MOAB: Mesh Oriented datABase
(version 5.2.1)
Assign subsets of a mesh do different domains. More...
#include <DomainClassifier.hpp>
Classes | |
struct | DomainBlock |
struct | DomainSet |
Public Member Functions | |
MESQUITE_EXPORT void | test_valid_classification (Mesh *mesh, MsqError &err) |
Check that classification maps to B-Rep topology. | |
MESQUITE_EXPORT | DomainClassifier () |
virtual MESQUITE_EXPORT | ~DomainClassifier () |
virtual MESQUITE_EXPORT void | snap_to (Mesh::VertexHandle entity_handle, Vector3D &coordinate) const |
virtual MESQUITE_EXPORT void | vertex_normal_at (Mesh::VertexHandle entity_handle, Vector3D &coordinate) const |
virtual MESQUITE_EXPORT void | element_normal_at (Mesh::ElementHandle entity_handle, Vector3D &coordinate) const |
virtual MESQUITE_EXPORT void | vertex_normal_at (const Mesh::VertexHandle *handles, Vector3D coordinates[], unsigned count, MsqError &err) const |
evaluate surface normals | |
virtual MESQUITE_EXPORT void | closest_point (Mesh::VertexHandle handle, const Vector3D &position, Vector3D &closest, Vector3D &normal, MsqError &err) const |
evaluate closest point and normal | |
virtual MESQUITE_EXPORT void | domain_DoF (const Mesh::VertexHandle *handle_array, unsigned short *dof_array, size_t num_handles, MsqError &err) const |
MESQUITE_EXPORT void | clear () |
Clear all data, including MeshDomain list. | |
MESQUITE_EXPORT MeshDomain * | find_vertex_domain (Mesh::VertexHandle vertex) const |
MESQUITE_EXPORT MeshDomain * | find_element_domain (Mesh::ElementHandle element) const |
MESQUITE_EXPORT void | delete_sub_domains (bool yesno) |
MESQUITE_EXPORT void | delete_all_sub_domains () |
Static Public Member Functions | |
static MESQUITE_EXPORT void | classify_by_tag (DomainClassifier &result, Mesh *mesh, const char *tag_name, MeshDomain **domain_array, const int *id_array, unsigned array_length, MsqError &err) |
Classify mesh entities using tag values. | |
static MESQUITE_EXPORT void | classify_skin_geometrically (DomainClassifier &result, Mesh *mesh, double tolerance, MeshDomain **domain_array, const int *dimension_array, unsigned array_length, MsqError &err) |
Skin mesh and classify skin entities geometrically. | |
static MESQUITE_EXPORT void | classify_geometrically (DomainClassifier &result, Mesh *mesh, double tolerance, MeshDomain **domain_array, const int *dimension_array, unsigned array_length, MsqError &err) |
Classify all mesh entities geometrically. | |
static MESQUITE_EXPORT void | classify_by_handle (DomainClassifier &result, Mesh *mesh, DomainSet *domain_set_array, unsigned array_length, MsqError &err) |
Specify classification explicitly for each entity. | |
Static Private Member Functions | |
static MeshDomain * | find_domain (Mesh::EntityHandle handle, const std::vector< DomainBlock > &list) |
Private Attributes | |
bool | deleteSubDomains |
std::vector< DomainBlock > | vertexList |
std::vector< DomainBlock > | elementList |
Provide classification of mesh entities to domain(s). For example, given a domain defined by multiple surfaces and curves of intersection, associate the appropriate elements and vertices to the appropriate geometric entities.
Definition at line 48 of file DomainClassifier.hpp.
Definition at line 164 of file DomainClassifier.hpp.
: deleteSubDomains( false ) {}
MBMesquite::DomainClassifier::~DomainClassifier | ( | ) | [virtual] |
Definition at line 1181 of file DomainClassifier.cpp.
References delete_all_sub_domains(), and deleteSubDomains.
{ if( deleteSubDomains ) delete_all_sub_domains(); }
void MBMesquite::DomainClassifier::classify_by_handle | ( | DomainClassifier & | result, |
Mesh * | mesh, | ||
DomainSet * | domain_set_array, | ||
unsigned | array_length, | ||
MsqError & | err | ||
) | [static] |
For each mesh element and vertex that is classified to a domain, specify that classification explicitly.
result | DomainClassifier to popupate |
mesh | The MBMesquite::Mesh instance |
domain_set_array | Array of DomainClassifier::DomainSet structs specifying for each MeshDomain: the domain instance and the elements and vertices associated with the domain. |
array_length | Length of 'domain_set_array' |
Definition at line 581 of file DomainClassifier.cpp.
