); 01128 01129 // Construct Mesh instance 01130 const int DIM = 3; 01131 const int NVTX = 6; 01132 const int NELEM = 1; 01133 double coords[DIM * NVTX] = { 0, 0, 0, x1, 0, 0, 0, y2, 0, x3, 0, 0, x4, y4, 0, 0, y5, 0 }; 01134 const int fixed[NVTX] = { 1, 0, 1, 0, 0, 0 }; 01135 const unsigned long conn[NVTX * NELEM] = { 01136 0, 1, 2, 3, 4, 5, 01137 }; 01138 ArrayMesh mesh( DIM, NVTX, coords, fixed, NELEM, TRIANGLE, conn, false, NVTX ); 01139 01140 // Construct Geometry 01141 LineDomain xaxis( Vector3D( 0, 0, 0 ), Vector3D( 1, 0, 0 ) ); 01142 LineDomain yaxis( Vector3D( 0, 0, 0 ), Vector3D( 0, 1, 0 ) ); 01143 PlanarDomain xyplane( PlanarDomain::XY ); 01144 DomainClassifier::DomainSet sets[] = { &xaxis, &yaxis, &xyplane }; 01145 01146 vector< Mesh::VertexHandle > verts; 01147 vector< Mesh::ElementHandle > elems; 01148 mesh.get_all_vertices( verts, err ); 01149 ASSERT_NO_ERROR( err ); 01150 mesh.get_all_elements( elems, err ); 01151 ASSERT_NO_ERROR( err ); 01152 CPPUNIT_ASSERT_EQUAL( (size_t)1, elems.size() ); 01153 01154 // Associate mesh with geometry 01155 sets[0].vertices.push_back( verts[1] ); 01156 sets[0].vertices.push_back( verts[3] ); 01157 sets[1].vertices.push_back( verts[2] ); 01158 sets[1].vertices.push_back( verts[5] ); 01159 sets[2].elements.push_back( elems[0] ); 01160 sets[2].vertices.push_back( verts[4] ); 01161 DomainClassifier geom; 01162 DomainClassifier::classify_by_handle( geom, &mesh, sets, 3, err ); 01163 ASSERT_NO_ERROR( err ); 01164 01165 // Solve 01166 MeshDomainAssoc mesh_and_domain = MeshDomainAssoc( &mesh, &geom ); 01167 q.run_instructions( &mesh_and_domain, err ); 01168 ASSERT_NO_ERROR( err ); 01169 CPPUNIT_ASSERT( !hit_iteration_limit() ); 01170 01171 // Pass back modified coordinate values 01172 x1 = coords[DIM * 1 + 0]; 01173 x3 = coords[DIM * 3 + 0]; 01174 x4 = coords[DIM * 4 + 0]; 01175 y4 = coords[DIM * 4 + 1]; 01176 } 01177 01178 void HigherOrderTest::test_tri_open_domain() 01179 { 01180 double x1 = 2; 01181 double y2 = 2; 01182 double x3 = 1; 01183 double y5 = 1; 01184 double x4 = 1; 01185 double y4 = 1; 01186 test_tri_open_domain( x1, x3, x4, y2, y5, y4 ); 01187 CPPUNIT_ASSERT_DOUBLES_EQUAL( 2.0, x1, 1e-3 ); 01188 CPPUNIT_ASSERT_DOUBLES_EQUAL( 2.0, y2, 1e-3 ); 01189 CPPUNIT_ASSERT_DOUBLES_EQUAL( 1.0, x3, 1e-3 ); 01190 CPPUNIT_ASSERT_DOUBLES_EQUAL( 1.0, x4, 1e-3 ); 01191 CPPUNIT_ASSERT_DOUBLES_EQUAL( 1.0, y4, 1e-3 ); 01192 } 01193 01194 /* 01195 Jason, 01196 01197 Here is an interesting test we should run that's slightly more like the SLAC problem. 01198 01199 A single quadratic triangle. IMR metric with W = equilateral ideal No geometry. 