MOAB: Mesh Oriented datABase
(version 5.3.1)
Implement some of the examples from N. Voshell. More...
#include "TestUtil.hpp"
#include "ShapeImprover.hpp"
#include "UntangleWrapper.hpp"
#include "MeshImpl.hpp"
#include "MsqError.hpp"
#include "QualityAssessor.hpp"
#include "PlanarDomain.hpp"
#include "CylinderDomain.hpp"
#include "SphericalDomain.hpp"
#include "MeshDomain1D.hpp"
#include "DomainClassifier.hpp"
#include "HexLagrangeShape.hpp"
#include <iostream>
#include <string>
#include <cstdlib>
Definition in file voshell.cpp.
typedef std::string( * example_setup_t)(DomainClassifier &geom, MeshImpl &mesh, MsqError &err) |
Definition at line 69 of file voshell.cpp.
std::string get_cut_cube_example | ( | DomainClassifier & | geom, |
MeshImpl & | mesh, | ||
MsqError & | err | ||
Definition at line 327 of file voshell.cpp.
References MBMesquite::DomainClassifier::classify_skin_geometrically(), filename, MSQ_ERRZERO, MBMesquite::MeshImpl::read_vtk(), MBMesquite::MeshImpl::set_skin_flags(), and STRINGIFY.
{ std::string filename = std::string( STRINGIFY( SRCDIR ) ) + "/cutCube.vtk"; const Vector3D vec_i( 5, 0, 0 ), vec_ni( -5, 0, 0 ); const Vector3D vec_j( 0, 5, 0 ), vec_nj( 0, -5, 0 ); const Vector3D vec_k( 0, 0, 5 ), vec_nk( 0, 0, -5 ); const Vector3D vec_tfl( 5, -5, 5 ), vec_tfr( 5, 5, 5 ); const Vector3D vec_tbl( -5, -5, 5 ), vec_tbr( -5, 5, 5 ); const Vector3D vec_bfl( 5, -5, -5 ), vec_bfr( 5, 5, -5 ); const Vector3D vec_bbl( -5, -5, -5 ), vec_bbr( -5, 5, -5 ); const Vector3D vec_ts( 5, 0, 2 ), vec_bs( 5, 0, -2 ); //++ 0D domains ++ static PointDomain pt_tfl( vec_tfl ), pt_tfr( vec_tfr ); static PointDomain pt_tbl( vec_tbl ), pt_tbr( vec_tbr ); static PointDomain pt_bfl( vec_bfl ), pt_bfr( vec_bfr ); static PointDomain pt_bbl( vec_bbl ), pt_bbr( vec_bbr ); //++ 1D domains ++ // top square static LineDomain ln_tf( vec_tfl, vec_j ), lin_tb( vec_tbr, vec_nj ); static LineDomain ln_tl( vec_tfl, vec_ni ), lin_tr( vec_tbr, vec_i ); // bottom square static LineDomain ln_bf( vec_bfl, vec_j ), lin_bb( vec_bbr, vec_nj ); static LineDomain ln_bl( vec_bfl, vec_ni ), lin_br( vec_bbr, vec_i ); // sides static LineDomain ln_lf( vec_bfl, vec_k ), lin_rf( vec_bfr, vec_k ); static LineDomain ln_lb( vec_bbl, vec_k ), lin_rb( vec_bbr, vec_k ); // top sphere static CircleDomain cr_tf( vec_ts, vec_i, 1.0 ), cr_tn( vec_ts, vec_k, 1.0 ); // bottom sphere static CircleDomain cr_bf( vec_bs, vec_i, 1.0 ), cr_bn( vec_bs, vec_k, 1.0 ); //++ 2D domains ++ // cube static PlanarDomain sf_i( vec_i, vec_i ), sf_ni( vec_ni, vec_ni ); static PlanarDomain sf_j( vec_j, vec_j ), sf_nj( vec_nj, vec_nj ); static PlanarDomain sf_k( vec_k, vec_k ), sf_nk( vec_nk, vec_nk ); // cut static CylinderDomain cy( 1.0, vec_k, vec_bs ); static SphericalDomain sp_t( vec_ts, 1.0 ), sp_b( vec_bs, 1.0 ); MeshDomain* base_domains[] = { &pt_tfl, &pt_tfr, &pt_tbl, &pt_tbr, &pt_bfl, &pt_bfr, &pt_bbl, &pt_bbr, &ln_tf, &lin_tb, &ln_tl, &lin_tr, &ln_bf, &lin_bb, &ln_bl, &lin_br, &ln_lf, &lin_rf, &ln_lb, &lin_rb, &cr_tf, &cr_tn, &cr_bf, &cr_bn, &sf_i, &sf_ni, &sf_j, &sf_nj, &sf_k, &sf_nk, &cy, &sp_t, &sp_b }; const int NDOM = sizeof( base_domains ) / sizeof( base_domains[0] ); int dim_array[NDOM] = { 0, 0, 0, 0, 0, 0, 0, 0, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 2, 2, 2, 2, 2, 2, 2, 2, 2 }; //++ MESH & DOMAIN ++ mesh.read_vtk( filename.c_str(), err ); MSQ_ERRZERO( err ); DomainClassifier::classify_skin_geometrically( geom, &mesh, 0.1, base_domains, dim_array, NDOM, err ); MSQ_ERRZERO( err ); mesh.set_skin_flags( false, false, true, err ); MSQ_ERRZERO( err ); return filename; }
std::string get_hex_3d_part_example | ( | DomainClassifier & | geom, |
Definition at line 438 of file voshell.cpp.
References MBMesquite::DomainClassifier::classify_skin_geometrically(), filename, l11(), l12(), MSQ_ERRZERO, MBMesquite::MeshImpl::read_vtk(), MBMesquite::MeshImpl::set_skin_flags(), and STRINGIFY.
{ std::string filename = std::string( STRINGIFY( SRCDIR ) ) + "/hex3Dpart.vtk"; // 2D domains const Vector3D vec_i( 1, 0, 0 ), vec_j( 0, 1, 0 ), vec_k( 0, 0, 1 ); const Vector3D vec_ni( -1, 0, 0 ), vec_nj( 0, -1, 0 ), vec_nk( 0, 0, -1 ); const Vector3D vec_left( -11.5, 0, 0 ), vec_right( 11.5, 0, 0 ); const Vector3D vec_top( 0, 5, 0 ), vec_bottom( 0, -5, 0 ); const Vector3D vec_front( 0, 0, 5 ), vec_back( 0, 0, -5 ); // 1D domains const Vector3D pt_top_front( 0, 5, 5 ), pt_top_back( 0, 5, -5 ); const Vector3D pt_bottom_front( 0, -5, 5 ), pt_bottom_back( 0, -5, -5 ); const Vector3D pt_top_left( -11.5, 5, 0 ), pt_top_right( 11.5, 5, 0 ); const Vector3D pt_bottom_left( -11.5, -5, 0 ), pt_bottom_right( 11.5, -5, 0 ); const Vector3D pt_left_front( -11.5, 0, 5 ), pt_left_back( -11.5, 0, -5 ); const Vector3D pt_right_front( 11.5, 0, 5 ), pt_right_back( 11.5, 0, -5 ); const Vector3D cpt_top_left( -1.5, 5, 0 ), cpt_top_right( 1.5, 5, 0 ); const Vector3D cpt_bottom_left( -1.5, -5, 0 ), cpt_bottom_right( 1.5, -5, 0 ); // 0D domains const Vector3D pt_tlf( -11.5, 5, 5 ), pt_tlb( -11.5, 5, -5 ); const Vector3D pt_trf( 11.5, 5, 5 ), pt_trb( 11.5, 5, -5 ); const Vector3D pt_blf( -11.5, -5, 5 ), pt_blb( -11.5, -5, -5 ); const Vector3D pt_brf( 11.5, -5, 5 ), pt_brb( 11.5, -5, -5 ); const Vector3D pt_c_tlf( -1.5, 5, 5 ), pt_c_tlb( -1.5, 5, -5 ); const Vector3D pt_c_trf( 1.5, 5, 5 ), pt_c_trb( 1.5, 5, -5 ); const Vector3D pt_c_blf( -1.5, -5, 5 ), pt_c_blb( -1.5, -5, -5 ); const Vector3D pt_c_brf( 1.5, -5, 5 ), pt_c_brb( 1.5, -5, -5 ); static PointDomain p00( pt_tlf ); static PointDomain p01( pt_tlb ); static PointDomain p02( pt_trf ); static PointDomain p03( pt_trb ); static PointDomain p04( pt_blf ); static PointDomain p05( pt_blb ); static PointDomain p06( pt_brf ); static PointDomain p07( pt_brb ); static PointDomain p08( pt_c_tlf ); static PointDomain p09( pt_c_tlb ); static PointDomain p10( pt_c_trf ); static PointDomain p11( pt_c_trb ); static PointDomain p12( pt_c_blf ); static