MOAB: Mesh Oriented datABase
(version 5.4.0)
00001 /* ***************************************************************** 00002 MESQUITE -- The Mesh Quality Improvement Toolkit 00003 00004 Copyright 2008 Lawrence Livermore National Laboratory. Under 00005 the terms of Contract B545069 with the University of Wisconsin -- 00006 Madison, Lawrence Livermore National Laboratory retains certain 00007 rights in this software. 00008 00009 This library is free software; you can redistribute it and/or 00010 modify it under the terms of the GNU Lesser General Public 00011 License as published by the Free Software Foundation; either 00012 version 2.1 of the License, or (at your option) any later version. 00013 00014 This library is distributed in the hope that it will be useful, 00015 but WITHOUT ANY WARRANTY; without even the implied warranty of 00016 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00017 Lesser General Public License for more details. 00018 00019 You should have received a copy of the GNU Lesser General Public License 00020 (lgpl.txt) along with this library; if not, write to the Free Software 00021 Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA 00022 00023 (2008) kraftche@cae.wisc.edu 00024 00025 ***************************************************************** */ 00026 00027 #ifndef MSQ_DOMAIN_CLASSIFIER_HPP 00028 #define MSQ_DOMAIN_CLASSIFIER_HPP 00029 00030 /** \file DomainClassifier.hpp 00031 * \brief 00032 * \author Jason Kraftcheck 00033 */ 00034 00035 #include "Mesquite.hpp" 00036 #include "MeshInterface.hpp" 00037 00038 namespace MBMesquite 00039 { 00040 00041 /**\brief Assign subsets of a mesh do different domains. 00042 * 00043 * Provide classification of mesh entities to domain(s). For 00044 * example, given a domain defined by multiple surfaces and 00045 * curves of intersection, associate the appropriate elements 00046 * and vertices to the appropriate geometric entities. 00047 */ 00048 class DomainClassifier : public MeshDomain 00049 { 00050 public: 00051 /**\brief Check that classification maps to B-Rep topology */ 00052 MESQUITE_EXPORT void test_valid_classification( Mesh* mesh, MsqError& err ); 00053 00054 /**\brief Classify mesh entities using tag values 00055 * 00056 * Given a list of MeshDomain instances, a unique 00057 * integer ID for each MeshDomain, and a tag name: 00058 * classify mesh entities by matching the tag value 00059 * on each mesh entity to the list of MeshDomain IDs. 00060 * 00061 *\param result DomainClassifier to popupate 00062 *\param mesh The MBMesquite::Mesh instance 00063 *\param tag_name Tag containing integer domain ID for each mesh entity. 00064 *\param domain_array Array of MeshDomain instances. 00065 *\param id_array Array of integer MeshDomain IDs. 00066 *\param array_length Length of 'domain_array' and 'id_array' 00067 */ 00068 static MESQUITE_EXPORT void classify_by_tag( DomainClassifier& result, 00069 Mesh* mesh, 00070 const char* tag_name, 00071 MeshDomain** domain_array, 00072 const int* id_array, 00073 unsigned array_length, 00074 MsqError& err ); 00075 00076 /**\brief Skin mesh and classify skin entities geometrically. 00077 * 00078 * Calculate the boundary of the mesh, and classify boundary 00079 * entities by calculating the distance from the mesh domain 00080 * to each vertex. 00081 * 00082 * NOTE: Mesquite's limited MeshDomain callback interface 00083 * is not sufficient for robust geometric classification. If 00084 * the mesh is not sufficiently refined, this method may produce 00085 * invalid results. 00086 * 00087 * NOTE: This method should not be used for surface meshes. 00088 * Everything in a surface mesh should be classified to a domain. 00089 * not just the skin. Use classify_geometrically instead. 00090 * 00091 *\param result DomainClassifier to popupate 00092 *\param mesh The MBMesquite::Mesh instance 00093 *\param tolerance Maximum distance a vertex may deviate from its domain. 00094 *\param domain_array Array of MeshDomain instances. 00095 *\param dimension_array Topological dimensiono of each MeshDomain 00096 *\param array_length Length of 'domain_array' and 'dimension_array' 00097 */ 00098 MESQUITE_EXPORT static void classify_skin_geometrically( DomainClassifier& result, 00099 Mesh* mesh, 00100 double tolerance, 00101 MeshDomain** domain_array, 00102 const int* dimension_array, 00103 unsigned array_length, 00104 MsqError& err ); 00105 00106 /**\brief Classify all mesh entities geometrically. 00107 * 00108 * Classify entities by distance from vertex coordiantes to 00109 * mesh domain instances. 00110 * 00111 * NOTE: Mesquite's limited MeshDomain callback interface 00112 * is not sufficient for robust geometric classification. If 00113 * the mesh is not sufficiently refined, this method may produce 00114 * invalid results. 