voshell.cpp
00001 /* *****************************************************************
00002     MESQUITE -- The Mesh Quality Improvement Toolkit
00003
00004     Copyright 2010 Sandia National Laboratories.  Developed at the
00005     University of Wisconsin--Madison under SNL contract number
00006     624796.  The U.S. Government and the University of Wisconsin
00007     retain certain rights to this software.
00008
00009     This library is free software; you can redistribute it and/or
00010     modify it under the terms of the GNU Lesser General Public
00011     License as published by the Free Software Foundation; either
00012     version 2.1 of the License, or (at your option) any later version.
00013
00014     This library is distributed in the hope that it will be useful,
00015     but WITHOUT ANY WARRANTY; without even the implied warranty of
00016     MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00017     Lesser General Public License for more details.
00018
00019     You should have received a copy of the GNU Lesser General Public License
00020     (lgpl.txt) along with this library; if not, write to the Free Software
00021     Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307  USA
00022
00023     (2011) kraftche@cae.wisc.edu
00024
00025   ***************************************************************** */
00026
00027 /** \file voshell.cpp
00028  *  \brief Implement some of the examples from N. Voshell.
00029  *  \author Jason Kraftcheck
00030  *  \author Nick Voshell
00031  */
00032
00033 #include "TestUtil.hpp"
00034 #include "ShapeImprover.hpp"
00035 #include "UntangleWrapper.hpp"
00036 #include "MeshImpl.hpp"
00037 #include "MsqError.hpp"
00038 #include "QualityAssessor.hpp"
00039
00040 #include "PlanarDomain.hpp"
00041 #include "CylinderDomain.hpp"
00042 #include "SphericalDomain.hpp"
00043 #include "MeshDomain1D.hpp"
00044 #include "DomainClassifier.hpp"
00045
00046 #include "HexLagrangeShape.hpp"
00047 #include "TestUtil.hpp"
00048
00049 #include <iostream>
00050 #include <string>
00051 #include <cstdlib>
00052
00053 using namespace MBMesquite;
00054
00055 std::string get_homogenious_example( DomainClassifier& geom, MeshImpl& mesh, MsqError& err );
00056
00057 std::string get_part_example_tri( DomainClassifier& geom, MeshImpl& mesh, MsqError& err );
00058
00059 std::string get_part_example_quad( DomainClassifier& geom, MeshImpl& mesh, MsqError& err );
00060
00061 std::string get_sphere_cube_example( DomainClassifier& geom, MeshImpl& mesh, MsqError& err );
00062
00063 std::string get_cut_cube_example( DomainClassifier& geom, MeshImpl& mesh, MsqError& err );
00064
00065 std::string get_sphere_cylinder_example( DomainClassifier& geom, MeshImpl& mesh, MsqError& err );
00066
00067 std::string get_hex_3d_part_example( DomainClassifier& geom, MeshImpl& mesh, MsqError& err );
00068
00069 typedef std::string ( *example_setup_t )( DomainClassifier& geom, MeshImpl& mesh, MsqError& err );
00070 struct Example
00071 {
00072     char flag;
00073     example_setup_t func;
00074     const char* desc;
00075 };
00076
00077 int run_example( const Example& e, bool write_output_file );
00078
00079 const Example examples[] = { { 'H', &get_homogenious_example, "homogenous mesh (curvey surface) example" },
00080                              { 't', &get_part_example_tri, "part mesh with triangles" },
00081                              { 'q', &get_part_example_quad, "part mesh with quads" },