PointDomain p13( pt_c_blb ); static PointDomain p14( pt_c_brf ); static PointDomain p15( pt_c_brb ); static CircleDomain c00( pt_top_front, vec_k, 1.5 ); static CircleDomain c01( pt_top_back, vec_k, 1.5 ); static CircleDomain c02( pt_bottom_front, vec_k, 1.5 ); static CircleDomain c03( pt_bottom_back, vec_k, 1.5 ); static LineDomain l00( cpt_top_left, vec_k ); static LineDomain l01( cpt_top_right, vec_k ); static LineDomain l02( cpt_bottom_left, vec_k ); static LineDomain l03( cpt_bottom_right, vec_k ); static LineDomain l04( pt_top_front, vec_i ); static LineDomain l05( pt_top_back, vec_i ); static LineDomain l06( pt_bottom_front, vec_i ); static LineDomain l07( pt_bottom_back, vec_i ); static LineDomain l08( pt_top_left, vec_k ); static LineDomain l09( pt_top_right, vec_k ); static LineDomain l10( pt_bottom_left, vec_k ); static LineDomain l11( pt_bottom_right, vec_k ); static LineDomain l12( pt_left_front, vec_j ); static LineDomain l13( pt_left_back, vec_j ); static LineDomain l14( pt_right_front, vec_j ); static LineDomain l15( pt_right_back, vec_j ); static CylinderDomain C00( 1.5, vec_k, vec_top, false ); static CylinderDomain C01( 1.5, vec_k, vec_bottom, false ); static PlanarDomain P00( vec_ni, vec_left ); static PlanarDomain P01( vec_i, vec_right ); static PlanarDomain P02( vec_j, vec_top ); static PlanarDomain P03( vec_nj, vec_bottom ); static PlanarDomain P04( vec_k, vec_front ); static PlanarDomain P05( vec_nk, vec_back ); const int NDOM = 44; MeshDomain* base_domains[NDOM] = { &p00, &p01, &p02, &p03, &p04, &p05, &p06, &p07, &p08, &p09, &p10, &p11, &p12, &p13, &p14, &p15, &c00, &c01, &c02, &c03, &l00, &l01, &l02, &l03, &l04, &l05, &l06, &l07, &l08, &l09, &l10, &l11, &l12, &l13, &l14, &l15, &C00, &C01, &P00, &P01, &P02, &P03, &P04, &P05 }; int dim_array[NDOM] = { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 2, 2, 2, 2, 2, 2, 2, 2 }; //++ MESH & DOMAIN ++ mesh.read_vtk( filename.c_str(), err ); MSQ_ERRZERO( err ); DomainClassifier::classify_skin_geometrically( geom, &mesh, 0.1, base_domains, dim_array, NDOM, err ); MSQ_ERRZERO( err ); mesh.set_skin_flags( false, false, true, err ); MSQ_ERRZERO( err ); return filename; }
std::string get_homogenious_example | ( | DomainClassifier & | geom, |
Definition at line 224 of file voshell.cpp.
References filename, geom, get_planar_example(), mesh, MSQ_CHKERR, and STRINGIFY.
{ std::string filename = std::string( STRINGIFY( SRCDIR ) ) + "/homogeneousPart.vtk"; get_planar_example( filename.c_str(), geom, mesh, err );MSQ_CHKERR( err ); return filename; }
std::string get_part_example_quad | ( | DomainClassifier & | geom, |
Definition at line 238 of file voshell.cpp.
{ std::string filename = std::string( STRINGIFY( SRCDIR ) ) + "/quadPart.vtk"; get_planar_example( filename.c_str(), geom, mesh, err );MSQ_CHKERR( err ); return filename; }
std::string get_part_example_tri | ( | DomainClassifier & | geom, |
Definition at line 231 of file voshell.cpp.
