MOAB: Mesh Oriented datABase
(version 5.4.0)
00001 /* ***************************************************************** 00002 MESQUITE -- The Mesh Quality Improvement Toolkit 00003 00004 Copyright 2006 Lawrence Livermore National Laboratory. Under 00005 the terms of Contract B545069 with the University of Wisconsin -- 00006 Madison, Lawrence Livermore National Laboratory retains certain 00007 rights in this software. 00008 00009 This library is free software; you can redistribute it and/or 00010 modify it under the terms of the GNU Lesser General Public 00011 License as published by the Free Software Foundation; either 00012 version 2.1 of the License, or (at your option) any later version. 00013 00014 This library is distributed in the hope that it will be useful, 00015 but WITHOUT ANY WARRANTY; without even the implied warranty of 00016 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00017 Lesser General Public License for more details. 00018 00019 You should have received a copy of the GNU Lesser General Public License 00020 (lgpl.txt) along with this library; if not, write to the Free Software 00021 Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA 00022 00023 (2006) kraftche@cae.wisc.edu 00024 00025 ***************************************************************** */ 00026 00027 /** \file LinearPrism.cpp 00028 * \brief mapping function for linear prism 00029 * \author Jason Kraftcheck 00030 */ 00031 00032 #include "Mesquite.hpp" 00033 #include "MsqError.hpp" 00034 #include "LinearPrism.hpp" 00035 00036 namespace MBMesquite 00037 { 00038 00039 static const char* nonlinear_error = "Attempt to use LinearPrism mapping function for a nonlinear element\n"; 00040 00041 EntityTopology LinearPrism::element_topology() const 00042 { 00043 return PRISM; 00044 } 00045 00046 int LinearPrism::num_nodes() const 00047 { 00048 return 6; 00049 } 00050 00051 static const int edge_beg[] = { 0, 1, 2, 0, 1, 2, 3, 4, 5 }; 00052 static const int edge_end[] = { 1, 2, 0, 3, 4, 5, 4, 5, 3 }; 00053 static const int faces[5][5] = { { 4, 0, 1, 4, 3 }, 00054 { 4, 1, 2, 5, 4 }, 00055 { 4, 2, 0, 3, 5 }, 00056 { 3, 0, 1, 2, -1 }, 00057 { 3, 3, 4, 5, -1 } }; 00058 00059 static void coefficients_at_corner( unsigned corner, double* coeff_out, size_t* indices_out, size_t& num_coeff ) 00060 { 00061 num_coeff = 1; 00062 indices_out[0] = corner; 00063 coeff_out[0] = 1.0; 00064 } 00065 00066 static void coefficients_at_mid_edge( unsigned edge, double* coeff_out, size_t* indices_out, size_t& num_coeff ) 00067 { 00068 num_coeff = 2; 00069 indices_out[0] = edge_beg[edge]; 00070 indices_out[1] = edge_end[edge]; 00071 coeff_out[0] = 0.5; 00072 coeff_out[1] = 0.5; 00073 } 00074 00075 static void coefficients_at_mid_face( unsigned face, double* coeff_out, size_t* indices_out, size_t& num_coeff ) 00076 { 00077 double f; 00078 if( faces[face][0] == 4 ) 00079 { 00080 num_coeff = 4; 00081 f = 0.25; 00082 indices_out[3] = faces[face][4]; 