00082                              { 'c', &get_sphere_cube_example, "cube with subtracted hemisphere" },
00083                              { 'l', &get_cut_cube_example, "cube with slot removed" },
00084                              { 's', &get_sphere_cylinder_example, "cylinder with subtracted sphere" },
00085                              { 'x', &get_hex_3d_part_example, "rectangular prism with two cylindrical slots" } };
00086 const int num_examples   = sizeof( examples ) / sizeof( examples[0] );
00087
00088 void usage( const char* argv0, bool help = false )
00089 {
00090     std::cerr << "Usage: " << argv0 << "[-w] ";
00091     for( int i = 0; i < num_examples; ++i )
00092         std::cerr << " [-" << examples[i].flag << "]";
00093     std::cerr << std::endl;
00094
00095     if( !help )
00096     {
00097         std::cerr << "       " << argv0 << " -h" << std::endl;
00098         std::exit( 1 );
00099     }
00100     std::cerr << "  -w : Write final meshes to VTK file" << std::endl;
00101     std::cerr << "NOTE: If no options are specified, all examples will be run" << std::endl;
00102     for( int i = 0; i < num_examples; ++i )
00103         std::cerr << "  -" << examples[i].flag << " : Run " << examples[i].desc << std::endl;
00104     std::cerr << std::endl;
00105     std::exit( 0 );
00106 }
00107
00108 int main( int argc, char* argv[] )
00109 {
00110     bool write_final_meshes = false;
00111     std::vector< Example > list;
00112     for( int i = 1; i < argc; ++i )
00113     {
00114         if( argv[i][0] != '-' )
00115         {
00116             std::cerr << "Invalid argument: \"" << argv[i] << '"' << std::endl;
00117             usage( argv[0] );
00118         }
00119         for( int j = 1; argv[i][j]; ++j )
00120         {
00121             if( argv[i][j] == 'w' )
00122             {
00123                 write_final_meshes = true;
00124             }
00125             else
00126             {
00127                 int idx;
00128                 for( idx = 0; idx < num_examples; ++idx )
00129                     if( examples[idx].flag == argv[i][j] ) break;
00130                 if( idx == num_examples )
00131                 {
00132                     if( argv[i][j] == 'h' )
00133                         usage( argv[0], true );
00134                     else
00135                     {
00136                         std::cerr << "Invalid flag: '" << argv[i][j] << "'" << std::endl;
00137                         usage( argv[0] );
00138                     }
00139                 }
00140                 list.push_back( examples[idx] );
00141             }
00142         }
00143     }
00144
00145     const Example* exlist;
00146     int exlistlen;
00147     if( list.empty() )
00148     {
00149         exlist    = examples;
00150         exlistlen = num_examples;
00151     }
00152     else
00153     {
00154         exlist    = &list[0];
00155         exlistlen = list.size();
00156     }
00157
00158     int result = 0;
00159     for( int i = 0; i < exlistlen; ++i )
00160         result += run_example( exlist[i], write_final_meshes );
00161
00162     return result;
00163 }
00164
00165 int run_example( const Example& e, bool write_output_file )
00166 {
00167     MsqPrintError err( std::cerr );
00168     MeshImpl mesh;
00169     DomainClassifier domain;
00170     HexLagrangeShape hex27;
00171
00172     std::cout << std::endl
00173               << "--------------------------------------------------------------------" << std::endl