{ std::string filename = std::string( STRINGIFY( SRCDIR ) ) + "/triPart.vtk"; get_planar_example( filename.c_str(), geom, mesh, err );MSQ_CHKERR( err ); return filename; }
void get_planar_example | ( | const char * | filename, |
DomainClassifier & | geom, | ||
Definition at line 213 of file voshell.cpp.
References MBMesquite::DomainClassifier::classify_by_handle(), MBMesquite::MeshImpl::get_all_elements(), MBMesquite::MeshImpl::get_all_vertices(), MBMesquite::MeshImpl::mark_skin_fixed(), MSQ_ERRRTN, MBMesquite::MeshImpl::read_vtk(), MBMesquite::PlanarDomain::XY, and z.
Referenced by get_homogenious_example(), get_part_example_quad(), and get_part_example_tri().
{ static PlanarDomain z( PlanarDomain::XY ); mesh.read_vtk( filename, err );MSQ_ERRRTN( err ); mesh.mark_skin_fixed( err );MSQ_ERRRTN( err ); DomainClassifier::DomainSet set( &z ); mesh.get_all_vertices( set.vertices, err );MSQ_ERRRTN( err ); mesh.get_all_elements( set.elements, err );MSQ_ERRRTN( err ); DomainClassifier::classify_by_handle( geom, &mesh, &set, 1, err );MSQ_ERRRTN( err ); }
std::string get_sphere_cube_example | ( | DomainClassifier & | geom, |
Definition at line 245 of file voshell.cpp.
{ std::string filename = std::string( STRINGIFY( SRCDIR ) ) + "/sphereCube.vtk"; const Vector3D vec_i( 5, 0, 0 ), vec_ni( -5, 0, 0 ); const Vector3D vec_j( 0, 5, 0 ), vec_nj( 0, -5, 0 ); const Vector3D vec_k( 0, 0, 5 ), vec_nk( 0, 0, -5 ); const Vector3D vec_tfl( 5, -5, 5 ), vec_tfr( 5, 5, 5 ); const Vector3D vec_tbl( -5, -5, 5 ), vec_tbr( -5, 5, 5 ); const Vector3D vec_bfl( 5, -5, -5 ), vec_bfr( 5, 5, -5 ); const Vector3D vec_bbl( -5, -5, -5 ), vec_bbr( -5, 5, -5 ); const Vector3D vec_ts( 5, 0, 2 ), vec_bs( 5, 0, -2 ); //++ 0D domains ++ static PointDomain pt_tfl( vec_tfl ), pt_tfr( vec_tfr ); static PointDomain pt_tbl( vec_tbl ), pt_tbr( vec_tbr ); static PointDomain pt_bfl( vec_bfl ), pt_bfr( vec_bfr ); static PointDomain pt_bbl( vec_bbl ), pt_bbr( vec_bbr ); //++ 1D domains ++ // top square static LineDomain ln_tf( vec_tfl, vec_j ), lin_tb( vec_tbr, vec_nj ); static LineDomain ln_tl( vec_tfl, vec_ni ), lin_tr( vec_tbr, vec_i ); // bottom square static LineDomain ln_bf( vec_bfl, vec_j ), lin_bb( vec_bbr, vec_nj ); static LineDomain ln_bl( vec_bfl, vec_ni ), lin_br( vec_bbr, vec_i ); // sides static LineDomain ln_lf( vec_bfl, vec_k ), lin_rf( vec_bfr, vec_k ); static LineDomain ln_lb( vec_bbl, vec_k ), lin_rb( vec_bbr, vec_k ); // top sphere // CircleDomain cr_tf(vec_ts,vec_i,1.0), cr_tn(vec_ts,vec_k,1.0); // bottom sphere // CircleDomain cr_bf(vec_bs,vec_i,1.0), cr_bn(vec_bs,vec_k,1.0); static CircleDomain cr_ct( vec_k, vec_k, 1.0 ); //++ 2D domains ++ // cube static PlanarDomain sf_i( vec_i, vec_i ), sf_ni( vec_ni, vec_ni ); static PlanarDomain sf_j( vec_j, vec_j ), sf_nj( vec_nj, vec_nj ); static PlanarDomain sf_k( vec_k, vec_k ), sf_nk( vec_nk, vec_nk ); // cut // CylinderDomain cy(1.0,vec_k,vec_bs); static SphericalDomain sp_t( vec_k, 1.0 ); //, sp_b(vec_bs,1.0); MeshDomain* base_domains[] = { &pt_tfl, &pt_tfr, &pt_tbl, &pt_tbr, &pt_bfl, &pt_bfr, &pt_bbl, &pt_bbr, &ln_tf, &lin_tb, &ln_tl, &lin_tr, &ln_bf, &lin_bb, &ln_bl, &lin_br, &ln_lf, &lin_rf, &ln_lb, &lin_rb, // &cr_tf, &cr_tn, // &cr_bf, &cr_bn, &cr_ct, &sf_i, &sf_ni, &sf_j, &sf_nj, &sf_k, &sf_nk, //&cy, &sp_t //, &sp_b }; const int NDOM = sizeof( base_domains ) / sizeof( base_domains[0] ); int dim_array[NDOM] = { 0, 0, 0, 0, 0, 0, 0, 0, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, // 1,1,1, 2, 2, 2, 2, 2, 2, 2 //,2,2 }; //++ MESH & DOMAIN ++ mesh.read_vtk( filename.c_str(), err ); MSQ_ERRZERO( err ); DomainClassifier::classify_skin_geometrically( geom, &mesh, 0.1, base_domains, dim_array, NDOM, err ); MSQ_ERRZERO( err ); mesh.set_skin_flags( false, false, true, err ); MSQ_ERRZERO( err ); return filename; }
std::string get_sphere_cylinder_example | ( | DomainClassifier & | geom, |
Definition at line 399 of file voshell.cpp.
{ std::string filename = std::string( STRINGIFY( SRCDIR ) ) + "/sphereCylinder_1194_inv.vtk"; const Vector3D vec_k( 0, 0, 8 ), vec_nk( 0, 0, -8 ); const Vector3D vec_c( 0, 0, 5 ); //++ 0D domains ++ //++ 1D domains ++ // top circle static CircleDomain cr_to( vec_k, vec_k, 8.0 ), cr_ti( vec_k, vec_k, 4.0 ); // bottom circle static CircleDomain cr_bo( vec_nk, vec_nk, 8.0 ); //++ 2D domains ++ static PlanarDomain sf_t( vec_k, vec_k ), sf_b( vec_nk, vec_nk ); static CylinderDomain cy( 8.0, vec_k, vec_k ); static SphericalDomain sp( vec_c, 5.0 ); MeshDomain* base_domains[] = { &cr_to, &cr_ti, &cr_bo, &sf_t, &sf_b, &cy, &sp }; const int NDOM = sizeof( base_domains ) / sizeof( base_domains[0] ); int dim_array[NDOM] = { 1, 1, 1, 2, 2, 2, 2 }; //++ MESH & DOMAIN ++ mesh.read_vtk( filename.c_str(), err ); MSQ_ERRZERO( err ); DomainClassifier::classify_skin_geometrically( geom, &mesh, 0.001, base_domains, dim_array, NDOM, err ); MSQ_ERRZERO( err ); mesh.set_skin_flags( false, false, true, err ); MSQ_ERRZERO( err ); return filename; }
int main | ( | int | argc, |
char * | argv[] | ||
Definition at line 108 of file voshell.cpp.
References examples, num_examples, run_example(), and usage.
{ bool write_final_meshes = false; std::vector< Example > list; for( int i = 1; i < argc; ++i ) { if( argv[i][0] != '-' ) { std::cerr << "Invalid argument: \"" << argv[i] << '"' << std::endl; usage( argv[0] ); } for( int j = 1; argv[i][j]; ++j ) { if( argv[i][j] == 'w' ) { write_final_meshes = true; } else { int idx; for( idx = 0; idx < num_examples; ++idx ) if( examples[idx].flag == argv[i][j] ) break; if( idx == num_examples ) { if( argv[i][j] == 'h' ) usage( argv[0], true ); else { std::cerr << "Invalid flag: '" << argv[i][j] << "'" << std::endl; usage( argv[0] ); } } list.push_back( examples[idx] ); } } } const Example* exlist; int exlistlen; if( list.empty() ) { exlist = examples; exlistlen = num_examples; } else { exlist = &list[0]; exlistlen = list.size(); } int result = 0; for( int i = 0; i < exlistlen; ++i ) result += run_example( exlist[i], write_final_meshes ); return result; }
int run_example | ( | const Example & | e, |
bool | write_output_file | ||
Definition at line 162 of file voshell.cpp.