00083 coeff_out[3] = f; 00084 } 00085 else 00086 { 00087 num_coeff = 3; 00088 f = MSQ_ONE_THIRD; 00089 } 00090 00091 coeff_out[0] = f; 00092 coeff_out[1] = f; 00093 coeff_out[2] = f; 00094 indices_out[0] = faces[face][1]; 00095 indices_out[1] = faces[face][2]; 00096 indices_out[2] = faces[face][3]; 00097 } 00098 00099 static void coefficients_at_mid_elem( double* coeff_out, size_t* indices_out, size_t& num_coeff ) 00100 { 00101 num_coeff = 6; 00102 const double sixth = 1.0 / 6.0; 00103 coeff_out[0] = sixth; 00104 coeff_out[1] = sixth; 00105 coeff_out[2] = sixth; 00106 coeff_out[3] = sixth; 00107 coeff_out[4] = sixth; 00108 coeff_out[5] = sixth; 00109 indices_out[0] = 0; 00110 indices_out[1] = 1; 00111 indices_out[2] = 2; 00112 indices_out[3] = 3; 00113 indices_out[4] = 4; 00114 indices_out[5] = 5; 00115 } 00116 00117 void LinearPrism::coefficients( Sample loc, 00118 NodeSet nodeset, 00119 double* coeff_out, 00120 size_t* indices_out, 00121 size_t& num_coeff, 00122 MsqError& err ) const 00123 { 00124 if( nodeset.have_any_mid_node() ) 00125 { 00126 MSQ_SETERR( err )( nonlinear_error, MsqError::UNSUPPORTED_ELEMENT ); 00127 return; 00128 } 00129 00130 switch( loc.dimension ) 00131 { 00132 case 0: 00133 coefficients_at_corner( loc.number, coeff_out, indices_out, num_coeff ); 00134 break; 00135 case 1: 00136 coefficients_at_mid_edge( loc.number, coeff_out, indices_out, num_coeff ); 00137 break; 00138 case 2: 00139 coefficients_at_mid_face( loc.number, coeff_out, indices_out, num_coeff ); 00140 break; 00141 case 3: 00142 coefficients_at_mid_elem( coeff_out, indices_out, num_coeff ); 00143 break; 00144 default: 00145 MSQ_SETERR( err )( "Invalid/unsupported logical dimension", MsqError::INVALID_ARG ); 00146 } 00147 } 00148 00149 static void derivatives_at_corner( unsigned corner, 00150 size_t* vertex_indices_out, 00151 MsqVector< 3 >* d_coeff_d_xi_out, 00152 size_t& num_vtx ) 00153 { 00154 int tri = ( corner / 3 ); // 0 for xi=0, 1 for xi=1 00155 int tv = corner % 3; // index of corner with xi=constant triangle 00156 00157 num_vtx = 4; 00158 // three vertices within the xi=constant triangle 00159 vertex_indices_out[0] = 3 * tri; 00160 vertex_indices_out[1] = 3 * tri + 1; 00161 vertex_indices_out[2] = 3 * tri + 2; 00162 // vertex adjacent to corner in other triangle 00163 vertex_indices_out[3] = 3 - 6 * tri + corner; 00164 00165 // three vertices within the xi=constant triangle 00166 d_coeff_d_xi_out[0][0] = 0.0; 00167 d_coeff_d_xi_out[0][1] = -1.0; 00168 d_coeff_d_xi_out[0][2] = -1.0; 00169 d_coeff_d_xi_out[1][0] = 0.0; 00170 d_coeff_d_xi_out[1][1] = 1.0; 00171 d_coeff_d_xi_out[1][2] = 0.0; 00172 d_coeff_d_xi_out[2][0] = 0.0; 00173 d_coeff_d_xi_out[2][1] = 0.0; 00174 d_coeff_d_xi_out[2][2] = 1.0; 00175 // fix dxi value for input corner 00176 d_coeff_d_xi_out[tv][0] = 2 * tri - 1; 00177 // vertex adjacent to corner in other triangle 00178 d_coeff_d_xi_out[3][0] = 1 - 2 * tri; 00179 