00174               << e.desc << std::endl
00175               << "--------------------------------------------------------------------" << std::endl;
00176
00177     std::string name = e.func( domain, mesh, err );
00178     if( MSQ_CHKERR( err ) ) return 2;
00179     std::cout << "Loaded mesh from: " << name << std::endl;
00180
00181     UntangleWrapper untangler;
00182     untangler.set_slaved_ho_node_mode( Settings::SLAVE_NONE );
00183     untangler.set_mapping_function( &hex27 );
00184     MeshDomainAssoc mesh_and_domain = MeshDomainAssoc( &mesh, &domain, false, true );
00185     untangler.run_instructions( &mesh_and_domain, err );
00186     if( MSQ_CHKERR( err ) ) return 1;
00187     ShapeImprover smoother;
00188     smoother.set_slaved_ho_node_mode( Settings::SLAVE_NONE );
00189     smoother.set_mapping_function( &hex27 );
00190     smoother.set_vertex_movement_limit_factor( 0.05 );
00191     smoother.run_instructions( &mesh_and_domain, err );
00192     if( MSQ_CHKERR( err ) ) return 1;
00193
00194     if( write_output_file )
00195     {
00196         size_t idx = name.find( ".vtk" );
00197         if( idx != std::string::npos )
00198         {
00199             std::string newname( name.substr( 0, idx ) );
00200             newname += ".out";
00201             newname += name.substr( idx );
00202             name.swap( newname );
00203         }
00204         else
00205         {
00206             name += ".out";
00207         }
00208
00209         mesh.write_vtk( name.c_str(), err );MSQ_CHKERR( err );
00210         std::cout << "Write mesh to file: " << name << std::endl;
00211     }
00212
00213     return smoother.quality_assessor().invalid_elements();
00214 }
00215
00216 void get_planar_example( const char* filename, DomainClassifier& geom, MeshImpl& mesh, MsqError& err )
00217 {
00218     static PlanarDomain z( PlanarDomain::XY );
00219     mesh.read_vtk( filename, err );MSQ_ERRRTN( err );
00220     mesh.mark_skin_fixed( err );MSQ_ERRRTN( err );
00221     DomainClassifier::DomainSet set( &z );
00222     mesh.get_all_vertices( set.vertices, err );MSQ_ERRRTN( err );
00223     mesh.get_all_elements( set.elements, err );MSQ_ERRRTN( err );
00224     DomainClassifier::classify_by_handle( geom, &mesh, &set, 1, err );MSQ_ERRRTN( err );
00225 }
00226
00227 std::string get_homogenious_example( DomainClassifier& geom, MeshImpl& mesh, MsqError& err )
00228 {
00229     std::string filename = std::string( STRINGIFY( SRCDIR ) ) + "/homogeneousPart.vtk";
00230     get_planar_example( filename.c_str(), geom, mesh, err );MSQ_CHKERR( err );
00231     return filename;
00232 }
00233
00234 std::string get_part_example_tri( DomainClassifier& geom, MeshImpl& mesh, MsqError& err )
00235 {
00236     std::string filename = std::string( STRINGIFY( SRCDIR ) ) + "/triPart.vtk";
00237     get_planar_example( filename.c_str(), geom, mesh, err );MSQ_CHKERR( err );
00238     return filename;
00239 }
00240
00241 std::string get_part_example_quad( DomainClassifier& geom, MeshImpl& mesh, MsqError& err )
00242 {
00243     std::string filename = std::string( STRINGIFY( SRCDIR ) ) + "/quadPart.vtk";
00244     get_planar_example( filename.c_str(), geom, mesh, err );MSQ_CHKERR( err );
00245     return filename;
00246 }
00247
00248 std::string get_sphere_cube_example( DomainClassifier& geom, MeshImpl& mesh, MsqError& err )
00249 {
00250     std::string filename = std::string( STRINGIFY( SRCDIR ) ) + "/sphereCube.vtk";