References clear(), MBMesquite::DomainClassifier::DomainSet::domain, MBMesquite::DomainClassifier::DomainBlock::domain, elementList, MBMesquite::DomainClassifier::DomainSet::elements, MBMesquite::DomainClassifier::DomainBlock::firstHandle, MBMesquite::Mesh::get_all_elements(), MBMesquite::Mesh::get_all_vertices(), MBMesquite::DomainClassifier::DomainBlock::lastHandle, MSQ_ERRRTN, vertexList, and MBMesquite::DomainClassifier::DomainSet::vertices.
Referenced by classify_by_tag(), classify_geometrically(), classify_skin_geometrically(), get_planar_example(), DomainClassifierTest::test_classify_by_handle(), HigherOrderTest::test_tri_open_domain(), and DomainClassifierTest::test_valid_classification().
{ result.clear(); // get all vertices and elements std::vector< Mesh::VertexHandle > vertices; std::vector< Mesh::ElementHandle > elements; mesh->get_all_vertices( vertices, err );MSQ_ERRRTN( err ); mesh->get_all_elements( elements, err );MSQ_ERRRTN( err ); // sort all arrays so we can merge std::sort( vertices.begin(), vertices.end() ); std::sort( elements.begin(), elements.end() ); for( unsigned i = 0; i < array_length; ++i ) { std::sort( sets[i].vertices.begin(), sets[i].vertices.end() ); std::sort( sets[i].elements.begin(), sets[i].elements.end() ); } // build vertex block list std::vector< size_t > indices( array_length, 0 ); size_t idx = 0; while( idx < vertices.size() ) { DomainBlock block; block.firstHandle = vertices[idx]; block.lastHandle = vertices[idx]; // find domain unsigned dom = 0; for( dom = 0; dom < array_length; ++dom ) { const size_t i = indices[dom]; if( i < sets[dom].vertices.size() && sets[dom].vertices[i] == vertices[idx] ) { ++indices[dom]; break; } } ++idx; if( dom == indices.size() ) // no domain continue; block.domain = sets[dom].domain; while( indices[dom] < sets[dom].vertices.size() && sets[dom].vertices[indices[dom]] == vertices[idx] ) { block.lastHandle = vertices[idx]; ++idx; ++indices[dom]; } result.vertexList.push_back( block ); } // build vertex block list indices.clear(); indices.resize( array_length, 0 ); idx = 0; while( idx < elements.size() ) { DomainBlock block; block.firstHandle = elements[idx]; block.lastHandle = elements[idx]; // find domain unsigned dom = 0; for( dom = 0; dom < array_length; ++dom ) { const size_t i = indices[dom]; if( i < sets[dom].elements.size() && sets[dom].elements[i] == elements[idx] ) { ++indices[dom]; break; } } ++idx; if( dom == indices.size() ) // no domain continue; block.domain = sets[dom].domain; while( indices[dom] < sets[dom].elements.size() && sets[dom].elements[indices[dom]] == elements[idx] ) { block.lastHandle = elements[idx]; ++idx; ++indices[dom]; } result.elementList.push_back( block ); } /* printf("\n"); for (unsigned i = 0; i < result.vertexList.size(); ++i) printf("v %2lu-%2lu @ %p\n", (unsigned long)result.vertexList[i].firstHandle, (unsigned long)result.vertexList[i].lastHandle, result.vertexList[i].domain ); for (unsigned i = 0; i < result.elementList.size(); ++i) printf("e %2lu-%2lu @ %p\n", (unsigned long)result.elementList[i].firstHandle, (unsigned long)result.elementList[i].lastHandle, result.elementList[i].domain ); printf("\n"); */ }
void MBMesquite::DomainClassifier::classify_by_tag | ( | DomainClassifier & | result, |
Mesh * | mesh, | ||
const char * | tag_name, | ||
MeshDomain ** | domain_array, | ||
const int * | id_array, | ||
) | [static] |
Given a list of MeshDomain instances, a unique integer ID for each MeshDomain, and a tag name: classify mesh entities by matching the tag value on each mesh entity to the list of MeshDomain IDs.
tag_name | Tag containing integer domain ID for each mesh entity. |
domain_array | Array of MeshDomain instances. |
id_array | Array of integer MeshDomain IDs. |
array_length | Length of 'domain_array' and 'id_array' |
Definition at line 522 of file DomainClassifier.cpp.
References MBMesquite::arrptr(), classify_by_handle(), MBMesquite::MsqError::clear(), MBMesquite::Mesh::get_all_elements(), MBMesquite::Mesh::get_all_vertices(), MBMesquite::Mesh::INT, MSQ_ERRRTN, MSQ_SETERR, size, MBMesquite::Mesh::tag_get(), MBMesquite::Mesh::tag_get_element_data(), MBMesquite::Mesh::tag_get_vertex_data(), MBMesquite::MsqError::TAG_NOT_FOUND, and MBMesquite::Mesh::tag_properties().