References Example::desc, Example::func, MBMesquite::QualityAssessor::invalid_elements(), mesh, MSQ_CHKERR, MBMesquite::Wrapper::quality_assessor(), MBMesquite::IQInterface::run_instructions(), MBMesquite::Settings::set_mapping_function(), MBMesquite::Settings::set_slaved_ho_node_mode(), MBMesquite::ShapeImprover::set_vertex_movement_limit_factor(), MBMesquite::Settings::SLAVE_NONE, and MBMesquite::MeshImpl::write_vtk().
Referenced by main().
{ MsqPrintError err( std::cerr ); MeshImpl mesh; DomainClassifier domain; HexLagrangeShape hex27; std::cout << std::endl << "--------------------------------------------------------------------" << std::endl << e.desc << std::endl << "--------------------------------------------------------------------" << std::endl; std::string name = e.func( domain, mesh, err ); if( MSQ_CHKERR( err ) ) return 2; std::cout << "Loaded mesh from: " << name << std::endl; UntangleWrapper untangler; untangler.set_slaved_ho_node_mode( Settings::SLAVE_NONE ); untangler.set_mapping_function( &hex27 ); MeshDomainAssoc mesh_and_domain = MeshDomainAssoc( &mesh, &domain, false, true ); untangler.run_instructions( &mesh_and_domain, err ); if( MSQ_CHKERR( err ) ) return 1; ShapeImprover smoother; smoother.set_slaved_ho_node_mode( Settings::SLAVE_NONE ); smoother.set_mapping_function( &hex27 ); smoother.set_vertex_movement_limit_factor( 0.05 ); smoother.run_instructions( &mesh_and_domain, err ); if( MSQ_CHKERR( err ) ) return 1; if( write_output_file ) { size_t idx = name.find( ".vtk" ); if( idx != std::string::npos ) { std::string newname( name.substr( 0, idx ) ); newname += ".out"; newname += name.substr( idx ); name.swap( newname ); } else { name += ".out"; } mesh.write_vtk( name.c_str(), err );MSQ_CHKERR( err ); std::cout << "Write mesh to file: " << name << std::endl; } return smoother.quality_assessor().invalid_elements(); }
void usage | ( | const char * | argv0, |
bool | help = false |
Definition at line 88 of file voshell.cpp.
References examples, help(), and num_examples.
{ std::cerr << "Usage: " << argv0 << "[-w] "; for( int i = 0; i < num_examples; ++i ) std::cerr << " [-" << examples[i].flag << "]"; std::cerr << std::endl; if( !help ) { std::cerr << " " << argv0 << " -h" << std::endl; std::exit( 1 ); } std::cerr << " -w : Write final meshes to VTK file" << std::endl; std::cerr << "NOTE: If no options are specified, all examples will be run" << std::endl; for( int i = 0; i < num_examples; ++i ) std::cerr << " -" << examples[i].flag << " : Run " << examples[i].desc << std::endl; std::cerr << std::endl; std::exit( 0 ); }
{ { 'H', &get_homogenious_example, "homogenous mesh (curvey surface) example" }, { 't', &get_part_example_tri, "part mesh with triangles" }, { 'q', &get_part_example_quad, "part mesh with quads" }, { 'c', &get_sphere_cube_example, "cube with subtracted hemisphere" }, { 'l', &get_cut_cube_example, "cube with slot removed" }, { 's', &get_sphere_cylinder_example, "cylinder with subtracted sphere" }, { 'x', &get_hex_3d_part_example, "rectangular prism with two cylindrical slots" } }
Definition at line 79 of file voshell.cpp.
const int num_examples = sizeof( examples ) / sizeof( examples[0] ) |
Definition at line 86 of file voshell.cpp.