00251
00252     const Vector3D vec_i( 5, 0, 0 ), vec_ni( -5, 0, 0 );
00253     const Vector3D vec_j( 0, 5, 0 ), vec_nj( 0, -5, 0 );
00254     const Vector3D vec_k( 0, 0, 5 ), vec_nk( 0, 0, -5 );
00255
00256     const Vector3D vec_tfl( 5, -5, 5 ), vec_tfr( 5, 5, 5 );
00257     const Vector3D vec_tbl( -5, -5, 5 ), vec_tbr( -5, 5, 5 );
00258     const Vector3D vec_bfl( 5, -5, -5 ), vec_bfr( 5, 5, -5 );
00259     const Vector3D vec_bbl( -5, -5, -5 ), vec_bbr( -5, 5, -5 );
00260
00261     const Vector3D vec_ts( 5, 0, 2 ), vec_bs( 5, 0, -2 );
00262
00263     //++ 0D domains ++
00264
00265     static PointDomain pt_tfl( vec_tfl ), pt_tfr( vec_tfr );
00266     static PointDomain pt_tbl( vec_tbl ), pt_tbr( vec_tbr );
00267     static PointDomain pt_bfl( vec_bfl ), pt_bfr( vec_bfr );
00268     static PointDomain pt_bbl( vec_bbl ), pt_bbr( vec_bbr );
00269
00270     //++ 1D domains ++
00271
00272     // top square
00273     static LineDomain ln_tf( vec_tfl, vec_j ), lin_tb( vec_tbr, vec_nj );
00274     static LineDomain ln_tl( vec_tfl, vec_ni ), lin_tr( vec_tbr, vec_i );
00275     // bottom square
00276     static LineDomain ln_bf( vec_bfl, vec_j ), lin_bb( vec_bbr, vec_nj );
00277     static LineDomain ln_bl( vec_bfl, vec_ni ), lin_br( vec_bbr, vec_i );
00278     // sides
00279     static LineDomain ln_lf( vec_bfl, vec_k ), lin_rf( vec_bfr, vec_k );
00280     static LineDomain ln_lb( vec_bbl, vec_k ), lin_rb( vec_bbr, vec_k );
00281
00282     // top sphere
00283     // CircleDomain cr_tf(vec_ts,vec_i,1.0), cr_tn(vec_ts,vec_k,1.0);
00284     // bottom sphere
00285     // CircleDomain cr_bf(vec_bs,vec_i,1.0), cr_bn(vec_bs,vec_k,1.0);
00286     static CircleDomain cr_ct( vec_k, vec_k, 1.0 );
00287
00288     //++ 2D domains ++
00289
00290     // cube
00291     static PlanarDomain sf_i( vec_i, vec_i ), sf_ni( vec_ni, vec_ni );
00292     static PlanarDomain sf_j( vec_j, vec_j ), sf_nj( vec_nj, vec_nj );
00293     static PlanarDomain sf_k( vec_k, vec_k ), sf_nk( vec_nk, vec_nk );
00294     // cut
00295     // CylinderDomain cy(1.0,vec_k,vec_bs);
00296     static SphericalDomain sp_t( vec_k, 1.0 );  //, sp_b(vec_bs,1.0);
00297
00298     MeshDomain* base_domains[] = {
00299         &pt_tfl, &pt_tfr, &pt_tbl, &pt_tbr, &pt_bfl, &pt_bfr, &pt_bbl, &pt_bbr,
00300
00301         &ln_tf, &lin_tb, &ln_tl, &lin_tr, &ln_bf, &lin_bb, &ln_bl, &lin_br, &ln_lf, &lin_rf, &ln_lb, &lin_rb,
00302
00303         //  &cr_tf, &cr_tn,
00304         //  &cr_bf, &cr_bn,
00305         &cr_ct,
00306
00307         &sf_i, &sf_ni, &sf_j, &sf_nj, &sf_k, &sf_nk,
00308         //&cy,
00309         &sp_t  //, &sp_b
00310     };
00311     const int NDOM = sizeof( base_domains ) / sizeof( base_domains[0] );
00312
00313     int dim_array[NDOM] = {
00314         0, 0, 0, 0, 0, 0, 0, 0, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1,  // 1,1,1,
00315         2, 2, 2, 2, 2, 2, 2                                             //,2,2
00316     };
00317
00318     //++ MESH & DOMAIN ++
00319
00320     mesh.read_vtk( filename.c_str(), err );
00321     MSQ_ERRZERO( err );
00322     DomainClassifier::classify_skin_geometrically( geom, &mesh, 0.1, base_domains, dim_array, NDOM, err );
00323     MSQ_ERRZERO( err );
00324     mesh.set_skin_flags( false, false, true, err );
00325     MSQ_ERRZERO( err );
00326
00327     return filename;
00328 }
00329
00330 std::string get_cut_cube_example( DomainClassifier& geom, MeshImpl& mesh, MsqError& err )
00331 {
