MOAB: Mesh Oriented datABase
(version 5.3.1)
#include "MeshDomain1D.hpp"
#include "PlanarDomain.hpp"
#include "CylinderDomain.hpp"
#include "ConicDomain.hpp"
#include "SphericalDomain.hpp"
#include "DomainClassifier.hpp"
#include "MeshImpl.hpp"
#include "CLArgs.hpp"
#include "MsqError.hpp"
#include "TopologyInfo.hpp"
#include "domain.hpp"
#include <iostream>
#include <algorithm>
#include <cstdlib>
Classes | |
class | SphereDomainArg |
class | ConicDomainArg |
class | CylinderDomainArg |
class | PlanarDomainArg |
class | LineDomainArg |
class | CircleDomainArg |
class | PointDomainArg |
Functions | |
void | add_domain_args (CLArgs &args) |
MeshDomain * | process_domain_args (MeshImpl *mesh) |
Variables | |
std::vector< MeshDomain * > | domains |
std::vector< int > | domain_dims |
SphereDomainArg | sphere_arg (domains, domain_dims) |
ConicDomainArg | conic_arg (domains, domain_dims) |
CylinderDomainArg | cylinder_arg (domains, domain_dims) |
PlanarDomainArg | plane_arg (domains, domain_dims) |
CircleDomainArg | circle_arg (domains, domain_dims) |
LineDomainArg | line_arg (domains, domain_dims) |
PointDomainArg | point_arg (domains, domain_dims) |
CLArgs::ToggleArg | skin_mesh (false) |
const char * | SPHERE_VALUES [] = { "rad", "x", "y", "z" } |
const char * | CYLINDER_VALUES [] = { "rad", "i", "j", "k", "x", "y", "z" } |
const char * | CONE_VALUES [] = { "rad", "h", "i", "j", "k", "x", "y", "z" } |
void add_domain_args | ( | CLArgs & | args | ) |
Definition at line 212 of file domain.cpp.
References circle_arg, CIRCLE_FLAG, CONE_FLAG, CONE_VALUES, conic_arg, cylinder_arg, CYLINDER_FLAG, CYLINDER_VALUES, CLArgs::double_list_flag(), CLArgs::limit_list_flag(), line_arg, LINE_FLAG, plane_arg, PLANE_FLAG, point_arg, POINT_FLAG, SKIN_FLAG, skin_mesh, sphere_arg, SPHERE_FLAG, SPHERE_VALUES, and CLArgs::toggle_flag().
Referenced by main().
{ args.toggle_flag( SKIN_FLAG, "Mark boundary vertices as fixed (default if no domain specified)", &skin_mesh ); args.double_list_flag( SPHERE_FLAG, "Spherical domain as center and radius", &sphere_arg ); args.limit_list_flag( SPHERE_FLAG, 4, SPHERE_VALUES ); args.limit_list_flag( SPHERE_FLAG, 1, SPHERE_VALUES ); args.double_list_flag( PLANE_FLAG, "Planar domain as normal and point", &plane_arg ); args.limit_list_flag( PLANE_FLAG, 3, CYLINDER_VALUES + 1 ); args.limit_list_flag( PLANE_FLAG, 6, CYLINDER_VALUES + 1 ); args.double_list_flag( CYLINDER_FLAG, "Cylindrical radius, axis, and point", &cylinder_arg ); args.limit_list_flag( CYLINDER_FLAG, 4, CYLINDER_VALUES ); args.limit_list_flag( CYLINDER_FLAG, 7, CYLINDER_VALUES ); args.double_list_flag( CONE_FLAG, "Conic domain as base radius, height, axis, and base center", &conic_arg ); args.limit_list_flag( CONE_FLAG, 2, CONE_VALUES ); args.limit_list_flag( CONE_FLAG, 5, CONE_VALUES ); args.limit_list_flag( CONE_FLAG, 8, CONE_VALUES ); args.double_list_flag( LINE_FLAG, "Linear domain as direction and point", &line_arg ); args.limit_list_flag( LINE_FLAG, 3, CYLINDER_VALUES + 1 ); args.limit_list_flag( LINE_FLAG, 6, CYLINDER_VALUES + 1 ); args.double_list_flag( CIRCLE_FLAG, "Circular domain as radius, normal, and center", &circle_arg ); args.limit_list_flag( CIRCLE_FLAG, 4, CYLINDER_VALUES ); args.limit_list_flag( CIRCLE_FLAG, 7, CYLINDER_VALUES ); args.double_list_flag( POINT_FLAG, "Point domain", &point_arg ); args.limit_list_flag( POINT_FLAG, 3, SPHERE_VALUES + 1 ); }
MeshDomain* process_domain_args | ( | MeshImpl * | mesh | ) |
Definition at line 238 of file domain.cpp.
References MBMesquite::arrptr(), MBMesquite::DomainClassifier::classify_geometrically(), MBMesquite::DomainClassifier::classify_skin_geometrically(), domain_dims, domains, MBMesquite::MeshImpl::elements_get_topologies(), MBMesquite::MeshImpl::get_all_elements(), MBMesquite::MeshImpl::mark_skin_fixed(), skin_mesh, and CLArgs::ArgTemplate< T >::value().
{ MsqPrintError err( std::cerr ); MeshDomain* rval = 0; if( !domains.empty() ) { int max_domain_dim = *std::max_element( domain_dims.begin(), domain_dims.end() ); std::vector< Mesh::ElementHandle > elems; mesh->get_all_elements( elems, err ); std::vector< EntityTopology > types( elems.size() ); mesh->elements_get_topologies( arrptr( elems ), arrptr( types ), elems.size(), err ); EntityTopology max_type = *std::max_element( types.begin(), types.end() ); int max_elem_dim = TopologyInfo::dimension( max_type ); if( max_domain_dim == max_elem_dim && domains.size() == 1 ) { rval = domains.front(); } else { DomainClassifier* result = new DomainClassifier(); if( max_domain_dim < max_elem_dim ) { DomainClassifier::classify_skin_geometrically( *result, mesh, 1e-4, arrptr( domains ), arrptr( domain_dims ), domains.size(), err ); } else { DomainClassifier::classify_geometrically( *result, mesh, 1e-4, arrptr( domains ), arrptr( domain_dims ), domains.size(), err ); } rval = result; } } if( skin_mesh.value() ) { mesh->mark_skin_fixed( err, false ); } if( err ) { std::cerr << err << std::endl; exit( 3 ); } return rval; }
Referenced by add_domain_args().
const char* CONE_VALUES[] = { "rad", "h", "i", "j", "k", "x", "y", "z" } |
Definition at line 210 of file domain.cpp.
const char* CYLINDER_VALUES[] = { "rad", "i", "j", "k", "x", "y", "z" } |
Definition at line 209 of file domain.cpp.
std::vector< int > domain_dims |
Definition at line 198 of file domain.cpp.
Referenced by process_domain_args().
std::vector< MeshDomain* > domains |
Definition at line 197 of file domain.cpp.
Referenced by MBMesquite::DomainClassifier::classify_geometrically(), MBMesquite::DomainClassifier::classify_skin_geometrically(), MBMesquite::DomainClassifier::delete_all_sub_domains(), process_domain_args(), and MBMesquite::DomainClassifier::test_valid_classification().
CLArgs::ToggleArg skin_mesh(false) |
Referenced by add_domain_args(), and process_domain_args().
const char* SPHERE_VALUES[] = { "rad", "x", "y", "z" } |
Definition at line 208 of file domain.cpp.