01200 01201 Nodes: 01202 01203 (x,y) Type F/S/F 01204 ----------------------------------------------------------- 01205 (0,0) Corner Fixed 01206 (1,0) Corner Fixed 01207 (0.5,10) Corner Free 01208 (0.50,0.49) Mid Fixed 01209 (0.75,0.5) Mid Free 01210 (0.25,0.5) Mid Free 01211 -------------------------------------------------------- 01212 01213 Start with sample points at each of the node. 01214 01215 The Jacobian at the fixed mid-side node is nearly zero 01216 and the goal is to see if this can be improved by moving the 3 free nodes. 01217 01218 The node at (0.5,1.0) should move downward\u2026. Moving it upward makes 01219 the mid-node Jacobian negative, and the IMR barrier should prevent that. 01220 01221 Try including only some of the sample points to see if all are needed. 01222 01223 -- Pat 01224 */ 01225 void HigherOrderTest::test_tri_slac() 01226 { 01227 MsqPrintError err( cerr ); 01228 01229 // Construct Mesh instance 01230 const int DIM = 3; 01231 const int NVTX = 6; 01232 const int NELEM = 1; 01233 double coords[DIM * NVTX] = { 0.00, 0.00, 0, 1.00, 0.00, 0, 0.50, 10.0, 0, 01234 0.50, 0.30, 0, 0.75, 4.50, 0, 0.25, 4.50, 0 }; 01235 const int fixed[NVTX] = { 1, 1, 0, 1, 0, 0 }; 01236 const unsigned long conn[NVTX * NELEM] = { 01237 0, 1, 2, 3, 4, 5, 01238 }; 01239 ArrayMesh mesh( DIM, NVTX, coords, fixed, NELEM, TRIANGLE, conn, false, NVTX ); 01240 PlanarDomain xy( PlanarDomain::XY ); 01241 01242 // Solve 01243 q.run_instructions( &mesh, err ); 01244 ASSERT_NO_ERROR( err ); 01245 CPPUNIT_ASSERT( !hit_iteration_limit() ); 01246 01247 const Vector3D v0( coords + 0 * DIM ); 01248 const Vector3D v1( coords + 1 * DIM ); 01249 const Vector3D v2( coords + 2 * DIM ); 01250 const Vector3D v3( coords + 3 * DIM ); 01251 const Vector3D v4( coords + 4 * DIM ); 01252 const Vector3D v5( coords + 5 * DIM ); 01253 01254 // Expect vertex 2 to have moved downwards signficantly 01255 CPPUNIT_ASSERT( v2.y() < 2.0 ); 01256 CPPUNIT_ASSERT( v2.y() > 0.5 ); 01257 // Expect it to have stayed in the center along the X axis 01258 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.5, v2.x(), 1e-3 ); 01259 // Expect free mid-edge nodes to be "between" adjacent corners 01260 CPPUNIT_ASSERT( v4.x() > 0.5 ); 01261 CPPUNIT_ASSERT( v4.x() < 1.0 ); 01262 CPPUNIT_ASSERT( v5.x() > 0.0 ); 01263 CPPUNIT_ASSERT( v5.x() < 0.5 ); 01264 // Expect two free mid-edge nodes to be slightly above the 01265 // line between adjacent corners (slightly convex edge) 01266 // because the fixed mid-edge node on the bottom is moved upward 01267 Vector3D m12 = v2 - v1; 01268 Vector3D m02 = v2 - v0; 01269 double t1 = ( m12 % ( v4 - v0 ) ) / ( m12 % m12 ); 01270 double t2 = ( m02 % ( v5 - v0 ) ) / ( m02 % m02 ); 01271 Vector3D l4 = v0 * t1 * m12; // closed point to v4 on line v1,v2 01272 Vector3D l5 = v0 * t2 * m02; // closed point to v5 on line v0,v2 01273 // Check not to far from line 01274 CPPUNIT_ASSERT( ( l4 - v4 ).length() < 0.1 ); 01275 CPPUNIT_ASSERT( ( l5 - v5 ).length() < 0.1 ); 01276 // Check that edges are convex 01277 CPPUNIT_ASSERT( l4.x() < v4.x() ); 01278 CPPUNIT_ASSERT( l5.x() > v5.x() ); 01279 }