00332     std::string filename = std::string( STRINGIFY( SRCDIR ) ) + "/cutCube.vtk";
00333
00334     const Vector3D vec_i( 5, 0, 0 ), vec_ni( -5, 0, 0 );
00335     const Vector3D vec_j( 0, 5, 0 ), vec_nj( 0, -5, 0 );
00336     const Vector3D vec_k( 0, 0, 5 ), vec_nk( 0, 0, -5 );
00337
00338     const Vector3D vec_tfl( 5, -5, 5 ), vec_tfr( 5, 5, 5 );
00339     const Vector3D vec_tbl( -5, -5, 5 ), vec_tbr( -5, 5, 5 );
00340     const Vector3D vec_bfl( 5, -5, -5 ), vec_bfr( 5, 5, -5 );
00341     const Vector3D vec_bbl( -5, -5, -5 ), vec_bbr( -5, 5, -5 );
00342
00343     const Vector3D vec_ts( 5, 0, 2 ), vec_bs( 5, 0, -2 );
00344
00345     //++ 0D domains ++
00346
00347     static PointDomain pt_tfl( vec_tfl ), pt_tfr( vec_tfr );
00348     static PointDomain pt_tbl( vec_tbl ), pt_tbr( vec_tbr );
00349     static PointDomain pt_bfl( vec_bfl ), pt_bfr( vec_bfr );
00350     static PointDomain pt_bbl( vec_bbl ), pt_bbr( vec_bbr );
00351
00352     //++ 1D domains ++
00353
00354     // top square
00355     static LineDomain ln_tf( vec_tfl, vec_j ), lin_tb( vec_tbr, vec_nj );
00356     static LineDomain ln_tl( vec_tfl, vec_ni ), lin_tr( vec_tbr, vec_i );
00357     // bottom square
00358     static LineDomain ln_bf( vec_bfl, vec_j ), lin_bb( vec_bbr, vec_nj );
00359     static LineDomain ln_bl( vec_bfl, vec_ni ), lin_br( vec_bbr, vec_i );
00360     // sides
00361     static LineDomain ln_lf( vec_bfl, vec_k ), lin_rf( vec_bfr, vec_k );
00362     static LineDomain ln_lb( vec_bbl, vec_k ), lin_rb( vec_bbr, vec_k );
00363
00364     // top sphere
00365     static CircleDomain cr_tf( vec_ts, vec_i, 1.0 ), cr_tn( vec_ts, vec_k, 1.0 );
00366     // bottom sphere
00367     static CircleDomain cr_bf( vec_bs, vec_i, 1.0 ), cr_bn( vec_bs, vec_k, 1.0 );
00368
00369     //++ 2D domains ++
00370
00371     // cube
00372     static PlanarDomain sf_i( vec_i, vec_i ), sf_ni( vec_ni, vec_ni );
00373     static PlanarDomain sf_j( vec_j, vec_j ), sf_nj( vec_nj, vec_nj );
00374     static PlanarDomain sf_k( vec_k, vec_k ), sf_nk( vec_nk, vec_nk );
00375     // cut
00376     static CylinderDomain cy( 1.0, vec_k, vec_bs );
00377     static SphericalDomain sp_t( vec_ts, 1.0 ), sp_b( vec_bs, 1.0 );
00378
00379     MeshDomain* base_domains[] = { &pt_tfl, &pt_tfr, &pt_tbl, &pt_tbr, &pt_bfl, &pt_bfr, &pt_bbl, &pt_bbr,
00380
00381                                    &ln_tf,  &lin_tb, &ln_tl,  &lin_tr, &ln_bf,  &lin_bb, &ln_bl,  &lin_br, &ln_lf,
00382                                    &lin_rf, &ln_lb,  &lin_rb, &cr_tf,  &cr_tn,  &cr_bf,  &cr_bn,
00383
00384                                    &sf_i,   &sf_ni,  &sf_j,   &sf_nj,  &sf_k,   &sf_nk,  &cy,     &sp_t,   &sp_b };
00385     const int NDOM             = sizeof( base_domains ) / sizeof( base_domains[0] );
00386
00387     int dim_array[NDOM] = { 0, 0, 0, 0, 0, 0, 0, 0, 1, 1, 1, 1, 1, 1, 1, 1, 1,
00388                             1, 1, 1, 1, 1, 1, 1, 2, 2, 2, 2, 2, 2, 2, 2, 2 };
00389
00390     //++ MESH & DOMAIN ++
00391
00392     mesh.read_vtk( filename.c_str(), err );
00393     MSQ_ERRZERO( err );
00394     DomainClassifier::classify_skin_geometrically( geom, &mesh, 0.1, base_domains, dim_array, NDOM, err );
00395     MSQ_ERRZERO( err );
00396     mesh.set_skin_flags( false, false, true, err );
00397     MSQ_ERRZERO( err );
00398
00399     return filename;
00400 }
00401
00402 std::string get_sphere_cylinder_example( DomainClassifier& geom, MeshImpl& mesh, MsqError& err )
00403 {