Referenced by DomainClassifierTest::test_classify_by_tag().
{ TagHandle tag = mesh->tag_get( tag_name, err );MSQ_ERRRTN( err ); std::string name2; Mesh::TagType type; unsigned size; mesh->tag_properties( tag, name2, type, size, err );MSQ_ERRRTN( err ); if( type != Mesh::INT || size != 1 ) { MSQ_SETERR( err ) ( MsqError::TAG_NOT_FOUND, "Tag does not contain single integer value: %s\n", tag_name ); return; } std::vector< DomainSet > sets( array_length ); std::map< int, DomainSet* > idmap; for( unsigned i = 0; i < array_length; ++i ) { sets[i].domain = domain_array[i]; idmap[id_array[i]] = &sets[i]; } std::vector< Mesh::VertexHandle > vertices; std::vector< Mesh::ElementHandle > elements; mesh->get_all_vertices( vertices, err );MSQ_ERRRTN( err ); mesh->get_all_elements( elements, err );MSQ_ERRRTN( err ); if( vertices.empty() ) return; std::map< int, DomainSet* >::const_iterator iter; std::vector< int > ids( vertices.size() ); mesh->tag_get_vertex_data( tag, vertices.size(), arrptr( vertices ), arrptr( ids ), err );MSQ_ERRRTN( err ); for( size_t j = 0; j < vertices.size(); ++j ) { iter = idmap.find( ids[j] ); if( iter != idmap.end() ) iter->second->vertices.push_back( vertices[j] ); } ids.clear(); ids.resize( elements.size() ); if( !elements.empty() ) { mesh->tag_get_element_data( tag, elements.size(), arrptr( elements ), arrptr( ids ), err ); if( err ) { err.clear(); } else { for( size_t k = 0; k < elements.size(); ++k ) { iter = idmap.find( ids[k] ); if( iter != idmap.end() ) iter->second->elements.push_back( elements[k] ); } } } if( !sets.empty() ) classify_by_handle( result, mesh, arrptr( sets ), sets.size(), err ); }
void MBMesquite::DomainClassifier::classify_geometrically | ( | DomainClassifier & | result, |
Mesh * | mesh, | ||
double | tolerance, | ||
const int * | dimension_array, | ||
) | [static] |
Classify entities by distance from vertex coordiantes to mesh domain instances.
NOTE: Mesquite's limited MeshDomain callback interface is not sufficient for robust geometric classification. If the mesh is not sufficiently refined, this method may produce invalid results.
NOTE: This method is likely to fail for many domains for volume meshes. Use classify_skin_geometrically for volume meshes.
tolerance | Maximum distance a vertex may deviate from its domain. |
dimension_array | Topological dimensiono of each MeshDomain |
array_length | Length of 'domain_array' and 'dimension_array' |
Definition at line 441 of file DomainClassifier.cpp.
References MBMesquite::arrptr(), classify_by_handle(), MBMesquite::dimension_sort_domains(), domains, MBMesquite::Mesh::elements_get_topologies(), MBMesquite::geom_classify_elements(), MBMesquite::geom_classify_vertices(), MBMesquite::Mesh::get_all_elements(), MBMesquite::Mesh::get_all_vertices(), MSQ_ERRRTN, tolerance, and MBMesquite::vert_classify_elements().
Referenced by PatchDataTest::get_quad8_mesh_and_domain(), process_domain_args(), and DomainClassifierTest::test_classify_by_geometry().
{ if( !array_length ) return; std::vector< DomainSet > domains; int dim_indices[4]; dimension_sort_domains( domain_array, dimension_array, array_length, domains, dim_indices, err );MSQ_ERRRTN( err ); // classify vertices by position std::vector< Mesh::VertexHandle > vertices; mesh->get_all_vertices( vertices, err );MSQ_ERRRTN( err ); geom_classify_vertices( mesh, arrptr( domains ), dim_indices[3], vertices, tolerance, err );MSQ_ERRRTN( err ); // get elements and types std::vector< Mesh::ElementHandle > elems; mesh->get_all_elements( elems, err );MSQ_ERRRTN( err ); if( elems.empty() ) return; std::vector< EntityTopology > types( elems.size() ); mesh->elements_get_topologies( arrptr( elems ), arrptr( types ), elems.size(), err );MSQ_ERRRTN( err ); // get rid of elements w/ dimension other than 2 size_t w = 0; for( size_t r = 0; r < elems.size(); ++r ) { if( TopologyInfo::dimension( types[r] ) == 2 ) { elems[w] = elems[r]; ++w; } } elems.resize( w ); // classify elements using vertex classification std::vector< Mesh::ElementHandle > unknown; vert_classify_elements( mesh, arrptr( domains ), domains.size(), dim_indices, elems, unknown, err );MSQ_ERRRTN( err ); // classify unknown elements geometrically elems.swap( unknown ); unknown.clear(); geom_classify_elements( mesh, arrptr( domains ), domains.size(), dim_indices, elems, unknown, tolerance, err ); classify_by_handle( result, mesh, arrptr( domains ), domains.size(), err ); }
void MBMesquite::DomainClassifier::classify_skin_geometrically | ( | DomainClassifier & | result, |
Mesh * | mesh, | ||
) | [static] |
Calculate the boundary of the mesh, and classify boundary entities by calculating the distance from the mesh domain to each vertex.