d_coeff_d_xi_out[3][1] = 0.0; 00180 d_coeff_d_xi_out[3][2] = 0.0; 00181 } 00182 00183 static void derivatives_at_mid_edge( unsigned edge, 00184 size_t* vertex_indices_out, 00185 MsqVector< 3 >* d_coeff_d_xi_out, 00186 size_t& num_vtx ) 00187 { 00188 int opp; // vertex opposite edge in same triagle 00189 00190 switch( edge / 3 ) 00191 { 00192 case 0: // triangle at xi = 0 00193 opp = ( edge + 2 ) % 3; 00194 00195 num_vtx = 5; 00196 // vertices in this xi = 0 triagnle 00197 vertex_indices_out[0] = 0; 00198 vertex_indices_out[1] = 1; 00199 vertex_indices_out[2] = 2; 00200 // adjacent vertices in xi = 1 triangle 00201 vertex_indices_out[3] = 3 + edge; 00202 vertex_indices_out[4] = 3 + ( edge + 1 ) % 3; 00203 00204 // vertices in this xi = 0 triagnle 00205 d_coeff_d_xi_out[0][0] = -0.5; 00206 d_coeff_d_xi_out[0][1] = -1.0; 00207 d_coeff_d_xi_out[0][2] = -1.0; 00208 d_coeff_d_xi_out[1][0] = -0.5; 00209 d_coeff_d_xi_out[1][1] = 1.0; 00210 d_coeff_d_xi_out[1][2] = 0.0; 00211 d_coeff_d_xi_out[2][0] = -0.5; 00212 d_coeff_d_xi_out[2][1] = 0.0; 00213 d_coeff_d_xi_out[2][2] = 1.0; 00214 // clear dxi for vertex opposite edge in xi = 0 triangle 00215 d_coeff_d_xi_out[opp][0] = 0.0; 00216 // adjacent vertices in xi = 1 triangle 00217 d_coeff_d_xi_out[3][0] = 0.5; 00218 d_coeff_d_xi_out[3][1] = 0.0; 00219 d_coeff_d_xi_out[3][2] = 0.0; 00220 d_coeff_d_xi_out[4][0] = 0.5; 00221 d_coeff_d_xi_out[4][1] = 0.0; 00222 d_coeff_d_xi_out[4][2] = 0.0; 00223 break; 00224 00225 case 1: // lateral edges (not in either triangle) 00226 num_vtx = 6; 00227 vertex_indices_out[0] = 0; 00228 vertex_indices_out[1] = 1; 00229 vertex_indices_out[2] = 2; 00230 vertex_indices_out[3] = 3; 00231 vertex_indices_out[4] = 4; 00232 vertex_indices_out[5] = 5; 00233 00234 // set all deta & dzeta values, zero all dxi values 00235 d_coeff_d_xi_out[0][0] = 0.0; 00236 d_coeff_d_xi_out[0][1] = -0.5; 00237 d_coeff_d_xi_out[0][2] = -0.5; 00238 d_coeff_d_xi_out[1][0] = 0.0; 00239 d_coeff_d_xi_out[1][1] = 0.5; 00240 d_coeff_d_xi_out[1][2] = 0.0; 00241 d_coeff_d_xi_out[2][0] = 0.0; 00242 d_coeff_d_xi_out[2][1] = 0.0; 00243 d_coeff_d_xi_out[2][2] = 0.5; 00244 d_coeff_d_xi_out[3][0] = 0.0; 00245 d_coeff_d_xi_out[3][1] = -0.5; 00246 d_coeff_d_xi_out[3][2] = -0.5; 00247 d_coeff_d_xi_out[4][0] = 0.0; 00248 d_coeff_d_xi_out[4][1] = 0.5; 00249 d_coeff_d_xi_out[4][2] = 0.0; 00250 d_coeff_d_xi_out[5][0] = 0.0; 00251 d_coeff_d_xi_out[5][1] = 0.0; 00252 d_coeff_d_xi_out[5][2] = 0.5; 00253 00254 // set dxi values for end points of edge 00255 d_coeff_d_xi_out[( edge - 3 )][0] = -1; 00256 d_coeff_d_xi_out[edge][0] = 1; 00257 break; 00258 00259 case 2: // triangle at xi = 1 00260 opp = ( edge + 2 ) % 3; 00261 00262 num_vtx = 5; 00263 // vertices in this xi = 1 triagnle 00264 vertex_indices_out[0] = 3; 00265 vertex_indices_out[1] = 4; 00266 vertex_indices_out[2] = 5; 00267 // adjacent vertices in xi = 1 triangle 00268 vertex_indices_out[3] = edge - 6; 00269 