00404     std::string filename = std::string( STRINGIFY( SRCDIR ) ) + "/sphereCylinder_1194_inv.vtk";
00405
00406     const Vector3D vec_k( 0, 0, 8 ), vec_nk( 0, 0, -8 );
00407     const Vector3D vec_c( 0, 0, 5 );
00408
00409     //++ 0D domains ++
00410
00411     //++ 1D domains ++
00412
00413     // top circle
00414     static CircleDomain cr_to( vec_k, vec_k, 8.0 ), cr_ti( vec_k, vec_k, 4.0 );
00415     // bottom circle
00416     static CircleDomain cr_bo( vec_nk, vec_nk, 8.0 );
00417
00418     //++ 2D domains ++
00419
00420     static PlanarDomain sf_t( vec_k, vec_k ), sf_b( vec_nk, vec_nk );
00421     static CylinderDomain cy( 8.0, vec_k, vec_k );
00422     static SphericalDomain sp( vec_c, 5.0 );
00423
00424     MeshDomain* base_domains[] = { &cr_to, &cr_ti, &cr_bo, &sf_t, &sf_b, &cy, &sp };
00425     const int NDOM             = sizeof( base_domains ) / sizeof( base_domains[0] );
00426
00427     int dim_array[NDOM] = { 1, 1, 1, 2, 2, 2, 2 };
00428
00429     //++ MESH & DOMAIN ++
00430
00431     mesh.read_vtk( filename.c_str(), err );
00432     MSQ_ERRZERO( err );
00433     DomainClassifier::classify_skin_geometrically( geom, &mesh, 0.001, base_domains, dim_array, NDOM, err );
00434     MSQ_ERRZERO( err );
00435     mesh.set_skin_flags( false, false, true, err );
00436     MSQ_ERRZERO( err );
00437
00438     return filename;
00439 }
00440
00441 std::string get_hex_3d_part_example( DomainClassifier& geom, MeshImpl& mesh, MsqError& err )
00442 {
00443     std::string filename = std::string( STRINGIFY( SRCDIR ) ) + "/hex3Dpart.vtk";
00444
00445     // 2D domains
00446
00447     const Vector3D vec_i( 1, 0, 0 ), vec_j( 0, 1, 0 ), vec_k( 0, 0, 1 );
00448     const Vector3D vec_ni( -1, 0, 0 ), vec_nj( 0, -1, 0 ), vec_nk( 0, 0, -1 );
00449
00450     const Vector3D vec_left( -11.5, 0, 0 ), vec_right( 11.5, 0, 0 );
00451     const Vector3D vec_top( 0, 5, 0 ), vec_bottom( 0, -5, 0 );
00452     const Vector3D vec_front( 0, 0, 5 ), vec_back( 0, 0, -5 );
00453
00454     // 1D domains
00455
00456     const Vector3D pt_top_front( 0, 5, 5 ), pt_top_back( 0, 5, -5 );
00457     const Vector3D pt_bottom_front( 0, -5, 5 ), pt_bottom_back( 0, -5, -5 );
00458
00459     const Vector3D pt_top_left( -11.5, 5, 0 ), pt_top_right( 11.5, 5, 0 );
00460     const Vector3D pt_bottom_left( -11.5, -5, 0 ), pt_bottom_right( 11.5, -5, 0 );
00461
00462     const Vector3D pt_left_front( -11.5, 0, 5 ), pt_left_back( -11.5, 0, -5 );
00463     const Vector3D pt_right_front( 11.5, 0, 5 ), pt_right_back( 11.5, 0, -5 );
00464
00465     const Vector3D cpt_top_left( -1.5, 5, 0 ), cpt_top_right( 1.5, 5, 0 );
00466     const Vector3D cpt_bottom_left( -1.5, -5, 0 ), cpt_bottom_right( 1.5, -5, 0 );
00467
00468     // 0D domains
00469
00470     const Vector3D pt_tlf( -11.5, 5, 5 ), pt_tlb( -11.5, 5, -5 );
00471     const Vector3D pt_trf( 11.5, 5, 5 ), pt_trb( 11.5, 5, -5 );
00472     const Vector3D pt_blf( -11.5, -5, 5 ), pt_blb( -11.5, -5, -5 );
00473     const Vector3D pt_brf( 11.5, -5, 5 ), pt_brb( 11.5, -5, -5 );
00474
00475     const Vector3D pt_c_tlf( -1.5, 5, 5 ), pt_c_tlb( -1.5, 5, -5 );
00476     const Vector3D pt_c_trf( 1.5, 5, 5 ), pt_c_trb( 1.5, 5, -5 );
00477     const Vector3D pt_c_blf( -1.5, -5, 5 ), pt_c_blb( -1.5, -5, -5 );
00478     const Vector3D pt_c_brf( 1.5, -5, 5 ), pt_c_brb( 1.5, -5, -5 );
00479
00480     static PointDomain p00( pt_tlf );
00481     static PointDomain p01( pt_tlb );
00482     static PointDomain p02( pt_trf );
00483     static PointDomain p03( pt_trb );