NOTE: This method should not be used for surface meshes. Everything in a surface mesh should be classified to a domain. not just the skin. Use classify_geometrically instead.
Definition at line 487 of file DomainClassifier.cpp.
References MBMesquite::arrptr(), classify_by_handle(), MBMesquite::dimension_sort_domains(), domains, MBMesquite::find_skin(), MBMesquite::geom_classify_elements(), MBMesquite::geom_classify_vertices(), MBMesquite::MsqError::INVALID_MESH, MSQ_ERRRTN, MSQ_SETERR, tolerance, and MBMesquite::vert_classify_elements().
Referenced by get_cut_cube_example(), get_hex_3d_part_example(), get_sphere_cube_example(), get_sphere_cylinder_example(), SlaveBoundaryVerticesTest::make_mesh(), process_domain_args(), and DomainClassifierTest::test_classify_skin().
{ if( !array_length ) return; std::vector< DomainSet > domains; int dim_indices[4]; dimension_sort_domains( domain_array, dimension_array, array_length, domains, dim_indices, err );MSQ_ERRRTN( err ); std::vector< Mesh::VertexHandle > vertices; std::vector< Mesh::ElementHandle > elements; find_skin( mesh, vertices, elements, err );MSQ_ERRRTN( err ); // classify vertices by position geom_classify_vertices( mesh, arrptr( domains ), dim_indices[3], vertices, tolerance, err );MSQ_ERRRTN( err ); // classify elements using vertex classification std::vector< Mesh::ElementHandle > unknown; vert_classify_elements( mesh, arrptr( domains ), domains.size(), dim_indices, elements, unknown, err );MSQ_ERRRTN( err ); // classify unknown elements geometrically elements.swap( unknown ); unknown.clear(); geom_classify_elements( mesh, arrptr( domains ), domains.size(), dim_indices, elements, unknown, tolerance, err ); if( !unknown.empty() ) { MSQ_SETERR( err )( "Count not classify all skin elements", MsqError::INVALID_MESH ); return; } classify_by_handle( result, mesh, arrptr( domains ), domains.size(), err ); }
MESQUITE_EXPORT void MBMesquite::DomainClassifier::clear | ( | ) | [inline] |
Definition at line 190 of file DomainClassifier.hpp.
References elementList, and vertexList.
Referenced by classify_by_handle(), and delete_all_sub_domains().
{ vertexList.clear(); elementList.clear(); }
void MBMesquite::DomainClassifier::closest_point | ( | Mesh::VertexHandle | handle, |
const Vector3D & | position, | ||
Vector3D & | closest, | ||
Vector3D & | normal, | ||
) | const [virtual] |
Given a position in space, return the closest position in the domain and the domain normal at that point.
entity_handle | Evaluate the subset of the domain contianing this entity |
position | Input position for which to evaluate |
closest | Closest position in the domain. |
normal | Domain normal at the location of 'closest' |
Implements MBMesquite::MeshDomain.
Definition at line 1159 of file DomainClassifier.cpp.
References find_vertex_domain().
{ if( const MeshDomain* dom = find_vertex_domain( handle ) ) dom->closest_point( handle, position, closest, normal, err ); }
Definition at line 1186 of file DomainClassifier.cpp.
References clear(), domains, elementList, and vertexList.
Referenced by ~DomainClassifier().
{ // get unique list of domains std::set< MeshDomain* > domains; std::vector< DomainBlock >::iterator i; for( i = vertexList.begin(); i != vertexList.end(); ++i ) domains.insert( i->domain ); for( i = elementList.begin(); i != elementList.end(); ++i ) domains.insert( i->domain ); std::set< MeshDomain* >::iterator j; for( j = domains.begin(); j != domains.end(); ++j ) delete *j; clear(); }
MESQUITE_EXPORT void MBMesquite::DomainClassifier::delete_sub_domains | ( | bool | yesno | ) | [inline] |
Definition at line 215 of file DomainClassifier.hpp.