00115 * 00116 * NOTE: This method is likely to fail for many domains for 00117 * volume meshes. Use classify_skin_geometrically for 00118 * volume meshes. 00119 * 00120 *\param result DomainClassifier to popupate 00121 *\param mesh The MBMesquite::Mesh instance 00122 *\param tolerance Maximum distance a vertex may deviate from its domain. 00123 *\param domain_array Array of MeshDomain instances. 00124 *\param dimension_array Topological dimensiono of each MeshDomain 00125 *\param array_length Length of 'domain_array' and 'dimension_array' 00126 */ 00127 MESQUITE_EXPORT static void classify_geometrically( DomainClassifier& result, 00128 Mesh* mesh, 00129 double tolerance, 00130 MeshDomain** domain_array, 00131 const int* dimension_array, 00132 unsigned array_length, 00133 MsqError& err ); 00134 00135 struct DomainSet 00136 { 00137 MESQUITE_EXPORT DomainSet( MeshDomain* dom ) : domain( dom ) {} 00138 MESQUITE_EXPORT DomainSet() : domain( 0 ) {} 00139 MeshDomain* domain; 00140 MESQUITE_EXPORT void set_vertices( const std::vector< Mesh::VertexHandle >& verts ) 00141 { 00142 vertices = verts; 00143 } 00144 MESQUITE_EXPORT void set_elements( const std::vector< Mesh::ElementHandle >& elems ) 00145 { 00146 elements = elems; 00147 } 00148 MESQUITE_EXPORT void get_vertices( std::vector< Mesh::VertexHandle >& verts ) const 00149 { 00150 verts = vertices; 00151 } 00152 MESQUITE_EXPORT void get_elements( std::vector< Mesh::ElementHandle >& elems ) const 00153 { 00154 elems = elements; 00155 } 00156 std::vector< Mesh::VertexHandle > vertices; 00157 std::vector< Mesh::ElementHandle > elements; 00158 }; 00159 00160 /**\brief Specify classification explicitly for each entity. 00161 * 00162 * For each mesh element and vertex that is classified to 00163 * a domain, specify that classification explicitly. 00164 * 00165 *\param result DomainClassifier to popupate 00166 *\param mesh The MBMesquite::Mesh instance 00167 *\param domain_set_array Array of DomainClassifier::DomainSet structs 00168 * specifying for each MeshDomain: the 00169 * domain instance and the elements and 00170 * vertices associated with the domain. 00171 *\param array_length Length of 'domain_set_array' 00172 */ 00173 MESQUITE_EXPORT static void classify_by_handle( DomainClassifier& result, 00174 Mesh* mesh, 00175 DomainSet* domain_set_array, 00176 unsigned array_length, 00177 MsqError& err ); 00178 00179 MESQUITE_EXPORT DomainClassifier() : deleteSubDomains( false ) {} 00180 00181 MESQUITE_EXPORT virtual ~DomainClassifier(); 00182 00183 MESQUITE_EXPORT 00184 virtual void snap_to( Mesh::VertexHandle entity_handle, Vector3D& coordinate ) const; 00185 00186 MESQUITE_EXPORT 00187 virtual void vertex_normal_at( Mesh::VertexHandle entity_handle, Vector3D& coordinate ) const; 00188 MESQUITE_EXPORT 00189 virtual void element_normal_at( Mesh::ElementHandle entity_handle, Vector3D& coordinate ) const; 00190 00191 MESQUITE_EXPORT 00192 virtual void vertex_normal_at( const Mesh::VertexHandle* handles, 00193 Vector3D coordinates[], 00194 unsigned count, 00195 MsqError& err ) const; 00196 00197 MESQUITE_EXPORT 00198 virtual void closest_point( Mesh::VertexHandle handle, 00199 const Vector3D& position, 00200 Vector3D& closest, 00201 Vector3D& normal, 00202 MsqError& err ) const; 00203 00204 MESQUITE_EXPORT 00205 virtual void domain_DoF( const Mesh::VertexHandle* handle_array, 00206 unsigned short* dof_array, 00207 size_t num_handles, 00208 MsqError& err ) const; 00209 00210 /**\brief Clear all data, including MeshDomain list */ 00211 MESQUITE_EXPORT 00212 void clear() 00213 { 00214 vertexList.clear(); 00215 elementList.clear(); 00216 } 00217 00218 struct DomainBlock 00219 { 00220 Mesh::EntityHandle firstHandle; 00221 Mesh::EntityHandle lastHandle; 00222 MeshDomain* domain; 00223 }; 00224 00225 MESQUITE_EXPORT 00226 MeshDomain* find_vertex_domain( Mesh::VertexHandle vertex ) const 00227 { 00228 return find_domain( vertex, vertexList ); 00229 } 00230 MESQUITE_EXPORT 00231 MeshDomain* find_element_domain( Mesh::ElementHandle element ) const 00232 { 00233 return find_domain( element, elementList ); 00234 } 00235 00236 MESQUITE_EXPORT 00237 void delete_sub_domains( bool yesno ) 00238 { 00239 deleteSubDomains = yesno; 00240 } 00241 00242 MESQUITE_EXPORT 00243 void delete_all_sub_domains(); 00244 00245 private: 00246 bool deleteSubDomains; 00247 00248 static MeshDomain* find_domain( Mesh::EntityHandle handle, const std::vector< DomainBlock >& list ); 00249 00250 std::vector< DomainBlock > vertexList; 00251 std::vector< DomainBlock > elementList; 00252 }; 00253 00254 } // namespace MBMesquite 00255 00256 #endif // MSQ_DOMAIN_CLASSIFIER_HPP