vertex_indices_out[4] = ( edge - 5 ) % 3; 00270 00271 // vertices in this xi = 1 triagnle 00272 d_coeff_d_xi_out[0][0] = 0.5; 00273 d_coeff_d_xi_out[0][1] = -1.0; 00274 d_coeff_d_xi_out[0][2] = -1.0; 00275 d_coeff_d_xi_out[1][0] = 0.5; 00276 d_coeff_d_xi_out[1][1] = 1.0; 00277 d_coeff_d_xi_out[1][2] = 0.0; 00278 d_coeff_d_xi_out[2][0] = 0.5; 00279 d_coeff_d_xi_out[2][1] = 0.0; 00280 d_coeff_d_xi_out[2][2] = 1.0; 00281 // clear dxi for vertex opposite edge in xi = 1 triangle 00282 d_coeff_d_xi_out[opp][0] = 0.0; 00283 // adjacent vertices in xi = 0 triangle 00284 d_coeff_d_xi_out[3][0] = -0.5; 00285 d_coeff_d_xi_out[3][1] = 0.0; 00286 d_coeff_d_xi_out[3][2] = 0.0; 00287 d_coeff_d_xi_out[4][0] = -0.5; 00288 d_coeff_d_xi_out[4][1] = 0.0; 00289 d_coeff_d_xi_out[4][2] = 0.0; 00290 break; 00291 } 00292 } 00293 static void derivatives_at_mid_face( unsigned face, 00294 size_t* vertex_indices_out, 00295 MsqVector< 3 >* d_coeff_d_xi_out, 00296 size_t& num_vtx ) 00297 { 00298 num_vtx = 6; 00299 vertex_indices_out[0] = 0; 00300 vertex_indices_out[1] = 1; 00301 vertex_indices_out[2] = 2; 00302 vertex_indices_out[3] = 3; 00303 vertex_indices_out[4] = 4; 00304 vertex_indices_out[5] = 5; 00305 00306 int opp; // start vtx of edge opposite from quad face 00307 int tri_offset; // offset in d_coeff_d_xi_out for triangle containing edge 00308 00309 if( face < 3 ) 00310 { // quad face 00311 // set all values 00312 d_coeff_d_xi_out[0][0] = -0.5; 00313 d_coeff_d_xi_out[0][1] = -0.5; 00314 d_coeff_d_xi_out[0][2] = -0.5; 00315 d_coeff_d_xi_out[1][0] = -0.5; 00316 d_coeff_d_xi_out[1][1] = 0.5; 00317 d_coeff_d_xi_out[1][2] = 0.0; 00318 d_coeff_d_xi_out[2][0] = -0.5; 00319 d_coeff_d_xi_out[2][1] = 0.0; 00320 d_coeff_d_xi_out[2][2] = 0.5; 00321 d_coeff_d_xi_out[3][0] = 0.5; 00322 d_coeff_d_xi_out[3][1] = -0.5; 00323 d_coeff_d_xi_out[3][2] = -0.5; 00324 d_coeff_d_xi_out[4][0] = 0.5; 00325 d_coeff_d_xi_out[4][1] = 0.5; 00326 d_coeff_d_xi_out[4][2] = 0.0; 00327 d_coeff_d_xi_out[5][0] = 0.5; 00328 d_coeff_d_xi_out[5][1] = 0.0; 00329 d_coeff_d_xi_out[5][2] = 0.5; 00330 // clear dxi for ends of edge opposite from face 00331 opp = ( face + 2 ) % 3; 00332 d_coeff_d_xi_out[opp][0] = 0.0; 00333 d_coeff_d_xi_out[( opp + 3 )][0] = 0.0; 00334 } 00335 else 00336 { // triangular faces 00337 // set all xi values, zero all other values 00338 const double third = 1. / 3; 00339 d_coeff_d_xi_out[0][0] = -third; 00340 d_coeff_d_xi_out[0][1] = 0; 00341 d_coeff_d_xi_out[0][2] = 0; 00342 d_coeff_d_xi_out[1][0] = -third; 00343 d_coeff_d_xi_out[1][1] = 0; 00344 d_coeff_d_xi_out[1][2] = 0; 00345 d_coeff_d_xi_out[2][0] = -third; 00346 d_coeff_d_xi_out[2][1] = 0; 00347 d_coeff_d_xi_out[2][2] = 0; 00348 d_coeff_d_xi_out[3][0] = third; 00349 d_coeff_d_xi_out[3][1] = 0; 00350 d_coeff_d_xi_out[3][2] = 0; 00351 d_coeff_d_xi_out[4][0] = third; 00352 d_coeff_d_xi_out[4][1] = 0; 00353 d_coeff_d_xi_out[4][2] = 0; 00354 d_coeff_d_xi_out[5][0] = third; 00355 