References deleteSubDomains.
Referenced by PatchDataTest::get_quad8_mesh_and_domain(), and SlaveBoundaryVerticesTest::make_mesh().
{ deleteSubDomains = yesno; }
void MBMesquite::DomainClassifier::domain_DoF | ( | const Mesh::VertexHandle * | handle_array, |
unsigned short * | dof_array, | ||
size_t | num_handles, | ||
Definition at line 1166 of file DomainClassifier.cpp.
References MBMesquite::MeshDomain::domain_DoF(), find_vertex_domain(), and MSQ_ERRRTN.
Referenced by SlaveBoundaryVerticesTest::test_slaved_common().
{ for( size_t i = 0; i < num_handles; ++i ) { const MeshDomain* dom = find_vertex_domain( handles[i] ); if( !dom ) dof_array[i] = 3; else { dom->domain_DoF( handles + i, dof_array + i, 1, err );MSQ_ERRRTN( err ); } } }
void MBMesquite::DomainClassifier::element_normal_at | ( | Mesh::ElementHandle | entity_handle, |
Vector3D & | coordinate | ||
Definition at line 1138 of file DomainClassifier.cpp.
References find_element_domain().
{ if( const MeshDomain* dom = find_element_domain( entity_handle ) ) dom->element_normal_at( entity_handle, coordinate ); }
MeshDomain * MBMesquite::DomainClassifier::find_domain | ( | Mesh::EntityHandle | handle, |
const std::vector< DomainBlock > & | list | ||
) | [static, private] |
Definition at line 1119 of file DomainClassifier.cpp.
Referenced by find_element_domain(), and find_vertex_domain().
std::vector< DomainClassifier::DomainBlock >::const_iterator i;
i = std::lower_bound( list.begin(), list.end(), handle );
return ( i != list.end() && i->firstHandle <= handle ) ? i->domain : NULL;
MESQUITE_EXPORT MeshDomain* MBMesquite::DomainClassifier::find_element_domain | ( | Mesh::ElementHandle | element | ) | const [inline] |
Definition at line 209 of file DomainClassifier.hpp.
References elementList, and find_domain().
Referenced by DomainClassifierTest::check_domain(), and element_normal_at().
{ return find_domain( element, elementList ); }
MESQUITE_EXPORT MeshDomain* MBMesquite::DomainClassifier::find_vertex_domain | ( | Mesh::VertexHandle | vertex | ) | const [inline] |
Definition at line 204 of file DomainClassifier.hpp.
References find_domain(), and vertexList.
Referenced by DomainClassifierTest::check_domain(), closest_point(), domain_DoF(), snap_to(), and vertex_normal_at().
{ return find_domain( vertex, vertexList ); }
void MBMesquite::DomainClassifier::snap_to | ( | Mesh::VertexHandle | entity_handle, |
Modifies "coordinate" so that it lies on the domain to which "entity_handle" is constrained. The handle determines the domain. The coordinate is the proposed new position on that domain.
Definition at line 1127 of file DomainClassifier.cpp.
{ if( const MeshDomain* dom = find_vertex_domain( entity_handle ) ) dom->snap_to( entity_handle, coordinate ); }
void MBMesquite::DomainClassifier::test_valid_classification | ( | Mesh * | mesh, |
Definition at line 782 of file DomainClassifier.cpp.
References MBMesquite::arrptr(), dim, dof(), domains, elementList, MBMesquite::Mesh::elements_get_attached_vertices(), MBMesquite::Mesh::elements_get_topologies(), MBMesquite::faces, MBMesquite::Mesh::get_all_elements(), MBMesquite::Mesh::get_all_vertices(), MBMesquite::MsqError::INVALID_STATE, MSQ_ERRRTN, MSQ_SETERR, n, MBMesquite::next_vertex(), vertexList, MBMesquite::Mesh::vertices_get_attached_elements(), and vtx().
Referenced by DomainClassifierTest::test_valid_classification().