00484     static PointDomain p04( pt_blf );
00485     static PointDomain p05( pt_blb );
00486     static PointDomain p06( pt_brf );
00487     static PointDomain p07( pt_brb );
00488
00489     static PointDomain p08( pt_c_tlf );
00490     static PointDomain p09( pt_c_tlb );
00491     static PointDomain p10( pt_c_trf );
00492     static PointDomain p11( pt_c_trb );
00493     static PointDomain p12( pt_c_blf );
00494     static PointDomain p13( pt_c_blb );
00495     static PointDomain p14( pt_c_brf );
00496     static PointDomain p15( pt_c_brb );
00497
00498     static CircleDomain c00( pt_top_front, vec_k, 1.5 );
00499     static CircleDomain c01( pt_top_back, vec_k, 1.5 );
00500     static CircleDomain c02( pt_bottom_front, vec_k, 1.5 );
00501     static CircleDomain c03( pt_bottom_back, vec_k, 1.5 );
00502
00503     static LineDomain l00( cpt_top_left, vec_k );
00504     static LineDomain l01( cpt_top_right, vec_k );
00505     static LineDomain l02( cpt_bottom_left, vec_k );
00506     static LineDomain l03( cpt_bottom_right, vec_k );
00507
00508     static LineDomain l04( pt_top_front, vec_i );
00509     static LineDomain l05( pt_top_back, vec_i );
00510     static LineDomain l06( pt_bottom_front, vec_i );
00511     static LineDomain l07( pt_bottom_back, vec_i );
00512     static LineDomain l08( pt_top_left, vec_k );
00513     static LineDomain l09( pt_top_right, vec_k );
00514     static LineDomain l10( pt_bottom_left, vec_k );
00515     static LineDomain l11( pt_bottom_right, vec_k );
00516     static LineDomain l12( pt_left_front, vec_j );
00517     static LineDomain l13( pt_left_back, vec_j );
00518     static LineDomain l14( pt_right_front, vec_j );
00519     static LineDomain l15( pt_right_back, vec_j );
00520
00521     static CylinderDomain C00( 1.5, vec_k, vec_top, false );
00522     static CylinderDomain C01( 1.5, vec_k, vec_bottom, false );
00523     static PlanarDomain P00( vec_ni, vec_left );
00524     static PlanarDomain P01( vec_i, vec_right );
00525     static PlanarDomain P02( vec_j, vec_top );
00526     static PlanarDomain P03( vec_nj, vec_bottom );
00527     static PlanarDomain P04( vec_k, vec_front );
00528     static PlanarDomain P05( vec_nk, vec_back );
00529
00530     const int NDOM                 = 44;
00531     MeshDomain* base_domains[NDOM] = { &p00, &p01, &p02, &p03, &p04, &p05, &p06, &p07,
00532
00533                                        &p08, &p09, &p10, &p11, &p12, &p13, &p14, &p15,
00534
00535                                        &c00, &c01, &c02, &c03,
00536
00537                                        &l00, &l01, &l02, &l03,
00538
00539                                        &l04, &l05, &l06, &l07, &l08, &l09, &l10, &l11, &l12, &l13, &l14, &l15,
00540
00541                                        &C00, &C01, &P00, &P01, &P02, &P03, &P04, &P05 };
00542
00543     int dim_array[NDOM] = { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 1, 1, 1, 1, 1,
00544                             1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 2, 2, 2, 2, 2, 2, 2, 2 };
00545
00546     //++ MESH & DOMAIN ++
00547
00548     mesh.read_vtk( filename.c_str(), err );
00549     MSQ_ERRZERO( err );
00550     DomainClassifier::classify_skin_geometrically( geom, &mesh, 0.1, base_domains, dim_array, NDOM, err );
00551     MSQ_ERRZERO( err );
00552     mesh.set_skin_flags( false, false, true, err );
00553     MSQ_ERRZERO( err );
00554
00555     return filename;
00556 }