d_coeff_d_xi_out[5][1] = 0; 00356 d_coeff_d_xi_out[5][2] = 0; 00357 // set deta and dzeta values for vertices in same triangle as edge 00358 tri_offset = 3 * ( face - 3 ); // either 0 or 3 00359 d_coeff_d_xi_out[tri_offset][1] = -1.0; 00360 d_coeff_d_xi_out[tri_offset][2] = -1.0; 00361 d_coeff_d_xi_out[tri_offset + 1][1] = 1.0; 00362 d_coeff_d_xi_out[tri_offset + 2][2] = 1.0; 00363 } 00364 } 00365 static void derivatives_at_mid_elem( size_t* vertex_indices_out, MsqVector< 3 >* d_coeff_d_xi_out, size_t& num_vtx ) 00366 { 00367 const double third = 1. / 3; 00368 00369 num_vtx = 6; 00370 ; 00371 vertex_indices_out[0] = 0; 00372 vertex_indices_out[1] = 1; 00373 vertex_indices_out[2] = 2; 00374 vertex_indices_out[3] = 3; 00375 vertex_indices_out[4] = 4; 00376 vertex_indices_out[5] = 5; 00377 00378 d_coeff_d_xi_out[0][0] = -third; 00379 d_coeff_d_xi_out[0][1] = -0.5; 00380 d_coeff_d_xi_out[0][2] = -0.5; 00381 d_coeff_d_xi_out[1][0] = -third; 00382 d_coeff_d_xi_out[1][1] = 0.5; 00383 d_coeff_d_xi_out[1][2] = 0.0; 00384 d_coeff_d_xi_out[2][0] = -third; 00385 d_coeff_d_xi_out[2][1] = 0.0; 00386 d_coeff_d_xi_out[2][2] = 0.5; 00387 d_coeff_d_xi_out[3][0] = third; 00388 d_coeff_d_xi_out[3][1] = -0.5; 00389 d_coeff_d_xi_out[3][2] = -0.5; 00390 d_coeff_d_xi_out[4][0] = third; 00391 d_coeff_d_xi_out[4][1] = 0.5; 00392 d_coeff_d_xi_out[4][2] = 0.0; 00393 d_coeff_d_xi_out[5][0] = third; 00394 d_coeff_d_xi_out[5][1] = 0.0; 00395 d_coeff_d_xi_out[5][2] = 0.5; 00396 } 00397 00398 void LinearPrism::derivatives( Sample loc, 00399 NodeSet nodeset, 00400 size_t* vertex_indices_out, 00401 MsqVector< 3 >* d_coeff_d_xi_out, 00402 size_t& num_vtx, 00403 MsqError& err ) const 00404 { 00405 if( nodeset.have_any_mid_node() ) 00406 { 00407 MSQ_SETERR( err )( nonlinear_error, MsqError::UNSUPPORTED_ELEMENT ); 00408 return; 00409 } 00410 00411 switch( loc.dimension ) 00412 { 00413 case 0: 00414 derivatives_at_corner( loc.number, vertex_indices_out, d_coeff_d_xi_out, num_vtx ); 00415 break; 00416 case 1: 00417 derivatives_at_mid_edge( loc.number, vertex_indices_out, d_coeff_d_xi_out, num_vtx ); 00418 break; 00419 case 2: 00420 derivatives_at_mid_face( loc.number, vertex_indices_out, d_coeff_d_xi_out, num_vtx ); 00421 break; 00422 case 3: 00423 derivatives_at_mid_elem( vertex_indices_out, d_coeff_d_xi_out, num_vtx ); 00424 break; 00425 default: 00426 MSQ_SETERR( err )( "Invalid/unsupported logical dimension", MsqError::INVALID_ARG ); 00427 } 00428 } 00429 00430 void LinearPrism::ideal( Sample, MsqMatrix< 3, 3 >& J, MsqError& ) const 00431 { 00432 const double a = 0.52455753171082409; // 2^(-2/3) * 3^(-1/6) 00433 const double b = 0.90856029641606983; // a * sqrt(3) = 1/2 cbrt(6) 00434 00435 J( 0, 0 ) = 2 * a; 00436 J( 0, 1 ) = 0.0; 00437 J( 0, 2 ) = 0.0; 00438 J( 1, 0 ) = 0.0; 00439 J( 1, 1 ) = 2 * a; 00440 J( 1, 2 ) = a; 00441 J( 2, 0 ) = 0.0; 00442 J( 2, 1 ) = 0.0; 00443 J( 2, 2 ) = b; 00444 } 00445 00446 } // namespace MBMesquite