{ size_t i; // Get all mesh entities std::vector< Mesh::VertexHandle > vertices; std::vector< Mesh::ElementHandle > elements; mesh->get_all_vertices( vertices, err );MSQ_ERRRTN( err ); mesh->get_all_elements( elements, err );MSQ_ERRRTN( err ); std::sort( vertices.begin(), vertices.end() ); std::sort( elements.begin(), elements.end() ); // Get contents of each domain. std::map< MeshDomain*, int >::iterator iter; std::map< MeshDomain*, int > idxmap; for( i = 0; i < vertexList.size(); ++i ) idxmap[vertexList[i].domain] = 0; for( i = 0; i < elementList.size(); ++i ) idxmap[elementList[i].domain] = 0; std::vector< DomainSet > domains( idxmap.size() ); int idx = 0; for( iter = idxmap.begin(); iter != idxmap.end(); ++iter ) { iter->second = idx; domains[idx].domain = iter->first; ++idx; } for( i = 0; i < vertexList.size(); ++i ) { std::vector< Mesh::VertexHandle >::const_iterator s, e; s = std::lower_bound( vertices.begin(), vertices.end(), vertexList[i].firstHandle ); e = std::upper_bound( vertices.begin(), vertices.end(), vertexList[i].lastHandle ); DomainSet& set = domains[idxmap[vertexList[i].domain]]; std::copy( s, e, std::back_inserter( set.vertices ) ); } for( i = 0; i < elementList.size(); ++i ) { std::vector< Mesh::ElementHandle >::const_iterator s, e; s = std::lower_bound( elements.begin(), elements.end(), elementList[i].firstHandle ); e = std::upper_bound( elements.begin(), elements.end(), elementList[i].lastHandle ); DomainSet& set = domains[idxmap[elementList[i].domain]]; std::copy( s, e, std::back_inserter( set.elements ) ); } // guess geometric dimension for each domain std::map< DomainSet*, int > dimmap; std::vector< unsigned short > dof; for( i = 0; i < domains.size(); ++i ) { if( !domains[i].elements.empty() ) dimmap[&domains[i]] = 2; else { dof.resize( domains[i].vertices.size() ); domains[i].domain->domain_DoF( &( domains[i].vertices[0] ), arrptr( dof ), dof.size(), err );MSQ_ERRRTN( err ); unsigned short dim = *std::max_element( dof.begin(), dof.end() ); dimmap[&domains[i]] = dim; } } // group domains by dimension std::vector< DomainSet* > points, curves, surfaces; for( std::map< DomainSet*, int >::iterator it = dimmap.begin(); it != dimmap.end(); ++it ) { switch( it->second ) { case 0: points.push_back( it->first ); break; case 1: curves.push_back( it->first ); break; case 2: surfaces.push_back( it->first ); break; default: MSQ_SETERR( err ) ( MsqError::INVALID_STATE, "Invalid domain dimension: %d\n", it->second ); break; } } // check that each point-domain has a single vertex for( i = 0; i < points.size(); ++i ) { if( points[i]->vertices.size() != 1 || !points[i]->elements.empty() ) { MSQ_SETERR( err )( "Point domain mesh not a single vertex.", MsqError::INVALID_STATE ); return; } } // check that each curve domain has a chain of connected edges std::set< Mesh::VertexHandle > unseen; for( i = 0; i < curves.size(); ++i ) { if( !curves[i]->elements.empty() ) { MSQ_SETERR( err )( "Elements associated with 1D domain.", MsqError::INVALID_STATE ); return; } unseen.clear(); std::copy( curves[i]->vertices.begin(), curves[i]->vertices.end(), std::inserter( unseen, unseen.begin() ) ); const Mesh::VertexHandle first_vtx = *unseen.begin(); unseen.erase( unseen.begin() ); Mesh::VertexHandle vtx = first_vtx; // find chain of vertices while( next_vertex( mesh, vtx, unseen, err ) ) MSQ_ERRRTN( err ); // search again from the starting vertex because // it probably wasn't the first one on the curve vtx = first_vtx; while( next_vertex( mesh, vtx, unseen, err ) ) MSQ_ERRRTN( err ); // were all vertices in a chain? if( !unseen.empty() ) { MSQ_SETERR( err ) ( "Curve domain contains vertices not in a simply connected chain.", MsqError::INVALID_STATE ); return; } } std::set< Mesh::VertexHandle > seen; std::set< Mesh::ElementHandle > remaining; std::vector< Mesh::VertexHandle > verts, verts2; std::vector< Mesh::ElementHandle > stack, vert_elems; std::vector< EntityTopology > types; std::vector< size_t > junk; // if surface contains elements... for( i = 0; i < surfaces.size(); ++i ) { if( surfaces[i]->elements.empty() ) continue; // Check that any vertices on surface are contained in an // element on the surface. verts.clear(); mesh->elements_get_attached_vertices( &( surfaces[i]->elements[0] ), surfaces[i]->elements.size(), verts, junk, err );MSQ_ERRRTN( err ); seen.clear(); std::copy( verts.begin(), verts.end(), std::inserter( seen, seen.begin() ) ); std::vector< Mesh::VertexHandle >::const_iterator v; for( v = surfaces[i]->vertices.begin(); v != surfaces[i]->vertices.end(); ++v ) { std::set< Mesh::VertexHandle >::iterator j = seen.find( *v ); if( j == seen.end() ) { MSQ_SETERR( err ) ( "Vertex on surface domain not in any element.", MsqError::INVALID_STATE ); return; } } // check that elements form 2D patch stack.clear(); remaining.clear(); std::copy( surfaces[i]->elements.begin(), surfaces[i]->elements.end(), std::inserter( remaining, remaining.begin() ) ); stack.push_back( *remaining.begin() ); remaining.erase( remaining.begin() ); while( !stack.empty() ) { Mesh::ElementHandle elem = stack.back(); stack.pop_back(); verts.clear(); mesh->elements_get_attached_vertices( &elem, 1, verts, junk, err );MSQ_ERRRTN( err ); // for each edge for( size_t j = 0; j < verts.size(); ++j ) { Mesh::VertexHandle v1 = verts[j], v2 = verts[( j + 1 ) % verts.size()]; vert_elems.clear(); mesh->vertices_get_attached_elements( &v1, 1, vert_elems, junk, err );MSQ_ERRRTN( err ); types.resize( vert_elems.size() ); if( !vert_elems.empty() ) { mesh->elements_get_topologies( arrptr( vert_elems ), arrptr( types ), vert_elems.size(), err );MSQ_ERRRTN( err ); } while( !vert_elems.empty() ) { Mesh::ElementHandle e2 = vert_elems.back(); EntityTopology type = types.back(); vert_elems.pop_back(); types.pop_back(); if( TopologyInfo::dimension( type ) != 2 ) continue; verts2.clear(); mesh->elements_get_attached_vertices( &e2, 1, verts2, junk, err );MSQ_ERRRTN( err ); size_t jdx = std::find( verts2.begin(), verts2.end(), v1 ) - verts2.begin(); if( verts2[( jdx + 1 ) % verts2.size()] != v2 && verts2[( jdx + verts2.size() - 1 ) % verts2.size()] != v2 ) continue; std::set< Mesh::ElementHandle >::iterator r = remaining.find( e2 ); if( r == remaining.end() ) continue; stack.push_back( *r ); remaining.erase( r ); } } } if( !remaining.empty() ) { MSQ_SETERR( err ) ( "Surface mesh not a single, simply-connected patch", MsqError::INVALID_STATE ); return; } } // check that sides of volume elements that are on surface // form simply connected patch for( i = 0; i < surfaces.size(); ++i ) { // build list of sides known to be on surface std::sort( surfaces[i]->vertices.begin(), surfaces[i]->vertices.end() ); std::set< std::pair< Mesh::ElementHandle, int > > sides; for( size_t j = 0; j < surfaces[i]->vertices.size(); ++j ) { Mesh::VertexHandle v = surfaces[i]->vertices[j]; vert_elems.clear(); mesh->vertices_get_attached_elements( &v, 1, vert_elems, junk, err );MSQ_ERRRTN( err ); types.resize( vert_elems.size() ); if( !vert_elems.empty() ) { mesh->elements_get_topologies( arrptr( vert_elems ), arrptr( types ), vert_elems.size(), err );MSQ_ERRRTN( err ); } while( !vert_elems.empty() ) { Mesh::ElementHandle e = vert_elems.back(); EntityTopology type = types.back(); vert_elems.pop_back(); types.pop_back(); if( TopologyInfo::dimension( type ) != 3 ) continue; verts.clear(); mesh->elements_get_attached_vertices( &e, 1, verts, junk, err );MSQ_ERRRTN( err ); for( unsigned s = 0; s < TopologyInfo::faces( type ); ++s ) { unsigned n; const unsigned* si = TopologyInfo::face_vertices( type, s, n ); unsigned ns = 0; for( unsigned k = 0; k < n; ++k ) { if( std::binary_search( surfaces[i]->vertices.begin(), surfaces[i]->vertices.end(), verts[si[k]] ) ) ++ns; } if( ns >= 3 ) sides.insert( std::pair< Mesh::ElementHandle, int >( e, s ) ); } } } std::vector< std::pair< Mesh::ElementHandle, int > > sstack; sstack.push_back( *sides.begin() ); sides.erase( sides.begin() ); while( !sstack.empty() ) { Mesh::ElementHandle e = sstack.back().first; int s = sstack.back().second; sstack.pop_back(); verts.clear(); mesh->elements_get_attached_vertices( &e, 1, verts, junk, err );MSQ_ERRRTN( err ); EntityTopology type; mesh->elements_get_topologies( &e, &type, 1, err );MSQ_ERRRTN( err ); unsigned n; const unsigned* si = TopologyInfo::face_vertices( type, s, n ); // for each edge for( unsigned j = 0; j < n; ++j ) { Mesh::VertexHandle v1 = verts[si[j]], v2 = verts[si[( j + 1 ) % n]]; vert_elems.clear(); mesh->vertices_get_attached_elements( &v1, 1, vert_elems, junk, err );MSQ_ERRRTN( err ); types.resize( vert_elems.size() ); if( !vert_elems.empty() ) { mesh->elements_get_topologies( arrptr( vert_elems ), arrptr( types ), vert_elems.size(), err );MSQ_ERRRTN( err ); } while( !vert_elems.empty() ) { Mesh::ElementHandle e2 = vert_elems.back(); EntityTopology type2 = types.back(); vert_elems.pop_back(); types.pop_back(); if( TopologyInfo::dimension( type ) != 3 ) continue; verts2.clear(); mesh->elements_get_attached_vertices( &e2, 1, verts2, junk, err );MSQ_ERRRTN( err ); // for each face for( unsigned s2 = 0; s2 < TopologyInfo::faces( type2 ); ++s2 ) { std::set< std::pair< Mesh::ElementHandle, int > >::iterator side; side = sides.find( std::pair< Mesh::ElementHandle, int >( e2, s2 ) ); if( side == sides.end() ) continue; unsigned n2; const unsigned* si2 = TopologyInfo::face_vertices( type2, s2, n2 ); unsigned jdx; for( jdx = 0; jdx < n2; ++jdx ) if( verts2[si2[jdx]] == v1 ) break; assert( jdx < n2 ); if( verts2[si2[( jdx + 1 ) % n2]] == v2 || verts2[si2[( jdx + n2 - 1 ) % n2]] == v2 ) { sstack.push_back( *side ); sides.erase( side ); } } } } } if( !sides.empty() ) { MSQ_SETERR( err ) ( "Surface mesh not a single, simply-connected patch", MsqError::INVALID_STATE ); return; } } }
void MBMesquite::DomainClassifier::vertex_normal_at | ( | Mesh::VertexHandle | entity_handle, |
Returns the normal of the domain to which "entity_handle" is constrained. For non-planar surfaces, the normal is calculated at the point on the domain that is closest to the passed in value of "coordinate". If the domain does not have a normal, or the normal cannot be determined, "coordinate" is set to (0,0,0). Otherwise, "coordinate" is set to the domain's normal at the appropriate point. In summary, the handle determines the domain. The coordinate determines the point of interest on that domain.
User should see also PatchData::get_domain_normal_at_vertex and PatchData::get_domain_normal_at_element .
Definition at line 1132 of file DomainClassifier.cpp.
{ if( const MeshDomain* dom = find_vertex_domain( entity_handle ) ) dom->vertex_normal_at( entity_handle, coordinate ); }
void MBMesquite::DomainClassifier::vertex_normal_at | ( | const Mesh::VertexHandle * | handles, |
Vector3D | coordinates[], | ||
unsigned | count, | ||
Returns normals for a domain.
handles | The domain evaluated is the one in which this mesh entity is constrained. |
coordinates | As input, a list of positions at which to evaluate the domain. As output, the resulting domain normals. |
count | The length of the coordinates array. |
Definition at line 1144 of file DomainClassifier.cpp.
References find_vertex_domain(), MBMesquite::MsqError::INVALID_ARG, MSQ_ERRRTN, MSQ_SETERR, and MBMesquite::MeshDomain::vertex_normal_at().
{ for( unsigned i = 0; i < count; ++i ) { const MeshDomain* dom = find_vertex_domain( handles[i] ); if( !dom ) { MSQ_SETERR( err )( MsqError::INVALID_ARG ); return; } dom->vertex_normal_at( handles + i, coordinates + i, 1, err );MSQ_ERRRTN( err ); } }
bool MBMesquite::DomainClassifier::deleteSubDomains [private] |
Definition at line 224 of file DomainClassifier.hpp.
Referenced by delete_sub_domains(), and ~DomainClassifier().
std::vector< DomainBlock > MBMesquite::DomainClassifier::elementList [private] |
Definition at line 229 of file DomainClassifier.hpp.
Referenced by classify_by_handle(), clear(), delete_all_sub_domains(), find_element_domain(), and test_valid_classification().
std::vector< DomainBlock > MBMesquite::DomainClassifier::vertexList [private] |
Definition at line 228 of file DomainClassifier.hpp.
Referenced by classify_by_handle(), clear(), delete_all_sub_domains(), find_vertex_domain(), and test_valid_classification().
